重要提示:PCB作品文件展下载说明
Item |
Quantity |
AgilePN |
ASSY_OPT |
Reference |
Value |
Description |
ASSY_NOTE |
Mfg Name |
Mfg Part Number |
PCB Footprint |
1 |
3 |
agilepn |
C1,C2,C3 |
220uF |
CAP, POL, 220UF 100V 20% | |
NICHICON |
UVK2A221MHD |
CAPRD_12p5x20mm |
2 |
5 |
agilepn |
C4,C5,C6,C10,C19 |
0.1uF |
CAP, CER 0.1UF 50V 10% X7R 0603 | |
KEMET |
C0603C104K5RACTU |
cc0603_ov |
1 |
1 |
AGILEPN |
C37 |
1.8PF |
CAP, CER 1.8PF 50V C0G 0402 | |
KEMET |
C0402C189C5GACTU |
CC0402_25 |
2 |
3 |
AGILEPN |
C24,C25,C26 |
100PF |
CAP, CER 100PF 50V 5% C0G 0402 | |
KEMET |
C0402C101J5GACTU |
CC0402_25 |
3 |
1 |
AGILEPN |
C38 |
820PF |
CAP, CER 820PF 50V 5% C0G 0402 | |
KEMET |
C0402C821J5GACTU |
CC0402_25 |
4 |
1 |
AGILEPN |
C36 |
6.8NF |
CAP, CER 6.8NF 50V 10% X7R 0402 | |
KEMET |
C0402C682K5RACTU |
CC0402_25 |
5 |
8 |
AGILEPN |
C7,C8,C9,C12,C14,C15,C22,C23 |
0.01UF |
CAP, CER 0.01UF 50V 10% X7R 0402 | |
KEMET |
C0402C103K5RACTU |
CC0402_25 |
6 |
8 |
AGILEPN |
C11,C13,C16,C17,C18,C27,C29,C35 |
0.1UF |
CAP, CER 0.1UF 16V 10% X7R 0402 | |
KEMET |
C0402C104K4RACTU |
CC0402_25 |
7 |
2 |
AGILEPN |
C20,C28 |
0.1UF |
CAP, CER 0.1UF 100V 10% X7R 0805 | |
KEMET |
C0805C104K1RACTU |
CC0805_OV |
8 |
1 |
AGILEPN |
C39 |
2.2UF |
CAP, CER 2.2UF 100V 10% X7R 1210 | |
TDK |
C3225X7R2A225K230AB |
CC1210_OV |
9 |
1 |
AGILEPN |
C40 |
47UF |
CAP, CER 47UF 10V 20% X5R 1206 | |
MURATA |
GRM31CR61A476ME15L |
CC1206_OV |
10 |
5 |
AGILEPN |
D1,D2,D3,D4,D8 |
1N914 |
DIODE, 75V 150MA | |
FAIRCHILD |
1N914BWS |
SODFL2513X100N |
11 |
2 |
AGILEPN |
D5,D7 |
DFLS1100 |
DIODE, SCHOTTKY, 100V 1A | |
DIODES INC |
DFLS1100-7 |
SODFL3718X100N |
12 |
1 |
AGILEPN |
D6 |
MM3Z15VB |
DIODE, ZENER, 15V 2% 200MW | |
FAIRCHILD |
MM3Z15VB |
SODFL2513X100N |
13 |
2 |
J1,J3 |
SSQ-108-03-G-D |
CON 2X8 FEMALE 100MIL SP 335H 394LL AU |
SAMTEC |
SSQ-108-03-G-D |
SAMTEC_SSQ-108-03-G-D |
14 |
1 |
J2 |
SSQ-110-03-G-D |
CON 2X10 FEMALE 100MIL SP 335H 394LL AU |
SAMTEC |
SSQ-110-03-G-D |
SAMTEC_SSQ-110-03-G-D |
15 |
1 |
J4 |
SSQ-106-03-G-D |
CON 2X6 FEMALE 100MIL SP 335H 394LL AU |
SAMTEC |
SSQ-106-03-G-D |
SAMTEC_SSQ-106-03-G-D |
16 |
1 |
AGILEPN |
J6 |
PJ-102AH |
CONNECTOR, BARREL | |
CUI |
PJ-102AH |
CON_PJ-102AH |
17 |
1 |
AGEILPN |
J7 |
KRM03 |
CONNECTOR, 3-PIN SCREW TERMINAL | |
LUMBERG |
KRM03 |
CON_KRM03 |
18 |
1 |
AGILEPN |
J8 |
22-05-3051 |
CONNECTOR, 5-PIN, 100MIL | |
MOLEX |
22-05-3051 |
CON_22-05-3051 |
19 |
1 |
AGILEPN |
L1 |
100UH |
INDUCTOR, 100UH | |
BOURNS |
SRN8040-101M |
IND_SRN8040 |
20 |
3 |
AGILEPN |
Q1,Q2,Q3 |
FDMS8090 |
MOSFET - DUAL N-CH, 100V | |
FAIRCHILD |
FDMS8090 |
POWER56-10 |
21 |
1 |
AGILEPN |
Q4 |
FDMS86163P |
MOSFET - P-CH, 100V | |
FAIRCHILD |
FDMS86163P |
