4.A^5J'W X><C#G Iix,}kzss g)Z8WH$;H3 +LHU}'| Comment | Description | Designator | Footprint | LibRef | Quantity | GRM1555C1H150JA01D | CAP, CERM, 15 pF, 50 V,+/- 5%,C0G/NP0, 0402 | C1 | 0402 | GRM1555C1H150JA01D | 1 | GRM0335C1H330JA01D | CAP, CERM, 33 pF, 50V,+/- 5%, C0G/NP0, 0201 | C2, C3, C4, C5 | 0201 | GRM0335C1H330JA01D | 4 | GRM188R60J225KE19D | CAP, CERM, 2.2 礔, 6.3V,+/- 10%, X5R, 0603 | C6 | 0603 | GRM188R60J225KE19D | 1 | GRM155R71A104KA01D | CAP, CERM, 0.1 礔, 10V,+/- 10%, X7R, 0402 | | 0402 | GRM155R71A104KA01D | 49 | CL05A106MP8NUB8 | CAP, CERM, 10 礔, 10V,+/- 20%, X5R, 0402 | C11, C14, C21, C38,C41, C60 | 0402 | GRM155R61A106ME11 | 6 | GRM155R71H102KA01D | CAP, CERM, 1000 pF,50 V,+/- 10%, X7R, 0402 | C13, C23, C40, C53 | 0402 | GRM155R71H102KA01D | 4 | GRM155R61A105KE15D | CAP, CERM, 1 礔, 10V,+/- 10%, X5R, 0402 | C24, C27, C29, C31,C33, C35, C51, C55, C57, C59, C109, C113, C116 | 0402 | GRM155R61A105KE15D | 13 | GRM155R71C103KA01D | CAP, CERM, 0.01 礔, 16V,+/- 10%, X7R, 0402 | C26, C28, C30, C32,C34, C36, C54, C69, C85, C115 | 0402 | GRM155R71C103KA01D | 10 | GRM155R61A104KA01D | CAP, CERM, 0.1 礔, 10V,+/- 10%, X5R, 0402 | C37 | 0402 | GRM155R61A104KA01D | 1 | CL21B106KOQNNNE | CAP, CERM, 10 礔, 16V,+/- 10%, X7R, 0805 | C63, C72, C73, C74,C75 | 0805_HV | CL21B106KOQNNNE | 5 | GCM155R71C104KA55D | CAP, CERM, 0.1 礔, 16V,+/- 10%, X7R, 0402 | C64, C66, C71, C83,C88, C106 | 0402 | GCM155R71C104KA55D | 6 | CL05A475MO5NUNC | CAP, CERM, 4.7 礔, 16V,+/- 20%, X5R, 0402 | C65 | 0402 | GRM155R61C475ME11D | 1 | UUD1E221MNL1GS | CAP, AL, 220 礔, 25 V,+/- 20%, 0.17 ohm, SMD | C70 | SM_RADIAL_8MM | UUD1E221MNL1GS | 1 | CL21A226KPCLRNC | CAP, CERM, 22 礔, 10V,+/- 20%, X7R, 0805 | C76, C77, C78 | 0805_HV | GRM21BZ71A226ME15L | 3 | CL10A475MP5LNNC | CAP, CERM, 4.7 礔, 10V,+/- 20%, X7R, 0603 | C79, C98 | 0603 | GRM188Z71A475ME15D | 2 | GRM1885C1E102JA01D | CAP, CERM, 1000 pF,25 V,+/- 5%, C0G/NP0, 0603 | C80 | 0603 | GRM1885C1E102JA01D | 1 | GRM188Z71C475KE21D | CAP, CERM, 4.7 礔, 16V,+/- 10%, X7R, 0603 | C81, C82 | 0603 | GRM188Z71C475KE21D | 2 | GRM033R71C102KA01D | CAP, CERM, 1000 pF,16 V,+/- 10%, X7R, 0201 | C84, C91, C94, C96,C97 | 0201 | GRM033R71C102KA01D | 5 | GRM155R71E273KA88D | CAP, CERM, 0.027 礔,25 V,+/- 10%, X7R, 0402 | C86 | 0402 | GRM155R71E273KA88D | 1 | GRM155R71E223KA61D | CAP, CERM, 0.022 礔,25 V,+/- 10%, X7R, 0402 | C89, C90, C92, C93 | 0402 | GRM155R71E223KA61D | 4 | C1005X5R1C105K050BC | CAP, CERM, 1 礔, 16V,+/- 10%, X5R, 0402 | C107 | 0402 | C1005X5R1C105K050BC | 1 | GRM219R61C226ME15L | CAP, CERM, 22 礔, 16V,+/- 20%, X5R, 0805 | C108, C112 | 0805_HV | GRM219R61C226ME15L | 2 | GRM188R71C104KA01D | CAP, CERM, 0.1 礔, 16V,+/- 10%, X7R, 0603 | C111, C118, C119 | 0603 | GRM188R71C104KA01D | 3 | SBR0220T5-7-F | Diode, Schottky, 20V, 0.2 A, SOD-523 | D1 | SOD-523 | SBR0220T5-7-F | 1 | D5V0M1U2LP3-7 | Diode, TVS, Uni, 5.5V, 11 Vc, 2-XFDFN | D2 | X3-DFN0603-2 | D5V0M1U2LP3-7 | 1 | NSR20F30NXT5G | Diode, Schottky, 30V, 2 A, 2-XFDFN | D3 | DSN2_0603 | NSR20F30NXT5G | 1 | T5V0LCS5-7 | Diode, TVS, Uni, 3 V,SOD-523 | D5, D8 | SOD-523 | CMP-0084433-1 | 2 | 0154005.DRL | Fuse, 5 A,125VAC/VDC, SMD | F1 | FUSE_154 | CMP-0078640-1 | 1 | 3413.0117.22 | Fuse, 0.375 A,125VAC/VDC, SMD | F2 | Fuse_USF1206 | CMP-0084010-1 | 1 | FTSH-110-01-L-DV-K | Header (Shrouded),1.27mm, 10x2, Tin, SMT | J1 | Samtec_FTSH-110-01-x-DV-K | CMP-0075631-1 | 1 | TSHC-123-D-03-145-GT-LF | Header, 2.54 mm,23x2, Gold, TH | J4, J5 | Major_TSHC-123-D-03-145 | CMP-0075328-1 | 2 | TSM-107-01-L-DV | Header, 2.54mm, 7x2,Gold, SMT | J7 | Samtec_TSM-107-01-x-DV | TSM-107-01-L-DV | 1 | DM3BT-DSF-PEJS | Conncetor, micro SD,8+2 Pos, R/A, SMT | J8 | Hirose_DM3BT-DSF-PEJS | CMP-0080007-1 | 1 | 10118194-0001LF | Receptacle, USB 2.0,Micro-USB Type B, R/A, SMT | J9 | FCI_10118194-0001LF | 10118194-0001LF | 1 | PJ-063AH | DC POWER JACK, R/A,TH | J10 | CUI_PJ-063AH | CMP-0079472-1 | 1 | | Header, 2mm, 2x1,Gold, TH | J11, J12, J13, J14 | Samtec_PTT-102-01-x-S | PTT-102-01-L-S | 4 | ED555/2DS | Terminal Block, 3.5mmPitch, 2x1, TH | J15 | TERM_BLK_ED555-2DS | CMP-0074913-1 | 1 | BLM18KG601SN1D | Ferrite Bead, 600 ohm@ 100 MHz, 1.3 A, 0603 | L1, L3, L4 | 0603 | BLM18KG601SN1D | 3 | BLM15GG471SN1D | Ferrite Bead, 470 ohm@ 100 MHz, 0.2 A, 0402 | L2, L5, L6, L7, L8,L9 | 0402 | BLM15GG471SN1D | 6 | VLCF4020T-2R2N1R7 | Inductor, Shielded,Ferrite, 2.2 礖, 1.72 A, 0.059 ohm, SMD | L12, L13, L14 | VLCF4020 | VLCF4020T-2R2N1R7 | 3 | 74438356022 | Inductor, Shielded,2.2 礖, 4.7 A, 0.029 ohm, SMD | L16 | WE-MAPI_4020 | 74438356022 | 1 | CRCW06030000Z0EA | RES, 0, 5%, 0.1 W,0603 | L61, L62 | 0603 | CRCW06030000Z0EA | 2 | THT-14-423-10 | Thermal TransferPrintable Labels, 0.650" W x 0.200" H - 10,000 per roll | LBL1 | Label_650x200 | CMP-0003625-1 | 1 | LTST-C191TGKT | LED, Green, SMD | LED0, LED1, VDD_BBB,Vin_5V | LTST-C191_Green | LTST-C191TGKT | 4 | SPS0916B-J-01 | Dynamic Speaker | LS1 | AAC_SPS0916B-J-01 | SPS0916B-J-01 | 1 | MMBT3904-7-F | Transistor, NPN, 40V, 0.2 A, SOT-23 | Q1 | SOT-23 | MMBT3904-7-F, DiodesInc. | 1 | DDC114YU-7-F | Transistor, Dual NPN,50 V, 0.1 A, SOT-363 | Q2 | SOT-363 | DMC564040R, Panasonic | 1 | CSD23280F3 | MOSFET, P-CH, -12 