Item# | Qty | Ref Des | Device | Package | Value | Voltage | 65 | 1 | D40 | Diode | SOT_23 | BAS40-04 | 40V | 61 | 2 | D5,D6 | Diode | SOD_123 | BAT54T1G | 30V | 104 | 5 | L16,L17,L18,L19,L55 | Ferrite Chip | 805 | | | 100 | 8 | L6,L11,L32,L33,L48,L49,L52,L62 | Ferrite Chip | 603 | | | 109 | 2 | L35,L36 | Ferrite Chip | 603 | | | 67 | 1 | DS1 | LED | | LED-GRN-RED | 2.0V | 69 | 2 | DS35,DS36 | LED | | LED-RED-SMT | 2.0V | 260 | 1 | U25 | Filter | MURATA_BNX01 | 50MOHM | | 63 | 9 | D18,D21,D25,D27,D28,D31,D34,D39,D41 | Diode | DIO_SMB_403A_03 | MBRS240LT3G | 40V | 116 | 1 | L66 | Inductor | IND_WURTH_1390 | | | 108 | 3 | L29,L30,L58 | Filter | BEAD_LAIRD_28C0236 | | | 113 | 4 | L47,L50,L60,L65 | Inductor | IND_74479887310 | | | 99 | 2 | L5,L9 | Inductor | IND_744310115 | | | 107 | 3 | L24,L25,L28 | Inductor | IND_LAIRD_28F0121_1SR_10 | | | 140 | 12 | Q21,Q22,Q24,Q25,Q26,Q28,Q29,Q32,Q37,Q38,Q39,Q40 | Transistor | SOT523 | MMBT3904T | 40V | 62 | 11 | D7,D8,D9,D10,D11,D12,D13,D14,D15,D16,D17 | Diode | SOD_123 | MMSZ4680T1G | 2.2V | 60 | 3 | D1,D2,D3 | Diode | SOD_123 | MMSZ4686T1G | 3.9V | 105 | 1 | L20 | Inductor | IND_WURTH_1210 | | | 110 | 2 | L38,L39 | Inductor | IND_VLS252012ET_3R3M | | | 64 | 4 | D19,D20,D23,D24 | Diode | SOD_123 | MMSZ4683T1G | 3.0V | 111 | 1 | L43 | Inductor | IND_WURTH_744308015 | | | 112 | 1 | L44 | Inductor | IND_WURTH_744308020 | | | 96 | 1 | L2 | Inductor | IND_WURTH_7050 | | | 97 | 1 | L3 | Inductor | IND_WURTH_744310200 | | | 114 | 1 | L59 | Inductor | IND_WURTH_744316047 | | | 103 | 1 | L13 | Inductor | IND_WURTH_744787039 | | | 102 | 1 | L12 | Inductor | IND_WURTH_74437324022 | | | 95 | 1 | L1 | Inductor | IND_WURTH_744373340068 | | | 106 | 1 | L21 | Inductor | IND_WURTH_744373460047 | | | 115 | 2 | L61,L67 | Inductor | 402 | | | 117 | 8 | L68,L69,L70,L71,L72,L73,L74,L75 | Inductor | 402 | | | 101 | 1 | L10 | Inductor | IND_WURTH_74408941022 | | | 76 | 16 | J7,J9,J12,J13,J14,J15,J16,J17,J20,J21,J22,J38,J42,J54,J88,J153 | Header | 1X2 | HDR_1X2 | | 83 | 0 | J57,J58,J59,J60,J61,J62,J63,J64,J65,J66,J67,J68 | Header | 1X1 | DNP | | 86 | 8 | J85,J90,J108,J109,J110,J112,J113,J159 | Header | 1X3 | HDR_1X3 | | 73 | 1 | J3 | Header | 2X12 | HDR_2X12 | | 82 | 2 | J56,J164 | Header | 2X2 | HDR_2X2 | | 87 | 1 | J87 | Header | 2X6 | HDR_2X6 | | 91 | 1 | J98 | Header | 2X4 | HDR_2X4 | | 94 | 1 | J162 | Header | 2X3 | HDR_2X3 | | 81 | 2 | J55,J160 | Header | F2X6_PMOD | HDR_2X6_F_RA | | 72 | 2 | J2,J83 | Connector | | ZX62D_AB_5P8 | | 93 | 1 | J118 | Connector | | 