SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_TOL | COMP_CLASS | REFDES |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C1 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C2 |
CC3528-21 | MOT_TCAP_CC3528-21_2.1MM_150-75 | 10UF | 20% | IC | C3 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C4 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C5 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C6 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C7 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C8 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C9 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C10 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C11 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C12 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C13 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C14 |
CC3216 | MOT_TCAP_CC3216_1.8MM_150-75258 | 33UF | 20% | IC | C15 |
CC1210-32 | MOT_CAP_CC1210-32_3.17MM_150-75 | 4.7UF | 10% | IC | C16 |
CC3216 | MOT_TCAP_CC3216_1.8MM_150-75258 | 33UF | 20% | IC | C17 |
CC1210-32 | MOT_CAP_CC1210-32_3.17MM_150-75 | 4.7UF | 10% | IC | C18 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C19 |
CC3216 | MOT_TCAP_CC3216_1.8MM_150-75258 | 33UF | 20% | IC | C21 |
CC1206 | MOT_CAP_CC1206_1.27MM_150-30029 | 1.0UF | 10% | IC | C22 |
CC1210-32 | MOT_CAP_CC1210-32_3.17MM_150-75 | 4.7UF | 10% | IC | C23 |
CC1210-32 | MOT_CAP_CC1210-32_3.17MM_150-75 | 4.7UF | 10% | IC | C24 |
CC3216 | MOT_TCAP_CC3216_1.8MM_150-75258 | 33UF | 20% | IC | C25 |
CC1206 | MOT_CAP_CC1206_1.27MM_150-30029 | 1.0UF | 10% | IC | C29 |
CC3528-21 | MOT_TCAP_CC3528-21_2.1MM_150-75 | 10UF | 20% | IC | C30 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C31 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C84 |
CC0603 | MOT_CAP_CC0603_0.90MM_150-75139 | 47PF | 5% | IC | C85 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C96 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C100 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C102 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C115 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C116 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C117 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C118 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C119 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C120 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C123 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C124 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C125 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C126 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C127 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C128 |
CC0603 | CAP_NP_CC0603_0.90MM_150-75009_ | 0.01UF | 10% | IC | C130 |
CC0603 | CAP_NP_CC0603_0.90MM_150-75009_ | 0.01UF | 10% | IC | C131 |
CC0603 | CAP_NP_CC0603_0.90MM_150-75009_ | 0.01UF | 10% | IC | C132 |
CC0603 | CAP_NP_CC0603_0.90MM_150-75009_ | 0.01UF | 10% | IC | C133 |
CC0603 | CAP_NP_CC0603_0.90MM_150-75009_ | 0.01UF | 10% | IC | C134 |
CC0603 | CAP_NP_CC0603_0.90MM_150-75009_ | 0.01UF | 10% | IC | C135 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C136 |
CC0603 | CAP_NP_CC0603_0.90MM_150-75009_ | 0.01UF | 10% | IC | C137 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C138 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C139 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C140 |
CC0603 | CAP_NP_CC0603_0.90MM_150-75009_ | 0.01UF | 10% | IC | C141 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C143 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C144 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C145 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C150 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C151 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C152 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C153 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C157 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C158 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C159 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C160 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C166 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C167 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C170 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C171 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C172 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C173 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C176 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C177 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C178 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C179 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C180 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C187 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C188 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C189 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C190 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C191 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C192 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C193 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C194 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C195 |
CC3528-21 | MOT_TCAP_CC3528-21_2.1MM_150-75 | 10UF | 20% | IC | C196 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C197 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C198 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C199 |
CC3528-21 | MOT_TCAP_CC3528-21_2.1MM_150-75 | 10UF | 20% | IC | C200 |
CC3528-21 | MOT_TCAP_CC3528-21_2.1MM_150-75 | 10UF | 20% | IC | C201 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C204 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C205 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C206 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C207 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C208 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C209 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C210 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C211 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C212 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C213 |
