查看: 2224|回复: 4
[Allegro16.6以下] S32K146EVB S32K146 评估板
发表于 2018-11-27 20:32:13 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
S32K146EVB-QSP.zip (8.7 MB, 下载次数: 4)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_TOLCOMP_CLASSREFDES
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.55M1000pF DISCRETEC1
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.65M4.7uF10%DISCRETEC2
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.65M4.7uF10%DISCRETEC3
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC4
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC5
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6MM1.0UF DISCRETEC6
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC7
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.65M4.7uF10%DISCRETEC8
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1.25M2.2UF DISCRETEC9
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC10
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.7MM10uF DISCRETEC11
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1MM_110uF10%DISCRETEC12
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6_10.1UF DISCRETEC16
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.965220PF DISCRETEC17
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.65M4.7uF10%DISCRETEC18
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC19
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.27M10.0uF DISCRETEC21
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.9M0.1uF DISCRETEC22
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.27M10.0uF DISCRETEC24
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC25
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC26
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.27M10.0uF DISCRETEC27
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6_10.1UF DISCRETEC28
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1.0MM4700 PF DISCRETEC40
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.9M0.1uF DISCRETEC47
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.27M10.0uF DISCRETEC49
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.56M0.01UF20%DISCRETEC59
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_112PF DISCRETEC126
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_112PF DISCRETEC127
CCE6P8X6P8CAP_POL_CCE6P8X6P8_DISCRETE_6.147uF DISCRETEC128
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_20.1uF DISCRETEC129
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_20.1uF DISCRETEC131
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_20.1uF DISCRETEC133
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_20.1uF DISCRETEC140
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_20.1uF DISCRETEC141
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_20.1uF DISCRETEC142
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4MM10UF DISCRETEC143
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4MM10UF DISCRETEC144
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_20.1uF DISCRETEC146
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9MM10pF10%DISCRETEC533
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9MM10pF10%DISCRETEC535
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.27M10.0uF DISCRETEC536
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4MM10UF DISCRETEC539
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_20.1uF DISCRETEC540
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_20.1uF DISCRETEC541
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4MM10UF DISCRETEC542
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_20.1uF DISCRETEC543
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.9M0.1uF DISCRETEC544
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.9M0.1uF DISCRETEC545
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.9M0.1uF DISCRETEC546
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.9M0.1uF DISCRETEC547
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.9M0.1uF DISCRETEC548
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC549
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.9M0.1uF DISCRETEC550
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1.0MM4700 PF DISCRETEC551
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4MM10UF DISCRETEC552
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_20.1uF DISCRETEC553
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.9M0.1uF DISCRETEC554
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.9M0.1uF DISCRETEC555
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.9M0.1uF DISCRETEC556
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.9M0.1uF DISCRETEC557
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_20.1uF DISCRETEC558
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.9M0.1uF DISCRETEC559
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.9M0.1uF DISCRETEC560
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.9M0.1uF DISCRETEC561
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.9M0.1uF DISCRETEC562
