查看: 7258|回复: 8
[Allegro16.6以下] LX2160A-RDB QorIQ LX2160A参考设计板原理图PCB
终身成就奖原创先锋奖特殊贡献奖优秀斑竹奖金点子奖
发表于 2018-12-8 19:05:34 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
BH1MOUNT_HOLE_MTG156_PTH_IC_0.05MMMOUNTINGHOLEMTG156_PTH
BH12MOUNT_HOLE_MH180-135P_IC_0.1MMMH_180MH180-135P
BT1BATTERY_SKT_3V_SKT_BAT_225X886_CR2032+HOLDERSKT_BAT_225X886_3V
D1LED_LED_0603_IC_0.8MM_370-75076LED_YELLOWLED_0603
D2DIODE_SCHTKY_SOD-882_IC_0.5MM_4PMEG2005AELSOD-882
D3DIODE_SCHTKY_SOD-882_IC_0.5MM_4PMEG2005AELSOD-882
D5LED_LED_0603_IC_1.1MM_370-75143LED_GREENLED_0603
D9LED_LED_0603_IC_1.1MM_370-75143LED_GREENLED_0603
D10LED_LED_0603_IC_1.1MM_370-75143LED_GREENLED_0603
D11LED_LED_0603_IC_1.1MM_370-75143LED_GREENLED_0603
D13LED_LED_0603_IC_1.1MM_370-75143LED_GREENLED_0603
D14DIODE_SOD323_IC_1.05MM_480-75131N4148WSSOD323
D15DIODE_SOD323_IC_1.05MM_480-75131N4148WSSOD323
D16DIODE_SOD323_IC_1.05MM_480-75131N4148WSSOD323
D17DIODE_SOD323_IC_1.05MM_480-75131N4148WSSOD323
D18LED_LED_0603_IC_0.8MM_370-75078BLUELED_0603
D44LED_LED_0603_IC_1.1MM_370-75143LED_GREENLED_0603
D45LED_LED_0603_IC_1.1MM_370-75143LED_GREENLED_0603
F2FUSE_RESETTABLE_FUSE_SMD050_DIS1AFUSE_SMD050
F6BLM18R_IND_0603_DISCRETE_0.75MBLM18KG300TN1IND_0603
F7BLM18R_IND_0603_DISCRETE_0.75MBLM18KG300TN1IND_0603
FL4FILTER_BNX028_FILTER6_12P3X9P3_BNX028-01FILTER6_12P3X9P3
FL5EMIFILTER_CC_CC_NFM41P_1806_DIS1.5uFCC_NFM41P_1806
FL6EMIFILTER_CC_CC_NFM41P_1806_DIS1.5uFCC_NFM41P_1806
FL7EMIFILTER_CC_CC_NFM41P_1806_DIS1.5uFCC_NFM41P_1806
FL8EMIFILTER_CC_CAP3_3P4X1P8_SM_DI27uFCAP3_3P4X1P8_SM
FL9EMIFILTER_CC_CAP3_3P4X1P8_SM_DI27uFCAP3_3P4X1P8_SM
FL10EMIFILTER_CC_CAP3_3P4X1P8_SM_DI27uFCAP3_3P4X1P8_SM
FL11EMIFILTER_CC_CAP3_3P4X1P8_SM_DI27uFCAP3_3P4X1P8_SM
FL13NFM18PC225B1A3_CC0603_NFM18PC_DNFM18PC225B1A3CC0603_NFM18PC
FL30NFM18PC225B1A3_CC0603_NFM18PC_DNFM18PC225B1A3CC0603_NFM18PC
J1ATX_12V_PWR_CONN8_CONN_2X4_165_CON2X4CONN_2X4_165_TH
