查看: 6861|回复: 4
[Allegro17.4以下] MIMXRT1064-EVK:i.MX RT1064评估套件原理图PCB
终身成就奖原创先锋奖特殊贡献奖优秀斑竹奖金点子奖
发表于 2018-12-4 20:08:50 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
Item Number
Quantity
AGILE_PN
ASSY_OPT
Value
DESCRIPTION
MFG_NAME01
MFG_PN01
470-75394
RES MF ZERO OHM 1/16W 5% 0402
ROHM
MCR01MZPJ000
470-75557
DNP
10K
RES MF 10K 1/16W 5% 0402
VISHAY INTERTECHNOLOGY
CRCW040210K0JNED
90OHM
IND CHK 90 OHM@100MHZ 330MA 25% 0805
MURATA
DLW21HN900SQ2L
47uF
CAP CER 47UF 6.3V 10% X5R 1206
MURATA
GRM31CR60J476KE19L
150-78463
4.7uF
CAP CER 4.7UF 6.3V 20% X5R 0402
TDK
C1005X5R0J475M050BC
RB521S30
DIODE SCH RECT 200MA 30V AEC-Q101 SOD-523
NEXPERIA
RB521S30,115
470-75394
DNP
ROHM
MCR01MZPJ000
150-75634
0.1UF
CAP CER 0.1UF 10V 10% X5R 0402
KEMET
C0402C104K8PAC
9
DNP
0.02
RES MF 0.02 OHM 1/10W 1% 0603
WSL0603R0200FEA
470-75555
1K
RES MF 1.0K 1/16W 5% 0402
CRCW04021K00JNED
DNP
1K
CRCW04021K00JNED
NUP2105L
DIODE DUAL LINE CAN BUS PROTECTOR 27V350W SOT-23
On semiconductor
NUP2105LT1G
13
4.7PF
CAP CER 4.7PF 50V 0.25PF C0G 0402
MURATA
GRM1555C1H4R7CA01D
14
6.49K
RES MF 6.49K  1/16W 1% 0402
WALSIN TECHNOLOGY CORP.
WR04X6491FTL
DNP
HDR 1X2
HDR 1X2 TH 100MIL SP 339H AU 98L
ANYTRONIC CORPORATION LIMITED
0901S0202011N9T-31RF
16
330 OHM
IND FER BEAD 330OHM@100MHZ 1.7A 0603
TDK
MPZ1608S331A
17
93.1
RES MF 93.1 OHM 1/8W 1% AEC-Q200 0603
KOA SPEER
RK73H1JTTD93R1F
18
14
150-78675
10uF
CAP CER 10UF 10V 10% X5R 0603
MURATA
GRM188R61A106KE69D
12.0K
RES MF 12.0K 1/16W 1% 0402
BOURNS
CR0402-FX-1202GLF
2.2K
RES MF 2.2K 1/16W 5% 0402
YAGEO AMERICA
RC0402JR-072K2L
470-75557
10K
CRCW040210K0JNED
22
DNP
FXOS8700CQ
IC ACCELEROMETER AND MAGNETOMETER SENSOR3-AXIS 2.5V QFN16
Freescale Semiconductor
FXOS8700CQ
23
10PF
CAP CER 10PF 50V 5% C0G 0402
AVX
04025A100JAT2A
24
4.7uH
IND WW FER 4.7uH@1MHz 1.4A 20% 4012
TDK
VLS4012ET-4R7M
25
9
470-75626
4.7K
RES MF 4.7K 1/16W 5% 0402
NIC COMPONENTS CORP
NRCL04J472TRF
26
243K
RES MF 243K 1/10W 1% AEC-Q200 0402
KOA SPEER
RK73H1ETTP2433F
27
UM1550S-18
IC LIN VREG LDO 1.8V 250MA 1.8-8V SOT23-3
Union Semiconductor, Inc
UM1550S-18
510-75618
