Bill of Material ReportSYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_TOL | COMP_CLASS | REFDES |
ANTENNA_2450AT42B100N | ANTENNA_2450AT42B100_ANTENNA_24 | ANTENNA_2450AT42B100 | | IC | A1 |
ANTENNA_2450AT18D0100N | ANTENNA_CERAMIC_1_3_GND_ANTENNA | 2450AT18D0100 | | DISCRETE | A3 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_1PF_CAPC | 1pF | | IC | ANT1 |
INDC1005X60L | INDUCTOR_INDC1005X60L_22NH_INDC | 22nH | | IC | ANT2 |
RESC1005X40L | RESISTOR_RESC1005X40L_DNM_RESC1 | DNM | | IC | ANT3 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_DNM_CAPC | DNM | | IC | C15 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_DNM_CAPC | DNM | | IC | C25 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_1UF_CAPC | 1uF | | IC | C26 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_DNM_CAPC | DNM | | IC | C27 |
CAPC0603X35L | CAPACITOR_CAPC0603X35L_100NF_CA | 100nF | | IC | C35 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_12PF_CAP | 12pF | | IC | C36 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_12PF_CAP | 12pF | | IC | C38 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_DNM_CAPC | DNM | | IC | C40 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_100NF_CA | 100nF | | IC | C91 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_10UF_CAP | 10uF | | IC | C99 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_100NF_CA | 100nF | | IC | C101 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_100NF_CA | 100nF | | IC | C111 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_100NF_CA | 100nF | | IC | C191 |
CAPC1608X90L | CAPACITOR_CAPC1608X90N_10UF_CAP | 10uF | | IC | C192 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_6.2PF_CA | 6.2pF | | IC | C221 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_6.2PF_CA | 6.2pF | | IC | C231 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_100NF_CA | 100nF | | IC | C241 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_100NF_CA | 100nF | | IC | C251 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_100NF_CA | 100nF | | IC | C271 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_100NF_CA | 100nF | | IC | C281 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_10PF_CAP | 10pF | | IC | C311 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_100NF_CA | 100nF | | IC | C321 |
CAPC0603X35L | CAPACITOR_CAPC0603X35L_100NF_CA | 100nF | | IC | C322 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_1UF_CAPC | 1uF | | IC | C331 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_100NF_CA | 100nF | | IC | C361 |
CAPC1005X60L | CAPACITOR_CAPC1005X60N_4.7UF_CA | 4.7uF | | IC | C371 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_100NF_CA | 100nF | | IC | C382 |
CAPC1005X60L | CAPACITOR_CAPC1005X60N_4.7UF_CA | 4.7uF | | IC | C391 |
CAPC1608X90L | CAPACITOR_CAPC1608X90L_22UF_CAP | 22uF | | IC | C421 |
CAPC1608X90L | CAPACITOR_CAPC1608X90L_22UF_CAP | 22uF | | IC | C422 |
CAPC1608X90L | CAPACITOR_CAPC1608X90L_10UF_CAP | 10uF | | IC | C432 |
CAPC1005X60L | CAPACITOR_CAPC1005X60N_4.7UF_CA | 4.7uF | | IC | C441 |
CAPC1608X90L | CAPACITOR_CAPC1608X90L_10UF_CAP | 10uF | | IC | C471 |