J2CONN_PWR_12X2_CON_ATXPWR_2X12_ACON_2X12_PWRCON_ATXPWR_2X12_A
J3CONN_HDR_2X1_HDR102_IO_8.71MM_HDR1X2 THHDR102
J4CONN_HDR_2X1_HDR102_IO_8.71MM_HDR1X2 THHDR102
J5CON12_98414_PMBUS_CON12_SHRD_2MCON_2X6THCON12_SHRD_2MM_TH
J6CONN_HDR_2X1_HDR102_IO_8.71MM_HDR1X2 THHDR102
J7CONN_HDR_2X1_HDR102_IO_8.71MM_HDR1X2 THHDR102
J8CONN_HDR_2X1_HDR102_IO_8.71MM_HDR1X2 THHDR102
J9CONN_HDR_2X1_HDR102_IO_8.71MM_HDR1X2 THHDR102
J10CONN_HDR_5X1_HDR105_IO_9.45MM_290120-0125HDR105
J11CONN_HDR_5X2_HDR205_10M_50_SM_KFTSH-105-01-L-DV-KHDR205_10M_50_SM_K
J13CONN_HDR_10X2_HDR210_50_TFM-SN_TFM-110-02-S-D-SN-K-TRHDR210_50_TFM-SN
J14DDR4_SOCKET_SM_CON_DDR4_288SKT_SD-78730-1002CON_DDR4_288SKT_SM
J15DDR4_SOCKET_SM_CON_DDR4_288SKT_SD-78730-1002CON_DDR4_288SKT_SM
J16DDR4_SOCKET_SM_CON_DDR4_288SKT_SD-78730-1002CON_DDR4_288SKT_SM
J17DDR4_SOCKET_SM_CON_DDR4_288SKT_SD-78730-1002CON_DDR4_288SKT_SM
J18CON_ZQSFP_2X19_CAGE_CAGE_ZQSFP_CON38 PCI+QSFP38 CAGECAGE_ZQSFP_CON38_SMD
J19CON_SFPCAGE_1X2_SUBASSY_SFP_CAG2170088-2+2180739-1SUBASSY_SFP_CAGE_1X2_TH
J21CON_RJ45_19P_A_CON19_RJ-45_LED_RJ45-19CON19_RJ-45_LED_80MIL_TH_RA_A
J22CON_RJ45_19P_A_CON19_RJ-45_LED_RJ45-19CON19_RJ-45_LED_80MIL_TH_RA_A
J23CONN_PCIEXP_64P_CUST_B_CON64_1MPCIE-LP-04-01-F-DV-A-K-TRCON64_1MM_SM_PCIE_LP
J24CON_SATA_PLUG7_CON_7_SATA_V_SM_HDR1X7CON_7_SATA_V_SM
J25CON_SATA_PLUG7_CON_7_SATA_V_SM_HDR1X7CON_7_SATA_V_SM
J26CON_SATA_PLUG7_CON_7_SATA_V_SM_HDR1X7CON_7_SATA_V_SM
J27CON_SATA_PLUG7_CON_7_SATA_V_SM_HDR1X7CON_7_SATA_V_SM
J28CONN_PCI_EXPRESS_X8_CON98_1MM_SPCIE-LP-08-01-F-DV-A-K-TRCON98_1MM_SM_PCIE_LP
J29CONN_HDR_6X2_TSM2X6_SMD_IO_9.65HDR_2X6TSM2X6_SMD
J30USB_3P0_TYPEA_CON9_USBA_VER_7P3USB_TYPE_ACON9_USBA_VER_7P32X25P7
J31CONN_HDR_2X1_HDR102_IO_8.71MM_HDR1X2 THHDR102
J32USB_KMMX_10P_CON10_MICROUSB_0P6USB3_MICRO_ABCON10_MICROUSB_0P65MM_SM
J33CONN_HDR_2X1_HDR102_IO_8.71MM_HDR1X2 THHDR102