TP_35MIL
TEST POINT PAD .035 SMT, no part to order
29
RED
LED ULTRA BRIGHT RED SGL 30MA 0603
LITE ON
LTST-C190KRKT
30
180K
RES MF 180K 1/10W 1% AEC-Q200 0402
KOA SPEER
RK73H1ETTP1803F
31
74LVC2T45DC
IC TRANSLATING XCVR DUAL BIT/SUPPLY TS1.2-5.5V VSSOP8
NEXPERIA
74LVC2T45DC
32
14
470-75597
100K
RES MF 100K 1/16W 5% 0402
VENKEL COMPANY
CR0402-16W-104JT
33
ESD5B5.0ST1G
DIODE SUPPRESSOR 16A@30NS 5V@1UA SOD-523
on semiconductor
ESD5B5.0ST1G
34
DHN-04
SW 4P SPST DIP 25MA 24V SMT
DIPTRONICS MANUFACTURING
DHN-04-V
35
DNP
CON_2_RCA
CON 2 RCA SKT RA TH BLACK -- 512H SN
KYCON
KLPX-0848A-2-B
36
1.0UF
CAP CER 1.0UF 10V 10% X5R 0402
YAGEO AMERICA
CC0402KRX5R6BB105
37
UM805RE
IC VOLT MONITOR 2.63V VTH RST 1-5.5VSOT143
UM805RE
38
22UF
CAP CER 22UF 6.3V 20% X5R 0603
Samsung
CL10A226MQ8NRNE
39
22
150-76271
0.22uF
CAP CER 0.22UF 6.3V 20% X5R 0402
MURATA
GRM155R60J224ME01
40
DNP
15PF
CAP CER 15PF 16V 5% C0G 0402
KEMET
C0402C150J4GAC
41
74LVC1T45GW,125
IC XCVR XLATING DUAL 3-STATE 1.2- 5.5VTSSOP6
NEXPERIA
74LVC1T45GW,125
42
DNP
4.7K
NIC COMPONENTS CORP
NRCL04J472TRF
43
DNP
100K
VENKEL COMPANY
CR0402-16W-104JT
44
200K
RES MF 200K 1/10W 1% AEC-Q200 0402
KOA SPEER
RK73H1ETTP2003F
45
DNP
22UF
Samsung
CL10A226MQ8NRNE
46
SPST PB
SW SPST MOM NO PB TACT 50mA 50V SMT
E SWITCH
TL3301AF260QG/TR
47
49.9
RES MF 49.9 OHM 1/10W 1% 0603
BOURNS
CR0603-FX-49R9ELF
48
SKT_1X8
CON 1X8 SKT TH 100MIL SP 344H AU 118L
08001S3 0811-29RF
49
SKT_1X10
CON 1X10 SKT TH 100MIL SP 344H AU 118L
08001S3 1011-29RF
50
BH25420B301
CON 2X10 PLUG SHRD TH 100MIL CTR 366H AU118L
SHENZHEN ATOM TECHNOLOGY CO.,LTD
BH25420B301
51
DNP
TTWB1010L
XFMR SMT 780UH/780UH/250MA WIDEBANDXFMR6_6.6X6.2
COILCRAFT
TTWB1010LD
52
NTSX2102GU8H
IC DUAL SUPPLY XCVR 50 MBPS 5.5V XQFN8
NXP Semiconductors
NTSX2102GU8H
53
NTS0102
IC XCVR 2-BIT 1.65-3.6V/2.3-5.5V TSSOP8
NXP SEMICONDUCTORS
NTS0102DP
54
EM6022P
AUDIO DEVICE MIC 0.5MA 2V 38-48+/-3dB2.2KOHM 6MM TH
Soberton Inc
EM6022P
55
5006
TEST POINT BLK 70X220 MIL TH
Keystone Electronics
5006
56
FDMA530PZ
TRAN PMOS PWR 30V 6.8A
FAIRCHILD
FDMA530PZ
57
DNP
DHN-04