CC3528-21 | MOT_TCAP_CC3528-21_2.1MM_150-75 | 10UF | 20% | IC | C214 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C215 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C216 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C217 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C218 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C219 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C220 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C221 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C222 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C223 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C224 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C225 |
CC3528-21 | MOT_TCAP_CC3528-21_2.1MM_150-75 | 10UF | 20% | IC | C226 |
CC3528-21 | MOT_TCAP_CC3528-21_2.1MM_150-75 | 10UF | 20% | IC | C227 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C228 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C229 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C230 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C231 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C232 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C233 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C234 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C235 |
CC3528-21 | MOT_TCAP_CC3528-21_2.1MM_150-_1 | 22UF | 10% | IC | C236 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C237 |
CC3528-21 | MOT_TCAP_CC3528-21_2.1MM_150-75 | 10UF | 20% | IC | C238 |
CC3528-21 | MOT_TCAP_CC3528-21_2.1MM_150-75 | 10UF | 20% | IC | C239 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C240 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C241 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C242 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C243 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C244 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C247 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C248 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C249 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C250 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C251 |
CC3216 | MOT_TCAP_CC3216_1.8MM_150-75258 | 33UF | 20% | IC | C252 |
CC3216 | MOT_TCAP_CC3216_1.8MM_150-75258 | 33UF | 20% | IC | C253 |
CC3216 | MOT_TCAP_CC3216_1.8MM_150-75258 | 33UF | 20% | IC | C254 |
CC3216 | MOT_TCAP_CC3216_1.8MM_150-75258 | 33UF | 20% | IC | C255 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C256 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C257 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C258 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C259 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C260 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C261 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C262 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C263 |
CC3216 | MOT_TCAP_CC3216_1.8MM_150-75258 | 33UF | 20% | IC | C264 |
CC3216 | MOT_TCAP_CC3216_1.8MM_150-75258 | 33UF | 20% | IC | C265 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C266 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C267 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C268 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C269 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C270 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C271 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C272 |
CC7343 | MOT_TCAP_CC7343_3.1MM_150-30016 | 100UF | 10% | IC | C273 |
CC7343 | MOT_TCAP_CC7343_3.1MM_150-30016 | 100UF | 10% | IC | C274 |
CC7343 | MOT_TCAP_CC7343_3.1MM_150-30016 | 100UF | 10% | IC | C275 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C276 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C277 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C278 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C279 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C280 |
CC7343 | MOT_TCAP_CC7343_3.1MM_150-30016 | 100UF | 10% | IC | C281 |
CC7343 | MOT_TCAP_CC7343_3.1MM_150-30016 | 100UF | 10% | IC | C282 |
CC7343 | MOT_TCAP_CC7343_3.1MM_150-30016 | 100UF | 10% | IC | C283 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C284 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C285 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C286 |
CC0603 | CAP_NP_CC0603_0.90MM_150-75009_ | 0.01UF | 10% | IC | C287 |
CC0603 | CAP_NP_CC0603_0.90MM_150-75009_ | 0.01UF | 10% | IC | C288 |
CC1210-32 | MOT_CAP_CC1210-32_3.17MM_150-75 | 4.7UF | 10% | IC | C289 |
CC1210-32 | MOT_CAP_CC1210-32_3.17MM_150-75 | 4.7UF | 10% | IC | C290 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C291 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C292 |
CC0805 | MOT_CAP_CC0805_1.4MM_150-75079 | 470PF | 5% | IC | C293 |
CC0805_OV | MOT_CAP_CC0805_OV_1.25MM_150-75 | 6.8nF | 5% | IC | C294 |
CC0805 | MOT_CAP_CC0805_1.4MM_150-75172 | 0.01UF | 5% | IC | C295 |
CC0805 | MOT_CAP_CC0805_1.4MM_150-75079 | 470PF | 5% | IC | C296 |
CC0603 | CAP_NP_CC0603_0.90MM_150-75009_ | 0.01UF | 10% | IC | C297 |
CC0805_OV | MOT_CAP_CC0805_OV_1.25MM_150-75 | 6.8nF | 5% | IC | C298 |
CC0805 | MOT_CAP_CC0805_1.4MM_150-75172 | 0.01UF | 5% | IC | C299 |
CC1210-32 | MOT_CAP_CC1210-32_3.17MM_150-75 | 4.7UF | 10% | IC | C300 |
CC0603 | CAP_NP_CC0603_0.90MM_150-75009_ | 0.01UF | 10% | IC | C301 |
CC0603 | CAP_NP_CC0603_0.90MM_150-75009_ | 0.01UF | 10% | IC | C302 |
CC0603 | CAP_NP_CC0603_0.90MM_150-75009_ | 0.01UF | 10% | IC | C303 |
CC0603 | CAP_NP_CC0603_0.90MM_150-75009_ | 0.01UF | 10% | IC | C304 |
CC1206 | MOT_CAP_CC1206_1.27MM_150-30029 | 1.0UF | 10% | IC | C305 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C306 |
CC7343A | MOT_TCAP_CC7343A_3.1MM_150-7512 | 47UF | 10% | IC | C307 |
CC0603 | CAP_NP_CC0603_0.90MM_150-75009_ | 0.01UF | 10% | IC | C308 |
CC0603 | CAP_NP_CC0603_0.90MM_150-75009_ | 0.01UF | 10% | IC | C309 |
CC0603 | CAP_NP_CC0603_0.90MM_150-75009_ | 0.01UF | 10% | IC | C310 |
CC0603 | CAP_NP_CC0603_0.90MM_150-75009_ | 0.01UF | 10% | IC | C311 |
CC0603 | CAP_NP_CC0603_0.90MM_150-75009_ | 0.01UF | 10% | IC | C312 |
CC0603 | CAP_NP_CC0603_0.90MM_150-75009_ | 0.01UF | 10% | IC | C313 |
CC0805 | MOT_CAP_CC0805_1.4MM_150-75079 | 470PF | 5% | IC | C314 |
CC0805 | MOT_CAP_CC0805_1.4MM_150-75079 | 470PF | 5% | IC | C315 |
CC0603 | CAP_NP_CC0603_0.90MM_150-75009_ | 0.01UF | 10% | IC | C316 |
CC0603 | CAP_NP_CC0603_0.90MM_150-75009_ | 0.01UF | 10% | IC | C317 |
CC0603 | CAP_NP_CC0603_0.90MM_150-75009_ | 0.01UF | 10% | IC | C318 |
CC0603 | CAP_NP_CC0603_0.90MM_150-75009_ | 0.01UF | 10% | IC | C319 |
CC0603 | CAP_NP_CC0603_0.90MM_150-75009_ | 0.01UF | 10% | IC | C320 |
CC0603 | CAP_NP_CC0603_0.90MM_150-75009_ | 0.01UF | 10% | IC | C321 |