J34CONN_HDR_3X1_HDR103_IO_8.38MM_HDR_1X3HDR103
J35CONN_HDR_3X1_HDR103_IO_8.38MM_HDR_1X3HDR103
J36CONN_HDR_3X1_HDR103_IO_8.38MM_HDR_1X3HDR103
J37CONN_HDR_3X1_HDR103_IO_8.38MM_HDR_1X3HDR103
J38CONN_HDR_4X1_CON_4X1_2P54_TH_4747053-3000CON_4X1_2P54_TH_47053
J39CONN_HDR_4X1_CON_4X1_2P54_TH_4747053-3000CON_4X1_2P54_TH_47053
J40CONN_HDR_4X1_CON_4X1_2P54_TH_4747053-3000CON_4X1_2P54_TH_47053
J41CONN_HDR_4X1_CON_4X1_2P54_TH_4747053-3000CON_4X1_2P54_TH_47053
J42CONN_SDCARD_PUSH_PULL_9P_SH2_COCONN_SD_CARD9CON_SDCARD_28P9X29_SM_RA
J43CONN_HDR_3X1_HDR103_IO_8.38MM_HDR_1X3HDR103
J44CONN_HDR_4X1_CON_4X1_2P54_TH_4747053-3000CON_4X1_2P54_TH_47053
J45CONN_HDR_3X1_HDR103_IO_8.38MM_HDR_1X3HDR103
J46CONN_HDR_2X1_HDR102_IO_8.71MM_HDR1X2 THHDR102
J47CONN_HDR_2X1_HDR102_IO_8.71MM_HDR1X2 THHDR102
J48CONN_HDR_2X1_HDR102_IO_8.71MM_HDR1X2 THHDR102
J50MMBX_SMT_F_CUST_CON_SMA_IO_9.53CON1 SMACON_SMA
J52MMBX_SMT_F_CUST_CON_SMA_IO_9.53CON1 SMACON_SMA
J53CONN_HDR_5X2_HDR205_IO_8.6MM_21HDR2X5HDR205
J54HDR_1X3_HDR1X3_TH_IO_12.04MM_21HDR1X3HDR1X3_TH
J55CONN_HDR_3X1_HDR103_IO_8.38MM_HDR_1X3HDR103
J56CONN_HDR_3X2_HDR203_IO_8.636MM_HDR2X3HDR203
J57CONN_HDR_2X1_HDR102_IO_8.71MM_HDR1X2 THHDR102
J58CONN_HDR_2X1_HDR102_IO_8.71MM_HDR1X2 THHDR102
L1INDUCTOR_IND2_10P5X10P3_SM_DISC1.5uHIND2_10P5X10P3_SM
L2INDUCTOR_IND2_10P5X10P3_SM_DISC1.5uHIND2_10P5X10P3_SM
L3INDUCTOR_IND_IHLP_DISCRETE_3MM_1.5uHIND_IHLP
L4ETQP6F_2P_IND2_10P4X8_DISCRETE_175nHIND2_10P4X8
L5ETQP6F_2P_IND2_10P4X8_DISCRETE_175nHIND2_10P4X8
L6INDUCTOR_IND2_744308033_DISCRET0.33uHIND2_744308033
L7INDUCTOR_IND2_744308033_DISCRET0.33uHIND2_744308033
L8INDUCTOR_IND2_10P5X10P3_SM_DISC1.5uHIND2_10P5X10P3_SM
L9INDUCTOR_IND2_10P5X10P3_SM_DISC1.5uHIND2_10P5X10P3_SM
L10INDUCTOR_IND2_10P5X10P3_SM_DISC1.5uHIND2_10P5X10P3_SM
L11INDUCTOR_IND2_10P5X10P3_SM_DISC1.5uHIND2_10P5X10P3_SM
L12INDUCTOR_IND2_744308033_DISCRET0.33uHIND2_744308033
