[AD格式] TB-S5D5目标板套件 原理图 PCB
查看3325 | 回复5 | 2018-12-9 13:31:06 | 显示全部楼层 |阅读模式
Comment             Pattern     Quantity  Components
CAP-000029-01       CAPC0603-01     22    C1, C5, C6, C7, C8, C9, C11  Ceramic Chip Capacitor 0603 0.1uF 50V
                                           C17, C18, C21, C23, C24, C25
                                           C26, C27, C29, C30, C50, C51
                                           C52, C53, C54
CAP-000040-01       CAPC0603-01      1    C33                          Ceramic Chip Capacitor 0603 18pF 50V
CAP-000043-01       CAPC0603-01      4    C4, C19, C20, C28            Ceramic Chip Capacitor 0603 4.7uF 6.3V
CAP-000059-01       CAPC0402-01      2    C15, C16                     Ceramic Chip Capacitor 0402 12pF 50V
CAP-000062-01       CAPC0402-01      1    C12                          Ceramic Chip Capacitor 0402 0.01uF 50V
CAP-000063-01       CAPC0402-01      3    C2, C3, C22                  Ceramic Chip Capacitor 0402 1uF 16V
CAP-000081-01       CAPC0201-01      2    C13, C14                     Ceramic Chip Capacitor 0201 10pF 25V
CAP-000127-01       CAPC0402-01      2    C31, C32                     Ceramic Chip Capacitor 0402 47pF 50V NP0/C0G
CON-000050-01       SAMTEC_SSW-106-02-F-D-RA-PMOD    1    J5                           Samtec Female Header 0.1" pitch PMOD 2x6 Right Angle
CON-000109-A1       J_2x20pHDR100mil    4    J1, J2, J3, J4               Header 0.1" pitch 40pos 2x20, T<->B Inverted
CON-000116-01       FCI_10118192     2    J9, J11                      USB Micro 2.0 Female 5 Pin Right Angle
CON-000148-01       SAMTEC_SSW-106-02-F-S-RA    1    J6                           Samtec Female Header 0.1" pitch 6pos 1x6 Right Angle
CON-000174-01       FCI_77313-801-04LF    1    J8                           FCI Header 0.1" pitch 4pos 2x2
CON-000241-01       TC2030NL         1    J12                          Tag Connect TC-2030 PCB Pads 6 Pos 2x3
CON-REN001-01       J_10PTH2CX5R     1    J10                          10 Position Shrouded Header 1.27mm Pitch
DIO-000012-01       ONSEMI_SOD-123LF    1    D1                           OnSemi Schottky Power Rectifier 40V 1A
ICN-000202-01       RENESAS_PLQP0064KB-A_N    1    U2                           Renesas S124 32-Bit 32MHz Cortex M0+ MCU LQFP64
ICN-000215-01       SOT-89-3         1    U3                           LDO Regulator 3.3V 600mA
ICN-R01001-01       RENESAS_PLQP0144KA-B_N    1    U1                           Renesas S5D5 ARM Cortex M4 120MHz MCU LQFP144
IND-000027-01       FL0504           1    FL1                          Common Mode Filter Inductor, 200 ohm CM @ 100MHz
LED-000001-01       LED_DIALIGHT-598-8610    1    LED2                         Dialight Bicolor LED Red/Green 1210
LED-000005-01       LED_0603-RED     1    LED1                         Lite-On LED Red Clear 0603
POT-000001-02       BOURNS_3352T     1    POT1                         Bourns Single Turn Trimmer 10K0
RES-000091-01       RESC0603-01      3    R6, R7, R8                   Chip Resistor Thick Film 0603 10K2 1% 1/10W
RES-000117-01       RESCAF0804       2    RA1, RA2                     Chip Resistor Array 0804 30K0 5% 1/16W 4 x 0402
RES-000124-01       RESC0402-01      2    R1, R5                       Chip Resistor Thick Film 0402 470R 0.5% 1/16W
RES-000127-01       RESC0402-01      1    R10                          Chip Resistor Thick Film 0402 4K70 0.5% 1/16W
RES-000140-01       RESC0402-01      2    R2, R9                       Chip Resistor Thick Film 0402 1K50 0.5% 1/16W
RES-000173-01       RESC0402-01      1    R3                           Chip Resistor Thick Film 0402 47K0 1% 1/10W
RES-000206-01       RESC0603-01      1    R4                           Chip Resistor Thick Film 0603 560R0 1% 1/10W
RES-000220-01       RESC0402-01      2    R11, R12                     Chip Resistor Thick Film 0402 150R 1% 1/10W
RES-R70620-01       RESC0603-01      2    R51, R52                     Chip Resistor Thick Film 0603 27 5% 1/10W
SWT-000013-01       SW_C&K_PTS645_43    2    S1, S2                       Push Button Switch 6 x 6mm 4.3mm High
This BOM is for Engineering Use Only, NOT FOR PURCHASE USE. _SERIOUSENGINEERING    1    A_Logo1                      Combination disclaimer and Serious Integrated Design splash
XTL-000006-01       ABRACON_ABS07    1    X2                           Crystal 32.769KHz 12.5pF SMT
XTL-000011-01       TXC_7V           1    X1                           Crystal 12MHz 10pF
购买主题 本主题需向作者支付 1 枚金币 才能浏览
重要提示:PCB作品文件展下载说明
郑先生 | 2018-12-9 14:11:01 | 显示全部楼层
robinfit | 2018-12-9 15:47:03 | 显示全部楼层
tonyz1 | 2022-8-7 08:58:11 | 显示全部楼层
tonyz1 | 2022-8-7 08:59:09 | 显示全部楼层
tonyz1 | 2022-8-7 08:59:32 | 显示全部楼层
