Name | Part Type | PCB Decal | Value |
BEAD6009 | FB_/_BLM15PX221SN1 | BEAD0402 | |
CON2601 | CON_/_6_/_CPL6506-0130ESZ | BAT/6P/SMD/P1.2/CPL6506-0130ESZ/SMK | CON / 6 / CPL6506-0130ESZ |
CON3301 | CAR_KIT_/_MM8130-2600 | MM8130-2600 | Car_Kit / MM8130-2600 |
CON3401 | CAR_KIT_/_MM8130-2600 | MM8130-2600 | Car_Kit / MM8130-2600 |
CON3603 | CON_/_MM5829-2700RJ4 | COAXIAL/SMD/MM5829-2700B | CON / MM5829-2700RJ4 |
CON3604 | CON_/_MM5829-2700RJ4 | COAXIAL/SMD/MM5829-2700B | CON / MM5829-2700RJ4 |
CON4101 | CON_/_12_/_TA-M017-012-07-811 | MICROSD/8P/SMD/TA-M017-012-07-811 | CON / 12 / TA-M017-012-07-811 |
CON5001 | CAR_KIT_/_MM8130-2600 | MM8130-2600 | Car_Kit / MM8130-2600 |
CON5201 | CON_/_30_/_24-5804-030-000-829+ | CON15X2/SMD/P0.4/F/24-5804-030-000-829+ | CON / 30 / 24-5804-030-000-829+ |
CON6001 | CON_/_5_/_EJ-36952-10-GP | AUDIOJACK/5P/DIP/EJ-36952-10-GP | CON / 5 / EJ-36952-10-GP |
CON6002 | CON_/_30_/_24-5804-030-000-829+ | CON15X2/SMD/P0.4/F/24-5804-030-000-829+ | CON / 30 / 24-5804-030-000-829+ |
CON6201 | CON_/_10_/_AXE510127 | CON5X2/SMD/P0.4/F/AXE510127 | CON / 10 / AXE510127 |
CON6203 | TMP_093700 | CON17X2/SMD/F/P0.4/24-5804-034-000-829 | CON / 34 / 24-5804-034-000-829+ |
CON6301 | CON_/_30_/_24-5804-030-000-829+ | CON15X2/SMD/P0.4/F/24-5804-030-000-829+ | CON / 30 / 24-5804-030-000-829+ |
CON6303 | CON_/_30_/_24-5804-030-000-829+ | CON15X2/SMD/P0.4/F/24-5804-030-000-829+ | CON / 30 / 24-5804-030-000-829+ |
CON6401 | CON_/_10_/_AXE510127 | CON5X2/SMD/P0.4/F/AXE510127 | CON / 10 / AXE510127 |
CON6601 | CON_/_5_/_KEIRAKU_KIU90511S1R | MICROUSB/5P/SMD/P0.65/R/KIU90511S1R | CON / 5 / KEIRAKU KIU90511S1R |
CON6701 | CON_/_10_/_SCGD1B0314 | SIM/10P/SMD/SCGD1B0307 | CON / 10 / SCGD1B0314 |
CON6702 | CON_/_10_/_SCGD1B0314 | SIM/10P/SMD/SCGD1B0307 | CON / 10 / SCGD1B0314 |
CON6703 | CON_/_10_/_AXE510127 | CON5X2/SMD/P0.4/F/AXE510127 | CON / 10 / AXE510127 |
CON6705 | CON_/_24_/_WP7A-S024VA1 | CON12X2/P0.4/SMD/F/WP7A-S024VA1/JAE | CON / 24 / WP7A-S024VA1 |
CON6801 | VIB_/_3_/_Z3OC1T8219731 | VIBRATOR/3P/SMD/Z30C1T8219731 | VIB / 3 / Z3OC1T8219731 |
CON9001 | CON_/_40_/_AXT640124 | CON20X2/SMD/M/AXT640124/FPC | CON / 40 / AXT640124 |
D2601 | D_/_RB160M-60 | RB160M-30-EVB | D / RB160M-60 |
D6401 | LED_/_IR83-01C-L491-TR8 | LED/SMD/IR83-01C | LED / IR83-01C-L491-TR8 / NC |
D6601 | ESD_/_AZ4514-01F | DFN1610P2E/SMD/AZ4514-01F | ESD / AZ4514-01F |
