查看: 6014|回复: 31
[AD格式] MSP430FR6047IPZR_超声波感应水表前端原理图与PCB设计
PADS-180606高级班
社区居民终身成就奖特殊贡献奖优秀斑竹奖
发表于 2018-11-8 16:33:55 | 显示全部楼层 |阅读模式
游客,如果您要查看本帖隐藏内容请回复
DesignatorValueQuantityDescription
!PCB1Printed Circuit Board
BUT_DOWN, BUT_LEFT, BUT_RIGHT,BUT_SELECT, BUT_UP5Switch, Tactile, SPST-NO, 0.05A, 12V, SMT
C1, C2, C5, C6, C13, C20, C28, C102,C104, C108, C113, C118, C119, C121, C202, C203, C204, C400, C402, C408, C409,C4110.1uF22CAP, CERM, 0.1 μF, 16 V, +/- 10%, X7R, 040
C3, C4, C14, C111, C2101000pF5CAP, CERM, 1000 pF, 50 V, +/- 5%, C0G/NP0, 0402
C7, C8, C15, C16, C17, C1812pF6CAP, CERM, 12 pF, 50 V, +/- 5%, C0G/NP0, 0402
C94.7uF1CAP, CERM, 4.7 μF, 16 V, +/- 10%, X7R, 080
C10, C19, C410, C41310uF4CAP, CERM, 10 μF, 10 V, +/- 20%, X5R, 060
C11, C121000pF2CAP, CERM, 1000 pF, 50 V, +/- 1%, C0G/NP0, 0603
C21, C23, C2447uF3CAP, CERM, 47 μF, 6.3 V, +/- 20%, X5R, 080
C22, C25, C26, C271uF4CAP, CERM, 1 μF, 10 V, +/- 10%, X7R, 060
C100, C101, C200, C201, C403, C40422pF6CAP, CERM, 22 pF, 50 V, +/- 5%, C0G/NP0, 0402
C103, C112, C116, C117, C120, C2054.7uF6CAP, CERM, 4.7 μF, 10 V, +/- 20%, X5R, 060
C105, C106, C206, C2070.22uF4CAP, CERM, 0.22 μF, 16 V, +/- 10%, X7R, 040
C107, C2080.47uF2CAP, CERM, 0.47 μF, 16 V, +/- 10%, X5R, 040
C109, C110, C114, C11533pF4CAP, CERM, 33 pF, 50 V, +/-5%, C0G/NP0, 0402
C401, C405, C406, C40710pF4CAP, CERM, 10 pF, 50 V, +/- 5%, C0G/NP0, 0402
C4120.01uF1CAP, CERM, 0.01 μF, 16 V, +/- 10%, X7R, 040
D100, D203, LED3Red3LED, Red, SMD
D101, D201, D202, LED1, LED2Green5LED, Green, SMD
D102, D10340V2Diode, Schottky, 40V, 0.2A, SOT-23
FID1, FID2, FID33Fiducial mark.  There is nothing tobuy or mount.
H1, H2, H3, H44Bumpon, Cylindrical, 0.312 X 0.200, Black
J11Header, 2.54 mm, 5x2, Gold, TH
J21Header, 2.54mm, 2x2, Gold, TH
J31Header, 100mil, 4x2, Tin, TH
J4, J72Header, 100mil, 2x1, Gold, TH
J5, J62Header, 100mil, 10x2, Gold, TH
J81Header, 100mil, 4x2, Gold, TH
J101Header, 2.54 mm, 3x1, Gold, TH
J301Header, 100mil, 2x2, Gold, TH
J31, J32, J333Header, 100mil, 2x1, Gold, TH
J341Header (shrouded), 100 mil, 7x2, Gold, TH
J100, J2002Header, 2.54 mm, 7x1, Gold, TH
L1, L2600 ohm2Ferrite Bead, 600 ohm @ 100 MHz, 2 A, 0805
L32.2uH1Inductor, Shielded, Ferrite, 2.2 μH, 1.57 A, 0.042 ohm, SM
L1012.2uH1Inductor, Shielded, Composite, 2.2uH, 0.95A, 0.16 ohm, SMD
LCD1108 Segment LCD Display, TH
MCU_RESET, S201, S2023SWITCH TACTILE SPST-NO 0.05A 12V
POW_SEL1Switch, Slide, SP3T, On-On-On, 3 Pos, 0.3A, 30 VDC, TH
Q100, Q2002Resonator, 4MHz, 39pF SMD
Q101-50V1MOSFET, P-CH, -50V, -0.13A, SOT-323
Q1020.7V1Transistor, NPN, 45V, 0.1A, SOT-23
Q4001Resonator, 6MHz, 15pF SMD
R1, R2, R3, R4, R6, R7, R8, R39, R40,R21110010RES, 100, 5%, 0.063 W, 0402
R9, R10100k2RES, 100 k, 5%, 0.063 W, 0402
R11200k1Trimmer, 200 K, 0.25 W, SMD
R12, R13, R14330k3RES, 330 k, 5%, 0.063 W, 0402
R15, R26, R100, R101, R201, R203226RES, 22, 5%, 0.063 W, 0402
R16, R172002RES, 200, 1%, 0.063 W, 0402
R18, R106, R121, R123, R209, R40447k6RES, 47 k, 5%, 0.063 W, 0402
R1901RES, 0, 5%, 0.125 W, 0805
