Bill of Material ReportSYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_TOL | COMP_CLASS | REFDES |
PI_DAX_BRIDGE_RS605_H | DIODE BRIDGE_1234_PI_DAX_BRIDGE | RS605 | | IC | BR1 |
PINPYCAPRAD540X290LS400040 | CAP NP_PINPYCAPRAD540X290LS4000 | 1 nF | | IC | C1 |
PINPYCAPRAD540X290LS400040 | CAP NP_PINPYCAPRAD540X290LS4000 | 1 nF | | IC | C2 |
PINPCAPRAD550X395490030HORZ | CAP NP_PINPCAPRAD550X395490030H | 220 nF | | IC | C3 |
PINPYCAPRAD540X290LS400040 | CAP NP_PINPYCAPRAD540X290LS40_1 | 2.2 nF | | IC | C4 |
PINPYCAPRAD540X290LS400040 | CAP NP_PINPYCAPRAD540X290LS40_1 | 2.2 nF | | IC | C5 |
PINPCAPRAD550X395490030HORZ | CAP NP_PINPCAPRAD550X395490030H | 220 nF | | IC | C6 |
PI_NP_CAPRAD512X345LS394D040 | CAP NP_PI_NP_CAPRAD512X345LS394 | 470 nF | | IC | C7 |
PISMC0805 | CAP NP_PISMC0805_1 UF | 1 uF | | IC | C8 |
PISMC0805 | CAP NP_PISMC0805_1 UF | 1 uF | | IC | C9 |
PISMC0805 | CAP NP_PISMC0805_470 PF | 470 pF | | IC | C10 |
PISMC0805 | CAP NP_PISMC0805_100 NF | 100 nF | | IC | C11 |
PISMC0805 | CAP NP_PISMC0805_1 UF | 1 uF | | IC | C12 |
PI_NP_CAP250X200LS170D030 | CAP NP_PI_NP_CAP250X200LS170D03 | 10 nF | 20 | IC | C13 |
PISMC0805 | CAP NP_PISMC0805_470 PF | 470 pF | | IC | C14 |
PI_PCAP_D500LS200_040_2000H | CAP POL_PI_PCAP_D500LS200_040_2 | 82 uF | | IC | C15 |
PINPCAPRAD350X100200030 | CAP NP_PINPCAPRAD350X100200030_ | 2.2 nF | 10 | IC | C16 |
PISMC0603 | CAP NP_PISMC0603_1000 PF | 1000 pF | | IC | C17 |
PISMC0603 | CAP NP_PISMC0603_100 PF | 100 pF | | IC | C18 |
PISMC0603 | CAP NP_PISMC0603_100 NF | 100 nF | | IC | C19 |
PISMC0805 | CAP NP_PISMC0805_4.7 UF | 4.7 uF | | IC | C20 |
PIPOLCAPCLYD200LS80030 | CAP POL_PIPOLCAPCLYD200LS80030_ | 22 uF | | IC | C21 |
PISMC0805 | CAP NP_PISMC0805_* | * | | IC | C22 |
PISMC0805 | CAP NP_PISMC0805_100 NF | 100 nF | | IC | C23 |
PINPYCAPRAD540X290LS400040 | CAP NP_PINPYCAPRAD540X290LS40_1 | 2.2 nF | | IC | C24 |
PINPYCAPRAD540X290LS400040 | CAP NP_PINPYCAPRAD540X290LS40_1 | 2.2 nF | | IC | C25 |
PISMC0805 | CAP NP_PISMC0805_470 PF_10 | 470 pF | 10 | IC | C26 |
PISMC1206 | CAP NP_PISMC1206_1 UF | 1 uF | | IC | C27 |
PIPOLCAPCLYD500LS2000401200LH | CAP POL_PIPOLCAPCLYD500LS200040 | 1200 uF | 20 | IC | C28 |
PIPOLCAPCLYD395X630LS200030H | CAP POL_PIPOLCAPCLYD395X630LS20 | 330 uF | 20 | IC | C29 |
PISMC0805 | CAP NP_PISMC0805_470 PF_10 | 470 pF | 10 | IC | C30 |
PISMC1206 | CAP NP_PISMC1206_1 UF | 1 uF | | IC | C31 |
PIPOLCAPCLYD500LS2000401200LH | CAP POL_PIPOLCAPCLYD500LS2000_1 | 1800 uF | 20 | IC | C32 |
