SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_TOL | COMP_CLASS | REFDES |
CR2032_LF | BATTERY_CR2032_LF_5.4MM_801-75 | BATTERY | | IC | BT1 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C1 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C2 |
CC0603 | CAP_NP_CC0603_0.90MM_150-75142_ | 0.1UF | 10% | IC | C3 |
CC0603 | CAP_NP_CC0603_1.0MM_150-30010_1 | 1000PF | 5% | IC | C4 |
CC7343A | CAP_POL_CC7343A_3.1MM_150-75053 | 100UF | 10% | IC | C5 |
CC0603 | CAP_NP_CC0603_0.87MM_150-75118 | 0.10UF | 5% | IC | C6 |
CC0603 | CAP_NP_CC0603_0.87MM_150-75118 | 0.10UF | 5% | IC | C7 |
CC0603 | CAP_NP_CC0603_0.87MM_150-75118 | 0.10UF | 5% | IC | C8 |
CC0603 | CAP_NP_CC0603_0.87MM_150-75118 | 0.10UF | 5% | IC | C9 |
CC1210 | CAP_NP_CC1210_2.7MM_150-75365_1 | 100UF | 20% | IC | C10 |
CC0603 | CAP_NP_CC0603_0.87MM_150-75118 | 0.10UF | 5% | IC | C11 |
CC0603 | CAP_NP_CC0603_0.87MM_150-75118 | 0.10UF | 5% | IC | C12 |
CC6032 | CAP_POL_CC6032_1.5MM_150-75147_ | 47UF | 20% | IC | C13 |
CC3216 | CAP_POL_CC3216_1.8MM_150-75055_ | 10UF | 10% | IC | C14 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C15 |
CC0603 | CAP_NP_CC0603_0.86MM_150-30087 | 10nF | 5% | IC | C18 |
CC0603 | CAP_NP_CC0603_0.87MM_150-75272_ | 16PF | 5% | IC | C20 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C21 |
CC0603 | CAP_NP_CC0603_1.0MM_150-30028_1 | 1.0 UF | 10% | IC | C22 |
CC6032 | CAP_POL_CC6032_1.5MM_150-75147_ | 47UF | 20% | IC | C23 |
CC1210 | CAP_NP_CC1210_2.42MM_150-30186 | 47uF | 10% | IC | C24 |
CC0603 | CAP_NP_CC0603_0.86MM_150-75593_ | 820PF | 5% | IC | C25 |
CC0603 | CAP_NP_CC0603_0.87MM_150-77380 | 30.0PF | 5% | IC | C27 |
CC0603 | CAP_NP_CC0603_0.99MM_150-76834_ | 1800PF | 5% | IC | C28 |
CC0603 | CAP_NP_CC0603_0.99MM_150-76834_ | 1800PF | 5% | IC | C31 |
CC0603 | CAP_NP_CC0603_0.87MM_150-77380 | 30.0PF | 5% | IC | C32 |
CC0603 | CAP_NP_CC0603_0.86MM_150-75593_ | 820PF | 5% | IC | C34 |
CC1210 | CAP_NP_CC1210_2.42MM_150-30186 | 47uF | 10% | IC | C35 |
CC3216 | CAP_POL_CC3216_1.8MM_150-75055_ | 10UF | 10% | IC | C36 |
CC0603 | CAP_NP_CC0603_0.87MM_150-75272_ | 16PF | 5% | IC | C37 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C38 |
CC0603 | CAP_NP_CC0603_1.0MM_150-30028_1 | 1.0 UF | 10% | IC | C42 |
CC0603 | CAP_NP_CC0603_1.0MM_150-30028_1 | 1.0 UF | 10% | IC | C43 |
CC0603 | CAP_NP_CC0603_0.84MM_150-75560_ | 18PF | 10% | IC | C44 |
CC0603 | CAP_NP_CC0603_0.84MM_150-75560_ | 18PF | 10% | IC | C45 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C46 |
CC0603 | CAP_NP_CC0603_0.86MM_150-30087 | 10nF | 5% | IC | C47 |
CC3216 | CAP_POL_CC3216_1.8MM_150-75055_ | 10UF | 10% | IC | C48 |
CC3216 | CAP_POL_CC3216_1.8MM_150-75055_ | 10UF | 10% | IC | C51 |
CC3216 | CAP_POL_CC3216_1.8MM_150-75055_ | 10UF | 10% | IC | C52 |
CC0603 | CAP_NP_CC0603_1.0MM_150-30028_1 | 1.0 UF | 10% | IC | C53 |
CC0603 | CAP_NP_CC0603_1.0MM_150-30028_1 | 1.0 UF | 10% | IC | C54 |
CC3528-21 | CAP_POL_CC3528-21_2.1MM_150-752 | 10UF | 20% | IC | C56 |