L13INDUCTOR_IND2_10P5X10P3_SM_DISC1.5uHIND2_10P5X10P3_SM
L14INDUCTOR_IND2_10P5X10P3_SM_DISC1.5uHIND2_10P5X10P3_SM
L15INDUCTOR_IND2_10P5X10P3_SM_DISC1.5uHIND2_10P5X10P3_SM
L16INDUCTOR_IND2_10P5X10P3_SM_DISC1.5uHIND2_10P5X10P3_SM
L17BEAD_0_IND_0603A_DISCRETE_0.75MBLM18KG121TN1IND_0603A
L18BEAD_0_IND_0603A_DISCRETE_0.75MBLM18KG121TN1IND_0603A
L27BEAD_IND_2P_0181_SM_DISCRETE_3.28F0181IND_2P_0181_SM
L28BLM18R_IND_0603_DISCRETE_0.65MM120OHM@100MHZIND_0603
L29BEAD_IND_0805_DISCRETE_1.05MM_1MPZ2012S101AIND_0805
L48NFE31P_IND_NFE31P_DISCRETE_1.75NFE31PT222Z1E9LIND_NFE31P
L51NFE31P_IND_NFE31P_DISCRETE_1.75NFE31PT222Z1E9LIND_NFE31P
L52INDUCTOR_IND_2016A_DISCRETE_1.810UHIND_2016A
L53INDUCTOR_IND_2016A_DISCRETE_1.810UHIND_2016A
L54BEAD_0_IND_0603A_DISCRETE_0.75MBLM18KG121TN1IND_0603A
L55BEAD_0_IND_0603A_DISCRETE_0.75MBLM18KG121TN1IND_0603A
L56BEAD_0_IND_0603A_DISCRETE_0.75MBLM18KG121TN1IND_0603A
L57BEAD_0_IND_0603A_DISCRETE_0.75MBLM18KG121TN1IND_0603A
L59BEAD_IND_0805_DISCRETE_1.05MM_1MPZ2012S101AIND_0805
L60IND_IND_2P2X2_DISCRETE_1.4MM_184.7UHIND_2P2X2
L61IND_IND_2P2X2_DISCRETE_1.4MM_184.7UHIND_2P2X2
P1RJ45_MAG_2X1_LED_CON_RJ45_2X1_MRJ4513X2PORTSCON_RJ45_2X1_MAG_LED
P2DSD9M_DUALDB-9MM_IO_31.75MM_2102XDB9DUALDB-9MM
P3DSD9M_DUALDB-9MM_IO_31.75MM_2102XDB9DUALDB-9MM
Q1PNP_SOT23_IC_1.3MM_480-75192_MMMMBT3906LSOT23
Q2PNP_SOT23_IC_1.3MM_480-75192_MMMMBT3906LSOT23
SS1SPACER_STANDOFF_S228-134T_IC_1.071CCAAZ40BSTANDOFF_S228-134T
SS2SPACER_STANDOFF_S228-134T_IC_1.071CCAAZ40BSTANDOFF_S228-134T
SW1SW_DIP_8_SW_DIP16_8POS_SM_IC_2.218-8LPSTSW_DIP16_8POS_SM
SW2SW_DIP_8_SW_DIP16_8POS_SM_IC_2.218-8LPSTSW_DIP16_8POS_SM
SW3SW_DIP_8_SW_DIP16_8POS_SM_IC_2.218-8LPSTSW_DIP16_8POS_SM
SW4SW_DIP_8_SW_DIP16_8POS_SM_IC_2.218-8LPSTSW_DIP16_8POS_SM
SW5SPL6BL_SW6_TACT_SW6_TACT_LED_THSPL6BLHSW6_TACT_LED_TH
SW7SW_TACT-SPST-2_SM1_SW2_TL1105S_TL1105SF160QSW2_TL1105S
