ITM |
QTY |
PART DESIGNATOR |
PART |
DESCRIPTIONS |
MAN |
PART # |
1 |
4 |
C1,C2,C3,C4 |
10uF,10V |
CAP CER 10UF 10V Y5V 0805 |
TDK |
C2012Y5V1A106Z |
3 |
2 |
C46,C47 |
47uF |
CAP CER 47UF 10V X5R 1210 |
Murata |
GRM32ER61A476KE20L |
4 |
4 |
C48,C49,C53,C61 |
47pF |
CAP CER 47PF 50V C0G 5% 0402 |
TDK |
C1005C0G1H470J |
5 |
9 |
C50,C51,C52,C54,C57,C60,C63,C78,C79 |
0.1uF |
CAP 0.1uF 16V 10% 0402 X7R |
Kemet |
C0402C104K4RACT |
6 |
5 |
C55,C56,C58,C59,C62 |
10uF,0805 |
TDK |
C2012Y5V1A106Z |
8 |
4 |
D1,D2,D3,D4 |
PGB0010603MR |
Ferrite Bead 150 Ohm 800mA |
Steward |
LI0805H151R-10 |
9 |
2 |
D5,D6 |
598-8170-107F |
LED Green SMD 20mA 2V 0805 |
Dialight |
598-8170-107F |
10 |
3 |
FB6,FB7,FB8 |
MMZ1608R301A |
FERRITE CHIP 300 OHM 500MA 0603 |
TDK |
MMZ1608R301A |
11 |
2 |
P1,P2 |
2x23 HEADER FEMALE |
.100 CL Dual Row- Straight Socket Strip-using .025" Sq. Pins |
MLE |
SSHQ-123-D-08-G-LF |
MLE |
SSHQ-123-D-08-F-LF |
12 |
1 |
P3 |
2x5 HEADER FEMALE |
MLE |
SSHQ-105-D-08-G-LF |
2x5 HEADER FEMALE |
MLE |
SSHQ-105-D-08-F-LF |
13 |
2 |
P6,P7 |
PHONOJACK STEREO-R |
CONN JACK STEREO 3POS 3.5MM SMD |
CUI |
SJ1-3513-SMT |
14 |
1 |
Q1 |
DMC56404 |
TRANS NPN/NPN W/RES 50V SMINI6 |
Panasonic |
DMC564040R |
16 |
3 |
R108,R109,R110 |
33,402 |
RES 33.0 OHM 1/16W 1% 0402 SMD |
Yaego |
RC0805FR-0749R9L |
17 |
1 |
R111 |
.1,0805 |
RES .10 OHM 1/8W 5% 0805 |
CTS |
73L3R10J |
18 |
1 |
R112 |
28K |
RES 28.0K OHM 1/16W 1% 0402 SMD |
Yaego |
RC0402FR-0728KL |
19 |
1 |
R113 |
56.2K |
RES 56.2K OHM 1/16W 1% 0402 SMD |
Yaego |
CRCW040256K2FKED |
20 |
2 |
R114,R115 |
5.6K |
RES 5.6K OHM 1/16W 5% 0402 SMD |
Yaego |
RC0402JR-075K6L |
21 |
3 |
R116,R117,R118 |
4.75K |
RES 4.75K OHM 1/16W 1% 0402 SMD |
Stackpole Electronics |
RMCF0402FT4K75 |
22 |
2 |
R119,R120 |
470,5% |
RES 470 OHM 1/10W 5% 0402 SMD |
Panasonic |
ERJ-2GEJ471X |
23 |
2 |
R121,R122 |
100K,1% |
Resistor 100Kohm 1/16W 1% 0402 |
Yageo |
CRCW0402100KJNED |
24 |
1 |
R123 |
10K |
Resistor 10Kohm 1/16W 5% 0402 |
Rohm |
MCR01MZPJ103 |
25 |
2 |
R130,R132 |
402 |
Resistor Zero ohm Jumper 0402 |
Yaego |
RC0402JR-070RL |
27 |
1 |
SW1 |
2 POS Dip Switch |
SWITCH TAPE SEAL 2 POS SMD |
CTS |
219-2MST |
29 |
1 |
U6 |
TLV320AIC3106 |
IC STER AUD CODEC 32 BIT 48-VQFN |
TI |
TLV320AIC3106IRGZR |
30 |
1 |
U7 |
TPS73701DRBR |
IC REG LDO CAP FREE 8-SON |
TI |
TPS73701DRBR |
31 |
1 |
U8 |
CAT24C256W |
IC EEPROM 256KBIT 400KHZ 8SOIC |
ON |
CAT24C256WI-G |
33 |
1 |
Y1 |
12MHz |
OSCILLATOR 12.000 MHZ 3.3V SMD |
Fox |
FXO-HC735-12 | |
DNI |
C5,C6,C67,C68,C69,C70,C71,C72,C73,C74,C75,
C76,C77,C80,C81,R1,131,R133,U9 | | | | |
