小米蓝牙音箱 e8Y;~OAj[
z m&?G
PartType RefDes PartDecal Pins Layer Orient. X Y SMD Glued ~Pm[Ud
ANT ANT1 TP-DIP-80MIL_D40MIL 1 Bottom 0 -8.496 8.549 No No J ;|i6q q
ANT-BLUETOOTH ANT2 BT_ANT_S 1 Bottom 79.245 -12.444 13.906 Yes No vJ a?5Jr
INDUCTOR B1 L0603 2 Bottom 180 40.590 24.931 Yes No pR,eus;8
BAT-LI-NT B1P BAT 2 Bottom 90 6.458 43.853 No No z~ f;5 xtI
INDUCTOR B2 L0603 2 Bottom 180 40.510 27.297 Yes No gz~)v\5D/
C0603 C1 C0603 2 Bottom 180 14.568 58.671 Yes No u&Lp
C0603 C2 C0603 2 Bottom 180 28.207 31.986 Yes No !D!1%@
e
C0603 C3 C0603 2 Bottom 0 23.585 8.333 Yes No g{U?Y"
C0603 C4 C0603 2 Bottom 270 21.297 16.361 Yes No /hC'-6:]^
C0805 C7 C0805 2 Bottom 270 19.373 43.876 Yes No ?kBX:(g
C0805 C13 C0805 2 Bottom 90 8.931 45.625 Yes No 'ZXd|WI
C0805 C14 C0805 2 Bottom 270 22.017 43.775 Yes No F5(D A
C0603 C16 C0603 2 Bottom 180 12.354 47.684 Yes No gNj~o^6|@
C0603 C30 C0603 2 Bottom 90 38.109 12.559 Yes No d>YX18'<Q
C0603 C42 C0603 2 Bottom 0 29.844 8.413 Yes No +ak<yV1=
C0603 C55 C0603 2 Bottom 0 31.366 11.848 Yes No Q\qI+F2?
C0603 C57 C0603 2 Bottom 90 31.098 15.518 Yes No z"PU`v
C0603 C58 C0603 2 Bottom 270 26.829 23.787 Yes No 4*Y`Pn@
C0603 C60 C0603 2 Bottom 180 40.616 23.069 Yes No a?NoNv)&
C0603 C61 C0603 2 Bottom 180 40.510 28.999 Yes No J^xIfV~zt
C0603 C62 C0603 2 Bottom 0 23.498 10.244 Yes No tT`{xM
SPEAKER CN2 BAT 2 Top 90 44.244 24.408 No No c)q'" r
MMC_SOCKET/TF CN4 TF 15 Top 144.544 27.645 45.038 No Yes j}F;Bfq!
DIODE-SCHOTTKY D5 SS14 2 Bottom 0 11.374 50.188 Yes No EjjW%"C,
DIODE-LED D6 LED 2 Top 337.166 -10.405 38.706 No No hVLVMqd
CE3216 EC1 3216 2 Bottom 270 29.207 24.569 Yes No 3$#=*Zp
CE3216 EC2 3216 2 Bottom 90 18.591 15.815 Yes No }u&,;]
PHONE-4P J2 PHONE-4 6 Top 0 17.944 55.411 No Yes v;$cx*?
