查看: 2599|回复: 8
[Allegro16.6以下] ADC32J45 Dual-Channel, 14-Bit, 160-MSPS Analog-to-Digital Converter Evaluatio
发表于 2018-12-1 10:00:25 | 显示全部楼层 |阅读模式
01.rar (1.01 MB, 下载次数: 4)
Design Name E:/FPGA/MAX/OK ADC32J45 Dual-Channel, 14-Bit, 160-MSPS Analog-to-Digital Converter Evaluation Module/sbac207/ADC32XXEVM_B.brd
Date Sat Dec 01 09:19:01 2018
Bill of Material Report (Condensed) SYM_NAME COMP_DEVICE_TYPE COMP_VALUE COMP_TOL COMP_CLASS QUANTITY REFDES
0402 CAP_0402_0.1UF_0402_.1UF_10% .1uF 10% IC 4 C1;C7;C8;C14
0402 CAP0603_0402_11PF_1% 11pF 1% IC 2 C2;C9
0402 CAP_0402_0.1UF_H_0402_.1UF_10% .1uF 10% IC 4 C3;C4;C10;C11
0402 CAP0603_0402_.1UF_10%_ .1uF 10% IC 10 C5;C6;C12;C13;C45;C48;C69;C173;C174;C194
0402 CAP0402_0402_.1UF_10%_ .1uF 10% IC 16 C29;C30;C31;C32;C33;C34;C35;C36;C37;C42;C43;C44;C46;C47;C169;C170
0402 CAP0402_0402_.22UF_+/-10%_ .22uF +/-10% IC 4 C38;C39;C40;C41
0402 CAP NP_0_0402_.1UF_10%_ .1uF 10% IC 2 C50;C54
0402 CAPACITOR_NP_1_0402_.1UF_10% .1uF 10% IC 10 C59;C60;C62;C65;C70;C72;C188;C190;C198;C200
0402 CAPACITOR_NP_1_0402_0.01UF_10% 0.01uF 10% IC 4 C66;C68;C191;C196
0402 CAP_0402_33PF_0402_33PF 33pF   IC 2 C180;C205
0402 CAP_0402_18PF_0402_180PF 180pF   IC 2 C181;C206
0402 IND_0402_0402_39NH 39nH   IC 4 L1;L4;L5;L8
0402 IND_0402_H_0402_0 0   IC 2 L2;L6
0402 RES_0402_49.9_0402_49.9_1% 49.9 1% IC 8 R1;R6;R10;R12;R15;R19;R24;R26
0402 RES_0402_ZERO_0402_0 0   IC 12 R2;R13;R16;R27;R120;R121;R135;R136;R137;R138;R141;R144
0402 RES_0402_4.99_0402_9.09 9.09   IC 4 R3;R14;R139;R142
0402 R_0402_0_5% 0 5% IC 19 R4;R11;R18;R25;R62;R65;R67;R68;R69;R70;R84;R85;R86;R113;R114;R116;R117;R118;R119
0402 RES_0402_24.9_0402_24.9 24.9   IC 4 R5;R9;R21;R22
0402 RES0603_0402_0_5% 0 5% IC 4 R7;R8;R20;R23
0402 RES0603_0402_1K_1% 1K 1% IC 2 R57;R87
0402 R_4_0402_10K_1%_ 10K 1% IC 1 R58
0402 RES0603_0402_49.9_1%_ERJ-3EKF49 49.9 1% IC 2 R59;R63
0402 RES0603_0402_100_1%_ 100 1% IC 10 R60;R61;R64;R66;R104;R149;R150;R151;R152;R153
0402 R_0402_22_1% 22 1% IC 4 R71;R72;R73;R74
0402 RES_0402_1K_0402_1K 1K   IC 1 R75
0402 RES_0402_1K_0402_0 0   IC 4 R76;R77;R80;R81
0402 RES_0402_1K_0402_105K 105K   IC 1 R78
0402 RES_0402_1K_0402_143K 143K   IC 1 R79