CC0805 | MOT_CAP_CC0805_1.4MM_150-75079 | 470PF | 5% | IC | C322 |
CC0805 | MOT_CAP_CC0805_1.4MM_150-75079 | 470PF | 5% | IC | C323 |
CC0603 | CAP_NP_CC0603_0.90MM_150-75009_ | 0.01UF | 10% | IC | C324 |
CC0603 | CAP_NP_CC0603_0.90MM_150-75009_ | 0.01UF | 10% | IC | C325 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C326 |
CC0603 | CAP_NP_CC0603_0.90MM_150-75009_ | 0.01UF | 10% | IC | C327 |
CC0603 | CAP_NP_CC0603_0.90MM_150-75009_ | 0.01UF | 10% | IC | C328 |
CC0603 | CAP_NP_CC0603_0.90MM_150-75009_ | 0.01UF | 10% | IC | C329 |
CC0603 | CAP_NP_CC0603_0.90MM_150-75009_ | 0.01UF | 10% | IC | C330 |
CC0805 | MOT_CAP_CC0805_1.4MM_150-75079 | 470PF | 5% | IC | C331 |
CC0805 | MOT_CAP_CC0805_1.4MM_150-75079 | 470PF | 5% | IC | C332 |
CC0603 | CAP_NP_CC0603_0.90MM_150-75009_ | 0.01UF | 10% | IC | C333 |
CC0603 | CAP_NP_CC0603_0.90MM_150-75009_ | 0.01UF | 10% | IC | C334 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C335 |
CC0805 | MOT_CAP_CC0805_1.4MM_150-75079 | 470PF | 5% | IC | C356 |
CC3528-21 | MOT_TCAP_CC3528-21_2.1MM_150-75 | 10UF | 20% | IC | C406 |
CC3216 | MOT_TCAP_CC3216_1.8MM_150-75258 | 33UF | 20% | IC | C407 |
CC3216 | MOT_TCAP_CC3216_1.8MM_150-75258 | 33UF | 20% | IC | C408 |
CC7343 | MOT_TCAP_CC7343_3.1MM_150-30016 | 100UF | 10% | IC | C409 |
CC7343 | MOT_TCAP_CC7343_3.1MM_150-30016 | 100UF | 10% | IC | C410 |
CC3528-21 | MOT_TCAP_CC3528-21_2.1MM_150-_1 | 22UF | 10% | IC | C411 |
CC1206 | MOT_CAP_CC1206_1.27MM_150-30029 | 1.0UF | 10% | IC | C555 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C556 |
CC1206 | MOT_CAP_CC1206_1.27MM_150-30029 | 1.0UF | 10% | IC | C557 |
CC1206 | MOT_CAP_CC1206_1.27MM_150-30029 | 1.0UF | 10% | IC | C558 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C559 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C560 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C677 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C765 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C766 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C880 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C881 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C882 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C883 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C884 |
CC0603 | CAP_NP_CC0603_0.90MM_150-75009_ | 0.01UF | 10% | IC | C920 |
CC3528-21 | MOT_TCAP_CC3528-21_2.1MM_150-7 | 220UF | 10% | IC | C921 |
CC7343A | MOT_TCAP_CC7343A_3.1MM_150-7512 | 47UF | 10% | IC | C922 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C950 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C952 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C954 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C955 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C956 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C957 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C958 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C959 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C960 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C961 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C962 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C963 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C964 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C965 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C966 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C967 |
CC1206 | MOT_CAP_CC1206_1.27MM_150-30029 | 1.0UF | 10% | IC | C968 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C969 |
CC0603 | MOT_CAP_CC0603_0.90MM_150-75138 | 33PF | 5% | IC | C974 |
CC0603 | MOT_CAP_CC0603_0.90MM_150-75138 | 33PF | 5% | IC | C975 |
CC0603 | MOT_CAP_CC0603_0.86MM_150-7528 | 100PF | 5% | IC | C976 |
CC0603 | MOT_CAP_CC0603_0.86MM_150-7528 | 100PF | 5% | IC | C977 |
CC0603 | MOT_CAP_CC0603_0.86MM_150-7528 | 100PF | 5% | IC | C978 |
CC3528-21 | MOT_TCAP_CC3528-21_2.1MM_150-75 | 10UF | 20% | IC | C979 |
CC0603 | MOT_CAP_CC0603_0.86MM_150-7528 | 100PF | 5% | IC | C980 |
CC0805 | MOT_CAP_CC0805_1.6MM_150-75170_ | 1000PF | 5% | IC | C981 |
CC0805 | MOT_CAP_CC0805_1.6MM_150-75170_ | 1000PF | 5% | IC | C982 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C983 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C984 |
CC0805 | MOT_CAP_CC0805_1.6MM_150-75170_ | 1000PF | 5% | IC | C985 |
CC0603 | MOT_CAP_CC0603_0.86MM_150-7528 | 100PF | 5% | IC | C986 |
CC0603 | MOT_CAP_CC0603_0.86MM_150-7528 | 100PF | 5% | IC | C987 |
CC0805 | MOT_CAP_CC0805_1.6MM_150-75170_ | 1000PF | 5% | IC | C988 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C989 |
CC0805 | MOT_CAP_CC0805_1.6MM_150-75170_ | 1000PF | 5% | IC | C990 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C991 |
CC0805 | MOT_CAP_CC0805_1.6MM_150-75170_ | 1000PF | 5% | IC | C992 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C993 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C994 |
CC0805 | MOT_CAP_CC0805_1.6MM_150-75170_ | 1000PF | 5% | IC | C995 |
CC0805 | MOT_CAP_CC0805_1.6MM_150-75170_ | 1000PF | 5% | IC | C996 |
CC0603 | MOT_CAP_CC0603_0.86MM_150-7528 | 100PF | 5% | IC | C997 |
CC0603 | MOT_CAP_CC0603_0.86MM_150-7528 | 100PF | 5% | IC | C998 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C999 |
CC0805 | MOT_CAP_CC0805_1.6MM_150-75170_ | 1000PF | 5% | IC | C1000 |
CC0805 | MOT_CAP_CC0805_1.6MM_150-75170_ | 1000PF | 5% | IC | C1001 |
CC3528-21 | MOT_TCAP_CC3528-21_2.1MM_150-75 | 10UF | 20% | IC | C1002 |
CC0805 | MOT_CAP_CC0805_1.6MM_150-75170_ | 1000PF | 5% | IC | C1003 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C1004 |
CC0805 | MOT_CAP_CC0805_1.6MM_150-75170_ | 1000PF | 5% | IC | C1005 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C1006 |
CC0603 | MOT_CAP_CC0603_0.86MM_150-7528 | 100PF | 5% | IC | C1007 |
CC0805 | MOT_CAP_CC0805_1.6MM_150-75170_ | 1000PF | 5% | IC | C1008 |
CC0603 | MOT_CAP_CC0603_0.92MM_150-7522 | 0.1 UF | 10% | IC | C1009 |
CC0805_OV | MOT_CAP_CC0805_OV_0.95MM_150-7 | 15PF | 5% | IC | C1010 |
CC0805_OV | MOT_CAP_CC0805_OV_0.95MM_150-7 | 15PF | 5% | IC | C1011 |
CC3216 | MOT_TCAP_CC3216_1.8MM_150-75288 | 10UF | 10% | IC | C1012 |
CUT_TRACE | CUT_TRACE_RADIAL_CUT_TRACE_470- | 0 OHM | | IC | CT1 |
CUT_TRACE | CUT_TRACE_RADIAL_CUT_TRACE_470- | 0 OHM | | IC | CT2 |
CUT_TRACE | CUT_TRACE_RADIAL_CUT_TRACE_470- | 0 OHM | | IC | CT3 |
CUT_TRACE | CUT_TRACE_RADIAL_CUT_TRACE_470- | 0 OHM | | IC | CT4 |
CUT_TRACE | CUT_TRACE_RADIAL_CUT_TRACE_470- | 0 OHM | | IC | CT5 |
CUT_TRACE | CUT_TRACE_RADIAL_CUT_TRACE_470- | 0 OHM | | IC | CT6 |