LED_0603LED_LED_0603_IC_0.9MM_370-75079RED ICD1
LED_0603LED_LED_0603_IC_0.67MM_370-7656LED GREEN ICD2
LED_0603LED_LED_0603_IC_0.85MM_370-7654GREEN ICD3
SOD-128DIODE_SCHTKY_SOD-128_IC_1.1MM_PMEG3050EP ICD6
SOD-128DIODE_SCHTKY_SOD-128_IC_1.1MM_PMEG3050EP ICD9
LED6_5X6MMLED_TRI_COLOR_LED6_5X6MM_IC_2.6LED RED/GRN/BL ICD11
DSN0603-2DIODE_BIDIR_DSN0603-2_IC_0.32MMPESD5V0R1BSF ICD17
DSN0603-2DIODE_BIDIR_DSN0603-2_IC_0.32MMPESD5V0R1BSF ICD18
DSN0603-2DIODE_BIDIR_DSN0603-2_IC_0.32MMPESD5V0R1BSF ICD19
TP_TH_063TEST_POINT_3_TP_TH_063_IC_5.6MM5006 ICGND1
TP_TH_063TEST_POINT_3_TP_TH_063_IC_5.6MM5006 ICGND2
CON_3X8_100_TH_C041HDR-3X8_A_CON_3X8_100_TH_C041_ISSW-108-01-G-T IOJ1
CON_3X10_100_TH_C041HDR-3X10_A_CON_3X10_100_TH_C041SSW-110-01-G-T IOJ2
CON2X8_2P54_THHDR_2X8_M_CON2X8_2P54_TH_IO_8.6CON 2X8 IOJ3
CON_3X8_100_TH_C041HDR-3X8_A_CON_3X8_100_TH_C041_ISSW-108-01-G-T IOJ4
CON20_2P54_THCONN_HDR_10X2_CON20_2P54_TH_IO_CON 2X10 IOJ5
CON_3X10_100_TH_C041HDR-3X10_A_CON_3X10_100_TH_C041SSW-110-01-G-T IOJ6
CON_MICROAB_10F_25_SM_RAMICRO_USB_CONN_10PIN_CON_MICROAUSB_MICRO_AB IOJ7
HDR103_ACONN_HDR_3X1_HDR103_A_IO_8.74MMHDR 1X3 IOJ10
CON_HDR_4M_100_TH_RACONN_HDR_4X1_CON_HDR_4M_100_TH_HDR 1X4 RA IOJ11
CON_2RH_10_50CONN_HDR_5X2_CON_2RH_10_50_IO_3HDR 2X5 IOJ12
CON_HDR_4M_100_TH_RACONN_HDR_4X1_CON_HDR_4M_100_TH_HDR 1X4 RA IOJ13
CON_2RH_10_50CONN_HDR_5X2_CON_2RH_10_50_IO_3HDR 2X5 IOJ14
CON3_PWR_JACK_TH_PJ051ADC_POWER_JACK_SHD_CON3_PWR_JACKCON PWR 3 IOJ16
HDR103_ACONN_HDR_3X1_HDR103_A_IO_8.74MMHDR 1X3 IOJ104
HDR103_ACONN_HDR_3X1_HDR103_A_IO_8.74MMHDR 1X3 IOJ107
IND_1608BEAD_IND_1608_DISCRETE_0.95MM_1330 OHM DISCRETEL1
IND_1608BEAD_IND_1608_DISCRETE_0.95MM_1330 OHM DISCRETEL2
IND_0402INDUCTOR_FERRITE_IND_0402_DISCR30 OHM DISCRETEL512
LFPAK5_1P27_5X4PMOS_5P_LFPAK5_1P27_5X4_IC_1.2PHPT61003PY ICQ1
SC_75NPN_SC_75_IC_0.9MM_480-75477_MMMBT3904TT1G ICQ6
SC_75NPN_SC_75_IC_0.9MM_480-75477_MMMBT3904TT1G ICQ7
SC_75NPN_SC_75_IC_0.9MM_480-75477_MMMBT3904TT1G ICQ8
SC_75NPN_SC_75_IC_0.9MM_480-75477_MMMBT3904TT1G ICQ9
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_44.7K1%DISCRETER1
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__2330 OHM DISCRETER2
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110.0K5%DISCRETER3
RC0402_25RES_RC0402_25_DISCRETE_0.40MM_180K DISCRETER4
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM__1220 DISCRETER12
POT3_3352TPOT_POT3_3352T_DISCRETE_4.32MM5K20%DISCRETER13
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_44.7K1%DISCRETER15
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110.0K5%DISCRETER16
RC0402_25RES_RC0402_25_DISCRETE_0.45M_105%DISCRETER18
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__433 DISCRETER21
RC0402_25RES_RC0402_25_DISCRETE_0.45M_105%DISCRETER24
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__433 DISCRETER25
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_44.7K1%DISCRETER30
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110.0K5%DISCRETER31
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER32
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER35
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110.0K5%DISCRETER39
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110.0K5%DISCRETER42
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__510.0K1%DISCRETER44
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER47
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER49
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110.0K5%DISCRETER51
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_44.7K1%DISCRETER52
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_1680 DISCRETER56
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_44.7K1%DISCRETER57
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__610.0K1%DISCRETER60
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__310.0K DISCRETER62
RC0402_25RES_RC0402_25_DISCRETE_0.40M_115K1%DISCRETER68
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__71.0K1%DISCRETER69
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__510.0K1%DISCRETER74
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__310.0K DISCRETER77
RC0805_OVRES_RC0805_OV_DISCRETE_0.65MM_42K DISCRETER80
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM__20 DISCRETER84
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM__20 DISCRETER88
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM__31.0M DISCRETER91
RC1206_OVRES_RC1206_OV_DISCRETE_0.6MM_4760.4 DISCRETER92
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_1680 DISCRETER95
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_1680 DISCRETER96
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_1680 DISCRETER97
RC1206_OVRES_RC1206_OV_DISCRETE_0.6MM_4760.4 DISCRETER98
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470 DISCRETER117
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER119
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER120
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4710K DISCRETER121
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER122