CC0603 | CAP_NP_CC0603_0.86MM_150-30087 | 10nF | 5% | IC | C57 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C58 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C59 |
CC3528-21 | CAP_POL_CC3528-21_2.1MM_150-752 | 10UF | 20% | IC | C60 |
CC1206 | CAP_NP_CC1206_1.27MM_150-30029_ | 1.0UF | 10% | IC | C61 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C73 |
CC3216 | CAP_POL_CC3216_1.8MM_150-75055_ | 10UF | 10% | IC | C74 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C75 |
CC0603 | CAP_NP_CC0603_0.90MM_150-75116_ | 18PF | 5% | IC | C77 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C78 |
CC0603 | CAP_NP_CC0603_0.90MM_150-75116_ | 18PF | 5% | IC | C79 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C84 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C85 |
CC3528-21 | CAP_POL_CC3528-21_2.1MM_150-752 | 10UF | 20% | IC | C86 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C87 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C88 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C89 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C90 |
CC0603 | CAP_NP_CC0603_0.87MM_150-75140_ | 1000PF | 10% | IC | C91 |
CC7343A | CAP_POL_CC7343A_3.1MM_150-75053 | 100UF | 10% | IC | C92 |
CC1206 | CAP_NP_CC1206_1.27MM_150-30029_ | 1.0UF | 10% | IC | C93 |
CC3528-21 | CAP_POL_CC3528-21_2.1MM_150-752 | 10UF | 20% | IC | C94 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C95 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C96 |
CC3528-21 | CAP_POL_CC3528-21_2.1MM_150-752 | 10UF | 20% | IC | C97 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C98 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C99 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C108 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C109 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C110 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C111 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C112 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C113 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C114 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C115 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C116 |
CC1808 | CAP_NP_CC1808_1.65MM_150-30012_ | 1000PF | 20% | IC | C117 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C118 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C119 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C500 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C501 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C502 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C503 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C504 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C505 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C506 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C507 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C508 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C509 