查看: 4967|回复: 10
[Allegro17.4以下] KITFS4503CAEEVM FS4503系统基础芯片线性0.5A Vcore, FS1b, LDT, CAN原理
终身成就奖原创先锋奖特殊贡献奖优秀斑竹奖金点子奖
发表于 2018-12-4 01:22:44 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
Item TypeItem RevDescriptionMfr. Part Number
MarketingPNA MCO39117Evaluation kit - FS4503,KITFS4503CAEEVM
PartB ECO65138PACKING LIST, KITFS4503CAEEVM
PartB ECO65138HW PACKOUT, KITFS4503CAEEVM
PartA ROR-08101KIT, PACKAGING BOX & FOAM SET, 8.75 X5.75 X 2.5590-75137
PartE ECO63289BOX, 8.75"  X 5.75"  X 2.5", FLIP TOP/LOCK TOP, W/FSL  LOGO570-75123
PartE ECO63289BOX, 8.75"  X 5.75"  X 2.5", FLIP TOP/LOCK TOP, W/FSL  LOGOM-219-31-857006
PartD MCO35200CUSTOM CUT OUT FOAM SET, POLYURETHANEANTI-STATIC, 8.75 X 5.75 OD TO USE WITH 570-75123 BOX590-75124
PartA ECO64493CONNECTOR, TERMINAL BLOCK PLUG, 2 POS,STR 3.81MM1803578
PartA ECO64493CONNECTOR, TERMINAL BLOCK PLUG, 10 POS,STR 3.81MM1803659
PartA1 MCO35043CABLE, USB TYPE A MALE/TYPE MINI B MALE3FT10U2-15103
PartC LOR-04007QUICK START GUIDE, ANALOG TOOLS924-76425
PartC LOR-04007LABEL, GENERIC ANALOG KITS805-77324
PartI ECO63277LABEL, PDC BARCODEMOT-PDC (B1850101-7)
PartI ECO63277LABEL, PDC BARCODEK545-PAI
PartA LOR-04003LABEL, CE MARK805-75208
PartA LOR-04003LABEL, CE MARKMOT-CE
PartA ECO64502PWA, KITFS4503CAEEVM
PartB ECO62547PWB, KITFS6522LAEEVB170-28821_B
CADPartA MCO34745SHUNT 0.1IN SP BLUE AUSNT-100-BL-G
CADPartA MCO34900BUMPON CYLINDRICAL .312X.215 BLKSJ61A6
PartA MCO35191LABEL, 1"X.25", ASSEMBLY /REVISION
PartA MCO35295LABEL, 1"X.25", SCHEMATIC /REVISION
PartA1 MCO35042LABEL, .75"X.25", SERIAL NUMBER
PartA MCO34955LABEL, 1.5" x 0.375, WHITE,MARKETING PN805-772662
PartA ECO64388SUB ASSEMBLY, SCHEMATIC PARTS, 700-29241,KITFS4503CAEEVM
CADPartA MCO34847CAP CER 0.01UF 50V 5% X7R 060306035C103JAT2A
CADPartA MCO34890CAP CER 0.22uF 25V 10% X7R 0603C0603C224K3RACTU
CADPartA MCO34870CAP ALEL 47uF 50V 20% -- SMDEMVH500ADA470MJA0G
CADPartA MCO34898CAP CER 1uF 50V 10% X7R 1206CGA5L3X7R1H105K160AB
CADPartA MCO34840CAP CER 22uF 16V 20% X7R AEC-Q200 1210GCM32ER71C226ME19
CADPartA MCO34862CAP CER 3.3UF 16V 10% X7R AEC-Q200 0805CGA4J3X7R1C335K125AB
CADPartA ECO56728CAP CER 10uF 16V 20% X7S AEC-Q200 0805GCM21BC71C106ME36
CADPartA ECO56729CAP CER 4.7uF 50V 10% X7S AEC-Q200 1206GCM31CC71H475KA03L
CADPartA MCO34901IND FER BEAD 330OHM@100MHZ 2.5A -- SMTUPZ2012E331-2R5TF
CADPartA MCO34901IND FER BEAD 330OHM@100MHZ 2.5A -- SMTMPZ2012S331A
CADPartA MCO34908IND FER BEAD 100 OHM@100MHZ 3A 25% 1806MPZ1608S101A
CADPartA MCO34884IND PWR 22UH@100KHZ 2.25A 20% SMTB82464G4223M
CADPartA MCO34851IND PWR 1uH@0.1MHz 3.6A 20% SMDB82472G6102M000
CADPartA MCO34844CONN,HEAD,2X5,STR,50/50 CON-2RH-10-50FTS-105-01-F-D
