ITEM | QTY | Ref. Des. | Description | Manufacturer | Part Number | 1 | 5 | C1-C3, C8, C9 | CAP., 1000pF, X7R, 50V, 10%, 0402, SINGLE SOURCE ONLY | MURATA | GRM155R71H102KA01J | 2 | 3 | C4, C6, C7 | CAP., 1.2pF, C0G, 50V, ±0.25pF, 0402, SINGLE SOURCE ONLY | MURATA | GJM1555C1H1R2CB01D | 3 | 1 | C5 | CAP., 10pF, C0G, 50V, 5%, 0402, SINGLE SOURCE ONLY | MURATA | GRM1555C1H100JZ01D | 4 | 2 | C10, C11 | CAP., 10nF, X7R, 50V, 10%, 0402, SINGLE SOURCE ONLY | MURATA | GRM155R71H103KA88D | 5 | 1 | C12 | CAP., 2.2uF, X5R, 10V, 10%, 0603, SINGLE SOURCE ONLY | MURATA | GRM188R61A225KE34D | 6 | 3 | E1,E2,E3 | TEST POINT,TURRET,0.061",MTG. HOLE | MILL-MAX | 2308-2-00-80-00-00-07-0 | 7 | 3 | J1-J3 | CONN., SMA, 50Ω Edge-Launch | E.F. Johnson | 142-0701-851 | 8 | 3 | L1-L3 | IND., 6.8nH, 2%, 0402, WIRE-WOUND | COILCRAFT | 0402HP-6N8XGL | 9 | 1 | L4 | IND., 1.5nH, ±0.3nH,0402, MULTILAYER | MURATA | LQG15HS1N5S02 | 10 | 1 | R1 | RES., 0Ω JUMPER, 0402 | VISHAY | CRCW04020000Z0ED | 11 | 1 | T1 | XFMR, 1:1, 4.5-3000 MHz | MINI-CIRCUITS | TC1-1-13M+ | 12 | 1 | T2 | XFMR, 4:1, 3300-4200 MHz | MINI-CIRCUITS | NCS4-442+ | 13 | 1 | U1 | IC, LTC5562IUC, QFN 10 PIN, 2mm x 2mm | LINEAR TECH | LTC5562IUC |
