Item |
Qty |
CY Part Number |
Reference |
Description |
Manufacturer |
Mfr Part Number |
ROHS? |
Sub OK? |
1 |
1 |
REF-14647 REV *B |
N/A |
Schematic |
N/A |
REF-14647 REV *B |
N/A |
N/A |
2 |
1 |
121R-46100 REV *B |
N/A |
Assembly Drawing |
N/A |
121R-46100 REV *B |
N/A |
N/A |
3 |
1 |
N/A |
N/A |
Fab Drawing |
N/A |
N/A |
N/A |
N/A |
4 |
1 |
121R-46100 REV *B |
N/A |
Assembly Adhesive Label |
N/A |
121R-46100 REV *B |
N/A |
N/A |
5 |
1 |
PDCR-9461 REV *A |
PCB |
PRINTED CIRCUIT BOARD |
Cypress Semiconductor |
PDCR-9461 REV *A |
NA |
NA |
6 |
1 |
200R-13246 |
BH1 |
BATTERY HOLDER 9V Male PC MT |
Keystone Electronics |
593 |
YES |
YES |
7 |
1 |
200R-13245 |
BH2 |
BATTERY HOLDER 9V Female PC MT |
594 |
YES |
YES |
8 |
4 |
710R-14367 |
C1,C3,C9,C30 |
CAP ELECT 10UF 25V VS SMD size B |
Panasonic - ECG |
EEE-1EA100WR |
YES |
YES |
9 |
1 |
710R-14873 |
C2 |
CAP ELECT 330UF 25V FK SMD |
Panasonic - ECG |
EEE-FK1E331P |
YES |
YES |
10 |
2 |
730R-14723 |
C4,C25 |
CAP CERAMIC 1.0UF 25V X5R 0603 10% |
Taiyo Yuden |
TMK107BJ105KA-T |
YES |
YES |
11 |
1 |
720R-11297 |
C10 |
CAP 10000PF 16V CERAMIC X7R 0402 |
Yageo America |
04022R103K7B20D |
YES |
YES |
12 |
10 |
730R-11274 |
C11,C13,C14,C15,C16,C21,C22,C26,C27,C28 |
CAP .10UF 16V CERAMIC X7R 0603 |
Kemet |
C0603C104J4RACTU |
YES |
YES |
13 |
2 |
730R-11353 |
C12,C29 |
CAP 10UF 16V CERAMIC X5R 1210 |
Panasonic - ECG |
ECJ-4YB1C106K |
YES |
YES |
14 |
1 |
730R-11131 |
C17 |
CAP .33UF 16V CERAMIC X7R 0805 |
Panasonic - ECG |
ECJ-2YB1C334K |
YES |
YES |
15 |
2 |
730R-10074 |
C20,C23 |
CAP .1UF 50V CERAMIC X7R 0805 |
Panasonic - ECG |
ECJ-2YB1H104K |
YES |
YES |
16 |
1 |
730R-15034 |
C24 |
CAP 33nF 50V CERAMIC X8R 0603 |
TDK Corporation |
C1608X8R1H333K |
YES |
YES |
17 |
1 |
860R-10292 |
D1 |
LED GREEN CLEAR 1206 SMD |
Chicago Miniature Lamp, Inc |
CMD15-21VGC/TR8 |
YES |
YES |
18 |
1 |
810R-14768 |
D2 |
DIODE SCHOTTKY 40V 1.5A SMA |
Vishay IR |
10MQ040NTRPBF |
YES |
YES |
19 |
4 |
800R-11254 |
D3,D4,D5,D6 |
LED HI EFF RED CLEAR 1206 SMD |
CMD15-21VRC/TR8 |
YES |
YES |
20 |
1 |
810R-15036 |
D7 |
DIODE ZENER 3.6V 500MW SOD123 |
ON Semiconductor |
MMSZ4685T1G |
YES |
ASK |
21 |
1 |
800R-15037 |
F1 |
FUSE RESETTABLE .10A 30V HLD SMD |
Bourns |
MF-USMF010-2 |
YES |
ASK |
22 |
1 |
430R-14648 |
J1 |
CONN JACK POWER 2.1mm PCB RA |
CUI |
PJ-102A |
YES |
Yes, as long as the inner pin is 2.0mmdiameter |
23 |
4 |
