查看: 3208|回复: 10
[Allegro16.6以下] LS1043A住宅网关参考设计
发表于 2018-11-27 20:10:41 | 显示全部楼层 |阅读模式
[/free]
S12ZVMAEVB_QSP.zip (9.38 MB, 下载次数: 4)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_TOLCOMP_CLASSREFDES
HU2032-LFBATT_HOLDER_TH3_20MM_HU2032-LF_BATTERY HOLDER ICBT1
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC1
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC2
C_0402_IPCCAP_VERT_C_0402_IPC_1000PF1000pF ICC3
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC4
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC5
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC7
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC8
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC9
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC10
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC11
C_0805_IPCCAP_VERT_C_0805_IPC_4.7UF4.7uF ICC12
C_1812_IPCCAP_VERT_C_1812_IPC_68PF68pF ICC13
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC14
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC15
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC16
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC17
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC18
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC19
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC20
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC22
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC23
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC24
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC25
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC26
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC27
C_0805_IPCCAP_VERT_C_0805_IPC_4.7UF4.7uF ICC28
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC29
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC30
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC31
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC32
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC33
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC34
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC35
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC36
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC37
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC38
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC39
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC40
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC41
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC42
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC43
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC44
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC45
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC46
C_0402_IPCCAP_VERT_C_0402_IPC_.01UF.01uF ICC47
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC48
C_0402_IPCCAP_VERT_C_0402_IPC_.01UF.01uF ICC49
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC50
C_0402_IPCCAP_VERT_C_0402_IPC_.01UF.01uF ICC51
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC52
C_0402_IPCCAP_VERT_C_0402_IPC_.01UF.01uF ICC53
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC54
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC55
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC56
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC57
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC58
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC59
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC60
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC61
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC62
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC63
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC64
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC65
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC66
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC67
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC68
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC69
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC70
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC71
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC72
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC73
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC74
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC75
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC76
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC77
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC78
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC79
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC80
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC81
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC82
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC83
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC84
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC85
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC86
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC87
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC88
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC89
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC90
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC91
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC92
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC93
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC94
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC95
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC96
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC97
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC98
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC99
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC100
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC101
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC102
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC103
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC104
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC105
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC106
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC107
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC108
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC109
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC110
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC111
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC112
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC113
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC114
C_0805_IPCCAP_VERT_C_0805_IPC_4.7UF4.7uF ICC115
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC116
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC117
C_0402_IPCCAP_VERT_C_0402_IPC_.01UF.01uF ICC118
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC119
C_0402_IPCCAP_VERT_C_0402_IPC_.01UF.01uF ICC120
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC121
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC122
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC123
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC124
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC125
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC126
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC127
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC128
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC129
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC130
C_0402_IPCCAP_HORIZ_C_0402_IPC_22PF22pF ICC131
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC132
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC133
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC134
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC135
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC136
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC137
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC138
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC139
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC140
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC141
C_0402_IPCCAP_VERT_C_0402_IPC_18PF18pF ICC142
C_0402_IPCCAP_VERT_C_0402_IPC_18PF18pF ICC143
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC144
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC145
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC146
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC147
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC148
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC149
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC150
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC151
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC152
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC153
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC156
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC158
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC160
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC161
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC162
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC163
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC164
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC165
C_1206_IPCCAP_HORIZ_C_1206_IPC_1000PF,2KV1000pF,2KV ICC166
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC167
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC168
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC169
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC170
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC171
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC172
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC173
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC174
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC175
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC176
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC177
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC178
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC179
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC180
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC181
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC182
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC183
C_0402_IPCCAP_HORIZ_C_0402_IPC_1UF1uF ICC184
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC187
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC188
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC189
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC190
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC191
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC192
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC193
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC194
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC195
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC196
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC197
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC198
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC199
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC200
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC201
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC202
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC203
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC204
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC205
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC206
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC207
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC208
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC209
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC210
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC211
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC212
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC213
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC214
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC215
C_0805_IPCCAP_VERT_C_0805_IPC_4.7UF4.7uF ICC216
C_0402_IPCCAP_VERT_C_0402_IPC_.01UF.01uF ICC217
C_0402_IPCCAP_VERT_C_0402_IPC_.01UF.01uF ICC218
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC219
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC220
C_0805_IPCCAP_VERT_C_0805_IPC_4.7UF4.7uF ICC221
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC222
C_0805_IPCCAP_HORIZ_C_0805_IPC_22NF100V22nF 100V ICC223
C_0805_IPCCAP_VERT_C_0805_IPC_22NF100V22nF 100V ICC224
C_0805_IPCCAP_VERT_C_0805_IPC_22NF100V22nF 100V ICC225
C_0805_IPCCAP_HORIZ_C_0805_IPC_22NF100V22nF 100V ICC226
C_0805_IPCCAP_HORIZ_C_0805_IPC_22NF100V22nF 100V ICC227
C_0805_IPCCAP_VERT_C_0805_IPC_22NF100V22nF 100V ICC228
C_0805_IPCCAP_VERT_C_0805_IPC_22NF100V22nF 100V ICC229
C_0805_IPCCAP_HORIZ_C_0805_IPC_4.7UF4.7uF ICC230
C_0805_IPCCAP_HORIZ_C_0805_IPC_22NF100V22nF 100V ICC231
C_0805_IPCCAP_HORIZ_C_0805_IPC_4.7UF4.7uF ICC232
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC233
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC234
C_0402_IPCCAP_HORIZ_C_0402_IPC_2200PF2200pF ICC235
C_0402_IPCCAP_HORIZ_C_0402_IPC_22PF22pF ICC236
C_0603_IPCCAP_VERT_C_0603_IPC_0.1UF_100V0.1uF_100V ICC237
C_0603_IPCCAP_VERT_C_0603_IPC_0.1UF_100V0.1uF_100V ICC238
EEUFM1E221CAPT_VERT_EEUFM1E221_220UF_25V220uF_25V ICC239
C_0603_IPCCAP_VERT_C_0603_IPC_0.1UF_100V0.1uF_100V ICC240
ECA1JM100CAPT_VERT_ECA1JM100_10UF_63V10uF_63V ICC241
UVR_DDCAPT_VERT_UVR_DD_1UF_100V1uF_100V ICC242
C_0805_IPCCAP_VERT_C_0805_IPC_.22UF.22uF ICC243
C_0603_IPCCAP_VERT_C_0603_IPC_0.1UF0.1uF ICC244
C_0603_IPCCAP_VERT_C_0603_IPC_0.1UF_100V0.1uF_100V ICC245
C_0603_IPCCAP_VERT_C_0603_IPC_0.1UF_100V0.1uF_100V ICC246