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C510 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C511 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C512 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C513 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C514 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C515 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C516 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C517 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C518 |
CC0603 | CAP_NP_CC0603_0.92MM_150-75229 | 0.1 UF | 10% | IC | C519 |
CC0603 | CAP_NP_CC0603_1.0MM_150-30028_1 | 1.0 UF | 10% | IC | C520 |
CC0603 | CAP_NP_CC0603_1.0MM_150-30028_1 | 1.0 UF | 10% | IC | C521 |
LED_0603_C1 | LED_LED_0603_C1_0.80MM_370-750 | GREEN | | IC | D1 |
LED_0603_C1 | LED_LED_0603_C1_0.80MM_370-750 | GREEN | | IC | D2 |
D_SMC | DIODE_ZENER21_D_SMC_2.56MM_480 | 1SMC5.OAT3 | | IC | D3 |
DPAK | MBRD835LG_DPAK_2.38MM_480-30009 | MBRD835L | | IC | D4 |
DPAK | MBRD835LG_DPAK_2.38MM_480-30009 | MBRD835L | | IC | D5 |
LED_LUMEX_SM | LED_LED_LUMEX_SM_1.5MM_370-7504 | SML-LXL1206IC | | IC | D6 |
LED_LUMEX_SM | LED_LED_LUMEX_SM_1.5MM_370-750 | SML-LXL1206GC | | IC | D7 |
LED_LUMEX_SM | LED_LED_LUMEX_SM_1.5MM_370-750 | SML-LXL1206GC | | IC | D10 |
LED_LUMEX_SM | LED_LED_LUMEX_SM_1.5MM_370-750 | SML-LXL1206GC | | IC | D11 |
LED_LUMEX_SM | LED_LED_LUMEX_SM_1.5MM_370-750 | SML-LXL1206GC | | IC | D12 |
LED_LUMEX_SM | LED_LED_LUMEX_SM_1.5MM_370-750 | SML-LXL1206GC | | IC | D13 |
LED_LUMEX_SM | LED_LED_LUMEX_SM_1.5MM_370-750 | SML-LXL1206GC | | IC | D14 |
LED_LUMEX_SM | LED_LED_LUMEX_SM_1.5MM_370-750 | SML-LXL1206GC | | IC | D15 |
LED_LUMEX_SM | LED_LED_LUMEX_SM_1.5MM_370-750 | SML-LXL1206GC | | IC | D16 |
LED_0603_C1 | LED_LED_0603_C1_0.80MM_370-750 | GREEN | | IC | D17 |
1812 | FUSE_RESETTABLE_1812_0.78MM_510 | 2.6A | | IC | F1 |
HDR102 | CONN_HDR_2X1_HDR102_8.71MM_210 | HDR_2X1 | | IC | H1 |
HDR102 | CONN_HDR_2X1_HDR102_8.71MM_210 | HDR_2X1 | | IC | H2 |
HDR102 | CONN_HDR_2X1_HDR102_8.71MM_210 | HDR_2X1 | | IC | H3 |
SKT2X30_SSW_MIRRORED | CONN_HDR_30X2_SKT2X30_SSW_MIRRO | CON_2X30 | | IC | J1 |
HDR102 | CONN_HDR_2X1_HDR102_8.71MM_210 | HDR_2X1 | | IC | J2 |
HDR213 | CONN_HDR_13X2_HDR213_8.38MM_21 | HDR_2X13 | | IC | J3 |
HDR205_4W | CONN_HDR_5X2_HDR205_4W_9.65MM_2 | N2510-6003RB | | IC | J4 |
PJ-102AH | DC POWERJACK_PJ-102AH_11MM_210 | DC_POWER_JACK | | IC | J5 |
HDR103_STAG_SM | CONN_HDR_3X1_HDR103_STAG_SM_10. | HDR 3X1 | | IC | J6 |
HDR103_STAG_SM | CONN_HDR_3X1_HDR103_STAG_SM_10. | HDR 3X1 | | IC | J7 |
HDR102 | CONN_HDR_2X1_HDR102_8.71MM_210 | HDR_2X1 | | IC | J8 |
HDR103_STAG_SM | CONN_HDR_3X1_HDR103_STAG_SM_10. | HDR 3X1 | | IC | J9 |
HDR103_STAG_SM | CONN_HDR_3X1_HDR103_STAG_SM_10. | HDR 3X1 | | IC | J10 |
HDR103_STAG_SM | CONN_HDR_3X1_HDR103_STAG_SM_10. | HDR 3X1 | | IC | J11 |
HDR103_STAG_SM | CONN_HDR_3X1_HDR103_STAG_SM_10. | HDR 3X1 | | IC | J12 |
HDR103_STAG_SM | CONN_HDR_3X1_HDR103_STAG_SM_10. | HDR 3X1 | | IC | J13 |