EMI6205 | EMI_/_DLM0NSN900HY2 | L/CHOKE/SMD/DLM0NSN900HY2 | EMI / DLM0NSN900HY2 |
EMI6310 | EMI_/_MCF08062G900-T | FILTER/4P/SMD/MCF0806 | |
EMI6601 | EMI_/_DLP11RN450UL2 | L/CHOKE/SMD/DLP11RN450UL2 | EMI / DLP11RN450UL2 |
ESD6602 | ESD_/_LXES1UBAA1-096 | SOD882/SMD/PESD5V0S1BL | ESD / LXES1UBAA1-096 |
ESD6605 | ESD_/_AZ5825-01F | VR0402 | ESD / AZ5825-01F / NC |
ESD6606 | ESD_/_AZ5315-02F | ESD/SMD/AZ5315-02F | ESD / AZ5315-02F |
ESD6716 | ESD_/_ESD5451NKM | SOD882/SMD/PESD5V0S1BL | ESD / ESD5451NKM |
FB2201 | FB_/_BLM15HG102SN1 | BEAD0402 | FB / BLM15HG102SN1 |
L3701 | L_/_1_/_UH_/_2520 | L/IND/SMD/2520 | |
LED2601 | LED_/_LUWF8DN-SGSI-RS | FLASH_LED/LUW_F8DN | LED / LUWF8DN-SGSI-RS |
MIC1 | MIC_/_SPH1642HT5H-1 | MODULE/SMD/SPH1642HT5H-1 | |
NTC3201 | NTC_/_NCP03WF104F05RL_/_0201 | R0201 | NTC / NCP03WF104F05RL / 0201 |
NTC6401 | NTC_/_NTCG104EF104F_/_0402 | R0402 | NTC / NTCG104EF104F / 0402 |
PL2001 | PL_/_0.47_/_UH_/_2520 | L/IND/SMD/CIGT252012LMR47MNE | PL / 0.47 / uH / 2520 |
PL2002 | PL_/_0.47_/_UH_/_2520 | L/IND/SMD/CIGT252012LMR47MNE | PL / 0.47 / uH / 2520 |
PL2003 | PL_/_1_/_UH_/_2520 | L/IND/SMD/MEMK2520 | PL / 1 / uH / 2520 |
PL2004 | PL_/_1_/_UH_/_2520 | L/IND/SMD/MEMK2520 | PL / 1 / uH / 2520 |
PL2005 | PL_/_1_/_UH_/_2520 | L/IND/SMD/MEMK2520 | PL / 1 / uH / 2520 |
PL2601 | PL_/_1_/_UH_/_2520 | L/IND/SMD/DFE252012F/TOKO | PL / 1 / uH / 2520 |
PL2602 | PL_/_1_/_UH_/_2520 | L/IND/SMD/DFE252012F/TOKO | PL / 1 / uH / 2520 |
PL2603 | PL_/_4.7_/_UH_/_2016 | L/IND/SMD/VLS201610E | PL / 4.7 / uH / 2016 |
PL2604 | PL_/_4.7_/_UH_/_2016 | L/IND/SMD/VLS201610E | PL / 4.7 / uH / 2016 |
Q6402 | Q_/_RUM003N02GT2L | VMT3/SMD/RUM003N02 | Q / RUM003N02GT2L |
REC6002 | REC_/_2403_260_00031_ | RECEIVER/2P/SMD/NPR0612A-J-01/MTK0052 | ? |
SC9184 | SC_/_SCC0802B | SHIELD_CAN_CLIP/3P/SMD/PTV3121N | SC / SCC0802B |
SC9194 | SC_/_SCC0802B | SHIELD_CAN_CLIP/3P/SMD/PTV3121N | SC / SCC0802B |
SC9196 | SC_/_RFC1207B | CABLE_CLIP/3P/SMD/PCV1003 | SC / RFC1207B |
SC9197 | SC_/_RFC1409B | RF-CABLE-CLIP/3P/SMD/P1201Y | |
SC9198 | SC_/_RFC1409B | RF-CABLE-CLIP/3P/SMD/P1201Y | |
SC9199 | SC_/_RFC1207B | CABLE_CLIP/3P/SMD/PCV1003 | SC / RFC1207B |
SW6701 | SW_/_4_/_SKSMAFE010 | KEYPAD/4P/SMD/SKSMAFE010 | SW / 4 / SKSMAFE010 |
U1001 | U_/_MT6739-DISCRETE-LP3-SBS | MT6739/VFBGA491/P0.4/B0.25/11.8X11 |
U2001 | U_/_MT6357V/A | MT6357/VFBGA209/P0.4/B0.25/7.0X6.6 |