UVR_DDCAPT_VERT_UVR_DD_1UF_100V1uF_100V ICC247
ECA1JM100CAPT_VERT_ECA1JM100_10UF_63V10uF_63V ICC248
C_0603_IPCCAP_VERT_C_0603_IPC_220PF220pF ICC249
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC250
C_0402_IPCCAP_VERT_C_0402_IPC_3000PF3000pF ICC251
C_0402_IPCCAP_VERT_C_0402_IPC_2.2UF2.2uF ICC252
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC253
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC254
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC255
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC256
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC257
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC258
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC259
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC260
C_0201_IPCCAP_VERT_C_0201_IPC_1500PF1500pF ICC261
CT_7343_IPCCAPT_VERT_CT_7343_IPC_470UF470uF ICC262
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC263
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC264
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC265
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC266
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC267
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC268
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC269
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC270
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC271
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC272
C_0201_IPCCAP_VERT_C_0201_IPC_1500PF1500pF ICC273
C_0201_IPCCAP_VERT_C_0201_IPC_1500PF1500pF ICC274
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC275
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC276
C_0201_IPC_03CAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC277
C_0402_IPCCAP_VERT_C_0402_IPC_3000PF3000pF ICC278
C_0402_IPCCAP_VERT_C_0402_IPC_2.2UF2.2uF ICC279
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC280
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC281
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC282
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC283
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC284
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC285
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC286
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC287
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC288
C_0201_IPCCAP_VERT_C_0201_IPC_1500PF1500pF ICC289
C_0201_IPCCAP_VERT_C_0201_IPC_1500PF1500pF ICC290
C_0201_IPCCAP_VERT_C_0201_IPC_1500PF1500pF ICC291
C_0201_IPCCAP_VERT_C_0201_IPC_1500PF1500pF ICC292
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC293
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC294
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC295
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC296
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC297
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC298
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC299
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC300
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC301
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC302
C_0201_IPCCAP_VERT_C_0201_IPC_1500PF1500pF ICC303
C_0201_IPCCAP_VERT_C_0201_IPC_1500PF1500pF ICC304
C_0201_IPCCAP_VERT_C_0201_IPC_1500PF1500pF ICC305
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC306
C_0402_IPCCAP_VERT_C_0402_IPC_3000PF3000pF ICC307
C_0402_IPCCAP_VERT_C_0402_IPC_2.2UF2.2uF ICC308
C_0201_IPCCAP_VERT_C_0201_IPC_1500PF1500pF ICC309
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC310
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC311
C0201_CIRCAP_VERT_C_0201_IPC_03_1UF1uF ICC312
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC313
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC314
C0201_CIRCAP_VERT_C_0201_IPC_03_1UF1uF ICC315
C_0402_IPCCAP_VERT_C_0402_IPC_3000PF3000pF ICC316
C_0201_IPC_03CAP_VERT_C_0201_IPC_03_1UF1uF ICC317
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC318
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC319
C_0402_IPCCAP_VERT_C_0402_IPC_3000PF3000pF ICC320
C_0805_IPCCAP_VERT_C_0805_IPC_4.7UF4.7uF ICC321
C_0603_IPCCAP_VERT_C_0603_IPC_.47UF.47uF ICC322
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC323
C_0805_IPCCAP_VERT_C_0805_IPC_4.7UF4.7uF ICC324
C_0603_IPCCAP_VERT_C_0603_IPC_.47UF.47uF ICC325
C_0201_IPC_03CAP_VERT_C_0201_IPC_03_1UF1uF ICC326
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC327
C_0402_IPCCAP_VERT_C_0402_IPC_2.2UF2.2uF ICC328
C_0402_IPCCAP_VERT_C_0402_IPC_3000PF3000pF ICC329
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC330
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC331
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC332
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC333
C_0402_IPCCAP_VERT_C_0402_IPC_3000PF3000pF ICC334
C_0402_IPCCAP_VERT_C_0402_IPC_2.2UF2.2uF ICC335
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC336
C_0402_IPCCAP_VERT_C_0402_IPC_2.2UF2.2uF ICC337
C_0201_IPCCAP_VERT_C_0201_IPC_1500PF1500pF ICC338
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC339
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC340
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC341
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC342
C_0201_IPCCAP_VERT_C_0201_IPC_1500PF1500pF ICC343
C_0402_IPCCAP_VERT_C_0402_IPC_2.2UF2.2uF ICC344
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC345
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC346
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC347
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC348
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC349
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC350
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC351
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC352
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC353
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC354
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC355
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC356
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC357
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC358
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC359
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC360
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC361
CT_7343_IPCCAPT_VERT_CT_7343_IPC_470UF470uF ICC362
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC363
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC364
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC365
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC366
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC367
C_0201_IPC_03CAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC368
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC369
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC370
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC371
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC372
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC373
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC374
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC375
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC376
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC377
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC378
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC379
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC380
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC381
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC382
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC383
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC384
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC385
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC386
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC387
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC388
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC389
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC390
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC391
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC392
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC393
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC394
C_0201_IPC_03CAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC395
C_0201_IPC_03CAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC396
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC397
C_0201_IPCCAP_VERT_C_0201_IPC_1500PF1500pF ICC398
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC399
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC400
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC401
C0201_CIRCAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC402
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC403
C_0201_IPC_03CAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC404
C_0201_IPC_03CAP_VERT_C_0201_IPC_03_0.1UF0.1uF ICC405
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC408
C_0402_IPCCAP_VERT_C_0402_IPC_22NF22nF ICC411
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC412
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC414
C_0402_IPCCAP_VERT_C_0402_IPC_.01UF.01uF ICC415
C_0402_IPCCAP_VERT_C_0402_IPC_22NF22nF ICC416
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC417
C_0402_IPCCAP_VERT_C_0402_IPC_.01UF.01uF ICC418
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC419
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC420
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC421
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC422
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC423
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC424
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC425
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC426
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC427
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC428
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC429
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC430
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC431
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC432
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC433
C_1210_IPC_1CAP_VERT_C_1210_IPC_1_100UF100uF ICC434
C_1210_IPC_1CAP_VERT_C_1210_IPC_1_100UF100uF ICC435
C_0805_IPCCAP_VERT_C_0805_IPC_47UF47uF ICC436
C_0805_IPCCAP_VERT_C_0805_IPC_47UF47uF ICC437
C_0805_IPCCAP_VERT_C_0805_IPC_2.2UF2.2uF ICC438
C_0805_IPCCAP_VERT_C_0805_IPC_47UF47uF ICC439
C_0805_IPCCAP_VERT_C_0805_IPC_47UF47uF ICC440
C_0805_IPCCAP_VERT_C_0805_IPC_47UF47uF ICC441
C_0805_IPCCAP_VERT_C_0805_IPC_47UF47uF ICC442
C_0402_IPCCAP_VERT_C_0402_IPC_100PF100pF ICC443
C_0201_IPCCAP_VERT_C_0201_IPC_.01UF.01uF ICC444
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC445
C_0805_IPCCAP_VERT_C_0805_IPC_47UF47uF ICC446
C_0805_IPCCAP_VERT_C_0805_IPC_47UF47uF ICC447
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC448
C_0402_IPCCAP_VERT_C_0402_IPC_10PF10pF ICC449
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC450
C_0402_IPCCAP_VERT_C_0402_IPC_10PF10pF ICC451
C_0402_IPCCAP_VERT_C_0402_IPC_10PF10pF ICC452
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC453
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC455
C_0402_IPCCAP_VERT_C_0402_IPC_.01UF.01uF ICC456
C_0402_IPCCAP_VERT_C_0402_IPC_22PF22pF ICC457
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC458
C_1206_IPCCAP_VERT_C_1206_IPC_10UF10uF ICC459
CT_7343_IPCCAPT_VERT_CT_7343_IPC_100UF,25100uF, 25V ICC460
CT_7343_IPCCAPT_VERT_CT_7343_IPC_100UF,25100uF, 25V ICC461
CT_7343_IPCCAPT_VERT_CT_7343_IPC_100UF,25100uF, 25V ICC462
C_0402_IPCCAP_VERT_C_0402_IPC_10PF10pF ICC464
C_0402_IPCCAP_VERT_C_0402_IPC_1000PF1000pF ICC466
C_0603_IPCCAP_VERT_C_0603_IPC_.47UF.47uF ICC467
C_0603_IPCCAP_VERT_C_0603_IPC_.47UF.47uF ICC468
C_0805_IPCCAP_VERT_C_0805_IPC_4.7UF4.7uF ICC469
C_0603_IPCCAP_VERT_C_0603_IPC_.47UF.47uF ICC470
C_0805_IPCCAP_VERT_C_0805_IPC_4.7UF4.7uF ICC471
C_0805_IPCCAP_VERT_C_0805_IPC_4.7UF4.7uF ICC472
C_0805_IPCCAP_VERT_C_0805_IPC_4.7UF4.7uF ICC473
C_0805_IPCCAP_VERT_C_0805_IPC_4.7UF4.7uF ICC474
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC475
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC476
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC477
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC478
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC479
C_0805_IPCCAP_VERT_C_0805_IPC_4.7UF4.7uF ICC480
C_0805_IPCCAP_VERT_C_0805_IPC_4.7UF4.7uF ICC481
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC482
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC483
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC484
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC485
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC486
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC487
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC488
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC489
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC490
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC491
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC492
C_0805_IPCCAP_VERT_C_0805_IPC_4.7UF4.7uF ICC493
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC494
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC495
C_0805_IPCCAP_VERT_C_0805_IPC_4.7UF4.7uF ICC496
C_0805_IPCCAP_VERT_C_0805_IPC_4.7UF4.7uF ICC497
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC498
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC499
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC500
C_0805_IPCCAP_VERT_C_0805_IPC_4.7UF4.7uF ICC501