CAPC1608X90L | CAPACITOR_CAPC1608X90L_10UF_CAP | 10uF | | IC | C481 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_100NF_CA | 100nF | | IC | C491 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_22PF_CAP | 22pF | | IC | C511 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_22PF_CAP | 22pF | | IC | C521 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_100NF_CA | 100nF | | IC | C541 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_100NF_CA | 100nF | | IC | C561 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_4.7UF_CA | 4.7uF | | IC | C562 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_15PF_CAP | 15pF | | IC | C563 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_10UF_CAP | 10uF | | IC | C564 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_10UF_CAP | 10uF | | IC | C565 |
CAPC1005X60L | CAPACITOR_CAPC1005X60L_10UF_CAP | 10uF | | IC | C566 |
CAPC1005X60N | CAPACITOR_CAPC1005X60N_4.7UF_CA | 4.7uF | | IC | C567 |
CAPC0603X35L | CAPACITOR_CAPC0603X35L_100NF_CA | 100nF | | IC | C568 |
CAPC1608X90L | CAPACITOR_CAPC1608X90N_10UF_CAP | 10uF | | IC | C574 |
CAPC0603X35L | CAPACITOR_CAPC0603X35L_100NF_CA | 100nF | | IC | C575 |
CAPC0603X35L | CAPACITOR_CAPC0603X35L_100NF_CA | 100nF | | IC | C576 |
LEDC1708X67L | LED_LEDC1708X67L_LS L296-P2Q2-1 | LS L296-P2Q2-1 | | IC | CR1 |
LEDC1707X65L | LED_LEDC1707X65L_LPL296-J2L2-25 | LPL296-J2L2-25 | | IC | CR2 |
SOTFL35P100X50-3M | DIODE_TPD2EUSB30DR_V1_SOTFL35P1 | DIODE_TPD2EUSB30DR_V1 | | IC | CR4 |
FID100X115 | FIDMARK_FID100X115_FIDU_1MM | FIDU_1MM | | IC | FIDU8 |
FID100X115 | FIDMARK_FID100X115_FIDU_1MM | FIDU_1MM | | IC | FIDU11 |
FID100X115 | FIDMARK_FID100X115_FIDU_1MM | FIDU_1MM | | IC | FIDU12 |
FID100X115 | FIDMARK_FID100X115_FIDU_1MM | FIDU_1MM | | IC | FIDU13 |
FID100X115 | FIDMARK_FID100X115_FIDU_1MM | FIDU_1MM | | IC | FIDU14 |
FID100X115 | FIDMARK_FID100X115_FIDU_1MM | FIDU_1MM | | IC | FIDU15 |
FIL_DEA202450BT-1294C1N | FILTER_BPF_FIL_DEA202450BT-1294 | DEA202450BT-1294C1 | | IC | FL1 |
FIL_LFB182G45BG2D280N | FILTER_LFB_0_FIL_LFB182G45BG2D2 | LFB182G | | IC | FL2 |
FIL_BLM18HE152SN1DL | FILTER_2PIN_FIL_BLM18HE152SN1DL | BLM18HE152SN1 | | IC | FL3 |
HIROSE_MS156HFL | CONN_COAX_MS-156HF_HIROSE_MS156 | MS-156HF | | IC | J1 |
HIROSE_MS156HFL | CONN_COAX_MS-156HF_HIROSE_MS1_1 | MS-156HF | | IC | J2 |
MOLEX_474910001L | CONN_USB_MICRO_5+6_S_MOLEX_4749 | 47491-0001 | | IC | J3 |
INDC2016X100L | INDUCTOR_INDC2016X100L_2.2UH_IN | 2.2uH | | IC | L381 |
INDC2520X120L | INDUCTOR_INDC2520X120L_1UH_INDC | 1uH | | IC | L401 |
INDC2016X100L | INDUCTOR_INDC2016X100L_2.2UH_IN | 2.2uH | | IC | L431 |
INDC1608X100L | INDUCTOR_INDC1608X100L_CIM10U80 | CIM10U800N | | IC | L474 |
INDC2012X150L | INDUCTOR_INDC2012X150L_10UH_IND | 10uH | | IC | L475 |
TAGCONNECT_TC2030-CTX-NLN | CONN_IDC_TC2030-CTX-NL_TAGCONNE | TC2030-CTX-NL | | IC | P4 |
TAGCONNECT_TC2030-CTX-NLN | CONN_IDC_TC2030-CTX-NL_TAGCONNE | TC2030-CTX-NL | | IC | P5 |
DFN100X60X35-3A2N | MOSFET_N_CSD13381F4_DFN100X60X3 | CSD13381F4 | | DISCRETE | Q1 |
RESC0603X35L | RESISTOR_RESC0603X35L_270_RESC0 | 270 | | IC | R10 |
RESC1005X40L | RESISTOR_HOR_RESC1005X40L_0_RES | 0 | | IC | R12 |
RESC0603X35L | RESISTOR_RESC0603X35L_270_RESC0 | 270 | | IC | R21 |
RESC0603X35L | RESISTOR_RESC0603X35L_270_RESC0 | 270 | | IC | R22 |
RESC0603X35L | RESISTOR_RESC0603X35L_270_RESC0 | 270 | | IC | R24 |
RESC0603X35L | RESISTOR_RESC0603X35L_100K_RESC | 100k | | IC | R25 |
RESC0603X35N | RESISTOR_RESC0603X35N_100K_RESC | 100k | | IC | R26 |
RESC1005X40L | RESISTOR_RESC1005X40L_30.1K_RES | 30.1k | | IC | R55 |
