Item |
Qty |
Reference |
Value |
Description |
Manufacturer |
Mfr Part Number |
1 |
PCB,3.32"x2.1" CAF resistantHigh Tg ENIG finish, 4 layer, Color = RED, Silk = WHITE. |
Cypress |
2 |
1 |
C1 |
2200 pFd |
CAP CER 2200PF 50V 5% NP0 0805 |
Murata |
GRM2165C1H222JA01D |
3 |
12 |
C2,C7,C12,C14,C15,C17,C20,C21,C22,C24,C25,C27 |
0.1 uFd |
CAP .1UF 16V CERAMIC Y5V 0402 |
Panasonic - ECG |
ECJ-0EF1C104Z |
4 |
11 |
C3,C5,C8,C10,C11,C13,C18,C19,C23,C26,C28 |
1.0 uFd |
CAP CERAMIC 1.0UF 25V X5R 0603 10% |
Taiyo Yuden |
TMK107BJ105KA-T |
5 |
1 |
C4 |
10 uF 25V |
CAP TANT 10UF 25V 10% 1210 |
AVX Corporation |
TPSB106K025R1800 |
6 |
1 |
C6 |
22 uF 16V |
CAP TANT 22UF 16V 10% 1210 |
AVX Corporation |
TPSB226K016R0600 |
7 |
1 |
C9 |
10000 pFd |
CAP CER 10000PF 50V 5% NP0 0805 |
Murata |
GRM2195C1H103JA01D |
8 |
1 |
C16 |
0.01 uFd |
CAP 10000PF 16V CERAMIC 0402 SMD |
Panasonic - ECG |
ECJ-0EB1C103K |
9 |
6 |
D1,D2,D4,D11,D12,D13 |
MBR05 |
DIODE SCHOTTKY 0.5A 20V SOD-123 |
Fairchild Semiconductor |
MBR0520L |
10 |
1 |
D3 |
Power LED Amber |
LED AMBER 591NM DIFF LENS 2012 |
Sharp Microelectronics |
LT1ZV40A |
11 |
1 |
D5 |
2V Zener |
DIODE ZENER 2V 500MW SOD123 |
Diodes Inc |
BZT52C2V0-7-F |
12 |
3 |
D6, D7, D8 |
ESD diode |
SUPPRESSOR ESD 5VDC 0603 SMD |
Bourns Inc. |
CG0603MLC-05LE |
13 |
1 |
D9 |
RGB LED |
LED RED/GREEN/BLUE PLCC4 SMD |
Cree, Inc. |
CLV1A-FKB-CJ1M1F1BB7R4S3 |
14 |
1 |
D10 |
Status LED Green |
LED GREEN CLEAR 0805 SMD |
Chicago Miniature |
CMD17-21VGC/TR8 |
15 |
1 |
F1 |
FUSE |
PTC Resettable Fuses 15Volts 100Amps |
Bourns |
MF-MSMF050-2 |
16 |
2 |
J1, J4 |
8x1 RECP |
CONN HEADER FEMALE 8POS .1" GOLD |
Sullins Connector Solutions |
PPPC081LFBN-RC |
17 |
1 |
J2 |
9x2 RECP |
CONN HEADER FMAL 18PS.1" DL GOLD |
PPPC092LFBN-RC |
18 |
1 |
J3 |
10x1 RECP |
CONN HEADER FMALE 10POS .1" GOLD |
PPPC101LFBN-RC |
19 |
1 |
J6 |
50MIL KEYED SMD |
CONN HEADER 10 PIN 50MIL KEYED SMD |
Samtec |
FTSH-105-01-L-DV-K |
20 |
1 |
J8 |
6x2 RECP |
CONN HEADER FMAL 12PS.1" DL GOLD |
PPPC062LFBN-RC |
21 |
1 |
J9 |
3p_jumper |
CONN HEADER VERT SGL 3POS GOLD |
3M |
961103-6404-AR |
22 |
1 |
J10 |
USB MINI B |
CONN USB MINI AB SMT RIGHT ANGLE |
TE Connectivity |
1734035-2 |
23 |
1 |
J13 |
2p_jumper |
CONN HEADER VERT SGL 2POS GOLD |
3M |
961102-6404-AR |
24 |
3 |
Q1,Q2,Q3 |
PMOS |
MOSFET P-CH 30V 3.8A SOT23-3 |
Diodes Inc |
DMP3098L-7 |
25 |
1 |
R3 |
560 ohm |
RES 560 OHM 1/8W 5% 0805 SMD |
Panasonic - ECG |
ERJ-6GEYJ561V |
26 |
12 |
R4,R11,R12,R14,R15,R16,R24,R25,R32,R33,R34,R45 |
ZERO |
RES 0.0 OHM 1/10W 0603 SMD |
Panasonic-ECG |
ERJ-3GEY0R00V |
27 |
1 |
R5 |
ZERO |
RES 0.0 OHM 1/8W 0805 SMD |
Panasonic-ECG |
ERJ-6GEY0R00V |
28 |
4 |
R8,R9,R22,R23 |
2.2K |
RES 2.2K OHM 1/10W 5% 0603 SMD |
Panasonic - ECG |
ERJ-3GEYJ222V |
29 |
2 |
R10,R41 |
4.7K |
RES 4.7K OHM 1/10W 5% 0603 SMD |
Panasonic-ECG |
ERJ-3GEYJ472V |
30 |
1 |
R13 |
100K |
RES 100K OHM 1/10W 5% 0402 SMD |
Panasonic - ECG |
ERJ-2GEJ104X |
31 |
5 |
R17,R18,R19,R20,R21 |
560 ohm |
RES 560 OHM 1/10W 5% 0603 SMD |