HDR103_STAG_SM | CONN_HDR_3X1_HDR103_STAG_SM_10. | HDR 3X1 | | IC | J14 |
CON_SMA | CONN_COAX_1P_F_CON_SMA_9.652MM_ | CON 1 JACK | | IC | J15 |
HDR102 | CONN_HDR_2X1_HDR102_8.71MM_210 | HDR_2X1 | | IC | J16 |
HDR103_STAG_SM | CONN_HDR_3X1_HDR103_STAG_SM_10. | HDR 3X1 | | IC | J17 |
HDR102 | CONN_HDR_2X1_HDR102_8.71MM_210 | HDR_2X1 | | IC | J18 |
HDR208 | CONN_HDR_8X2_HDR208_8.4MM_210-1 | HDR_2X8 | | IC | J19 |
CON_CF_50M_SM_RA | CF_CONNECTOR_CON_CF_50M_SM_RA_5 | CF CONNECTOR | | IC | J20 |
HDR102 | CONN_HDR_2X1_HDR102_8.71MM_210 | HDR_2X1 | | IC | J21 |
HDR102 | CONN_HDR_2X1_HDR102_8.71MM_210 | HDR_2X1 | | IC | J22 |
HDR103_STAG_SM | CONN_HDR_3X1_HDR103_STAG_SM_10. | HDR 3X1 | | IC | J23 |
HDR102 | CONN_HDR_2X1_HDR102_8.71MM_210 | HDR_2X1 | | IC | J24 |
HDR2X4 | CONN_HDR_4X2_HDR2X4_8.382MM_210 | HDR_2X4 | | IC | J25 |
HDR103_STAG_SM | CONN_HDR_3X1_HDR103_STAG_SM_10. | HDR 3X1 | | IC | J27 |
HDR103_STAG_SM | CONN_HDR_3X1_HDR103_STAG_SM_10. | HDR 3X1 | | IC | J28 |
HDR103_STAG_SM | CONN_HDR_3X1_HDR103_STAG_SM_10. | HDR 3X1 | | IC | J29 |
HDR103_STAG_SM | CONN_HDR_3X1_HDR103_STAG_SM_10. | HDR 3X1 | | IC | J30 |
HDR103_STAG_SM | CONN_HDR_3X1_HDR103_STAG_SM_10. | HDR 3X1 | | IC | J31 |
HDR102 | CONN_HDR_2X1_HDR102_8.71MM_210 | HDR_2X1 | | IC | J32 |
HDR103_STAG_SM | CONN_HDR_3X1_HDR103_STAG_SM_10. | HDR 3X1 | | IC | J33 |
HDR103_STAG_SM | CONN_HDR_3X1_HDR103_STAG_SM_10. | HDR 3X1 | | IC | J34 |
HDR103_STAG_SM | CONN_HDR_3X1_HDR103_STAG_SM_10. | HDR 3X1 | | IC | J35 |
CON_8_RJ45_100_TH | 10_100M_JACK_CON_8_RJ45_100_TH_ | RJ45 | | IC | J36 |
MINIAB_RECEPT | USB_MINI_AB_RECEPTACLE_MINIAB_R | USB_MINI_AB_RECEPTACLE | | IC | J37 |
CON_DB9S_RA_318 | CONN_DB9F_MTGTABS_CON_DB9S_RA_3 | DB9_5747844-4 | | IC | J38 |
CON_DB9S_RA_318 | CONN_DB9F_MTGTABS_CON_DB9S_RA_3 | DB9_5747844-4 | | IC | J39 |
CON_DB9S_RA_318 | CONN_DB9F_MTGTABS_CON_DB9S_RA_3 | DB9_5747844-4 | | IC | J40 |
HDR114 | CONN_HDR_14X1_HDR114_8.38MM_21 | HDR_1X14 | | IC | JP1 |
IND_6363 | COIL_IND_6363_3MM_180-76716_3.3 | 3.3UH | 20% | IC | L1 |
IND_6363 | COIL_IND_6363_3MM_180-76716_3.3 | 3.3UH | 20% | IC | L2 |
IND_0603 | IND_IND_0603_0.8MM_180-75495_10 | 100MHZ | | IC | L3 |
IND_0603 | IND_IND_0603_0.8MM_180-75495_10 | 100MHZ | | IC | L4 |
IND_0603 | IND_IND_0603_0.8MM_180-75495_10 | 100MHZ | | IC | L5 |
IND_0603 | IND_IND_0603_0.8MM_180-75495_10 | 100MHZ | | IC | L6 |
IND_0603 | IND_IND_0603_0.8MM_180-75495_10 | 100MHZ | | IC | L7 |
IND_0603 | IND_IND_0603_0.8MM_180-75495_10 | 100MHZ | | IC | L8 |
IND_0603 | IND_IND_0603_0.8MM_180-75495_10 | 100MHZ | | IC | L11 |
IND_1206A | BEAD_IND_1206A_1.3MM_180-75060_ | 26OHM | 25% | IC | L12 |
IND_0603 | IND_IND_0603_0.8MM_180-75495_10 | 100MHZ | | IC | L13 |
IND_0603 | IND_IND_0603_0.8MM_180-75495_10 | 100MHZ | | IC | L14 |
IND_1206A | BEAD_IND_1206A_1.3MM_180-75060_ | 26OHM | 25% | IC | L15 |
IND_0603 | INDUCTOR_IND_0603_0.95MM_180-75 | 1K | 25% | IC | L16 |
IND_0603 | INDUCTOR_IND_0603_0.95MM_180-75 | 1K | 25% | IC | L17 |
