查看: 4163|回复: 9
[Allegro16.6以下] i.MXRT160EVKDS评估套件原理图PCB
终身成就奖原创先锋奖特殊贡献奖优秀斑竹奖金点子奖
发表于 2018-11-13 21:20:53 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
ItemNumberQuantityAGILE_PNASSY_OPTValueDESCRIPTIONMFG_NAME01MFG_PN01
183470-753940RES MF ZERO OHM 1/16W 5% 0402ROHMMCR01MZPJ000
218470-75557DNP10KRES MF 10K 1/16W 5% 0402VISHAY INTERTECHNOLOGYCRCW040210K0JNED
32180-7633690OHMIND CHK 90 OHM@100MHZ 330MA 25% 0805MURATADLW21HN900SQ2L
41150-7850347uFCAP CER 47UF 6.3V 10% X5R 1206MURATAGRM31CR60J476KE19L
531150-784634.7uFCAP CER 4.7UF 6.3V 20% X5R 0402TDKC1005X5R0J475M050BC
610480-79672RB521S30DIODE SCH RECT 200MA 30V AEC-Q101 SOD-523NEXPERIARB521S30,115
737470-75394DNP0RES MF ZERO OHM 1/16W 5% 0402ROHMMCR01MZPJ000
8145150-756340.1UFCAP CER 0.1UF 10V 10% X5R 0402KEMETC0402C104K8PAC
96470-80199DNP0.02RES MF 0.02 OHM 1/10W 1% 0603VISHAY INTERTECHNOLOGYWSL0603R0200FEA
1034470-755551KRES MF 1.0K 1/16W 5% 0402VISHAY INTERTECHNOLOGYCRCW04021K00JNED
115470-75555DNP1KRES MF 1.0K 1/16W 5% 0402VISHAY INTERTECHNOLOGYCRCW04021K00JNED
121480-77157NUP2105LDIODE DUAL LINE CAN BUS PROTECTOR 27V 350W SOT-23On semiconductorNUP2105LT1G
132150-763354.7PFCAP CER 4.7PF 50V 0.25PF C0G 0402MURATAGRM1555C1H4R7CA01D
141470-309276.49KRES MF 6.49K  1/16W 1%0402WALSIN TECHNOLOGY CORP.WR04X6491FTL
155210-81490DNPHDR 1X2HDR 1X2 TH 100MIL SP 339H AU 98LANYTRONIC CORPORATION LIMITED0901S0202011N9T-31RF
168180-78156330 OHMIND FER BEAD 330OHM@100MHZ 1.7A 0603TDKMPZ1608S331A
171470-7790093.1RES MF 93.1 OHM 1/8W 1% AEC-Q200 0603KOA SPEERRK73H1JTTD93R1F
1814150-7867510uFCAP CER 10UF 10V 10% X5R 0603MURATAGRM188R61A106KE69D
194470-7608312.0KRES MF 12.0K 1/16W 1% 0402BOURNSCR0402-FX-1202GLF
207470-766022.2KRES MF 2.2K 1/16W 5% 0402YAGEO AMERICARC0402JR-072K2L
2145470-7555710KRES MF 10K 1/16W 5% 0402VISHAY INTERTECHNOLOGYCRCW040210K0JNED
221312-80418DNPFXOS8700CQIC ACCELEROMETER AND MAGNETOMETER SENSOR 3-AXIS 2.5V QFN16Freescale SemiconductorFXOS8700CQ
232150-7526510PFCAP CER 10PF 50V 5% C0G 0402AVX04025A100JAT2A
242180-786744.7uHIND WW FER 4.7uH@1MHz 1.4A 20% 4012TDKVLS4012ET-4R7M
259470-756264.7KRES MF 4.7K 1/16W 5% 0402NIC COMPONENTS CORPNRCL04J472TRF
261470-31102243KRES MF 243K 1/10W 1% AEC-Q200 0402KOA SPEERRK73H1ETTP2433F
271315-81422UM1550S-18IC LIN VREG LDO 1.8V 250MA 1.8-8V SOT23-3Union Semiconductor, IncUM1550S-18
2813510-75618TP_35MILTEST POINT PAD .035 SMT, no part to order
292370-75079REDLED ULTRA BRIGHT RED SGL 30MA 0603LITE ONLTST-C190KRKT
302470-31088180KRES MF 180K 1/10W 1% AEC-Q200 0402KOA SPEERRK73H1ETTP1803F
