查看: 2091|回复: 0
[AD格式] MSP430FR2433 LaunchPad™ Development Kit 开发板 硬件全套资料
发表于 2018-12-9 12:45:16 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
MSP-EXP430FR2433_Hardware_Design_Files.zip (3.7 MB, 下载次数: 2)
Bill of Material for
On 2018/12/8/周六 at 13:18:54
Comment             Pattern     Quantity  Components
1051640001          Molex_1051640001    1    J102                         Receptacle, USB 2.0, Micro B, 5 Position, R/A, SMT
1188E-1K2-V-TR      SW_1188E         3    S1, S2, S3                   Switch, SPST, 0.05 A, 12 VDC, SMD
293D106X0010A2TE3   3216-18          1    C104                         CAP, TA, 10 礔, 10 V, +/- 20%, 3.4 ohm, SMD
293D475X9010A2TE3   3216-18          2    C106, C109                   CAP, TA, 4.7 礔, 10 V, +/- 10%, 5 ohm, SMD
5001                Keystone5001     9    TP101, TP102, TP103, TP104   Test Point, Miniature, Black, TH
                                           TP105, TP106, TP107, TP108
                                           TP109
742792622           0603             2    L102, L103                   Ferrite Bead, 180 ohm @ 100 MHz, 0.5 A, 0603
BAS40-05W,115       SOT-323          2    D101, D102                   Diode, Schottky, 40 V, 0.12 A, AEC-Q101, SOT-323
BC850CW,115         SOT-323          1    T102                         Transistor, NPN, 45 V, 0.1 A, SOT-323
CBC2518T2R2M        CBC2518          1    L101                         Inductor, Wirewound, Ceramic, 2.2 礖, 0.89 A, 0.13 ohm, SMD
CRCW04020000Z0ED    0402             1    R119                         RES, 0, 5%, 0.063 W, 0402
CRCW040210R0FKED    0402             2    R129, R130                   RES, 10.0, 1%, 0.063 W, 0402
CRCW0402150KFKED    0402             1    R125                         RES, 150 k, 1%, 0.063 W, 0402
CRCW04021K40FKED    0402             1    R105                         RES, 1.40 k, 1%, 0.063 W, 0402
CRCW04021M00JNED    0402             1    R106                         RES, 1.0 M, 5%, 0.063 W, 0402
CRCW0402221KFKED    0402             6    R112, R113, R114, R115, R121 RES, 221 k, 1%, 0.063 W, 0402
                                           R122
CRCW0402240KFKED    0402             1    R124                         RES, 240 k, 1%, 0.063 W, 0402
CRCW040227R0JNED    0402             2    R103, R104                   RES, 27, 5%, 0.063 W, 0402
CRCW04022K20FKED    0402             1    R126                         RES, 2.20 k, 1%, 0.063 W, 0402
CRCW040233K0JNED    0402             1    R123                         RES, 33 k, 5%, 0.063 W, 0402
CRCW0402390RJNED    0402             1    R102                         RES, 390, 5%, 0.063 W, 0402
CRCW0402392RFKED    0402             1    R7                           RES, 392, 1%, 0.063 W, 0402
CRCW0402470RJNED    0402             2    R101, R120                   RES, 470, 5%, 0.063 W, 0402
CRCW040247K0JNED    0402             1    R109                         RES, 47 k, 5%, 0.063 W, 0402
CRCW04024K70JNED    0402             2    R116, R117                   RES, 4.7 k, 5%, 0.063 W, 0402
CRCW04026K81FKED    0402             1    R128                         RES, 6.81 k, 1%, 0.063 W, 0402
CRCW06030000Z0EA    0603             4    R2, R3, R4, R5               RES, 0, 5%, 0.1 W, 0603
CRCW120622R0JNEA    1206             1    R8                           RES, 22, 5%, 0.25 W, 1206
CRG0402F4K7         0402             2    R107, R108                   RES, 4.70 k, 1%, 0.063 W, 0402
CSTCR4M00G15L99-R0  Murata_CSTCR     1    Q101                         Resonator, 4MHz, 39pF SMD
DMG1013UW-7         SOT-323          1    T101                         MOSFET, P-CH, -20 V, -0.82 A, SOT-323
EEC-S0HD224H        SD_1050x600      1    C6                           CAP, Electric Double Layer, 220000 礔, 5.5 V, +80/-20%, TH
ERJ-2RKF3301X       0402             1    R127                         RES, 3.30 k, 1%, 0.1 W, AEC-Q200 Grade 0, 0402
GRM1555C1E120JA01D  0402             2    C2, C3                       CAP, CERM, 12 pF, 25 V, +/- 5%, C0G/NP0, 0402
GRM1555C1H100JA01D  0402             2    C110, C111                   CAP, CERM, 10 pF, 50 V, +/- 5%, C0G/NP0, 0402
GRM1555C1H101JA01D  0402             1    C127                         CAP, CERM, 100 pF, 50 V, +/- 5%, C0G/NP0, 0402