U2601 | U_/_RT4505 | WLCSP9/SMD/P0.4/B0.25/RT4505 | U / RT4505 |
U2602 | U_/_RT9458WSC | WLCSP20/P0.4/B0.25/RT9458 | RT9458 |
U2603 | U_/_RT4531WSC | WLCSP9/P0.4/B0.25/RT4531 | U / RT4531WSC |
U2604 | U_/_RT4801A-50WSC | WLCSP15/P0.4/B0.25/RT4801A | U / RT4801A-50WSC |
U2605 | U_/_RT9081AGQZA | DFN6/SMD/P0.4/RT9081A | |
U3101 | U_/_MT6177MV/BCA-H | MT6173/VFBGA120/P0.4/B0.25/5.0X4.6 |
U3202 | PA_/_QM56022 | SKY77643 | |
U3203 | BPF_/_FI_168B1915FX-TXM | FILTER/SMD/DEA160915BT-1303B1MT | |
U3204 | FBAR_/_F6HH2G350EH71 | FILTER/5P/SMD/F6HH2G350EH71 | |
U3205 | SAW_/_ACPF-8041 | ACPF-8041/SMD | |
U3301 | TXM_/_RF5216 | SKY77910 | |
U3302 | DPX_/_D5DA737M5K2H2 | SAW/8P/SMD/SAYEY1G95GA0F0A | <Value> |
U3303 | SPDT_/_RF1630 | RF1630 | RF1630 |
U3304 | DPX_/_D5FC788M0K3ND | SAW/8P/SMD/SAYEY1G95GA0F0A | |
U3305 | DPX_/_D6HQ2G655DP02 | SAW/8P/SMD/SAYEY1G95GA0F0A | |
U3306 | DPX_/_D6DA2G132K2D4 | SAW/8P/SMD/SAYEY1G95GA0F0A | |
U3307 | DPX_/_D6DA2G140K2A4 | SAW/8P/SMD/SAYEY1G95GA0F0A | |
U3308 | DPX_/_D6DA1G842K2C4 | SAW/8P/SMD/SAYEY1G95GA0F0A | |
U3309 | DPX_/_D5DA876M5K2P6 | SAW/8P/SMD/SAYEY1G95GA0F0A | |
U3310 | DPX_/_D5DA942M5K2S2 | SAW/8P/SMD/SAYEY1G95GA0F0A | |
U3311 | LPF_/_FI_168B1888GL-TXM | FILTER/SMD/DEA160915BT-1303B1MT | LPF / FI 168B1888GL-TXM |
U3312 | SPDT_/_RF1630 | RF1630 | RF1630 |
U3313 | DPX_/_D5FC847M0K3NE | SAW/8P/SMD/SAYEY1G95GA0F0A | |
U3314 | DPX_/_ACMD6125 | ACMD-6125/SMD | <Value> |
U3315 | LPF_/_FI_105L0767F8 | FILTER/6P/SMD/1005LPF/TDK | |
U3316 | DPX_/_TQQ1013 | DUPLEXER/SMD/TQQ1013 | DPX / TQQ1013 |
U3317 | LPF_/_FI_105L0829GZ | FILTER/6P/SMD/1005LPF/TDK | |
U3401 | ASM_/_SKY13563-670LF | SKY13563 | |
U3402 | SAW_/_F6QA2G140M2AM | SAWFILTER/5P/SMD/SAFFB2G14AA0F0A |
U3403 | SAW_/_F6HQ2G593AP31 | FILTER/SMD/8P/F6HQ2G593AP31 | |
U3404 | SAW_/_F5QA737M5M2QN | SAWFILTER/5P/SMD/SAFFB2G14AA0F0A |
U3405 | SAW_/_SAFFB1G96AA1F0A | SAWFILTER/5P/SMD/SAFFB2G14AA0F0A | SAW / SAFFB1G96AA1F0A |
U3406 | SPDT_/_RF1630 | RF1630 | RF1630 |
U3407 | SAW_/_F5QA788M0M2QB | SAWFILTER/5P/SMD/SAFFB2G14AA0F0A | SAW / F5QA788M0M2QB |
U3408 | SAW_/_F5QA876M5M2QP | SAWFILTER/5P/SMD/SAFFB2G14AA0F0A |
U3409 | SAW_/_F5QA942M5M2AW | SAWFILTER/5P/SMD/SAFFB2G14AA0F0A |
U3410 | LPF_/_FI_168B1888GL-TXM | FILTER/SMD/DEA160915BT-1303B1MT | LPF / FI 168B1888GL-TXM |
U3411 | SPDT_/_RF1630 | RF1630 | RF1630 |
U3412 | LPF_/_FI_105L0829GZ | FILTER/6P/SMD/1005LPF/TDK | |