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER123
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER124
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER125
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER126
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER127
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER128
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER129
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER130
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER131
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM__20 DISCRETER133
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM__20 DISCRETER134
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER136
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER137
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM__20 DISCRETER146
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM__20 DISCRETER147
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER152
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER153
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER154
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER155
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER156
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER161
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER162
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER164
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM__20 DISCRETER165
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM__20 DISCRETER167
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER169
RC0805_OVRES_RC0805_OV_DISCRETE_0.65MM_42K DISCRETER171
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM__20 DISCRETER172
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM__20 DISCRETER300
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_44.7K DISCRETER525
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM__20 DISCRETER527
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_44.7K DISCRETER528
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER529
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER532
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM__20 DISCRETER533
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM__20 DISCRETER534
RC0805_OVRES_RC0805_OV_DISCRETE_0.65MM_12.2 DISCRETER535
RC0805_OVRES_RC0805_OV_DISCRETE_0.65MM_10k DISCRETER537
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_4.7K DISCRETER538
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_44.7K1%DISCRETER562
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM__20 DISCRETER567
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM__20 DISCRETER568
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_44.7K1%DISCRETER571
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_44.7K1%DISCRETER572
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4710K DISCRETER573
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4710K DISCRETER574
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4710K DISCRETER575
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_44.7K1%DISCRETER576
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER577
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER578
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER579
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER580
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER581
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER582
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER583
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER584
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER585
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER586
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER587
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER588
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER589
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER590
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER591
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER592
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470 DISCRETER593
RC0603_OVRES_RC0603_OV_DISCRETE_0.55M_11K DISCRETER595
RC0603_OVRES_RC0603_OV_DISCRETE_0.55M_11K DISCRETER596
RC0603_OVRES_RC0603_OV_DISCRETE_0.55M_11K DISCRETER597
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4710K DISCRETER598
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_433K DISCRETER599
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_433K DISCRETER600
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4710K DISCRETER601
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_433K DISCRETER602
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4710K DISCRETER603
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4710K DISCRETER604
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_433K DISCRETER605
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110.0K5%DISCRETER607
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110.0K5%DISCRETER608