CUT_TRACE | CUT_TRACE_RADIAL_CUT_TRACE_470- | 0 OHM | | IC | CT7 |
CUT_TRACE | CUT_TRACE_RADIAL_CUT_TRACE_470- | 0 OHM | | IC | CT8 |
CUT_TRACE | CUT_TRACE_RADIAL_CUT_TRACE_470- | 0 OHM | | IC | CT9 |
CUT_TRACE | CUT_TRACE_RADIAL_CUT_TRACE_470- | 0 OHM | | IC | CT10 |
CUT_TRACE | CUT_TRACE_RADIAL_CUT_TRACE_470- | 0 OHM | | IC | CT11 |
SOD-80 | DIODE_SOD-80_1.5MM_480-75257_R | RLS4148 | | IC | D1 |
SOD-80 | DIODE_SOD-80_1.5MM_480-75257_R | RLS4148 | | IC | D2 |
1206LD_1A2C | LED_1A2C_1206LD_1A2C_0.75MM_370 | LED RED | | IC | D3 |
1206LD_1A2C | LED_1A2C_1206LD_1A2C_0.75MM_370 | LED RED | | IC | D5 |
1206LD_1A2C | LED_1A2C_1206LD_1A2C_0.75MM_370 | LED RED | | IC | D9 |
1206LD_1A2C | LED_1A2C_1206LD_1A2C_0.75MM_370 | LED RED | | IC | D14 |
D_SMC | DIODE_ZENER21_D_SMC_2.56MM_480 | 1SMC5.OAT3 | | IC | D16 |
1206LD_1A2C | LED_1A2C_1206LD_1A2C_0.75MM_370 | LED RED | | IC | D17 |
DPAK | MBRD835LG_DPAK_2.38MM_480-30009 | MBRD835L | | IC | D21 |
DPAK | MBRD835LG_DPAK_2.38MM_480-30009 | MBRD835L | | IC | D22 |
LED1206_SMT | LED_LED1206_SMT_0.75MM_370-7506 | APT3216MGC | | IC | D23 |
LED1206_SMT | LED_LED1206_SMT_0.75MM_370-750 | APT3216SEC | | IC | D30 |
LED1206_SMT | LED_LED1206_SMT_0.75MM_370-750 | APT3216SEC | | IC | D31 |
LED1206_SMT | LED_LED1206_SMT_0.75MM_370-750 | APT3216SEC | | IC | D32 |
LED1206_SMT | LED_LED1206_SMT_0.75MM_370-750 | APT3216SEC | | IC | D33 |
LED1206_SMT | LED_LED1206_SMT_0.75MM_370-750 | APT3216SEC | | IC | D34 |
LED1206_SMT | LED_LED1206_SMT_0.75MM_370-750 | APT3216SEC | | IC | D35 |
LED1206_SMT | LED_LED1206_SMT_0.75MM_370-750 | APT3216SEC | | IC | D36 |
LED1206_SMT | LED_LED1206_SMT_0.75MM_370-750 | APT3216SEC | | IC | D37 |
LED1206_SMT | LED_LED1206_SMT_0.75MM_370-7506 | APT3216MGC | | IC | D956 |
LED1206_SMT | LED_LED1206_SMT_0.75MM_370-7506 | APT3216MGC | | IC | D957 |
LED1206_SMT | LED_LED1206_SMT_0.75MM_370-7506 | APT3216MGC | | IC | D958 |
FUSE_6X3 | FUSE_FUSE_6X3_2.69MM_510-75438_ | 5A | | IC | F1 |
FUSE_6X3 | FUSE_FUSE_6X3_2.69MM_510-75438_ | 5A | | IC | F2 |
JUMP2X2-6040 | HDR 2X2, 0.0025" IN, 0.1" CTR | HDR 2X2 | | IC | H4 |
HDR102 | HDR_1X2_M_HDR102_9.1MM_210-300 | HDR_1X2_M | | IC | H8 |
HDR103_A | CONN_HDR_3X1_HDR103_A_10.45MM_ | HDR_1X3_M | | IC | H9 |
HDR102 | HDR_1X2_M_HDR102_9.1MM_210-300 | HDR_1X2_M | | IC | H10 |
HDR102 | HDR_1X2_M_HDR102_9.1MM_210-300 | HDR_1X2_M | | IC | H11 |
HDR102 | HDR_1X2_M_HDR102_9.1MM_210-300 | HDR_1X2_M | | IC | H12 |
HDR102 | HDR_1X2_M_HDR102_9.1MM_210-300 | HDR_1X2_M | | IC | H13 |
HDR102 | HDR_1X2_M_HDR102_9.1MM_210-300 | HDR_1X2_M | | IC | H14 |
HDR102 | HDR_1X2_M_HDR102_9.1MM_210-300 | HDR_1X2_M | | IC | H15 |
HDR102 | HDR_1X2_M_HDR102_9.1MM_210-300 | HDR_1X2_M | | IC | H16 |
HDR205 | CONN_HDR_5X2_HDR205_330MIL_210- | HDR_2X5 | | IC | H20 |
HDR2X4 | CONN_HDR_4X2_HDR2X4_8.382MM_210 | HDR_2X4 | | IC | H21 |
HDR205 | CONN_HDR_5X2_HDR205_330MIL_210- | HDR_2X5 | | IC | H26 |
HDR103 | JUMPER3PIN_HDR103_9.5 MM_210-3 | HDR_1X3 | | IC | H36 |
HDR216 | CONN_HDR_16X2_HDR216_8.382MM_2 | HDR_2X16 | | IC | H900 |
CON_SMA | SMA_CON_SMA_9.652MM_210-75859_ | SMA | | IC | J10 |
CON_SMA | SMA_CON_SMA_9.652MM_210-75859_ | SMA | | IC | J11 |
CON_SMA | SMA_CON_SMA_9.652MM_210-75859_ | SMA | | IC | J12 |
CON_SMA | SMA_CON_SMA_9.652MM_210-75859_ | SMA | | IC | J13 |
60PIN_PCI | CON PCI 32BIT / 3.3VTH_60PIN_P | PCI 32BIT/3.3V | | IC | J14 |
60PIN_PCI | CON PCI 32BIT / 3.3VTH_60PIN_P | PCI 32BIT/3.3V | | IC | J15 |
60PIN_PCI | CON PCI 32BIT / 3.3VTH_60PIN_P | PCI 32BIT/3.3V | | IC | J16 |
60PIN_PCI | CON PCI 32BIT / 3.3VTH_60PIN_P | PCI 32BIT/3.3V | | IC | J17 |
CON_SMA | SMA_CON_SMA_9.652MM_210-75859_ | SMA | | IC | J18 |
HDR106_3P96 | CONN_HDR_6X1_HDR106_3P96_578MIL | 1x6 | | IC | J21 |
HDR213 | CONN_HDR_13X2_HDR213_8.38MM_21 | HDR_2X13 | | IC | J24 |
CON_20_ATX_PWR | ATX_PWR_CONN_CON_20_ATX_PWR_12. | HDR2X10 | | IC | J50 |
CON_28P_PROBE | P6860_6880_28PINS_CON_28P_PROBE | P6860/6880_28pins | | IC | J56 |
CON_28P_PROBE | P6860_6880_28PINS_CON_28P_PROBE | P6860/6880_28pins | | IC | J57 |
CON_28P_PROBE | P6860_6880_28PINS_CON_28P_PROBE | P6860/6880_28pins | | IC | J58 |
CON_28P_PROBE | P6860_6880_28PINS_CON_28P_PROBE | P6860/6880_28pins | | IC | J59 |
CON_28P_PROBE | P6860_6880_28PINS_CON_28P_PROBE | P6860/6880_28pins | | IC | J60 |
CON_28P_PROBE | P6860_6880_28PINS_CON_28P_PROBE | P6860/6880_28pins | | IC | J61 |
CON_28P_PROBE | P6860_6880_28PINS_CON_28P_PROBE | P6860/6880_28pins | | IC | J62 |
CON_28P_PROBE | P6860_6880_28PINS_CON_28P_PROBE | P6860/6880_28pins | | IC | J63 |
CON_28P_PROBE | P6860_6880_28PINS_CON_28P_PROBE | P6860/6880_28pins | | IC | J64 |
CON_28P_PROBE | P6860_6880_28PINS_CON_28P_PROBE | P6860/6880_28pins | | IC | J65 |
CON_28P_PROBE | P6860_6880_28PINS_CON_28P_PROBE | P6860/6880_28pins | | IC | J66 |
CON_28P_PROBE | P6860_6880_28PINS_CON_28P_PROBE | P6860/6880_28pins | | IC | J67 |
HDR102 | HDR_1X2_M_HDR102_9.1MM_210-300 | HDR_1X2_M | | IC | J906 |
CON_USB_RA | USB_B_RCPT_CON_USB_RA_11.50MM_2 | USB_TYPE_B | | IC | J907 |
HDR220 | CONN_HDR_20X2_HDR220_8.38MM_21 | HDR_2X20 | | IC | J908 |
CON_USB_MINIAB | USB_MINI_AB_RECEPTACLE | USB_MINI_AB_SKT | | IC | J909 |
HDR203 | CONN_HDR_3X2_HDR203_8.5MM_210- | HDR_2X3 | | IC | J910 |
HDR103 | CONN_HDR_3X1_HDR103_8.38MM_210 | HDR_1X3 | | IC | J911 |
HDR103 | CONN_HDR_3X1_HDR103_8.38MM_210 | HDR_1X3 | | IC | JP903 |
HDR103 | CONN_HDR_3X1_HDR103_8.38MM_210 | HDR_1X3 | | IC | JP904 |
HDR102 | HDR_1X2_M_HDR102_9.1MM_210-300 | HDR_1X2_M | | IC | JP906 |
HDR102 | HDR_1X2_M_HDR102_9.1MM_210-300 | HDR_1X2_M | | IC | JP907 |
HDR102 | HDR_1X2_M_HDR102_9.1MM_210-300 | HDR_1X2_M | | IC | JP908 |
HDR103 | CONN_HDR_3X1_HDR103_8.38MM_210 | HDR_1X3 | | IC | JP909 |
HDR103 | CONN_HDR_3X1_HDR103_8.38MM_210 | HDR_1X3 | | IC | JP910 |
HDR103 | CONN_HDR_3X1_HDR103_8.38MM_210 | HDR_1X3 | | IC | JP911 |
HDR103 | CONN_HDR_3X1_HDR103_8.38MM_210 | HDR_1X3 | | IC | JP912 |
JACK_PWR_RA | DC POWERJACK_JACK_PWR_RA_430MI | RAPC722 | | IC | JP917 |
HDR103 | CONN_HDR_3X1_HDR103_8.38MM_210 | HDR_1X3 | | IC | JP918 |
IND_0603 | IND_IND_0603_0.8MM_180-75495_10 | 100MHZ | | IC | L1 |
IND_0603 | IND_IND_0603_0.8MM_180-75495_10 | 100MHZ | | IC | L2 |
IND_0603 | IND_IND_0603_0.8MM_180-75495_10 | 100MHZ | | IC | L22 |
IND_7445510 | INDUCTOR_IND_7445510_2.92MM_18 | 10UH | | IC | L23 |
IND_7445510 | INDUCTOR_IND_7445510_2.92MM_18 | 10UH | | IC | L24 |
IND_74456047 | INDUCTOR_IND_74456047_5.3MM_180 | 4.7UH | | IC | L25 |
IND_74456047 | INDUCTOR_IND_74456047_5.3MM_180 | 4.7UH | | IC | L26 |
IND_0603 | IND_IND_0603_0.8MM_180-75495_10 | 100MHZ | | IC | L27 |
