slar139a.zip
(15.46 MB, 下载次数: 2)
Bill of Material for
On 2018/12/8/周六 at 13:24:18
Comment Pattern Quantity Components
1051640001 Molex_1051640001 1 USB Receptacle, USB 2.0, Micro B, 5 Position, R/A, SMT
3224W-1-204E TRIM_3224W 1 R11 Trimmer, 200 K, 0.25 W, SMD
60900213421 Wurth_60900213421 11 SH-10, SH-J1, SH-J2, SH-J3 Shunt, 2.54mm, Gold, Black
SH-J4, SH-J5, SH-J6, SH-J7
SH-J8, SH-J9, SH-J11
61300311121 WURTH_61300311121 1 J10 Header, 2.54 mm, 3x1, Gold, TH
61301021121 WURTH_61301021121 1 J1 Header, 2.54 mm, 5x2, Gold, TH
ABM3-8.000MHZ-D2Y-T Abracon_ABM3 1 Y1 Crystal, 8MHz, SMD
ABS07-32.768KHZ-9-T XTAL_ABS07 1 Y2 CRYSTAL, 32.768KHZ, 9PF, SMD
AWSCR-8.00CV-T Abracon_AWSCR-CV 1 Y3 Ceramic Resonator, 8MHz, 22pF, SMD
B3U-1000P SW_B3U-1000P 3 MCU_RESET, S201, S202 SWITCH TACTILE SPST-NO 0.05A 12V
BAS40-05-7-F SOT-23 2 D102, D103 Diode, Schottky, 40V, 0.2A, SOT-23
BC850CLT1G SOT-23 1 Q102 Transistor, NPN, 45V, 0.1A, SOT-23
CIG21L2R2MNE 0805 1 L101 Inductor, Shielded, Composite, 2.2uH, 0.95A, 0.16 ohm, SMD
CRCW04020000Z0ED 0402S 15 R27, R28, R29, R30, R31, R32 RES, 0, 5%, 0.063 W, 0402
R33, R34, R35, R36, R37, R38
R50, R51, R124
CRCW0402100KJNED 0402S 2 R9, R10 RES, 100 k, 5%, 0.063 W, 0402
CRCW0402100RJNED 0402S 10 R1, R2, R3, R4, R6, R7, R8 RES, 100, 5%, 0.063 W, 0402
R39, R40, R211
CRCW040210K0JNED 0402S 2 R207, R418 RES, 10 k, 5%, 0.063 W, 0402
CRCW0402150KFKED 0402S 1 R109 RES, 150 k, 1%, 0.063 W, 0402
CRCW040215K0JNED 0402S 8 R400, R401, R402, R403, R405 RES, 15 k, 5%, 0.063 W, AEC-Q200 Grade 0, 0402
R410, R411, R412
CRCW04021K50JNED 0402S 3 R103, R206, R408 RES, 1.5 k, 5%, 0.063 W, 0402
CRCW04021M00JNED 0402S 1 R210 RES, 1.0 M, 5%, 0.063 W, 0402
CRCW0402200RFKED 0402S 2 R16, R17 RES, 200, 1%, 0.063 W, 0402
CRCW0402221KFKED 0402S 6 R107, R108, R116, R117, R118 RES, 221 k, 1%, 0.063 W, 0402
R119
CRCW040222R0JNED 0402S 12 R15, R26, R100, R101, R201 RES, 22, 5%, 0.063 W, 0402
R203, R407, R409, R413, R414
R415, R416
CRCW0402240KFKED 0402S 1 R110 RES, 240 k, 1%, 0.063 W, 0402
CRCW040227R0JNED 0402S 1 R406 RES, 27 ohm, 5%, 0.063W, 0402
CRCW04022K20FKED 0402S 1 R113 RES, 2.20 k, 1%, 0.063 W, 0402
CRCW04022K20JNED 0402S 2 R200, R208 RES, 2.2 k, 5%, 0.063 W, 0402
CRCW0402330KJNED 0402S 3 R12, R13, R14 RES, 330 k, 5%, 0.063 W, 0402
CRCW040233R0JNED 0402S 1 RUSB RES, 33 ohm, 5%, 0.063W, 0402
CRCW0402390RJNED 0402S 5 R23, R24, R105, R202, R204 RES, 390, 5%, 0.063 W, 0402
CRCW04023K32FKED 0402S 1 R115 RES, 3.32 k, 1%, 0.063 W, 0402
CRCW0402470RJNED 0402S 4 R25, R104, R120, R205 RES, 470, 5%, 0.063 W, 0402
CRCW040247K0JNED 0402S 6 R18, R106, R121, R123, R209 RES, 47 k, 5%, 0.063 W, 0402
R404
CRCW04024K70JNED 0402S 2 R111, R112 RES, 4.7 k, 5%, 0.063 W, 0402
CRCW04026K81FKED 0402S 1 R114 RES, 6.81 k, 1%, 0.063 W, 0402
CRCW0402820RJNED 0402S 1 R122 RES, 820, 5%, 0.063 W, 0402
CRCW08050000Z0EA 0805_HV 1 R19 RES, 0, 5%, 0.125 W, 0805
CSTCR4M00G15L99-R0 Murata_CSTCR 2 Q100, Q200 Resonator, 4MHz, 39pF SMD
CSTCR6M00G53Z-R0 Murata_CSTCR 1 Q400 Resonator, 6MHz, 15pF SMD
DMG1013UW SOT-323 1 Q101 MOSFET, P-CH, -50V, -0.13A, SOT-323
FH-1138P ADKOM_FH-1138P 1 LCD 108 Segment LCD Display, TH
Fiducial Fiducial10-30 3 FID1, FID2, FID3 Fiducial mark. There is nothing to buy or mount.
