查看: 7119|回复: 30
[Pads_VX.2x] 量产手机板MT53 pcb SCH
终身成就奖原创先锋奖特殊贡献奖优秀斑竹奖金点子奖
发表于 2018-11-12 21:01:15 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
项目数量参考编号元件名称制造商数值封装
11J8084PINS_PITCH1.5CON-4PIN-SIDEKEY-PITCH1.5
21X4017M26000018TXC7M26000018CRYSTAL_4PIN_3.2X2.5_TXC
31U1017M26000028TXC7M26000028CRYSTAL_4PIN_3.2X2.5_TXC
42J3 J902ANT_TEST_H2312ANT_TEST_H2312
52R100 R925ANT_TP_TEST_0.5DJANT_TP_TEST_0.5
61U301APL3206APL3206APL3206
73B502 B507-508B0402-BK1005HM102-TBK1005HM102-TBEAD0402
84B201-204B0402-BK1005LL470-TBK1005LL470-TBEAD0402
96C701 C703-704 C706 C715-716C0402_1.0PFCAP0402_HQ
108C104-107 C136-139C0402_1.8PFGRM1555C1H1R8CZ01-(D/J)CAP0402_HQ
1130C2-3 C124-126 C305-309 C401 C502-503 C507-508 C632 C708-710 C721 C723C742-745 C906 C910 C922-924C0402_100NFLMK105BJ104KV-FCAP0402_HQ
122C511 C831C0402_100PFGRM1555C1H101JZ01-(D/J)CAP0402_HQ
131C828C0402_10NFGRM155R7(1C/1E)103KA01-(D/J)CAP0402_HQ
145C130 C145 C530-531 C705C0402_1NFGRM155R71H102KA01-(D/J)CAP0402_HQ
1535C121 C123 C201-202 C301 C303-304 C313 C318-320 C322-328 C330 C333C406-407 C415-416 C601-603 C605 C702 C707 C725 C810 C827 C833 C925C0402_1UFJMK105BJ105KV-FCAP0402_HQ
1610C423-424 C410-414 C420-422C0402_1UF1uFCAP0402_HQ
173C408-409 C417C0402_1UF100nFCAP0402_HQ
187C115-116 C122 C127 C134 C311-312C0402_22PFGRM1555C1H220JZ01-(D/J)CAP0402_HQ
1915C108-110 C117 C205-206 C504 C506 C509-510 C512 C515-516 C830 C832C0402_33PFGRM1555C1H330JZ01-(D/J)CAP0402_HQ
202C404-405C0402_33PF3.9nFCAP0402_HQ
211C425C0402_33PF33pFCAP0402_HQ
221C132C0402_5.6PFGRM1555C1H5R6CZ01-(D/J)CAP0402_HQ
2324C4 C101-103 C111-114 C119 C129 C131 C140-141 C505 C620 C625 C630-631C635-636 C822 C829 C915-916C0402_NCNCCAP0402_HQ_NC
246C711 C901 C903-905 C920C0603_2.2UFJMK107BJ225KA-TCAP0603
2510C302 C314-317 C321 C513-514 C902 C918C0603_4.7UFJMK107BJ475KA-TCAP0603
261C826C0603_4.7UF4.7uFCAP0603
271C501C0805_10UFJMK212BJ106MG-TCAP0805
281C340C0805_1UFEMK212BJ105KD-TCAP0805
291C329C0805_22UFJMK212BJ226MG-TCAP0805
301C133C0805_NCNCCAP0805_NC
314J803-805 J807CAF99-06153-1503CAF99-06153-1503CAF99-06153-1503
321J608CAM_CON_24PIN_S808CAMERA_CON_24PIN_D757
333C429-430 C1261CAP-100N_10%_X5R_16V-0402GRM155R61C104K*100nFCAP0402
342C1260 C1263CAP-100N_10%_X5R_16V-0402GRM155R61C104K*NCCAP0402
351C15CAP-100P_5%_COG_50V-0402GRM1555C1H101J*//CM05CG101J50AH/CC0402JRNPO9BN101100pFCAP0402
362C730 C734CAP-10N_10%_X7R_16V-0402GRM155R71C103K*//CM05X7R103K16AH10nFCAP0402