420R-15020 |
J2,J3,J4,J5 |
CONN HEADER 6POS .100 STR 15AU |
FCI |
67996-206HLF |
YES |
ASK |
24 |
4 |
420R-14394 |
J6,J7,J8,J12 |
CONN HEADR BRKWAY .100 03POS STR |
Tyco Electronics/Amp |
9-146280-0-03 |
YES |
YES |
25 |
1 |
420R-14207 |
J9 |
CONN USB MINI B SMT RIGHT ANGLE |
Tyco |
1734035-2 |
YES |
YES |
26 |
3 |
420R-15019 |
J10,J11,J14 |
CONN HEADR BRKWAY .100 02POS STR |
Tyco Electronics |
9-146280-0-02 |
YES |
YES |
27 |
4 |
420R-14748 |
P1,P2,P3,P4 |
CONN FMALE 32POS DL .050 SMT GOLD |
Samtec |
RSM-116-02-S-D-LC |
YES |
ASK |
28 |
3 |
420R-14749 |
P5,P7,P8 |
CONN FMALE 40POS DL .100 R/A GOLD |
Sullins Electronics Corp. |
PPPC202LJBN-RC |
YES |
YES |
29 |
1 |
420R-14750 |
P6 |
CONN FMALE 46POS DL .100 R/A GOLD |
PPPC232LJBN-RC |
YES |
YES |
30 |
1 |
400-00034 |
P9 |
CONN RECT 6POS .100 VERT |
3M |
929850-01-06-RA |
YES |
ASK |
31 |
1 |
200R-14783 |
P11 |
SOLDERLESS BREADBOARD 1.8x1.35 |
3M |
923273-I |
YES |
YES |
32 |
1 |
420R-13978 |
P12 |
CONN RECT 8POS .100 VERT |
3M |
929850-01-08-RA |
YES |
ASK |
33 |
1 |
420R-14763 |
P14 |
CONN RECT 12POS .100 VERT |
3M |
929850-01-12-RA |
YES |
YES |
34 |
1 |
420R-13476 |
P15 |
CONN D-SUB RCPT R/A 9POS 30GOLD |
AMP Division of TYCO |
5747844-4 |
YES |
ASK |
35 |
1 |
420R-14858 |
P16 |
CONN RECEPT 4POS .100 VERT GOLD |
3M |
929850-01-04-RA |
YES |
ASK |
36 |
1 |
420R-14761 |
P17 |
CONN RECEPT 12POS 2mm SMD TIN |
Hirose Electric Co. LTD. |
DF11Z-12DS-2V(20) |
YES |
ASK |
37 |
1 |
420R-14760 |
P18 |
CONN REC .100 14POS for LCM-S01602DSR/A |
3M |
929850-01-14-RA |
YES |
NO |
38 |
1 |
400-00035 |
P19 |
CONN RECT 17POS .100 VERT |
3M |
929850-01-17-RA |
YES |
ASK |
39 |
10 |
630R-10039 |
R1,R21,R22,R23,R24,R25,R26,R28,R29,R30 |
RES 1.0K OHM 1/16W 5% 0603 SMD |
Panasonic - ECG |
ERJ-3GEYJ102V |
YES |
YES |
40 |
1 |
630R-14857 |
R10 |
RES 120 OHM 1/10W 5% 0603 SMD |
Panasonic-ECG |
ERJ-3GEYJ121V |
YES |
YES |
41 |
1 |
670R-14664 |
R11 |
TRIMPOT 500 OHM 6mm SQ SMD |
Bourns Inc. |
3361P-1-501GLF |
YES |
ASK |
42 |
1 |
610R-10040 |
R14 |
RES 100K OHM 1/16W 5% 0402 SMD |
Panasonic - ECG |
ERJ-2GEJ104X |
YES |
YES |
43 |
1 |
620R-10623 |
R15 |
RES 200 OHM 1/16W 5% 0603 SMD |
Panasonic - ECG |
ERJ-3GEYJ201V |
YES |
YES |
44 |
9 |
620R-10519 |
R16,R18,R41,R42,R43,R44,R45,R46,R47 |
RES ZERO OHM 1/16W 5% 0603 SMD |
Panasonic - ECG |
ERJ-3GEY0R00V |
YES |
YES |
45 |
2 |
620R-10524 |
R17,R19 |
RES 100 OHM 1/16W 5% 0603 SMD |