CADPartA2 MCO34901HDR 2X2 TH 2.54MM CTR 330H AU 98L0902S1002011-2LF
CADPartA2 MCO34901HDR 2X2 TH 2.54MM CTR 330H AU 98L77313-801-04LF
CADPartA2 MCO34901HDR 2X2 TH 2.54MM CTR 330H AU 98LHTSW-102-07-SM-D
CADPartA2 MCO34901HDR 2X2 TH 2.54MM CTR 330H AU 98LTSW-102-07-G-D
CADPartA2 MCO34901HDR 2X2 TH 2.54MM CTR 330H AU 98LTSW-102-07-S-D
CADPartA1 MCO34851HDR 2X5 TH 100MIL CTR 339H AU 95L090102S05011-2LF
CADPartA1 MCO34851HDR 2X5 TH 100MIL CTR 339H AU 95L77313-801-10LF
CADPartA1 MCO34851HDR 2X5 TH 100MIL CTR 339H AU 95L69192-110HLF
CADPartA1 MCO34851HDR 2X5 TH 100MIL CTR 339H AU 95L210-92-05GB01
CADPartA1 MCO34851HDR 2X5 TH 100MIL CTR 339H AU 95LTSW-105-07-G-D
CADPartA1 MCO34851HDR 2X5 TH 100MIL CTR 339H AU 95LTSW-105-07-S-D
CADPartA1 MCO34863HDR 2X3 TH 100MIL CTR 335H AU 95L929665-01-03-EU
CADPartA1 MCO34863HDR 2X3 TH 100MIL CTR 335H AU 95L77313-801-06LF
CADPartA1 MCO34863HDR 2X3 TH 100MIL CTR 335H AU 95L69192-106HLF
CADPartA1 MCO34863HDR 2X3 TH 100MIL CTR 335H AU 95LHTSW-103-07-SM-D
CADPartA1 MCO34863HDR 2X3 TH 100MIL CTR 335H AU 95LTSW-103-07-G-D
CADPartA1 MCO34863HDR 2X3 TH 100MIL CTR 335H AU 95LTSW-103-07-S-D
CADPartA MCO38546HDR 2X10 TH 100MIL CTR 330H AU 100L929665-01-10-EU
CADPartA MCO38546HDR 2X10 TH 100MIL CTR 330H AU 100L69192-620_
CADPartA MCO38546HDR 2X10 TH 100MIL CTR 330H AU 100LHTSW-110-07-SM-D
CADPartA MCO38546HDR 2X10 TH 100MIL CTR 330H AU 100LTSW-110-07-G-D
CADPartA MCO38546HDR 2X10 TH 100MIL CTR 330H AU 100LTSW-110-07-S-D
CADPartA1 MCO34745CON 1 PWR PLUG DIAM 2MM RA TH -- 430H NIPJ-102AH
CADPartA1 MCO34806TEST POINT PC MULTI PURPOSE BLK TH5011
CADPartA1 MCO34883TEST POINT PC MULTI PURPOSE RED TH5010
CADPartA MCO34867HDR 1X2 TH 100MIL SP 338H SN 100LTSW-102-07-T-S
CADPartA MCO34821CON 1X10 PLUG SHRD RA TH 3.81MM SP 285HSN 134L1803358
CADPartA MCO34900CON 1X2 PLUG SHRD RA TH 3.81MM SP 285H SN134L1803277
CADPartA MCO34871HDR 1x3 TH 100MIL SP 343H SN 100LTSW-103-07-T-S
CADPartA MCO34818HDR 2X4 TH 100MIL CTR 343H SN 100LTSW-104-07-T-D
CADPartA MCO34907TEST POINT PC MULTI PURPOSE YELLOW TH5014
CADPartA MCO34880TEST POINT PAD 30MIL DIA SMT, NO PART TOORDER
CADPartA MCO34846CON 5 USB_MINI_B_RECEPTACLE RA SMT 0.8MM168H AU1734035-2
CADPartA MCO34866XTAL 8MHZ 20PPM PAR 18PF ESR 200OHM SMTABM3B-8.000MHZ-B2-T
CADPartA MCO34844MOUNTING HOLE DRILL 126 PAD 244 PLATEDTH, no part to order
CADPartA MCO34749IC XCVR VXLTR 1BIT TS 1.65-5.5V SO-6SN74LVC1T45DRLR
CADPartA MCO38905IC LEVEL SHIFTER HEX 2-6V SO1674HC4050D,652
CADPartA MCO34819IC LIN OPAMP QUAD 1.8-6V SOIC14MCP6004-I/SL
CADPartMCO38044IC XCVR CAN FS1b 0.8A 4.5V LQFP48MC33FS4503CAE
CADPartA SOR-03762IC MCU 128KB FLASH 16KB RAM 48MHZ1.71-3.6V QFN48MKL25Z128VFT4