R20, R21, R22, R41, R42, R43, R44, R45,R46, R47, R48, R4912RES, xxx ohm, x%, xW, [PackageReference]
R23, R243902RES, 390, 5%, 0.063 W, 0402
R25, R104, R120, R2054704RES, 470, 5%, 0.063 W, 0402
R27, R28, R29, R30, R31, R32, R33, R34,R35, R36, R37, R38, R50, R51, R124015RES, 0, 5%, 0.063 W, 0402
R103, R206, R4081.5k3RES, 1.5 k, 5%, 0.063 W, 0402
R105, R202, R2043903RES, 390 ohm, 5%, 0.063W, 0402
R107, R108, R116, R117, R118, R119221k6RES, 221 k, 1%, 0.063 W, 0402
R109150k1RES, 150 k, 1%, 0.063 W, 0402
R110240k1RES, 240 k, 1%, 0.063 W, 0402
R111, R1124.7k2RES, 4.7 k, 5%, 0.063 W, 0402
R1132.20k1RES, 2.20 k, 1%, 0.063 W, 0402
R1146.81k1RES, 6.81 k, 1%, 0.063 W, 0402
R1153.32k1RES, 3.32 k, 1%, 0.063 W, 0402
R1228201RES, 820, 5%, 0.063 W, 0402
R200, R2082.2k2RES, 2.2 k, 5%, 0.063 W, 0402
R207, R41810k2RES, 10 k, 5%, 0.063 W, 0402
R2101.0Meg1RES, 1.0 M, 5%, 0.063 W, 0402
R400, R41015k2RES, 15 k, 5%, 0.063 W, AEC-Q200 Grade 0, 0402
R401, R402, R403, R405, R411, R41215k6RES, 15 k, 5%, 0.063 W, 0402
R406271RES, 27 ohm, 5%, 0.063W, 0402
R407, R409, R413, R414, R415, R416226RES, 22 ohm, 5%, 0.063W, 0402
RUSB331RES, 33 ohm, 5%, 0.063W, 0402
SH-10, SH-J1, SH-J2, SH-J3, SH-J4, SH-J5,SH-J6, SH-J7, SH-J8, SH-J9, SH-J1111Shunt, 2.54mm, Gold, Black
U11Mixed-Signal Microcontroller, PZ0100A (LQFP-100)
U21Single Output LDO, 150 mA, Adjustable 1.22 to 5.25 V Output, 2.2 to 5.5 VInput, with 500 nA Quiescent Current, 5-pin SOT (DDC), -40 to 125 degC, Green(RoHS & no Sb/Br)
U31360nA IQ Step Down Converter for Low Power Applications, DSS0012A
U100, U2002Mixed Signal MicroController, RGC0064B
U10110.75-Ohm DUAL SPST ANALOG SWITCH WITH 1.8-V COMPATIBLE INPUT LOGIC,RSE0008A (UQFN-8)
U102116 MHz Mixed Signal Microcontroller with 8 KB Flash, 256 B SRAM and 16GPIOs, 16-pin QFN (RSA), Green (RoHS & no Sb/Br)
U103, U201, U2023Low-Capacitance Array with + / - 15 kV ESD Protection, 4 Channels, -40 to+85 degC, 5-pin SOT (DRL), Green (RoHS & no Sb/Br)
U4001Low-Capacitance + / - 15 kV ESD-Protection Array for High-Speed DataInterfaces, 2 Channels, -40 to +85 degC, 5-pin SOT (DRL), Green (RoHS &no Sb/Br)
U40114-Port Full-Speed USB Hub, 3.3V, -40 to 85 degC, 32-Pin QFN (RHB), Green(RoHS & no Sb/Br)
U4021Single Output High PSRR LDO, 500 mA, Fixed 3.3 V Output, 2.7 to 6.5 VInput, with Low IQ, 8-pin SON (DRB), -40 to 125 degC, Green (RoHS & noSb/Br)
USB1Receptacle, USB 2.0, Micro B, 5 Position, R/A, SMT
Y11Crystal, 8MHz, SMD
Y21CRYSTAL, 32.768KHZ, 9PF, SMD
Y31Ceramic Resonator, 8MHz, 22pF, SMD
生活就是油盐酱醋再加一点糖,快活就是一天到晚乐呵呵的忙!
    昨天 10:18
  • 签到天数: 93 天
    发表于 2018-11-8 17:02:12 | 显示全部楼层
    社区居民终身成就奖特殊贡献奖
    发表于 2018-11-13 16:21:25 | 显示全部楼层
    终身成就奖社区居民宣传大使奖
    发表于 2018-12-24 10:22:12 | 显示全部楼层
    是官方文件么,官网有免费下呢
    社区居民忠实会员终身成就奖
    发表于 2019-1-30 14:03:11 | 显示全部楼层
    发表于 2019-3-21 11:45:30 | 显示全部楼层
    社区居民终身成就奖优秀斑竹奖社区明星宣传大使奖特殊贡献奖原创先锋奖
    发表于 2019-3-21 12:57:32 | 显示全部楼层
    发表于 2019-3-21 13:11:40 | 显示全部楼层
    头像被屏蔽
    禁止发言
    发表于 2019-11-16 20:57:13 | 显示全部楼层
    提示: 作者被禁止或删除 内容自动屏蔽
    发表于 2019-12-2 20:11:43 | 显示全部楼层
    公告:服务器刚移机,
    大家请不要下载东西。
    会下载失败