IND_0603 | INDUCTOR_IND_0603_0.95MM_180-75 | 1K | 25% | IC | L18 |
IND_0603 | INDUCTOR_IND_0603_0.95MM_180-75 | 1K | 25% | IC | L19 |
IND_0603 | INDUCTOR_IND_0603_0.95MM_180-76 | 470OHM | 25% | IC | L20 |
IND_0603 | INDUCTOR_IND_0603_0.95MM_180-75 | 1K | 25% | IC | L21 |
IND_0603 | INDUCTOR_IND_0603_0.95MM_180-75 | 1K | 25% | IC | L22 |
IND_0603 | INDUCTOR_IND_0603_0.95MM_180-75 | 1K | 25% | IC | L23 |
IND_0603 | INDUCTOR_IND_0603_0.95MM_180-75 | 1K | 25% | IC | L24 |
IND_0603 | INDUCTOR_IND_0603_0.95MM_180-76 | 470OHM | 25% | IC | L25 |
IND_0603 | INDUCTOR_IND_0603_0.95MM_180-76 | 470OHM | 25% | IC | L26 |
IND_0603 | IND_IND_0603_0.8MM_180-75495_10 | 100MHZ | | IC | L500 |
IND_0603 | IND_IND_0603_0.8MM_180-75495_10 | 100MHZ | | IC | L501 |
IND_0603 | BEAD_IND_0603_0.95MM_180-76301_ | 10 OHM | 25% | IC | L502 |
SOT23-28X44 | MOSFET_N_SOT23-28X44_1.11MM_480 | NTR4501NT1G | | IC | Q1 |
RC0603 | RES_RC0603_0.55MM_470-75407_0 | 0 OHM | 1% | IC | R1 |
RC0603 | RES_RC0603_0.55MM_470-75407_0 | 0 OHM | 1% | IC | R2 |
RC0603 | RES_RC0603_0.55MM_470-75407_0 | 0 OHM | 1% | IC | R3 |
RC0603 | RES_RC0603_0.55MM_470-75407_0 | 0 OHM | 1% | IC | R4 |
RC0603 | RES_RC0603_0.55MM_470-75422_10. | 10.0K | 1% | IC | R5 |
RC0603 | RES_RC0603_0.55MM_470-75422_10. | 10.0K | 1% | IC | R6 |
RC0603 | RES_RC0603_0.55MM_470-75398_22 | 22 OHM | 5% | IC | R7 |
RC0603 | RES_RC0603_0.55MM_470-75422_10. | 10.0K | 1% | IC | R8 |
RC0603 | RES_RC0603_0.55MM_470-75422_10. | 10.0K | 1% | IC | R9 |
RC0603 | RES_RC0603_0.55MM_470-75422_10. | 10.0K | 1% | IC | R10 |
RC0603 | RES_RC0603_0.55MM_470-75407_0 | 0 OHM | 1% | IC | R11 |
RC0603 | RES_RC0603_0.55MM_470-75411_100 | 100 OHM | 5% | IC | R12 |
RC0603 | RES_RC0603_0.55MM_470-75422_10. | 10.0K | 1% | IC | R13 |
RC0603 | RES_RC0603_0.55MM_470-30298_270 | 270 OHM | 5% | IC | R14 |
RC0603 | RES_RC0603_0.55MM_470-30301_560 | 560 OHM | 5% | IC | R15 |
RC0603 | RES_RC0603_0.55MM_470-75422_10. | 10.0K | 1% | IC | R16 |
RC0603 | RES_RC0603_0.55MM_470-75422_10. | 10.0K | 1% | IC | R17 |
RC0603 | RES_RC0603_0.55MM_470-75422_10. | 10.0K | 1% | IC | R18 |
RC0603 | RES_RC0603_0.55MM_470-75422_10. | 10.0K | 1% | IC | R19 |
RC0603 | RES_RC0603_0.55MM_470-75424_100 | 100K | 1% | IC | R20 |
RC0603 | RES_RC0603_0.55MM_470-75424_100 | 100K | 1% | IC | R21 |
RC0603 | RES_RC0603_0.55MM_470-75424_100 | 100K | 1% | IC | R22 |
RC0603 | RES_RC0603_0.55MM_470-75424_100 | 100K | 1% | IC | R23 |
RC0603 | RES_RC0603_0.55MM_470-75398_22 | 22 OHM | 5% | IC | R24 |
RC0603 | RES_RC0603_0.55MM_470-75422_10. | 10.0K | 1% | IC | R25 |
RC0603_OV | RES_RC0603_OV_0.55MM_470-77984_ | 1.2K | 1% | IC | R26 |
RC0603 | RES_RC0603_0.55MM_470-30129_20 | 20.0 K | 1% | IC | R27 |
RC0603 | RES_RC0603_0.55MM_470-78024_5.3 | 5.36K | 1% | IC | R28 |
RC0402_25 | MOT_RES_RC0402_25_0.4MM_470-754 | 10.0K | 1% | IC | R29 |
RC0603 | RES_RC0603_0.55MM_470-75424_100 | 100K | 1% | IC | R30 |
RC0402_25 | MOT_RES_RC0402_25_0.4MM_470-754 | 10.0K | 1% | IC | R31 |