0402 RES_0402_1K_0402_20K 20K   IC 1 R82
0402 R_1_0402_DISCRETE_25.5K_1%_ 25.5K 1% DISCRETE 2 R83;R115
0402 RES_0402_249_0402_205 205   IC 4 R92;R93;R127;R128
0402 RES_0402_249_0402_499 499   IC 4 R94;R95;R129;R130
0402 RES0402_0402_59 59   IC 4 R96;R98;R131;R133
0402 RES0603_0402_49.9_1%_ 49.9 1% IC 4 R97;R108;R124;R132
0402 RES_0402_249_0402_442 442   IC 2 R101;R134
0402 RES_0402_249_0402_35.7 35.7   IC 4 R109;R110;R125;R126
0402 RES0402_0402_6.2 6.2   IC 4 R145;R146;R147;R148
0603 CAP0603_0603_10NF 10nF   IC 1 C49
0603 CAP0603_0603_47PF 47pF   IC 2 C52;C53
0603 CAP NP_0_0603_1.0UF_10%_ 1.0uF 10% IC 8 C58;C64;C74;C187;C195;C199;C207;C208
0603 CAP NP_1_0603_1.0UF_10% 1.0uF 10% IC 2 C71;C192
0603 CAP NP_0_0603_.01UF_5%_ .01uF 5% IC 1 C168
0603 CAP_0603_1000PF_0603_10NF 10nF   IC 2 C189;C209
0603 IND0603_0603_11PF_1% 11pF 1% IC 2 L3;L7
0603 IND0603_0603_250NH 250nH   IC 4 L23;L24;L26;L27
0603 RES0603_0603_2 2   IC 2 R106;R122
0603 RES0603_0603_20K 20K   IC 2 R107;R123
0805 CAP NP_1_0805_10UF_10% 10uF 10% IC 3 C57;C67;C197
0805 CAP_1206_2.2UF_0805_10UF_10% 10uF 10% IC 1 C61
0805 CAP0201_0805_47UF_10%_ 47uF 10% IC 2 C73;C193
0805 FERRITE_BEAD_0805_1K @ 100MHZ 1K @ 100MHz   IC 2 FB8;FB9
0805 R_0805_0.2_1% 0.2 1% IC 2 RS1;RS2
1206 FUSE_0_1206_FUSE 2.0A 63V FAST FUSE 2.0A 63V FAST   IC 1 F1
1206 FERRITE_BEAD_1206_68 OHM @ 100M 68 OHM @ 100MHz   IC 1 FB1
1206 FERRITE_BEAD_1206_68 OHM @ 10_1 68 OHM @ 100MHz   IC 1 FB2
1206_BEAD_NFM31P BEAD_NFM31P_1206_BEAD_NFM31P_27 27uF   IC 1 FB3
1210 CAP NP_0_1210_47UF_10% 47uF 10% IC 1 C55
1210 CAP_1210_22UF_1210_22UF 22uF   IC 2 C56;C63
1806 FERRITE_BEAD_1806_1K @ 100MHZ 1K @ 100MHz   IC 3 FB4;FB5;FB7
C-0603_X2Y CAP_X2Y_C-0603_X2Y_0.22UF 0.22uF   IC 2 C160;C210
CON_RAPC722_JACK_THVT_3 CONN JACK PWR_CON_RAPC722_JACK_ CONN JACK PWR   IC 1 J15
CON_SMRT_USBMNE20_F USB_MINI_AB_MNE20-5G5P10_CON_SM USB_MINI_AB   IC 1 J14
CON_SMVT_120POS_QTH_SAMTEC_RT1 CON_SMVT_120POS_QTH_SAMTEC_CON_ QTH-060-01-F-D-A-RT1   IC 1 J13
DBV5 TPS2400_DBV5_TPS2400 TPS2400   IC 1 U3
DBV5 INA138_DBV5_INA138 INA138   IC 2 U6;U9
DIODE_MBRB2515L MBRB2515L_5_DIODE_MBRB2515L_MBR MBRB2515L   IC 1 D2
HDR_THVT_1X2_100_M JUMPER_1X2_100_HDR_THVT_1X2_100 HEADER_1x2_100_430L   IC 4 JP2;JP3;JP4;JP5