22_11_2032 | | 84 | 6 | J69,J70,J71,J72,J79,J80 | SMA | | 32K10K-400L5 | | 80 | 1 | J52 | Connector | | 39-30-1060 | | 128 | 1 | P6 | Connector | MICTOR38P_RECP | MICTR38P_REC | | 77 | 1 | J8 | Connector | | 87832-1420 | | 74 | 2 | J4,J5 | Connector | | ASP_134486_01 | | 78 | 1 | J10 | Connector | | 794285-1 | | 75 | 1 | J6 | Connector | 2X10 | HDR_BOX_2X10 | | 88 | 1 | J92 | Connector | | 103308-2 | | 131 | 1 | P11 | Connector | CON_MOLEX_47272 | 472720001 | | 130 | 1 | P9 | Connector | CON_MOLEX_678005 | 67800-5005 | | 85 | 1 | J84 | Connector | 2X8 | HDR_BOX_2X8 | | 71 | 1 | J1 | Connector | | DDR4_SO-DIMM_SHIELDED | | 247 | 1 | SW9 | Switch | | 1825910-6 | | 129 | 1 | P7 | Connector | 1888811-1 | 1888811-1 | | 90 | 1 | J96 | Connector | | KMMX-AB10-SMT1SB30TR | | 127 | 1 | P2 | Connector | R-OP-008080-6-F-N-26-F63 | R-OP-008080-6-F-N-26-F63 | | 89 | 1 | J93 | Connector | | 70246-1201 | | 126 | 1 | P1 | Connector | CON_FCI_10061913_98 | 10061913-102CLF | | 92 | 1 | J100 | Socket | | DM1AA-SF-PEJ_21 | | 249 | 1 | U1 | DUT Socket | | SOC_DA7_FFVB1156_IRONWOOD | | 256 | 1 | U21 | USB Module | DIGILENT_USB_JTAG_2_NC | DIGILENT_USB_JTAG_2_NC | 1.8-5V | 132 | 1 | P12 | Socket | 7499111221A | RJ45 | | 245 | 1 | SW7 | Switch | | EVQ-11L07K | | 244 | 1 | SW6 | Switch | | SDA04H1SBD | | 246 | 1 | SW8 | Switch | | SDA05H1SBD | | 248 | 1 | SW13 | Switch | | SDA08H1SBD | | 243 | 11 | SW2,SW3,SW4,SW5,SW14,SW15,SW16,SW17,SW18,SW19,SW20 | Switch | | TL3301EF100QG | | 242 | 1 | SW1 | Switch | | 1101M2S3AQE2 | | 253 | 1 | U11 | IC Bus Transceiver | QFN_RSW_10 | SN74AVC2T245 | 1.2V-3.6V | 279 | 2 | U58,U114 | IC Bus Transceiver | QFN_RSV_16 | SN74AVC4T245 | 1.2V-3.6V | 274 | 4 | U48,U66,U67,U68 | IC Bus Transceiver | TSSOP_24 | SN74AVC8T245 | 1.2V | 258 | 1 | U23 | IC EEPROM | TSSOP8_65P440X300MM | M24C08-WDW6TP | 2.5V-5V | 257 | 1 | U22 | IC Supervisor | TQFN_16 | MAX16025 | | 259 | 2 | U24,U27 | IC Switch | SC70_5 | NC7SZ66P5X | 1.65V | 271 | 5 | U43,U44,U113,U139,U147 | IC Translator | SC70_6 | SN74AVC1T45 | 1.2V-3.6V | 264 | 4 | U33,U52,U53,U54 | IC Translator | SOIC_14 | TXS0104E | 1.7V-5.5V | 295 | 1 | U116 | IC USB interface | USB3320_QFN32 | USB3320 | 3.3V | 98 | 8 | L4,L7,L8,L22,L23,L31,L37,L42 | Inductor | IND_IHLP2020BZ_ER | | | 283 | 5 | U62,U112,U130,U140,U142 | IC Gate | SC70_5 | SN74LVC1G08 | 1.65V-5.5V | 275 | 1 | U50 | IC Buffer | SC70_6 | NC7WZ07 | 5.5V | 137 | 10 | Q11,Q12,Q13,Q14,Q30,Q33,Q34,Q35,Q43,Q44 | Mosfet | SOT_23 | NDS331N | 20V | 296 | 1 | U117 | IC Gate | SC70_6 | SN74LVC1G11 | 1.65V-5.5V | 134 | 4 | Q1,Q2,Q3,Q4 | Transistor | SOT_23 | BSS138 | 50V | 306 | 1 | U141 | IC Translator | TSSOP_20 | TXS0108E | 1.2V-3.6V,1.6-5.5V | 282 | 2 | U61,U97 | IC Expander | TCA6416APWR | TCA6416A | 1.65V-5.5V | 292 | 1 | U108 | IC Attenuator | QFN36_6X6MM | SI5324C-C-GM | 1.7V,3.6V | 299 | 1 | U122 | IC/Socket | SOIC_8 | SN65HVD232 | 3.0V-3.6V | 281 | 1 | U60 | IC Multiplexer | VQFN_20 | PCA9544ARGYR | 2.3-5.5V | 272 | 4 | U45,U55,U134,U136 | IC Translator | DCT_R_PDSO_G8 | PCA9306DCTR | 1.2-3.3V, 1.8-5.5V | 254 | 18 | U15,U16,U65,U74,U75,U76,U77,U78,U79,U80,U81,U84,U85,U86,U87,U88,U92,U93 | IC Regulator | DGS_MSOP_10 | INA226 | 36V | 308 | 2 | X1,X2 | IC ESD Solution | DRY_6_SON | TPD4S012 | 20V | 294 | 1 | U115 | IC ESD Solution | DRT_R_PDSO_N3 | TPD2EUSB30DRTR | 5.5V | 304 | 1 | U132 | IC ESD Solution | DRL_R_PDSO_N6 | TPD4E001DRLR | 0.9-5.5V | 302 | 1 | U129 | IC ESD Solution | SON_15P | TPD8S009DSMR | 0-6V | 291 | 1 | U103 | IC Monitor | SOT23_6 | MAX16052 | 28V | 269 | 1 | U41 | IC Flash | VQFN_48 | MSP430F5342 | 1.8V | 135 | 2 | Q5,Q27 | Transistor | PWRCLIP_33 | FDPC8011S | 25V | 273 | 4 | U46,U47,U49,U63 | IC Regulator | TQFN_32_EP | MAX15301 | 18V | 252 | 8 | U4,U6,U7,U8,U9,U10,U13,U18 | IC Controller | TQFN_40_EP | MAX15303 | 18V | 139 | 2 | Q19,Q20 | Mosfet | PWR_56 | FDMS8018 | 30V | 138 | 4 | Q15,Q16,Q17,Q18 | Mosfet | PWR_56 | FDMS8558S | 25V | 280 | 1 | U59 | IC Buffer | DCU_R_PDSO_G8 | SN74LVC3G07 | 1.65V | 267 | 3 | U37,U38,U39 | IC LDO Regulator | TDFN_10_3X3_EP | MAX15027 | 1.425V-3.6V | 276 | 1 | U51 | IC Buffer | QFN16_SI_3X3MM | SI53340-B-GM | 1.71-3.63V | 265 | 2 | U34,U135 | IC I2C Switch | TSSOP_24 | TCA9548APWR | 1.65-5.5V | 263 | 1 | U32 | IC LDO Regulator | SC70_5 | MAX8892EXK+T | 1.5V-4.5V | 289 | 2 | U95,U96 | IC Regulator | QFN_36_C | MAX20751EKX | 3.3V | 262 | 2 | U28,U29 | IC Regulator | HPQFN_19_A | VT1697SBFQX | 3.3V, 1.8V | 251 | 8 | U3,U5,U12,U14,U17,U30,U31,U143 | IC LDO Regulator | TSSOP_16_EP | MAX8869EUE18+ | 1.8V | 136 | 1 | Q7 | Transistor | PWR_56 | SI7157DP | 20V | 255 | 1 | U20 | IC Clock | QFN36_6X6MM | SI5328B | 2.5V,3.6V | 290 | 1 | U98 | IC PHY Transceiver | PQFP_64_EP | DP83867IRPAP | 1.8V-3.3V | 307 | 1 | U148 | IC LDO Regulator | TDFN_8_EP | MAX8902B | 1.7V-5.5V | 268 | 1 | U40 | IC Bridge | 64_VFQFN | CP2108 | 3.3V | 261 | 1 | U26 | IC Gate | SOT23_5 | SN74AUC1G32 | 0.8-2.7V | 278 | 1 | U57 | IC Switch | 6DSBGA | TPS22924C | 0.75-3.6V | 300 | 1 | U124 | IC Receiver | TSSOP_14 | FIN1019 | 3.3V | 303 | 1 | U131 | Diode