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC502
C_0805_IPCCAP_VERT_C_0805_IPC_4.7UF4.7uF ICC503
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC504
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC505
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC506
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC507
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC508
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC509
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC510
C_0603_IPCCAP_VERT_C_0603_IPC_.47UF.47uF ICC511
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC512
C_0402_IPCCAP_HORIZ_C_0402_IPC_100PF100pF ICC513
C_0402_IPCCAP_HORIZ_C_0402_IPC_100PF100pF ICC514
C_0805_IPCCAP_HORIZ_C_0805_IPC_1UF1uF ICC515
C_0805_IPCCAP_VERT_C_0805_IPC_1UF1uF ICC516
C_0805_IPCCAP_HORIZ_C_0805_IPC_1000PF1000pF ICC517
C_0805_IPCCAP_HORIZ_C_0805_IPC_1UF1uF ICC518
C_0402_IPCCAP_VERT_C_0402_IPC_8.2PF8.2pF ICC519
C_0402_IPCCAP_VERT_C_0402_IPC_8.2PF8.2pF ICC520
C_0805_IPCCAP_HORIZ_C_0805_IPC_1000PF1000pF ICC521
C_0402_IPCCAP_HORIZ_C_0402_IPC_4700PF4700pF ICC522
C_0402_IPCCAP_HORIZ_C_0402_IPC_100PF100pF ICC523
C_0402_IPCCAP_HORIZ_C_0402_IPC_4700PF4700pF ICC524
C_0402_IPCCAP_HORIZ_C_0402_IPC_100PF100pF ICC525
C_0402_IPCCAP_VERT_C_0402_IPC_27PF27pF ICC526
C_0402_IPCCAP_HORIZ_C_0402_IPC_820PF820pF ICC527
C_0603_IPCCAP_HORIZ_C_0603_IPC_0.1UF_100V0.1uF_100V ICC528
C_0402_IPCCAP_HORIZ_C_0402_IPC_150PF150pF ICC529
C_0402_IPCCAP_HORIZ_C_0402_IPC_270PF270pF ICC530
C_0603_IPCCAP_VERT_C_0603_IPC_3900PF3900pF ICC531
C_0603_IPCCAP_VERT_C_0603_IPC_3900PF3900pF ICC532
C_0402_IPCCAP_HORIZ_C_0402_IPC_270PF270pF ICC533
C_0402_IPCCAP_HORIZ_C_0402_IPC_820PF820pF ICC534
C_0603_IPCCAP_HORIZ_C_0603_IPC_0.1UF_100V0.1uF_100V ICC535
C_0402_IPCCAP_HORIZ_C_0402_IPC_150PF150pF ICC536
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC537
C_0402_IPCCAP_HORIZ_C_0402_IPC_270PF270pF ICC538
C_0402_IPCCAP_HORIZ_C_0402_IPC_22PF22pF ICC539
C_0402_IPCCAP_VERT_C_0402_IPC_4.7PF4.7pF ICC540
C_0402_IPCCAP_VERT_C_0402_IPC_4.7PF4.7pF ICC541
C_0402_IPCCAP_HORIZ_C_0402_IPC_270PF270pF ICC542
C_0402_IPCCAP_HORIZ_C_0402_IPC_22PF22pF ICC543
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC544
C_0402_IPCCAP_HORIZ_C_0402_IPC_100PF100pF ICC545
C_0402_IPCCAP_HORIZ_C_0402_IPC_100PF100pF ICC546
C_0805_IPCCAP_HORIZ_C_0805_IPC_1UF1uF ICC547
C_0805_IPCCAP_VERT_C_0805_IPC_1UF1uF ICC548
C_0805_IPCCAP_HORIZ_C_0805_IPC_1000PF1000pF ICC549
C_0805_IPCCAP_HORIZ_C_0805_IPC_1UF1uF ICC550
C_0402_IPCCAP_VERT_C_0402_IPC_8.2PF8.2pF ICC551
C_0402_IPCCAP_VERT_C_0402_IPC_8.2PF8.2pF ICC552
C_0805_IPCCAP_HORIZ_C_0805_IPC_1000PF1000pF ICC553
C_0402_IPCCAP_HORIZ_C_0402_IPC_4700PF4700pF ICC554
C_0402_IPCCAP_HORIZ_C_0402_IPC_100PF100pF ICC555
C_0402_IPCCAP_HORIZ_C_0402_IPC_4700PF4700pF ICC556
C_0402_IPCCAP_HORIZ_C_0402_IPC_100PF100pF ICC557
C_0402_IPCCAP_VERT_C_0402_IPC_27PF27pF ICC558
C_0402_IPCCAP_HORIZ_C_0402_IPC_820PF820pF ICC559
C_0603_IPCCAP_HORIZ_C_0603_IPC_0.1UF_100V0.1uF_100V ICC560
C_0402_IPCCAP_HORIZ_C_0402_IPC_150PF150pF ICC561
C_0402_IPCCAP_HORIZ_C_0402_IPC_270PF270pF ICC562
C_0603_IPCCAP_VERT_C_0603_IPC_3900PF3900pF ICC563
C_0603_IPCCAP_VERT_C_0603_IPC_3900PF3900pF ICC564
C_0402_IPCCAP_HORIZ_C_0402_IPC_270PF270pF ICC565
C_0402_IPCCAP_HORIZ_C_0402_IPC_820PF820pF ICC566
C_0603_IPCCAP_HORIZ_C_0603_IPC_0.1UF_100V0.1uF_100V ICC567
C_0402_IPCCAP_HORIZ_C_0402_IPC_150PF150pF ICC568
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC569
C_0402_IPCCAP_HORIZ_C_0402_IPC_270PF270pF ICC570
C_0402_IPCCAP_HORIZ_C_0402_IPC_22PF22pF ICC571
C_0402_IPCCAP_VERT_C_0402_IPC_4.7PF4.7pF ICC572
C_0402_IPCCAP_VERT_C_0402_IPC_4.7PF4.7pF ICC573
C_0402_IPCCAP_HORIZ_C_0402_IPC_270PF270pF ICC574
C_0402_IPCCAP_HORIZ_C_0402_IPC_22PF22pF ICC575
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC576
C_1210_IPC_1CAP_VERT_C_1210_IPC_1_10UF10uF ICC577
C_0603_IPCCAP_HORIZ_C_0603_IPC_75PF75pF ICC578
C_0402_IPCCAP_HORIZ_C_0402_IPC_68NF68nF ICC579
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC580
C_0805_IPCCAP_VERT_C_0805_IPC_39NF39nF ICC581
C_0805_IPCCAP_VERT_C_0805_IPC_39NF39nF ICC582
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC583
C_0603_IPCCAP_HORIZ_C_0603_IPC_75PF75pF ICC584
C_0402_IPCCAP_HORIZ_C_0402_IPC_68NF68nF ICC585
RAD_DISC_7R5PCAPT_VERT_RAD_DISC_7R5P_4.7NF_24.7nF_250VAC ICC586
C_0402_IPCCAP_HORIZ_C_0402_IPC_27PF27pF ICC587
C_0603_IPCCAP_HORIZ_C_0603_IPC_3900PF3900pF ICC588
C_0402_IPCCAP_HORIZ_C_0402_IPC_820PF820pF ICC589
C_0402_IPCCAP_HORIZ_C_0402_IPC_820PF820pF ICC590
C_0402_IPCCAP_HORIZ_C_0402_IPC_27PF27pF ICC591
C_0603_IPCCAP_HORIZ_C_0603_IPC_75PF75pF ICC592
C_0402_IPCCAP_HORIZ_C_0402_IPC_2700PF2700pF ICC593
C_0402_IPCCAP_HORIZ_C_0402_IPC_1800PF1800pF ICC594
C_0402_IPCCAP_HORIZ_C_0402_IPC_3.3NF3.3nF ICC595
C_0402_IPCCAP_VERT_C_0402_IPC_47PF_50V47pF_50V ICC596
C_0402_IPCCAP_VERT_C_0402_IPC_3.3NF3.3nF ICC597
C_0402_IPCCAP_HORIZ_C_0402_IPC_2700PF2700pF ICC598
C_0402_IPCCAP_HORIZ_C_0402_IPC_1800PF1800pF ICC599
C_0603_IPCCAP_HORIZ_C_0603_IPC_75PF75pF ICC600
C_0402_IPCCAP_HORIZ_C_0402_IPC_3.3NF3.3nF ICC601
C_1210_IPC_1CAP_VERT_C_1210_IPC_1_10UF10uF ICC602
C_0603_IPCCAP_HORIZ_C_0603_IPC_75PF75pF ICC603
C_0402_IPCCAP_HORIZ_C_0402_IPC_68NF68nF ICC604
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC605
C_0805_IPCCAP_VERT_C_0805_IPC_39NF39nF ICC606
C_0805_IPCCAP_VERT_C_0805_IPC_39NF39nF ICC607
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC608
C_0603_IPCCAP_HORIZ_C_0603_IPC_75PF75pF ICC609
C_0402_IPCCAP_HORIZ_C_0402_IPC_68NF68nF ICC610
RAD_DISC_7R5PCAPT_VERT_RAD_DISC_7R5P_4.7NF_24.7nF_250VAC ICC611
C_0402_IPCCAP_HORIZ_C_0402_IPC_27PF27pF ICC612
C_0603_IPCCAP_HORIZ_C_0603_IPC_3900PF3900pF ICC613
C_0402_IPCCAP_HORIZ_C_0402_IPC_820PF820pF ICC614
C_0402_IPCCAP_HORIZ_C_0402_IPC_820PF820pF ICC615
C_0402_IPCCAP_HORIZ_C_0402_IPC_27PF27pF ICC616
C_0603_IPCCAP_HORIZ_C_0603_IPC_75PF75pF ICC617
C_0402_IPCCAP_HORIZ_C_0402_IPC_2700PF2700pF ICC618
C_0402_IPCCAP_HORIZ_C_0402_IPC_1800PF1800pF ICC619
C_0402_IPCCAP_HORIZ_C_0402_IPC_3.3NF3.3nF ICC620
C_0402_IPCCAP_VERT_C_0402_IPC_47PF_50V47pF_50V ICC621
C_0402_IPCCAP_VERT_C_0402_IPC_3.3NF3.3nF ICC622
C_0402_IPCCAP_HORIZ_C_0402_IPC_2700PF2700pF ICC623
C_0402_IPCCAP_HORIZ_C_0402_IPC_1800PF1800pF ICC624
C_0603_IPCCAP_HORIZ_C_0603_IPC_75PF75pF ICC625
C_0402_IPCCAP_HORIZ_C_0402_IPC_3.3NF3.3nF ICC626
C_0805_IPCCAP_VERT_C_0805_IPC_1UF1uF ICC627
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC628
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC629
C_0805_IPCCAP_VERT_C_0805_IPC_1UF1uF ICC630
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC631
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC632
C_0805_IPCCAP_VERT_C_0805_IPC_1UF1uF ICC633
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC634
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC635
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC636
C_0805_IPCCAP_VERT_C_0805_IPC_1UF1uF ICC637
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC638
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC639
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC640
C_0805_IPCCAP_VERT_C_0805_IPC_1UF1uF ICC641
C_0201_IPCCAP_VERT_C_0201_IPC_.01UF.01uF ICC642
C_0201_IPCCAP_VERT_C_0201_IPC_.01UF.01uF ICC643
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC644
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC645
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC646
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC647
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC648
C_0201_IPCCAP_VERT_C_0201_IPC_.01UF.01uF ICC649
C_0805_IPCCAP_VERT_C_0805_IPC_1UF1uF ICC650
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC651
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC652
C_0805_IPCCAP_VERT_C_0805_IPC_1UF1uF ICC653
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC654
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC655
C_0805_IPCCAP_VERT_C_0805_IPC_1UF1uF ICC656
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC657
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC658
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC659
C_0805_IPCCAP_VERT_C_0805_IPC_1UF1uF ICC660
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC661
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC662
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC663
C_0805_IPCCAP_VERT_C_0805_IPC_1UF1uF ICC664
C_0201_IPCCAP_VERT_C_0201_IPC_.01UF.01uF ICC665
C_0201_IPCCAP_VERT_C_0201_IPC_.01UF.01uF ICC666
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC667
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC668
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC669
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC670
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC671
C_0201_IPCCAP_VERT_C_0201_IPC_.01UF.01uF ICC672
CT_7343_IPC_LPCAPT_VERT_CT_7343_IPC_LP_100UF100uF ICC673
C_1206_IPCCAP_VERT_C_1206_IPC_10UF10uF ICC674
C_0402_IPCCAP_VERT_C_0402_IPC_.01UF.01uF ICC675
C_1210_IPC_1CAP_VERT_C_1210_IPC_1_100UF100uF ICC676
C_1210_IPC_1CAP_VERT_C_1210_IPC_1_100UF100uF ICC677
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC678
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC679
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC680
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC681
C_0402_IPCCAP_VERT_C_0402_IPC_1000PF1000pF ICC682
C_0402_IPCCAP_HORIZ_C_0402_IPC_1500PF1500pF ICC683
C_0402_IPCCAP_HORIZ_C_0402_IPC_100PF100pF ICC684
C_0805_IPCCAP_HORIZ_C_0805_IPC_4.7UF4.7uF ICC685
C_0805_IPCCAP_VERT_C_0805_IPC_47UF47uF ICC686
C_0805_IPCCAP_VERT_C_0805_IPC_47UF47uF ICC687
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC688
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC690
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC691
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC692
C_0603_IPCCAP_HORIZ_C_0603_IPC_0.1UF0.1uF ICC693
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC694
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC695
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC696
C_0805_IPCCAP_VERT_C_0805_IPC_4.7UF4.7uF ICC697
C_0805_IPCCAP_VERT_C_0805_IPC_56PF56pF ICC698
C_0402_IPCCAP_VERT_C_0402_IPC_680PF680pF ICC699
C_1210_IPC_1CAP_VERT_C_1210_IPC_1_47UF47uF ICC700
C_1210_IPC_1CAP_VERT_C_1210_IPC_1_47UF47uF ICC701
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC702
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC703
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC704
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC705
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC706
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC707
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC708
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC709
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC710
C_1210_IPC_1CAP_VERT_C_1210_IPC_1_47UF47uF ICC711
C_1210_IPC_1CAP_VERT_C_1210_IPC_1_47UF47uF ICC712
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC713
C_1210_IPC_1CAP_VERT_C_1210_IPC_1_47UF47uF ICC714
C_1210_IPC_1CAP_VERT_C_1210_IPC_1_47UF47uF ICC715
C_1210_IPC_1CAP_VERT_C_1210_IPC_1_47UF47uF ICC716
C_1210_IPC_1CAP_VERT_C_1210_IPC_1_47UF47uF ICC717
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC718
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC719
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC720
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC721
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC722
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC723
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC724
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC725
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC726
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC727
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC728
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC729
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC730
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC731
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC732
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC733
C_1210_IPC_1CAP_VERT_C_1210_IPC_1_47UF47uF ICC734
C_1210_IPC_1CAP_VERT_C_1210_IPC_1_47UF47uF ICC735
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC736
C_1210_IPC_1CAP_VERT_C_1210_IPC_1_47UF47uF ICC737
C_1210_IPC_1CAP_VERT_C_1210_IPC_1_47UF47uF ICC738
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC739
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC740
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC741
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC742
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC743
C_1210_IPC_1CAP_VERT_C_1210_IPC_1_47UF47uF ICC744
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC745
C_1210_IPC_1CAP_VERT_C_1210_IPC_1_47UF47uF ICC746
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC747
C_1210_IPC_1CAP_VERT_C_1210_IPC_1_47UF47uF ICC748
C_1210_IPC_1CAP_VERT_C_1210_IPC_1_47UF47uF ICC749
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC750
C_1210_IPC_1CAP_VERT_C_1210_IPC_1_47UF47uF ICC751
C_1210_IPC_1CAP_VERT_C_1210_IPC_1_47UF47uF ICC752
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC753
C_1210_IPC_1CAP_VERT_C_1210_IPC_1_47UF47uF ICC754
C_1210_IPC_1CAP_VERT_C_1210_IPC_1_47UF47uF ICC755
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC756
C_0201_IPCCAP_VERT_C_0201_IPC_.01UF.01uF ICC757
C_0201_IPCCAP_VERT_C_0201_IPC_.01UF.01uF ICC758
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC759
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC760
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC761
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC762