IND_0603 | IND_IND_0603_0.8MM_180-75495_10 | 100MHZ | | IC | L35 |
IND_0603 | IND_IND_0603_0.8MM_180-75495_10 | 100MHZ | | IC | L36 |
IND_0603 | IND_IND_0603_0.8MM_180-75495_10 | 100MHZ | | IC | L37 |
IND_1206A | BEAD_IND_1206A_1.1MM_180-30032_ | 600OHM | 25% | IC | L38 |
IND_1206A | BEAD_IND_1206A_1.1MM_180-30032_ | 600OHM | 25% | IC | L39 |
MTG400C156 | MOUNT_HOLE_MTG400C156_0MM_280-7 | MNT_HOLE | | IC | MH1 |
MTG400C156 | MOUNT_HOLE_MTG400C156_0MM_280-7 | MNT_HOLE | | IC | MH2 |
MTG400C156 | MOUNT_HOLE_MTG400C156_0MM_280-7 | MNT_HOLE | | IC | MH3 |
MTG400C156 | MOUNT_HOLE_MTG400C156_0MM_280-7 | MNT_HOLE | | IC | MH4 |
MTG400C156 | MOUNT_HOLE_MTG400C156_0MM_280-7 | MNT_HOLE | | IC | MH5 |
MTG400C156 | MOUNT_HOLE_MTG400C156_0MM_280-7 | MNT_HOLE | | IC | MH6 |
DUALDB-9MM | DSD9M_DUALDB-9MM_31.75MM_210-76 | DB9 | | IC | P1 |
CON_DB9M_VERT | DB9_M_CON_DB9M_VERT_11.2MM_210- | DB9_M | | IC | P3 |
USB_A | USB_TYPE_A_USB_A_7.01MM_210-300 | USB_TYPE_A | | IC | P4 |
CON_RJ45_2X1_MAG_LED | RJ45_MAG_2X1_LED_CON_RJ45_2X1_M | 0845-2R1T-E4 | | IC | P5 |
SOT23 | NPN_SOT23_1.11MM_480-75173_MMB | MMBT3904LT1G | | IC | Q1 |
SOT23 | NPN_SOT23_1.11MM_480-75173_MMB | MMBT3904LT1G | | IC | Q4 |
SOT23 | NPN_SOT23_1.11MM_480-75173_MMB | MMBT3904LT1G | | IC | Q5 |
RC0402_25 | MOT_RES_RC0402_25_0.45MM_470-76 | 56 OHM | 5% | IC | R1 |
RC0402_25 | MOT_RES_RC0402_25_0.45MM_470-76 | 56 OHM | 5% | IC | R2 |
RC0402_25 | MOT_RES_RC0402_25_0.45MM_470-76 | 56 OHM | 5% | IC | R3 |
RC0402_25 | MOT_RES_RC0402_25_0.45MM_470-76 | 56 OHM | 5% | IC | R4 |
RC0402_25 | MOT_RES_RC0402_25_0.45MM_470-76 | 56 OHM | 5% | IC | R5 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75398 | 22 OHM | +/-5% | IC | R35 |
RC0402_25 | RES_RC0402_25_470-76037_1.0K | 1.0K | | IC | R57 |
RC0402_25 | RES_RC0402_25_470-76037_1.0K | 1.0K | | IC | R58 |
RC1206 | MOT_RES_RC1206_0.75MM_470-7554 | 100 OHM | +/-5% | IC | R66 |
RC1206 | MOT_RES_RC1206_0.75MM_470-7554 | 100 OHM | +/-5% | IC | R67 |
RC1206 | MOT_RES_RC1206_0.75MM_470-7554 | 100 OHM | +/-5% | IC | R68 |
RC1206 | MOT_RES_RC1206_0.75MM_470-7554 | 100 OHM | +/-5% | IC | R69 |
RC1206 | MOT_RES_RC1206_0.75MM_470-7554 | 100 OHM | +/-5% | IC | R70 |
RC1206 | MOT_RES_RC1206_0.75MM_470-7554 | 100 OHM | +/-5% | IC | R71 |
RC2512 | MOT_RES_RC2512_0.89MM_470-76704 | .022 OHM | 1% | IC | R72 |
RC2512 | MOT_RES_RC2512_0.89MM_470-76704 | .022 OHM | 1% | IC | R73 |
RC0805 | MOT_RES_RC0805_0.7MM_470-75663_ | 5.1K | 5% | IC | R115 |
RC0603 | MOT_RES_RC0603_0.55MM_470-7540 | 0 OHM | | IC | R116 |
RC0603 | MOT_RES_RC0603_0.55MM_470-7540 | 0 OHM | | IC | R117 |
RC0603 | MOT_RES_RC0603_0.55MM_470-7540 | 0 OHM | | IC | R118 |
RC0603 | MOT_RES_RC0603_0.55MM_470-7540 | 0 OHM | | IC | R119 |
RC0603 | MOT_RES_RC0603_0.55MM_470-7540 | 0 OHM | | IC | R122 |
RC0805 | MOT_RES_RC0805_0.7MM_470-75663_ | 5.1K | 5% | IC | R123 |
RC0805 | MOT_RES_RC0805_0.7MM_470-75663_ | 5.1K | 5% | IC | R124 |
RC0603 | MOT_RES_RC0603_0.55MM_470-7540 | 0 OHM | | IC | R125 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75398 | 22 OHM | +/-5% | IC | R126 |
RC0603 | MOT_RES_RC0603_0.55MM_470-7540 | 0 OHM | | IC | R127 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75398 | 22 OHM | +/-5% | IC | R128 |
RC0603 | MOT_RES_RC0603_0.55MM_470-7540 | 0 OHM | | IC | R129 |
RC0603 | MOT_RES_RC0603_0.55MM_470-7540 | 0 OHM | | IC | R130 |
RC0805 | MOT_RES_RC0805_0.7MM_470-75663_ | 5.1K | 5% | IC | R131 |
RC0603 | MOT_RES_RC0603_0.55MM_470-7541 | 10K | | IC | R133 |
RC0603 | MOT_RES_RC0603_0.55MM_470-7541 | 10K | | IC | R134 |
RC0603 | MOT_RES_RC0603_0.55MM_470-7541 | 10K | | IC | R135 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75846 | 1.0M | 5% | IC | R136 |
RC0603 | MOT_RES_RC0603_0.55MM_470-76703 | 18M | 5% | IC | R137 |
RC0603 | MOT_RES_RC0603_0.55MM_470-7542 | 10.0 OHM | +/-1% | IC | R138 |
RC0603 | MOT_RES_RC0603_0.55MM_470-7542 | 10.0 OHM | +/-1% | IC | R139 |
RC0603 | MOT_RES_RC0603_0.55MM_470-7542 | 10.0 OHM | +/-1% | IC | R140 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75377 | 75 OHM | 5% | IC | R141 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75403 | 51 OHM | 5% | IC | R142 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75403 | 51 OHM | 5% | IC | R143 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75403 | 51 OHM | 5% | IC | R144 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75403 | 51 OHM | 5% | IC | R145 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75377 | 75 OHM | 5% | IC | R146 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75377 | 75 OHM | 5% | IC | R147 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75398 | 22 OHM | +/-5% | IC | R148 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75403 | 51 OHM | 5% | IC | R149 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75398 | 22 OHM | +/-5% | IC | R150 |
RC0603 | MOT_RES_RC0603_0.55MM_470-7540 | 0 OHM | | IC | R151 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75377 | 75 OHM | 5% | IC | R152 |
RC0603 | MOT_RES_RC0603_0.55MM_470-7541 | 10K | | IC | R153 |
RC0805 | MOT_RES_RC0805_0.7MM_470-75663_ | 5.1K | 5% | IC | R154 |
RC0603 | MOT_RES_RC0603_0.55MM_470-7551 | 1.50K | +/-1% | IC | R157 |
RC0805 | MOT_RES_RC0805_0.7MM_470-75933_ | 49.9K | 1% | IC | R158 |
RC0603 | MOT_RES_RC0603_0.5MM_470-76702_ | 39K | 1% | IC | R159 |
RC0603 | MOT_RES_RC0603_0.5MM_470-76701_ | 300 OHM | 1% | IC | R160 |
RC0603 | MOT_RES_RC0603_0.5MM_470-30141_ | 330K | +/-1% | IC | R161 |
RC0603 | MOT_RES_RC0603_0.5MM_470-76700_ | 28K | 1% | IC | R162 |
RC0603 | MOT_RES_RC0603_0.45MM_470-30037 | 31.6K | +/-1% | IC | R163 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75422 | 10.0K | | IC | R164 |
RC0603 | MOT_RES_RC0603_0.55MM_470-7554 | 5.11K | +/-1% | IC | R165 |
RC0603 | MOT_RES_RC0603_0.5MM_470-30163_ | 5.1K | +/-1% | IC | R166 |
RC0603 | MOT_RES_RC0603_0.55MM_470-7554 | 5.11K | +/-1% | IC | R167 |
RC0805 | MOT_RES_RC0805_0.7MM_470-75933_ | 49.9K | 1% | IC | R172 |
RC0603 | MOT_RES_RC0603_0.5MM_470-76702_ | 39K | 1% | IC | R173 |
RC0603 | MOT_RES_RC0603_0.5MM_470-76701_ | 300 OHM | 1% | IC | R174 |
RC0603 | MOT_RES_RC0603_0.45MM_470-30035 | 40.2K | +/-1% | IC | R175 |
RC0603 | MOT_RES_RC0603_0.5MM_470-30141_ | 330K | +/-1% | IC | R176 |
RC0603 | MOT_RES_RC0603_0.55MM_470-7551 | 1.50K | +/-1% | IC | R177 |
RC0603 | MOT_RES_RC0603_0.5MM_470-30163_ | 5.1K | +/-1% | IC | R180 |
RC0603 | MOT_RES_RC0603_0.55MM_470-7554 | 5.11K | +/-1% | IC | R181 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75422 | 10.0K | | IC | R182 |