GRM1555C1H330JA01D  0402             4    C115, C116, C122, C123       CAP, CERM, 33 pF, 50 V, +/- 5%, C0G/NP0, 0402
GRM155R61A104KA01D  0402             9    C103, C105, C113, C114, C118 CAP, CERM, 0.1 礔, 10 V, +/- 10%, X5R, 0402
                                           C120, C121, C124, C125
GRM155R61A224KE19D  0402             1    C126                         CAP, CERM, 0.22 礔, 10 V, +/- 10%, X5R, 0402
GRM155R61C474KE01   0402             1    C101                         CAP, CERM, 0.47 礔, 16 V, +/- 10%, X5R, 0402
GRM155R61H104ME14D  0402             1    C4                           CAP, CERM, 0.1 礔, 50 V, +/- 20%, X5R, 0402
GRM155R71H102KA01D  0402             2    C1, C112                     CAP, CERM, 1000 pF, 50 V, +/- 10%, X7R, 0402
GRM185R61A105KE36D  0603             1    C108                         CAP, CERM, 1 礔, 10 V, +/- 10%, X5R, 0603
GRM188R60J106ME84   0603             1    C5                           CAP, CERM, 10 礔, 6.3 V, +/- 20%, X5R, 0603
GRM188R61C224KA88D  0603             2    C102, C107                   CAP, CERM, 0.22 礔, 16 V, +/- 10%, X5R, 0603
GRM188R61C475KAAJ   0603             2    C117, C119                   CAP, CERM, 4.7 礔, 16 V, +/- 10%, X5R, 0603
LTST-C190CKT        LED_LTST-C190_Red    2    LED1, LED101                 LED, Red, SMD
LTST-C190GKT        LED_LTST-C190    2    LED2, LED102                 LED, Green, SMD
MSP430F5528IRGCT    RGC0064B         1    MSP101                       25 MHz Mixed Signal Microcontroller with 128 KB Flash, 8192 B SRAM and 47 GPIOs, -40 to 85 degC, 64-pin QFN (RGC), Green (RoHS & no Sb/Br)
MSP430FR2433IRGER   RGE0024H         1    MSP1                         MSP430FR2433 16 MHz Ultra-Low-Power Microcontroller with 16 KB FRAM, 4 KB RAM, 19 IO, 4 Timers, RGE0024H (VQFN-24)
MSP430G2452IRSA16R  RSA0016B         1    MSP102                       16 MHz Mixed Signal Microcontroller with 8 KB Flash, 256 B SRAM and 16 GPIOs, 16-pin QFN (RSA), Green (RoHS & no Sb/Br)
PEC03SAAN           CONN_PEC03SAAN    1    J4                           Header, 100mil, 3x1, Tin, TH
PEC03SAAN           PEC03SAAN_Launchpad_3V3    1    J5                           Header, 100mil, 3x1, Tin, TH
PEC03SAAN           PEC03SAAN_Launchpad_5V0    1    J6                           Header, 100mil, 3x1, Tin, TH
PEC07DAAN           PEC07DAAN_Launchpad_EZ-FET    1    J101                         Header, 100mil, 7x2, Tin, TH
RC0402FR-07470RL    0402             1    R6                           RES, 470, 1%, 0.063 W, 0402
RC0402FR-0747KL     0402             1    R1                           RES, 47.0 k, 1%, 0.0625 W, 0402
RC0402FR-07820RL    0402             1    R118                         RES, 820, 1%, 0.063 W, 0402
SNT-100-BK-G        SNT-100-BK-G    10    SH-J4, SH-J10, SH-J11        Shunt, 100mil, Gold plated, Black
                                           SH-J101-1, SH-J101-2
                                           SH-J101-3, SH-J101-4
                                           SH-J101-5, SH-J101-6
                                           SH-J101-7
SSQ-102-03-F-S      BoosterPack_20pin_J3    1    J3                           Receptacle, 2.54mm, 2x1, Gold, TH
SSQ-110-03-F-S      BoosterPack_20pin_J1    1    J1                           Receptacle, 2.54mm, 10x1, Gold, TH
SSQ-110-03-F-S      BoosterPack_20pin_J2    1    J2                           Receptacle, 2.54mm, 10x1, Gold, TH
TLV70033DSET        DSE0006A         1    IC101                        Single Output LDO, 200 mA, Fixed 3.3 V Output, 2 to 5.5 V Input, with Low IQ, 6-pin WSON (DSE), -40 to 125 degC, Green (RoHS & no Sb/Br)
TPD4E004DRYR        DRY0006A         1    IC102                        ESD-Protection Array for High-Speed Data Interfaces, 4 Channels, -40 to +85 degC, 6-pin SON (DRY), Green (RoHS & no Sb/Br)
TS5A21366RSER       RSE0008A         1    IC103                        0.75-Ohm DUAL SPST ANALOG SWITCH WITH 1.8-V COMPATIBLE INPUT LOGIC, RSE0008A (UQFN-8)
TSW-102-07-G-S      TSW-102-07-G-S    2    J10, J11                     Header, 100mil, 2x1, Gold, TH
X1A0001410014       Epson_FC-135     1    Q1                           Crystal, 32.768 KHz, 12.5 pF, SMD
[/hide]
重要提示:PCB作品文件展下载说明