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC763
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC764
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC765
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC766
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC767
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC768
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC769
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC770
C_0805_IPCCAP_VERT_C_0805_IPC_22UF22uF ICC771
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC772
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC773
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC774
C_0805_IPCCAP_VERT_C_0805_IPC_4.7UF4.7uF ICC775
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC776
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC777
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC778
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC779
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC780
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC781
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC782
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC783
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC784
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC785
C_0201_IPCCAP_VERT_C_0201_IPC_.01UF.01uF ICC786
C_0201_IPCCAP_VERT_C_0201_IPC_.01UF.01uF ICC787
C_0201_IPCCAP_VERT_C_0201_IPC_.01UF.01uF ICC788
C_0201_IPCCAP_VERT_C_0201_IPC_.01UF.01uF ICC789
C_0201_IPCCAP_VERT_C_0201_IPC_.01UF.01uF ICC790
C_0201_IPCCAP_VERT_C_0201_IPC_.01UF.01uF ICC791
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC792
C_0201_IPCCAP_VERT_C_0201_IPC_.01UF.01uF ICC793
C_0201_IPCCAP_VERT_C_0201_IPC_.01UF.01uF ICC794
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC795
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC796
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC797
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC798
C_0201_IPCCAP_VERT_C_0201_IPC_.01UF.01uF ICC799
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC800
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC801
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC802
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC803
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC804
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC805
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC806
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC807
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC808
C_0201_IPCCAP_VERT_C_0201_IPC_.01UF.01uF ICC809
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC810
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC811
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC812
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC813
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC814
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC815
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC816
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC817
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC818
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC819
C_0201_IPCCAP_VERT_C_0201_IPC_.01UF.01uF ICC820
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC821
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC822
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC823
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC824
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC825
C_0201_IPCCAP_VERT_C_0201_IPC_.01UF.01uF ICC826
C_0201_IPCCAP_VERT_C_0201_IPC_.01UF.01uF ICC827
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC828
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC829
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC830
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC831
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC832
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC833
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC834
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC835
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC836
C_0201_IPCCAP_VERT_C_0201_IPC_.01UF.01uF ICC837
C_0402_IPCCAP_VERT_C_0402_IPC_10PF10pF ICC838
C_0402_IPCCAP_VERT_C_0402_IPC_10PF10pF ICC839
C_0201_IPCCAP_VERT_C_0201_IPC_.01UF.01uF ICC840
C_0201_IPCCAP_VERT_C_0201_IPC_.01UF.01uF ICC841
C_0201_IPCCAP_VERT_C_0201_IPC_.01UF.01uF ICC842
C_0201_IPCCAP_VERT_C_0201_IPC_.01UF.01uF ICC843
C_0201_IPCCAP_VERT_C_0201_IPC_.01UF.01uF ICC844
C_0201_IPCCAP_VERT_C_0201_IPC_.01UF.01uF ICC845
C_0201_IPCCAP_VERT_C_0201_IPC_.01UF.01uF ICC846
C_0201_IPCCAP_VERT_C_0201_IPC_.01UF.01uF ICC847
C_0201_IPCCAP_VERT_C_0201_IPC_.01UF.01uF ICC848
C_0201_IPCCAP_VERT_C_0201_IPC_.01UF.01uF ICC849
C_0201_IPCCAP_VERT_C_0201_IPC_.01UF.01uF ICC850
C_0201_IPCCAP_VERT_C_0201_IPC_.01UF.01uF ICC851
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC852
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC853
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC854
C_0201_IPCCAP_VERT_C_0201_IPC_.01UF.01uF ICC855
C_0201_IPCCAP_VERT_C_0201_IPC_.01UF.01uF ICC856
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC857
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC858
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC859
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC860
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC861
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC862
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC863
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC864
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC865
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC866
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC867
C_0201_IPCCAP_VERT_C_0201_IPC_.01UF.01uF ICC868
C_0201_IPCCAP_VERT_C_0201_IPC_.01UF.01uF ICC869
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC870
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC871
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC872
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC873
C_0201_IPCCAP_VERT_C_0201_IPC_.01UF.01uF ICC874
C_0201_IPCCAP_VERT_C_0201_IPC_.01UF.01uF ICC875
C_0201_IPCCAP_VERT_C_0201_IPC_.01UF.01uF ICC876
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC877
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC878
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC879
C_0805_IPCCAP_VERT_C_0805_IPC_4.7UF4.7uF ICC880
C_0805_IPCCAP_VERT_C_0805_IPC_4.7UF4.7uF ICC881
C_1210_IPC_1CAP_VERT_C_1210_IPC_1_22UF22uF ICC882
C_1210_IPC_1CAP_VERT_C_1210_IPC_1_22UF22uF ICC883
C_1210_IPC_1CAP_VERT_C_1210_IPC_1_47UF47uF ICC884
CT_3216_IPCCAPT_VERT_CT_3216_IPC_22UF22uF ICC885
C_0805_IPCCAP_VERT_C_0805_IPC_10UF10uF ICC886
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC887
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC888
C_0402_IPCCAP_VERT_C_0402_IPC_0.22UF0.22uF ICC889
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC890
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC891
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC892
C_0402_IPCCAP_HORIZ_C_0402_IPC_0.1UF0.1uF ICC893
C_0402_IPCCAP_HORIZ_C_0402_IPC_22NF22nF ICC894
C_0402_IPCCAP_HORIZ_C_0402_IPC_22NF22nF ICC895
C_0402_IPCCAP_VERT_C_0402_IPC_1UF1uF ICC896
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC897
C_0402_IPCCAP_VERT_C_0402_IPC_0.1UF0.1uF ICC898
LED_0603_1DIODE_LED_0603_GRN_LED_0603_1_GGRN ICCR1
LED_0603_1DIODE_LED_0603_RED_HER_LED_0603RED ICCR3
LED_0603_1DIODE_LED_0603_GRN_LED_0603_1_GGRN ICCR5
0606_PACK_598-8410-207FDIODE_LED_0606_REDGRN_SMT_0606_RED/GRN ICCR6
LED_0603_1DIODE_LED_0603_GRN_LED_0603_1_GGRN ICCR7
LED_0603_1DIODE_LED_0603_GRN_LED_0603_1_GGRN ICCR8
LED_0603_1DIODE_LED_0603_GRN_LED_0603_1_GGRN ICCR9
LED_0603_1DIODE_LED_0603_GRN_LED_0603_1_GGRN ICCR10
LED_0603_1DIODE_LED_0603_GRN_LED_0603_1_GGRN ICCR11
LED_CBI_3MMDIODE_LED_3MM_DUAL_YEL_GRN_TH4_3MM YEL GRN ICCR12
SOT_23_3DIODE_SCH_SOT23_0R4MA_DUAL_SOT_400mA Dual ICD1
SMA_DIODEDIODE_SCH_SMA_3A_40V_MBRA340_SM1A 200V ICD2
SOD-123DIODE_SCH_SOD123_SOD-123_MMSZ52MMSZ5245 ICD3
SOT-143SUP_TVS_SOT143_70VWM_7VC_SOT-14SR70.TCT ICD4
SOD-323SUP_TVS_SOD323_8VWM_13R4V_SOD-3CDSOD323-T08LC ICD5
SOD-323SUP_TVS_SOD323_8VWM_13R4V_SOD-3CDSOD323-T08LC ICD6
SOT-143SUP_TVS_SOT143_70VWM_7VC_SOT-14SR70.TCT ICD7
SOD-323SUP_TVS_SOD323_8VWM_13R4V_SOD-3CDSOD323-T08LC ICD8
SOD-323SUP_TVS_SOD323_8VWM_13R4V_SOD-3CDSOD323-T08LC ICD9
SOD-323DIODE_SCH_SOD323_0R2A_BAT54_SODBAT54 ICD10
SOD-123DIODE_ZENER_SMA_3W_12VRW_SOD-1230V, 1A ICD11
SOD-123DIODE_ZENER_SMA_3W_12VRW_SOD-1230V, 1A ICD12
SOD-123DIODE_ZENER_SMA_3W_12VRW_SOD-1230V, 1A ICD13
MF-SM013FUSE_3A_SMT3R2X6R6_250V_MF-SM01SM013/250V ICF1
MF-SM013FUSE_3A_SMT3R2X6R6_250V_MF-SM01SM013/250V ICF2
MF-SM013FUSE_3A_SMT3R2X6R6_250V_MF-SM01SM013/250V ICF3
MF-SM013FUSE_3A_SMT3R2X6R6_250V_MF-SM01SM013/250V ICF4
MINISMDC260FFUSE_2R6A_1812_12V_PTC_MINISMDC2.6Amp ICF5
MINISMDC260FFUSE_2R6A_1812_12V_PTC_MINISMDC2.6Amp ICF6
FU_10MM_SMFUSE_1A_600V_SMT_FU_10MM_SM_1A,1A, 600V ICF7
FU_10MM_SMFUSE_1A_600V_SMT_FU_10MM_SM_1A,1A, 600V ICF8
FU_10MM_SMFUSE_1A_600V_SMT_FU_10MM_SM_1A,1A, 600V ICF9
FU_10MM_SMFUSE_1A_600V_SMT_FU_10MM_SM_1A,1A, 600V ICF10
HS_ATS-CPX035035025HRDW_HS_41X45_11R7MM_PUSHPIN_HSATS Push-Pin HeatSink ICHS2
CON_1X5_MICRO_USBB_MIDCON_USBB_1X5_F_RA_TH-MID_MICRO_USB Micro-B ICJ1
CONN_2X5_R05_FTSH_DV_007CON_HDR_2X5_M_VT_007_CONN_2X5_R0.05in M SMT ICJ2
TSW_8X1CON_HDR_1X8_M_VT_0R1_TH_TSW_8X10.1in M TH ICJ3
TSW_6X1CON_HDR_1X6_M_VT_0R1_TH_TSW_6X10.1in M TH ICJ4
TSW_8X1CON_HDR_1X8_M_VT_0R1_TH_TSW_8X10.1in M TH ICJ5
TSW_10X1CON_HDR_1X10_M_VT_0R1_TH_TSW_100.1in M TH ICJ6
CON_503182CON_USD_10_F_RA_SMT_TOP_503182AuSD ICJ7
GSB311231HRCON_USBA3R0_2X1_F_RA_TH_STACK_GUSBA3r0 ICJ8
0845-2R1TCON_RJ45_2X1_F_RA_TH_MAG1G_LED_F TH ICJ9
0845-2R1TCON_RJ45_2X1_F_RA_TH_MAG1G_LED_F TH ICJ10
5555163_6PINCON_RJ11_1X6_F_RA_TH_5555163_6PRA TH ICJ11
5555163_6PINCON_RJ11_1X6_F_RA_TH_5555163_6PRA TH ICJ12
TMM_2X1CON_HDR_1X2_M_VT_0R1_TH_TMM_2X12mm TH ICJ13
TMM_2X1CON_HDR_1X2_M_VT_2MM_SMT_TMM_2X2MM M SMT ICJ14
TMM_2X1CON_HDR_1X2_M_VT_2MM_SMT_TMM_2X2MM M SMT ICJ15
TMM_2X1CON_HDR_1X2_M_VT_2MM_SMT_TMM_2X2MM M SMT ICJ16
TMM_2X1CON_HDR_1X2_M_VT_2MM_SMT_TMM_2X2MM M SMT ICJ17
SIP_3PCON_HDR_1X3_M_VT_0R1_TH_SIP_3P_0.1in M TH ICJ18
PJ-102AHCON_PWR_3PIN_M_RA_TH_2R0MM_PJ-12.0mm Pin ICJ19
HTSW_2X1CON_HDR_1X2_M_VT_0R1_TH_HTSW_2X0.1in M TH ICJ20
TSM_2X1_SVCON_HDR_1X2_M_VT_0R1_SMT_TSM_2X0.1in M SMT ICJ21
TSM_2X1_SVCON_HDR_1X2_M_VT_0R1_SMT_TSM_2X0.1in M SMT ICJ22
5555163_6PINCON_RJ11_1X6_F_RA_TH_5555163_6PRA TH ICJ23
HTSW_2X1CON_HDR_1X2_M_VT_0R1_TH_HTSW_2X0.1in M TH ICJ24
5555163_6PINCON_RJ11_1X6_F_RA_TH_5555163_6PRA TH ICJ25
HTSW_2X1CON_HDR_1X2_M_VT_0R1_TH_HTSW_2X0.1in M TH ICJ26
HTSW_2X1CON_HDR_1X2_M_VT_0R1_TH_HTSW_2X0.1in M TH ICJ27
CONN_URFL_6GHZCON_COAX_M_VT_SMT_URFL_6GHZ_CONU.FL_RF_6GHZ ICJ28
HTSW_2X1CON_HDR_1X2_M_VT_0R1_TH_HTSW_2X0.1in M TH ICJ29
HTSW_7X2CON_HDR_2X7_M_VT_0R1_TH_HTSW_7X.1in M TH ICJ30
CON_1X5_MICRO_USBB_MIDCON_USBB_1X5_F_RA_TH-MID_MICRO_USB Micro-B ICJ31
HTSW_2X1CON_HDR_1X2_M_VT_0R1_TH_HTSW_2X0.1in M TH ICJ32
TSM_3X1_SVCON_HDR_1X3_M_VT_0R1_SMT_TSM_3X0.1in M SMT ICJ33
SIP_3PCON_HDR_1X3_M_VT_0R1_TH_SIP_3P_0.1in M TH ICJ34
SIP_3PCON_HDR_1X3_M_VT_0R1_TH_SIP_3P_0.1in M TH ICJ35
L_0402IND_HORIZ_WIDE_L_0402_120OHM.5120Ohm .5A ICL1
L_0402IND_VERT_WIDE_L_0402_120OHM.5A120Ohm .5A ICL2
L_0402IND_VERT_WIDE_L_0402_120OHM.5A120Ohm .5A ICL3
L_0402IND_HORIZ_WIDE_L_0402_120OHM.5120Ohm .5A ICL4
L_1206_EMIFILIND_LCL_2R2NF_3R2X1R6MM_6A_SMT_2.2nF 6A ICL5
DLW21SIND_CMC_0805_90OHM_0R28A_DLW21S90Ohm 0.28A ICL6
L_1206_EMIFILIND_LCL_2R2NF_3R2X1R6MM_6A_SMT_2.2nF 6A ICL7
DLW21SIND_CMC_0805_90OHM_0R28A_DLW21S90Ohm 0.28A ICL8
L_0603IND_HORIZ_WIDE_L_0603_180OHM1.180Ohm 1.5A ICL10
L_0603IND_HORIZ_WIDE_L_0603_180OHM1.180Ohm 1.5A ICL11
L_0603IND_HORIZ_WIDE_L_0603_120OHM3A120Ohm 3A ICL12
L_0603IND_HORIZ_WIDE_L_0603_120OHM3A120Ohm 3A ICL13
L_0603IND_HORIZ_WIDE_L_0603_120OHM3A120Ohm 3A ICL14
L_0603IND_HORIZ_WIDE_L_0603_120OHM3A120Ohm 3A ICL15
L_0603IND_HORIZ_WIDE_L_0603_120OHM3A120Ohm 3A ICL16
L_0603IND_HORIZ_WIDE_L_0603_120OHM3A120Ohm 3A ICL17
SDR1006IND_VERT_NARROW_SDR1006_47UH,147uH, 1.25A ICL18
L_1206_EMIFILIND_LCL_2R2NF_3R2X1R6MM_6A_SMT_2.2nF 6A ICL19
L_1206_EMIFILIND_LCL_2R2NF_3R2X1R6MM_6A_SMT_2.2nF 6A ICL20
L_0603IND_HORIZ_WIDE_L_0603_120OHM3A120Ohm 3A ICL21
L_0603IND_HORIZ_WIDE_L_0603_120OHM3A120Ohm 3A ICL22
L_0603IND_HORIZ_WIDE_L_0603_120OHM3A120Ohm 3A ICL23
L_0603IND_HORIZ_WIDE_L_0603_120OHM3A120Ohm 3A ICL24
L_0603IND_HORIZ_WIDE_L_0603_120OHM3A120Ohm 3A ICL25
L_0603IND_HORIZ_WIDE_L_0603_120OHM3A120Ohm 3A ICL26
L_0603IND_HORIZ_WIDE_L_0603_120OHM3A120Ohm 3A ICL27
L_0603IND_HORIZ_WIDE_L_0603_120OHM3A120Ohm 3A ICL28
L_0603IND_HORIZ_WIDE_L_0603_120OHM3A120Ohm 3A ICL29
L_0603IND_HORIZ_WIDE_L_0603_120OHM3A120Ohm 3A ICL30
L_0603IND_HORIZ_WIDE_L_0603_120OHM3A120Ohm 3A ICL31
L_0603IND_HORIZ_WIDE_L_0603_120OHM3A120Ohm 3A ICL32
L_0603IND_HORIZ_WIDE_L_0603_120OHM3A120Ohm 3A ICL33
DLW5BTIND_CHOKE_5X5MM_SMT4_5A_50V_DLWChoke ICL34
L_0402_WE-CBFIND_HORIZ_WIDE_L_0402_WE-CBF_2222Ohm 6A ICL35
FDV0630_IHLPIND_HORIZ_WIDE_FDV0630_IHLP_1.51.5uH ICL36
L_0402_WE-CBFIND_HORIZ_WIDE_L_0402_WE-CBF_2222Ohm 6A ICL37
XFL3010IND_HORIZ_WIDE_XFL3010_1.0UH1.0uH ICL38
XFL3010IND_HORIZ_WIDE_XFL3010_1.0UH1.0uH ICL39
XFL3010IND_HORIZ_WIDE_XFL3010_1.0UH1.0uH ICL40
XFL3010IND_HORIZ_WIDE_XFL3010_1.0UH1.0uH ICL41
L_SMT_1812IND_HORIZ_NARROW_L_SMT_1812_2.22.2uH ICL42
CM453232IND_HORIZ_NARROW_CM453232_10UH,10uH, 1.6 OHM ICL43
CM453232IND_HORIZ_NARROW_CM453232_10UH,10uH, 1.6 OHM ICL44
L_SMT_1812IND_HORIZ_NARROW_L_SMT_1812_2.22.2uH ICL45
L_SMT_1812IND_HORIZ_NARROW_L_SMT_1812_330330uH ICL46
L_SMT_1812IND_HORIZ_NARROW_L_SMT_1812_330330uH ICL47