371C823CAP-10U_10%_X5R_6.3V-0805GRM21BR60J106KE19L/CM21X5R106K06AT10uFCAP0805
381C825CAP-10U_10%_X5R_6.3V-0805GRM21BR60J106KE19L/CM21X5R106K06AT10uCAP0805
392C907 C921CAP-12P_5%_COG_50V-0402CM05CG120J50AH/GRM155C1H120J*12pFCAP0402
401C909CAP-12P_5%_COG_50V-0402CM05CG120J50AH/GRM155C1H120J*1pFCAP0402
412C911 C914CAP-12P_5%_COG_50V-0402CM05CG120J50AH/GRM155C1H120J*1uFCAP0402
422C913 C917CAP-12P_5%_COG_50V-0402CM05CG120J50AH/GRM155C1H120J*100pFCAP0402
431C912CAP-12P_5%_COG_50V-0402CM05CG120J50AH/GRM155C1H120J*8.2pFCAP0402
441C919CAP-12P_5%_COG_50V-0402CM05CG120J50AH/GRM155C1H120J*100nFCAP0402
451C908CAP-12P_5%_COG_50V-0402CM05CG120J50AH/GRM155C1H120J*15pFCAP0402
462C820-821CAP-15N_10%_X7R_16V-0402CC0402KRX7R7BB15315nFCAP0402
4710C728-729 C731-733 C735-739CAP-1UF_+/-10%_X5R_6.3V-0402GRGRM155R60J105K*//CV05X5R105K06AH1uFCAP0402
481C608CAP-2.2U_10%_X5R_6.3V-0603GRM188R60J225K*//CM105X5R225K06AH2.2uFCAP0603
491C426CAP-220P_10%_X7R_50V-0402GRM155R71H221K*//CM05X7R221K50AH220pFCAP0402
502C9-10CAP-33P_5%_COG_50V-0402GRM1555C1H330J*//CM05CG330J50AH33pFCAP0402
511C427CAP-390P_10%_X5R_50V-0402CM05X5R391K50AH390pFCAP0402
522C418-419CAP0402_100N100nFSC0402
531C428CAP_0402A100pFCAP0402_HQ
541J303CON-BAT_3PIN_PAN37-03273-1004-LCNPAN35-02623-1501PAN35-02623-1501CON-BAT_3PIN_PAN37-03273-1004-LCN
551J302CON-BAT_PAN26-03432-1500_LCN_V818PAN26-03432-1500PAN26-03432-1500CON-BAT_PAN26-03432-1500++
561J304CON-DC_JACK_DC_0097_002CON-DC_JACK_DC_0097_002
571J1CON-I/O_10PIN_U02-1B1F380A-2318CON-I/O_10PIN_U02-4B1B380A-2318
581J606CON-LCM_12PIN_0.8CON-LCM_12PIN_0.8
591X301CRYSTAL_MS3V_T1R_12.5RFSSP-T7-FCRYSTAL_MS3V-T1R_T7_12.5PF(KDS_XTAL_SM)
602C402-403C_0402A8.2nFCAP0402_HQ
613D820-822DF5320_BRIGHTA-LIGHTD2311_SPEAKER
6249S1-14 S18-28 S30 S32-34 S36-47 S50 S112-115 S119 S121 S123DOMED4.8MMDOMED4MM
632S29 S35DOMED4MMDOMED4MM
641J501EAR_JACK_HZ-PJACK035-E_DH5340LinkconnEAR_JACK_DH5340
652D501 D503ESD9X5V-2/TR_DF2S6.8FSESD9X5V-2/TR_DF2S6.8FSESD9X5V-2/TR_DF2S6.8FS
665D604-607 D701ESD9X5V-2/TR_DF2S6.8FS_NCNCESD9X5V-2/TR_DF2S6.8FS_NC
671U103FAR_G6KG_1G8425-Y4PAFUJITSUFAR_G6KG_1G8425-Y4PAFAR_G6KG_1G8425-Y4PA
684F1-4FIDUCIAL_WITHPASTEFIDUCIALFIDUCIAL_WITHPASTE
691U603FT690WFT690WBGA_9PIN_1.463_1.463
702U704-705IC-ANALOG_SWITCH_MT6302_MTKMT6302N-LMT6302N-LIC-ANALOG_SWITCH_MT6302_MTK
711U902IC-LDO-DUAL_2.8V_1.8V_SOT236_RICHTEKRT9011-MGPJ6LDO-2.8/1.8VSOT-23-6
