查看: 3770|回复: 10
[Allegro17.4以下] 采用桥式开关电机驱动器和Link开关TN2的300 W三相逆变器原
PADS-180606高级班
社区居民终身成就奖特殊贡献奖优秀斑竹奖
发表于 2018-12-6 16:25:11 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
2层456PIN   300 W 3-Phase Inverter Using BridgeSwitch Motor Driver and LinkSwitch-TN2.zip (588 KB, 下载次数: 31) [/hide]
Bill of Material ReportSYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_TOLCOMP_CLASSREFDESPI_MILLMAX030DTERM_1PIN_PI_MILLMAX030D_CON1CON1 IC+5VPI_MILLMAX030DTERM_1PIN_PI_MILLMAX030D_CON1CON1 ICAINB10PI_MILLMAX030DTERM_1PIN_PI_MILLMAX030D_CON1CON1 ICAINB11PI_MILLMAX030DTERM_1PIN_PI_MILLMAX030D_CON1CON1 ICAINB12PI_MILLMAX030DTERM_1PIN_PI_MILLMAX030D_CON1CON1 ICBPL_UPI_MILLMAX030DTERM_1PIN_PI_MILLMAX030D_CON1CON1 ICBPL_VPI_MILLMAX030DTERM_1PIN_PI_MILLMAX030D_CON1CON1 ICBPL_WPISMC0805CAP NP_PISMC0805_100 PF100 pF ICC1PISMC1812CAP NP_PISMC1812_220 NF220 nF ICC2PISMC1206CAP NP_PISMC1206_4.7 UF4.7 uF ICC3PISMC0603CAP NP_PISMC0603_1000 PF1000 pF ICC4PISMC0603CAP NP_PISMC0603_470 PF470 pF ICC5PISMC0603CAP NP_PISMC0603_1 NF1 nF ICC6PISMC0603CAP NP_PISMC0603_100 NF100 nF ICC7PISMC0805CAP NP_PISMC0805_100 PF100 pF ICC8PISMC0603CAP NP_PISMC0603_4.7UF4.7uF ICC9PISMC0603CAP NP_PISMC0603_1 NF1 nF ICC10PISMC0603CAP NP_PISMC0603_100 NF100 nF ICC11PISMC0805CAP NP_PISMC0805_4.7 UF4.7 uF ICC12PISMC0603CAP NP_PISMC0603_1 NF1 nF ICC13PISMC0603CAP NP_PISMC0603_100 NF100 nF ICC14PISMC0603CAP NP_PISMC0603_1000 PF1000 pF ICC15PISMC0603CAP NP_PISMC0603_1 UF_PISMC06031 uF ICC16PISMC0805CAP NP_PISMC0805_4.7 UF4.7 uF ICC17PISMC0603CAP NP_PISMC0603_470 PF470 pF ICC18PISMC0603CAP NP_PISMC0603_10 NF10 nF ICC19PISMC0805CAP NP_PISMC0805_100 PF100 pF ICC20PISMC1812CAP NP_PISMC1812_220 NF220 nF ICC21PISMC1206CAP NP_PISMC1206_4.7 UF4.7 uF ICC22PISMC0603CAP NP_PISMC0603_1000 PF1000 pF ICC23PIPOLCAPCLYD710LS300040CAP POL_PIPOLCAPCLYD710LS30004047 uF ICC24PISMC0603CAP NP_PISMC0603_470 PF470 pF ICC25PISMC0603CAP NP_PISMC0603_1 UF_PISMC06031 uF ICC26PISMC0603CAP NP_PISMC0603_100 NF100 nF ICC27PISMC0603CAP NP_PISMC0603_1 UF1 uF