L_SMT_1812IND_HORIZ_NARROW_L_SMT_1812_2.22.2uH ICL48
L_SMT_1812IND_HORIZ_NARROW_L_SMT_1812_1.01.0uH ICL49
L_SMD_1608IND_HORIZ_NARROW_L_SMD_1608_22U22uH ICL50
L_SMD_1608IND_HORIZ_NARROW_L_SMD_1608_22U22uH ICL51
L_SMT_1812IND_HORIZ_NARROW_L_SMT_1812_2.22.2uH ICL52
L_SMT_1812IND_HORIZ_NARROW_L_SMT_1812_1.01.0uH ICL53
L_SMT_1812IND_HORIZ_NARROW_L_SMT_1812_2.22.2uH ICL54
CM453232IND_HORIZ_NARROW_CM453232_10UH,10uH, 1.6 OHM ICL55
CM453232IND_HORIZ_NARROW_CM453232_10UH,10uH, 1.6 OHM ICL56
L_SMT_1812IND_HORIZ_NARROW_L_SMT_1812_2.22.2uH ICL57
L_SMT_1812IND_HORIZ_NARROW_L_SMT_1812_330330uH ICL58
L_SMT_1812IND_HORIZ_NARROW_L_SMT_1812_330330uH ICL59
L_SMT_1812IND_HORIZ_NARROW_L_SMT_1812_2.22.2uH ICL60
L_SMT_1812IND_HORIZ_NARROW_L_SMT_1812_1.01.0uH ICL61
L_SMD_1608IND_HORIZ_NARROW_L_SMD_1608_22U22uH ICL62
L_SMD_1608IND_HORIZ_NARROW_L_SMD_1608_22U22uH ICL63
L_SMT_1812IND_HORIZ_NARROW_L_SMT_1812_2.22.2uH ICL64
L_SMT_1812IND_HORIZ_NARROW_L_SMT_1812_1.01.0uH ICL65
LTC0265-52XFMR_1-1_SMT8_4R7MH_CUSTOM_LTC0LTC0265-52 ICL66
L_SMT_1812IND_HORIZ_NARROW_L_SMT_1812_330330uH ICL67
L_SMT_1812IND_HORIZ_NARROW_L_SMT_1812_330330uH ICL68
LTC0265-52XFMR_1-1_SMT8_4R7MH_CUSTOM_LTC0LTC0265-52 ICL69
L_SMT_1812IND_HORIZ_NARROW_L_SMT_1812_330330uH ICL70
L_SMT_1812IND_HORIZ_NARROW_L_SMT_1812_330330uH ICL71
L_0402IND_HORIZ_WIDE_L_0402_120OHM.5120Ohm .5A ICL72
L_0402IND_HORIZ_WIDE_L_0402_120OHM.5120Ohm .5A ICL73
L_1206_IPCIND_HORIZ_NARROW_L_1206_IPC_5050 ICL74
L_0402IND_HORIZ_WIDE_L_0402_120OHM.5120Ohm .5A ICL75
L_0402IND_HORIZ_WIDE_L_0402_120OHM.5120Ohm .5A ICL76
L_0402IND_HORIZ_WIDE_L_0402_120OHM.5120Ohm .5A ICL77
L_0402IND_HORIZ_WIDE_L_0402_120OHM.5120Ohm .5A ICL78
L_0402IND_HORIZ_WIDE_L_0402_120OHM.5120Ohm .5A ICL79
L_1206_IPCIND_HORIZ_NARROW_L_1206_IPC_5050 ICL80
L_0402IND_HORIZ_WIDE_L_0402_120OHM.5120Ohm .5A ICL81
L_0402IND_HORIZ_WIDE_L_0402_120OHM.5120Ohm .5A ICL82
L_0402IND_HORIZ_WIDE_L_0402_120OHM.5120Ohm .5A ICL83
IHLP-2020BZ-01IND_HORIZ_NARROW_IHLP-2020BZ-010.68uH ICL84
FDV0630_IHLPIND_HORIZ_WIDE_FDV0630_IHLP_4.74.7uH ICL85
FDV0630_IHLPIND_HORIZ_WIDE_FDV0630_IHLP_4.74.7uH ICL86
IHLP-4040DZ-01IND_HORIZ_NARROW_IHLP-4040DZ-011.0uH ICL87
DRA74IND_HORIZ_NARROW_DRA74_2.2UH2.2uH ICL88
DRA74IND_HORIZ_NARROW_DRA74_2.2UH2.2uH ICL89
L_0402IND_HORIZ_WIDE_L_0402_120OHM.5120Ohm .5A ICL90
L_0402IND_VERT_WIDE_L_0402_120OHM.5A120Ohm .5A ICL91
L_0402IND_VERT_WIDE_L_0402_120OHM.5A120Ohm .5A ICL92
L_0201IND_HORIZ_WIDE_L_0201_120OHM.2120Ohm .2A ICL93
L_0201IND_HORIZ_WIDE_L_0201_120OHM.2120Ohm .2A ICL94
L_0201IND_HORIZ_WIDE_L_0201_120OHM.2120Ohm .2A ICL95
L_0402IND_HORIZ_WIDE_L_0402_120OHM.5120Ohm .5A ICL96
L_0402IND_HORIZ_WIDE_L_0402_120OHM.5120Ohm .5A ICL97
L_0402IND_HORIZ_WIDE_L_0402_120OHM.5120Ohm .5A ICL98
L_0402IND_HORIZ_WIDE_L_0402_120OHM.5120Ohm .5A ICL99
L_1206_EMIFILIND_LCL_2R2NF_3R2X1R6MM_6A_SMT_2.2nF 6A ICL100
74441-0001CON_SFP+_1X20_F_RA_SMT_74441-000.8mm SMT ICP1
CON52_0P8_SMT_FULL-HALF_NSPCON_MINI-PCIEX1_2X26_F_RA_HOLE_PCIe x1 ICP2
CON52_0P8_SMT_FULL-HALF_NSPCON_MINI-PCIEX1_2X26_F_RA_HOLE_PCIe x1 ICP3
TSM_3X1_SVCON_HDR_1X3_M_VT_0R1_SMT_TSM_3X0.1in M SMT ICP4
TSM_3X1_SVCON_HDR_1X3_M_VT_0R1_SMT_TSM_3X0.1in M SMT ICP5
TSM_3X1_SVCON_HDR_1X3_M_VT_0R1_SMT_TSM_3X0.1in M SMT ICP6
SOT_23_3XSTR_SW_NPN_SOT23_MGSF2N02_SOT_MGSF2N02 ICQ1
SOT-223-4XSTR_PWR_PNP_SOT223_5A_100V_SOTZXTP2013 ICQ2
SOT_23_3XSTR_SW_NPN_SOT23_MMBT3904_SOT_MMBT3904 ICQ3
XSTR_PQFN08AREV4XSTR_PWR_NFET_PQFN8_FDMS6681Z_XFDMS6681Z ICQ4
SON3X3-8XSTR_PWR_NFET_SON8_60A_25V_SON3CSD16340Q3 ICQ5
SON2X2-6XSTR_PWR_PFET_SON6_5A_20V_SON2XCSD25302Q2 ICQ6
SOT-323LXSTR_PWR_NFET_SOT23-3_1R8A_20V_DMN2065UW ICQ7
SON2X2-6XSTR_PWR_NFET_SON6_22A_20V_SON2CSD15571Q2 ICQ8
SON2X2-6XSTR_PWR_PFET_SON6_5A_20V_SON2XCSD25302Q2 ICQ9
SOT-323LXSTR_PWR_NFET_SOT23-3_1R8A_20V_DMN2065UW ICQ10
SON2X2-6XSTR_PWR_NFET_SON6_22A_20V_SON2CSD15571Q2 ICQ11
SOT_23_3XSTR_SW_NPN_SOT23_MMBT3904_SOT_MMBT3904 ICQ12
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER1
R_0402_IPCRES_VERT_R_0402_IPC_10K10K ICR2
R_0402_IPCRES_VERT_R_0402_IPC_10K10K ICR3
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER4
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER5
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER6
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR7
R_0402_IPCRES_VERT_R_0402_IPC_1K1K ICR8
R_0402_IPCRES_VERT_R_0402_IPC_1K1K ICR9
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR10
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR11
R_0402_IPCRES_VERT_R_0402_IPC_1K1K ICR12
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR13
R_0402_IPCRES_HORIZ_R_0402_IPC_4.7K4.7K ICR14
R_0402_IPCRES_HORIZ_R_0402_IPC_4.7K4.7K ICR15
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR16
R_0402_IPCRES_HORIZ_R_0402_IPC_4.7K4.7K ICR17
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR18
R_0402_IPCRES_HORIZ_R_0402_IPC_4.7K4.7K ICR19
R_0402_IPCRES_HORIZ_R_0402_IPC_4.7K4.7K ICR20
R_0402_IPCRES_HORIZ_R_0402_IPC_4.7K4.7K ICR21
R_0402_IPCRES_VERT_R_0402_IPC_1K1K ICR22
R_0402_IPCRES_VERT_R_0402_IPC_1K1K ICR23
R_0402_IPCRES_VERT_R_0402_IPC_10K10K ICR24
R_0402_IPCRES_VERT_R_0402_IPC_10K10K ICR25
R_0402_IPCRES_HORIZ_R_0402_IPC_4.7K4.7K ICR26
R_0402_IPCRES_HORIZ_R_0402_IPC_4.7K4.7K ICR27
R_0402_IPCRES_HORIZ_R_0402_IPC_10K10K ICR28
R_0402_IPCRES_VERT_R_0402_IPC_10K10K ICR29
R_0402_IPCRES_VERT_R_0402_IPC_10K10K ICR30
R_0402_IPCRES_VERT_R_0402_IPC_10K10K ICR31
R_0402_IPCRES_VERT_R_0402_IPC_00 ICR32
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR33
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER34
R_0402_IPCRES_HORIZ_R_0402_IPC_4.7K4.7K ICR35
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER36
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER37
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR38
R_0402_IPCRES_VERT_R_0402_IPC_49.9,1%49.9, 1% ICR39
R_0402_IPCRES_VERT_R_0402_IPC_49.9,1%49.9, 1% ICR40
R_0402_IPCRES_HORIZ_R_0402_IPC_330330 ICR41
R_0402_IPCRES_HORIZ_R_0402_IPC_33.2,1%33.2, 1% ICR42
R_0402_IPCRES_HORIZ_R_0402_IPC_33.2,1%33.2, 1% ICR43
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER44
R_0402_IPCRES_VERT_R_0402_IPC_00 ICR45
R_0402_IPCRES_VERT_R_0402_IPC_91K,1%91K, 1% ICR46
R_0402_IPCRES_VERT_R_0402_IPC_10K10K ICR47
R_0402_IPCRES_VERT_R_0402_IPC_1K1K ICR48
R_0402_IPCRES_VERT_R_0402_IPC_1K1K ICR49
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER50
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER51
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER52
R_0402_IPCRES_VERT_R_0402_IPC_1K1K ICR53
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER54
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER55
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER56
R_0402_IPCRES_VERT_R_0402_IPC_91K,1%91K, 1% ICR57
R_0402_IPCRES_VERT_R_0402_IPC_1K1K ICR58
R_0402_IPCRES_VERT_R_0402_IPC_91K,1%91K, 1% ICR59
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER60
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER61
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER62
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER63
R_0402_IPCRES_VERT_R_0402_IPC_91K,1%91K, 1% ICR64
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER65
R_0402_IPCRES_HORIZ_R_0402_IPC_330330 ICR67
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR68
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR69
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR70
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR71
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR72
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR73
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR74
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR75
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR76
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR77
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR78
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR80
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR81
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR82
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR83
R_0402_IPCRES_HORIZ_R_0402_IPC_3333 ICR84
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR85
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR86
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR87
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR88
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR89
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR90
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR91
R_0402_IPCRES_VERT_R_0402_IPC_2K,1%2K, 1% ICR92
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR93
R_0402_IPCRES_VERT_R_0402_IPC_10K10K ICR96
R_0402_IPCRES_VERT_R_0402_IPC_2K,1%2K, 1% ICR100
R_0402_IPCRES_VERT_R_0402_IPC_2K,1%2K, 1% ICR101
R_0402_IPCRES_VERT_R_0402_IPC_2K,1%2K, 1% ICR107
R_0402_IPCRES_VERT_R_0402_IPC_2K,1%2K, 1% ICR108
R_0402_IPCRES_VERT_R_0402_IPC_10K10K ICR111
R_0402_IPCRES_VERT_R_0402_IPC_10K10K ICR112
R_0402_IPCRES_VERT_R_0402_IPC_10K10K ICR113
R_0402_IPCRES_VERT_R_0402_IPC_10K10K ICR114
R_0402_IPCRES_VERT_R_0402_IPC_10K10K ICR116
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER118
R_0402_IPCRES_VERT_R_0402_IPC_100K100K ICR119
R_0402_IPCRES_VERT_R_0402_IPC_100K100K ICR120
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER122
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER123
R_0402_IPCRES_VERT_R_0402_IPC_330330 ICR125
R_0402_IPCRES_HORIZ_R_0402_IPC_25.5K,1%25.5K, 1% ICR126
R_0402_IPCRES_HORIZ_R_0402_IPC_1.02K,1%1.02K, 1% ICR127
R_0402_IPCRES_VERT_R_0402_IPC_00 ICR128
R_0402_IPCRES_HORIZ_R_0402_IPC_1K1K ICR129
R_0402_IPCRES_HORIZ_R_0402_IPC_200,1%200, 1% ICR130
R_0402_IPCRES_VERT_R_0402_IPC_00 ICR131
R_0402_IPCRES_HORIZ_R_0402_IPC_1K1K ICR132
R_0402_IPCRES_HORIZ_R_0402_IPC_200,1%200, 1% ICR133
R_0402_IPCRES_VERT_R_0402_IPC_00 ICR134
R_0402_IPCRES_HORIZ_R_0402_IPC_10K10K ICR135
R_0402_IPCRES_HORIZ_R_0402_IPC_10K10K ICR136
R_0402_IPCRES_HORIZ_R_0402_IPC_200,1%200, 1% ICR137
R_0402_IPCRES_HORIZ_R_0402_IPC_10K10K ICR138
R_0402_IPCRES_VERT_R_0402_IPC_36,1%36, 1% ICR139
R_0402_IPCRES_VERT_R_0402_IPC_36,1%36, 1% ICR140
R_0402_IPCRES_HORIZ_R_0402_IPC_162,1%162, 1% ICR141
R_0402_IPCRES_HORIZ_R_0402_IPC_162,1%162, 1% ICR142
R_0402_IPCRES_HORIZ_R_0402_IPC_4.7K4.7K ICR143
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER144
R_0402_IPCRES_HORIZ_R_0402_IPC_240,1%240, 1% ICR145
R_0402_IPCRES_HORIZ_R_0402_IPC_240,1%240, 1% ICR146
R_0402_IPCRES_HORIZ_R_0402_IPC_240,1%240, 1% ICR147
R_0402_IPCRES_VERT_R_0402_IPC_00 ICR148
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR149
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR150
R_0402_IPCRES_HORIZ_R_0402_IPC_39,1%39, 1% ICR151
R_0402_IPCRES_HORIZ_R_0402_IPC_39,1%39, 1% ICR152
R_0402_IPCRES_HORIZ_R_0402_IPC_39,1%39, 1% ICR153
R_0402_IPCRES_HORIZ_R_0402_IPC_39,1%39, 1% ICR154
R_0402_IPCRES_HORIZ_R_0402_IPC_39,1%39, 1% ICR155
R_0402_IPCRES_HORIZ_R_0402_IPC_39,1%39, 1% ICR156
R_0402_IPCRES_HORIZ_R_0402_IPC_39,1%39, 1% ICR157
R_0402_IPCRES_HORIZ_R_0402_IPC_39,1%39, 1% ICR158
R_0402_IPCRES_HORIZ_R_0402_IPC_39,1%39, 1% ICR159
R_0402_IPCRES_HORIZ_R_0402_IPC_4.7K4.7K ICR160
R_0402_IPCRES_HORIZ_R_0402_IPC_39,1%39, 1% ICR161
R_0402_IPCRES_HORIZ_R_0402_IPC_39,1%39, 1% ICR162
R_0402_IPCRES_HORIZ_R_0402_IPC_39,1%39, 1% ICR163
R_0402_IPCRES_HORIZ_R_0402_IPC_39,1%39, 1% ICR164
R_0402_IPCRES_HORIZ_R_0402_IPC_39,1%39, 1% ICR165
R_0402_IPCRES_HORIZ_R_0402_IPC_39,1%39, 1% ICR166
R_0402_IPCRES_HORIZ_R_0402_IPC_39,1%39, 1% ICR167
R_0402_IPCRES_HORIZ_R_0402_IPC_39,1%39, 1% ICR168
R_0402_IPCRES_HORIZ_R_0402_IPC_39,1%39, 1% ICR169
R_0402_IPCRES_HORIZ_R_0402_IPC_39,1%39, 1% ICR170
R_0402_IPCRES_HORIZ_R_0402_IPC_39,1%39, 1% ICR171
R_0402_IPCRES_HORIZ_R_0402_IPC_39,1%39, 1% ICR172
R_0402_IPCRES_HORIZ_R_0402_IPC_39,1%39, 1% ICR173
R_0402_IPCRES_HORIZ_R_0402_IPC_39,1%39, 1% ICR174
R_0402_IPCRES_HORIZ_R_0402_IPC_39,1%39, 1% ICR175
R_0402_IPCRES_HORIZ_R_0402_IPC_39,1%39, 1% ICR176
R_0402_IPCRES_HORIZ_R_0402_IPC_39,1%39, 1% ICR177
R_0402_IPCRES_HORIZ_R_0402_IPC_39,1%39, 1% ICR178
R_0402_IPCRES_HORIZ_R_0402_IPC_39,1%39, 1% ICR179
R_0402_IPCRES_HORIZ_R_0402_IPC_39,1%39, 1% ICR180
R_0402_IPCRES_HORIZ_R_0402_IPC_240,1%240, 1% ICR181
R_0402_IPCRES_HORIZ_R_0402_IPC_240,1%240, 1% ICR182
R_0402_IPCRES_HORIZ_R_0402_IPC_2222 DISCRETER183
R_0402_IPCRES_HORIZ_R_0402_IPC_2222 DISCRETER184
R_0402_IPCRES_HORIZ_R_0402_IPC_2222 DISCRETER185
R_0402_IPCRES_HORIZ_R_0402_IPC_2222 DISCRETER186
R_0402_IPCRES_HORIZ_R_0402_IPC_4.7K4.7K ICR187
R_0402_IPCRES_HORIZ_R_0402_IPC_2222 DISCRETER188
R_0402_IPCRES_HORIZ_R_0402_IPC_2222 DISCRETER189
R_0402_IPCRES_HORIZ_R_0402_IPC_10K10K ICR190
R_0402_IPCRES_HORIZ_R_0402_IPC_10K10K ICR191
R_0402_IPCRES_HORIZ_R_0402_IPC_10K10K ICR192
R_0402_IPCRES_HORIZ_R_0402_IPC_1010 ICR193
R_0402_IPCRES_VERT_R_0402_IPC_6868 ICR194
R_0402_IPCRES_VERT_R_0402_IPC_330330 ICR195
R_0402_IPCRES_VERT_R_0402_IPC_200,1%200, 1% ICR196
R_0402_IPCRES_VERT_R_0402_IPC_10K10K ICR200
R_0402_IPCRES_VERT_R_0402_IPC_2.7K2.7K ICR201
R_0402_IPCRES_VERT_R_0402_IPC_2.7K2.7K ICR202
R_0402_IPCRES_VERT_R_0402_IPC_2.7K2.7K ICR203
R_0402_IPCRES_VERT_R_0402_IPC_2.7K2.7K ICR204
R_0603_IPCRES_VERT_R_0603_IPC_475,1%475, 1% ICR210
R_0402_IPCRES_HORIZ_R_0402_IPC_2.7K2.7K ICR211
R_0402_IPCRES_HORIZ_R_0402_IPC_2.7K2.7K ICR213
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR215
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR216
R_0402_IPCRES_HORIZ_R_0402_IPC_2.7K2.7K ICR217
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR218
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR219
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR220
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR221
R_0402_IPCRES_VERT_R_0402_IPC_10K10K ICR222