U3417 | SAW_/_F6QA1G842M2AN | SAWFILTER/5P/SMD/SAFFB2G14AA0F0A |
U3600 | SP4T_/_QM13134-PK020 | LGA10/SMD/P0.4/QM13134 | |
U3601 | DPDT_/_SKY13396-397LF | SKY13396 | DPDT / SKY13396-397LF |
U3603 | SPDT_/_RF1141A | RF1141A | |
U3604 | SPDT_/_RF1141A | RF1141A | |
U3605 | DIPX_/_DPX202700DT-4162A1MT | DIPLEXER/6P/SMD/DPX202700DT-4162A1MT | DIPX / DPX202700DT-4162A1MT |
U3701 | U_/_RF7061 | WLCSP24/SMD/P0.4/B0.21/RF7061 | |
U3901 | SAW_/_F6QA2G140M2AM | SAWFILTER/5P/SMD/SAFFB2G14AA0F0A |
U3902 | LNA_/_BGA8H1BN6 | LNA/6P/SMD/BGA8L1BN6 | |
U3903 | LNA_/_BGA8H1BN6 | LNA/6P/SMD/BGA8L1BN6 | |
U3904 | SAW_/_F6QA2G140M2AM | SAWFILTER/5P/SMD/SAFFB2G14AA0F0A |
U3905 | LNA_/_BGA8H1BN6 | LNA/6P/SMD/BGA8L1BN6 | |
U3906 | LNA_/_BGA8H1BN6 | LNA/6P/SMD/BGA8L1BN6 | |
U3907 | SAW_/_SAFFB1G96AA1F0A | SAWFILTER/5P/SMD/SAFFB2G14AA0F0A | SAW / SAFFB1G96AA1F0A |
U3908 | SAW_/_SAFFB1G96AA1F0A | SAWFILTER/5P/SMD/SAFFB2G14AA0F0A | SAW / SAFFB1G96AA1F0A |
U3909 | LNA_/_QM14137 | LNA/15P/SMD/P0.4/BGM17HBA15 | |
U3910 | LNA_/_QM14137 | LNA/15P/SMD/P0.4/BGM17HBA15 | |
U4001 | U_/_H9CCNNNBJTMLAR-NUM | FBGA178/SMD/B0.4/3-IN-1 | |
U4201 | U_/_H26M41208HPR | BGA153/P0.5/B0.27/11.5X13/SKHYNIX |
U5001 | U_/_MT6625LN_/_AME-PEGA-L | MT6625/SQFN40/SMD/P0.4/5X5 | U / MT6625LN / AME-PEGA-L |
U5002 | BPF_/_ACPF-7124 | FILTER/SMD/ACPF-7124 | BPF / ACPF-7124 |
U5003 | TRPX_/_TP2012-A1255DAT/LF | FILTER/SMD/LFD211G57ME3 | |
U5004 | U_/_BGA824N6 | TSNP-6-2/SMD/P0.4/BGA824N6 | |
U5005 | BPF_/_SAFFB1G56AC0F0A | SAWFILTER/SMD/SAFFB1G56AC0F0A | |
U6101 | U_/_AW8736FCR | FCLGA16/SMD/P0.4/B0.23/AW8736 | U / AW8736FCR |
U6401 | U_/_ITG-1010 | QFN16/SMD/P0.5/ITG-1010 | |
U6402 | U_/_AK09911C | WLCSP8/SMD/P0.4/B0.25/AK09911 | |
U6403 | U_/_BMP280 | LGA8/SMD/P0.65/BMP280 | U / BMP280 |
U6405 | U_/_AK09918C | WLCSP4/P0.4/B0.21/AK09918 | |
U6406 | U_/_MC3413 | LGA12/SMD/P0.5/MC3410 | |
U6704 | U_/_RT9078-33GQZ | ZQFN4/SMD/P0.625/RT9078 | |
VR2001 | ESD_/_AZ5825-01F | VR0402 | ESD / AZ5825-01F / NC |
VR2601 | ESD_/_AZ5825-01F | VR0402 | ESD / AZ5825-01F |
VR2602 | ESD_/_DF2B6.8M1ACT | VR0402 | ESD / DF2B6.8M1ACT |
X2201 | TMS_/_NX2520SG26MHZEXS00ACS1021 | TCXO/SMD/2.5X2.0/KT2520K-2016K | |
X5001 | TCXO_/_KT2016K26000ZAW18T5S | OSC/4P/SMD/KT1612A-KT2016K/2-IN-1 |
XME943 | ME_/_X_/_X_/_X_/_DESCRIPTION | | PCB / PCB_WS3435 |
XME943_13 | ME_/_PCB | | ME / E19-MTTM01A01059TS / TIM_RFTXM |