311312-8175174LVC2T45DCIC TRANSLATING XCVR DUAL BIT/SUPPLY TS 1.2-5.5V VSSOP8NEXPERIA74LVC2T45DC
3214470-75597100KRES MF 100K 1/16W 5% 0402VENKEL COMPANYCR0402-16W-104JT
335480-76937ESD5B5.0ST1GDIODE SUPPRESSOR 16A@30NS 5V@1UA SOD-523on semiconductorESD5B5.0ST1G
341510-77990DHN-04SW 4P SPST DIP 25MA 24V SMTDIPTRONICS MANUFACTURINGDHN-04-V
352210-78092DNPCON_2_RCACON 2 RCA SKT RA TH BLACK -- 512H SNKYCONKLPX-0848A-2-B
3610150-757721.0UFCAP CER 1.0UF 10V 10% X5R 0402YAGEO AMERICACC0402KRX5R6BB105
371315-80564UM805REIC VOLT MONITOR 2.63V VTH RST 1-5.5V SOT143Union Semiconductor, IncUM805RE
385150-7846722UFCAP CER 22UF 6.3V 20% X5R 0603SamsungCL10A226MQ8NRNE
3922150-762710.22uFCAP CER 0.22UF 6.3V 20% X5R 0402MURATAGRM155R60J224ME01
406150-75720DNP15PFCAP CER 15PF 16V 5% C0G 0402KEMETC0402C150J4GAC
412312-8127774LVC1T45GW,125IC XCVR XLATING DUAL 3-STATE 1.2- 5.5V TSSOP6NEXPERIA74LVC1T45GW,125
425470-75626DNP4.7KRES MF 4.7K 1/16W 5% 0402NIC COMPONENTS CORPNRCL04J472TRF
434470-75597DNP100KRES MF 100K 1/16W 5% 0402VENKEL COMPANYCR0402-16W-104JT
443470-31093200KRES MF 200K 1/10W 1% AEC-Q200 0402KOA SPEERRK73H1ETTP2003F
452150-78467DNP22UFCAP CER 22UF 6.3V 20% X5R 0603SamsungCL10A226MQ8NRNE
464510-77562SPST PBSW SPST MOM NO PB TACT 50mA 50V SMTE SWITCHTL3301AF260QG/TR
474470-7543249.9RES MF 49.9 OHM 1/10W 1% 0603BOURNSCR0603-FX-49R9ELF
482210-81617SKT_1X8CON 1X8 SKT TH 100MIL SP 344H AU 118LANYTRONIC CORPORATION LIMITED08001S3 0811-29RF
491210-81618SKT_1X10CON 1X10 SKT TH 100MIL SP 344H AU 118LANYTRONIC CORPORATION LIMITED08001S3 1011-29RF
501210-80775BH25420B301CON 2X10 PLUG SHRD TH 100MIL CTR 366H AU 118LSHENZHEN ATOM TECHNOLOGY CO.,LTDBH25420B301
512560-75273DNPTTWB1010LXFMR SMT 780UH/780UH/250MA WIDEBAND XFMR6_6.6X6.2COILCRAFTTTWB1010LD
521312-80763NTSX2102GU8HIC DUAL SUPPLY XCVR 50 MBPS 5.5V XQFN8NXP SemiconductorsNTSX2102GU8H
531312-80889NTS0102IC XCVR 2-BIT 1.65-3.6V/2.3-5.5V TSSOP8NXP SEMICONDUCTORSNTS0102DP
541510-77987EM6022PAUDIO DEVICE MIC 0.5MA 2V 38-48+/-3dB 2.2KOHM 6MM THSoberton IncEM6022P
554210-301555006TEST POINT BLK 70X220 MIL THKeystone Electronics5006
562480-77039FDMA530PZTRAN PMOS PWR 30V 6.8AFAIRCHILDFDMA530PZ
572510-77990DNPDHN-04SW 4P SPST DIP 25MA 24V SMTDIPTRONICS MANUFACTURINGDHN-04-V
583315-80554UM1750S-00IC VREG LDO ADJ 1-5V 350mA 2.5-6V SOT23-5Union Semiconductor, IncUM1750S-00
592480-753172SK3018TRANS MOSFET N-CH 30V .1A SOT-323ROHM2SK3018T106
601211-80120CON_1X24CON 1X24 FPC/FFC RA SKT SMT 0.5MM SP 146H SN/AUSHENZHEN ATOM TECHNOLOGY CO.,LTDFPC05024-09200