R_0402_IPCRES_HORIZ_R_0402_IPC_4.7K4.7K ICR223
R_0805_IPCRES_HORIZ_R_0805_IPC_00 ICR224
R_0402_IPCRES_VERT_R_0402_IPC_10K10K ICR225
R_0402_IPCRES_VERT_R_0402_IPC_10K10K ICR226
R_0402_IPCRES_HORIZ_R_0402_IPC_2.7K2.7K ICR227
R_0402_IPCRES_HORIZ_R_0402_IPC_200,1%200, 1% ICR228
R_0402_IPCRES_HORIZ_R_0402_IPC_499,1%499, 1% ICR229
R_0402_IPCRES_HORIZ_R_0402_IPC_200,1%200, 1% ICR230
R_0402_IPCRES_VERT_R_0402_IPC_10K10K ICR231
R_0805_IPCRES_HORIZ_R_0805_IPC_00 ICR232
R_0402_IPCRES_HORIZ_R_0402_IPC_220220 ICR233
R_0402_IPCRES_HORIZ_R_0402_IPC_220220 ICR234
R_0402_IPCRES_HORIZ_R_0402_IPC_220220 ICR235
R_1206_IPCRES_HORIZ_R_1206_IPC_1M,1%1M, 1% ICR236
R_0402_IPCRES_HORIZ_R_0402_IPC_220220 ICR237
R_0402_IPCRES_HORIZ_R_0402_IPC_220220 ICR238
R_0402_IPCRES_HORIZ_R_0402_IPC_220220 ICR239
R_0402_IPCRES_HORIZ_R_0402_IPC_220220 ICR240
R_0402_IPCRES_HORIZ_R_0402_IPC_220220 ICR241
R_0402_IPCRES_VERT_R_0402_IPC_10K10K ICR242
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR243
R_0402_IPCRES_HORIZ_R_0402_IPC_2K,1%2K, 1% ICR244
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR245
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR246
R_0402_IPCRES_VERT_R_0402_IPC_22K22K ICR247
R_0402_IPCRES_VERT_R_0402_IPC_22K22K ICR248
R_0402_IPCRES_VERT_R_0402_IPC_22K22K ICR249
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR250
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR251
R_0402_IPCRES_HORIZ_R_0402_IPC_619,1%619, 1% ICR253
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR254
R_0402_IPCRES_HORIZ_R_0402_IPC_330330 ICR255
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER256
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR257
R_0402_IPCRES_VERT_R_0402_IPC_10K10K ICR258
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR259
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR260
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR261
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR262
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR263
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR264
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR265
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER266
R_0603_IPCRES_HORIZ_R_0603_IPC_1,1%1, 1% ICR267
R_1206_IPCRES_HORIZ_R_1206_IPC_499K,1%499K, 1% ICR270
R_1206_IPCRES_HORIZ_R_1206_IPC_499K,1%499K, 1% ICR271
R_0603_IPCRES_HORIZ_R_0603_IPC_10K,1%10K, 1% ICR272
R_0402_IPCRES_HORIZ_R_0402_IPC_49.9,1%49.9, 1% ICR273
R_0402_IPCRES_HORIZ_R_0402_IPC_33.2,1%33.2, 1% ICR274
R_0402_IPCRES_HORIZ_R_0402_IPC_49.9,1%49.9, 1% ICR275
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR276
R_0603_IPCRES_HORIZ_R_0603_IPC_10K,1%10K, 1% ICR277
R_1206_IPCRES_HORIZ_R_1206_IPC_499K,1%499K, 1% ICR278
R_1206_IPCRES_HORIZ_R_1206_IPC_499K,1%499K, 1% ICR279
R_0402_IPCRES_HORIZ_R_0402_IPC_10K,1%10K, 1% ICR280
R_1206_IPCRES_HORIZ_R_1206_IPC_499K,1%499K, 1% ICR281
R_1206_IPCRES_HORIZ_R_1206_IPC_499K,1%499K, 1% ICR282
R_0603_IPCRES_HORIZ_R_0603_IPC_10K,1%10K, 1% ICR283
R_0402_IPCRES_VERT_R_0402_IPC_47.5K,1%47.5K, 1% ICR284
R_0402_IPCRES_HORIZ_R_0402_IPC_49.9,1%49.9, 1% ICR285
R_0603_IPCRES_HORIZ_R_0603_IPC_10K,1%10K, 1% ICR288
R_1206_IPCRES_HORIZ_R_1206_IPC_499K,1%499K, 1% ICR289
R_1206_IPCRES_HORIZ_R_1206_IPC_499K,1%499K, 1% ICR290
R_1206_IPCRES_HORIZ_R_1206_IPC_1M,1%1M, 1% ICR291
R_1206_IPCRES_HORIZ_R_1206_IPC_1M,1%1M, 1% ICR292
R_0402_IPCRES_VERT_R_0402_IPC_47.5K,1%47.5K, 1% ICR293
R_1206_IPCRES_HORIZ_R_1206_IPC_1M,1%1M, 1% ICR294
R_0402_IPCRES_HORIZ_R_0402_IPC_75K,0.5%75K, 0.5% ICR295
R_1206_IPCRES_HORIZ_R_1206_IPC_1M,1%1M, 1% ICR296
R_1206_IPCRES_HORIZ_R_1206_IPC_10,1%10, 1% ICR297
R_1206_IPCRES_HORIZ_R_1206_IPC_10,1%10, 1% ICR298
R_0402_IPCRES_VERT_R_0402_IPC_1K1K ICR299
R_1206_IPCRES_VERT_R_1206_IPC_5.1,1%5.1, 1% ICR300
R_0603_IPCRES_VERT_R_0603_IPC_75,1%75, 1% ICR301
R_1206_IPCRES_HORIZ_R_1206_IPC_5.1,1%5.1, 1% ICR302
R_0402_IPCRES_VERT_R_0402_IPC_10K10K ICR303
R_0402_IPCRES_VERT_R_0402_IPC_00 ICR304
R_0603_IPCRES_VERT_R_0603_IPC_51K51K ICR305
R_0603_IPCRES_HORIZ_R_0603_IPC_75,1%75, 1% ICR306
R_0603_IPCRES_VERT_R_0603_IPC_1,1%1, 1% ICR307
R_0603_IPCRES_VERT_R_0603_IPC_1,1%1, 1% ICR308
R_0603_IPCRES_VERT_R_0603_IPC_1,1%1, 1% ICR309
R_0603_IPCRES_VERT_R_0603_IPC_1,1%1, 1% ICR310
R_0402_IPCRES_HORIZ_R_0402_IPC_3.48K,1%3.48K, 1% ICR311
R_0402_IPCRES_VERT_R_0402_IPC_1K1K ICR312
R_0402_IPCRES_HORIZ_R_0402_IPC_2222 DISCRETER313
R_0402_IPCRES_HORIZ_R_0402_IPC_2222 DISCRETER314
R_0402_IPCRES_HORIZ_R_0402_IPC_2222 DISCRETER315
R_0402_IPCRES_HORIZ_R_0402_IPC_2222 DISCRETER316
R_0402_IPCRES_HORIZ_R_0402_IPC_2222 DISCRETER317
R_0402_IPCRES_HORIZ_R_0402_IPC_2222 DISCRETER318
R_0402_IPCRES_HORIZ_R_0402_IPC_2222 DISCRETER319
R_0402_IPCRES_HORIZ_R_0402_IPC_1010 ICR320
R_0402_IPCRES_HORIZ_R_0402_IPC_1010 ICR321
R_0402_IPCRES_HORIZ_R_0402_IPC_5.1,1%5.1, 1% ICR322
R_0402_IPCRES_VERT_R_0402_IPC_330330 ICR323
R_0402_IPCRES_HORIZ_R_0402_IPC_5.1,1%5.1, 1% ICR324
R_0402_IPCRES_HORIZ_R_0402_IPC_5.1,1%5.1, 1% ICR325
R_0402_IPCRES_HORIZ_R_0402_IPC_0.33,1%0.33, 1% ICR326
R_0402_IPCRES_HORIZ_R_0402_IPC_0.33,1%0.33, 1% ICR327
R_0402_IPCRES_HORIZ_R_0402_IPC_5.1,1%5.1, 1% ICR328
R_0402_IPCRES_VERT_R_0402_IPC_330330 ICR330
R_0402_IPCRES_VERT_R_0402_IPC_330330 ICR331
R_0402_IPCRES_VERT_R_0402_IPC_330330 ICR332
R_0402_IPCRES_VERT_R_0402_IPC_330330 ICR333
R_0402_IPCRES_VERT_R_0402_IPC_91K,1%91K, 1% ICR334
R_0402_IPCRES_VERT_R_0402_IPC_1K1K ICR336
R_0402_IPCRES_VERT_R_0402_IPC_100K,1%100K, 1% ICR337
R_0402_IPCRES_VERT_R_0402_IPC_40.2K,1%40.2K, 1% ICR338
R_0402_IPCRES_VERT_R_0402_IPC_100K,1%100K, 1% ICR340
R_0402_IPCRES_VERT_R_0402_IPC_100K,1%100K, 1% ICR342
R_0402_IPCRES_VERT_R_0402_IPC_60.4K,1%60.4K, 1% ICR343
R_0402_IPCRES_VERT_R_0402_IPC_604,1%604, 1% ICR346
R_0402_IPCRES_VERT_R_0402_IPC_60.4K,1%60.4K, 1% ICR347
R_0402_IPCRES_VERT_R_0402_IPC_604,1%604, 1% ICR348
R_0402_IPCRES_VERT_R_0402_IPC_00 ICR349
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER350
R_0402_IPCRES_VERT_R_0402_IPC_1010 ICR351
R_0402_IPCRES_VERT_R_0402_IPC_1010 ICR352
R_0402_IPCRES_VERT_R_0402_IPC_3.16K,1%3.16K, 1% ICR353
R_0402_IPCRES_VERT_R_0402_IPC_10K10K ICR354
WSL2726RES_0R001_2726_4PIN_WSL2726_0.00.001, 1% 3W ICR355
R_0402_IPCRES_VERT_R_0402_IPC_5.1K,1%5.1K, 1% ICR356
R_0402_IPCRES_VERT_R_0402_IPC_1010 ICR357
R_0402_IPCRES_VERT_R_0402_IPC_1010 ICR358
R_0402_IPCRES_VERT_R_0402_IPC_10K10K ICR359
R_0402_IPCRES_VERT_R_0402_IPC_3.16K,1%3.16K, 1% ICR360
R_0402_IPCRES_VERT_R_0402_IPC_3.48K,1%3.48K, 1% ICR361
R_0402_IPCRES_VERT_R_0402_IPC_69.8K,1%69.8K, 1% ICR362
R_0402_IPCRES_VERT_R_0402_IPC_15K15K ICR363
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR364
R_0402_IPCRES_VERT_R_0402_IPC_10K10K ICR365
R_0402_IPCRES_VERT_R_0402_IPC_75K,1%75K, 1% ICR366
R_0402_IPCRES_VERT_R_0402_IPC_887K,1%887K, 1% ICR367
R_0402_IPCRES_VERT_R_0402_IPC_100K,1%100K, 1% ICR368
R_0402_IPCRES_VERT_R_0402_IPC_10K10K ICR369
R_0402_IPCRES_VERT_R_0402_IPC_324K,1%324K, 1% ICR370
R_0402_IPCRES_VERT_R_0402_IPC_412K,1%412K, 1% ICR371
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR372
R_0402_IPCRES_VERT_R_0402_IPC_10K10K ICR373
R_0402_IPCRES_VERT_R_0402_IPC_10K10K ICR374
R_0402_IPCRES_HORIZ_R_0402_IPC_10K10K ICR375
R_0402_IPCRES_VERT_R_0402_IPC_10K10K ICR376
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER377
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER378
R_0402_IPCRES_HORIZ_R_0402_IPC_100,1%100, 1% DISCRETER379
R_0402_IPCRES_HORIZ_R_0402_IPC_30.9K,1%30.9K, 1% ICR380
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER381
R_0402_IPCRES_HORIZ_R_0402_IPC_10K,1%10K, 1% ICR382
R_0402_IPCRES_HORIZ_R_0402_IPC_30.9K,1%30.9K, 1% ICR383
R_0402_IPCRES_HORIZ_R_0402_IPC_10K,1%10K, 1% ICR384
R_0402_IPCRES_VERT_R_0402_IPC_100,1%100, 1% ICR385
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER386
R_0402_IPCRES_VERT_R_0402_IPC_750750 ICR387
R_0402_IPCRES_VERT_R_0402_IPC_100,1%100, 1% ICR388
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER389
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER390
R_0402_IPCRES_HORIZ_R_0402_IPC_3.01K,1%3.01K, 1% ICR391
R_0603_IPCRES_HORIZ_R_0603_IPC_4.7K,1%4.7K, 1% ICR392
R_0402_IPCRES_HORIZ_R_0402_IPC_66.5K,1%66.5K, 1% ICR393
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER394
R_0402_IPCRES_HORIZ_R_0402_IPC_10K,1%10K, 1% ICR395
R_0402_IPCRES_HORIZ_R_0402_IPC_200,1%200, 1% ICR396
R_0402_IPCRES_HORIZ_R_0402_IPC_3.57K,1%3.57K, 1% ICR397
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER398
R_0402_IPCRES_HORIZ_R_0402_IPC_120,1%120, 1% ICR399
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER400
R_0603_IPCRES_HORIZ_R_0603_IPC_300,1%300, 1% ICR401
R_0402_IPCRES_HORIZ_R_0402_IPC_845%845% ICR402
R_0402_IPCRES_HORIZ_R_0402_IPC_120,1%120, 1% ICR403
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER404
R_0603_IPCRES_HORIZ_R_0603_IPC_300,1%300, 1% ICR405
R_0402_IPCRES_HORIZ_R_0402_IPC_845%845% ICR406
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER407
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER408
R_0402_IPCRES_HORIZ_R_0402_IPC_3.57K,1%3.57K, 1% ICR409
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER410
R_0402_IPCRES_VERT_R_0402_IPC_820,1%820, 1% ICR411
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER412
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER413
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER414
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER415
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER416
R_0402_IPCRES_HORIZ_R_0402_IPC_100,1%100, 1% DISCRETER417
R_0402_IPCRES_HORIZ_R_0402_IPC_30.9K,1%30.9K, 1% ICR418
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER419
R_0402_IPCRES_HORIZ_R_0402_IPC_10K,1%10K, 1% ICR420
R_0402_IPCRES_HORIZ_R_0402_IPC_30.9K,1%30.9K, 1% ICR421
R_0402_IPCRES_HORIZ_R_0402_IPC_10K,1%10K, 1% ICR422
R_0402_IPCRES_VERT_R_0402_IPC_100,1%100, 1% ICR423
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER424
R_0402_IPCRES_VERT_R_0402_IPC_750750 ICR425
R_0402_IPCRES_VERT_R_0402_IPC_100,1%100, 1% ICR426
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER427
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER428
R_0402_IPCRES_HORIZ_R_0402_IPC_3.01K,1%3.01K, 1% ICR429
R_0603_IPCRES_HORIZ_R_0603_IPC_4.7K,1%4.7K, 1% ICR430
R_0402_IPCRES_HORIZ_R_0402_IPC_66.5K,1%66.5K, 1% ICR431
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER432
R_0402_IPCRES_HORIZ_R_0402_IPC_10K,1%10K, 1% ICR433
R_0402_IPCRES_HORIZ_R_0402_IPC_200,1%200, 1% ICR434
R_0402_IPCRES_HORIZ_R_0402_IPC_3.57K,1%3.57K, 1% ICR435
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER436
R_0402_IPCRES_HORIZ_R_0402_IPC_120,1%120, 1% ICR437
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER438
R_0603_IPCRES_HORIZ_R_0603_IPC_300,1%300, 1% ICR439
R_0402_IPCRES_HORIZ_R_0402_IPC_845%845% ICR440
R_0402_IPCRES_HORIZ_R_0402_IPC_120,1%120, 1% ICR441
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER442
R_0603_IPCRES_HORIZ_R_0603_IPC_300,1%300, 1% ICR443
R_0402_IPCRES_HORIZ_R_0402_IPC_845%845% ICR444
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER445
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER446
R_0402_IPCRES_HORIZ_R_0402_IPC_3.57K,1%3.57K, 1% ICR447
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER448
R_0402_IPCRES_VERT_R_0402_IPC_820,1%820, 1% ICR449
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER450
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER451
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER452
R_0603_IPCRES_HORIZ_R_0603_IPC_60.4,1%60.4, 1% ICR453
R_1206_IPCRES_HORIZ_R_1206_IPC_26.7,1%26.7, 1% ICR454
R_1206_IPCRES_HORIZ_R_1206_IPC_26.7,1%26.7, 1% ICR455
R_0603_IPCRES_HORIZ_R_0603_IPC_30.1,1%30.1, 1% ICR456
R_0603_IPCRES_HORIZ_R_0603_IPC_1,1%1, 1% ICR457
R_0805_IPCRES_VERT_R_0805_IPC_866,1%866, 1% ICR458
R_0603_IPCRES_HORIZ_R_0603_IPC_30.1,1%30.1, 1% ICR459
R_0603_IPCRES_HORIZ_R_0603_IPC_1,1%1, 1% ICR460
R_1206_IPCRES_HORIZ_R_1206_IPC_26.7,1%26.7, 1% ICR461
R_1206_IPCRES_HORIZ_R_1206_IPC_26.7,1%26.7, 1% ICR462
R_0603_IPCRES_HORIZ_R_0603_IPC_60.4,1%60.4, 1% ICR463
R_0402_IPCRES_VERT_R_0402_IPC_00 ICR464
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER465
R_0402_IPCRES_HORIZ_R_0402_IPC_1.33K,1%1.33K, 1% ICR466
R_0402_IPCRES_VERT_R_0402_IPC_200,1%200, 1% ICR467
R_0402_IPCRES_HORIZ_R_0402_IPC_1.33K,1%1.33K, 1% ICR468
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER469
R_0603_IPCRES_HORIZ_R_0603_IPC_412,1%412, 1% ICR470
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER471
R_0402_IPCRES_HORIZ_R_0402_IPC_49.9,1%49.9, 1% ICR472
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER473
R_0402_IPCRES_VERT_R_0402_IPC_00 ICR474
R_0402_IPCRES_VERT_R_0402_IPC_00 ICR475
R_0402_IPCRES_VERT_R_0402_IPC_00 ICR476
R_0402_IPCRES_HORIZ_R_0402_IPC_49.9,1%49.9, 1% ICR477
R_0402_IPCRES_VERT_R_0402_IPC_00 ICR478
R_0402_IPCRES_HORIZ_R_0402_IPC_49.9,1%49.9, 1% ICR479
R_0603_IPCRES_HORIZ_R_0603_IPC_412,1%412, 1% ICR480
R_0402_IPCRES_HORIZ_R_0402_IPC_49.9,1%49.9, 1% ICR481
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER482
R_0603_IPCRES_HORIZ_R_0603_IPC_60.4,1%60.4, 1% ICR483
R_1206_IPCRES_HORIZ_R_1206_IPC_26.7,1%26.7, 1% ICR484
R_1206_IPCRES_HORIZ_R_1206_IPC_26.7,1%26.7, 1% ICR485
R_0603_IPCRES_HORIZ_R_0603_IPC_30.1,1%30.1, 1% ICR486
R_0603_IPCRES_HORIZ_R_0603_IPC_1,1%1, 1% ICR487
R_0805_IPCRES_VERT_R_0805_IPC_866,1%866, 1% ICR488
R_0603_IPCRES_HORIZ_R_0603_IPC_30.1,1%30.1, 1% ICR489
R_0603_IPCRES_HORIZ_R_0603_IPC_1,1%1, 1% ICR490
R_1206_IPCRES_HORIZ_R_1206_IPC_26.7,1%26.7, 1% ICR491
R_1206_IPCRES_HORIZ_R_1206_IPC_26.7,1%26.7, 1% ICR492
R_0603_IPCRES_HORIZ_R_0603_IPC_60.4,1%60.4, 1% ICR493
R_0402_IPCRES_VERT_R_0402_IPC_00 ICR494
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER495
R_0402_IPCRES_HORIZ_R_0402_IPC_1.33K,1%1.33K, 1% ICR496
