p#J}@a Z10#6v tq>QZEg KH2a 2 cD2}EqZ 9 4层497PIN 本部分内容设定了隐藏,需要回复后才能看到(回复后还看不到就刷新一下即可) yZA}WTGe Comment | Designator | Footprint | Quantity | Cap Pol3 | C1 | CAP SIZE 10X10 | 1 | Cap | C2, C5, C15, C16,C19, C20, C23, C24, C27, C28 | 1206CAP | 10 | Cap | C3, C4, C6, C7, C8,C9, C10, C11, C12, C13, C14, C17, C18, C21, C22, C25, C26, C29 | 0805CAP | 18 | Cap Semi | C30, C31, C32 | 0805CAP | 3 | LED-SMT | D1 | LED-0805 | 1 | PMEG2005EJ,115 | D2 | SOD323 DIODE | 1 | KEYSTONE TPMINIATURE | DIR, EN, FALT, MODE,MODE0, MODE1, SNS, VREF | TP KEYSTONE WHT 5002 | 8 | KEYSTONE TPCOMPACT | GND | TP KEYSTONE BLK 5011 | 1 | GND | GND1 | TP KEYSTONE BLK 5011 | 1 | JUMPER-3PIN_open | JP1 | JUMPER-3PIN | 1 | Inductor | L1 | COILCRAFT LPS6235 | 1 | max | max | Maxim LOGO-3 | 1 | Header 2 | P1, P6, P7, P8, P9 | TERMINAL BLOCKEDZ250/2 | 5 | Arduino_Power | P2 | SAMTEC SSQ-108-03-G-S | 1 | Arduino_Analog | P3 | SAMTEC SSQ-106-03-G-S | 1 | Arduin_DIO1 | P4 | SAMTEC SSQ-108-03-G-S | 1 | Arduino_DIO2 | P5 | SAMTEC SSQ-110-03-G-S | 1 | Res1 | R1, R2, R3, R4, R6,R7, R10, R11, R14, R15, R16, R18, R19, R20, R22, R23, R24, R25, R26, R27,R28, R29, R31, R34, R35, R36, R37, R38, R40, R43, R44, R45, R46, R47, R49,R52, R53, R54, R55, R56, R58, R61, R62, R63, R64, R65, R66, R67, R68, R69,R70, R71 | 0805RES | 52 | Res1 | R5, R8, R9, R12, R13,R17, R21, R30, R33, R39, R42, R48, R51, R57, R60 | 0805 | 15 | Res1 | R32, R41, R50, R59 | 1206RES | 4 | SW-PB | RESET | SWITCH-PB-SMT_NARROW | 1 | max | RON | RONS LOGO | 1 | MAX17501 | U1 | TDFN10_3X2MM_EP | 1 | MAX7300 | U2 | QFN40 6MM_EP | 1 | MAX5387 | U3, U4 | TSSOP-14 | 2 | MAX4704 | U5, U7, U9, U11 | QFN12_3X3mm_EP | 4 | MAX14871 | U6, U8, U10, U12 | TSSOP-16 | 4 | tX Z5oG7 [ 此帖被topdenzengzhi在2018-12-01 10:18重新编辑 ]
