Item |
Qty |
Reference |
Value |
Description |
Manufacturer |
Mfr Part Number |
Alternate Manufacturer |
Alternate Mfr Part Number |
Sub Allowed |
ROHS |
UL Certified |
1 |
PCB, 68.58 mm x 53.34 mm, High Tg, ENIGfinish, 4 layer, Color = RED, Silk = WHITE. |
Cypress |
N/A |
Yes |
N/A |
2 |
1 |
C1 |
2200 pFd |
CAP CER 2200PF 50V 5% NP0 0805 |
Murata |
GRM2165C1H222JA01D |
ASK |
Yes |
Yes |
3 |
13 |
C2,C9,C10,C12,C14,C15,C17,C20,C21,C22,C24,C25,C27 |
0.1 uFd |
CAP .1UF 16V CERAMIC Y5V 0402 |
Panasonic - ECG |
ECJ-0EF1C104Z |
ASK |
Yes |
Yes |
4 |
9 |
C3,C11,C13,C18,C19,C23,C26,C28,C29 |
1.0 uFd |
CAP CERAMIC 1.0UF 25V X5R 0603 10% |
Taiyo Yuden |
TMK107BJ105KA-T |
ASK |
Yes |
Yes |
5 |
1 |
C4 |
10 uF 25V |
CAP TANT 10UF 25V 10% 1210 |
AVX Corporation |
TPSB106K025R1800 |
ASK |
Yes |
Yes |
6 |
1 |
C6 |
22 uF 16V |
CAP TANT 22UF 16V 10% 1210 |
AVX Corporation |
TPSB226K016R0600 |
ASK |
Yes |
Yes |
7 |
1 |
C16 |
0.01 uFd |
CAP 10000PF 16V CERAMIC 0402 SMD |
Panasonic - ECG |
ECJ-0EB1C103K |
ASK |
Yes |
Yes |
8 |
1 |
C8 |
10uFd |
CAP CER 10UF 6.3V 20% X5R 0603 |
Samsung Electro-Mechanics America, Inc |
CL10A106MQ8NNNC |
ASK |
Yes |
Yes |
9 |
7 |
D1,D2,D3,D4,D9,D10,D11 |
MBR05 |
DIODE SCHOTTKY 0.5A 20V SOD-123 |
Fairchild Semiconductor |
MBR0520L |
ASK |
Yes |
Yes |
10 |
1 |
LED1 |
Power LED Amber |
LED 595NM AMB DIFF 0805 SMD |
Avago Technologies |
HSMA-C170 |
ASK |
Yes |
Yes |
11 |
1 |
D5 |
2V Zener |
DIODE ZENER 2V 500MW SOD123 |
Diodes Inc |
BZT52C2V0-7-F |
ASK |
Yes |
Yes |
12 |
3 |
D6, D7, D8 |
ESD diode |
SUPPRESSOR ESD 5VDC 0603 SMD |
Bourns Inc. |
CG0603MLC-05LE |
ASK |
Yes |
Yes |
13 |
1 |
LED3 |
RGB LED |
LED RED/GREEN/BLUE PLCC4 SMD |
Cree, Inc. |
CLV1A-FKB-CJ1M1F1BB7R4S3 |
ASK |
Yes |
Yes |
14 |
1 |
LED2 |
Status LED Green |
LED GREEN CLEAR 0805 SMD |
Chicago Miniature |
CMD17-21VGC/TR8 |
ASK |
Yes |
Yes |
15 |
1 |
F1 |
FUSE |
PTC Resettable Fuses 15Volts 100Amps |
Bourns |
MF-MSMF050-2 |
ASK |
Yes |
Yes |
16 |
2 |
J1, J4 |
8x1 RECP |
CONN HEADER FEMALE 8POS .1" GOLD |
Sullins Connector Solutions |
PPPC081LFBN-RC |
Protectron Electromech |
P9401-08-21 |
ASK |
Yes |
Yes |
17 |
1 |
J2 |
6x1 RECP |
CONN HEADER FMAL 6POS.1" GOLD |
PPPC061LFBN-RC |
P9401-06-21 |
ASK |
Yes |
Yes |
18 |
1 |
J3 |
10x1 RECP |
CONN HEADER FMALE 10POS .1" GOLD |
PPPC101LFBN-RC |
P9401-10-21 |
ASK |
Yes |
Yes |
19 |
1 |
J5 |
1X1 RECP |
CONN RCPT 1POS .100" SNGL HORZ |
Samtec Inc |
BCS-101-L-S-HE |
ASK |
Yes |
Yes |
20 |
