查看: 3357|回复: 12
[AD格式] 电机驱动器的隔离式电流分流和电压测量参考设计
PADS-180606高级班
社区居民终身成就奖特殊贡献奖优秀斑竹奖
发表于 2018-12-9 17:42:32 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
4层1028PIN
游客,如果您要查看本帖隐藏内容请回复
DesignatorDescriptionQuantity
!PCB1Printed CircuitBoard1
C1, C2, C8, C9, C32, C64CAP,AL, 22uF, 25V, +/-20%, 0.76 ohm, SMD6
C3, C7,C13, C15, C112, C124, C136CAP, CERM,0.1uF, 25V, +/-5%, X7R, 06037
C4, C10, C17, C114, C126, C138CAP,CERM, 3900pF, 25V, +/-5%, C0G/NP0, 06036
C5, C6,C11, C12, C14, C16, C18, C19, C20, C21, C26, C27, C29, C31, C34, C36, C41,C43, C44, C46, C53, C54, C59, C60, C68, C69, C70, C72, C74, C76, C78, C80,C85, C87, C88, C90, C97, C98, C104, C105, C106, C109, C110, C111, C115, C116,C118, C119, C120, C121, C122, C123, C127, C128, C130, C131, C132, C133, C134,C135, C139, C140, C142, C143, C144, C145CAP, CERM,0.1uF, 50V, +/-10%, X7R, 060366
C22, C23, C61, C62, C63CAP,CERM, 1000pF, 2KV 10% X7R 12065
C24,C25, C28, C30, C33, C35, C37, C39, C47, C48, C55, C56, C57, C58, C65, C66,C67, C71, C73, C75, C77, C79, C81, C83, C91, C92, C99, C100, C101, C102,C107, C108CAP, CERM,10uF, 35V, +/-20%, X7R, 121032
C38, C40, C51, C52, C82, C84, C95, C96, C103CAP,CERM, 4.7uF, 50V, +/-10%, X5R, 08059
C42, C45,C49, C50, C86, C89, C93, C94CAP, CERM,0.01uF, 100V, +/-5%, X7R, 06038
C113, C117, C125, C129, C137, C141CAP,CERM, 4700pF, 100V, +/-10%, X7R, 06036
D1, D2,D3, D4, D5, D6, D35, D36, D37, D38, D39, D40Diode, P-N,70V, 0.2A, SOT-32312
D7, D8, D9, D10, D19, D20, D21, D22, D23, D24Diode,Schottky, 20V, 0.5A, SOD-12310
D11, D12,D15, D16, D25, D26, D29, D30, D31Diode, Zener,6.2V, 1W, PowerDI1239
D13, D14, D17, D18, D27, D28, D32, D33, D34LEDSmartLED Green 570NM9
FB1, FB2,FB3, FB4, FB5, FB6, FB7, FB8, FB9FERRITE CHIP1000 OHM 300MA 06039
FID1, FID2, FID3, FID4, FID5, FID6, FID7, FID8Fiducialmark.  There is nothing to buy ormount.8
J1Connector,Right Angle 2x20 pin, 100mil spacing1
J2, J4, J6, J8TerminalBlock, 4x1, 2.54mm, TH4
J3, J5,J7, J9, J10, J11, J12, J13, J14, J15, J16, J17, J18, J19, J20, J21, J22Header, Male2-pin, 100mil spacing,17
LBL1ThermalTransfer Printable Labels, 0.650" W x 0.200" H - 10,000 per roll1
MH1, MH2,MH3, MH4Mountin hole,NPTH Drill 3.2mm4
R1, R4, R9, R12, R20, R29RES,100 ohm, 1%, 0.1W, 06036
R2, R10,R23RES 50mOHM 3W.5% TO-247 TH3
R3, R11, R24RESMETAL .005 OHM 5W 1% RADIAL3
R5, R6,R13, R14, R19, R25, R26, R30, R31, R54, R57, R59, R60, R63, R65, R67, R69,R72, R78, R81, R83, R84, R85, R89, R91, R93, R96, R102, R105, R107, R108,R109, R113, R115, R117, R120RES, 0 ohm, 5%,0.1W, 060336
R7, R8, R15, R16, R27, R28, R32, R33, R73, R74, R97, R98, R121,R122RES,10.0 ohm, 1%, 0.1W, 060314
R17,R18, R51, R52, R55, R70, R75, R76, R79, R94, R99, R100, R103, R118RES 2.2M OHM1/3W 1% 121014
R21, R61, R68, R87, R92, R111, R116RES2K OHM 1/3W 1% 12107
R22RES, 2.00k ohm,0.5%, 0.1W, 06031
R34, R35, R40, R41, R42, R43, R48, R49, R50RES,3.9k ohm, 5%, 0.1W, 06039
R36, R37,R44, R45RES, 37.0k ohm,0.1%, 0.1W, 06034
R38, R39, R46, R47RES,11.5k ohm, 1%, 0.1W, 06034
R53, R71,R77, R95, R101, R119RES 15.0K OHM1/10W .1% SMD 06036
R56, R66, R80, R90, R104, R114RES,56.0 ohm, 1%, 0.1W, 06036
R58, R82,R106RES, 1.00k ohm,1%, 0.1W, 06033
R62, R64, R86, R88, R110, R112RES,4.70k ohm, 1%, 0.1W, 06036
T1, T2,T3, T4, T5Transformer475uH SMD5
TP1, TP2, TP3, TP4, TP5, TP6, TP7, TP8, TP9, TP10, TP11, TP12TestPoint, O.040 Hole12
U1, U2, U420 MHz,Isolated Delta-Sigma Modulator, LVDS interface:3
U3, U21, U24, U2720MHz, Isolated Delta-Sigma Modulator, LVDS interface:4
U5, U6,U11, U12, U13TransformerDriver for Isolated Power Supplies, DBV0005A5
U7, U8, U14, U15-36V,-200mA, Ultralow-Noise, Negative Linear Regulator4
U9, U10,U16, U17, U18Regulator, LDO,5V, 0.15A, SOT23-55
U19, U22, U25IC,Precision, 200uA, 36V Supply Instrument Amplifier.3
U20, U23,U26IC, 1.1nV/vHzNoise, Low Power, Precision OpAmp3
重要提示:PCB作品文件展下载说明
生活就是油盐酱醋再加一点糖,快活就是一天到晚乐呵呵的忙!
    PADS-181217初级班
    发表于 2018-12-10 00:59:40 | 显示全部楼层
  • 签到天数: 74 天
    发表于 2018-12-11 08:56:25 | 显示全部楼层
  • 签到天数: 9 天
    发表于 2018-12-11 08:56:47 | 显示全部楼层
    头像被屏蔽
    禁止发言
    发表于 2019-11-12 18:45:02 | 显示全部楼层
    提示: 作者被禁止或删除 内容自动屏蔽
    发表于 2019-12-23 15:32:40 | 显示全部楼层
    像美国牛人造火箭
    终身成就奖社区居民社区明星宣传大使奖
    发表于 2020-3-13 18:17:53 | 显示全部楼层
    太帅了,超喜欢,感谢
    发表于 2020-3-16 14:30:30 | 显示全部楼层
    非常感谢楼主的分享,楼主辛苦了!
    发表于 2020-3-17 13:07:40 | 显示全部楼层
  • 签到天数: 36 天
    发表于 2021-6-9 08:30:24 | 显示全部楼层