RC0603 | RES_RC0603_0.55MM_470-30129_20 | 20.0 K | 1% | IC | R32 |
RC0603 | RES_RC0603_0.55MM_470-78045_12. | 12.7K | 1% | IC | R33 |
RC0603 | RES_RC0603_0.55MM_470-77984_1.2 | 1.2K | 1% | IC | R34 |
RC0603 | RES_RC0603_0.55MM_470-75846_1.0 | 1.0M | 5% | IC | R35 |
RC0603 | RES_RC0603_0.55MM_470-75804_22 | 220 OHM | 1% | IC | R36 |
RC0603 | RES_RC0603_0.55MM_470-75422_10. | 10.0K | 1% | IC | R37 |
RC0603 | RES_RC0603_0.55MM_470-75407_0 | 0 OHM | 1% | IC | R38 |
RC0603 | RES_RC0603_0.55MM_470-75422_10. | 10.0K | 1% | IC | R39 |
RC0603 | RES_RC0603_0.55MM_470-75422_10. | 10.0K | 1% | IC | R40 |
RC0603 | RES_RC0603_0.55MM_470-75804_22 | 220 OHM | 1% | IC | R44 |
POT3_3352W | POT_POT3_3352W_9.91MM_470-7832 | 3352W-1-502LF | 20% | IC | R49 |
RC0603 | RES_RC0603_0.55MM_470-75422_10. | 10.0K | 1% | IC | R56 |
RC0603 | RES_RC0603_0.55MM_470-75414_4. | 4.7K | 5% | IC | R61 |
RC0603 | RES_RC0603_0.55MM_470-75422_10. | 10.0K | 1% | IC | R62 |
RC0603 | RES_RC0603_0.55MM_470-75422_10. | 10.0K | 1% | IC | R63 |
RC0603 | RES_RC0603_0.55MM_470-75804_22 | 220 OHM | 1% | IC | R64 |
RC0603 | RES_RC0603_0.55MM_470-75804_22 | 220 OHM | 1% | IC | R65 |
RC0603 | RES_RC0603_0.55MM_470-75804_22 | 220 OHM | 1% | IC | R66 |
RC0603 | RES_RC0603_0.55MM_470-75422_10. | 10.0K | 1% | IC | R67 |
RC0603 | RES_RC0603_0.55MM_470-75804_22 | 220 OHM | 1% | IC | R68 |
RC0603 | RES_RC0603_0.55MM_470-75804_22 | 220 OHM | 1% | IC | R69 |
RC0603 | RES_RC0603_0.55MM_470-75804_22 | 220 OHM | 1% | IC | R70 |
RC0603 | RES_RC0603_0.55MM_470-75804_22 | 220 OHM | 1% | IC | R71 |
RC0603 | RES_RC0603_0.55MM_470-30301_560 | 560 OHM | 5% | IC | R72 |
RC0603 | RES_RC0603_0.55MM_470-75424_100 | 100K | 1% | IC | R73 |
RC0603 | RES_RC0603_0.55MM_470-75407_0 | 0 OHM | 1% | IC | R500 |
RC0603 | RES_RC0603_0.55MM_470-75422_10. | 10.0K | 1% | IC | R501 |
RC0603 | RES_RC0603_0.55MM_470-75422_10. | 10.0K | 1% | IC | R502 |
RC0603 | RES_RC0603_0.55MM_470-75422_10. | 10.0K | 1% | IC | R503 |
RC0603 | RES_RC0603_0.55MM_470-75422_10. | 10.0K | 1% | IC | R504 |
RC0603 | RES_RC0603_0.55MM_470-75915_1.0 | 1.0K | 0.10% | IC | R505 |
RC0603 | RES_RC0603_0.55MM_470-75398_22 | 22 OHM | 5% | IC | R506 |
RC0603 | RES_RC0603_0.55MM_470-75398_22 | 22 OHM | 5% | IC | R507 |
RC0603 | RES_RC0603_0.55MM_470-75398_22 | 22 OHM | 5% | IC | R508 |
RC0603 | RES_RC0603_0.55MM_470-75398_22 | 22 OHM | 5% | IC | R509 |
RC0603 | RES_RC0603_0.55MM_470-75398_22 | 22 OHM | 5% | IC | R510 |
RC0603 | RES_RC0603_0.55MM_470-76703_18M | 18M | 5% | IC | R511 |
RC0603 | RES_RC0603_0.55MM_470-75422_10. | 10.0K | 1% | IC | R512 |
RC0603 | RES_RC0603_0.55MM_470-75915_1.0 | 1.0K | 0.10% | IC | R513 |
RC0603 | RES_RC0603_0.55MM_470-75422_10. | 10.0K | 1% | IC | R514 |
RC0603 | RES_RC0603_0.55MM_470-75915_1.0 | 1.0K | 0.10% | IC | R515 |
RC0603 | RES_RC0603_0.55MM_470-75389_33 | 33.0 OHM | 1% | IC | R516 |
RC0603 | RES_RC0603_0.55MM_470-75389_33 | 33.0 OHM | 1% | IC | R517 |
RC0603 | RES_RC0603_0.55MM_470-75398_22 | 22 OHM | 5% | IC | R518 |