GRM1555C1H100JA01D 0402S 4 C401, C405, C406, C407 CAP, CERM, 10 pF, 50 V, +/- 5%, C0G/NP0, 0402
GRM1555C1H102JA01D 0402S 5 C3, C4, C14, C111, C210 CAP, CERM, 1000 pF, 50 V, +/- 5%, C0G/NP0, 0402
GRM1555C1H120JA01D 0402 4 C7, C8, C15, C16 CAP, CERM, 12 pF, 50 V, +/- 5%, C0G/NP0, 0402
GRM1555C1H120JA01D 0402S 2 C17, C18 CAP, CERM, 12 pF, 50 V, +/- 5%, C0G/NP0, 0402
GRM1555C1H220JA01D 0402S 6 C100, C101, C200, C201, C403 CAP, CERM, 22 pF, 50 V, +/- 5%, C0G/NP0, 0402
C404
GRM1555C1H330JA01D 0402S 4 C109, C110, C114, C115 CAP, CERM, 33 pF, 50 V, +/-5%, C0G/NP0, 0402
GRM155R61C474KE01 0402S 2 C107, C208 CAP, CERM, 0.47 礔, 16 V, +/- 10%, X5R, 0402
GRM155R71C103KA01D 0402S 1 C412 CAP, CERM, 0.01 礔, 16 V, +/- 10%, X7R, 0402
GRM155R71C104KA88D 0402 1 C28 CAP, CERM, 0.1 礔, 16 V, +/- 10%, X7R, 0402
GRM155R71C104KA88D 0402S 21 C1, C2, C5, C6, C13, C20 CAP, CERM, 0.1 礔, 16 V, +/- 10%, X7R, 0402
C102, C104, C108, C113, C118
C119, C121, C202, C203, C204
C400, C402, C408, C409, C411
GRM155R71C224KA12D 0402S 4 C105, C106, C206, C207 CAP, CERM, 0.22 礔, 16 V, +/- 10%, X7R, 0402
GRM1885C1H102FA01J 0603S 2 C11, C12 CAP, CERM, 1000 pF, 50 V, +/- 1%, C0G/NP0, 0603
GRM188R61A106ME69D 0603S 4 C10, C19, C410, C413 CAP, CERM, 10 礔, 10 V, +/- 20%, X5R, 0603
GRM188R61A475MAAJ 0603S 6 C103, C112, C116, C117, C120 CAP, CERM, 4.7 礔, 10 V, +/- 20%, X5R, 0603
C205
GRM188R71A105KA61D 0603S 4 C22, C25, C26, C27 CAP, CERM, 1 礔, 10 V, +/- 10%, X7R, 0603
GRM21BR60J476ME15L 0805_HV 1 C21 CAP, CERM, 47 礔, 6.3 V, +/- 20%, X5R, 0805
GRM21BR60J476ME15L 0805L 2 C23, C24 CAP, CERM, 47 礔, 6.3 V, +/- 20%, X5R, 0805
GRM21BR71C475KA73L 0805_HV 1 C9 CAP, CERM, 4.7 礔, 16 V, +/- 10%, X7R, 0805
HMTSW-102-07-G-S-240 SAMTEC_HMTSW-102-07-G-S-240 2 J4, J7 Header, 100mil, 2x1, Gold, TH
LTST-C190CKT LED_LTST-C190_Red 3 D100, D203, LED3 LED, Red, SMD
LTST-C191TGKT LTST-C191_Green 5 D101, D201, D202, LED1, LED2 LED, Green, SMD
MPZ2012S601A 0805L 2 L1, L2 Ferrite Bead, 600 ohm @ 100 MHz, 2 A, 0805
MSP430F5528IRGCR RGC0064B 2 U100, U200 Mixed Signal MicroController, RGC0064B
MSP430FR6047IPZR PZ0100A_N 1 U1 Mixed-Signal Microcontroller, PZ0100A (LQFP-100)
MSP430G2452IRSA16T RSA0016B 1 U102 16 MHz Mixed Signal Microcontroller with 8 KB Flash, 256 B SRAM and 16 GPIOs, 16-pin QFN (RSA), Green (RoHS & no Sb/Br)
