UID:13578
- 注册时间2013-09-07
- 最后登录2024-04-25
- 在线时间14696小时
访问TA的空间加好友用道具
PCB: 附件出售:T866_MBX_REF_BASIC_V01_150105.zip <y7nGXzLK 附件出售:T866_MBX_REF_BASIC_V01_.zip Mj2`p#5wKh . =yF 原理: 附件出售:T866_MBX_REF_BASIC_V01_150105.pdf 4$~eG"wu Pp# At3> @FO=0_;y Item *6IytWOX5 Index | Value | Decal | qty | Name | IC | | | 1 | | 1 | T866 | BGA562_0P65_18X18MM | 1 | U12 | Unkown | | | 797 | | 2 | 0R | C0402 | 1 | 7C16 | 3 | MARK | MARK | 4 | M1,M2,M3,M4 | 4 | 0R | R0402 | 15 | 4R17,5R4,5R5,5R32,6R22,6R26,7R5,8R1,8R2,8R3,8R4,8R10,8R14,8R15,9R5 | 5 | 0R | R0603 | 1 | 1R46 | 6 | 0R | R0805 | 3 | 1R65,2R1,5R40 | 7 | 18PF | C0402 | 2 | 4C18,4C19 | 8 | 22PF | C0402 | 1 | 6C31 | 9 | 27PF | C0402 | 6 | 1C13,1C16,1C21,1C29,9C6,9C7 | 10 | 100PF | C0402 | 9 | 3C20,3C23,3C28,3C32,3C41,3C47,3C52,6C30,6C32 | 11 | 150PF | C0402 | 2 | 6C4,6C5 | 12 | 0.1UF | C0402 | 91 | 1C3,1C6,1C8,1C14,1C17,1C22,1C23,1C24,1C30,1C32,1C39,1C40,1C44,2C3,2C8,2C15,2C16,2C17,2C18,2C19,3C5,3C6,3C7,3C8,3C10,3C11,3C13,3C14,3C16,3C19,3C22,3C24,3C25,3C26,3C27,3C29,3C31,3C34,3C35,3C36,3C38,3C39,3C42,3C44,3C45,3C49,3C53,3C57,3C58,3C59,3C60,4C3,4C4,4C6,4C7,4C9,4C10,4C12,4C14,4C15,4C16,4C21,4C25,5C2,5C9,5C11,5C12,5C13,6C8,6C10,6C12,6C19,6C22,6C23,6C25,6C26,6C28,6C29,7C17,8C1,8C2,8C4,8C7,8C9,8C11,8C13,8C14,9C1,9C8,9C10,9C11 | 13 | 0.33UF | C0402 | 2 | 6C11,6C14 | 14 | 1.8UH | L0603 | 1 | 6L1 | 15 | 2.2R | R0603 | 1 | 9R16 | 16 | 2.2R | R0805 | 8 | 1R2,1R3,1R5,1R7,1R26,1R40,1R42,1R47 | 17 | 4.7R | R0402 | 3 | 4R6,6R13,6R18 | 18 | 6.8R | R0805 | 1 | 1R41 | 19 | 22R | R0402 | 13 | 2R4,4R30,4R31,4R42,4R43,7R13,7R18,7R19,7R20,7R21,7R22,9R1,9R20 | 20 | 75R | R0402 | 4 | 9R6,9R7,9R8,9R9 | 21 | 100R | R0402 | 3 | 4R33,4R37,6R12 | 22 | 150R | R0402 | 2 | 3R2,3R15 | 23 | 240R | R0402 | 6 | 3R10,3R11,3R12,3R13,3R21,3R22 | 24 | 470R | R0402 | 2 | 6R1,6R2 | 25 | 1K | R0402 | 11 | 4R36,4R38,4R39,5R10,5R11,5R18,5R19,6R5,7R7,8R5,8R7 | 26 | 1.2K | R0402 | 1 | 6R16 | 27 | 2K | R0402 | 2 | 5R14,5R21 | 28 | 2.2K | R0402 | 4 | 5R27,5R28,5R30,5R31 | 29 | 3K | R0402 | 1 | 6R15 | 30 | 4.7K | R0402 | 10 | 1R48,1R50,2R9,4R12,6R6,9R10,9R11,9R12,9R13,9R14 | 31 | 10K | R0402 | 20 | 1R6,1R13,1R28,1R29,3R1,3R14,4R4,4R10,4R15,4R19,4R32,6R4,6R7,6R8,6R9,6R10,6R11,6R23,9R3,9R4 | 32 | 27K | R0402 | 4 | 5R1,5R2,5R3,5R29 | 33 | 47K | R0402 | 18 | 1R14,1R20,1R30,1R31,1R34,1R36,4R28,5R7,5R8,5R9,5R16,5R17,5R23,5R24,5R25,5R26,5R33,5R37 | 34 | 100K | R0402 | 4 | 1R15,1R16,1R17,4R35 | 35 | 470K | R0402 | 2 | 4R34,5R34 | 36 | PMBT3904 | SOT-23 | 5 | 1Q1,1Q4,1Q5,1Q6,5Q12 | 37 | UPDATE_SWITCH | SW-TK-TS-03PV | 1 | 4SW1 | 38 | 24MHZ_20PPM | HC-49/SM | 1 | 4Y1 | 39 | 25MHZ_20PPM | Y-SMD4P3225 | 1 | 9Y1 | 40 | A2005WV-N-2X13P_DEBUG | CN-2P00-2X13P | 1 | 9J2 | 41 | HDMI_TYPE-A | HDMI-A-DIP-V | 2 | 5J2,5J3 | 42 | REMOTE_OUTPUT | TP30 | 1 | 4TP12 | 43 | 1UF_6.3V | C0402 | 20 | 1C1,1C34,1C36,1C38,2C6,3C2,3C51,4C13,4C17,5C5,5C6,5C7,5C8,5C14,5C15,5C16,6C21,6C24,6C27,7C12 | 44 | 4.7UF_6.3V | C0603 | 34 | 1C2,1C7,1C33,1C35,1C37,2C2,2C9,2C49,2C50,3C1,3C3,3C9,3C21,3C30,3C40,3C46,3C48,3C54,3C55,4C2,4C8,5C10,6C1,6C9,6C15,6C16,6C20,7C10,8C8,8C10,8C12,9C2,9C3,9C4 | 45 | 22UF_6.3V | C0805 | 15 | 1C5,1C10,1C11,1C12,1C15,1C18,1C19,1C20,1C26,1C27,1C28,1C31,8C3,8C5,8C6 | 46 | 22UF_16V | C1206 | 1 | 1C41 | 47 | FUSE-500MA | FUSE-0805 | 3 | 8F1,8F2,8F3 | 48 | 2.2UH_3A_DCR¡Ü35MOHM | L5050 | 4 | 1L1,1L2,1L3,1L4 | 49 | USB-3.0-AF | USB-3.0-AF | 1 | 8J1 | 50 | USB-A | USB_CONA | 2 | 8J2,8J3 | 51 | 25M_OUT_RST | TP30 | 2 | 9TP14,9TP25 | 52 | RJ45-LED-LYRG | RJ45LED-LY-RG | 1 | 9J1 | 53 | RS809R | SOT-23 | 1 | 4U3 | 54 | NC | ACM2012-2P | 2 | 8L1,8L2 | 55 | HJ-313E | AV-HJ-313E | 1 | 6J1 | 56 | KLM4G1FEAC-B031 | BGA169-INAND | 1 | 4U2 | 57 | 1NF | C0402 | 115 | 1C4,1C9,1C42,1C43,1C45,1C47,1C48,1C51,1C56,1C57,2C1,2C4,2C5,2C7,2C10,2C11,2C12,2C13,2C14,2C20,2C21,2C22,2C23,2C24,2C25,2C26,2C27,2C28,2C29,2C30,2C31,2C32,2C33,2C34,2C35,2C36,2C37,2C38,2C39,2C40,2C41,2C42,2C43,2C44,2C45,2C46,2C47,2C48,2C51,2C52,3C4,3C12,3C15,3C17,3C18,3C33,3C37,3C43,3C50,3C56,3C61,3C62,3C63,3C64,3C65,3C66,3C67,3C68,3C69,3C70,3C72,3C73,3C74,3C76,3C78,4C1,4C5,4C11,4C22,4C23,5C1,5C17,5C18,6C2,6C3,6C6,6C7,6C13,6C33,6C34,6C35,6C36,6C37,6C38,6C39,6C40,6C41,6C42,6C43,6C45,6C46,7C1,7C2,7C3,7C4,7C5,7C6,7C7,7C8,7C9,7C11,7C15,7C18,7C19,9C5 | 58 | NC | C0603 | 7 | 3C71,3C75,3C77,6C17,6C18,7C13,7C14 | 59 | NC | C0805 | 4 | 1C25,1C46,1C53,1C55 | 60 | NC | C1206 | 2 | 1C54,9C9 | 61 | NC | C3216 | 2 | 1EC1,1EC2 | 62 | NC | CN-2P00-2X20P-L | 2 | 2J2,2J3 | 63 | NC | CN-2P50-4P | 1 | 4J1 | 64 | NC | CN-2P50-6P | 1 | 4J2 | 65 | DC-0501 | DC-0501 | 1 | 1J1 | 66 | K4B2G1646Q-BCK0 | DDR_96PIN | 4 | 3U1,3U2,3U3,3U4 | 67 | AZ1045-04F | DFN2510P10E | 6 | 5D1,5D2,5D3,5D4,5D5,5D6 | 68 | NC | DFN4120P10E | 1 | 8D1 | 69 | IRM-3638N3 | DIP-IR | 1 | 4U1 | 70 | NC | EMI-TF2010A4X | 8 | 