查看: 2395|回复: 1
[AD格式] AVR_KIT_MAINBOARD_v23_M2_OUT/pcb
发表于 2018-11-3 21:31:53 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
Bill of Material for AVR_KIT_MAINBOARD_v23_M2_OUT.pcb
On 2018/11/3 at 21:26:53
Comment             Pattern     Quantity  Components
*                   RJ45             1    RJ100
0.1uF               0805            12    C101, C102, C107, C108, C109
                                           C110, C111, C113, C117, C120
                                           C134, C137
1000uF/16V          C1000UF/16V      2    C126, C127
1000uF/16V          C1000UF/50V      1    C125
100R                0805             9    R132, R133, R134, R135, R136
                                           R137, R146, R203, R231
100R                AXIAL-0.4        1    R196
10K                 0805            39    R138, R139, R150, R160, R161
                                           R162, R163, R164, R165, R166
                                           R167, R183, R184, R185, R186
                                           R187, R188, R189, R190, R193
                                           R194, R195, R200, R201, R204
                                           R209, R213, R214, R215, R217
                                           R219, R220, R225, R226, R227
                                           R228, R229, R230, R233
10K                 RESADJ           1    RJ102
10Pin Port Plug     PLUG10          10    KEYS, LED_G, LED_R, PORT_A
                                           PORT_B, PORT_C, PORT_D
                                           PORT_E, PORT_F, PORT_G
10uF                1210             1    C112
10uH x2             INDU10UHX2       1    T101
10uH                1210             2    L100, L101
150R                0805            10    R108, R109, R110, R111, R112
                                           R113, R114, R115, R191, R192
1K                  0805            12    R159, R168, R169, R170, R171
                                           R172, R173, R174, R197, R208
                                           R211, RJ101
1K5                 0805            10    R100, R101, R102, R103, R104
                                           R105, R106, R107, R145, R212
1N4004              DIO10.46-5.3x2.8    1    D103
1N4148              1206D            2    D100, D102
1uF                 0805             6    C124, C128, C129, C130, C131
                                           C132
220uF/16V           C100UF/10V       2    C116, C121
22K                 0805             4    R221, R222, R223, R224
22pF                0805             6    C114, C115, C118, C119, C122
                                           C123
27R                 0805             2    R143, R144
2K2                 0805            10    R124, R125, R126, R127, R128
                                           R129, R130, R131, R147, R202
32.768K             XTAL1            1    XJ102
330R                0805            24    R141, R149, R151, R152, R153
                                           R154, R155, R156, R157, R158
                                           R175, R176, R177, R178, R179
                                           R180, R181, R182, R198, R199
                                           R205, R207, R210, R218
330R                1206             8    R116, R117, R118, R119, R120
                                           R121, R122, R123
330uH               INDU330UH        1    L102
3904K               SOT-23/2         1    Q131
3906K               SOT-23/2        29    Q100, Q101, Q102, Q103, Q104
                                           Q105, Q106, Q107, Q114, Q115
                                           Q116, Q117, Q118, Q119, Q120
                                           Q121, Q122, Q123, Q124, Q125
                                           Q126, Q127, Q128, Q129, Q132
                                           Q133, Q134, Q135, Q136
470R                0805             4    R140, R142, R148, R206
5K                  RESADJ           1    RJ103
6M Hz               XTAL             1    XJ100
7.3728M             XTAL             1    XJ101
74LS244N            DW020            1    U113
93C46               SOP/8            1    U108
AGND                PIN1             1    P117
AMS1117-3.3         ZZ311            1    U101
AT24C00             DIP8             2    U105, U106
AT45DB041B          EIAJ-SOIC        1    U100
ATmega8-16AI        QFP32A           1    U109
AVR_ISA             AVR_ISA          2    ISA1, ISA2
Bell                BELL             1    LS100
BT5401              SOT-23/2         1    Q130
BT5551              SOT-23/2         6    Q108, Q109, Q110, Q111, Q112
                                           Q113
BUTTON              BUTTON1          8    K0, K1, K2, K3, K4, K5, K6
                                           K7
BUTTON              LBTN-01          1    RESET
Cap                 0805             1    C100
DIPSW8              DIPSW8           2    DW100, DW101
Dpy Blue-CA         DLED2            6    DS100, DS101, DS102, DS103
                                           DS104, DS105
DS1302              DIP8             1    U111
FT245BM             QFP32A           1    U107
GND                 PIN1             3    P114, P115, P116
GREEN               LED2            12    A0, A1, A2, A3, A4, A5, A6
                                           A7, DS122, G.COM, G.IR, G.RDY
H38B(5V/3V)         HDR1X3           1    IR001
Header 10X2         IDC2X10          2    DLED, PORT_C/A
Header 19X2         HDR2X19          1    P124
Header 1x3          HDR1X3           1    P100
Header 2            HDR1X2           1    P103
Header 20X2         HDR2X20          1    P123
Header 3            HDR1X3           4    P112, P122, P127, P129
Header 3X2          HDR2X3           2    P126, P130
Header 3X2          IDC2X3           1    RS485
Header 4X2          HDR2X4           1    P125
Header 5X2          IDC2X5           1    ISP_COM
Header 7X2          IDC2X7           5    P101, P102, PORT_D/B, UISP
                                           USBP
IN5822              IN5822           1    D101
LM2576T-ADJ         LM2576           1    U112
LOGO                ALEYNLOGO        1    LOGO
LUCKBUTTON          LBTN-01          1    SWAP
MAX232CPE           NSO16            1    U114
MAX491EPD           NSO14            1    U110
POSITION            POSITION         8    P113, P120, P131, P132, P133
                                           P134, P135, P136
POWER_CON           POWER_CON        1    J119
PWR_SWITH           PWR_SWITH        1    SW100
RED                 LED2            10    B0, B1, B2, B3, B4, B5, B6
                                           B7, R.ISP, R.USP
Res2                0805             1    R216
RS232 COM           RS232            1    JF100
TC1206/LM3033B      HDR1X20          1    LCD101
USBCON              USB/B            1    J103
YELLOW              LED2             1    Y.RST
4.5 MB, 下载次数: 3, 下载积分: 金币 -5 枚
重要提示:PCB作品文件展下载说明
  • 签到天数: 6 天
    承接PCB设计
    发表于 2018-11-4 08:58:54 | 显示全部楼层