HDR_THVT_1X3_100_M JUMPER_1X3_SMT_HDR_THVT_1X3_100 Jumper_1x3   IC 1 JP1
HDR_THVT_1X3_100_M SMD_JUMPER_1X3_HDR_THVT_1X3_100 HDR, THVT, 3POS   IC 2 JP6;JP7
IND_SM_LQH44P_1515 IND_POWER_1.5UH_IND_SM_LQH44P_1 1uH   IC 1 L17
LED_1206 LED_GREEN_1206_LED_1206_LED GRE LED GREEN   IC 1 D1
QFN20_RGW_P65PITCH TPS7A4700_QFN20_RGW_P65PITCH_TP TPS7A4700   IC 2 U5;U8
QFN48_RGZ_RTC ADC32XX_QFN48_RGZ_RTC_ADC32XX ADC32XX   IC 1 U1
QFN_16_124X124_PWRPAD THS4541RGT_QFN_16_124X124_PWRPA THS4541RGT   IC 2 U7;U10
SJP3_JUMPER_0603 JUMPER_1X3_SMT_SJP3_JUMPER_0603 Jumper_1x3_SMT   IC 2 SJP1;SJP2
SMA_RECP_250X250 SMA-END_PLUG_ROUND_SMA_RECP_250 SMA_END_RND   IC 4 J1;J2;J3;J4
SMA_THVT_312X312 SMA-THVT_142-0701-201_REC_SMA_T SMB_THVT_REC   IC 4 J9;J10;J11;J12
SON_DSG_8 TPS62080_SON8_SON_DSG_8_TPS6208 TPS62080   IC 1 U4
SON_Q5B_8 CSD18532Q5B_SON_Q5B_8_CSD18532Q CSD18532Q5   IC 1 Q1
SOT_23_321 DIODE_BAV99_SOT_23_321_BAV99 BAV99   IC 2 D3;D4
SSOP_28_413X221_26 FT245RL_0_SSOP_28_413X221_26_FT FT245RL   IC 1 U2
SW_RESET_PTS635 SW PUSHBUTTON_1_SW_RESET_PTS635 SW PUSHBUTTON   DISCRETE 1 SW1
TANT_A CAP POL-B_10UF_10V_TANT_A_4.7UF 4.7uF 10% IC 1 C51
TESTPOINT_62DIA TESTLOOP_BLACK_TESTPOINT_62DI_1 Testloop_Red   IC 1 TP4
TESTPOINT_62DIA TESTLOOP_BLACK_TESTPOINT_62DIA_ Testloop_Black   IC 5 TP5;TP9;TP10;TP11;TP12
TFMR_6_RF_DUAL_FOOTPRINT TFMR_6_WBC1-1TLB_TFMR_6_RF_DUAL ADT1-1WT   IC 4 T1;T2;T3;T4
TFMR_6_RF_DUAL_FOOTPRINT XFMR_6_JTX-4-10T_TFMR_6_RF_DUAL ADT4-6WT+   IC 2 T9;T10
TP_THVT_060_RND TP_THVT_060_RND-RED_TP_THVT_060 TP_THVT_060_RND-RED   IC 1 TP1
TP_THVT_100_RND TESTPOINT_BLUE_TP_THVT_100_RND_ RED   IC 1 TP8
PADS-181015高级班
社区居民忠实会员社区劳模终身成就奖特殊贡献奖原创先锋奖优秀斑竹奖金点子奖
发表于 2018-12-1 15:56:55 | 显示全部楼层
最后成功的人往往不是最有才华的人,而是那些默默付出直到最后一刻也不放弃的那些人!
    前天 10:30
  • 签到天数: 66 天
    发表于 2018-12-1 20:18:54 | 显示全部楼层
    发表于 2018-12-1 20:51:18 | 显示全部楼层
    终身成就奖原创先锋奖
    发表于 2018-12-4 08:45:48 | 显示全部楼层
    18 分钟前
  • 签到天数: 176 天
    发表于 2018-12-4 08:49:55 | 显示全部楼层
    1元学习PADS(5期)
    发表于 2018-12-4 08:52:13 | 显示全部楼层
    终身成就奖原创先锋奖
    发表于 2018-12-4 09:08:07 | 显示全部楼层
    发表于 2018-12-4 11:48:22 | 显示全部楼层
    公告:服务器刚移机,
    大家请不要下载东西。
    会下载失败
