查看: 1717|回复: 1
[AD格式] 评估板:STM8L1526_EVAL
发表于 2018-12-5 22:55:10 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
en.stm8l1526-eval.zip (1.59 MB, 下载次数: 8)
Bill of Material for
On 2018/12/5/周三 at 21:30:15
Comment             Pattern     Quantity  Components
[N/A]               0603C           11    C17, C39, C41, C42, C44, C46
                                           C47, C54, C64, C72, C86
[N/A]               0603R            9    C35, R40, R59, R68, R74, R82
                                           R96, R98, R99
[N/A]               0805R            1    R29
[N/A]               3314-J           1    RV3
[N/A]               SOT-23           2    T5, T6
                     JP2_SMD          4    SB1, SB2, SB5, SB6
                     SIP2             6    JP3, JP4, JP8, JP9, JP14
                                           JP15
                     SIP3             7    JP1, JP5, JP6, JP7, JP10
                                           JP11, JP13
+3V3                TP               1    TP3
0                   0603R           23    R16, R27, R32, R37, R38, R44
                                           R48, R50, R51, R52, R53, R56
                                           R60, R63, R71, R73, R76, R77
                                           R83, R85, R94, R126, R127
0                   0805R           16    R28, R31, R34, R35, R39, R42
                                           R55, R58, R62, R66, R69, R75
                                           R80, R111, R115, R116
1.2K                0603R            1    R8
100                 0603R            4    R12, R72, R104, R122
100K                0603R            5    R18, R21, R64, R88, R105
100nF               0603C           44    C1, C3, C4, C5, C6, C9, C10
                                           C14, C15, C16, C18, C21, C23
                                           C24, C31, C33, C34, C40, C49
                                           C50, C51, C52, C55, C56, C57
                                           C58, C59, C61, C62, C63, C65
                                           C68, C69, C70, C71, C74, C76
                                           C78, C79, C80, C81, C82, C83
                                           C84
10K                 0603R           16    R10, R17, R30, R45, R46, R57
                                           R61, R65, R67, R70, R78, R89
                                           R117, R119, R123, R124
10K                 3296W            1    RV2
10nF                0603C            1    C36
10uF                TAN-A            4    C12, C19, C20, C22
124[1%]             0603R            1    R23
15K                 0603R            2    R20, R90
16MHz (with socket) XTAL_SOCKET      1    X1
180pF               0603C            1    C29
18K                 0603R            1    R25
1K                  0603R            8    R6, R9, R15, R19, R81, R86
                                           R87, R97
1K5                 0603R            1    R109
1nF                 0603C            2    C66, C73
1uF                 0603C            1    C60
1uF                 TAN-A            6    C28, C37, C48, C53, C67, C85
2.2K                0603R            1    R11
2.2uF               TAN-A            1    C26
2.4" LCD connector (MB542 with AM240320L8TNQW-00H) MB542            1    CN3
2[1%]               0603R            1    R92
20P                 0603C            2    C75, C77
20pF                0603C            2    C30, C38
214017              SMD214012        1    CN16
22                  0603R            3    R1, R107, R108
220uF               C310M-6          1    C8
22K                 0603R            2    R33, R36
2K[1%]              0603R            1    R91
2K2[1%]             0603R            1    R125
3.3K                0603R            1    R95
300                 0603R            2    R4, R5
30K                 0603R            1    R84
330                 0805R            1    R43
330pF               0603C            1    C45
3386P-201H[5%]      3296W            1    RV1
4.7uF               TAN-A            4    C2, C7, C13, C27
40.2[1%]            0603R            1    R14
47                  0603R            3    R7, R100, R121
470nF               0603C            1    C43
47pF                0603C            1    C11
4K7                 0603R            8    R79, R102, R106, R112, R113
                                           R114, R118, R120
5                   0603R            1    R3
50                  0603R            1    R110
500                 0805R            1    R13
510                 0603R            1    R103
5V                  TP               1    TP4
6.8pF               0603C            2    C25, C32
60                  0603R            1    R26
609-1306-ND(2.54mm) SIP4             1    CN12
680                 0603R            5    R2, R22, R41, R93, R101
680                 0805R            3    R47, R49, R54
74LV4060PW          TSSOP16          1    U23
82K                 0603R            1    R24
8MHz                XTAL1            1    X3
9012                SOT-23           1    T7
9013                SOT-23           3    T1, T4, T8
AIN-                TP               1    TP5
AIN+                TP               1    TP8
BAT60               SOD-323          1    D1
BEAD                0603L            1    L1
Blue                0603D            1    LD4
BNX002-01           BNX001           1    U3
BSN20               SOT-23           2    TR1, TR2
CCO                 TP               1    TP9
DB9-male UART2      DB9/M            1    CN1
DC-10B              DC10B            1    CN2
Green               0603D            1    LD1
Ground              TP               1    TP1
Header 13X2 on the left 2*13P            1    CN4
Header 13X2 on the right 2*13P            1    CN10
Header 18X2         2*18P            1    CN5
Header 3X2          2*3P             1    JP2
Header              2*18P            1    CN6
JTAG                JTAG             1    CN9
KDMG15008-03        KS1508           1    U24
KECG2740TBL         KEC2740          1    U4
L-317EGW-SS         D0.1             1    LD5
LD1086D2M           D2PAK/A          1    U12
LD1086D2M33         D2PAK/A          1    U13
LM393PT             TSSOP8(6.4)      1    U6
M24C64-FDW5TP       TSSOP8(6.4)      1    U29
M25P128-VME6G       VDFPN8(8*6)      1    U18
MAX9938FEUK+        SOT-23-5L        1    U20
MC_connector        IDC34S           1    CN7
MC306-G-06Q-32.768 (manufacturer JFVNY) SM8              1    X2
MIC_OUT             TP               1    TP6
MIC+                TP               1    TP7
MT008-A             JOY              1    U17
Orange              0603D            1    LD2
PJS008-2000 (SMS064FF or SMS128FF) MSD(PJS008)      1    CN14
QTH-030-01-L-D-A    QTH-030-01-L-D-A    1    CN8
Red                 0603D            4    LD3, LD7, LD8, LD9
RESET (Black)       PB10             1    B1
SFH409-2            D0.1L            1    LD6
SMAJ5.0A-TR         1R1C             1    Z1
SN74LVC1G04DCKT     PDSO-G5          1    U25
SN74LVC1G66DCKT     PDSO-G5          1    U21
SN74LVC2T45DCUT     VSSOP8           6    U1, U10, U11, U19, U22, U26
solder bridge       JP3_SMD          3    SB3, SB4, SB7
ST3241EBPR          SSOP28           1    U8
ST-613              PJST-613         1    CN13
STLM75M2E           SO8              1    U28
STM32F103C8T6       LQFP48           1    U27
STM8L152C6T6        IC234-0484-039    1    U16
STM8L152C6T6        LQFP48           1    U14
STT5PF20V           SOT23-6L         2    T2, T3
TFDU4300            IR_VISHAY3       1    U2
TS461CLT            SOT-23-5L        1    U9
TS4990IST           MSOP8            1    U15
USB-typeB connector USB-B            1    CN11
USER (Blue)         PB10             1    B2
VB334               VB334            1    CN15
VDD_ADJ             TP               1    TP2
ZEN056V130A24LS     polyzen          1    U5
ZYMG12232B-GB1      LCD12232-GB1     1    U7
重要提示:PCB作品文件展下载说明
    发表于 2018-12-6 08:49:46 | 显示全部楼层