PIPOLCAPCLYD395X630LS200030H | CAP POL_PIPOLCAPCLYD395X630LS_1 | 470 uF | 20 | IC | C33 |
PIDAX800X225060DO15DO201AD | DIODE_PIDAX800X225060DO15DO201A | 1N5408-T | | IC | D1 |
PIDV200X110X040DO41 | DIODE_PIDV200X110X040DO41_FR107 | FR107-B | | IC | D2 |
PIDV200X110X040DO41 | DIODE_PIDV200X110X040DO41_FR107 | FR107-B | | IC | D3 |
PIDVTO2203VF1H | DS_DUAL_CK_AKA_PIDVTO2203VF1H_S | STPS10150CT | | IC | D4 |
PIDVTO2203VF1H | DS_DUAL_CK_A_AC_PIDVTO2203VF1H_ | STPS30100ST | | IC | D5 |
PIDAX475X125040DO41 | DIODE_PIDV200X110X040DO41_FR107 | FR107-B | | IC | D6 |
PI_TR5_SUBMIN_FUSE | FUSE_PI_TR5_SUBMIN_FUSE_2 A | 2 A | | IC | F1 |
PI_HS_PFS3_LNKHP110W | HS-PI_CUSTOM_0_PI_HS_PFS3_LNKHP | HEATSINK,FAB, W/PINS, PI CUST | | IC | HS1 |
PI_HS_PFS3_LNKHP110W | HS-PI_CUSTOM_1_PI_HS_PFS3_LNKHP | HEATSINK,FAB, W/PINS, PI CUST | | IC | HS2 |
PI_HS_DIODES_SEC_DER393 | HS-PI_CUSTOM2_PI_HS_DIODES_SEC_ | HEATSINK, FAB,W/EYELET, PI CUST | | IC | HS3 |
PI_HDR_6PIN_LOCK | CON6_PI_HDR_6PIN_LOCK_CON6 | CON6 | | IC | J1 |
PI_JUMPER500 | JUMPER_1_PI_JUMPER500_J | J | | IC | JP1 |
PI_JUMPER600 | JUMPER_1_PI_JUMPER600_J | J | | IC | JP2 |
PI_JUMPER1200 | JUMPER_1_PI_JUMPER1200_J | J | | IC | JP3 |
PI_JUMPER300 | JUMPER_1_PI_JUMPER300_J | J | | IC | JP4 |
PI_JUMPER400 | JUMPER_1_PI_JUMPER400_J | J | | IC | JP5 |
PI_JUMPER1700 | JUMPER_1_PI_JUMPER1700_J | J | | IC | JP6 |
PI_JUMPER1600 | JUMPER_1_PI_JUMPER1600_J | J | | IC | JP7 |
PI_JUMPER300 | JUMPER_1_PI_JUMPER300_J | J | | IC | JP8 |
PI_JUMPER300 | JUMPER_1_PI_JUMPER300_J | J | | IC | JP9 |
PI_JUMPER700 | JUMPER_1_PI_JUMPER700_J | J | | IC | JP10 |
PI_JUMPER900 | JUMPER_1_PI_JUMPER900_J | J | | IC | JP11 |
PI_JUMPER1200-18AWG-SLD | JUMPER_1_PI_JUMPER1200-18AWG-SL | J | | IC | JP12 |
PI_4P_700X400D055_HORIZ | INDUCTOR_4P_REVD_PI_IND_4P_690X | 10mH | | IC | L1 |
PI_BOBBIN_PQ38_6P | BPQ38/6P/GENERIC_PI_BOBBIN_PQ38 | PQ38 | | IC | L2 |
PI_2P_700X400D055_HORIZ | INDUCTOR_PI_2P_700X400D055_HORI | 470uH | | IC | L3 |
PI_CHOKE_TOK441LS197D043 | INDUCTOR_PI_CHOKE_TOK441LS197D0 | 1.0 uH | 0.2 | IC | L4 |
PI_CHOKE_TOK441LS197D043 | INDUCTOR_PI_CHOKE_TOK441LS197D0 | 1.0 uH | 0.2 | IC | L5 |
PIMTGHOLE4 | MTG_HOLE_6-32_PIMTGHOLE4_NO 4 | No 4 | | IC | MTG_HOLE4 |
PIMTGHOLE4 | MTG_HOLE_6-32_PIMTGHOLE4_NO 4 | No 4 | | IC | MTG_HOLE5 |
PIMTGHOLE4 | MTG_HOLE_6-32_PIMTGHOLE4_NO 4 | No 4 | | IC | MTG_HOLE6 |
PIMTGHOLE4 | MTG_HOLE_6-32_PIMTGHOLE4_NO 4 | No 4 | | IC | MTG_HOLE7 |
PISMSOT23132 | NPN_BEC_PISMSOT23132_MMBT4401LT | MMBT4401LT1G | | IC | Q1 |