1 |
J6 |
50MIL KEYED SMD |
CONN HEADER 10 PIN 50MIL KEYED SMD |
Samtec |
FTSH-105-01-L-DV-K |
ASK |
Yes |
Yes |
21 |
1 |
J8 |
6x2 RECP |
CONN HEADER FMAL 12PS.1" DL GOLD |
PPPC062LFBN-RC |
P9403-12-21 |
ASK |
Yes |
Yes |
22 |
1 |
J9 |
3p_jumper |
CONN HEADER VERT SGL 3POS GOLD |
3M |
961103-6404-AR |
ASK |
Yes |
Yes |
23 |
1 |
J10 |
USB MINI B |
CONN USB RECEPTACLE 5POS RT ANG |
Molex Inc |
0548190519 |
ASK |
Yes |
Yes |
24 |
2 |
J13,J14 |
2p_jumper |
CONN HEADER VERT SGL 2POS GOLD |
3M |
961102-6404-AR |
ASK |
Yes |
Yes |
25 |
3 |
Q1,Q2,Q3 |
PMOS |
MOSFET P-CH 30V 3.8A SOT23-3 |
Diodes Inc |
DMP3098L-7 |
ASK |
Yes |
Yes |
26 |
1 |
R3 |
560 ohm |
RES 560 OHM 1/8W 5% 0805 SMD |
Panasonic - ECG |
ERJ-6GEYJ561V |
ASK |
Yes |
Yes |
27 |
24 |
R4,R7,R11,R12,R14,R16,R18,R24,R25,R32,R33,R34,R44,R45,R47,R48,R49,R50,R51,R52,R53,R54,R55,R57 |
ZERO |
RES 0.0 OHM 1/10W 0603 SMD |
Panasonic-ECG |
ERJ-3GEY0R00V |
ASK |
Yes |
Yes |
28 |
1 |
R5 |
ZERO |
RES 0.0 OHM 1/8W 0805 SMD |
Panasonic-ECG |
ERJ-6GEY0R00V |
ASK |
Yes |
Yes |
29 |
4 |
R8,R9 |
2.2K |
RES 2.2K OHM 1/10W 5% 0603 SMD |
Panasonic - ECG |
ERJ-3GEYJ222V |
ASK |
Yes |
Yes |
30 |
1 |
R13 |
100K |
RES 100K OHM 1/10W 5% 0402 SMD |
Panasonic - ECG |
ERJ-2GEJ104X |
ASK |
Yes |
Yes |
31 |
2 |
R26, R27 |
22E |
RES 22 OHM 1/10W 1% 0603 SMD |
Panasonic - ECG |
ERJ-3EKF22R0V |
ASK |
Yes |
Yes |
32 |
1 |
R28 |
2.2K |
RES 2.2K OHM 1/8W 5% 0805 SMD |
Panasonic - ECG |
ERJ-6GEYJ222V |
ASK |
Yes |
Yes |
33 |
2 |
R29,R30 |
1.5K |
RES 1.5K OHM 1/8W 5% 0805 SMD |
Panasonic - ECG |
ERJ-6GEYJ152V |
ASK |
Yes |
Yes |
34 |
1 |
R31 |
330 ohm |
RES 330 OHM 1/8W 5% 0805 SMD |
Panasonic - ECG |
ERJ-6GEYJ331V |
ASK |
Yes |
Yes |
35 |
1 |
R35 |
232 ohm |
RES 232 OHM 1/10W 1% 0603 SMD |
Panasonic - ECG |
ERJ-3EKF2320V |
ASK |
Yes |
Yes |
36 |
1 |
R36 |
120 ohm |
RES 120 OHM 1/10W 1% 0603 SMD |
Panasonic - ECG |
ERJ-3EKF1200V |
ASK |
Yes |
Yes |
37 |
2 |
R37,R39 |
15K |
RES 15K OHM 1/10W 5% 0603 SMD |
Panasonic - ECG |
ERJ-3GEYJ153V |
ASK |
Yes |
Yes |
38 |
2 |
R38,R40 |
30K |
RES 30K OHM 1/10W 5% 0603 SMD |
Panasonic - ECG |
ERJ-3GEYJ303V |
ASK |
Yes |
Yes |
39 |
1 |
R42 |
1K |
RES 1K OHM 1/8W 5% 0805 SMD |
Panasonic - ECG |
ERJ-6GEYJ102V |
ASK |
Yes |
Yes |
40 |
1 |
R43 |
442 ohm |
RES 442 OHM 1/10W 1% 0603 SMD |
Panasonic - ECG |
ERJ-3EKF4420V |
ASK |
Yes |
Yes |
41 |
1 |
SW1 |
SW PUSHBUTTON |
SWITCH TACTILE SPST-NO 0.05A 12V |
Panasonic - ECG |
EVQ-PE105K |
ASK |
Yes |
Yes |
