查看: 3293|回复: 5
[AD格式] 带有宽视野 (FOV) 天线的 AWR1642 障碍检测传感器评估模块 原
发表于 2018-12-9 12:53:40 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
sprr342.zip (5.53 MB, 下载次数: 4)
Bill of Material for
Comment             Pattern     Quantity  Components
04025A150FAT2A      0402L            1    C78                          CAP, CERM, 15 pF, 50 V,+/- 1%, C0G/NP0, 0402
0440005.WR          1206             1    F1                           Fuse, 5 A, 32VAC/VDC, SMD
105017-0001         CONN_105017-0001    1    J8                           Connector, Receptacle, Micro-USB Type B, R/A, Bottom Mount SMT
128-0711-201        JOHNSON_128-0711-201    1    J2                           UMC Straight Jack Receptacle, 50 Ohm, Gold, SMT
BLM21PG300SH1D      0805_HV          2    FB1, FB2                     Ferrite Bead, 30 ohm @ 100 MHz, 4 A, 0805
BSS123              SOT-23           2    Q1, Q2                       MOSFET, N-CH, 100 V, 0.17 A, SOT-23
C0402C103K4RACTU    0402L            2    C66, C69                     CAP, CERM, 0.01 礔, 16 V,+/- 10%, X7R, 0402
C0402C104K8RACTU    0402L           14    C16, C20, C42, C43, C49, C64 CAP, CERM, 0.1 礔, 10 V,+/- 10%, X7R, 0402
                                           C67, C71, C75, C76, C79, C91
                                           C92, C97
C0402C330J5GAC      0402L            1    C88                          CAP, CERM, 33 pF, 50 V, +/- 5%, C0G/NP0, 0402
C0603X7S1A104K030BC 0201_033         1    C8                           CAP, CERM, 0.1 礔, 10 V,+/- 10%, X7S, 0201
C1005X7R1E103K050BB 0402L            1    C50                          CAP, CERM, 0.01 礔, 25 V,+/- 10%, X7R, 0402
C1005X7R1H472K050BA 0402L            1    C24                          CAP, CERM, 4700 pF, 50 V,+/- 10%, X7R, 0402
C1005X7S0J105M050BC 0402L            4    C41, C61, C62, C85           CAP, CERM, 1 礔, 6.3 V,+/- 20%, X7S, 0402
C1005X7S1A225K050BC 0402_065L        4    C74, C77, C80, C86           CAP, CERM, 2.2 uF, 10 V, +/- 10%, X7S, 0402
CGA2B2NP01H391J050BA 0402L            4    C93, C94, C95, C96           CAP, CERM, 390 pF, 50 V,+/- 5%, C0G/NP0, AEC-Q200 Grade 0, 0402
CGA2B3X7R1H104K050BB 0402L            2    C2, C21                      CAP, CERM, 0.1 uF, 50 V, +/- 10%, X7R, AEC-Q200 Grade 1, 0402
CGA2B3X8R1H103K050BB 0402L            4    C28, C29, C44, C46           CAP, CERM, 0.01 礔, 50 V,+/- 10%, X8R, AEC-Q200 Grade 0, 0402
CGA5L1X7R0J226M160AC 1206_180         3    C25, C30, C31                CAP, CERM, 22 uF, 6.3 V, +/- 10%, X7R, AEC-Q200 Grade 1, 1206
CHS-01TB            SW_CHS-01TB      1    S2                           Switch, Slide, SPST, Top Slide, SMT
CRCW02010000Z0ED    0201             2    R210, R211                   RES, 0, 5%, 0.05 W, 0201
CRCW02010000Z0ED    0201_Silk       72    R1, R2, R4, R5, R6, R7, R8   RES, 0, 5%, 0.05 W, 0201
                                           R9, R10, R17, R18, R19, R20
                                           R21, R22, R23, R24, R25, R26
                                           R27, R28, R29, R30, R31, R32
                                           R33, R35, R36, R48, R49, R50
                                           R51, R52, R53, R58, R59, R60
                                           R62, R63, R64, R65, R66, R67
                                           R69, R70, R71, R72, R75, R76
                                           R94, R102, R104, R105, R106
                                           R108, R109, R111, R135, R136
                                           R144, R146, R162, R163, R164
                                           R165, R166, R167, R168, R169
                                           R198, R199, R201
CRCW020120R0FNED    0201_033        18    R54, R55, R56, R57, R179     RES, 20.0, 1%, 0.05 W, 0201
                                           R180, R181, R182, R183, R184