721U901IC-LDO_2.8V/300MA_RP9193-SOT235RP9193-28PBRP9193-28PBRP9193-28PB
731U102IC-RFPA_SKY77518_SKYWORKSSKY77518SKY77518IC-RFPA_SKY77518-SKYWORKS
741U904IC-WIFI-MT5921AMT5921A BGA7*7MT5921_BGA_7X7
751U801IC_AUDIO_AW8731IC_AUDIO_AW8731
764B401 B501 B503-504IND-FERR_BEAD-100MHZ_BLM15AG601SN1D_0402BLM15AG601SN1DBLM15AG601SN1DBEAD0402
775L903-907IND-ML-1.5NH_0.3NH_ELJRF1N8DFB_0402LQG15HN1N5S02D4.3nHIND0402
782L504-505IND-ML-39NH_5%_LQG15HS39NJ02D-0402LQG15HS39NJ02D39nHIND0402
791L404IND-ML-68NH_+/-5%_R34111106800A_0402LQG15HN68NJ02D68nHIND0402
801L405IND-ML-68NH_+/-5%_R34111106800A_0402LQG15HN68NJ02D180nHIND0402
811L403IND-ML-8.2NH_0.3NH_LQG15HN8N2S02D-0402LQG15HN8N2S02D8.2nHIND0402
821L501IND-MULTILAYER-10UH-0603MLF1608E100KT10uHIND0603
832L401-402IND0402_0R0RSL0402
841J806JON_20PIN_PITCH0.8JON_20PIN_PITCH0.8
852L705-706L0402_15NHIND0402_HQ
862L106 L115L0402_18NHHK100518NJ-TIND0402_HQ
872L707-708L0402_3.3NHIND0402_HQ
881L103L0402_3.9NHHK10053N9S-TIND0402_HQ
892L111 L114L0402_4.7NHHK10054N7S-TIND0402_HQ
903B505-506 R726L0402_56NHHK100556NJ-TIND0402_HQ
918L102 L104-105 L108 L702 L720 L901-902L0402_NCNCIND0402_HQ_NC
921L301L0805_2.2UHCIG21W2R2MNEIND0805
931L302L0805_4.7UHCIG21W4R7MNEIND0805
941J607LCM_36PIN_DF5340CON-LCM_36PIN_DF5340
951J604LCM_37PINCON-LCM_37PIN_D2331
9616D801-816LED0603LED0603
971J2MM8430-2610MM8430-2610MM8430-2600
981U402MT5132-LQFP78_4AMT5192-QFN68?
991U201MT6253N-LMT6253N-LAQFN261_11.5X11.5X0.85_MT6253
1001U701MT6612N/AF-LMT6612N/AF-LQFN40_5X5_MT6612N
1011ANT103PAD_ANT2X3PAD2X3
1021J5PAD_ANT_2.2X3ANT_2.2_3
1033ANT2 ANT101 J701PAD_ANT_2X3PAD_ANT_2X3
1041J401PAD_ANT_3.5X3.7ANT_3.5X3.7
1052J503-504PAD_SPK/REC/MOT_1X2TP_2.0X5.0
1062SPK1+2-3PAD_SPK/REC/MOT_1X2TP_1.0X2.0
1072J101-102PAD_SPK/REC/MOT_2.0X6PAD_2.0X6
1081U401PF38F3040M0Y3DEPF38F3040M0Y3DEBGA56_6.2X7.7/8X9.2_1.1
1091D1PG05BSESCESD1P0RFLCAP0402_HQ
1102R502-503R0402_1.5KRC0402JR-071K5LRES0402_HQ
11112R205 R311 R613 R810-811 R901-903 R905 R909-910R0402_100KRC0402JR-07100KLRES0402_HQ
1121R919R0402_100K910KRES0402_HQ
1132R508-509R0402_100RRC0402JR-07100RLRES0402_HQ
1149R102 R507 R601-606 R805R0402_10KRC0402JR-0710KLRES0402_HQ
1151R703R0402_15KRC0402JR-0715KLRES0402_HQ
11612D502 R105 R107-109 R301 R310 R501 R504 R512-514R0402_1KRC0402JR-071KLRES0402_HQ
1171R612R0402_220RRC0402JR-07220RLRES0402_HQ
1182R104 R809R0402_24KRC0402JR-0724KLRES0402_HQ
1192R505-506R0402_2KRC0402JR-072KLRES0402_HQ