U1LX2160_LS2081_SKT1517_1MM_60X60LX2160_LS2081+ CONTACT GRID + HW ASSEMBLY HEATSINSKT1517_1MM_60X60MM
U2FDC6330_SSOT_6P_SSOT6_1P7X3_IC_FDC6330LSSOT6_1P7X3
U3MC34717_C_QFN26_0P5_5X5_EP_3P75MC34717EPQFN26_0P5_5X5_EP_3P75
U4EPM2210F256C5N_256BGA_BGA256_1MEPM2210F256C5NBGA256_1MM_17X17
U9ADM6315_4P_SC70_4_IC_1.1MM_315ADM6711SC70_4
U10ADM6315_4P_SC70_4_IC_1.1MM_315ADM6711SC70_4
U11FDMF5820DC_PQFN31_0P5_5X5_IC_0.FDMF5820DCPQFN31_0P5_5X5
U12LTC3882_40P_EP_QFN40_0P5_6P1X6PLTC3882QFN40_0P5_6P1X6P1
U13FDMF5820DC_PQFN31_0P5_5X5_IC_0.FDMF5820DCPQFN31_0P5_5X5
U14100201_SO_10_SC70-5_IC_1.1MM_31SN74CBTLV1G125DCKRSC70-5
U15LTC7150_BGA42_BGA42_0P8_5X6_IC_LTC7150SBGA42_0P8_5X6
U16LTC7150_BGA42_BGA42_0P8_5X6_IC_LTC7150SBGA42_0P8_5X6
U17MC34717_C_QFN26_0P5_5X5_EP_3P75MC34717EPQFN26_0P5_5X5_EP_3P75
U18100201_SO_10_SC70-5_IC_1.1MM_31SN74CBTLV1G125DCKRSC70-5
U19100201_SO_10_SC70-5_IC_1.1MM_31SN74CBTLV1G125DCKRSC70-5
U20MC34712_QFN24_4X4MM_SLUG_IC_1MMMC34712EPQFN24_4X4MM_SLUG
U21MC34712_QFN24_4X4MM_SLUG_IC_1MMMC34712EPQFN24_4X4MM_SLUG
U22LTC3026_MSOP_10P_MSOP10_0P5_3P1LTC3026EMSEMSOP10_0P5_3P1X3P1_EP
U23100201_SO_10_SC70-5_IC_1.1MM_31SN74CBTLV1G125DCKRSC70-5
U24LTC3026_MSOP_10P_MSOP10_0P5_3P1LTC3026EMSEMSOP10_0P5_3P1X3P1_EP
U26100201_SO_10_SC70-5_IC_1.1MM_31SN74CBTLV1G125DCKRSC70-5
U27MAX8902B_TDFN8_1P98_2P10X2P10_IMAX8902BTDFN8_1P98_2P10X2P10
U28100201_SO_10_SC70-5_IC_1.1MM_31SN74CBTLV1G125DCKRSC70-5
U29LTC7150_BGA42_BGA42_0P8_5X6_IC_LTC7150SBGA42_0P8_5X6
U30MC34717_C_QFN26_0P5_5X5_EP_3P75MC34717EPQFN26_0P5_5X5_EP_3P75
U31MC34717_C_QFN26_0P5_5X5_EP_3P75MC34717EPQFN26_0P5_5X5_EP_3P75
U33FPF1321_6P_WLCSP6_0P5_0P98X1P48FPF1321UCXWLCSP6_0P5_0P98X1P48
U34NX5P2924BUK_BGA6_0P5_0P92X1P42_NX5P2924BUKBGA6_0P5_0P92X1P42_NSP
U3774AUP1T34GW_SC70-5_IC_1.1MM_31274AUP1T34GWSC70-5
U4174CBTLV3253DS_QSOP16-16X70_IC_174CBTLV3253DSQSOP16-16X70
U4274CBTLV3253DS_QSOP16-16X70_IC_174CBTLV3253DSQSOP16-16X70