611470-804871.5KRES MF 1.5K 1/16W 1% 0402BOURNSCR0402-FX-1501GLF
621470-30297220RES MF 220 OHM 1/10W 5% 0603YAGEO AMERICARC0603JR-07220RL
634150-75265DNP10PFCAP CER 10PF 50V 5% C0G 0402AVX04025A100JAT2A
641480-75997MBR120VLSFT1GDIODE SCH RECT 1A 20V SMTON SEMICONDUCTORMBR120VLSFT1G
651210-30004DNPSHORT_100milCON 2 JUMPER MALE 2.54MM SP 157H AUPRECI-DIP CONNECTION TECHNOLOGY999-11-110-10
663470-30454100RES MF 100 OHM 1/16W 1% 0402THYE MING TECH CO LTDCR-02FL6--100R
671315-80508MP2144GJIC SYNC STEP-DOWN SW 1.2MHZ 0.6V 2A 2.5-5.5V TSOT23-8MONOLITHIC POWER SYSTEMSMP2144GJ
681470-3101540.2KRES MF 40.2K  1/16W 1%0402YAGEO AMERICARC0402FR-0740K2L
691312-81479TJA1057GT/3IC XCVR CAN 4.75-5.25V/2.95-5.25V AEC-Q100 SO8NXP SEMICONDUCTORSTJA1057GT/3
702470-7659030KRES MF 30K 1/16W 1% 0402THYE MING TECH CO LTDCR02FL6-30K
711334-77760IS42S16160J-6BLIIC MEM DRAM 16MX16 166MHZ SYNC 3.0-3.6V TFBGA54ISSIIS42S16160J-6BLI
7216210-81490HDR 1X2HDR 1X2 TH 100MIL SP 339H AU 98LANYTRONIC CORPORATION LIMITED0901S0202011N9T-31RF
736150-7572015PFCAP CER 15PF 16V 5% C0G 0402KEMETC0402C150J4GAC
741480-75982MBRA160T3GDIODE SCH PWR RECT 1A 60V CASE 403DON SEMICONDUCTORMBRA160T3G
751480-78465MMBT3906TT1GTRAN PNP GEN AMP 200MA 40V AEC-Q101 SC75ON SEMICONDUCTORMMBT3906TT1G
762470-760643.3KRES MF 3.3K 1/16W 5% 0402YAGEO AMERICARC0402JR-073K3L
772150-7679633UFCAP CER 33UF 6.3V 20% X5R 1210MURATAGRM32DR60J336ME19L
783470-31135464KRES MF 464K 1/10W 1% AEC-Q200 0402KOA SPEERRK73H1ETTP4643F
791180-777971uHIND PWR 1UH@100KHZ 2.6A 30% SMTShenzhen Sunlord Electronics Co., LtdSWPA4020S1R0NT
801750-77763CON 1X40 + CON 1X6 + TFT DISPLAYSUBASSEMBLY CON 1X40 FPC SMT RA + CON 1X6 FPC/FFC RA SKT + TFTDISPLAY 4.3INCHSUBASSEMBLY211-79974,211-79976,375-00010
812150-76630DNP18PFCAP CER 18PF 50V 1% C0G 0402YAGEOCC0402FRNPO9BN180
821470-7623875.0RES TF 75.0 OHM 1/8W 1% 0805YAGEO AMERICARC0805FR-0775RL
832150-300820.01UFCAP CER 0.01UF 16V 20% X7R 0402AVX0402YC103MAT2A
841370-75097LED_RED-GRNLED RED GRN DUAL 30/25MA SMTKINGBRIGHTAPB3025ESGC-F01
858180-77771120 OhmIND FER BEAD 120 OHM@100MHZ 0.5A 25% 0402MurataBLM15AG121SN1D
861470-79978DNP1MRES MF 1M 1/10W 5% AEC-Q200 0402KOA SPEERRK73B1ETTP105J
874280-76498DNP.635" LONGFASTENER, STANDOFF 4.5MMX3.53XM3.0X0.5 ROUND THR .635"LBRASSUNICORPMSS251-R-1-A-16
881370-76549GREENLED GRN SGL 25MA 0603KINGBRIGHTKPT-1608SGC
891470-80029374RES MF 374 OHM 1/8W 1% 0805VISHAY INTERTECHNOLOGYCRCW0805374RFKEA
901211-79704PJ31360-ICON 6 AUD JACK RA SMT -- 191H AUSHENZHEN ATOM TECHNOLOGY CO.,LTDPJ31360-I