R_0402_IPCRES_VERT_R_0402_IPC_200,1%200, 1% ICR497
R_0402_IPCRES_HORIZ_R_0402_IPC_1.33K,1%1.33K, 1% ICR498
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER499
R_0603_IPCRES_HORIZ_R_0603_IPC_412,1%412, 1% ICR500
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER501
R_0402_IPCRES_HORIZ_R_0402_IPC_49.9,1%49.9, 1% ICR502
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER503
R_0402_IPCRES_VERT_R_0402_IPC_00 ICR504
R_0402_IPCRES_VERT_R_0402_IPC_00 ICR505
R_0402_IPCRES_VERT_R_0402_IPC_00 ICR506
R_0402_IPCRES_HORIZ_R_0402_IPC_49.9,1%49.9, 1% ICR507
R_0402_IPCRES_VERT_R_0402_IPC_00 ICR508
R_0402_IPCRES_HORIZ_R_0402_IPC_49.9,1%49.9, 1% ICR509
R_0603_IPCRES_HORIZ_R_0603_IPC_412,1%412, 1% ICR510
R_0402_IPCRES_HORIZ_R_0402_IPC_49.9,1%49.9, 1% ICR511
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER512
R_0402_IPCRES_VERT_R_0402_IPC_00 ICR513
R_0402_IPCRES_VERT_R_0402_IPC_00 ICR514
R_0402_IPCRES_HORIZ_R_0402_IPC_1010 ICR515
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER516
R_0402_IPCRES_VERT_R_0402_IPC_00 ICR517
R_0402_IPCRES_VERT_R_0402_IPC_00 ICR518
R_0402_IPCRES_HORIZ_R_0402_IPC_1010 ICR519
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER520
R_0402_IPCRES_VERT_R_0402_IPC_39K,1%39K, 1% ICR521
R_0402_IPCRES_VERT_R_0402_IPC_100K,1%100K, 1% ICR522
R_0402_IPCRES_HORIZ_R_0402_IPC_110K,1%110K, 1% ICR523
R_0402_IPCRES_VERT_R_0402_IPC_39K,1%39K, 1% ICR524
R_0402_IPCRES_HORIZ_R_0402_IPC_4.99K,1%4.99K, 1% ICR525
R_0402_IPCRES_VERT_R_0402_IPC_59.0K,1%59.0K, 1% ICR526
R_0402_IPCRES_HORIZ_R_0402_IPC_10K10K ICR527
R_0402_IPCRES_VERT_R_0402_IPC_13K,1%13K, 1% ICR528
R_0402_IPCRES_VERT_R_0402_IPC_47K,1%47K, 1% ICR529
R_0402_IPCRES_VERT_R_0402_IPC_47K,1%47K, 1% ICR530
R_0402_IPCRES_VERT_R_0402_IPC_47K,1%47K, 1% ICR531
R_0402_IPCRES_VERT_R_0402_IPC_681,1%681, 1% ICR532
R_0402_IPCRES_VERT_R_0402_IPC_1K,1%1K, 1% ICR533
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER534
R_1206_IPCRES_VERT_R_1206_IPC_1M,1%1M, 1% ICR535
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER536
R_0402_IPCRES_VERT_R_0402_IPC_110K,1%110K, 1% ICR537
R_0402_IPCRES_VERT_R_0402_IPC_27K,1%27K, 1% ICR538
R_0402_IPCRES_VERT_R_0402_IPC_84.5K,1%84.5K, 1% ICR539
R_0402_IPCRES_HORIZ_R_0402_IPC_3.01,1%3.01, 1% ICR540
R_0402_IPCRES_HORIZ_R_0402_IPC_3.01,1%3.01, 1% ICR541
R_0402_IPCRES_VERT_R_0402_IPC_4.75K,1%4.75K, 1% ICR542
R_0402_IPCRES_VERT_R_0402_IPC_4.75K,1%4.75K, 1% ICR543
R_0402_IPCRES_VERT_R_0402_IPC_4.75K,1%4.75K, 1% ICR544
R_0402_IPCRES_HORIZ_R_0402_IPC_3.01,1%3.01, 1% ICR545
R_0402_IPCRES_HORIZ_R_0402_IPC_3.01,1%3.01, 1% ICR546
R_0402_IPCRES_VERT_R_0402_IPC_1K,1%1K, 1% ICR547
R_0402_IPCRES_VERT_R_0402_IPC_4.75K,1%4.75K, 1% ICR548
R_0402_IPCRES_VERT_R_0402_IPC_4.75K,1%4.75K, 1% ICR549
R_0402_IPCRES_HORIZ_R_0402_IPC_3.01,1%3.01, 1% ICR550
R_0402_IPCRES_HORIZ_R_0402_IPC_3.01,1%3.01, 1% ICR551
R_0402_IPCRES_VERT_R_0402_IPC_100K,1%100K, 1% ICR552
R_0402_IPCRES_VERT_R_0402_IPC_100K,1%100K, 1% ICR553
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER554
R_0402_IPCRES_VERT_R_0402_IPC_100K,1%100K, 1% ICR555
R_0402_IPCRES_VERT_R_0402_IPC_4.75K,1%4.75K, 1% ICR556
R_0402_IPCRES_VERT_R_0402_IPC_5.36K,1%5.36K, 1% ICR557
R_0402_IPCRES_VERT_R_0402_IPC_100K,1%100K, 1% ICR558
R_0402_IPCRES_HORIZ_R_0402_IPC_90.0,2%90.0, 2% ICR559
R_0402_IPCRES_HORIZ_R_0402_IPC_90.0,2%90.0, 2% ICR560
R_0402_IPCRES_VERT_R_0402_IPC_1.02K,1%1.02K, 1% ICR561
R_0402_IPCRES_VERT_R_0402_IPC_100K,1%100K, 1% ICR562
R_0402_IPCRES_VERT_R_0402_IPC_100K,1%100K, 1% ICR563
R_0402_IPCRES_HORIZ_R_0402_IPC_162,1%162, 1% ICR564
R_0402_IPCRES_HORIZ_R_0402_IPC_90.0,2%90.0, 2% ICR565
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR566
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR567
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR568
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR569
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR570
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR571
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR572
R_0402_IPCRES_VERT_R_0402_IPC_4.75K,1%4.75K, 1% ICR573
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR574
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR575
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR576
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR577
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR578
R_0402_IPCRES_VERT_R_0402_IPC_4.75K,1%4.75K, 1% ICR579
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR580
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR581
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR582
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR583
R_0402_IPCRES_VERT_R_0402_IPC_4.75K,1%4.75K, 1% ICR584
R_0402_IPCRES_HORIZ_R_0402_IPC_330330 ICR585
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR586
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR587
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR588
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR589
R_0402_IPCRES_HORIZ_R_0402_IPC_330330 ICR590
R_0402_IPCRES_VERT_R_0402_IPC_4.75K,1%4.75K, 1% ICR591
R_0402_IPCRES_HORIZ_R_0402_IPC_330330 ICR592
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR593
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR594
R_0402_IPCRES_HORIZ_R_0402_IPC_330,1%330, 1% ICR595
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR596
R_0402_IPCRES_HORIZ_R_0402_IPC_330,1%330, 1% ICR597
R_0402_IPCRES_HORIZ_R_0402_IPC_330,1%330, 1% ICR598
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR599
R_0402_IPCRES_HORIZ_R_0402_IPC_330330 ICR600
R_0402_IPCRES_VERT_R_0402_IPC_4.75K,1%4.75K, 1% ICR601
R_0402_IPCRES_VERT_R_0402_IPC_4.75K,1%4.75K, 1% ICR602
R_0402_IPCRES_VERT_R_0402_IPC_4.75K,1%4.75K, 1% ICR603
R_0402_IPCRES_VERT_R_0402_IPC_1K1K ICR604
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER605
R_0402_IPCRES_VERT_R_0402_IPC_100100 ICR606
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER607
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER608
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER609
R_0402_IPCRES_VERT_R_0402_IPC_4.75K,1%4.75K, 1% ICR610
R_0402_IPCRES_VERT_R_0402_IPC_4.75K,1%4.75K, 1% ICR611
R_0402_IPCRES_VERT_R_0402_IPC_1.24K,1%1.24K, 1% ICR612
R_0402_IPCRES_VERT_R_0402_IPC_00 ICR613
R_0402_IPCRES_VERT_R_0402_IPC_1K,1%1K, 1% ICR614
R_0402_IPCRES_VERT_R_0402_IPC_14.3K,1%14.3K, 1% ICR615
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR616
R_0402_IPCRES_VERT_R_0402_IPC_1K,1%1K, 1% ICR617
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR618
R_0402_IPCRES_VERT_R_0402_IPC_15.8K,1%15.8K, 1% ICR619
R_0402_IPCRES_VERT_R_0402_IPC_15.8K,1%15.8K, 1% ICR620
R_0402_IPCRES_VERT_R_0402_IPC_15.8K,1%15.8K, 1% ICR621
R_0402_IPCRES_VERT_R_0402_IPC_1K,1%1K, 1% ICR622
R_0402_IPCRES_VERT_R_0402_IPC_3.16K,1%3.16K, 1% ICR623
R_0402_IPCRES_VERT_R_0402_IPC_00 ICR624
R_0402_IPCRES_VERT_R_0402_IPC_00 ICR625
R_0402_IPCRES_VERT_R_0402_IPC_4.75K,1%4.75K, 1% ICR626
R_0402_IPCRES_VERT_R_0402_IPC_4.75K,1%4.75K, 1% ICR627
R_0402_IPCRES_VERT_R_0402_IPC_4.75K,1%4.75K, 1% ICR628
R_0402_IPCRES_VERT_R_0402_IPC_4.75K,1%4.75K, 1% ICR629
R_0402_IPCRES_VERT_R_0402_IPC_1K,1%1K, 1% ICR630
R_0402_IPCRES_VERT_R_0402_IPC_4.75K,1%4.75K, 1% ICR631
R_0402_IPCRES_HORIZ_R_0402_IPC_200,1%200, 1% ICR632
R_0402_IPCRES_HORIZ_R_0402_IPC_200,1%200, 1% ICR633
R_0402_IPCRES_VERT_R_0402_IPC_4.75K,1%4.75K, 1% ICR634
R_0402_IPCRES_VERT_R_0402_IPC_73.2K,1%73.2K, 1% ICR635
R_0402_IPCRES_VERT_R_0402_IPC_73.2K,1%73.2K, 1% ICR636
R_0402_IPCRES_VERT_R_0402_IPC_00 ICR637
R_0402_IPCRES_VERT_R_0402_IPC_73.2K,1%73.2K, 1% ICR638
R_0402_IPCRES_VERT_R_0402_IPC_4.75K,1%4.75K, 1% ICR639
R_0402_IPCRES_VERT_R_0402_IPC_73.2K,1%73.2K, 1% ICR640
R_0402_IPCRES_HORIZ_R_0402_IPC_100,1%100, 1% DISCRETER641
R_0402_IPCRES_VERT_R_0402_IPC_205K,1%205K, 1% ICR642
R_0402_IPCRES_HORIZ_R_0402_IPC_100,1%100, 1% DISCRETER643
R_0402_IPCRES_VERT_R_0402_IPC_205K,1%205K, 1% ICR644
R_0402_IPCRES_VERT_R_0402_IPC_33.2K,1%33.2K, 1% ICR645
R_0402_IPCRES_VERT_R_0402_IPC_240,1%240, 1% ICR646
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER647
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER648
R_0402_IPCRES_VERT_R_0402_IPC_100,1%100, 1% ICR649
R_0402_IPCRES_VERT_R_0402_IPC_100,1%100, 1% ICR650
R_0402_IPCRES_HORIZ_R_0402_IPC_240,1%240, 1% ICR651
R_0402_IPCRES_HORIZ_R_0402_IPC_240,1%240, 1% ICR652
R_0402_IPCRES_HORIZ_R_0402_IPC_240,1%240, 1% ICR653
R_0402_IPCRES_HORIZ_R_0402_IPC_240,1%240, 1% ICR654
R_0402_IPCRES_HORIZ_R_0402_IPC_240,1%240, 1% ICR655
R_0402_IPCRES_HORIZ_R_0402_IPC_240,1%240, 1% ICR656
R_0805_IPCRES_HORIZ_R_0805_IPC_00 ICR657
R_0805_IPCRES_VERT_R_0805_IPC_00 ICR658
R_0805_IPCRES_HORIZ_R_0805_IPC_00 ICR659
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR660
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR661
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR662
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR663
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR664
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR665
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR666
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR667
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR668
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR669
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR670
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR671
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR672
R_0402_IPCRES_VERT_R_0402_IPC_4.75K,1%4.75K, 1% ICR673
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR674
R_0402_IPCRES_VERT_R_0402_IPC_4.75K,1%4.75K, 1% ICR675
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR676
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR677
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR678
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR679
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR680
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR681
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR682
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR683
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR684
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR685
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR686
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR687
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR688
R_0402_IPCRES_VERT_R_0402_IPC_1K1K ICR689
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR690
R_0402_IPCRES_VERT_R_0402_IPC_1K1K ICR691
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR692
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR693
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR694
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR695
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR696
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR697
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR698
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR699
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR700
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR701
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR702
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR703
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR704
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR705
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR706
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR707
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR708
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR709
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR710
R_0402_IPCRES_HORIZ_R_0402_IPC_100,1%100, 1% DISCRETER711
R_0402_IPCRES_HORIZ_R_0402_IPC_100,1%100, 1% DISCRETER712
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR713
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR714
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR715
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR716
R_0402_IPCRES_HORIZ_R_0402_IPC_100,1%100, 1% DISCRETER717
R_0402_IPCRES_HORIZ_R_0402_IPC_100,1%100, 1% DISCRETER718
R_0402_IPCRES_HORIZ_R_0402_IPC_100,1%100, 1% DISCRETER719
R_0402_IPCRES_HORIZ_R_0402_IPC_100,1%100, 1% DISCRETER720
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR721
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR722
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR723
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR724
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR725
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR726
R_0402_IPCRES_HORIZ_R_0402_IPC_2K,1%2K, 1% ICR727
R_0402_IPCRES_HORIZ_R_0402_IPC_2K,1%2K, 1% ICR728
R_0402_IPCRES_HORIZ_R_0402_IPC_100,1%100, 1% DISCRETER729
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR730
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR731
R_0402_IPCRES_HORIZ_R_0402_IPC_100,1%100, 1% DISCRETER732
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR733
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR734
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR735
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR736
R_0402_IPCRES_HORIZ_R_0402_IPC_2K,1%2K, 1% ICR737
R_0402_IPCRES_HORIZ_R_0402_IPC_2K,1%2K, 1% ICR738
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER739
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR740
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR741
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR742
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR743
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR744
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR745
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR746
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR747