42 |
1 |
TP5 |
BLACK |
TEST POINT PC MINI .040"D Black |
Keystone Electronics |
5001 |
ASK |
Yes |
Yes |
43 |
2 |
TVS1,TVS2 |
5V 350W |
TVS UNIDIR 350W 5V SOD-323 |
Dioded Inc. |
SD05-7 |
ASK |
Yes |
Yes |
44 |
1 |
U1 |
NCP1117DTARKG |
NCP1117DTARKG |
ON Semiconductor |
NCP1117DTARKG |
ASK |
Yes |
Yes |
45 |
1 |
U2 |
PSoC 4 S0 (CY8C400) |
24 QFN PSoC4 S0 target chip |
Cypress Semiconductor |
CY8C4014LQI-422 |
ASK |
Yes |
Yes |
46 |
1 |
U3 |
PSoC 5LP (CY8C5868LTI-LP039) |
68QFN PSoC 5LP chip for USB debug channeland USB-Serial interface |
CY8C5868LTI-LP039 |
ASK |
Yes |
Yes |
47 |
1 |
U4 |
F-RAM |
F-RAM with I2C interface |
FM24W256-G |
ASK |
Yes |
Yes |
No Load Components | | | | | | | | | |
48 |
1 |
BT1 |
Coin Cell Battery Holder |
HOLDER CR2032 GOLD LEADS SMD |
MPD |
BU2032SM-BT-GTR |
1060 | | | |
49 |
1 |
C5 |
10000 pFd |
CAP CER 10000PF 50V 5% NP0 0805 |
Murata |
GRM2195C1H103JA01D |
50 |
2 |
C7,C30 |
0.1 uFd |
Panasonic - ECG |
ECJ-0EF1C104Z |
51 |
1 |
J7 |
50MIL KEYED SMD |
Samtec |
52 |
1 |
J11 |
2 PIN HDR |
CONN HEADER FEMALE 2POS .1" GOLD |
PPPC021LFBN-RC |
P9401-02-21 | | | |
53 |
1 |
J12 |
3X2 RECP |
CONN HEADER .100 DUAL STR 12POS |
PBC06DFAN |
54 |
7 |
R1,R2,R15,R17,R19,R46,R56 |
ZERO |
Panasonic-ECG |
ERJ-3GEY0R00V |
55 |
1 |
R6 |
ZERO |
Panasonic-ECG |
ERJ-6GEY0R00V |
56 |
2 |
R10,R41 |
4.7K |
RES 4.7K OHM 1/10W 5% 0603 SMD |
Panasonic-ECG |
ERJ-3GEYJ472V |
57 |
2 |
R20,R21 |
10K |
RES 10K OHM 1/10W 5% 0603 SMD |
Panasonic - ECG |
ERJ-3GEYJ103V |
58 |
2 |
R22,R23 |
2.2K |
Panasonic - ECG |
ERJ-3GEYJ222V |
59 |
3 |
TP1,TP2,TP6 |
RED |
TEST POINT PC MINI .040"D RED |
5000 |
60 |
2 |
TP3,TP4 |
BLACK |
5001 |
Install on Bottom of PCB As per theSilk Screen in the Corners | | | | | | | | | |
61 |
4 |
N/A |
N/A |
BUMPON CYLINDRICAL .312X.215 BLACK |
3M |
SJ61A6 |
ASK |
Yes |
Yes |
Special Jumper InstallationInstructions | | | | | | | | | |
62 |
1 |
J9 |
Install jumper across pins 1 and 2 |
Rectangular Connectors MINI JUMPERGF 6.0MM CLOSE TYPE BLACK |
Kobiconn |
151-8010-E |
ASK |
Yes |
Yes |
63 |
1 |
J13 |
Kobiconn |
151-8010-E |
ASK |
Yes |
Yes |
64 |
1 |
J14 |
Kobiconn |
151-8010-E |
ASK |
Yes |
Yes |
Label | | | | | | | | | | | |
65 |
1 |
N/A |
N/A |
LBL, PCBA Anti-Static Warning, 10mm X10mm |
Cypress Semiconductor | | | | | | |
66 |
1 |
N/A |
N/A |
LBL, PCA Label, Vendor Code, Datecode,Serial Number 121-60150-01 Rev 03 (YYWWVVXXXXX) |
67 |
1 |
N/A |
N/A |
LBL, QR code, 10mm X 10mm |