913312-81574NX5P3090UKIC USB PD TYPE C CURRENT LIMITED PWR SW 2.5-5.5V WLCSP12NXP SEMICONDUCTORSNX5P3090UK,012
921470-3096515KRES MF 15K  1/16W 1%0402WALSIN TECHNOLOGY CORP.WR04X1502FTL
933150-75634DNP0.1UFCAP CER 0.1UF 10V 10% X5R 0402KEMETC0402C104K8PAC
941480-77217MM5Z5V1ST1GDIODE ZNR -- 0.2W 5.1V AEC-Q101 SOD523ON SEMICONDUCTORMM5Z5V1ST1G
951211-79967RJ45_YLW+GRNCON 12 RJ45 SHLD RA SM 1.02MM SP 625H --HanRun Electronics Co., LtdHR961160C
962470-7584710RES MF 10 OHM 1/10W 5% 0603BOURNSCR0603-JW-100ELF
972150-76334DNP1000pFCAP CER 1000PF 50V 5% C0G 0402MURATAGRM1555C1H102JA01D
983470-76240100KRES MF 100K 1/16W 1% 0402YAGEO AMERICARC0402FR-07100KL
993211-80104USB_MICROAB_RECEPTACLECON 5 USB MICRO_AB RA SKT SMT 0.65MM SP 110H AUANYTRONIC CORPORATION LIMITED23971101#LCP-58RF
1002470-81890270RES MF 270 OHM 1/16W 5% 0402YageoRC0402JR-07270RL
1012150-3010927PFCAP CER 27PF 50V 5% C0G 0402KEMETC0402C270J5GAC
1021480-79704BSH111BKTRAN NMOS SW FET 55V 210mA SOT23NEXPERIABSH111BKR
1031312-81089KSZ8081RNBIC XCVR 10/100M EPHY 3.3V QFN32MicrelKSZ8081RNBIA
1041342-00655S26KS512SDPBHI02IC MEM FLASH 512 Mbit (64 Mbyte) Octal SPI 1.8V 166MHz BGA24CYPRESS SEMICONDUCTORS26KS512SDPBHI02
1051230-7745224MHZXTAL 24MHZ -- 30PPM 3.2X2.5MM SMDTXC CORP7V24000002
1062470-7867462.0RES MF 62.0 OHM 1/4W 1% AEC-Q200 0805KOA SPEERRK73H2ATTD62R0F
1072150-3026956PFCAP CER 56PF 50V 5% C0G 0402MURATAGRM1555C1H560JA01D
1081480-75205DNPSRV05-4DIODE TVS ARRAY 12A 5V 300W SOT23_S6SEMTECH CORPSRV05-4.TCT
1091480-77718IRLML6401TRAN PMOS PWR 12V 4.3A SOT23INTERNATIONAL RECTIFIERIRLML6401TRPBF
1102480-78843RClamp0854P.TCTDIODE TVS ARRAY 3 5.5V SLP1616P6SEMTECH CORPRClamp0854P.TCT
1111312-30127NL17SZ126DFIC BUF TS 1.65-5.5V SOT-353ON SEMICONDUCTORNL17SZ126DFT2G
1123150-794542.2uFCAP CER 2.2uF 6.3V 10% X5R 0402MURATAGRM155R60J225KE95
1133211-76642TPAD_030TEST POINT PAD 30MIL DIA SMT, NO PART TO ORDERNOTACOMPONENTNOTACOMPONENT
1142470-82143100RES MF 100 OHM 1/16W 5% 0402YAGEO AMERICARC0402JR-07100RL
1151210-80780CON_1_PWRCON 1 PWR PLUG RA TH 2.5A 20V -- 441H SN/NISHENZHEN ATOM TECHNOLOGY CO.,LTDDC060024202
1161334-77734IS25WP064AJBLEIC MEM FLASH QPI 64Mb 1.65-1.95V SOIC8WISSIIS25WP064A-JBLE
1171315-81585NX3P191UKIC LOAD SW 1A 1.1-3.6V WLCSP4NXP SEMICONDUCTORSNX3P191UK,012
1181344-02176LPC4322JET100IC MCU  CORTEX M4 CORE512kB FLASH 2.4-3.6V BGA100NXP SEMICONDUCTORSLPC4322JET100E
1192150-763341000pFCAP CER 1000PF 50V 5% C0G 0402MURATAGRM1555C1H102JA01D
1201230-7808212MHZXTAL 12MHZ RSN -- 18PF 30PPM SMTABRACON CORPABLS2-12.000MHZ-D4Y-T