DHN-04-V
58
UM1750S-00
IC VREG LDO ADJ 1-5V 350mA 2.5-6V SOT23-5
UM1750S-00
59
2SK3018
TRANS MOSFET N-CH 30V .1A SOT-323
ROHM
2SK3018T106
60
CON_1X24
CON 1X24 FPC/FFC RA SKT SMT 0.5MM SP 146HSN/AU
FPC05024-09200
61
1.5K
RES MF 1.5K 1/16W 1% 0402
BOURNS
CR0402-FX-1501GLF
62
220
RES MF 220 OHM 1/10W 5% 0603
YAGEO AMERICA
RC0603JR-07220RL
63
DNP
10PF
AVX
04025A100JAT2A
64
MBR120VLSFT1G
DIODE SCH RECT 1A 20V SMT
ON SEMICONDUCTOR
MBR120VLSFT1G
65
DNP
SHORT_100mil
CON 2 JUMPER MALE 2.54MM SP 157H AU
PRECI-DIP CONNECTION TECHNOLOGY
999-11-110-10
66
100
RES MF 100 OHM 1/16W 1% 0402
THYE MING TECH CO LTD
CR-02FL6--100R
67
MP2144GJ
IC SYNC STEP-DOWN SW 1.2MHZ 0.6V 2A2.5-5.5V TSOT23-8
MONOLITHIC POWER SYSTEMS
MP2144GJ
68
40.2K
RES MF 40.2K  1/16W 1% 0402
YAGEO AMERICA
RC0402FR-0740K2L
69
TJA1057GT/3
IC XCVR CAN 4.75-5.25V/2.95-5.25VAEC-Q100 SO8
NXP SEMICONDUCTORS
TJA1057GT/3
70
30K
RES MF 30K 1/16W 1% 0402
CR02FL6-30K
71
IS42S16160J-6BLI
IC MEM DRAM 16MX16 166MHZ SYNC 3.0-3.6VTFBGA54
ISSI
IS42S16160J-6BLI
72
16
210-81490
HDR 1X2
73
15PF
KEMET
C0402C150J4GAC
74
MBRA160T3G
DIODE SCH PWR RECT 1A 60V CASE 403D
ON SEMICONDUCTOR
MBRA160T3G
75
MMBT3906TT1G
TRAN PNP GEN AMP 200MA 40V AEC-Q101 SC75
ON SEMICONDUCTOR
MMBT3906TT1G
76
3.3K
RES MF 3.3K 1/16W 5% 0402
YAGEO AMERICA
RC0402JR-073K3L
77
33UF
CAP CER 33UF 6.3V 20% X5R 1210
MURATA
GRM32DR60J336ME19L
78
464K
RES MF 464K 1/10W 1% AEC-Q200 0402
KOA SPEER
RK73H1ETTP4643F
79
1uH
IND PWR 1UH@100KHZ 2.6A 30% SMT
Shenzhen Sunlord Electronics Co., Ltd
SWPA4020S1R0NT
80
CON 1X40 + CON 1X6 + TFT DISPLAY
SUBASSEMBLY CON 1X40 FPC SMT RA + CON 1X6FPC/FFC RA SKT + TFT DISPLAY 4.3INCH
SUBASSEMBLY
211-79974,211-79976,375-00010
81
DNP
18PF
CAP CER 18PF 50V 1% C0G 0402
YAGEO
CC0402FRNPO9BN180
75.0
RES TF 75.0 OHM 1/8W 1% 0805
YAGEO AMERICA
RC0805FR-0775RL
83
0.01UF
CAP CER 0.01UF 16V 20% X7R 0402
AVX
0402YC103MAT2A
84
LED_RED-GRN
LED RED GRN DUAL 30/25MA SMT
KINGBRIGHT
APB3025ESGC-F01
85
120 Ohm
IND FER BEAD 120 OHM@100MHZ 0.5A 25% 0402
Murata
BLM15AG121SN1D
86
DNP
1M
RES MF 1M 1/10W 5% AEC-Q200 0402
KOA SPEER