Panasonic - ECG |
ERJ-3GEYJ101V |
YES |
YES |
46 |
1 |
600-00153 |
R20 |
10K OHM THUMBWH CERM ST POT |
BI Technologies |
91AR10KLF |
YES |
ASK |
47 |
1 |
670R-13632 |
R31 |
POT 10K CARBON LAYDOWN (103) |
Panasonic - ECG |
EVN-D8AA03B14 |
YES |
ASK |
48 |
7 |
600-00156 |
R32,R33,R34,R35,R36,R37,R38 |
RES 6.04K OHM 1/10W 1% 0603 SMD |
Panasonic - ECG |
ERJ-3EKF6041V |
YES |
YES |
49 |
1 |
630R-14779 |
R39 |
RES 200K OHM 1/10W 5% 0603 SMD |
Panasonic-ECG |
ERJ-3GEYJ204V |
YES |
YES |
50 |
1 |
620R-12056 |
R48 |
RES 100K OHM 1/10W 1% 0603 SMD |
Yageo |
RC0603FR-07100KL |
YES |
YES |
51 |
3 |
200R-14786 |
SW1,SW2,SW4 |
SWITCH TACT 6mm MOM 150GF |
Omron |
B3F-1022 |
YES |
YES |
52 |
1 |
200-00003 |
SW3 |
SWITCH SLIDE MINI SPDT PCMNT SLV |
APEM Components |
GH36P010001 |
YES |
ASK |
53 |
5 |
200R-11428 |
TP1,TP2,TP3,TP4,TP14 |
TEST POINT 43 HOLE 65 PLATED RED |
5000 |
YES |
YES |
54 |
4 |
200R-11507 |
TP18,TP19,TP56,TP58 |
TEST POINT 43 HOLE 65 PLATED WHITE |
5002 |
YES |
YES |
55 |
9 |
200R-11429 |
TP30,TP32,TP33,TP34,TP35,TP36,TP37,TP38,TP39 |
TEST POINT 43 HOLE 65 PLATED BLACK |
5001 |
YES |
YES |
56 |
1 |
800R-14328 |
TVS1 |
TVS 5.0 VOLT 350 WATT SOD-323 |
Semtech |
SD05.TCT |
YES |
ASK |
57 |
1 |
500R-14661 |
U2 |
IC REG LDO 1.0A 5.0V TO-252 |
Diodes Inc |
AP1117D50L-13 |
YES |
ASK |
58 |
1 |
520-00005 |
U4 |
IC REG LDO 0.3A ADJ 8MSOP |
National Semiconductor |
LP3982IMM-ADJ/NOPB |
YES |
ASK |
59 |
1 |
500R-13586 |
U5 |
IC SINGLE USB PORT TVS SOT-23-6 |
Texas Instruments |
SN65220DBV |
YES |
ASK |
60 |
1 |
500R-14771 |
U6 |
IC LINE DRVR/RCVR RS232 16-SOIC |
Texas Insturments |
SN65C3232ED |
YES |
ASK |
61 |
1 |
500R-14775 |
U7 |
IC XLATR 8BIT LV 20-TSSOP |
NXP Semiconductors |
GTL2003PW |
YES |
ASK |
62 |
1 |
420R-14774 |
U8 |
IC SOCKET 8PIN MS TIN/TIN .300 |
Mill-Max Manufacturing |
110-44-308-41-001000 |
YES |
ASK |
63 |
1 |
500R-14773 |
U11 |
IC REG LDO 300mA 3.3V SOT89R |
Diodes Inc |
AP130-33YRL-13 |
YES |
ASK |
64 |
1 |
800R-13241 |
NA |
5V LCD Module 16POS w/14 pin headerinstalled |
Lumex |
LCM-S01602DSR/A |
YES |
ASK |
65 |
5 |
200R-14746 |
NA |
BUMPER WHITE .500X.23 SQUARE |
Richco Plastics Co. |
RBS-3R |
YES |
ASK |
66 |
11 |
NA |
NA |
SHUNT GOLD W/HANDLE, BLACK |
Kobiconn |
151-8030-E |
YES |
ASK |
DO NOT INSTALL |
67 |
2 |
NA |
R27,R49 |
RES NO LOAD 0603 SMD |
NA |
NA |
68 |
1 |
NA |
R40 |
RES NO LOAD 0805 SMD |
NA |
NA |