CADPartA SOR-03762IC MCU 128KB FLASH 16KB RAM 48MHZ1.71-3.6V QFN48PKL25Z128VFT4
CADPartA MCO34890LED RED SGL 20MA SMTLS M67K-H2L1-1-0-2-R18-Z
CADPartA MCO34900LED GRN SGL 20MA SMTLP M67K-E2G1-25
CADPartA MCO34735RES MF 15.0 OHM 1/4W 1% 1206CRCW120615R0FKEA
CADPartA MCO38630RES MF 560 1/10W 5% 0603WR06X561JTL
CADPartA MCO38630RES MF 560 1/10W 5% 0603RC0603JR-07560RL
CADPartA1 MCO34879RES MF 6.49K  1/16W 1% 0402RK73H1ETTP6491F
CADPartA1 MCO34879RES MF 6.49K  1/16W 1% 0402WR04X6491FTL
CADPartA1 MCO34908RES MF 11K  1/16W 1% 0402CR0402-FX-1102GLF
CADPartA1 MCO34908RES MF 11K  1/16W 1% 0402RK73H1ETTP1102F
CADPartA1 MCO34908RES MF 11K  1/16W 1% 0402WR04X1102FTL
CADPartA2 MCO38981RES MF ZERO OHM 1/10W -- AEC-Q200 0603RK73Z1JTTD
CADPartA2 MCO38981RES MF ZERO OHM 1/10W -- AEC-Q200 0603ERJ-3GEY0R00V
CADPartA2 MCO38981RES MF ZERO OHM 1/10W -- AEC-Q200 0603CRCW06030000Z0EA
CADPartA MCO34877RES MF 15 OHM 2W 1% 2512352115RFT
CADPartA MCO34905RES MF ZERO OHM 1/16W -- AEC-Q200 0402CRCW04020000Z0ED
CADPartA ECO59275RES TF 30 OHM 2W 1% 2512352130RFT
CADPartA MCO34743DIODE SW 150MA 75V SOD-3231N4148WS-7-F
CADPartA1 MCO34864DIODE ZNR 3W 5.6V -- REGULATOR SMB1SMB5919BT3G
CADPartA1 MCO34880TRAN PMOS PWR 50V 130MA SOT23BSS84LT1G
CADPartA MCO37513TRAN NMOS GEN 12A 55V AEC-Q101 SOT223BUK9832-55A,115
CADPartA MCO34855DIODE ESD 2LINE 5V SOT23GSOT05C-GS08
CADPartA MCO34898DIODE SCH PWR RECT 2A 40V AEC-Q101 SMBSS24T3G
CADPartA ECO53972DIODE ZNR 2.4-36V 5mA 400mW AEC-Q101SOD323PDZ36B,115
CADPartA ECO58844DIODE ZENER 375mW 18V AEC-Q101 SOD123FBZT52H-B18,115
CADPartA ECO59730DIODE SCH 100V 3A AEC-Q101 SOD128PMEG10030ELP
CADPartA MCO37949TRAN PNP PWR 120mOHM 3A 60V AEC-Q101LFPAK56PHPT60603PYX
CADPartA MCO37999TRAN NMOS PWR 30V 400mA AEC-Q101 SOT23NX3008NBK,215
CADPartA MCO38000DIODE ZNR 250mA 20V AEC-Q101 SOD123BZT52H-C20,115
CADPartA MCO34859SW 4P DIP 25MA 24V SMT97C04ST
CADPartA MCO34836SW SPST DIP SMT 24V 25MA97C06ST
CADPartA MCO34862FUSE FAST 0.5A 32V SMT 0805MFU0805FF00500P100
CADPartA MCO34886SW SPDT SLD 5A@120VAC/28VDC 2A@250VAC TH500SSP3S1M6QEA
CADPartA MCO34823CAP CER 680PF 50V 5% C0G 060306035A681JAT2A
CADPartA MCO34823CAP CER 680PF 50V 5% C0G 0603C0603C681J5GAC
CADPartA MCO34823CAP CER 680PF 50V 5% C0G 0603GRM1885C1H681JA01D
CADPartA MCO34823CAP CER 680PF 50V 5% C0G 0603C0603C0G500-681JNE
CADPartA MCO34876CAP CER 220PF 50V 10% C0G 0603C0603C221K5GACTU
CADPartA MCO34902CAP CER 150PF 50V 5% C0G 0603C0603C151J5GAC
CADPartA MCO34902CAP CER 150PF 50V 5% C0G 06030603CG151J500NT
CADPartA MCO34902CAP CER 150PF 50V 5% C0G 06030603N151J500LT
CADPartA MCO34847CAP CER 0.01UF 50V 5% X7R 0603C0603C103J5RACTU