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110.0K5%DISCRETER609
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110.0K5%DISCRETER610
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110.0K5%DISCRETER611
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110.0K5%DISCRETER612
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110.0K5%DISCRETER613
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110.0K5%DISCRETER614
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110.0K5%DISCRETER615
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110.0K5%DISCRETER617
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110.0K5%DISCRETER618
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110.0K5%DISCRETER619
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110.0K5%DISCRETER620
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110.0K5%DISCRETER621
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110.0K5%DISCRETER622
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4710K DISCRETER623
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470 DISCRETER624
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470 DISCRETER625
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470 DISCRETER626
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER629
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER630
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER632
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER633
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER635
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER637
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER638
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER640
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER641
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER642
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER643
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER644
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER645
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER646
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER647
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER648
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER649
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER651
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER652
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER653
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER654
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER655
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER656
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER657
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER658
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM__20 DISCRETER659
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470 DISCRETER660
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470 DISCRETER661
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4710K DISCRETER662
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4710K DISCRETER663
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM__20 DISCRETER664
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM__20 DISCRETER665
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM__20 DISCRETER667
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER668
SH0603RES_SHORT-2_SH0603_DISCRETE_0.10 DISCRETESH1
SH0603RES_SHORT-2_SH0603_DISCRETE_0.10 DISCRETESH11
SH0603RES_SHORT-2_SH0603_DISCRETE_0.10 DISCRETESH12
SH0603RES_SHORT-2_SH0603_DISCRETE_0.10 DISCRETESH13
SW4_SPST_4P8X3P6_2P5EDGE_MOUNT_PB_SW_2_SW4_SPST_4P8EVQ-P2402W ICSW2
SW4_SPST_4P8X3P6_2P5EDGE_MOUNT_PB_SW_2_SW4_SPST_4P8EVQ-P2402W ICSW3
SW4_SPST_4P8X3P6_2P5EDGE_MOUNT_PB_SW_2_SW4_SPST_4P8EVQ-P2402W ICSW5
ELECTRODE_SQ_15MMELECTRODE_ELECTRODE_SQ_15MM_IC_Electrode ICSW7
ELECTRODE_SQ_15MMELECTRODE_ELECTRODE_SQ_15MM_IC_Electrode ICSW8
SW4_SPST_4P8X3P6_2P5EDGE_MOUNT_PB_SW_2_SW4_SPST_4P8EVQ-P2402W ICSW9
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP5
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP6
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP7
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP8
TP_TH_063TEST_POINT_0_TP_TH_063_IC_5.59MTEST_POINT ICTP9
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP10
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP11
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP12
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP18
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP28
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP29
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP30
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP503
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP504
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP505
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP506
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP507
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP508
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP509