5L1,5L2,5L3,5L4,5L5,5L6,8L3,8L4 | 71 | NC | ESD0402 | 25 | 2D1,2D2,2D3,2D4,2D5,2D6,4D1,4D2,5D7,5D8,5D9,5D10,5D11,5D14,5D15,5D16,5D17,5D18,5D19,5D21,6D1,8D7,8D8,8D9,8D10 | 72 | 100MHZ220OHM | FB0603 | 7 | 5FB1,5FB2,5FB3,6FB1,8FB1,8FB2,8FB3 | 73 | ZX-HDMI-07A | HDMI-19P-SMD | 1 | 5J1 | 74 | HOLE17 | HOLE17 | 4 | H1,H2,H3,H4 | 75 | MS-156 | J-MS-156 | 1 | 7J1 | 76 | GQ-10 | JGQ-10 | 1 | 6J2 | 77 | NC | L3030 | 1 | 7L1 | 78 | NC | L5050 | 1 | 1L6 | 79 | BLUE_LED | LED0805 | 3 | 1D1,1D2,1D3 | 80 | IP101GR | QFN40P4X4-33N | 1 | 9U1 | 81 | 100K_1% | R0402 | 123 | 1R1,1R8,1R9,1R10,1R11,1R12,1R18,1R19,1R22,1R23,1R24,1R25,1R32,1R35,1R37,1R38,1R49,1R51,1R58,1R59,1R60,2R3,2R5,2R6,2R7,2R8,2R11,2R12,2R13,2R14,2R15,2R16,2R17,2R18,2R19,2R20,2R21,2R22,2R23,2R24,2R25,2R26,2R27,2R28,2R29,2R30,2R31,2R32,2R33,3R6,3R7,3R8,3R9,3R19,3R20,4R1,4R2,4R3,4R5,4R7,4R8,4R9,4R11,4R13,4R14,4R16,4R18,4R20,4R21,4R22,4R23,4R24,4R25,4R26,4R27,4R29,4R44,5R6,5R12,5R13,5R15,5R20,5R22,6R3,6R14,6R17,6R19,6R20,6R21,6R24,6R25,6R27,6R28,6R29,6R30,6R31,6R32,6R33,6R34,7R1,7R2,7R3,7R4,7R6,7R8,7R9,7R10,7R11,7R12,7R14,7R15,7R16,7R17,7R23,8R6,8R8,8R9,8R12,9R2,9R15,9R17,9R18,9R19 | 82 | NC | R0603 | 5 | 1R21,1R27,1R33,1R39,2R2 | 83 | NC | R0805 | 7 | 1R4,1R43,1R44,1R45,8R11,8R13,8R16 | 84 | 4X0R | RN0402 | 8 | 5RN1,5RN2,5RN3,5RN4,5RN5,5RN6,8RN1,8RN2 | 85 | NC | SOD-123 | 3 | 2D7,4D4,5D12 | 86 | ES7134LV/CS4334-DSZ | SOIC-8-150MIL | 1 | 6U2 | 87 | RTL8189ETV | SOP44_AP6S | 1 | 7U1 | 88 | DIO2125XM10 | SOP50P490X110-11N | 1 | 6U1 | 89 | WPM2015 | SOT-23 | 16 | 1Q2,1Q3,5Q1,5Q2,5Q3,5Q4,5Q5,5Q6,5Q7,5Q8,5Q9,5Q10,5Q11,5Q13,7Q1,7Q2 | 90 | WL2803E18-5 | SOT23-5 | 6 | 1U5,1U6,1U7,1U8,1U9,1U11 | 91 | SY8113BADC | SOT23-6 | 5 | 1U1,1U2,1U3,1U4,1U12 | 92 | NC | TDYU4-D01A | 1 | 6T1 | 93 | TFWF1-EBF1-1X0X | TF-CARD-PUSH | 1 | 2J1 | 94 | AO_5V | TP30 | 55 | 1TP1,1TP2,1TP3,1TP4,1TP5,1TP6,1TP7,1TP8,1TP9,1TP10,1TP11,2TP1,2TP2,2TP3,2TP5,2TP6,2TP7,2TP8,2TP9,2TP13,2TP14,4TP3,4TP6,4TP7,4TP8,4TP9,4TP10,4TP11,5TP1,5TP4,6TP9,9TP1,9TP2,9TP3,9TP4,9TP5,9TP6,9TP7,9TP8,9TP9,9TP10,9TP11,9TP12,9TP13,9TP15,9TP16,9TP17,9TP18,9TP19,9TP20,9TP21,9TP22,9TP23,9TP24,9TP27 | 95 | H1601CG | TS8121C | 1 | 9T1 | 96 | NC | TSOP-6 | 1 | 7U2 | 97 | NC | TSSOP-10-PT05 | 1 | 6U3 | 98 | NC | UM02BS | 1 | 7U3 | 99 | NC | Y-SMD4P3225 | 2 | 7Y1,7Y2 | | | | | | Design Part count: 798 | | | | | q|r^)0W KW`^uoY$ QMwrt [ 此帖被yfchen1003在2018-09-28 18:54重新编辑 ]