RESC1005X40L | RESISTOR_RESC1005X40L_51K_RESC1 | 51k | | IC | R56 |
RESC0603X35L | RESISTOR_RESC0603X35L_10K_RESC0 | 10k | | IC | R61 |
RESC0603X35L | RESISTOR_RESC0603X35L_10K_RESC0 | 10k | | IC | R291 |
RESC0603X35L | RESISTOR_RESC0603X35L_10K_RESC0 | 10k | | IC | R301 |
RESC0603X35L | RESISTOR_RESC0603X35L_10K_RESC0 | 10k | | IC | R321 |
RESC0603X35L | RESISTOR_RESC0603X35L_10K_RESC0 | 10k | | IC | R329 |
RESC0603X35L | RESISTOR_RESC0603X35L_10K_RESC0 | 10k | | IC | R330 |
RESC0603X35L | RESISTOR_RESC0603X35L_10K_RESC0 | 10k | | IC | R331 |
RESC0603X35L | RESISTOR_RESC0603X35L_10K_RESC0 | 10k | | IC | R332 |
RESC1005X40L | RESISTOR_RESC1005X40L_1MEG_RESC | 1Meg | | IC | R333 |
RESC0603X35L | RESISTOR_RESC0603X35L_270_RESC0 | 270 | | IC | R337 |
RESC0603X35L | RESISTOR_RESC0603X35L_270_RESC0 | 270 | | IC | R338 |
RESC0603X35L | RESISTOR_RESC0603X35L_4.7K_RESC | 4.7k | | IC | R339 |
RESC0603X35L | RESISTOR_RESC0603X35L_100K_RESC | 100k | | IC | R341 |
RESC1005X40L | RESISTOR_RESC1005X40L_0_RESC100 | 0 | | IC | R472 |
RESC0603X35L | RESISTOR_RESC0603X35L_10K_RESC0 | 10k | | IC | R532 |
RESC0603X35L | RESISTOR_RESC0603X35L_10K_RESC0 | 10k | | IC | R533 |
RESC0603X35L | RESISTOR_RESC0603X35L_10K_RESC0 | 10k | | IC | R534 |
RESC0603X35L | RESISTOR_RESC0603X35L_100K_RESC | 100k | | IC | R535 |
RESC0603X35L | RESISTOR_RESC0603X35L_10K_RESC0 | 10k | | IC | R537 |
RESC0603X35L | RESISTOR_RESC0603X35L_10K_RESC0 | 10k | | IC | R538 |
RESC0603X35L | RESISTOR_RESC0603X35L_100K_RESC | 100k | | IC | R541 |
RESC0603X35L | RESISTOR_RESC0603X35L_10K_RESC0 | 10k | | IC | R542 |
RESC0603X35L | RESISTOR_RESC0603X35L_10K_RESC0 | 10k | | IC | R548 |
RESC0603X35L | RESISTOR_RESC0603X35L_2.7K_RESC | 2.7k | | IC | R549 |
RESC0603X35AL | RESISTOR_RESC0603X35AN_0_RESC06 | 0 | | IC | R550 |
RESC0603X35AL | RESISTOR_RESC0603X35AN_0_RESC06 | 0 | | IC | R551 |
RESC0603X35AL | RESISTOR_RESC0603X35AN_0_RESC06 | 0 | | IC | R552 |
RESC0603X35N | RESISTOR_RESC0603X35N_100_RESC0 | 100 | | IC | R553 |
SWITCH_TEXAS | BUTTON_CARBON_2_SWITCH_TEXAS_BU | BUTTON_CARBON | | IC | SW1 |
SWITCH_TEXAS | BUTTON_CARBON_2_SWITCH_TEXAS_BU | BUTTON_CARBON | | IC | SW2 |
SW_TL3700AF160Q_A2N | SWITCH_TACT_V1_SW_TL3700AF160Q_ | TL3700AF160Q | | DISCRETE | SW3 |
SW_TL3700AF160Q_A2L | SWITCH_TACT_V1_SW_TL3700AF160_1 | TL3700AF160Q | | DISCRETE | SW4 |
TP50 | TEST_POINT_TP50_20_SMD | 20_SMD | | IC | TP1 |
TP50 | TEST_POINT_TP50_20_SMD | 20_SMD | | IC | TP2 |
TP50 | TEST_POINT_TP50_20_SMD | 20_SMD | | IC | TP3 |
QFNFC50P900X900X100-65FL | IC_PROC_CC3200_VQFN64_QFNFC50P9 | CC3200R1M2RGC | | IC | U1 |
QFNFC50P500X500X100-33AL | IC_RF_CC26XX_5X5_QFN32_QFNFC50P | CC26xx-5x5 | | IC | U2 |
SON127P600X500X80-9N | IC_FLASH_W25X80AL_WSON8_SON127P | W25X80ALZPIG | | IC | U3 |
SON50P300X200X60-9L | IC_FLASH_W25X20CL_USON8_SON50P3 | W25X20CLUXIG | | IC | U4 |
QFNFC50P400X400X80-25BM | IC_PERIPH_CP2105_QFN24_V1_0_QFN | IC_PERIPH_CP2105_QFN24_V1 | | IC | U5 |
SON50P250X250X60-9N | IC_PERIPH_MFI337S3959_SON8_SON5 | MFI337S3959 | | IC | U6 |
SON65P300X300X100-9AL | IC_PM_TPS79601_SON8_SON65P300X3 | TPS79601DR | | IC | U7 |
XTAL_FC-135L | CRYSTAL_XTAL_FC-135L_32.768KHZ_ | 32.768kHz | | IC | Y1 |
OSCCC250X320X60-4L | XTAL_4PIN_S_OSCCC250X320X60-4L_ | 24MHz | | IC | Y2 |
OSCCC200X250X90-4AL | CRYSTAL_13_OSCCC200X250X90-4AL_ | 40MHz | | IC | Y3 |
XTAL_FC12ML | XTAL_XTAL_FC12ML_32.768KHZ_XTAL | 32.768kHz | | IC | Y4 |