                                           R185, R186, R187, R188, R189
                                           R190, R191, R192
CRCW020133R2FNED    0201_Silk        5    R39, R40, R42, R44, R45      RES, 33.2, 1%, 0.05 W, 0201
CRCW0402100KFKED    0402L            6    R14, R110, R138, R158, R172  RES, 100 k, 1%, 0.063 W, 0402
                                           R173
CRCW040210K0FKED    0402L           28    R3, R13, R15, R16, R41, R43  RES, 10.0 k, 1%, 0.063 W, 0402
                                           R46, R47, R73, R74, R81, R83
                                           R84, R86, R89, R91, R98, R113
                                           R145, R148, R155, R170, R171
                                           R177, R194, R197, R206, R208
CRCW040212K7FKED    0402L            1    R82                          RES, 12.7 k, 1%, 0.063 W, 0402
CRCW040214K0FKED    0402L            1    R61                          RES, 14.0 k, 1%, 0.063 W, 0402
CRCW04021K00FKED    0402L            5    R123, R124, R126, R127, R140 RES, 1.00 k, 1%, 0.063 W, 0402
CRCW04021K96FKED    0402L            3    R122, R131, R139             RES, 1.96 k, 1%, 0.063 W, 0402
CRCW040230K0FKED    0402L            2    R157, R174                   RES, 30.0 k, 1%, 0.063 W, AEC-Q200 Grade 0, 0402
CRCW0402330KFKED    0402L            2    R151, R153                   RES, 330 k, 1%, 0.063 W, AEC-Q200 Grade 0, 0402
CRCW04023K00FKED    0402L            2    R121, R132                   RES, 3.00 k, 1%, 0.063 W, AEC-Q200 Grade 0, 0402
CRCW04023R83FKED    0402L            4    R202, R203, R204, R205       RES, 3.83, 1%, 0.063 W, 0402
CRCW040247K5FKED    0402L            1    R38                          RES, 47.5 k, 1%, 0.063 W, 0402
CRCW040249K9FKED    0402L            1    R156                         RES, 49.9 k, 1%, 0.063 W, 0402
CRCW040249R9FKED    0402L            1    R134                         RES, 49.9, 1%, 0.063 W, 0402
CRCW04024K87FKED    0402L            1    R125                         RES, 4.87 k, 1%, 0.063 W, 0402
CRCW04024K99FKED    0402L            2    R143, R147                   RES, 4.99 k, 1%, 0.063 W, 0402
CRCW040261R9FKED    0402L            2    R85, R87                     RES, 61.9, 1%, 0.063 W, 0402
CRCW0402750RFKED    0402L            3    R93, R101, R112              RES, 750, 1%, 0.063 W, AEC-Q200 Grade 0, 0402
CRCW04027K87FKED    0402L            3    R92, R95, R99                RES, 7.87 k, 1%, 0.063 W, AEC-Q200 Grade 0, 0402
CRCW040282K5FKED    0402L            3    R88, R96, R114               RES, 82.5 k, 1%, 0.063 W, AEC-Q200 Grade 0, 0402
CRCW20100000Z0EF    2010             3    R34, R115, R118              RES, 0, 5%, 0.75 W, AEC-Q200 Grade 0, 2010
CX3225SA40000D0PTWCC KYOCERA_CX3225SA    1    Y1                           Crystal, 40 MHz, 8pF, SMD
DFE252012P-R47M=P2  DFE252012P       6    L1, L2, L3, L4, L5, L6       Inductor, Shielded, 470 nH, 4.7 A, 0.021 ohm, SMD
ERJ-2GE0R00X        0402L           16    R11, R12, R37, R78, R97, R107 RES, 0, 5%, 0.063 W, 0402
                                           R119, R120, R128, R129, R141
                                           R152, R159, R178, R196, R200
ERJ-2GEJ101X        0402L            5    R68, R77, R79, R80, R154     RES, 100, 5%, 0.1 W, AEC-Q200 Grade 0, 0402
ERJ-2GEJ102X        0402L            1    R149                         RES, 1.0 k, 5%, 0.1 W, AEC-Q200 Grade 0, 0402
ERJ-2GEJ361X        0402L            1    R90                          RES, 360, 5%, 0.1 W, AEC-Q200 Grade 0, 0402
ERJ-2GEJ511X        0402L            5    R100, R103, R116, R117, R160 RES, 510, 5%, 0.1 W, AEC-Q200 Grade 0, 0402
ERJ-2RKF4991X       0402L            2    R142, R150                   RES, 4.99 k, 1%, 0.1 W, AEC-Q200 Grade 0, 0402
Fiducial            FIDUCIAL10-20    7    FID1, FID2, FID3, FID4, FID5 Fiducial mark.  There is nothing to buy or mount.