RK73B1ETTP105J
87
DNP
.635" LONG
FASTENER, STANDOFF 4.5MMX3.53XM3.0X0.5ROUND THR .635"L BRASS
UNICORP
MSS251-R-1-A-16
88
GREEN
LED GRN SGL 25MA 0603
KINGBRIGHT
KPT-1608SGC
89
374
RES MF 374 OHM 1/8W 1% 0805
CRCW0805374RFKEA
90
PJ31360-I
CON 6 AUD JACK RA SMT -- 191H AU
PJ31360-I
91
NX5P3090UK
IC USB PD TYPE C CURRENT LIMITED PWR SW2.5-5.5V WLCSP12
NXP SEMICONDUCTORS
NX5P3090UK,012
92
15K
RES MF 15K  1/16W 1% 0402
WR04X1502FTL
93
DNP
0.1UF
KEMET
C0402C104K8PAC
94
MM5Z5V1ST1G
DIODE ZNR -- 0.2W 5.1V AEC-Q101 SOD523
ON SEMICONDUCTOR
MM5Z5V1ST1G
95
RJ45_YLW+GRN
CON 12 RJ45 SHLD RA SM 1.02MM SP 625H --
HanRun Electronics Co., Ltd
HR961160C
96
RES MF 10 OHM 1/10W 5% 0603
BOURNS
CR0603-JW-100ELF
97
DNP
1000pF
CAP CER 1000PF 50V 5% C0G 0402
MURATA
GRM1555C1H102JA01D
98
100K
RES MF 100K 1/16W 1% 0402
YAGEO AMERICA
RC0402FR-07100KL
99
USB_MICROAB_RECEPTACLE
CON 5 USB MICRO_AB RA SKT SMT 0.65MM SP 110HAU
23971101#LCP-58RF
100
270
RES MF 270 OHM 1/16W 5% 0402
Yageo
RC0402JR-07270RL
101
27PF
CAP CER 27PF 50V 5% C0G 0402
KEMET
C0402C270J5GAC
102
BSH111BK
TRAN NMOS SW FET 55V 210mA SOT23
NEXPERIA
BSH111BKR
103
KSZ8081RNB
IC XCVR 10/100M EPHY 3.3V QFN32
Micrel
KSZ8081RNBIA
104
S26KS512SDPBHI02
IC MEM FLASH 512 Mbit (64 Mbyte) OctalSPI 1.8V 166MHz BGA24
CYPRESS SEMICONDUCTOR
S26KS512SDPBHI02
105
24MHZ
XTAL 24MHZ -- 30PPM 3.2X2.5MM SMD
TXC CORP
7V24000002
106
62.0
RES MF 62.0 OHM 1/4W 1% AEC-Q200 0805
KOA SPEER
RK73H2ATTD62R0F
107
56PF
CAP CER 56PF 50V 5% C0G 0402
MURATA
GRM1555C1H560JA01D
108
DNP
SRV05-4
DIODE TVS ARRAY 12A 5V 300W SOT23_S6
SEMTECH CORP
SRV05-4.TCT
109
IRLML6401
TRAN PMOS PWR 12V 4.3A SOT23
INTERNATIONAL RECTIFIER
IRLML6401TRPBF
110
RClamp0854P.TCT
DIODE TVS ARRAY 3 5.5V SLP1616P6
SEMTECH CORP
RClamp0854P.TCT
111
NL17SZ126DF
IC BUF TS 1.65-5.5V SOT-353
ON SEMICONDUCTOR
NL17SZ126DFT2G
112
2.2uF
CAP CER 2.2uF 6.3V 10% X5R 0402
MURATA
GRM155R60J225KE95
113
TPAD_030
TEST POINT PAD 30MIL DIA SMT, NO PART TOORDER
NOTACOMPONENT
NOTACOMPONENT
114
100
RES MF 100 OHM 1/16W 5% 0402
YAGEO AMERICA
RC0402JR-07100RL
115
CON_1_PWR
CON 1 PWR PLUG RA TH 2.5A 20V -- 441HSN/NI