RC0603 | MOT_RES_RC0603_0.5MM_470-30129 | 20.0 K | +/-1% | IC | R183 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75_1 | 1.0K | 1% | IC | R184 |
RC0402_25 | RES_RC0402_25_470-76037_1.0K | 1.0K | | IC | R188 |
RC0402_25 | RES_RC0402_25_470-76037_1.0K | 1.0K | | IC | R190 |
RC0402_25 | RES_RC0402_25_470-76037_1.0K | 1.0K | | IC | R192 |
RC0402_25 | RES_RC0402_25_470-76037_1.0K | 1.0K | | IC | R193 |
RC0402_25 | MOT_RES_RC0402_25_0.45MM_470-75 | 220 OHM | +/-5% | IC | R194 |
RC0402_25 | MOT_RES_RC0402_25_0.45MM_470-75 | 220 OHM | +/-5% | IC | R201 |
RC0402_25 | MOT_RES_RC0402_25_0.45MM_470-75 | 220 OHM | +/-5% | IC | R202 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75422 | 10.0K | | IC | R203 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75422 | 10.0K | | IC | R204 |
RC0402_25 | RES_RC0402_25_470-76037_1.0K | 1.0K | | IC | R206 |
RC0402_25 | RES_RC0402_25_470-76037_1.0K | 1.0K | | IC | R207 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75422 | 10.0K | | IC | R208 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75422 | 10.0K | | IC | R209 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75422 | 10.0K | | IC | R210 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75422 | 10.0K | | IC | R211 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75422 | 10.0K | | IC | R212 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75422 | 10.0K | | IC | R213 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75422 | 10.0K | | IC | R230 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75422 | 10.0K | | IC | R231 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75398 | 22 OHM | +/-5% | IC | R301 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75398 | 22 OHM | +/-5% | IC | R302 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75398 | 22 OHM | +/-5% | IC | R303 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75398 | 22 OHM | +/-5% | IC | R304 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75398 | 22 OHM | +/-5% | IC | R305 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75398 | 22 OHM | +/-5% | IC | R306 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75398 | 22 OHM | +/-5% | IC | R307 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75398 | 22 OHM | +/-5% | IC | R309 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75398 | 22 OHM | +/-5% | IC | R310 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75398 | 22 OHM | +/-5% | IC | R311 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75398 | 22 OHM | +/-5% | IC | R312 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75398 | 22 OHM | +/-5% | IC | R313 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75398 | 22 OHM | +/-5% | IC | R314 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75398 | 22 OHM | +/-5% | IC | R315 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75398 | 22 OHM | +/-5% | IC | R316 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75398 | 22 OHM | +/-5% | IC | R317 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75398 | 22 OHM | +/-5% | IC | R318 |
RC0402_25 | MOT_RES_RC0402_25_0.45MM_470-75 | 220 OHM | +/-5% | IC | R444 |
RC0402_25 | MOT_RES_RC0402_25_0.45MM_470-75 | 220 OHM | +/-5% | IC | R445 |
RC0402_25 | MOT_RES_RC0402_25_0.45MM_470-75 | 220 OHM | +/-5% | IC | R446 |
RC0805 | MOT_RES_RC0805_0.7MM_470-75663_ | 5.1K | 5% | IC | R450 |
RC0805 | MOT_RES_RC0805_0.7MM_470-75663_ | 5.1K | 5% | IC | R451 |
RC0805 | MOT_RES_RC0805_0.7MM_470-75663_ | 5.1K | 5% | IC | R452 |
RC0402_25 | MOT_RES_RC0402_25_0.41MM_470-75 | 4.7K | +/-5% | IC | R555 |
RC0402_25 | MOT_RES_RC0402_25_0.41MM_470-75 | 4.7K | +/-5% | IC | R556 |
RC0402_25 | MOT_RES_RC0402_25_0.41MM_470-75 | 4.7K | +/-5% | IC | R557 |
RC0402_25 | MOT_RES_RC0402_25_0.41MM_470-75 | 4.7K | +/-5% | IC | R558 |
RC0402_25 | MOT_RES_RC0402_25_0.45MM_470-75 | 220 OHM | +/-5% | IC | R587 |
RC0603 | MOT_RES_RC0603_0.55MM_470-7541 | 10K | | IC | R655 |
RC0603 | MOT_RES_RC0603_0.55MM_470-7540 | 0 OHM | | IC | R656 |
RC0603 | MOT_RES_RC0603_0.55MM_470-7540 | 0 OHM | | IC | R657 |
RC1206 | RES_RC1206_470-75924_0OHM | 0 OHM | | IC | R658 |
RC0603 | MOT_RES_RC0603_0.55MM_470-7540 | 0 OHM | | IC | R659 |
RC0805 | MOT_RES_RC0805_0.50MM_470-75064 | 15.0K | +/-1% | IC | R660 |
RC0402_25 | MOT_RES_RC0402_25_0.41MM_470-75 | 4.7K | +/-5% | IC | R661 |
RC0402_25 | MOT_RES_RC0402_25_0.41MM_470-75 | 4.7K | +/-5% | IC | R662 |
RC1206 | RES_RC1206_470-75924_0OHM | 0 OHM | | IC | R664 |
RC1206 | RES_RC1206_470-75924_0OHM | 0 OHM | | IC | R665 |
RC0603 | MOT_RES_RC0603_0.55MM_470-7540 | 0 OHM | | IC | R673 |
RC0603 | MOT_RES_RC0603_0.55MM_470-7540 | 0 OHM | | IC | R674 |
RC0603 | MOT_RES_RC0603_0.55MM_470-7540 | 0 OHM | | IC | R675 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75_2 | 100 OHM | 5% | IC | R687 |
RC0603 | MOT_RES_RC0603_0.55MM_470-7541 | 10K | | IC | R735 |
RC0603 | MOT_RES_RC0603__470-75848_33OH | 33 OHM | | IC | R736 |
RC0603 | MOT_RES_RC0603__470-75848_33OH | 33 OHM | | IC | R737 |
RC0603 | MOT_RES_RC0603_.5MM_470-75513_ | 12.0K | 1% | IC | R738 |
RC0603 | MOT_RES_RC0603_0.55MM_470-7540 | 0 OHM | | IC | R739 |
RC0603 | MOT_RES_RC0603__470-75848_33OH | 33 OHM | | IC | R740 |
RC0603 | MOT_RES_RC0603__470-75848_33OH | 33 OHM | | IC | R741 |
RC0603 | MOT_RES_RC0603__470-75848_33OH | 33 OHM | | IC | R742 |
RC0603 | MOT_RES_RC0603__470-75848_33OH | 33 OHM | | IC | R743 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75432 | 49.9 OHM | +/-1% | IC | R765 |
RC0402_25 | MOT_RES_RC0402_25_0.41MM_470-75 | 4.7K | +/-5% | IC | R808 |
RC0402_25 | MOT_RES_RC0402_25_0.41MM_470-75 | 4.7K | +/-5% | IC | R809 |
RC0402_25 | MOT_RES_RC0402_25_0.41MM_470-75 | 4.7K | +/-5% | IC | R810 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75422 | 10.0K | | IC | R900 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75422 | 10.0K | | IC | R901 |
RC0402_25 | MOT_RES_RC0402_25_0.45MM_470-75 | 220 OHM | +/-5% | IC | R903 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75422 | 10.0K | | IC | R904 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75422 | 10.0K | | IC | R905 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75422 | 10.0K | | IC | R906 |
RC0402_25 | MOT_RES_RC0402_25_0.45MM_470-75 | 220 OHM | +/-5% | IC | R907 |
RC0402_25 | MOT_RES_RC0402_25_0.41MM_470-75 | 4.7K | +/-5% | IC | R922 |
RC0402_25 | MOT_RES_RC0402_25_0.41MM_470-75 | 4.7K | +/-5% | IC | R944 |
RC0402_25 | MOT_RES_RC0402_25_0.41MM_470-75 | 4.7K | +/-5% | IC | R945 |
RC0402_25 | MOT_RES_RC0402_25_0.41MM_470-75 | 4.7K | +/-5% | IC | R946 |
RC0402_25 | MOT_RES_RC0402_25_0.41MM_470-75 | 4.7K | +/-5% | IC | R947 |