V,1.8 A, YJM0003A (PICOSTAR-3) | Q3 | YJM0003A | CSD23280F3 | 1 | CRCW040210K0JNED | RES, 10 k, 5%, 0.063W, 0402 | R1, R10, R13, R22,R34, R39, R40, R45, R51, R52, R55, R56, R57, R58, R59, R60, R63, R64, R65,R93, R94, R95, R107, R114, R115, R116, R117, R126, R136, R149 | 0402 | CRCW040210K0JNED | 30 | CRCW04024K70JNED | RES, 4.7 k, 5%, 0.063W, 0402 | R2, R3, R47, R49 | 0402 | CRCW04024K70JNED | 4 | CRCW04020000Z0ED | RES, 0, 5%, 0.063 W,0402 | R4, R5, R6, R8, R9,R11, R12, R24, R25, R62, R98, R101, R122, R129, R130, R133, R134, R142, R143 | 0402 | CRCW04020000Z0ED | 19 | CRCW04021K00FKED | RES, 1.00 k, 1%,0.063 W, 0402 | R7, R50, R70, R71,R72, R77, R78, R79, R84, R85, R86, R87, R92, R96, R97, R99, R100, R105 | 0402 | CRCW04021K00FKED | 18 | CRCW040222R0JNED | RES, 22, 5%, 0.063 W,0402 | R14, R17, R23, R26,R28, R29, R30, R31, R32, R33, R35, R36, R37, R38, R53, R54, R66, R123, R124,R127, R128, R131, R132, R135, R137, R138, R139, R140, R141, R144, R145, R146,R147, R148 | 0402 | CRCW040222R0JNED | 34 | CRCW0402100RJNED | RES, 100, 5%, 0.063W, 0402 | R15, R48 | 0402 | CRCW0402100RJNED | 2 | EXB-2HV220JV | RES, 22, 5%, 0.0625W, Resistor Array - 8x1 | R16, R18 | RESCAXS_EXB-2HV | CMP-0015346-3 | 2 | CRCW06031K50FKEA | RES, 1.50 k, 1%, 0.1W, 0603 | R19, R20 | 0603 | CRCW06031K50FKEA | 2 | CRCW0402100KJNED | RES, 100 k, 5%, 0.063W, 0402 | R21, R69, R73 | 0402 | CRCW0402100KJNED | 3 | CRCW04028K06FKED | RES, 8.06 k, 1%,0.063 W, 0402 | R27 | 0402 | CRCW04028K06FKED | 1 | CRCW040233R0JNED | RES, 33, 5%, 0.063 W,0402 | R41, R42, R102 | 0402 | CRCW040233R0JNED | 3 | CRCW040210R0FKED | RES, 10.0, 1%, 0.063W, 0402 | R43, R44, R46, R119,R120, R121 | 0402 | CRCW040210R0FKED | 6 | CRCW0402470RJNED | RES, 470, 5%, 0.063W, 0402 | R61, R83 | 0402 | CRCW0402470RJNED | 2 | CRCW04024K75FKED | RES, 4.75 k, 1%,0.063 W, 0402 | R67, R68 | 0402 | CRCW04024K75FKED | 2 | CRCW040247K0JNED | RES, 47 k, 5%, 0.063W, 0402 | R74, R75, R76, R80,R81, R82 | 0402 | CRCW040247K0JNED | 6 | CRCW0402100KFKED | RES, 100 k, 1%, 0.063W, 0402 | R88, R89 | 0402 | CRCW0402100KFKED | 2 | CRCW040222K1FKED | RES, 22.1 k, 1%,0.063 W, 0402 | R90 | 0402 | CRCW040222K1FKED | 1 | CRCW040275K0FKED | RES, 75.0 k, 1%,0.063 W, 0402 | R91 | 0402 | CRCW040275K0FKED | 1 | CRCW040268K1FKED | RES, 68.1 k, 1%,0.063 W, 0402 | R103 | 0402 | CRCW040268K1FKED | 1 | CRCW040210K0DHEDP | RES, 10.0 k, 0.5%,0.063 W, 0402 | R104, R108, R110,R112 | 0402 | CRCW040210K0DHEDP | 4 | CRCW040223K2FKED | RES, 23.2 k, 1%,0.063 W, 0402 | R106 | 0402 | CRCW040223K2FKED | 1 | CRCW040232K4FKED | RES, 32.4 k, 1%,0.063 W, 0402 | R109 | 0402 | CRCW040232K4FKED | 1 | RC0402FR-0721KL | RES, 21.0 k, 1%,0.063 W, 0402 | R111 | 0402 | CRCW040221K0FKED | 1 | EXB-2HV330JV | RES, 33, 5%, 0.0625W, Resistor Array - 8x1 | R113, R118 | RESCAXS_EXB-2HV | CMP-0015347-2 | 2 | CRCW040210K0FKED | RES, 10.0 k, 1%,0.063 W, 0402 | R125 | 0402 | CRCW040210K0FKED | 1 | B3U-1100P | Switch, SPST-NO,Off-Mom, 12 V, SMD | S1, S2, S3, S4 | SW_B3U-1100P | CMP-0002193-2 | 4 | TMS320C5517AZCH20 | Fixed-Point DigitalSignal Processor, ZCH0196A (NFBGA-196) | U1 | ZCH0196A | CMP-0078528-1 | 1 | TPS22915BYFPR | 5.5V, 2A, 38mO LoadSwitch With Quick Output Discharge, YFP0004AAAA (DSBGA-4) | U2, U3 | YFP0004AAAA | TPS22915BYFPR | 2 | TPD2EUSB30DRTR | ESD Solution forSuper-Speed (6 Gbps) USB 3.0 Interface, 2 Channels, -40 to +85 degC, 3-pinSOT (DRT), Green (Rohs & No Sb/Br) | U4 | DRT0003A | TPD2EUSB30DRTR | 1 | SN74LVC1G126DRLR | Single Bus BufferGate With 3-State Outputs, DRL0005A, LARGE T&R | U5, U15, U16 | DRL0005A | CMP-0052016-2 | 3 | TPS65023RSBR | Power Management IC(PMIC) with 3DC/DCs, 3 LDOs, I2C Interface and DVS, RSB0040B (WQFN-40) | U6 | RSB0040B | TPS65023RSBR | 1 | TPS3850G33DRCR | Precision VoltageSupervisor with Window Watchdog Timer, DRC0010J (VSON-10) | U7 | DRC0010J | TPS3850G33DRCR | 1 | TPS386000RGPR | Quad Supply VoltageSupervisors with Programmable Delay and Watchdog Timer, RGP0020A (VQFN-20) | U8 | RGP0020A | CMP-0079268-1 | 1 | AS4C32M16MS-7BCN | 512M Low Power MobileSDRAM (MSDR), BGA-54 | U9 | ALLIANCE_BGA-54 | CMP-0078950-1 | 1 | TAS2557YZR | 5.7-W Class-D MonoAudio Amplifier with Class-H Boost and Speaker Sense, YZ0042-C01 (DSBGA-42) | U10 | YZ0042-C01 | TAS2557YZR | 1 | TPD6F003DQDR | EMI Filter forDisplay Interface, 6 Channels, -40 to +85 degC, 12-pin WSON (DQD), Green(RoHS & no Sb/Br) | U11 | DQD0012A | TPD6F003DQDR | 1 | TPD1E10B06DPYR | ESD in 0402 Packagewith 10 pF Capacitance and 6 V Breakdown, 1 Channel, -40 to +125 degC, 2-pinX2SON (DPY), Green (RoHS & no Sb/Br) | U12 | DPY0002A | TPD1E10B06DPYR | 1 | TPS22912CYZVR | 5.5V, 2A, 61mO LoadSwitch With Reverse Current Protection, YZV0004ADAD (DSBGA-4) | U13 | YZV0004ADAD | TPS22912CYZVR | 1 | ABS06-32.768KHZ-9-1-T | Crystal, 32.768 kHz,10 ppm, 9, SMD | Y1 | Abracon_ABS06 | CMP-0079992-1 | 1 | ABM10AIG-12.000MHZ-4Z-T3 | Crystal, 12 MHz, SMD | Y2 | Abracon_ABM10AIG | ABM10AIG-24.576MHZ-J4Z-T3 | 1 | SIT8008BC-71-33E-12.288000G | Oscillator, 12.288MHz, AEC-Q200 Grade 4, SMD | Y3 | SiTIME_SIT8008_7 | CMP-0079468-1 | 1 |
PCB+SCH打包下载:[sell=2,money][/sell][attachment=130347] ixTjXl2g 2mY!gVi [ 此帖被samfol在2018-11-16 16:26重新编辑 ]