U45PRTR5V0U2AX_SOT143B_IC_1.1MM_48PRTR5V0U2AXSOT143B
U46PRTR5V0U2AX_SOT143B_IC_1.1MM_48PRTR5V0U2AXSOT143B
U47SDINADF4_128G_FBGA153_FBGA153_0SDINADF4-128GFBGA153_0P5_11P5X13
U48MTFC128G_LFBGA_169P_FBGA169_0P5MTFC128GAJAECE-ITFBGA169_0P5_14X18
U49CS4223_BGA121_FCBGA121_1MM_12X1WPCS4223FCBGA121_1MM_12X12
U50128K_EEPROM_16KX8_SOIC_8P_SO8_124AA512-I/SNSO8_1P27_4X5
U53IN112525_FBGA81_FCBGA81_1MM_10XIN112525FCBGA81_1MM_10X10
U5474AUP1T34GW_SC70-5_IC_1.1MM_31274AUP1T34GWSC70-5
U5574AUP1T34GW_SC70-5_IC_1.1MM_31274AUP1T34GWSC70-5
U56MAX14591_TDFN_8P_DFN_8_0P5_2X2_MAX14591DFN_8_0P5_2X2
U5774LVC2G34_SOT-363_0P65_SMT_IC_174LVC2G34GWSOT-363_0P65_SMT
U58AQR107_BGA_104P_BGA104_0P8_7X11AQR107BGA104_0P8_7X11
U59AT45DB041D-SU_SO8_1P27_4X5_IC_1AT45DB041E-SSHN2B-BSO8_1P27_4X5
U60NTSX2102GD_XSON8_0P5_3P1X2P1_ICNTSX2102GDXSON8_0P5_3P1X2P1
U62AQR107_BGA_104P_BGA104_0P8_7X11AQR107BGA104_0P8_7X11
U63AT45DB041D-SU_SO8_1P27_4X5_IC_1AT45DB041E-SSHN2B-BSO8_1P27_4X5
U65NX3DV221TK_10P_B_TDFN10_0P5_3P1NX3DV221TKTDFN10_0P5_3P1X3P1
U66NX3DV221TK_10P_B_TDFN10_0P5_3P1NX3DV221TKTDFN10_0P5_3P1X3P1
U67NX3DV221TK_10P_B_TDFN10_0P5_3P1NX3DV221TKTDFN10_0P5_3P1X3P1
U68NX3DV221TK_10P_B_TDFN10_0P5_3P1NX3DV221TKTDFN10_0P5_3P1X3P1
U69NX3DV221TK_10P_B_TDFN10_0P5_3P1NX3DV221TKTDFN10_0P5_3P1X3P1
U70NX3DV221TK_10P_B_TDFN10_0P5_3P1NX3DV221TKTDFN10_0P5_3P1X3P1
U71NX3DV221TK_10P_B_TDFN10_0P5_3P1NX3DV221TKTDFN10_0P5_3P1X3P1
U73AR8035_QFN40_A_QFN40_0P4_5P1X5PAR8035QFN40_0P4_5P1X5P1
U74NX5P3090UK_WLCSP12_WLCSP12_0P4_NX5P3090UKWLCSP12_0P4_1P38X1P68MM_SMDP
U7574AUP1G04GV_SOT23-5_A_IC_1.1MM_74AUP1G04GVSOT23-5_A
U76PRTR5V0U2AX_SOT143B_IC_1.1MM_48PRTR5V0U2AXSOT143B
U77DIODE_ESD_4CH_PUSB3AB4_XSON10_0PUSB3AB4XSON10_0P5_1P1X2P6MM
U78PRTR5V0U2AX_SOT143B_IC_1.1MM_48PRTR5V0U2AXSOT143B
U79NX5P3090UK_WLCSP12_WLCSP12_0P4_NX5P3090UKWLCSP12_0P4_1P38X1P68MM_SMDP