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR748
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR749
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR750
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR751
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR752
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR753
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR754
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR755
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR756
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR757
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR758
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR759
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR760
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR761
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR762
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR763
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR764
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR765
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR766
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR767
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR768
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR769
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR770
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR771
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR772
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR773
R_0402_IPCRES_HORIZ_R_0402_IPC_1K,1%1K, 1% ICR774
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR775
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR776
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR777
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR778
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR779
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR780
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR781
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR782
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER783
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER784
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER785
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER786
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR787
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR788
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR789
R_0402_IPCRES_HORIZ_R_0402_IPC_4.75K,1%4.75K, 1% ICR790
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER826
R_0402_IPCRES_HORIZ_R_0402_IPC_33.2,1%33.2, 1% ICR859
R_0402_IPCRES_HORIZ_R_0402_IPC_33.2,1%33.2, 1% ICR860
R_0402_IPCRES_HORIZ_R_0402_IPC_33.2,1%33.2, 1% ICR861
R_0402_IPCRES_HORIZ_R_0402_IPC_33.2,1%33.2, 1% ICR862
R_0402_IPCRES_VERT_R_0402_IPC_49.9,1%49.9, 1% ICR863
R_0402_IPCRES_VERT_R_0402_IPC_49.9,1%49.9, 1% ICR864
R_0402_IPCRES_VERT_R_0402_IPC_49.9,1%49.9, 1% ICR865
R_0402_IPCRES_VERT_R_0402_IPC_49.9,1%49.9, 1% ICR866
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER933
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER934
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER935
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER936
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER937
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER938
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER939
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER940
R_0402_IPCRES_HORIZ_R_0402_IPC_10K10K ICR941
R_0402_IPCRES_HORIZ_R_0402_IPC_10K10K ICR942
R_0402_IPCRES_HORIZ_R_0402_IPC_33.2,1%33.2, 1% ICR944
R_0402_IPCRES_HORIZ_R_0402_IPC_10K10K ICR945
R_0402_IPCRES_HORIZ_R_0402_IPC_33.2,1%33.2, 1% ICR946
R_0402_IPCRES_HORIZ_R_0402_IPC_33.2,1%33.2, 1% ICR947
R_0402_IPCRES_HORIZ_R_0402_IPC_33.2,1%33.2, 1% ICR948
R_0402_IPCRES_HORIZ_R_0402_IPC_10K10K ICR949
R_0402_IPCRES_HORIZ_R_0402_IPC_10K10K ICR950
R_0402_IPCRES_HORIZ_R_0402_IPC_10K10K ICR951
R_0402_IPCRES_VERT_R_0402_IPC_49.9,1%49.9, 1% ICR952
R_0402_IPCRES_VERT_R_0402_IPC_49.9,1%49.9, 1% ICR953
R_0402_IPCRES_HORIZ_R_0402_IPC_10K10K ICR955
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER956
R_0402_IPCRES_HORIZ_R_0402_IPC_1K1K ICR957
R_0402_IPCRES_VERT_R_0402_IPC_1K1K ICR958
R_0402_IPCRES_VERT_R_0402_IPC_1K1K ICR959
R_0402_IPCRES_VERT_R_0402_IPC_1K1K ICR960
R_0402_IPCRES_VERT_R_0402_IPC_1K1K ICR961
R_0402_IPCRES_VERT_R_0402_IPC_10K10K ICR962
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR963
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR964
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR965
R_0402_IPCRES_VERT_R_0402_IPC_1K1K ICR966
R_0402_IPCRES_VERT_R_0402_IPC_1K1K ICR967
R_0402_IPCRES_VERT_R_0402_IPC_1K1K ICR968
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER969
R_0402_IPCRES_HORIZ_R_0402_IPC_00 DISCRETER970
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR971
R_0402_IPCRES_HORIZ_R_0402_IPC_330330 ICR972
R_0402_IPCRES_VERT_R_0402_IPC_4.7K4.7K ICR973
R_0805_IPCRES_HORIZ_R_0805_IPC_00 ICR974
R_0805_IPCRES_HORIZ_R_0805_IPC_00 ICR975
R_0402_IPCRES_HORIZ_R_0402_IPC_2.7K2.7K ICR976
R_0402_IPCRES_HORIZ_R_0402_IPC_2.7K2.7K ICR977
KMR_KMS_SERIESSWITCH_PUSH_SPST_VT_SMT4_KMR_KMSPST NO. VT ICS1
KMR_KMS_SERIESSWITCH_PUSH_SPST_VT_SMT4_KMR_KMSPST NO. VT ICS2
KMR_KMS_SERIESSWITCH_PUSH_SPST_VT_SMT4_KMR_KMSPST NO. VT ICS3
GB15AHSWITCH_PUSH_SPDT_RA_THR_GB15AH_SPDT ICSW1
SOIC127P600-16TSWITCH_DIP_8P0LE_0R05_SMT16_W_S8POLE ICSW6
XFMR_SMT8_750510482XFMR_1-1_SMT8_400UH_AVDSL_XFMR_7.51E+08 ICT1
LTC0269-50XFMR_1-1_SMT8_730UH_CUSTOM_LTC0LTC0269-50 ICT2
XFMR_SMT8_750510491XFMR_1-1_SMT8_400UH_AVDSL_XFM_17.51E+08 ICT3
XFMR_SMT8_750510482XFMR_1-1_SMT8_400UH_AVDSL_XFMR_7.51E+08 ICT4
LTC0269-50XFMR_1-1_SMT8_730UH_CUSTOM_LTC0LTC0269-50 ICT5
XFMR_SMT8_750510491XFMR_1-1_SMT8_400UH_AVDSL_XFM_17.51E+08 ICT6
TP_SMT_0R5MMPAD_0R5MM_SMT_TP_SMT_0R5MM_TESTTest Point ICTP1
TP_SMT_0R5MMPAD_0R5MM_SMT_TP_SMT_0R5MM_TESTTest Point ICTP2
TP_SMT_0R5MMPAD_0R5MM_SMT_TP_SMT_0R5MM_TESTTest Point ICTP3
TP_SMT_0R5MMPAD_0R5MM_SMT_TP_SMT_0R5MM_TESTTest Point ICTP4
TP_SMT_0R5MMPAD_0R5MM_SMT_TP_SMT_0R5MM_TESTTest Point ICTP5
TP_SMT_0R5MMPAD_0R5MM_SMT_TP_SMT_0R5MM_TESTTest Point ICTP6
TP_SMT_0R5MMPAD_0R5MM_SMT_TP_SMT_0R5MM_TESTTest Point ICTP7
TP_SMT_0R5MMPAD_0R5MM_SMT_TP_SMT_0R5MM_TESTTest Point ICTP8
TP_SMT_0R5MMPAD_0R5MM_SMT_TP_SMT_0R5MM_TESTTest Point ICTP9
TP_SMT_0R5MMPAD_0R5MM_SMT_TP_SMT_0R5MM_TESTTest Point ICTP10
TP_SMT_0R5MMPAD_0R5MM_SMT_TP_SMT_0R5MM_TESTTest Point ICTP11
TP_SMT_0R5MMPAD_0R5MM_SMT_TP_SMT_0R5MM_TESTTest Point ICTP12
TP_SMT_0R5MMPAD_0R5MM_SMT_TP_SMT_0R5MM_TESTTest Point ICTP13
TP_SMT_0R5MMPAD_0R5MM_SMT_TP_SMT_0R5MM_TESTTest Point ICTP14
TP_SMT_0R5MMPAD_0R5MM_SMT_TP_SMT_0R5MM_TESTTest Point ICTP15
TP_SMT_0R5MMPAD_0R5MM_SMT_TP_SMT_0R5MM_TESTTest Point ICTP16
TP_SMT_0R5MMPAD_0R5MM_SMT_TP_SMT_0R5MM_TESTTest Point ICTP17
TP_SMT_0R5MMPAD_0R5MM_SMT_TP_SMT_0R5MM_TESTTest Point ICTP18
TP_SMT_0R5MMPAD_0R5MM_SMT_TP_SMT_0R5MM_TESTTest Point ICTP19
TP_SMT_0R5MMPAD_0R5MM_SMT_TP_SMT_0R5MM_TESTTest Point ICTP20
TP_SMT_0R5MMPAD_0R5MM_SMT_TP_SMT_0R5MM_TESTTest Point ICTP21
TP_SMT_0R5MMPAD_0R5MM_SMT_TP_SMT_0R5MM_TESTTest Point ICTP22
TP_SMT_0R5MMPAD_0R5MM_SMT_TP_SMT_0R5MM_TESTTest Point ICTP23
TP_SMT_0R5MMPAD_0R5MM_SMT_TP_SMT_0R5MM_TESTTest Point ICTP24
TP_SMT_0R5MMPAD_0R5MM_SMT_TP_SMT_0R5MM_TESTTest Point ICTP25
TP_SMT_0R5MMPAD_0R5MM_SMT_TP_SMT_0R5MM_TESTTest Point ICTP26
TP_SMT_0R5MMPAD_0R5MM_SMT_TP_SMT_0R5MM_TESTTest Point ICTP27
TP_SMT_0R5MMPAD_0R5MM_SMT_TP_SMT_0R5MM_TESTTest Point ICTP28
TP_SMT_0R5MMPAD_0R5MM_SMT_TP_SMT_0R5MM_TESTTest Point ICTP29
TP_SMT_0R5MMPAD_0R5MM_SMT_TP_SMT_0R5MM_TESTTest Point ICTP30
TP_SMT_0R5MMPAD_0R5MM_SMT_TP_SMT_0R5MM_TESTTest Point ICTP31
TP_SMT_0R5MMPAD_0R5MM_SMT_TP_SMT_0R5MM_TESTTest Point ICTP32
TP_SMT_0R5MMPAD_0R5MM_SMT_TP_SMT_0R5MM_TESTTest Point ICTP33
TP_SMT_0R5MMPAD_0R5MM_SMT_TP_SMT_0R5MM_TESTTest Point ICTP34
TP_SMT_0R5MMPAD_0R5MM_SMT_TP_SMT_0R5MM_TESTTest Point ICTP35
TP_SMT_0R5MMPAD_0R5MM_SMT_TP_SMT_0R5MM_TESTTest Point ICTP36
TP_SMT_0R5MMPAD_0R5MM_SMT_TP_SMT_0R5MM_TESTTest Point ICTP37
TP_SMT_0R5MMPAD_0R5MM_SMT_TP_SMT_0R5MM_TESTTest Point ICTP38
0402_DFNSUP_TVS_0402_BIDIR_1R8PF_0402_DSPA ICTVS1
0402_DFNSUP_TVS_0402_BIDIR_1R8PF_0402_DSPA ICTVS2
0402_DFNSUP_TVS_0402_BIDIR_1R8PF_0402_DSPA ICTVS3
0402_DFNSUP_TVS_0402_BIDIR_1R8PF_0402_DSPA ICTVS4
0402_DFNSUP_TVS_0402_BIDIR_1R8PF_0402_DSPA ICTVS5
0402_DFNSUP_TVS_0402_BIDIR_1R8PF_0402_DSPA ICTVS6
0402_DFNSUP_TVS_0402_BIDIR_1R8PF_0402_DSPA ICTVS7
0402_DFNSUP_TVS_0402_BIDIR_1R8PF_0402_DSPA ICTVS8
0402_DFNSUP_TVS_0402_BIDIR_1R8PF_0402_DSPA ICTVS9
0402_DFNSUP_TVS_0402_BIDIR_1R8PF_0402_DSPA ICTVS10
0402_DFNSUP_TVS_0402_BIDIR_1R8PF_0402_DSPA ICTVS11
0402_DFNSUP_TVS_0402_BIDIR_1R8PF_0402_DSPA ICTVS12
SOP65P300-8TIC_TEMP_MSOP8_MONITOR_I2C_7461_ADT7461 ICU1
SC70_5IC_AND_SC70_SINGLE_74LVC1G08_SC74LVC1G08 ICU2
SC70_5IC_AND_SC70_SINGLE_74LVC1G08_SC74LVC1G08 ICU3
BGA80P25X25-621TIC_CPU_FCPBGA621_LS1043A_BGA80PLS1043A ICU4
SOT_23_6SUP_ESD_SOT23-6_15KV_USBLC6_SOTUSBLC6 ICU6
QFN50P400X400-24-1TIC_USB_QFN24_UART_XCVR_CP2104_2CP2104 ICU7
SOIC127P1030-16NIC_RTC_SO16_I2C_PCF2129T_SOIC12PCF2129 ICU8
SOT_23_5IC_RSTVM_SOT235_2774_THR2R93V_1MIC2774N-29 ICU9
SC70_5IC_BUF_SC70_SINGLE_2_SC70_5_741741G07 ICU10
SOT_23_5IC_RSTVM_SOT235_2774_THR2R93V_SMIC2774N-17 ICU11
SC70_5IC_AND_SC70_SINGLE_74LVC1G08_SC74LVC1G08 ICU12
FBGA80P10X12-63MEMF_4GBX8_FBGA63_NAND_FBGA80P14Gb NAND 1.8V ICU14
QFN50P465X365-20-1T_1IC_BUF_VQFN20_8BIT_TXS0108E_QFNTXS0108E ICU15
DFN50P3X3-10P-CPIC_PWR_TDFN10_DUAL_MAX1588_DFN5MAX1588 ICU16
DFN50P2X7-14SUP_ESD_UDFN14_8KV_USB_SP3011_DSP3011 ICU17
DFN50P2X7-14SUP_ESD_UDFN14_8KV_USB_SP3011_DSP3011 ICU18
FBGA80P6X13-78TMEMDDR4_4GBX8_FBGA78_FBGA80P6X1MEMDDR4_512Mx8 ICU19
FBGA80P6X13-78TMEMDDR4_4GBX8_FBGA78_FBGA80P6X1MEMDDR4_512Mx8 ICU20
FBGA80P6X13-78TMEMDDR4_4GBX8_FBGA78_FBGA80P6X1MEMDDR4_512Mx8 ICU21
FBGA80P6X13-78TMEMDDR4_4GBX8_FBGA78_FBGA80P6X1MEMDDR4_512Mx8 ICU22
FBGA80P6X13-78TMEMDDR4_4GBX8_FBGA78_FBGA80P6X1MEMDDR4_512Mx8 ICU23
TSOP65P640-8NMEMEE_4KBX8_TSSOP8_100KHZ_I2C_TAT24C04C ICU24
TSSOP65P640-28TIC_CLKGEN_TSOP28_HCSL4_9FG430_T9FG430 ICU25
SOP65P780-16TIC_BUF_TSSOP16_I2C_8IO_PCA9554_PCA9554 ICU26
TSOP65P640-16NIC_MUX_TSSOP16_1X4_I2C_PCA9546_PCA9546 ICU27
F104S8AIC_ENETG_QFN138_QSGMII_F104S8A_F104S8A ICU28
QFN50P465X365-20-1T_1IC_BUF_VQFN20_8BIT_TXS0108E_QFNTXS0108E ICU30
QFN_64IC_VOICE_QFN64_DUAL_ZR88801_QFNZL88801 ICU31
SOIC127P600-8LSUP_ESD_SOIC8_SLIC_OV_TISP6NTP_TISP6NTP2C ICU32
DFN50P3X3-10REG_LDO_DFN10_0R5A_45VADJ_3065_LT3065 ICU35
DFN50P3X3-10REG_LDO_DFN10_0R5A_45VADJ_3065_LT3065 ICU36
SOP50P300-10TIC_PWR_MSOP8_MON_I2C_INA220_SOPINA220A ICU37
SC70_5IC_BUF_SC70_SINGLE_2_SC70_5_741741G07 ICU38
SC70_5IC_BUF_SC70_SINGLE_2_SC70_5_741741G07 ICU39
BGA127P11X7-77REG_MOD_BGA77_4X4A_14V_LTM4644_LTM4644 ICU40
BGA127P11X7-68REG_MOD_BGA68_10A_16V_LTM4649_BLTM4649 ICU41
SC70_5IC_BUF_SC70_SINGLE_2_SC70_5_741741G07 ICU42
SC70_5IC_BUF_SC70_SINGLE_2_SC70_5_741741G07 ICU43
SC70_5IC_BUF_SC70_SINGLE_2_SC70_5_741741G07 ICU44
DFN_PACK_10REG_SW_DFN10_LTC3568_ADJ_DFN_PALTC3568 ICU45
QFN50P800X800-56REG_PMIC_QFN56_MC34VR500V4_QFN5MC34VR500V4 ICU46
QFN40P900X900-76-1PIC_DSL_QFN76_IFE7S_SINGLE_QFN40FXS70IF1BE ICU47
QFN40P900X900-76-1PIC_DSL_QFN76_IFE7S_SINGLE_QFN40FXS70IF1BE ICU48
QFN50P700X800-52-3TREG_SW_QFN52-3T_LTC3608_3_QFN50LTC3608 ICU49
DD_PAK_5PREG_LIN_DDPAK5_5V_LT1529_3AMP_DLT1529 ICU50
SOP65P300-8TREG_LIN_MSOP8_ADJ_LDO_1R5A_SOP6MIC49150 ICU51
SOP65P640-16-CPREG_SW_TSOP16_LTC3124_BOOST_12VLTC3124 ICU52
BGA80P25X25-625TIC_DSL_FBGA625_PHY_RGMII_VX585_Vx585 ICU53
SON3X3-8XSTR_PWR_PFET_SON8_60A_20V_SON3CSD25401Q3 ICU54
DFN50P2X2-8TREG_LIN_TDFN8_ADJ_LDO_0R5A_DFN5MIC47053 ICU55
SC70_6IC_INV_SC70_DUAL_74LVC2G04_SC7074LVC2G04 ICU56
SOT95P300X300-5MREG_SUP_SOT23-5_UV_2R25V_SOT95PTPS3836J25DBVT ICU57
SC70_5IC_AND_SC70_SINGLE_74LVC1G08_SC74LVC1G08 ICU58
SOT95P280X145-5MIC_AND_TSOP5_SINGLE_OD_1G09_SOTOD, 74AHC1G09GV ICU59
SOT23_3TREG_LIN_SOT23_MCP1700_1R8V_SOT2MCP1700 ICU60
SOT_23_6SUP_ESD_SOT23-6_15KV_USBLC6_SOTUSBLC6 ICU61
QFN50P400X400-24-1TIC_USB_QFN24_UART_XCVR_CP2104_2CP2104 ICU62
FBGA80P6X16-96T_9MMX14MMMEMDDR3_X16_FBGA96_2_FBGA80P6X12GbX16 DDR3 ICU63
FBGA80P6X16-96T_9MMX14MMMEMDDR3_X16_FBGA96_2_FBGA80P6X12GbX16 DDR3 ICU64
FBGA80P10X12-63MEMF_4GBX8_FBGA63_NAND_FBGA80_14Gb NAND ICU65
BGA100P10X10-24TMEMF_512MB_BGA24_NOR_SPI_133MH_S25FL512 ICU66
QFN50P465X365-20-1T_1IC_BUF_VQFN20_8BIT_TXS0108E_QFNTXS0108E ICU67
SC70_5IC_BUF_SC70_SINGLE_2_SC70_5_741741G07 ICU68
SC70_5IC_BUF_SC70_SINGLE_2_SC70_5_741741G07 ICU69
SC70_6IC_INV_SC70_DUAL_74LVC2G04_SC7074LVC2G04 ICU70
QFN50P400X400-24-1TIC_ENET_QFN24_RTMR_DS125DF111_QDS125DF111 ICU71
SOIC127P600-8NMEMEE_4KBX8_SOIC8_100KHZ_I2C_SOAT24C04C ICU72
SC70_5IC_AND_SC70_SINGLE_74LVC1G08_SC74LVC1G08 ICU73
2027-XX-SMFUSE_GAS_2PIN_2027-XX-SM_2027-32027-35-SMLF ICV1
2027-XX-SMFUSE_GAS_2PIN_2027-XX-SM_2027-32027-35-SMLF ICV2
74737_1CON_SFP+_CAGE_F_RA_74737_1_SFP+SFP+ CAGE ICX1
OSC_3FP_3R2X2R5OSC_4PIN_OSC_3FP_3R2X2R5_100.00100.000MHz ICY1
ABM8XTAL_25MHZ_3R2X2R5_30PPM_18PF_425Mhz ICY2
OSC_6PAD_3R2X5OSC_HCSL_6PIN_OSC_6PAD_3R2X5_15156.25MHZ LVDS ICY3
OSC_6PAD_3R2X5OSC_HCSL_6PIN_OSC_6PAD_3R2X5_12125MHZ LVDS ICY5
OSC_3FP_3R2X2R5CRYSTAL_4P_OSC_3FP_3R2X2R5_25M25 MHz ICY6
[free]
购买主题 本主题需向作者支付 10 枚金币 才能浏览
重要提示:PCB作品文件展下载说明
    半小时前
  • 签到天数: 170 天
    发表于 2018-11-27 21:59:50 | 显示全部楼层
    无聊
    2025-1-1 20:13
    终身成就奖社区居民优秀斑竹奖
    发表于 2018-12-4 20:25:59 | 显示全部楼层
    发表于 2019-2-28 17:09:26 | 显示全部楼层
    昨天 15:30
  • 签到天数: 184 天
    1元学习PADS(3期)
    发表于 2019-3-1 08:36:58 | 显示全部楼层
    发表于 2019-3-1 08:47:59 | 显示全部楼层
    发表于 2020-1-13 16:53:34 | 显示全部楼层
    发表于 2022-11-18 11:37:21 | 显示全部楼层
    发表于 2023-6-10 18:43:08 | 显示全部楼层
    发表于 2023-6-10 18:44:14 | 显示全部楼层