ICC28PISMC0603CAP NP_PISMC0603_100 NF100 nF ICC29PISMC0805CAP NP_PISMC0805_10 UF10 uF ICC30PISMC0603CAP NP_PISMC0603_100 NF100 nF ICC31PISMC1812CAP NP_PISMC1812_220 NF220 nF ICC32PIPOLCAPCLYD200LS80030CAP POL_PIPOLCAPCLYD200LS80030_100 uF ICC33PISMC1206CAP NP_PISMC1206_4.7 UF4.7 uF ICC34PISMC0603CAP NP_PISMC0603_100 NF100 nF ICC35PISMC0603CAP NP_PISMC0603_1 UF_PISMC06031 uF ICC36PISMC0805CAP NP_PISMC0805_4.7 UF4.7 uF ICC37PISMC0603CAP NP_PISMC0603_100 NF100 nF ICC38PISMC0805CAP NP_PISMC0805_4.7 UF4.7 uF ICC39PISMC0603CAP NP_PISMC0603_1 UF1 uF ICC40PISMC0603CAP NP_PISMC0603_1 UF1 uF ICC41PI_SM_D_0603LED_PI_SM_D_0603_GREENGreen ICD1PISMDO214AC12DIODE SCHOTTKY_PISMDO214AC12_SSSS13-E3/61T ICD2PISMDO214AC12DIODE SCHOTTKY_PISMDO214AC12_SSSS13-E3/61T ICD3PIDV300X200X060DO15D0201ADDIODE_PIDV300X200X060DO15D0201A1N5404-E3/54 ICD4PISMDO214AC12DIODE SCHOTTKY_PISMDO214AC12_SSSS13-E3/61T ICD5PISMDDFLR120012DIODE_PISMDDFLR120012_DFLR1600-DFLR1600-7 ICD6PI_SM_SOD-123_12DIODE_PI_SM_SOD-123_12_UFM15PL-UFM15PL-TP ICD7FUSE_EFUSE_FUSE_E_FUSE HOLDERFuse Holder ICF1PI_MILLMAX030DTERM_1PIN_PI_MILLMAX030D_CON1CON1 ICFAULTPI_MILLMAX030DTERM_1PIN_PI_MILLMAX030D_CON1CON1 ICGNDPI_MILLMAX030DTERM_1PIN_PI_MILLMAX030D_CON1CON1 ICINH_UPI_MILLMAX030DTERM_1PIN_PI_MILLMAX030D_CON1CON1 ICINH_VPI_MILLMAX030DTERM_1PIN_PI_MILLMAX030D_CON1CON1 ICINH_WPI_MILLMAX030DTERM_1PIN_PI_MILLMAX030D_CON1CON1 ICINL_UPI_MILLMAX030DTERM_1PIN_PI_MILLMAX030D_CON1CON1 ICINL_VPI_MILLMAX030DTERM_1PIN_PI_MILLMAX030D_CON1CON1 ICINL_WPI_MILLMAX030DTERM_1PIN_PI_MILLMAX030D_CON1CON1 ICIPH_UPI_MILLMAX030DTERM_1PIN_PI_MILLMAX030D_CON1CON1 ICIPH_VPI_MILLMAX030DTERM_1PIN_PI_MILLMAX030D_CON1CON1 ICIPH_WPI_CONN_QC_TAB_2PIN_LS200CON2_PI_CONN_QC_TAB_2PIN_LS200_CON2 ICJ1PI_CONN_QC_TAB_2PIN_LS200CON2_PI_CONN_QC_TAB_2PIN_LS200_CON2 ICJ2PI_CONN_QC_TAB_2PIN_LS200CON2_PI_CONN_QC_TAB_2PIN_LS200_CON2 ICJ3PI_20P_2X10_SHROUDEDCON20_PI_20P_2X10_SHROUDED_CON2CON20 ICJ4INDC2012X105NINDUCTOR_BEAD_INDC2012X105N_220220 Ohm@100MHz ICL1PICHOKETOKINVD345H453LS197D030INDUCTOR_PICHOKETOKINVD345H453L680 