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP510
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP511
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP512
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP513
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP514
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP515
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP516
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP517
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP518
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP519
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP520
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP521
TP_TH_063TEST_POINT_0_TP_TH_063_IC_5.59MTEST_POINT ICTP522
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP523
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP524
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP525
TP_TH_063TEST_POINT_0_TP_TH_063_IC_5.59MTEST_POINT ICTP526
TP_TH_063TEST_POINT_0_TP_TH_063_IC_5.59MTEST_POINT ICTP527
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP528
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP529
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP530
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP531
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP532
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP533
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP534
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP535
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP536
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP537
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP538
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP539
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP540
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP541
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP542
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP543
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP544
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP545
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP546
TP_TH_063TEST_POINT_0_TP_TH_063_IC_5.59MTEST_POINT ICTP547
TP_TH_063TEST_POINT_0_TP_TH_063_IC_5.59MTEST_POINT ICTP548
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP549
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTPAD93
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTPAD94
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTPAD95
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTPAD96
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTPAD97
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTPAD98
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTPAD99
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTPAD100
TESTPOINT_135_070MILTEST_POINT_4_TESTPOINT_135_070MTESTLOOP ICTS1
TESTPOINT_135_070MILTEST_POINT_4_TESTPOINT_135_070MTESTLOOP ICTS2
TESTPOINT_135_070MILTEST_POINT_4_TESTPOINT_135_070MTESTLOOP ICTS3
TESTPOINT_135_070MILTEST_POINT_4_TESTPOINT_135_070MTESTLOOP ICTS4
TESTPOINT_135_070MILTEST_POINT_4_TESTPOINT_135_070MTESTLOOP ICTS5
TESTPOINT_135_070MILTEST_POINT_4_TESTPOINT_135_070MTESTLOOP ICTS6
TESTPOINT_135_070MILTEST_POINT_4_TESTPOINT_135_070MTESTLOOP ICTS7
TESTPOINT_135_070MILTEST_POINT_4_TESTPOINT_135_070MTESTLOOP ICTS8
TESTPOINT_135_070MILTEST_POINT_4_TESTPOINT_135_070MTESTLOOP ICTS9
TESTPOINT_135_070MILTEST_POINT_4_TESTPOINT_135_070MTESTLOOP ICTS10
XQFN8_1P45X1P25MMNTSX2102GU8H_8P_XQFN8_1P45X1P25NTSX2102GU8H ICU1
QFN8_1P6X1P6MM74LVC2T45GM_8P_QFN8_1P6X1P6MM_I74LVC2T45GM,125 ICU2
UDFN6_1X1P5MM74LVCH1T45_6P_UDFN6_1X1P5MM_IC_74LVCH1T45 ICU4
UDFN6_1X1P5MM74LVCH1T45_6P_UDFN6_1X1P5MM_IC_74LVCH1T45 ICU7
QFN32_S142EPPK20DX128V_QFN_32P_QFN32_S142EPMK20DX128VFM5 ICU8
SOT891_6P_0P35_1P05X1P05NC7WP14_SOT891_6P_0P35_1P05X1P074LVC2G14GF,132 ICU9
UDFN6_1X1P5MM74LVCH1T45_6P_UDFN6_1X1P5MM_IC_74LVCH1T45 ICU10
SOT23-6_AMIC2005-0.8YM6_SOT23-6_A_IC_1.4MIC2005-0.8YM6 ICU11
SOT23_5SSPX3819M5_FIX_0_SOT23_5S_IC_1.4SPX3819M5-L-3-3 ICU15
LQFP100_0P5_14X14PS32K144_LQFP_100P_A_0_LQFP100_PS32K144HFT0VLLT ICU17
SON20_0P5_3P6X5P6UJA1169TKF_3_SON20_0P5_3P6X5P6_UJA1169TK/F ICU19
SO8_1P27_4X5TJA1027T_8P_SO8_1P27_4X5_IC_1.7TJA1027T/20 ICU21
XQFN8_1P45X1P25MMNTSX2102GU8H_0_XQFN8_1P45X1P25MNTSX2102GU8H ICU26
XQFN8_1P45X1P25MMNTSX2102GU8H_0_XQFN8_1P45X1P25MNTSX2102GU8H ICU32
XQFN8_1P45X1P25MMNTSX2102GU8H_0_XQFN8_1P45X1P25MNTSX2102GU8H ICU33
XQFN8_1P45X1P25MMNTSX2102GU8H_0_XQFN8_1P45X1P25MNTSX2102GU8H ICU34
LQFP144_0P5_20X20MMS32K1XX_LQFP_144P_LQFP144_0P5_2PS32K118UEX0MLQT ICU35
XTAL3_3P35X1P45_SMXTAL_CS_XTAL3_3P35X1P45_SM_IC_08.00MHZ ICY1
XTAL2_3P3X2P6XTAL_CS10_XTAL2_3P3X2P6_IC_1MM_8MHZ ICY3
重要提示:PCB作品文件展下载说明
    5 天前
  • 签到天数: 55 天
    发表于 2023-4-27 11:05:42 | 显示全部楼层
    郁闷
    前天 08:30
  • 签到天数: 181 天
    Pads-230522高级班
    发表于 2023-4-27 11:55:24 | 显示全部楼层
    郁闷
    前天 08:30
  • 签到天数: 181 天
    Pads-230522高级班
    发表于 2023-4-27 11:55:33 | 显示全部楼层
    郁闷
    前天 08:30
  • 签到天数: 181 天
    Pads-230522高级班
    发表于 2023-4-27 11:55:41 | 显示全部楼层