USB-PORT5 J3 USB-MINI 11 Top 35.517 0.398 51.963 No Yes \1[v-hvK
CN-03 J4 CON3 3 Bottom 0 -1.180 43.323 Yes No 9X ^D(
KEY-3P KEY1 KEY-DIP-3P 3 Top 180 7.207 -0.702 No Yes *{1]b_<
KEY-3P KEY2 KEY-DIP-3P 3 Top 180 15.310 -2.642 No Yes !IAd.<,
KEY-3P KEY3 KEY-DIP-3P 3 Top 180 23.394 -2.669 No Yes *T:gx:Sg/
KEY-3P KEY4 KEY-DIP-3P 3 Top 180 31.453 -0.709 No Yes Hr}pO"%
LED-3PL LED21 LED-3PL 3 Top 292.754 44.448 42.194 No Yes ELa:yIl0
MIC-DIP-2P MIC1 MIC-DIP-D6 2 Top 35.364 34.059 4.547 No No ^Sj*
ON/OFF-5P ON/OFF1 SW-MKS_12D18A-3P-SMT 5 Bottom 270 14.753 24.348 No Yes +|c1G[Jh
R0603 R1 R0603 2 Bottom 90 23.502 18.483 Yes No .J fV4!=o
R0603 R3 R0603 2 Bottom 90 16.406 1.255 Yes No 'M=c-{f~
R0603 R6 R0603 2 Bottom 0 42.049 38.922 Yes No C[2LP$6*/
R0603 R7 R0603 2 Bottom 180 16.103 56.782 Yes No E7AYK&
R0603 R8 R0603 2 Bottom 180 26.712 10.215 Yes No ~z&Ho
R0603 R9 R0603 2 Bottom 0 24.332 21.262 Yes No lDF26<<\`
R0603 R10 R0603 2 Bottom 270 14.564 1.259 Yes No &:}}T=@M1
R0603 R11 R0603 2 Bottom 270 19.224 1.131 Yes No 97-=Vb
R0603 R12 R0603 2 Bottom 180 -2.768 41.012 Yes No j"wbq-n,7
R0603 R13 R0603 2 Bottom 270 11.099 1.318 Yes No daN#6e4Z+;
R0603 R14 R0603 2 Bottom 270 12.918 1.284 Yes No .~Y%
AI
R0603 R15 R0603 2 Bottom 270 22.619 1.131 Yes No > a"4aYj
R0603 R16 R0603 2 Bottom 0 41.902 40.957 Yes No F2WMts
R0603 R17 R0603 2 Bottom 180 15.487 14.532 Yes No 1WJ%n;
R0603 R18 R0603 2 Bottom 180 15.487 16.160 Yes No rG"QK!R5
R0603 R19 R0603 2 Bottom 180 42.085 36.832 Yes No Ou,Eu05jt'
R0603 R20 R0603 2 Bottom 180 26.741 8.333 Yes No 6eq`/~#
R0603 R21 R0603 2 Bottom 90 20.922 1.127 Yes No }$D{YHF
R0603 R23 R0603 2 Bottom 90 33.598 12.731 Yes No 5nh:S0M6V
R0603 R24 R0603 2 Bottom 0 -4.395 45.472 Yes No x^u[L$
R0603 R25 R0603 2 Bottom 0 11.852 42.442 Yes No w8298Kl
R0603 R31 R0603 2 Bottom 180 28.326 37.121 Yes No |p"4cG?)
R0603 R32 R0603 2 Bottom 180 28.352 38.924 Yes No vm4q1!!(
R0603 R33 R0603 2 Bottom 180 28.352 40.561 Yes No fNNik7
R0603 R34 R0603 2 Bottom 180 28.295 33.722 Yes No q+ )csgN
R0603 R35 R0603 2 Bottom 180 28.326 35.398 Yes No +E8}5pDt
R0603 R40 R0603 2 Bottom 90 24.264 1.127 Yes No >7j(V`i"y
R0603 R47 R0603 2 Bottom 270 22.119 47.963 Yes No C
YKW4
R0603 R48 R0603 2 Bottom 270 19.382 47.963 Yes No ^_o9%)RL(
R0603 R50 R0603 2 Bottom 0 41.268 15.363 Yes No @ 9q/jv`
R0603 R51 R0603 2 Bottom 0 41.268 16.840 Yes No Tj_~ BT
R0603 R53 R0603 2 Bottom 90 36.325 12.481 Yes No y+K21(z.
R0603 R56 R0603 2 Bottom 180 26.722 11.882 Yes No gW_^GrK pI
R0603 R57 R0603 2 Bottom 180 29.789 10.239 Yes No FEqR7
R0603 R60 R0603 2 Bottom 90 31.083 18.516 Yes No &Dw8GU}1
TP TP1 TP 1 Bottom 0 4.383 44.621 Yes No \[F4ooe
TP TP6 TP 1 Top 0 24.343 58.517 Yes No /m+q!yi &
TP TP7 TP 1 Top 0 24.296 55.523 Yes No 1h0cId8d
TP TP8 TP 1 Top 0 24.236 51.537 Yes No 7\p<k/TS
TP TP9 TP 1 Bottom 0 24.992 47.638 Yes No @o6^"
TP TP11 TP 1 Bottom 0 2.863 47.368 Yes No 7.DAwx.HYK
CPR8850F00 U1 EAB5001V01 62 Bottom 270 1.720 23.987 Yes Yes 3t^r;b
APL3202B_0 U2 SOT23-5 5 Bottom 270 12.250 44.759 Yes No a eo/4
XPT8871-SOP8 U3 XPT8871-SOP8 8 Bottom 90 35.331 18.856 Yes No 6yRxb(
ngC|BLT%h