U80DIODE_ESD_4CH_PUSB3AB4_XSON10_0PUSB3AB4XSON10_0P5_1P1X2P6MM
U8174AUP1G04GV_SOT23-5_A_IC_1.1MM_74AUP1G04GVSOT23-5_A
U82PCA9547_24P_TSSOP24_0P65_7P9X4PPCA9547PWTSSOP24_0P65_7P9X4P5
U83NTSX2102GD_XSON8_0P5_3P1X2P1_ICNTSX2102GDXSON8_0P5_3P1X2P1
U84128K_EEPROM_16KX8_SOIC_8P_SO8_124AA512-I/SNSO8_1P27_4X5
U85NTSX2102GD_XSON8_0P5_3P1X2P1_ICNTSX2102GDXSON8_0P5_3P1X2P1
U86PCA9547_24P_TSSOP24_0P65_7P9X4PPCA9547PWTSSOP24_0P65_7P9X4P5
U87ATMEL_SERIAL_EEPROM_64K-1_TSSOPAT24C02C-XHM-BTSSOP8
U88INA220AIDGST_MSOP_10_0P5_3X3_ICINA220AIDGSTMSOP_10_0P5_3X3
U89PCF2129AT_SO_20P_SO20_1P27_7P6XPCF2129ATSO20_1P27_7P6X12P95
U91SA56004ED_SO8_SO8_1P27_4X5_IC_1SA56004EDSO8_1P27_4X5
U92SA56004ED_SO8_SO8_1P27_4X5_IC_2SA56004FDSO8_1P27_4X5
U94LTC2804IDHC_DFN16_0P5_3X5_IC_0.LTC2804DFN16_0P5_3X5
U95LTC2804IDHC_DFN16_0P5_3X5_IC_0.LTC2804DFN16_0P5_3X5
U96TJA1051T_SO_8P_SO8_1P27_4X5_IC_TJA1051T/3SO8_1P27_4X5
U97SN74LVC2T45DCUT_8P_SSOP8_DCU_ICSN74LVC2T45SSOP8_DCU
U98SN74LVC2T45DCUT_8P_SSOP8_DCU_ICSN74LVC2T45SSOP8_DCU
U99TJA1051T_SO_8P_SO8_1P27_4X5_IC_TJA1051T/3SO8_1P27_4X5
U10074AUP2G06GW_SOT-363_0P65_SMT_IC74AUP2G06GWSOT-363_0P65_SMT
U10174AUP2G06GW_SOT-363_0P65_SMT_IC74AUP2G06GWSOT-363_0P65_SMT
U10274AUP2G06GW_SOT-363_0P65_SMT_IC74AUP2G06GWSOT-363_0P65_SMT
U10374LVC2G34_SOT-363_0P65_SMT_IC_174LVC2G34GWSOT-363_0P65_SMT
U10474LVC2G34_SOT-363_0P65_SMT_IC_174LVC2G34GWSOT-363_0P65_SMT
U105EMC2305_16P_EP_TQFN16_0P65_4X4MEMC2305TQFN16_0P65_4X4MM_TAB
U106100201_SO_10_SC70-5_IC_1.1MM_31SN74CBTLV1G125DCKRSC70-5
U107SN74LVC2G126DCTR_TSSOP8_A_IC_1.74LVC2G126TSSOP8_A
U108SN74LVC2G126DCTR_TSSOP8_A_IC_1.74LVC2G126TSSOP8_A
U109SN74LVC2G126DCTR_TSSOP8_A_IC_1.74LVC2G126TSSOP8_A
U111PRTR5V0U2AX_SOT143B_IC_1.1MM_48PRTR5V0U2AXSOT143B
U112MT35XU512ABA1G12_PBGA24_1_6X8MMMT35XU512ABA1G12PBGA24_1_6X8MM
U113PRTR5V0U2AX_SOT143B_IC_1.1MM_48PRTR5V0U2AXSOT143B
U114PRTR5V0U2AX_SOT143B_IC_1.1MM_48PRTR5V0U2AXSOT143B