PBC02DAAN Sullins_PxC02DAAN 1 J2 Header, 2.54mm, 2x2, Gold, TH
PBC07SAAN Sullins_xxC07SAAN 2 J100, J200 Header, 2.54 mm, 7x1, Gold, TH
PEC04DAAN CONN_PEC04DAAN 1 J3 Header, 100mil, 4x2, Tin, TH
SBH11-PBPC-D07-ST-BK CONN_SBH11-PBPC-D07-ST-BK 1 J34 Header (shrouded), 100 mil, 7x2, Gold, TH
SJ61A1 Bumpon_SJ61A1 4 H1, H2, H3, H4 Bumpon, Cylindrical, 0.312 X 0.200, Black
SS-13D16-VG 4 PA SW_SS-13D16-VG 1 POW_SEL Switch, Slide, SP3T, On-On-On, 3 Pos, 0.3A, 30 VDC, TH
TL1015AF160QG SW_TL1015AF160QG 5 BUT_DOWN, BUT_LEFT, BUT_RIGHT Switch, Tactile, SPST-NO, 0.05A, 12V, SMT
BUT_SELECT, BUT_UP
TPD2E001DRLR DRL0005A 1 U400 Low-Capacitance + / - 15 kV ESD-Protection Array for High-Speed Data Interfaces, 2 Channels, -40 to +85 degC, 5-pin SOT (DRL), Green (RoHS & no Sb/Br)
TPD4E002DRL2 DRL0005A 3 U103, U201, U202 Low-Capacitance Array with + / - 15 kV ESD Protection, 4 Channels, -40 to +85 degC, 5-pin SOT (DRL), Green (RoHS & no Sb/Br)
TPS62740DSSR DSS0012A 1 U3 360nA IQ Step Down Converter for Low Power Applications, DSS0012A
TPS73533DRBR DRB0008A 1 U402 Single Output High PSRR LDO, 500 mA, Fixed 3.3 V Output, 2.7 to 6.5 V Input, with Low IQ, 8-pin SON (DRB), -40 to 125 degC, Green (RoHS & no Sb/Br)
TPS78001DDCR DDC0005A_N 1 U2 Single Output LDO, 150 mA, Adjustable 1.22 to 5.25 V Output, 2.2 to 5.5 V Input, with 500 nA Quiescent Current, 5-pin SOT (DDC), -40 to 125 degC, Green (RoHS & no Sb/Br)
TS5A21366RSER RSE0008A 1 U101 0.75-Ohm DUAL SPST ANALOG SWITCH WITH 1.8-V COMPATIBLE INPUT LOGIC, RSE0008A (UQFN-8)
TSW-102-07-G-D TSW-102-07-G-D 1 J30 Header, 100mil, 2x2, Gold, TH
TSW-102-07-G-S TSW-102-07-G-S 3 J31, J32, J33 Header, 100mil, 2x1, Gold, TH
TSW-104-07-G-D TSW-104-07-G-D 1 J8 Header, 100mil, 4x2, Gold, TH
TSW-110-07-G-D TSW-110-07-G-D 2 J5, J6 Header, 100mil, 10x2, Gold, TH
TUSB2046BIRHBR RHB0032E 1 U401 4-Port Full-Speed USB Hub, 3.3V, -40 to 85 degC, 32-Pin QFN (RHB), Green (RoHS & no Sb/Br)
Used in BOM report 0402S 12 R20, R21, R22, R41, R42, R43 RES, xxx ohm, x%, xW, [PackageReference]
R44, R45, R46, R47, R48, R49
VLF302515MT-2R2M VLF302515MT 1 L3 Inductor, Shielded, Ferrite, 2.2 礖, 1.57 A, 0.042 ohm, SMD
[/hide] |