RC0402_25 | MOT_RES_RC0402_25_0.41MM_470-75 | 4.7K | +/-5% | IC | R948 |
RC0603 | MOT_RES_RC0603_0.5MM_470-76698_ | 4.87K | 1% | IC | R949 |
RC0402_25 | MOT_RES_RC0402_25_0.45MM_470-75 | 220 OHM | +/-5% | IC | R950 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75432 | 49.9 OHM | +/-1% | IC | R951 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75432 | 49.9 OHM | +/-1% | IC | R952 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75432 | 49.9 OHM | +/-1% | IC | R953 |
RC0402_25 | MOT_RES_RC0402_25_0.45MM_470-75 | 220 OHM | +/-5% | IC | R954 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75432 | 49.9 OHM | +/-1% | IC | R955 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75432 | 49.9 OHM | +/-1% | IC | R956 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75432 | 49.9 OHM | +/-1% | IC | R957 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75432 | 49.9 OHM | +/-1% | IC | R958 |
RC0402_25 | MOT_RES_RC0402_25_0.45MM_470-75 | 220 OHM | +/-5% | IC | R959 |
RC0402_25 | MOT_RES_RC0402_25_0.45MM_470-75 | 220 OHM | +/-5% | IC | R964 |
RC0402_25 | MOT_RES_RC0402_25_0.45MM_470-75 | 220 OHM | +/-5% | IC | R965 |
RC0402_25 | MOT_RES_RC0402_25_0.45MM_470-75 | 220 OHM | +/-5% | IC | R967 |
RC0402_25 | MOT_RES_RC0402_25_0.45MM_470-75 | 220 OHM | +/-5% | IC | R968 |
RC0603 | MOT_RES_RC0603_0.55MM_470-75377 | 75 OHM | 5% | IC | R969 |
RC0402_25 | MOT_RES_RC0402_25_0.41MM_470-75 | 4.7K | +/-5% | IC | R970 |
RC0402_25 | MOT_RES_RC0402_25_0.41MM_470-75 | 4.7K | +/-5% | IC | R971 |
RC0402_25 | MOT_RES_RC0402_25_0.45MM_470-75 | 220 OHM | +/-5% | IC | R972 |
RC0402_25 | MOT_RES_RC0402_25_0.41MM_470-75 | 4.7K | +/-5% | IC | R976 |
RC0402_25 | MOT_RES_RC0402_25_0.41MM_470-75 | 4.7K | +/-5% | IC | R977 |
RC0402_25 | MOT_RES_RC0402_25_0.41MM_470-75 | 4.7K | +/-5% | IC | R978 |
RC0603 | MOT_RES_RC0603_0.55MM_470-7541 | 10K | | IC | R979 |
RC0603 | MOT_RES_RC0603_0.55MM_470-7541 | 10K | | IC | R1004 |
RC0603 | MOT_RES_RC0603_0.55MM_470-7541 | 10K | | IC | R1005 |
RC0402_25 | MOT_RES_RC0402_25_0.45MM_470-75 | 220 OHM | +/-5% | IC | R9080 |
RC0603 | RES_RC0603_470-30153_15K | 15K | | IC | R9081 |
RC0603 | RES_RC0603_470-30153_15K | 15K | | IC | R9082 |
RC0603 | RES_RC0603_470-75398_22OHM | 22 OHM | | IC | R9083 |
RC0603 | RES_RC0603_470-75411_100OHM | 100 OHM | | IC | R9084 |
CRA06-8 | RESISTOR_DIP_4_A-D_CRA06-8_0.5 | 22OHM | +/-5% | IC | RN2 |
CRA06-8 | RESISTOR_DIP_4_A-D_CRA06-8_0.5 | 22OHM | +/-5% | IC | RN3 |
CRA06-8 | RESISTOR_DIP_4_A-D_CRA06-8_0.5 | 22OHM | +/-5% | IC | RN4 |
CRA06-8 | RESISTOR_DIP_4_A-D_CRA06-8_0.5 | 22OHM | +/-5% | IC | RN5 |
CRA06-8 | RESISTOR_DIP_4_A-D_CRA06-8_0.5 | 22OHM | +/-5% | IC | RN6 |
CRA06-8 | RESISTOR_DIP_4_A-D_CRA06-8_0.5 | 22OHM | +/-5% | IC | RN7 |
CRA06-8 | RESISTOR_DIP_4_A-D_CRA06-8_0.5 | 22OHM | +/-5% | IC | RN8 |
CRA06-8 | RESISTOR_DIP_4_A-D_CRA06-8_0.5 | 22OHM | +/-5% | IC | RN9 |
CRA06-8 | RESISTOR_DIP_4_A-D_CRA06-8_0.5 | 22OHM | +/-5% | IC | RN10 |
CRA06-8 | RESISTOR_DIP_4_A-D_CRA06-8_0.5 | 22OHM | +/-5% | IC | RN11 |
CRA06-8 | RESISTOR_DIP_4_A-D_CRA06-8_0.5 | 22OHM | +/-5% | IC | RN12 |
CRA06-8 | RESISTOR_DIP_4_A-D_CRA06-8_0.5 | 22OHM | +/-5% | IC | RN13 |
CRA06-8 | RESISTOR_DIP_4_A-D_CRA06-8_0.5 | 22OHM | +/-5% | IC | RN14 |
CRA06-8 | RESISTOR_DIP_4_A-D_CRA06-8_0.5 | 22OHM | +/-5% | IC | RN15 |
RNA4A8E | RN_EXBE_RNA4A8E_0.65MM_470-7673 | 4.7K | 5% | IC | RN16 |
RNA4A8E | RN_EXBE_RNA4A8E_0.65MM_470-7673 | 4.7K | 5% | IC | RN17 |
CRA06-8 | RESISTOR_DIP_4_A-D_CRA06-8_0.5 | 22OHM | +/-5% | IC | RN57 |
CRA06-8 | RESISTOR_DIP_4_A-D_CRA06-8_0.5 | 22OHM | +/-5% | IC | RN58 |
CRA06-8 | RESISTOR_DIP_4_A-D_CRA06-8_0.5 | 22OHM | +/-5% | IC | RN59 |
CRA06-8 | RESISTOR_DIP_4_A-D_CRA06-8_0.5 | 22OHM | +/-5% | IC | RN90 |
CRA06-8 | RESISTOR_DIP_4_A-D_CRA06-8_0.5 | 22OHM | +/-5% | IC | RN91 |
CRA06-8 | RESISTOR_DIP_4_A-D_CRA06-8_0.5 | 22OHM | +/-5% | IC | RN92 |
CRA06-8 | RESISTOR_DIP_4_A-D_CRA06-8_0.5 | 22OHM | +/-5% | IC | RN93 |
CRA06-8 | RESISTOR_DIP_4_A-D_CRA06-8_0.5 | 22OHM | +/-5% | IC | RN94 |
CRA06-8 | RESISTOR_DIP_4_A-D_CRA06-8_0.5 | 22OHM | +/-5% | IC | RN95 |
CRA06-8 | RESISTOR_DIP_4_A-D_CRA06-8_0.5 | 22OHM | +/-5% | IC | RN96 |
CRA06-8 | RESISTOR_DIP_4_A-D_CRA06-8_0.5 | 22OHM | +/-5% | IC | RN97 |
CRA06-8 | RESISTOR_DIP_4_A-D_CRA06-8_0.5 | 22OHM | +/-5% | IC | RN98 |
CRA06-8 | RESISTOR_DIP_4_A-D_CRA06-8_0.5 | 22OHM | +/-5% | IC | RN99 |
CRA06-8 | RESISTOR_DIP_4_A-D_CRA06-8_0.5 | 22OHM | +/-5% | IC | RN100 |
RNET_4_8 | RES_ISO4_SINGLE_RNET_4_8_0.7MM_ | 51 OHM | 5% | IC | RN101 |
RNET_4_8 | RES_ISO4_SINGLE_RNET_4_8_0.7MM_ | 51 OHM | 5% | IC | RN102 |
RNET_4_8 | RES_ISO4_SINGLE_RNET_4_8_0.7MM_ | 51 OHM | 5% | IC | RN103 |
RNET_4_8 | RES_ISO4_SINGLE_RNET_4_8_0.7MM_ | 51 OHM | 5% | IC | RN104 |
RNET_4_8 | RES_ISO4_SINGLE_RNET_4_8_0.7MM_ | 51 OHM | 5% | IC | RN105 |
RNET_4_8 | RES_ISO4_SINGLE_RNET_4_8_0.7MM_ | 51 OHM | 5% | IC | RN106 |
RNET_4_8 | RES_ISO4_SINGLE_RNET_4_8_0.7MM_ | 51 OHM | 5% | IC | RN107 |
RNET_4_8 | RES_ISO4_SINGLE_RNET_4_8_0.7MM_ | 51 OHM | 5% | IC | RN108 |
RNET_4_8 | RES_ISO4_SINGLE_RNET_4_8_0.7MM_ | 51 OHM | 5% | IC | RN109 |
RNET_4_8 | RES_ISO4_SINGLE_RNET_4_8_0.7MM_ | 51 OHM | 5% | IC | RN110 |
RNET_4_8 | RES_ISO4_SINGLE_RNET_4_8_0.7MM_ | 51 OHM | 5% | IC | RN111 |
RNA4A8E | RN_EXBE_RNA4A8E_0.65MM_470-7673 | 4.7K | 5% | IC | RN114 |
RNA4A8E | RN_EXBE_RNA4A8E_0.65MM_470-7674 | 10K | 5% | IC | RP3 |
RNA4A8E | RN_EXBE_RNA4A8E_0.65MM_470-7674 | 10K | 5% | IC | RP4 |
RNA4A8E | RN_EXBE_RNA4A8E_0.65MM_470-7674 | 10K | 5% | IC | RP7 |
RNA4A8E | RN_EXBE_RNA4A8E_0.65MM_470-7674 | 10K | 5% | IC | RP9 |
RNA4A8E | RN_EXBE_RNA4A8E_0.65MM_470-7674 | 10K | 5% | IC | RP10 |
RNA4A8E | RN_EXBE_RNA4A8E_0.65MM_470-7673 | 4.7K | 5% | IC | RP16 |
RNA4A8E | RN_EXBE_RNA4A8E_0.65MM_470-7673 | 4.7K | 5% | IC | RP17 |
RNA4A8E | RN_EXBE_RNA4A8E_0.65MM_470-7673 | 4.7K | 5% | IC | RP18 |
RNA4A8E | RN_EXBE_RNA4A8E_0.65MM_470-7673 | 4.7K | 5% | IC | RP19 |
RNA4A8E | RN_EXBE_RNA4A8E_0.65MM_470-7673 | 4.7K | 5% | IC | RP56 |
RNA4A8E | RN_EXBE_RNA4A8E_0.65MM_470-7673 | 4.7K | 5% | IC | RP78 |
RNET_4_8 | RES_ISO4_SINGLE_RNET_4_8_0.7M_1 | 470OHM | 5% | IC | RP93 |
RNET_4_8 | RES_ISO4_SINGLE_RNET_4_8_0.7M_1 | 470OHM | 5% | IC | RP94 |
RNET_4_8 | RES_ISO4_SINGLE_RNET_4_8_0.7M_1 | 470OHM | 5% | IC | RP95 |
RNET_4_8 | RES_ISO4_SINGLE_RNET_4_8_0.7M_1 | 470OHM | 5% | IC | RP96 |
RNA4A8E | RN_EXBE_RNA4A8E_0.65MM_470-7673 | 4.7K | 5% | IC | RP97 |
SW_DIP16_RCK_TH | SW_DIP_8_SW_DIP16_RCK_TH_7.5MM_ | 78RB08ST | | IC | SW1 |