RC0603 | RES_RC0603_0.55MM_470-75414_4. | 4.7K | 5% | IC | R519 |
RC0603 | RES_RC0603_0.55MM_470-75414_4. | 4.7K | 5% | IC | R520 |
RC0603 | RES_RC0603_0.55MM_470-75422_10. | 10.0K | 1% | IC | R521 |
RC0603 | RES_RC0603_0.55MM_470-75915_1.0 | 1.0K | 0.10% | IC | R522 |
RC0603 | RES_RC0603_0.55MM_470-75422_10. | 10.0K | 1% | IC | R523 |
RC0603 | RES_RC0603_0.55MM_470-75915_1.0 | 1.0K | 0.10% | IC | R524 |
RC0603 | RES_RC0603_0.55MM_470-75398_22 | 22 OHM | 5% | IC | R525 |
RC0603 | RES_RC0603_0.55MM_470-75398_22 | 22 OHM | 5% | IC | R526 |
RC0603 | RES_RC0603_0.55MM_470-75422_10. | 10.0K | 1% | IC | R527 |
RC0603 | RES_RC0603_0.55MM_470-75995_1. | 1.5K | 5% | IC | R528 |
RC0603 | RES_RC0603_0.55MM_470-75846_1.0 | 1.0M | 5% | IC | R529 |
RC0603 | RES_RC0603_0.55MM_470-76698_4. | 4.87K | 1% | IC | R530 |
RC0603 | RES_RC0603_0.55MM_470-75398_22 | 22 OHM | 5% | IC | R531 |
RC0603_OV | RES_RC0603_OV_0.55MM_470-77907_ | 120.0 OHM | 1% | IC | R532 |
RC0603 | RES_RC0603_0.55MM_470-75915_1.0 | 1.0K | 0.10% | IC | R533 |
RC0603 | RES_RC0603_0.55MM_470-75432_49 | 49.9 OHM | 1% | IC | R534 |
RC0603 | RES_RC0603_0.55MM_470-75432_49 | 49.9 OHM | 1% | IC | R535 |
RC0603 | RES_RC0603_0.55MM_470-75432_49 | 49.9 OHM | 1% | IC | R536 |
RC0603 | RES_RC0603_0.55MM_470-75432_49 | 49.9 OHM | 1% | IC | R537 |
RC0603 | RES_RC0603_0.55MM_470-30153_15 | 15K | 1% | IC | R538 |
RC0603 | RES_RC0603_0.55MM_470-30153_15 | 15K | 1% | IC | R539 |
RNET_4_8 | RES_ISO4_SINGLE_RNET_4_8_0.6MM_ | 1.0K | 5% | IC | RN1 |
RNET_4_8 | RES_ISO4_SINGLE_RNET_4_8_0.60MM | 10K | 5% | IC | RN2 |
RNET_4_8 | RES_ISO4_SINGLE_RNET_4_8_0.60MM | 10K | 5% | IC | RN3 |
RNET4 | RESISTOR_DIP_4_A-D_RNET4_0.7MM_ | 22 OHM | 5% | IC | RN4 |
RNET4 | RESISTOR_DIP_4_A-D_RNET4_0.7MM_ | 22 OHM | 5% | IC | RN5 |
RNET4 | RESISTOR_DIP_4_A-D_RNET4_0.7MM_ | 22 OHM | 5% | IC | RN6 |
RNET4 | RESISTOR_DIP_4_A-D_RNET4_0.7MM_ | 22 OHM | 5% | IC | RN7 |
RNET4 | RESISTOR_DIP_4_A-D_RNET4_0.7MM_ | 22 OHM | 5% | IC | RN8 |
RNET4 | RESISTOR_DIP_4_A-D_RNET4_0.7MM_ | 22 OHM | 5% | IC | RN9 |
RNET4 | RESISTOR_DIP_4_A-D_RNET4_0.7MM_ | 22 OHM | 5% | IC | RN10 |
RNET4 | RESISTOR_DIP_4_A-D_RNET4_0.7MM_ | 22 OHM | 5% | IC | RN11 |
RNET4 | RESISTOR_DIP_4_A-D_RNET4_0.7MM_ | 22 OHM | 5% | IC | RN12 |
RNET4 | RESISTOR_DIP_4_A-D_RNET4_0.7MM_ | 22 OHM | 5% | IC | RN13 |
RNET4 | RESISTOR_DIP_4_A-D_RNET4_0.7MM_ | 22 OHM | 5% | IC | RN14 |
RNET4 | RESISTOR_DIP_4_A-D_RNET4_0.7MM_ | 22 OHM | 5% | IC | RN15 |
RNET4 | RESISTOR_DIP_4_A-D_RNET4_0.7MM_ | 22 OHM | 5% | IC | RN16 |
RNET4 | RESISTOR_DIP_4_A-D_RNET4_0.7MM_ | 22 OHM | 5% | IC | RN17 |
RNET4 | RESISTOR_DIP_4_A-D_RNET4_0.7MM_ | 22 OHM | 5% | IC | RN20 |
RNET4 | RESISTOR_DIP_4_A-D_RNET4_0.7MM_ | 22 OHM | 5% | IC | RN21 |
SW4_PB_ESW_SM_P177 | SW_PB_ESW_SW4_PB_ESW_SM_P177_4. | SPST PB NO | | IC | SW1 |
SW4_PB_ESW_SM_P177 | SW_PB_ESW_SW4_PB_ESW_SM_P177_4. | SPST PB NO | | IC | SW2 |
SW4_PB_ESW_SM_P177 | SW_PB_ESW_SW4_PB_ESW_SM_P177_4. | SPST PB NO | | IC | SW3 |