PISMSOT23132 | NPN_BEC_PISMSOT23132_MMBT4401LT | MMBT4401LT1G | | IC | Q2 |
PISMR1206 | R_PISMR1206_620 K | 620 k | | IC | R1 |
PISMR1206 | R_PISMR1206_620 K | 620 k | | IC | R2 |
PISMR1206 | R_PISMR1206_620 K | 620 k | | IC | R3 |
PISMR1206 | R_PISMR1206_6.2 M | 6.2 M | | IC | R4 |
PISMR1206 | R_PISMR1206_6.2 M | 6.2 M | | IC | R5 |
PI14WRESD100LS500D030 | R_PI14WRESD100LS500D030_3.74 M_ | 3.74 M | | IC | R6 |
PISMR0805 | R_PISMR0805_162 K | 162 k | | IC | R7 |
PISMR1206 | R_PISMR1206_10 K | 10 k | | IC | R8 |
PISMR1206 | R_PISMR1206_30.1 K | 30.1 k | | IC | R9 |
PI14WRESD100LS500D030 | R_PI14WVRESD100LS100D030_3.74 M | 3.74 M | | IC | R10 |
PISMR1206 | R_PISMR1206_6.2 M | 6.2 M | | IC | R11 |
PISMR1206 | R_PISMR1206_6.2 M | 6.2 M | | IC | R12 |
PISMR0805 | R_PISMR0805_162 K | 162 k | | IC | R13 |
PI12WRESD180LS675D040 | R_PI12WRESD180LS675D040_1 K_5%_ | 1 k | 5% | IC | R14 |
PI12WRESD180LS675D040 | R_PI12WRESD180LS675D040_4.7_PI1 | 4.7 | | IC | R15 |
PISMR0603 | R_PISMR0603_124 K | 124 k | | IC | R16 |
PISMR0603 | R_PISMR0603_100 K | 100 k | | IC | R17 |
PISMR0805 | R_PISMR0805_6.8 K | 6.8 k | | IC | R18 |
PISMR1206 | R_PISMR1206_3.3 | 3.3 | | IC | R19 |
PI14WRESD100LS400D030 | R_PI14WRESD100LS400D030_61.9 K_ | 61.9 k | | IC | R20 |
PISMR0603 | R_PISMR0603_8.66 K | 8.66 k | | IC | R21 |
PISMR0805 | R_PISMR0805_2 K | 2 k | | IC | R22 |
PISMR0805 | R_PISMR0805_330 K | 330 k | | IC | R23 |
PISMR0603 | R_PISMR0603_2 K | 2 k | | IC | R24 |
PI12WVRESD180LS150D040 | R_PI12WVRESD180LS150D040_30_5%_ | 30 | 5% | IC | R25 |
PI12WVRESD180LS150D040 | R_PI12WVRESD180LS150D040_30_5%_ | 30 | 5% | IC | R26 |
PI12WVRESD180LS150D040 | R_PI12WVRESD180LS150D040_15_5%_ | 15 | 5% | IC | R27 |
PISMR1206 | R_PISMR1206_20 K | 20 k | | IC | R28 |
PISMR1206 | R_PISMR1206_24 K | 24 k | | IC | R29 |
PI_RAD150X300LS200D030 | THERMISTOR_PI_RAD150X300LS200D0 | 2.5 | | IC | RT1 |
PI_RAD450X550LS300D040_H | VARISTOR_PI_RAD450X550LS300D040 | 320 Vac | | IC | RV1 |
PI_BOBBIN_PQ3812_10P_1800LS | BPQ3812/10P/GENERIC_PI_BOBBIN_P | XXXX | | IC | T1 |
PITPKEYSTONE125X125 | TESTPOINT_PITPKEYSTONE125X125_C | CON1 | | IC | TP1 |
PITPKEYSTONE125X125 | TESTPOINT_PITPKEYSTONE125X125_C | CON1 | | IC | TP2 |
PIICLBENDESIPLG | DEV_HIPERPFS-3-ESIP-16C_PIICLBE | PFS7524L | | IC | U1 |
PI_IC_EDIP_11-12P | DEV_LNKHP_EDIP_ESOP_PI_IC_EDIP_ | LNK6777V | | IC | U2 |
PI_SM_SOD-123_12 | DIODE_ZENER_PI_SM_SOD-123_12_MM | MMSZ4700T1G | | IC | VR1 |
PIDV200X140X050DO15DO204AC | DIODE_ZENER_PIDV200X140X050DO15 | P6KE150A | | IC | VR2 |