1211315-79450WM8960IC CODEC STEREO WITH CLASS D SPEAKER DRIVER 1.71-3.6V QFN32WOLFSON MICROELECTRONICSWM8960CGEFL/RV
1221230-7810232.768KHZXTAL 32.768KHZ 7PF 20PPM -- SMTEPSON ELECTRONICSFC-135 32.7680KA-AG3
1231315-80553UM803RSIC VOLT MONITOR 2.63V RST VTH 1-5.5V AUTO SOT-23Union Semiconductor, IncUM803RS
1241210-81467HDR 2X5HDR 2X5 TH 100MIL CTR 338H AU 98LANYTRONIC CORPORATION LIMITED0902S1005011N9T-31RF
1251180-77935DNPACT45B-510-2PFILTER COMMON MODE 51uH@100kHZ 200mA 50V AEC-Q200 SMTTDKB82787C513H2
1262470-31004DNP33KRES MF 33K  1/16W 1%0402YAGEO AMERICARC0402FR-0733KL
1271211-8016995220030-14RRFCON 8 SKT SD/MMC RA SMT 43MIL SP 84H AUANYTRONIC CORPORATION LIMITED95220030-14RRF
1281315-81072NC7WV04L6XIC INVERTER ULP-A DUAL 0.93.6V MICROPAK6FAIRCHILDNC7WV04L6X
1291TMP-WF-33767MIMXRT1064DVL6AIC CPU ARM Cortex-M7 600MHZ 1.3V MAPBGA196NXP SEMICONDUCTORSMIMXRT1064DVL6A
1301470-312102.2MRES MF 2.2M 1/10W 1% AEC-Q200 0402KOA SPEERRK73H1ETTP2204F
1311315-81383UM1661IC DCDC LED DRIVER BOOST 500KHz-2MHz 24V 1.5A 2-6V SOT23-6Union Semiconductor, IncUM1661
1321180-7821510uHIND WW FER 10uH@1MHz 0.99A 20% 4012TDKVLS4012ET-100M
1331150-30082DNP0.01UFCAP CER 0.01UF 16V 20% X7R 0402AVX0402YC103MAT2A
1341210-81616SKT_1X6CON 1X6 SKT TH 100MIL SP 344H AU 118LANYTRONIC CORPORATION LIMITED08001S3 0611-29RF
1351315-76725PRTR5V0U2XIC USB ESD PROTECTION 8KV SOT143PHILIPS SEMICONDUCTORPRTR5V0U2X
1361210-81491HDR_1X3HDR 1X3 TH 100MIL SP 338H AU 98LANYTRONIC CORPORATION LIMITED0901S0203011N9T-31RF
1371510-77598EG2209ASW DPDT SLD 0.1A 12V L=4 THE SWITCHEG2209A
1381210-81491DNPHDR_1X3HDR 1X3 TH 100MIL SP 338H AU 98LANYTRONIC CORPORATION LIMITED0901S0203011N9T-31RF
1392150-30297220PFCAP CER 220PF 50V 5% C0G 0402KEMETC0402C221J5GAC
1401210-81466HDR 2X5HDR 2X5 TH 50MIL CTR 172H AU 91LANYTRONIC CORPORATION LIMITED0922S0205011N9T-31RF
1411470-799781MRES MF 1M 1/10W 5% AEC-Q200 0402KOA SPEERRK73B1ETTP105J
重要提示:PCB作品文件展下载说明
 楼主| 发表于 2018-11-13 21:23:08 | 显示全部楼层
SCH-32221_A.zip (2.15 MB, 下载次数: 2) LAY-32221_A.zip (4.36 MB, 下载次数: 2)
    昨天 12:05
  • 签到天数: 142 天
    社区居民终身成就奖特殊贡献奖原创先锋奖
    发表于 2018-11-13 21:36:05 | 显示全部楼层
    发表于 2018-11-13 21:47:07 | 显示全部楼层
    1元学习Allegro(1期)
    发表于 2018-11-14 08:27:01 | 显示全部楼层
    谢谢分享谢谢分享谢谢分享
    3 天前
  • 签到天数: 64 天
    社区居民终身成就奖特殊贡献奖优秀斑竹奖
    发表于 2018-11-14 09:08:55 | 显示全部楼层
    发表于 2018-11-14 09:18:19 | 显示全部楼层
    发表于 2018-11-14 09:43:58 | 显示全部楼层
    社区居民终身成就奖优秀斑竹奖社区明星宣传大使奖特殊贡献奖原创先锋奖
    发表于 2018-11-14 09:44:47 | 显示全部楼层
    1元学习Allegro(2期)
    发表于 2018-11-14 11:47:17 | 显示全部楼层