1201R201R0402_5.1K_FRC0402FR-075K1LRES0402_HQ
1211R114R0402_51RRC0402JR-0751RLRES0402_HQ
1223R305 R402 R808R0402_NCNCCAP0402
12330B303 B630 B801 B803-804 L109-110 R5 R101 R106 R112 R304 R306 R309 R401R403 R706 R708 R710-712 R714-715 R906-908 R911 R913-915R0402_ORRC0402JR-070RLRES0402_HQ
1242R713 R709R0402_ORNCRES0402_HQ
1251B302R0603_ORRC0603JR-070RLRES0603
1261R336R0805-0.2RRL0805FR-7W0R2LRES0805
1271U1RDA5802HSRDA5802HSQFN20_3X3_0.9_RDA
1282R817-818RES0402IPC SM-782 STD.100RRES0402
1296R12 R410 R415-417 R705RES-0R_5%_1/16W-0402MCR01MZPJ000//RC0402JR-070RL0RRES0402
1301R826RES-100K_5%_1/16W-0402MCR01MZPJ104// RC0402JR-07100KL100KRES0402
1311R917RES-100K_5%_1/16W-0402MCR01MZPJ104// RC0402JR-07100KL16k/1%RES0402
1324R819-821 R823RES-10K_5%_1/16W-0402MCR01MZPJ103// RC0402JR-0710KL10KRES0402
1331R412RES-10R_5%_1/16W-0402MCR01MZPJ100// RC0402JR-0710RL10RRES0402
1341R916RES-10R_5%_1/16W-0402MCR01MZPJ100// RC0402JR-0710RL18RRES0402
1352R632 R822RES-2.2K_5%_1/16W-0402RC0402JR-072K2L2.2KRES0402
1361R812RES-39R_5%_1/16W-0402RC0402JR-0739RL39RRES0402
1372R407-408RES-510R_5%_1/16W-0402RC0402JR-07510RL510RRES0402
1382R405-406RES-680R_5%_1/16W-0402RC0402JR-07680RL680RRES0402
1393RN401-403RN-1K470Ω8P4R-BR
1401U903RTC6667
1411U104SAFEA1G96FA0F00R14MURATANCSAW1410
1421U105SAFEA881MFL0F00MURATANCSAW1410
1431S824SWITCH-NSS507-212F-CCCG1T_OD_08081401
1442TP1 TP4TP_0.5TP0.5TP_0.5
1452MIC+501 MIC-502TP_1.2X3.0TP_1.2X3.0
1461TP301TP_1.8_PRODUCTIONTP1.5TP_1.8_6PIN
1472QN801-802TRAN-BJT-NPN_BC847BT_PHILIPSSOT-323
1481D301UDZSTE-175.1BUDZSTE-175.1BUMD2
1491J602WKTFH010_SO3WKTFH010_SO3CON-TFLASH_TFS07-8K30000
1501U905XTL581100-M118-042CRYSTAL_4PIN_3.2X2.5_TXC
评分
参与人数 1威望 -5 收起 理由
老吴 -5 重复。http://bbs.ntpcb.com/read.php?tid=281
查看全部评分
重要提示:PCB作品文件展下载说明
 楼主| 发表于 2018-11-12 21:02:29 | 显示全部楼层
[hide=2,money] mt53.sch.rar (171 KB, 下载次数: 4) mt53.pcb.rar (1.83 MB, 下载次数: 4)
[/hide]
发表于 2018-11-12 21:26:19 | 显示全部楼层
    无聊
    前天 17:42
  • 签到天数: 82 天
    社区居民忠实会员社区劳模终身成就奖特殊贡献奖原创先锋奖优秀斑竹奖
    发表于 2018-11-13 07:02:04 | 显示全部楼层
    发表于 2018-11-13 07:16:40 | 显示全部楼层
    无聊
    2024-10-31 10:00
  • 签到天数: 5 天
    1元学习Allegro(230718)
    发表于 2018-11-13 08:31:03 | 显示全部楼层
    PADS20220105初级班
    发表于 2018-11-13 08:43:37 | 显示全部楼层
    参考参考学习学习。。
    1元学习Allegro(1期)
    发表于 2018-11-13 08:45:51 | 显示全部楼层
    谢谢分享谢谢分享谢谢分享
    发表于 2018-11-13 08:49:58 | 显示全部楼层
    昨天 10:01
  • 签到天数: 44 天
    发表于 2018-11-13 08:53:03 | 显示全部楼层