Array | DQA_R_PSON_N10 | TPD4E05U06DQAR | 6.5V | 141 | 3 | Q41,Q45,Q46 | Transistor | SOT_23 | 2N7002_215 | 60V | 293 | 1 | U109 | IC EEPROM | TSSOP_8 | M24C64-W | 2.5V-5V | 301 | 4 | U125,U126,U127,U128 | IC Multiplexer | TQFN_28_ZH | PI2DBS6212 | 1.5V-1.8V | 287 | 16 | U71,U72,U73,U82,U83,U89,U90,U91,U99,U100,U101,U102,U104,U105,U106,U107 | IC Diode | TPD1E05U06DPYT | TPD1E05U06DPYT | 5.5V | 285 | 1 | U69 | Oscillator | | 350MHZ | | 288 | 1 | U94 | IC Retimer | SN65DP159RGZ | SN65DP159RGZ | 3.3, 1.1V | 298 | 1 | U121 | IC Power Switch | SOIC_8 | MIC2544A-1YM | 2.7V TO 5.5V | 286 | 2 | U70,U110 | IC HDMI | TPD12S016RKTR | TPD12S016RKTR | 5.5V | 297 | 2 | U119,U120 | Memory | SO16_50P300X413 | MT25QU512ABB8ESF-0SIT | 1.7V-2V | 250 | 1 | U2 | Memory | MT40A256M16GE-075E | MT40A256M16GE-075E | 1.2V | 120 | 1 | MMD1 | DDR4_SODIMM | DDR4_SODIMM | DDR4_SODIMM | | 311 | 2 | X6,X9 | Crystal | XTAL_CS_023_125X98 | 114.285MHZ | | 309 | 1 | X4 | Crystal | XTAL_ABM8 | 25.00MHZ | | 314 | 1 | X10 | Crystal | XTAL_HCM49 | 24.000MHZ | | 277 | 1 | U56 | Oscillator | SI570 | 10MHZ_TO_810MHZ | | 313 | 1 | X8 | Crystal | XTAL_MC306 | 32.768KHZ | | 310 | 1 | X5 | Crystal | XTAL_TXC_9HT10 | 32.768KHZ | | 270 | 1 | U42 | Oscillator | SI570 | 10MHZ_TO_810MHZ | | 312 | 1 | X7 | Crystal | 7M48072002 | 48.000MHZ | | 284 | 1 | U64 | Voltage Reference | SOT23_3 | REF3012AIDBZT | 1.25V | 266 | 2 | U35,U36 | Voltage Regulator | SON10_TPS51200 | TPS51200DRCT | 2.5VIN_2.5V-1.1V | 1 | 1 | B1 | Battery Slot | | TS518FE-FL35E | | 305 | 1 | U133 | Shifter | IP4856CX25_SHIFTER_ADAPTER | IP4855CX25_ADAPT | 1.2-3.3V | 121 | 9 | MRB1,MRB2,MRB3,MRB4,MRB5,MRB6,MRB7,MRB8,MRB9 | Bumper | | RUBBER_BUMPER | | 122 | 15 | MS1,MS2,MS3,MS4,MS5,MS6,MS9,MS11,MS12,MS13,MS14,MS15,MS16,MS17,MS18 | Screw | | MACHINE_SCREW_4-40 | | 119 | 14 | MJB1,MJB2,MJB3,MJB4,MJB5,MJB6,MJB7,MJB8,MJB9,MJB10,MJB11,MJB12,MJB13,MJB14 | Shunt | | JUMPER_BLOCK_2-PIN | | 124 | 9 | MSO1,MSO2,MSO3,MSO4,MSO5,MSO6,MSO7,MSO8,MSO9 | Standoff | | STANDOFF_0P625 | | 123 | 3 | MS7,MS8,MS10 | Screw | | MACHINE_SCREW_4-40 | | 125 | 9 | MW1,MW2,MW3,MW4,MW5,MW6,MW7,MW8,MW9 | Washer | | WASHER_FLAT_4 | | 59 | 0 | CBL2 | Cable | | USB_MICRO_CABLE | | 58 | 0 | CBL1 | Cable | | PC_POWER_CABLE | | 66 | 1 | DIMMCAGE1 | SODIMM_CAGE | SODIMM_CAGE | SODIMM_CAGE | | 70 | 1 | HS1 | Fan Sink | RADIAN_FA35+K52B+T710 | 12VDC | | 133 | 0 | PB1 | PWR_BRICK_12V | | PWR_BRICK_12V | | 8 | 0 | C81 | Capacitor | 1206 | DNP | 6.3V | 10 | 0 | C84 | Capacitor | 402 | DNP | DNP | | | | | | | |