uH ICL2TE_CONNECTIVITY_1734510-1USB_MINI_B_DIPCON5 IOP1PI_MILLMAX030DTERM_1PIN_PI_MILLMAX030D_CON1CON1 ICPGNDPIMTGHOLED156POST_CRKT_BRD_6-32_HEX_PIMTGHOLPost Hex, 6-32, snap, 0.375L, NYL ICPOST-CRKT_BRD_6-32_HEX1PIMTGHOLED156POST_CRKT_BRD_6-32_HEX_PIMTGHOLPost Hex, 6-32, snap, 0.375L, NYL ICPOST-CRKT_BRD_6-32_HEX2PIMTGHOLED156POST_CRKT_BRD_6-32_HEX_PIMTGHOLPost Hex, 6-32, snap, 0.375L, NYL ICPOST-CRKT_BRD_6-32_HEX3PIMTGHOLED156POST_CRKT_BRD_6-32_HEX_PIMTGHOLPost Hex, 6-32, snap, 0.375L, NYL ICPOST-CRKT_BRD_6-32_HEX4PISMR0603R_PISMR0603_330330 ICR1PISMR0805R_PISMR0805_4.99 K4.99 k ICR2PISMR0603R_PISMR0603_1 K1 k ICR3PISMR0603R_PISMR0603_22 K22 k ICR4PISMR1206R_PISMR1206_3 M3 M ICR5PI_VRES_VERTADJPOT_PI_VRES_VERTADJ_10 K10 k ICR6PISMR0603R_PISMR0603_1 K1 k ICR7PISMR1206R_PISMR1206_2.00 M2.00 M ICR8PISMR0603R_PISMR0603_100100 ICR9PISMR0603R_PISMR0603_100100 ICR10PISMR0603R_PISMR0603_1 K1 k ICR11PISMR0603R_PISMR0603_1 K1 k ICR12PISMR1206R_PISMR1206_2.00 M2.00 M ICR13PISMR0603R_PISMR0603_330330 ICR14PISMR0603R_PISMR0603_44.2 K44.2 k ICR15PISMR0603R_PISMR0603_1 K1 k ICR16PISMR0603R_PISMR0603_1 K1 k ICR17PISMR0603R_PISMR0603_10 K10 k ICR18PISMR0603R_PISMR0603_100100 ICR19PISMR0603R_PISMR0603_1 K1 k ICR20PISMR0603R_PISMR0603_44.2 K44.2 k ICR21PISMR2010R_PISMR2010_0.220.22 ICR22PISMR0603R_PISMR0603_1 K1 k ICR23PISMR0603R_PISMR0603_1 K1 k ICR24PISMR0603R_PISMR0603_1 K1 k ICR25PISMR0603R_PISMR0603_1 K1 k ICR26PISMR0603R_PISMR0603_100100 ICR27PISMR0603R_PISMR0603_1 K1 k ICR28PISMR0603R_PISMR0603_10 K10 k ICR29PISMR0603R_PISMR0603_1 K1 k ICR30PISMR0603R_PISMR0603_44.2 K44.2 k ICR31PISMR0603R_PISMR0603_1 K1 k ICR32PISMR0603R_PISMR0603_10 K10 k ICR33PISMR0603R_PISMR0603_10 K10 k ICR34PISMR0603R_PISMR0603_10 K10 k ICR35PISMR0805R_PISMR0805_4.75 K4.75 k ICR36PISMR0603R_PISMR0603_1 K1 k ICR37PISMR0805R_PISMR0805_100 K100 k ICR38PISMR0603R_PISMR0603_44.2 K44.2 k ICR39PISMR2010R_PISMR2010_0.220.22 ICR40PISMR0603R_PISMR0603_100100 ICR41PISMR0402R_PISMR0402_3.48 K3.48 k ICR42PISMR0603R_PISMR0603_1 