DC060024202
116
IS25WP064AJBLE
IC MEM FLASH QPI 64Mb 1.65-1.95V SOIC8W
ISSI
IS25WP064A-JBLE
117
NX3P191UK
IC LOAD SW 1A 1.1-3.6V WLCSP4
NXP SEMICONDUCTORS
NX3P191UK,012
118
LPC4322JET100
IC MCU CORTEX M4 CORE 512kB FLASH 2.4-3.6V BGA100
NXP SEMICONDUCTORS
LPC4322JET100E
119
1000pF
MURATA
GRM1555C1H102JA01D
120
12MHZ
XTAL 12MHZ RSN -- 18PF 30PPM SMT
ABRACON CORP
ABLS2-12.000MHZ-D4Y-T
121
WM8960
IC CODEC STEREO WITH CLASS D SPEAKERDRIVER 1.71-3.6V QFN32
WOLFSON MICROELECTRONICS
WM8960CGEFL/RV
122
32.768KHZ
XTAL 32.768KHZ 7PF 20PPM -- SMT
EPSON ELECTRONICS
FC-135 32.7680KA-AG3
123
UM803RS
IC VOLT MONITOR 2.63V RST VTH 1-5.5V AUTOSOT-23
UM803RS
124
HDR 2X5
HDR 2X5 TH 100MIL CTR 338H AU 98L
0902S1005011N9T-31RF
125
DNP
ACT45B-510-2P
FILTER COMMON MODE 51uH@100kHZ 200mA 50VAEC-Q200 SMT
TDK
B82787C513H2
126
DNP
33K
RES MF 33K  1/16W 1% 0402
YAGEO AMERICA
RC0402FR-0733KL
127
95220030-14RRF
CON 8 SKT SD/MMC RA SMT 43MIL SP 84H AU
95220030-14RRF
128
NC7WV04L6X
IC INVERTER ULP-A DUAL 0.93.6V MICROPAK6
FAIRCHILD
NC7WV04L6X
129
TMP-WF-33767
MIMXRT1064DVL6A
IC CPU ARM Cortex-M7 600MHZ 1.3VMAPBGA196
NXP SEMICONDUCTORS
MIMXRT1064DVL6A
130
2.2M
RES MF 2.2M 1/10W 1% AEC-Q200 0402
KOA SPEER
RK73H1ETTP2204F
131
UM1661
IC DCDC LED DRIVER BOOST 500KHz-2MHz 24V1.5A 2-6V SOT23-6
UM1661
132
10uH
IND WW FER 10uH@1MHz 0.99A 20% 4012
TDK
VLS4012ET-100M
133
DNP
0.01UF
AVX
0402YC103MAT2A
134
SKT_1X6
CON 1X6 SKT TH 100MIL SP 344H AU 118L
08001S3 0611-29RF
135
PRTR5V0U2X
IC USB ESD PROTECTION 8KV SOT143
PHILIPS SEMICONDUCTOR
PRTR5V0U2X
136
HDR_1X3
HDR 1X3 TH 100MIL SP 338H AU 98L
0901S0203011N9T-31RF
137
EG2209A
SW DPDT SLD 0.1A 12V L=4 TH
E SWITCH
EG2209A
138
DNP
HDR_1X3
139
220PF
CAP CER 220PF 50V 5% C0G 0402
KEMET
C0402C221J5GAC
140
HDR 2X5
HDR 2X5 TH 50MIL CTR 172H AU 91L
0922S0205011N9T-31RF
141
1M
KOA SPEER
RK73B1ETTP105J
重要提示:PCB作品文件展下载说明
 楼主| 发表于 2018-12-4 20:09:35 | 显示全部楼层
SCH-32221_A.DSN.rar (566 KB, 下载次数: 4) LAY-32221_A.brd.rar (3.89 MB, 下载次数: 4)
1元学习Allegro(1期)
发表于 2018-12-4 22:27:06 | 显示全部楼层
 楼主| 发表于 2018-12-4 22:49:16 | 显示全部楼层