SW3_SLIDE_TH | SW_PB_SPDT_3P_SW3_SLIDE_TH_12.7 | 1101M2S3CQE2 | | IC | SW4 |
SW4_PB_ESW_SM_P177 | SW_PB_ESW_SW4_PB_ESW_SM_P177_4. | SPST PB NO | | IC | SW5 |
SW4_PB_ESW_SM_P177 | SW_PB_ESW_SW4_PB_ESW_SM_P177_4. | SPST PB NO | | IC | SW6 |
C035S | T POINT R_C035S_0.005MM_280-75 | TEST POINT | | IC | TP1 |
C035S | T POINT R_C035S_0.005MM_280-75 | TEST POINT | | IC | TP2 |
C035S | T POINT R_C035S_0.005MM_280-75 | TEST POINT | | IC | TP3 |
C035S | T POINT R_C035S_0.005MM_280-75 | TEST POINT | | IC | TP4 |
C035S | T POINT R_C035S_0.005MM_280-75 | TEST POINT | | IC | TP5 |
C035S | T POINT R_C035S_0.005MM_280-75 | TEST POINT | | IC | TP6 |
C035S | T POINT R_C035S_0.005MM_280-75 | TEST POINT | | IC | TP7 |
C035S | T POINT R_C035S_0.005MM_280-75 | TEST POINT | | IC | TP8 |
C035S | T POINT R_C035S_0.005MM_280-75 | TEST POINT | | IC | TP9 |
C035S | T POINT R_C035S_0.005MM_280-75 | TEST POINT | | IC | TP10 |
C035S | T POINT R_C035S_0.005MM_280-75 | TEST POINT | | IC | TP11 |
C035S | T POINT R_C035S_0.005MM_280-75 | TEST POINT | | IC | TP12 |
C035S | T POINT R_C035S_0.005MM_280-75 | TEST POINT | | IC | TP13 |
C035S | T POINT R_C035S_0.005MM_280-75 | TEST POINT | | IC | TP14 |
C035S | T POINT R_C035S_0.005MM_280-75 | TEST POINT | | IC | TP15 |
TESTPOINT_135_070MIL | TESTLOOP_TESTPOINT_135_070MIL_1 | TESTLOOP | | IC | TP16 |
TESTPOINT_135_070MIL | TESTLOOP_TESTPOINT_135_070MIL_1 | TESTLOOP | | IC | TP17 |
TESTPOINT_135_070MIL | TESTLOOP_TESTPOINT_135_070MIL_1 | TESTLOOP | | IC | TP18 |
TESTPOINT_135_070MIL | TESTLOOP_TESTPOINT_135_070MIL_1 | TESTLOOP | | IC | TP19 |
TESTPOINT_135_070MIL | TESTLOOP_TESTPOINT_135_070MIL_1 | TESTLOOP | | IC | TP20 |
TESTPOINT_135_070MIL | TESTLOOP_TESTPOINT_135_070MIL_1 | TESTLOOP | | IC | TP21 |
TESTPOINT_135_070MIL | TESTLOOP_TESTPOINT_135_070MIL_1 | TESTLOOP | | IC | TP22 |
TESTPOINT_135_070MIL | TESTLOOP_TESTPOINT_135_070MIL_1 | TESTLOOP | | IC | TP23 |
QFN26_0P5_5X5 | MC34717_QFN26_0P5_5X5_1MM_330-2 | MC34717EP | | IC | U1 |
TSOP44_T2 | MR2A16A_TSOP44_T2_1.20MM_334-76 | MR2A16ACYS35 | | IC | U3 |
TQFP144 | MCF52259_TQFP144_1.6MM_312-7804 | MCF52259 | | IC | U4 |
BGA100_6X6MM | EPM240GM100C5N_BGA100_6X6MM_1.2 | EPM240ZM100C6 | | IC | U5 |
SOT-23-5 | NC7SZ14_SOT-23-5_1.45MM_312-759 | SN74LVC1G04 | | IC | U8 |
LQFP48 | DP83640_LQFP48_1.6MM_312-77858_ | DP83640 | | IC | U19 |
TSSOP16 | ICL3232_TSSOP16_1.1MM_312-78038 | ICL3232 | | IC | U20 |
SO8 | MIC2526_8P_SO8_1.73MM_312-75390 | MIC2026,MIC2076 | | IC | U21 |
TSSOP16 | ICL3232_TSSOP16_1.1MM_312-78038 | ICL3232 | | IC | U22 |
TSSOP16 | ICL3232_TSSOP16_1.1MM_312-78038 | ICL3232 | | IC | U23 |
S08_1P27_4X5 | SN65HVD230DR_S08_1P27_4X5_1.75M | SN65HVD230D | | IC | U24 |
DIP14_3_SKT | DIP14_DIP14_3_SKT_5.36MM_210-7 | DIP14 | | IC | Y1 |
XTLOSC4_SG_310_SM | XTAL_13Y_XTLOSC4_SG_310_SM_0.8M | 48MHZ | | IC | Y2 |
XTAL2-3P2X1P5-SM | CRYSTAL_XTAL2-3P2X1P5-SM_0.9MM_ | 32.768KHZ | | IC | Y3 |
XTL2_ECS250_SM | XTAL_XTL2_ECS250_SM_4.3MM_230-7 | 25MHz | | IC | Y4 |