SW4_PB_ESW_SM_P177 | SW_PB_ESW_SW4_PB_ESW_SM_P177_5M | TL3301AF160QG | | IC | SW2 |
SW_DIP16_RCK_TH | SW_DIP_8_SW_DIP16_RCK_TH_7.5MM_ | 78RB08ST | | IC | SW3 |
SW4_PB_ESW_SM_P177 | SW_PB_ESW_SW4_PB_ESW_SM_P177_5M | TL3301AF160QG | | IC | SW4 |
SW_DIP8_TH_GRH | SW_DIP-4_SM_SW_DIP8_TH_GRH_8MM_ | SW_DIP-4_SM | | IC | SW5 |
SW4_PB_ESW_SM_P177 | SW_PB_ESW_SW4_PB_ESW_SM_P177_5M | TL3301AF160QG | | IC | SW6 |
SW4_PB_ESW_SM_P177 | SW_PB_ESW_SW4_PB_ESW_SM_P177_5M | TL3301AF160QG | | IC | SW7 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T1 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T2 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T3 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T4 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T5 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T6 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T7 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T8 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T9 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T10 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T11 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T12 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T13 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T14 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T15 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T16 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T17 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T18 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T19 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T20 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T21 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T22 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T23 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T24 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T25 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T26 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T27 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T28 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T29 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T30 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T31 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T32 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T33 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T34 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T35 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T36 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T37 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T38 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T39 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T40 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T41 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T42 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T43 |
C018-008TENTED | T_JUNCTION_C018-008TENTED_0.0M | T_JUNCTION | | IC | T44 |
TEST_PIN_TP107 | TESTLOOP_TEST_PIN_TP107_2.286MM | TESTLOOP | | IC | TP1 |
TEST_PIN_TP107 | TESTLOOP_TEST_PIN_TP107_2.286MM | TESTLOOP | | IC | TP2 |
TEST_PIN_TP107 | TESTLOOP_TEST_PIN_TP107_2.286MM | TESTLOOP | | IC | TP3 |
TEST_PIN_TP107 | TESTLOOP_TEST_PIN_TP107_2.286MM | TESTLOOP | | IC | TP4 |
TEST_PIN_TP107 | TESTLOOP_TEST_PIN_TP107_2.286MM | TESTLOOP | | IC | TP5 |
TEST_PIN_TP107 | TESTLOOP_TEST_PIN_TP107_2.286MM | TESTLOOP | | IC | TP6 |
TEST_PIN_TP107 | TESTLOOP_TEST_PIN_TP107_2.286MM | TESTLOOP | | IC | TP7 |
SKT_1_34X34 | MCF5445_SKT_1_34X34_6.6MM_750-7 | SKT360 | | IC | U1 |
TSSOP16 | CY2309ZXC-1H_TSSOP16_1.1MM_312- | CY2309ZXC-1H | | IC | U2 |
TSSOP16 | CY2309ZXC-1H_TSSOP16_1.1MM_312- | CY2309ZXC-1H | | IC | U3 |
TSSOP16 | CY22393_TSSOP16_1.1MM_312-77098 | CY22393 | | IC | U8 |
TSOP32 | AT49BV040_TSOP32_1.2MM_334-7550 | AT49BV040/LCC | | IC | U12 |
TQFP144 | XC95144XL-TQ100_TQFP144_1.6MM_3 | XC95144XL-7TQG144C | | IC | U15 |
DPAK_CASE_369C-01 | NTD20N03L27_DPAK_CASE_369C-01_2 | NTD20N03L27T4G | | IC | U21 |
DPAK_CASE_369C-01 | NTD20N03L27_DPAK_CASE_369C-01_2 | NTD20N03L27T4G | | IC | U22 |
SO32_W_CASE1324-02 | MC34702_SO32_W_CASE1324-02_2.65 | MC34702 | | IC | U24 |
TVSOP56 | ATA BUSBUFFER_TVSOP56_1.2MM_31 | SN74CBTD16211 | | IC | U25 |
HDR220_SHR_TH | ATACONNECTOR_HDR220_SHR_TH_26. | ATA CONNECTOR | | IC | U26 |
LED_DUAL_7SEG | NAR263-C_LED_DUAL_7SEG_8MM_370- | 30mA | | IC | U28 |
SO32_W_CASE1324-02 | MC34702_SO32_W_CASE1324-02_2.65 | MC34702 | | IC | U100 |
PSOP8_1P27 | LP2997_PSOP8_1P27_1.68MM_315-75 | LP2997MR NOPB | | IC | U900 |
TQFP80_5MM | DP83849_TQFP80_5MM_1.2MM_312-75 | DP83849 | | IC | U901 |
TSSOP20 | 74LV541_TSSOP20_1.2MM_312-75962 | 74LV541/SO | | IC | U902 |
TSOP56 | JS28F128J3D-75_TSOP56_1.2MM_33 | 28F128J3D | | IC | U903 |
SO16W | M25P16-SO16_SO16W_2.65MM_334-75 | M25P16-SO16 | | IC | U905 |
SO8_W | M25P40_SO8_W_2.03MM_334-75537_M | M25P16-VMW6G | | IC | U906 |
SSOP16 | MAX3232_SSOP16_2MM_312-75933_MA | MAX3232 | | IC | U907 |
SSOP16 | MAX3232_SSOP16_2MM_312-75933_MA | MAX3232 | | IC | U908 |
QFN28_5X5MM_3P3 | CP2102_QFN28_5X5MM_3P3_1MM_312- | CP2102 | | IC | U909 |
BGA60_0P8MM | MT47H64M8_BGA60_0P8MM_1.2MM_334 | MT47H64M8 | | IC | U911 |
BGA60_0P8MM | MT47H64M8_BGA60_0P8MM_1.2MM_334 | MT47H64M8 | | IC | U912 |
BGA60_0P8MM | MT47H64M8_BGA60_0P8MM_1.2MM_334 | MT47H64M8 | | IC | U913 |
BGA60_0P8MM | MT47H64M8_BGA60_0P8MM_1.2MM_334 | MT47H64M8 | | IC | U914 |
TSOP44_T2 | MR2A16A_TSOP44_T2_1.20MM_334-75 | 256k x 16 bit 3.3V | | IC | U915 |
SSOP28 | MAX3243-SO_0_SSOP28_1.99MM_312- | MAX3243CDB | | IC | U916 |
TSSOP20 | XCF02S-V020_TSSOP20_1.2MM_342-0 | XCF02SVOG20C | | IC | U917 |
XTAL4-70X78-CTX | OSC3_XTAL4-70X78-CTX_1.6MM_230- | 18.432MHZ | | IC | U918 |
256-BALL_FPBGA | XC3S400-4FTG256C_256-BALL_FPBGA | XC3S400-4FTG256C | | IC | U919 |
DPAK_MC33269 | MC33269_DPAK_DPAK_MC33269_2.4MM | LD1117DT25CTR | | IC | U920 |
SSOP8 | SN74LVC2G74DCTR_SSOP8_1.3MM_312 | SN74LVC2G74DCTR | | IC | U921 |
SOT23_5S | SN74LVC1G14DBVR_SOT23_5S_1.45MM | SN74LVC1G14DBVR | | IC | U922 |
BGA80_0P5_5X5 | TLV320AIC23BIZQE_BGA80_0P5_5X5_ | TLV320AIC23B | | IC | U923 |
JACK_AUDIO_TRIP_STACK | STX-4335-5BGP-S1_JACK_AUDIO_TRI | 3.5MM | | IC | U924 |
QFN32 | USB3300_A_QFN32_1.0MM_312-75538 | USB3300 | | IC | U927 |
SO8 | MIC2526_8P_SO8_1.73MM_312-75936 | MIC2026-1YM | | IC | U928 |
XTL_HC49SLF | CRYSTAL_XTL_HC49SLF_3.6MM_230-3 | 25MHZ | | IC | X1 |
XTAL2-3P2X1P5-SM | CRYSTAL_XTAL2-3P2X1P5-SM_0.9MM_ | 32.768MHz | | IC | X2 |
XTL_HC49SLF | CRYSTAL_XTL_HC49SLF_3.6MM_230-3 | 25MHZ | | IC | X3 |