                                           FID6, FID7
GCM155R71C104KA55D  0402L            3    C4, C6, C11                  CAP, CERM, 0.1 uF, 16 V, +/- 10%, X7R, 0402
GCM155R71C224KE02D  0402L           15    C3, C5, C7, C10, C12, C39    CAP, CERM, 0.22 礔, 16 V,+/- 10%, X7R, AEC-Q200 Grade 1, 0402
                                           C47, C48, C51, C53, C56, C57
                                           C68, C84, C90
GCM188R70J225KE22D  0603             2    C87, C89                     CAP, CERM, 2.2 uF, 6.3 V, +/- 10%, X7R, AEC-Q200 Grade 1, 0603
GCM188R71C105KA64D  0603             5    C1, C13, C14, C33, C36       CAP, CERM, 1 uF, 16 V, +/- 10%, X7R, AEC-Q200 Grade 1, 0603
GCM188R71C474KA55D  0603             2    C18, C22                     CAP, CERM, 0.47 uF, 16 V, +/- 10%, X7R, AEC-Q200 Grade 1, 0603
GCM21BR71A106KE22L  0805_HV         18    C17, C19, C23, C32, C34, C35 CAP, CERM, 10 uF, 10 V, +/- 10%, X7R, 0805
                                           C37, C38, C40, C45, C52, C58
                                           C59, C60, C65, C72, C73, C83
GCM31CR71A226KE02   1206_180         4    C54, C55, C81, C82           CAP, CERM, 22 uF, 10 V, +/- 10%, X7R, AEC-Q200 Grade 1, 1206
GJM1555C1H4R7BB01D  0402L            2    C9, C15                      CAP, CERM, 4.7 pF, 50 V, +/- 2%, C0G/NP0, 0402
GRM1555C1H8R0DA01D  0402L            2    C63, C70                     CAP, CERM, 8 pF, 50 V, +/- 6%, C0G/NP0, 0402
KMR243GLFG          SW_KMR243GLFG    2    SW1, SW2                     Switch, SPST-NO, Off-Mom, 0.01 A, 32 VDC, SMD
LM4040C25QDBZR      DBZ0003A_N       1    U7                           Precision Micropower Shunt Voltage Reference, 0.5% accuracy, 2.5 V, 15 ppm / degC, 15 mA, -40 to 125 degC, 3-pin SOT-23 (DBZ), Green (RoHS & no Sb/Br)
LP87524BRNFRQ1      RNF0026C         1    U8                           Four-Phase 2.5-A-per-Phase Buck Converter With Integrated Switches, RNF0026C (VQFN-HR-26)
MCT06030Z0000ZP500  0603             7    R130, R133, R137, R161, R175 RES, 0, 5%, 0.125 W, 0603
                                           R176, R195
MX25V1635FZNQ       WSON-8L_6x5MM_EP    1    U1                           2.3V-3.6V, 16M-BIT [x 1/x 2/x 4] CMOS FLASH Memory, WSON-8
NX3225SA-16.000M-STD-CRS-2 NDK_NX3225SA     1    Y2                           Crystal, 16 MHz, 15 ppm, 8 pF, AEC-Q200 Grade 1, SMD
OSTTE030161         ON-SHORE_OSTTE030161    1    J3                           Terminal Block, 3.5mm, 3x1, Tin, R/A, TH
PJ-002AH            CUI_PJ-002AH     1    P6                           DC POWER JACK, R/A, TH
PNM0402E3502BST1    0402L            1    R193                         RES, 35000, 0.1%, 0.05 W, 0402
QSH-030-01-L-D-A    SAMTEC_QSH-030-01-X-D-A    1    J1                           Receptacle, 0.5 mm, 30x2, Gold, TH
Size: 0.65" x 0.20 " Label_650x200    1    LBL1                         Thermal Transfer Printable Labels, 0.650" W x 0.200" H - 10,000 per roll