U115MT35XU512ABA1G12_PBGA24_1_6X8MMMT35XU512ABA1G12PBGA24_1_6X8MM
U116NTSX2102GD_XSON8_0P5_3P1X2P1_ICNTSX2102GDXSON8_0P5_3P1X2P1
U117SI52208_QFN48P_QFN48_0P4_6X6_EPSi52208-A01AGMQFN48_0P4_6X6_EP3P6
U118SI53307_16P_EP_QFN16_0P5_3X3MM_Si53307-B-GMQFN16_0P5_3X3MM
U11974LVC2G34_SOT-363_0P65_SMT_IC_174LVC2G34GWSOT-363_0P65_SMT
U12074LVC2G34_SOT-363_0P65_SMT_IC_174LVC2G34GWSOT-363_0P65_SMT
U12174LVC2G34_SOT-363_0P65_SMT_IC_174LVC2G34GWSOT-363_0P65_SMT
U12274LVC2G34_SOT-363_0P65_SMT_IC_174LVC2G34GWSOT-363_0P65_SMT
U123AR8035_QFN40_A_QFN40_0P4_5P1X5PAR8035QFN40_0P4_5P1X5P1
U125AT24CM02_SO8_SO8_1P27_4X5_IC_1.AT24CM02-SSHM-BSO8_1P27_4X5
U126NTSX2102GD_XSON8_0P5_3P1X2P1_ICNTSX2102GDXSON8_0P5_3P1X2P1
U127100201_SO_10_SC70-5_IC_1.1MM_31SN74CBTLV1G125DCKRSC70-5
U128100201_SO_10_SC70-5_IC_1.1MM_31SN74CBTLV1G125DCKRSC70-5
U12974AUP1T34GW_SC70-5_IC_1.1MM_31274AUP1T34GWSC70-5
U130SI5341B_64P_EP_QFN64_0P5_9X9C_ISi5341B-D08333-GMQFN64_0P5_9X9C
Y1SG8002_OSC4_2P6X2P1_SM_IC_0.9MM25MHzOSC4_2P6X2P1_SM
Y2XTAL_13_XTAL4_5P15X3P35_SM_IC_125MHzXTAL4_5P15X3P35_SM
Y3XTAL_13Y_XTAL4_3P3X2P6_SM_FL_IC50MhzXTAL4_3P3X2P6_SM_FL
Y4XTAL_13Y_XTAL4_3P3X2P6_SM_FL_IC50MhzXTAL4_3P3X2P6_SM_FL
Y5XTAL_13_XTAL4_5P15X3P35_SM_IC_125MHzXTAL4_5P15X3P35_SM
Y7XTAL_13Y_XTAL_4_3P3X2P6MM_IC_0.7M48072002XTAL_4_3P3X2P6MM
Y9XTAL_13_XTAL4_5P15X3P35_SM_IC_125MHzXTAL4_5P15X3P35_SM
重要提示:PCB作品文件展下载说明
 楼主| 发表于 2018-12-8 19:07:45 | 显示全部楼层
[sell=10,2][hide=5,money] SCH-29455.DSN.rar (1.59 MB, 下载次数: 1) LAY-29455_B2.brd.rar (17.66 MB, 下载次数: 1) [/hide]
1元学习PADS(5期)
发表于 2018-12-8 20:00:49 | 显示全部楼层
    社区居民忠实会员终身成就奖特殊贡献奖优秀斑竹奖
    发表于 2018-12-8 20:12:03 | 显示全部楼层
    3 天前
  • 签到天数: 131 天
    发表于 2018-12-9 08:04:21 | 显示全部楼层
    感觉论坛里有相同文件??
    发表于 2019-12-16 12:12:10 | 显示全部楼层
    发表于 2021-9-2 18:58:39 | 显示全部楼层
    无聊
    2024-8-9 17:47
    发表于 2021-9-2 20:03:05 | 显示全部楼层
  • 签到天数: 6 天
    发表于 2021-9-2 22:18:14 | 显示全部楼层
