4层2066PIN
NuMaker Brick_v12.DSN.zip
(228 KB, 下载次数: 0)
NuMaker Brick_V12.pcb
(2.53 MB, 下载次数: 0)
[/hide]
Item | Quantity | Reference | Part | PCB Footprint | ______________________________________________ | | | | | | | | | | 1 | 1 | BUSY1 | LED G | LED0805 | 2 | 1 | BZ1 | BUZZER | BUZZER1 | 3 | 1 | B1 | BT2710-29 | BT2710 | 4 | 1 | CT1 | 1uF/6.3V | TANT-A | 5 | 63 | ICECB1,C1,ICECB2,C2,C3, | 0.1uF | C0603 | | | C4,C6,C7,C14,C17,C18,C19, | | | | | C21,C22,C28,C29,C30,C32, | | | | | C33,C39,C40,C41,C43,C44, | | | | | C50,C51,C52,C54,C55,C63, | | | | | C64,C65,C67,C68,C69,C70, | | | | | C71,C72,C74,C75,C81,C82, | | | | | C83,C85,C86,C92,C93,C94, | | | | | C96,C97,C103,C104,C105, | | | | | C107,C108,C114,C115,C116, | | | | | C117,C118,C120,C121,C128 | | | 6 | 15 | ICEC3,ICEC4,ICEC5,C5,C20, | 1uF | C0603 | | | C31,C42,C53,C73,C84,C95, | | | | | C106,C119,C129,C130 | | | 7 | 20 | C8,C10,C23,C25,C34,C36, | 10uF | C0603 | | | C45,C47,C56,C58,C76,C78, | | | | | C87,C89,C98,C100,C109, | | | | | C111,C122,C124 | | | 8 | 31 | C9,C11,C12,C24,C26,C27, | 10nF | C0603 | | | C35,C37,C38,C46,C48,C49, | | | | | C57,C59,C60,C66,C77,C79, | | | | | C80,C88,C90,C91,C99,C101, | | | | | C102,C110,C112,C113,C123, | | | | | C125,C126 | | | 9 | 1 | C13 | NC | C0603 | 10 | 2 | C15,C16 | 10p | C0603 | 11 | 1 | C61 | 0.22uF | C0603 | 12 | 2 | C62,C127 | 4.7uF | C0603 | 13 | 1 | D1 | IR333-F/H0/L10(HUH) | LED | 14 | 2 | ICEC1,ICEC2 | 20p | C0603 | 15 | 1 | ICED1 | SS24A | RB060L | 16 | 1 | ICEJP1 | HEADER 2.54 4X1 (NC) | SIP-4P | 17 | 1 | ICEJP2 | HEADER 2,54 5X1 (NC) | HEADER5x1 | 18 | 1 | ICEJP3 | HEADER 5X2(NC) | HEADER5X2 | 19 | 1 | ICEJ1 | mini USB 5pin | USB_MINI_B | 20 | 31 | ICER1,R2,R16,R27,R37,R50, | 10K | R0603 | | | R59,R64,R66,R73,R77,R84, | | | | | R90,R100,R109,R110,R111, | | | | | R112,R113,R114,R115,R116, | | | | | R117,R118,R119,R120,R121, | | | | | R122,R123,R126,R130 | | | 21 | 5 | RINT1,RB1,ICER2,RTDA3, | 33 | R0603 | | | ICER3 | | | 22 | 1 | ICEU1 | NUC12SRE3DE | NCU120_LQFP_64 | 23 | 1 | ICEX1 | 12MHz | XTAL\LP\SMD | 24 | 1 | ICE1 | LED R | LED0805 | 25 | 1 | IR1 | IRM-FM9038TM2-5DN | IRM-FM8038TM2-5DN | 26 | 19 | JP1,JP2,JP7,JP8,JP13, | HEADER 8(male 2.0mm) | HEADER1X8-1.27MM | | | JP14,JP20,JP21,JP26,JP27, | | | | | JP32,JP33,JP39,JP40,JP45, | | | | | JP46,JP51,JP52,JP56 | | | 27 | 19 | JP3,JP4,JP9,JP10,JP15, | HEADER 8(Female2.0mm) | HEADER1X8-1.27MM | | | JP16,JP22,JP23,JP28,JP29, | | | | | JP34,JP35,JP41,JP42,JP47, | | | | | JP48,JP53,JP54,JP57 | | | 28 | 11 | JP5,JP6,JP11,JP17,JP24, | HEADER 5(NC) | HEADER5 | | | JP30,JP36,JP43,JP49,JP55, | | | | | JP58 | | | 29 | 1 | JP19 | HC-SR04 | HEADER4 | 30 | 1 | JP59 | HEADER 5(Female) | HEADER5 | 31 | 1 | J1 | HEADER 2(Female) | HEADER2 | 32 | 2 | J2,J5 | USB | USB_MINI_B | 33 | 4 | J3,J4,J7,J8 | HEADER 6X2(NC) | HEADER6X2 | 34 | 1 | J6 | HEADER 2(male) | HEADER2 | 35 | 10 | LED1,LED4,LED7,LED10, | RED | LED0805 | | | LED13,LED16,LED19,LED22, | | | | | LED25,LED28 | | | 36 | 9 | LED2,LED5,LED8,LED11, | GREEN | LED0805 | | | LED14,LED17,LED20,LED23, | | | | | LED26 | | | 37 | 9 | LED3,LED6,LED9,LED12, | YELLOW | LED0805 | | | LED15,LED18,LED21,LED24, | | | | | LED27 | | | 38 | 2 | Q1,Q2 | SS8050 | SOT-23 | 39 | 1 | RGBLED1 | LTST-C19FD1WT | LED4PIN | 40 | 4 | RTDA1,RTCK1,RRSET1,R88 | 100K | R0603 | 41 | 27 | RTDA2,R6,R8,R20,R22,R31, | 0R | R0603 | | | R33,R41,R43,R52,R56,R58, | | | | | R60,R61,R70,R72,R81,R83, | | | | | R94,R96,R104,R106,R134, | | | | | R135,R141,R142,R143 | | | 42 | 1 | RV1 | GL5516 | GL55 | 43 | 12 | R1,R15,R26,R35,R36,R49, | 1K | R0603 | | | R65,R76,R86,R89,R99,R129 | | | 44 | 18 | R3,R4,R17,R18,R28,R29, | 330R | R0603 | | | R38,R39,R51,R54,R67,R68, | | | | | R78,R79,R91,R92,R101, | | | | | R102 | | | 45 | 8 | R5,R7,R9,R10,R11,R87, | 2K | R0603 | | | R108,R133 | | | 46 | 2 | R12,R136 | 3K | R0603 | 47 | 2 | R13,R85 | 5.1K | R0603 | 48 | 1 | R14 | 200R | R0603 | 49 | 18 | R19,R21,R30,R32,R40,R42, | NC | R0603 | | | R55,R57,R69,R71,R80,R82, | | | | | R93,R95,R103,R105,R139, | | | | | R140 | | | 50 | 8 | R23,R44,R124,R125,R127, | 4.7K | R0603 | | | R128,R131,R132 | | | 51 | 4 | R24,R45,R46,R47 | 510R | R0603 | 52 | 1 | R25 | 390 | R0603 | 53 | 3 | R34,R74,R97 | 3.9K | R0603 | 54 | 2 | R48,R63 | 620 | R0603 | 55 | 1 | R53 | 47R | R0603 | 56 | 2 | R62,R137 | 3.3K | R0603 | 57 | 1 | R75 | 1.2K | R0603 | 58 | 1 | R98 | 1.8K | R0603 | 59 | 1 | R107 | 3.6K | R0603 | 60 | 1 | R138 | SVR03K-B10KJ | R\VAR2 | 61 | 10 | SW1,SW2,SW4,SW6,SW8,SW10, | F.R. | SW4-SMD | | | SW12,SW14,SW16,SW25 | | | 62 | 15 | SW3,SW5,SW7,SW9,SW11, | SW PUSHBUTTON | SW-PT-004-A1 | | | SW13,SW15,SW17,SW18,SW19, | | | | | SW20,SW21,SW22,SW23,SW24 | | | 63 | 1 | S1 | MQ7 | MQ_7 | 64 | 9 | T1,T2,T3,T4,T5,T6,T7,T8, | T POINT(NC) | H3mm | | | T9 | | | 65 | 144 | T11,T12,T13,T14,T15,T16, | Hole(NC) | HOLE_BOARD1 | | | T17,T18,T19,T20,T21,T22, | | | | | T23,T24,T25,T26,T27,T28, | | | | | T29,T30,T31,T32,T33,T34, | | | | | T35,T36,T37,T38,T39,T40, | | | | | T41,T42,T43,T44,T45,T46, | | | | | T47,T48,T49,T50,T51,T52, | | | | | T53,T54,T55,T56,T57,T58, | | | | | T59,T60,T61,T62,T63,T64, | | | | | T65,T66,T67,T68,T69,T70, | | | | | T71,T72,T73,T74,T75,T76, | | | | | T77,T78,T79,T80,T81,T82, | | | | | T83,T84,T85,T86,T87,T88, | | | | | T89,T90,T91,T92,T93,T94, | | | | | T95,T96,T97,T98,T99,T100, | | | | | T101,T102,T103,T104,T105, | | | | | T106,T107,T108,T109,T110, | | | | | T111,T112,T113,T114,T116, | | | | | T117,T118,T119,T120,T121, | | | | | T122,T123,T124,T125,T126, | | | | | T127,T128,T129,T130,T131, | | | | | T132,T133,T134,T135,T136, | | | | | T137,T138,T139,T140,T141, | | | | | T142,T143,T144,T145,T146, | | | | | T147,T148,T149,T150,T151, | | | | | T152,T153,T154,T155 | | | 66 | 2 | U1,U24 | M452LG6AE | LQFP48L | 67 | 11 | U2,U4,U6,U8,U10,U16,U18, | AP7365-33WG-7 | SOT23-5 | | | U20,U22,U25,U26 | | | 68 | 8 | U3,U5,U7,U9,U15,U17,U19, | M451LE6AE | LQFP48L | | | U21 | | | 69 | 1 | U11 | HMC5883L(NC) | SQFN3X3-16 | 70 | 1 | U12 | MPU6500 | QFN-24-3X3X0.9MM | 71 | 1 | U13 | BMP280 | BMP280 | 72 | 1 | U14 | MS5611-01BA03(NC) | MS5611-01BA03 | 73 | 1 | U23 | HTU21D | HTU21D | 74 | 1 | Y1 | 32768 | XTAL-3.4MM-2P_DIP |