Panasonic-ECG |
ERJ-3GEYJ561V |
32 |
2 |
R26, R27 |
22E |
RES 22 OHM 1/10W 1% 0603 SMD |
Panasonic - ECG |
ERJ-3EKF22R0V |
33 |
1 |
R28 |
2.2K |
RES 2.2K OHM 1/8W 5% 0805 SMD |
Panasonic - ECG |
ERJ-6GEYJ222V |
34 |
2 |
R29,R30 |
1.5K |
RES 1.5K OHM 1/8W 5% 0805 SMD |
Panasonic - ECG |
ERJ-6GEYJ152V |
35 |
1 |
R31 |
330 ohm |
RES 330 OHM 1/8W 5% 0805 SMD |
Panasonic - ECG |
ERJ-6GEYJ331V |
36 |
1 |
R35 |
232 ohm |
RES 232 OHM 1/10W 1% 0603 SMD |
Panasonic - ECG |
ERJ-3EKF2320V |
37 |
1 |
R36 |
120 ohm |
RES 120 OHM 1/10W 1% 0603 SMD |
Panasonic - ECG |
ERJ-3EKF1200V |
38 |
2 |
R37,R39 |
1.5K |
RES 1.5K OHM 1/10W 5% 0603 SMD |
Panasonic - ECG |
ERJ-3GEYJ152V |
39 |
2 |
R38,R40 |
3K |
RES 3.0K OHM 1/10W 5% 0603 SMD |
Panasonic - ECG |
ERJ-3GEYJ302V |
40 |
1 |
R42 |
1K |
RES 1K OHM 1/8W 5% 0805 SMD |
Panasonic - ECG |
ERJ-6GEYJ102V |
41 |
1 |
R43 |
442 ohm |
RES 442 OHM 1/10W 1% 0603 SMD |
Panasonic - ECG |
ERJ-3EKF4420V |
42 |
2 |
SW1,SW2 |
SW PUSHBUTTON |
SWITCH TACTILE SPST-NO 0.05A 12V |
Panasonic - ECG |
EVQ-PE105K |
43 |
1 |
TP5 |
BLACK |
TEST POINT PC MINI .040"D Black |
Keystone Electronics |
5001 |
44 |
2 |
TVS1,TVS2 |
5V 350W |
TVS UNIDIR 350W 5V SOD-323 |
Dioded Inc. |
SD05-7 |
45 |
1 |
TVS4 |
18V 350W |
TVS DIODE 18V 1CH BI SMD |
Bourns Inc. |
CDSOD323-T18C |
46 |
1 |
U1 |
NCP1117DTARKG |
NCP1117DTARKG |
ON Semiconductor |
NCP1117DTARKG |
47 |
1 |
U2 |
PSoC 4 (CY8C4245AXI-483) |
44TQFP PSoC4A target chip |
Cypress Semiconductor |
CY8C4245AXI-483 |
48 |
1 |
U3 |
PSoC 5LP (CY8C5868LTI-LP039) |
68QFN PSoC 5LP chip for USB debug channeland USB-Serial interface |
CY8C5868LTI-LP039 |
No Load Components | | | | |
49 |
1 |
C29 |
1.0 uFd |
Taiyo Yuden |
TMK107BJ105KA-T |
50 |
1 |
J5 |
6X1 RECP RA |
CONN FEMALE 6POS .100" R/A GOLD |
PPPC061LGBN-RC |
51 |
1 |
J7 |
50MIL KEYED SMD |
Samtec |
52 |
1 |
J11 |
2 PIN HDR |
CONN HEADER FEMALE 2POS .1" GOLD |
PPPC021LFBN-RC |
53 |
1 |
J12 |
3x2 RECPT |
CONN HEADER FMAL 6PS .1" DL GOLD |
PPPC032LFBN-RC |
54 |
4 |
R1,R2,R7,R44,R46 |
ZERO |
Panasonic-ECG |
ERJ-3GEY0R00V |
55 |
1 |
R6 |
ZERO |
Panasonic-ECG |
ERJ-6GEY0R00V |
56 |
2 |
TP1,TP2 |
RED |
TEST POINT PC MINI .040"D RED |
5000 |
57 |
2 |
TP3,TP4,TP6 |
BLACK |
5001 |
58 |
1 |
TVS3 |
5V 350W |
Dioded Inc. |
SD05-7 |
Install on Bottom of PCB As per theSilk Screen in the Corners | | | | |
59 |
4 |
N/A |
N/A |
BUMPON CYLINDRICAL .312X.215 BLACK |
3M |
SJ61A6 |
Special Jumper InstallationInstructions | | | | |
60 |
1 |
J9 |
Install jumper across pins 1 and 2 |
Rectangular Connectors MINI JUMPERGF 6.0MM CLOSE TYPE BLACK |
Kobiconn |
151-8010-E |
61 |
1 |
J13 |
Kobiconn |
151-8010-E |
Label | | | | | | |
62 |
1 |
N/A |
N/A |
LBL, Kit Product Identification Label,Vendor Code, Datecode, Serial Number CY8CKIT-042 Rev** (YYWWVVXXXXX) |
Cypress Semiconductor | |
63 |
1 |
N/A |
N/A |
LBL, KIT Anti-Static Warning, 5/8" x2", "Attention Observe Precautions" |
64 |
1 |
N/A |
N/A |
Assembly Adhesive Label, Manufacturing ID |
65 |
1 |
N/A |
N/A |
Kit QR code |
