Footprint | Comment | LibRef | Designator | Description | Quantity | CR1220 | CR1220 | Battery | Battery | CR1220电池座 贴片 | 1 | Buzzer | Buzzer | Buzzer | Buzzer | 12*9.5MM 6.5MM间距 3-12V无源蜂鸣器 | 1 | C3216 | 22UF | CAPA | C1, C23 | 3216封装钽电容 22UF 10V以上 | 2 | C0603 | 104 | CAP | C2, C3, C5, C7,C9, C10, C11, C12, C13, C18, C19, C20, C24, C25, C26 | 0603封装电容 104 | 15 | C3216 | 4.7UF | CAPA | C4 | 3216封装钽电容 4.7UF 16V | 1 | C3216 | 1UF | CAPA | C6, C8 | 3216封装钽电容 1UF 16V | 2 | C0603 | 10PF | CAP | C14, C15, C16, C17 | 0603封装电容 10PF | 4 | C0603 | 22PF | CAP | C21, C22 | 0603封装电容 22PF | 2 | LED0603 | RED | LED | D1 | 0603封装LED 红色LED | 1 | LED0603 | BLUE | LED | D2, D3, D4 | 0603封装LED 蓝色LED | 3 | D1206 | 5.1V | DIODE | D5 | 1206封装 贴片5.1V稳压管 | 1 | D1206 | 1N4148 | DIODE | D6 | 1206封装 贴片1N4148 | 1 | F0805 | 6V/500MA | FUSE | F1 | 0805封装 6V/500MA自恢复保险丝 | 1 | KEY | KEY | KEY | K1, K2, K3, K4 | 2脚贴片按键 3*6*2.5MM | 4 | Header 3 | Header 3 | Header 3 | P1 | 单排针 2.54MM 3PIN | 1 | Header 3 | BOOT1 | Header 3 | P2 | 单排针 2.54MM 3PIN | 1 | Pin 2*2 | COM | Pin 2*2 | P3 | 双排针 2.54MM 2*2PIN | 1 | DG301-2P | DG301-2P | DG301-2P | P4, P5 | DG301-2P 5.08MM 接线端子 | 2 | Header 20*2 | Header 20*2 | Header 20*2 | P6 | 双排座 2.54MM 2*20P | 1 | LCD | LCD | LCD | P7 | 双排座 2.54MM 2*16P | 1 | DC3 20 | JTAG | JTAG | P8 | 简易牛角座 20芯 直脚 2.54MM | 1 | SOT-23 | S8550 | PNP | Q1, Q3, Q4 | SOT-23封装 S8550三极管 | 3 | SOT-23 | S8050 | NPN | Q2 | SOT-23封装 S8050三极管 | 1 | R0603 | 0R | RES | R1, R2 | 0603封装电阻 0R | 2 | R0603 | 47 | RES | R3 | 0603封装电阻 47R | 1 | R0603 | 470 | RES | R4, R43, R44, R45 | 0603封装电阻 470R | 4 | R0603 | 10K | RES | R5, R6, R7, R11,R19, R20, R21, R22,R23, R24, R28,R29, R30, R31, R32 | 0603封装电阻 10K | 15 | R0603 | 27 | RES | R8, R9, R16, R17 | 0603封装电阻 27R | 4 | R0603 | 1.5K | RES | R10, R18 | 0603封装电阻 1.5K | 2 | R0603 | 1K | RES | R12, R13, R14, R34, R36, R40 | 0603封装电阻 1K | 6 | R0603 | 45K | RES | R15 | 0603封装电阻 45K | 1 | R0603 | 4.7K | RES | R25, R26, R27, R35, R37, R39 | 0603封装电阻 4.7K | 6 | R0603 | 120 | RES | R33, R38 | 0603封装电阻 120R | 2 | R0603 | 2K | RES | R41 | 0603封装电阻 2K | 1 | 3362P | 20K | R | R42 | 3362P电位器 20K | 1 | SW | SW | SW | S1, S2 | SS-12F44 (1P2T) 型号 直脚开关 | 2 | TF | TF | TF | TF | 自弹式TF座 | 1 | QFP100 | STM32F103VET6 | STM32 | U1 | STM32F103VET6 | 1 | SOT223 | AMS1117-3.3 | AMS1117 | U2 | AMS1117-3.3 | 1 | SSOP28 | PL2303HX | PL2303HX | U3 | PL2303HX | 1 | SOP8 | AT24C02 | AT24C02 | U4 | SOP8封装 贴片AT24C02 | 1 | SOP8 | W25X16 | W25X16 | U5 | SOP8封装 贴片W25X16 | 1 | SOP8 | TJA1050 | TJA1050 | U6 | SOP8封装 贴片TJA1050 | 1 | SOP8 | MAX485 | MAX485 | U7 | SOP8封装 贴片MAX3485 | 1 | MINI USB | MINI USB | MINI USB | USB1, USB2 | MINI USB母座 | 2 | XTAL | 8M | CRYSTAL | Y1 | 直插 5.08MM 8M晶振 49S2封装 | 1 | XTAL1 | 32.768KHZ | CRYSTAL | Y2 | 直插 32.768KHZ晶振 2*6 小体积 | 1 | XTAL | 12M | CRYSTAL | Y3 | 直插 5.08MM 12M晶振 49S2封装 | 1 | | 跳线帽 | | | 2.54MM间距 跳线帽 | 5 | | MINI USB线 | | | MINI USB线 | 1 | | CR1220 | | | CR1220纽扣电池 | 1 | | M3*10 双通铜柱 | | | M3*10 双通铜柱 | 6 | | M3*6 圆头螺丝 | | | M3*6 圆头螺丝 | 6 | | | | | | 130 | Approved | | Notes | | | |
YY-STM32开发板(原理图和PCB源文件、BOM).zip
(18.22 MB, 下载次数: 8)