POWER56-8 |
22 |
4 |
AGILEPN |
R13,R14,R15,R36 |
0.01 |
RES, MF 0.01 1/2W 1% 1206 | |
SEI |
CSR1206FT10L0 |
RC1206_OV |
23 |
9 |
AGILEPN |
R1,R2,R4,R5,R6,R7,R8,R9,R12 |
10 |
RES, MF 10 1/16W 5% 0402 | |
VISHAY |
CRCW040210R0JNED |
RC0402_25 |
24 |
3 |
AGILEPN |
R49,R52,R55 |
100 |
RES, MF 100 1/16W 1% 0402 | |
VISHAY |
CRCW0402100RFKED |
RC0402_25 |
25 |
1 |
AGILEPN |
R56 |
200 |
RES, MF 200 1/16W 5% 0402 | |
VISHAY |
CRCW0402200RFKED |
RC0402_25 |
26 |
17 |
AGILEPN |
R10,R11,R16,R17,R18,R19,R23,R24,R25,R26,R27,R28,R37,R38,R48,R51,R53 |
1K |
RES, MF 1K 1/16W 1% 0402 | |
VISHAY |
CRCW04021K00FKED |
RC0402_25 |
27 |
3 |
AGILEPN |
R47,R50,R54 |
2K |
RES, MF 2K 1/16W 1% 0402 | |
VISHAY |
CRCW04022K00FKED |
RC0402_25 |
28 |
1 |
AGILEPN |
R57 |
2.15K |
RES, MF 2.15K 1/8W 1% 0805 | |
VISHAY |
CRCW08052K15FKEA |
RC0805_OV |
29 |
1 |
AGILEPN |
R35 |
3K |
RES, MF 3K 1/16W 1% 0402 | |
VISHAY |
CRCW04023K00FKED |
RC0402_25 |
30 |
3 |
AGILEPN |
R70,R71,R72 |
4.7K |
RES, MF 4.7K 1/16W 5% 0402 | |
VISHAY |
CRCW04024K70JNED |
RC0402_25 |
31 |
3 |
AGILEPN |
R32,R34,R58 |
10K |
RES, MF 10K 1/16W 1% 0402 | |
VISHAY |
CRCW040210K0FKED |
RC0402_25 |
32 |
8 |
AGILEPN |
R20,R21,R22,R29,R30,R31,R39,R40 |
20K |
RES, MF 20K 1/16W 1% 0402 | |
VISHAY |
CRCW040220K0FKED |
RC0402_25 |
33 |
1 |
AGILEPN |
R60 |
22.6K |
RES, MF 22.6K 1/8W 1% 0805 | |
VISHAY |
CRCW080522K6FKEA |
RC0805_OV |
34 |
1 |
AGILEPN |
R33 |
52.3K |
RES, MF 52.3K 1/16W 1% 0402 | |
VISHAY |
CRCW040252K3FKED |
RC0402_25 |
35 |
1 |
AGILEPN |
R46 |
59K |
RES, MF 59K 1/16W 1% 0402 | |
VISHAY |
CRCW040259K0FKED |
RC0402_25 |
36 |
1 |
AGILEPN |
R41 |
100K |
RES, MF 100K 1/16W 1% 0402 | |
VISHAY |
CRCW0402100KFKED |
RC0402_25 |
37 |
1 |
AGILEPN |
R59 |
150K |
RES, MF 150K 1/16W 1% 0402 | |
VISHAY |
CRCW0402150KFKED |
RC0402_25 |
38 |
1 |
AGILEPN |
R45 |
294K |
RES, MF 294K 1/16W 1% 0402 | |
VISHAY |
CRCW0402294KFKED |
RC0402_25 |
39 |
0 | |
DNP |
SH1 |
0 |
CUT TRACE RESISTOR | |
NOTACOMPONENT |
NOTACOMPONENT |
RC0402_25_CT |
40 |
8 |
AGILEPN |
TP1,TP2,TP3,TP4,TP5,TP6,TP7,TP8 |
TP |
TEST POINT | |
KEYSTONE |
5000 |
TP_TH_040 |
41 |
1 |
AGILEPN |
U1 |
FAN7888 |
IC, 3 CHAN HALF-BRIDGE DRIVER, SOIC-20 |
FAIRCHILD |
FAN7888MX |
SOIC127P1032X265-20N |
42 |
3 |
AGILEPN |
U2,U3,U4 |
FAN4852 |
OP AMP, DUAL | |
FAIRCHILD |
FAN4852IMU8X |
SOP65P490X110-8N |
43 |
1 |
AGILEPN |
U5 |
LM317AHV |
IC, LINEAR VOLTAGE REGULATOR ADJ | |
FAIRCHILD |
LM317AHVT |
TO-220 |
44 |
1 |
AGILEPN |
U6 |
74LVX14 |
IC, HEX SCHMITT TRIGGER INVERTER | |
FAIRCHILD |
74LVX14MTCX |
SOP65P640X120-14N |
45 |
1 |
AGILEPN |
U7 |
TPS54060 |
IC, BUCK REGULATOR | |
TI |
TPS54060ADGQ |
SOP50P490X110-11N |
重要提示:PCB作品文件展下载说明