K1 k ICR43PISMR0402R_PISMR0402_2.49 K_1%2.49 k1%ICR44PISMR0603R_PISMR0603_10 K10 k ICR45PISMR0603R_PISMR0603_44.2 K44.2 k ICR46PISMR0603R_PISMR0603_1 K1 k ICR47PISMR0805R_PISMR0805_24 K24 k ICR48PISMR0603R_PISMR0603_10 K10 k ICR49PISMR0603R_PISMR0603_1010 ICR50PISMR0805R_PISMR0805_22.122.1 ICR51PISMR0805R_PISMR0805_1 M1 M ICR52PISMR0603R_PISMR0603_44.2 K44.2 k ICR53PISMR2010R_PISMR2010_0.220.22 ICR54PISMR0805R_PISMR0805_22.122.1 ICR55PISMR0603R_PISMR0603_10 K10 k ICR56PISMR0805R_PISMR0805_56.2 K56.2 k ICR57PISMR0603R_PISMR0603_100100 ICR58PIRAD400X175LS250031THERMISTOR_PIRAD400X175LS25003110 ICRT1PISMR0603THERMISTOR_PISMR0603_100 K100 k ICRT2PI_SWITCH_SKRPABE010SW PUSHBUTTON-SPST_1-2_3-4_PI_SSPST ICSW1PI_SWITCH_SKRPABE010SW PUSHBUTTON-SPST_1-2_3-4_PI_SSPST ICSW2PI_SWITCH_DPDT_SLIDE_EG2209SW SLIDE-DPDT_PI_SWITCH_DPDT_SLDPDT SLIDE ICSW3PI_SM_14TSSOPTL084_HETERO_PI_SM_14TSSOP_AD86AD8648ARUZ ICU1PI_IC_INSOP_24CBRIDGESWITCH_1265C_PI_IC_INSOP_BRD1265C ICU2PI_SM_30_SSOPTMPM375FSDMG_PI_SM_30_SSOP_TMPMTMPM375FSDMG ICU3PI_IC_INSOP_24CBRIDGESWITCH_1265C_PI_IC_INSOP_BRD1265C ICU4PISMSO8DNSHORT5678LNK32XX_8C_PISMSO8DNSHORT5678_LLNK3204D ICU5PI_IC_INSOP_24CBRIDGESWITCH_1265C_PI_IC_INSOP_BRD1265C ICU6PI_SM_14LSSOPCOMPARATOR_QUAD_HETERO_PI_SM_14BA10339FV-E2 ICU7PI_SM_28-VFQFN_EPCP2102-GMR_PI_SM_28-VFQFN_EP_CPCP2102-GMR ICU8PI_SM_SOT_363SN74LVC1T45DCKR_PI_SM_SOT_363_SSN74LVC1T45DCKR ICU9PI_MILLMAX030DTERM_1PIN_PI_MILLMAX030D_CON1CON1 ICVBUS_INPI_IC_CER_RESONATORCRYSTAL_RESONATOR_PI_IC_CER_RES10.0000 MHz ICY1
重要提示:PCB作品文件展下载说明
生活就是油盐酱醋再加一点糖,快活就是一天到晚乐呵呵的忙!
发表于 2018-12-7 08:38:44 | 显示全部楼层
    社区居民忠实会员社区劳模终身成就奖
    发表于 2019-2-16 08:55:33 | 显示全部楼层
    发表于 2019-5-24 22:27:07 | 显示全部楼层
  • 签到天数: 58 天
    发表于 2019-5-25 00:21:54 | 显示全部楼层
  • 签到天数: 5 天
    PADS20210616高级班
    发表于 2019-5-25 07:28:26 | 显示全部楼层
    发表于 2019-5-26 09:10:19 | 显示全部楼层
    发表于 2019-5-30 15:40:25 | 显示全部楼层
  • 签到天数: 9 天
    发表于 2019-5-30 15:49:15 | 显示全部楼层
    前天 09:46
  • 签到天数: 59 天
    1元学习Allegro(1期)
    发表于 2021-9-6 11:23:03 | 显示全部楼层