CADPartA MCO35471CAP CER 180PF 50V 5% C0G 060306035A181JAT2A
CADPartA1 MCO34859CAP CER 0.10UF 25V 10% X7R 060306033C104KAT2A
CADPartA1 MCO34859CAP CER 0.10UF 25V 10% X7R 0603C0603C104K3RAC
CADPartA1 MCO34859CAP CER 0.10UF 25V 10% X7R 0603GRM188R71E104KA01
CADPartA1 MCO34859CAP CER 0.10UF 25V 10% X7R 0603C1608X7R1E104K080AA
CADPartA1 MCO34859CAP CER 0.10UF 25V 10% X7R 0603C0603X7R250-104KNE
CADPartA1 MCO34859CAP CER 0.10UF 25V 10% X7R 06030603B104K250CT
CADPartA1 MCO34859CAP CER 0.10UF 25V 10% X7R 0603CC0603KRX7R8BB104
CADPartA MCO34886CAP CER 1000PF 50V 10% C0G 060306035A102KAT2A
CADPartA MCO34886CAP CER 1000PF 50V 10% C0G 060306035U102KAT2A
CADPartA1 MCO34837IND PWR 2.2uH@100KHz 3A 20% SMTB82472G6222M000
CADPartA1 MCO34841CON 1 COAX SMB TH -- 325H AU5221111-1
CADPartA MCO34657TEST POINT BLK 70X220 MIL TH5006
CADPartA MCO34821RES MF 510 OHM 1/10W 5% 0603CR0603-JW-511ELF
CADPartA MCO34821RES MF 510 OHM 1/10W 5% 0603RK73B1JTTD511J
CADPartA MCO34821RES MF 510 OHM 1/10W 5% 0603ERJ3GEYJ511V
CADPartA MCO34821RES MF 510 OHM 1/10W 5% 0603CR060310W511JT
CADPartA MCO34821RES MF 510 OHM 1/10W 5% 0603CRCW0603510RJNEC
CADPartA MCO38582RES FLAT CHIP ZERO OHM 1/2W 5%  AEC-Q200 1210RK73Z2ETTD
CADPartA MCO34745RES MF 200 OHM 1/10W 5% 0603RK73B1JTTD201J
CADPartA MCO34745RES MF 200 OHM 1/10W 5% 0603CRCW0603200RJNEA
CADPartA MCO34749RES MF 18.0K 1/10W 1% AEC-Q200 0603CRCW060318K0FKEA
CADPartA MCO34746RES MF 39.0K 1/10W 1% 0603RK73H1JTTD3902F
CADPartA1 MCO35891RES MF 1.0M 1/10W 5% 0603RK73B1JTTD105J
CADPartA1 MCO35891RES MF 1.0M 1/10W 5% 0603RK73B1JTTP105J
CADPartA1 MCO35891RES MF 1.0M 1/10W 5% 0603ERJ3GEYJ105V
CADPartA1 MCO35891RES MF 1.0M 1/10W 5% 0603CRCW06031M00JNEA
CADPartA1 MCO35891RES MF 1.0M 1/10W 5% 0603CRCW06031M00JNEC
CADPartA ECO62034DIODE SCH PWR RECT 3A 30V AEC-Q101 SOD128PMEG3030BEP,115
重要提示:PCB作品文件展下载说明
 楼主| 发表于 2018-12-4 01:23:31 | 显示全部楼层
SCH-29241_A.DSN.rar (109 KB, 下载次数: 5) LAY-28821_B.brd.rar (3.02 MB, 下载次数: 5)
PADS-180606高级班
终身成就奖特殊贡献奖原创先锋奖优秀斑竹奖金点子奖
发表于 2018-12-4 07:48:13 | 显示全部楼层
    昨天 08:28
  • 签到天数: 157 天
    7万
    发表于 2018-12-4 08:05:17 | 显示全部楼层
    Re:KITFS4503CAEEVM
    来看一下吧
    PADS-171101高级班
    终身成就奖社区居民优秀斑竹奖特殊贡献奖
    发表于 2018-12-4 08:24:55 | 显示全部楼层
    发表于 2018-12-4 08:49:05 | 显示全部楼层
    昨天 12:20
  • 签到天数: 278 天
    终身成就奖社区居民特殊贡献奖原创先锋奖优秀斑竹奖
    发表于 2018-12-4 08:51:22 | 显示全部楼层
    昨天 08:27
  • 签到天数: 175 天
    1元学习Allegro(1期)
    终身成就奖优秀斑竹奖特殊贡献奖原创先锋奖
    发表于 2018-12-4 08:54:15 | 显示全部楼层
    PADS-180606高级班
    社区居民终身成就奖特殊贡献奖优秀斑竹奖
    发表于 2018-12-4 08:55:12 | 显示全部楼层
    生活就是油盐酱醋再加一点糖,快活就是一天到晚乐呵呵的忙!
    社区居民忠实会员社区劳模原创达人最爱沙发终身成就奖特殊贡献奖原创先锋奖优秀斑竹奖
    发表于 2018-12-4 08:58:16 | 显示全部楼层