SMS3923-040LF       SOD-882          1    D2                           Diode, Schottky,  V, 0.01 A, SOD-882
SSM-103-S-SV        SAMTEC_SSM-103-X-SV    2    J4, J7                       Receptacle, 2.54mm, 3x1, Gold with Tin tail, SMT
SSM-110-S-DV        SAMTEC_SSM-110-X-DV    2    J5, J6                       Receptacle, 2.54mm, 10x2, Gold with Tin tail, SMT
SZP6SMB6.8AT3G      SMB              1    D3                           Diode, TVS, Uni, 5.8 V, 10.5 Vc, AEC-Q101, SMB
T491B476K010AT      3528-21          2    C26, C27                     CAP, TA, 47 礔, 10 V, +/- 10%, SMD
TCAN1042HGVDQ1      D0008A_L         1    U3                           Automotive Fault Protected CAN Transceiver With Flexible Data-Rate, D0008A (SOIC-8)
TLMS1000-GS08       TLMX1000_RED     2    DS1, DS2                     LED, Red, SMD
TLMY1000-GS08       TLMX1000_YELLOW    2    DS3, DS4                     LED, Yellow, SMD
TM4C1294NCPDTT3     PDT0128A         1    U6                           Tiva C Series Microcontroller, 1024 KB Flash, 256 KB SRAM, 12 Bit, 20 Channels, -40 to 105 degC, 128-Pin TQFP (PDT), Green (RoHS & no Sb/Br), Tray
TMP112AIDRLR        DRL0006A         2    U12, U13                     1.4V-Capable +/-0.5degC Temperature Sensor with Alert Function and I2C/SMBus interface in SOT-563, DRL0006A (SOT-OTHER-6)
TPD4E004DRYR        DRY0006A         1    U10                          ESD-Protection Array for High-Speed Data Interfaces, 4 Channels, -40 to +85 degC, 6-pin SON (DRY), Green (RoHS & no Sb/Br)
TPS79601DRBR        DRB0008B         2    U9, U11                      Single Output High PSRR LDO, 1 A, Adjustable 1.2 to 5.5 V Output, 2.7 to 5.5 V Input, 8-pin SON (DRB), -40 to 125 degC, Green (RoHS & no Sb/Br)
TPS7A8101QDRBRQ1    DRB0008A         1    U4                           Automotive Low-Noise, Wide-Bandwidth, High PSRR, Low-Dropout 1-A Linear Regulator, DRB0008A (VSON-8)
TPS7A8801RTJR       RTJ0020D         1    U5                           Dual, 1-A, Low Noise (3.8-uVRMS), LDO Voltage Regulator, RTJ0020D (WQFN-20)
TS3A5018RSVR        RSV0016A         1    U14                          10-Ohm Quad SPDT Analog Switch, RSV0016A (UQFN-16)
TSW-102-07-G-S      TSW-102-07-X-S    5    P2, P3, P4, P5, P7           Header, 100mil, 2x1, Gold, TH
TSW-103-07-T-S      SAMTEC_TSW-103-07-T-S    1    P1                           Header, 2.54 mm, 3x1, Tin, TH
X1642BIGABL         ABL0161B         1    U2                           Single-Chip 77- and 79-GHz FMCW Radar Sensor, ABL0161B (FCBGA-161)
[/hide]
重要提示:PCB作品文件展下载说明
发表于 2019-11-20 17:40:08 | 显示全部楼层
发表于 2019-11-20 17:42:23 | 显示全部楼层
终身成就奖特殊贡献奖原创先锋奖金点子奖
发表于 2022-10-9 08:15:39 | 显示全部楼层
    11 小时前
  • 签到天数: 288 天
    发表于 2022-10-9 08:43:23 | 显示全部楼层
    郁闷
    2024-6-1 15:35
    终身成就奖金点子奖特殊贡献奖原创先锋奖
    发表于 2022-10-9 08:45:41 | 显示全部楼层
