Item Number |
Part Reference |
ASSY_OPT |
Value |
MFG_PN01 |
DESCRIPTION |
1 |
BAR1 |
ShortingBar1206 |
TEST POINT SHORTBAR1206, NO PART TO ORDER |
2 |
C1 C4 C8 C10 C11 C12 C14 C15 C16 C17 C19 |
2200PF |
06035C222KAT2A |
CAP CER 2200PF 50V 10% X7R 0603 |
3 |
C2 C5 C20 C21 C24 C34 |
2.2UF |
LMK107B7225KA-T |
CAP CER 2.2UF 10V 10% X7R 0603 |
4 |
C3 C6 C7 C25 C26 C27 C28 C30 C35 C36 |
0.10UF |
0603YC104JAT2A |
CAP CER 0.10UF 16V 5% X7R 0603 |
5 |
C9 C13 C18 |
330pF |
CC0603KRX7R8BB331 |
CAP CER 330pF 25V 10% X7R 0603 |
6 |
C22 C23 |
22 PF |
C0603C220J5GAC |
CAP CER 22PF 50V 5% C0G 0603 |
7 |
C29 C31 |
22UF |
GRM21BR60J226ME39L |
CAP CER 22UF 6.3V 20% X5R 0805 |
8 |
C32 C33 |
10uF |
LMK107BJ106MALTD |
CAP CER 10UF 10V 20% X5R 0603 |
9 |
C37 C38 |
1000pF |
GA352QR7GF102KW01L |
CAP CER 1000pF 250V X7R 10% 2211 |
10 |
D1 |
RED |
HSMH-C170 |
LED RED SGL 20MA 0805 |
11 |
D2 D4 D8 |
HSMG-C170 |
HSMG-C170 |
LED GREEN SGL 2.2V 20MA 0805 |
12 |
J1 J3 |
DNP |
HDR 2X5 |
0922S0205011N6T-2LF |
HDR 2X5 TH 50MIL CTR 167H AU 91L |
13 |
J2 |
CONN USB MINI-B |
1734035-2 |
CON 5 USB_MINI_B_RECEPTACLE RA SMT 0.8MM168H AU |
14 |
J4 |
PCI express x4 edge connector |
TBD |
CON 64 PCI EXPRESS X4 EDGE FOR ADD-INCARD, NO PART TO ORDER |
15 |
L1 L2 |
330 OHM |
MPZ2012S331A |
IND FER BEAD 330OHM@100MHZ 2.5A -- SMT |
16 |
R1 R3 R4 R5 R6 R7 R8 R9 R10 R11 R12 R13R14 R15 |
100 |
CRCW0603100RFKEA |
RES MF 100 OHM 1/10W 1% AEC-Q200 0603 |
17 |
R16 R24 R39 R85 |
330 |
RK73H1JTTD3300F |
RES MF 330 OHM 1/10W 1% 0603 |
18 |
R17 R18 R22 R23 R26 |
10K |
RK73B1JTTD103J |
RES MF 10K 1/10W 5% 0603 |
19 |
R19 R20 |
33 |
RK73H1JTTD33R0F |
RES MF 33 OHM 1/10W 1% 0603 |
20 |
R21 R25 R36 R37 R38 |
4.7K |
CRCW06034K70JNEA |
RES MF 4.7K 1/10W 5% 0603 |
21 |
R27 |
1.0 |
RK73H1JTTD1R00F |
RES MF 1.00 OHM 1/10W 1% 0603 |
22 |
R28 R29 R31 R32 R33 R34 R35 R86 R87 |
2.7K |
RK73B1JTTD272J |
RES MF 2.7K 1/10W 5% 0603 |
23 |
R88 R89 |
0 |
MC0603SAF0000T5E |
RES MF ZERO OHM 1/10W 1% 0603 |
24 |
SW1 |
EVQ-PE105K |
EVQPE105K |
SW SPST NO 0.05A 12V SMD |
25 |
TP1 TP2 TP5 TP6 TP7 |
TPAD_030 |
NOTACOMPONENT |
TEST POINT PAD 30MIL DIA SMT, NO PART TOORDER |
26 |
TP3 TP4 |
TP_PTH |
NOTACOMPONENT |
TEST POINT PAD 035-018MIL TH, NO PART TOORDER |
27 |
TP8 TP9 TP10 TP11 TP12 TP13 TP14 TP15TP16 TP17 |
TEST_POINT |
NO PART TO ORDER |
TEST POINT TH PAD 60 DRILL 39 DIAM, NOPART TO ORDER |
28 |
U1 |
MKV10Z32VLF7 |
MKV10Z32VLF7 |
IC MCU 32BIT 32KB FLASH 8KB RAM 75MHz1.8-3.6V LQFP48 |
29 |
U2 |
MK20DX128VFM5 |
MK20DX128VFM5 |
IC MCU FLASH 128KB 50MHZ 1.71-3.6V QFN32 |
30 |
U3 |
GSOT05C-GS08 |
GSOT05C-GS08 |
DIODE ESD 2LINE 5V SOT23 |
31 |
U4 |
74LVC125 |
74LVC125ABQ,115 |
IC QUAD BUF LINE DRV TS 1.2-3.6V DHVQFN14 |
32 |
U5 |
Si8605AD-B-IS |
Si8605AD-B-IS |
IC ISOLATOR 2 I2C CH BIDIR 3-5.5VAEC-Q100 SO16W |
33 |
U6 |
ADuM6201 |
ADuM6201ARWZ |
IC ISOLATOR 2CH W/ DC/DC CONVERTER5V/3.3V SO16 |
34 |
U7 |
NCP1117ST33T3G |
NCP1117ST33T3G |
IC VREG LDO 1A 3.3V SOT223 |
35 |
Y1 |
8MHZ |
ABM3B-8.000MHZ-B2-T |
XTAL 8MHZ 20PPM PAR 18PF ESR 200OHM SMT |
