查看: 2570|回复: 0
[Allegro16.6以下] Arria_10_GX_Transceiver_Signal_Integrity_Development_Kit 信号完整性开
发表于 2018-12-10 05:35:38 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
本板文件名为ALTERA_a10gx_si_e4_24Sep15_1705
本坛已有文件为ALTERA_a10gx_si_e4a_08OCT15_1330
本人已发文件为ALTERA_a10gx_si_e4_11Sep15_1405_QAed
三者布线略有不同,都是原厂文件
02 Arria_10_GX_Transceiver_Signal_Integrity_Development_Kit B.rar (10.38 MB, 下载次数: 3)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUEREFDES
USB-67068-8001CN-USB_USB-67068-8001_CN-USBCN-USBCN1
LUMEX_LED1206LED_LUMEX_LED1206_AMBER_LEDAmber_LEDD3
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD4
LUMEX_LED1206LED_LUMEX_LED1206_GREENGreenD8
LUMEX_LED1206LED_LUMEX_LED1206_GREENGreenD9
LUMEX_LED1206LED_LUMEX_LED1206_GREENGreenD10
LUMEX_LED1206LED_LUMEX_LED1206_GREENGreenD11
LUMEX_LED1206LED_LUMEX_LED1206_GREENGreenD12
LUMEX_LED1206LED_LUMEX_LED1206_GREENGreenD13
LUMEX_LED1206LED_LUMEX_LED1206_GREENGreenD14
LUMEX_LED1206LED_LUMEX_LED1206_GREENGreenD15
LUMEX_LED1206LED_LUMEX_LED1206_GREENGreenD16
LUMEX_LED1206LED_LUMEX_LED1206_GREENGreenD17
LUMEX_LED1206LED_LUMEX_LED1206_GREENGreenD18
LUMEX_LED1206LED_LUMEX_LED1206_GREENGreenD19
LUMEX_LED1206LED_LUMEX_LED1206_GREENGreenD20
LUMEX_LED1206LED_LUMEX_LED1206_GREENGreenD21
LUMEX_LED1206LED_LUMEX_LED1206_GREENGreenD22
LUMEX_LED1206LED_LUMEX_LED1206_GREENGreenD23
LUMEX_LED1206LED_LUMEX_LED1206_GREENGreenD24
LUMEX_LED1206LED_LUMEX_LED1206_GREENGreenD25
LUMEX_LED1206LED_LUMEX_LED1206_GREENGreenD26
SO8LT1389_SO8_LT1389LT1389D31
LUMEX_LED1206LED_LUMEX_LED1206_GREENGreenD32
LUMEX_LED1206LED_LUMEX_LED1206_GREENGreenD34
SOD323D-SCHOTTKY_0_SOD323_CMDSH-3CMDSH-3D44
SOD323D-SCHOTTKY_0_SOD323_CMDSH-3CMDSH-3D45
SOD323D-SCHOTTKY_0_SOD323_CMDSH-3CMDSH-3D46
SOD323D-SCHOTTKY_0_SOD323_CMDSH-3CMDSH-3D47
805INDUCTOR_805_120OHM,800MA120ohm, 800mAFB1
805INDUCTOR_805_120OHM,800MA120ohm, 800mAFB2
805INDUCTOR_805_120OHM,800MA120ohm, 800mAFB3
805INDUCTOR_805_120OHM,800MA120ohm, 800mAFB4
805INDUCTOR_805_120OHM,800MA120ohm, 800mAFB5
805INDUCTOR_805_120OHM,800MA120ohm, 800mAFB6
1612INDUCTOR_1612_56OHM,10A56ohm, 10AFB7
805INDUCTOR_805_120OHM,800MA120ohm, 800mAFB8
CUI_PD-40S_4PIN-DIN-JACK_RACUI_PD-40S_CUI_PD-40S_4PIN-DIN-PD-40SJ1
BANANA_JACKBANANA_JACK_RED_BANANA_JACK_B_1BANANA_JACK_BLACKJ2
BANANA_JACKBANANA_JACK_RED_BANANA_JACK_B_1BANANA_JACK_BLACKJ3
BANANA_JACKBANANA_JACK_RED_BANANA_JACK_BANBANANA_JACK_REDJ4
BANANA_JACKBANANA_JACK_RED_BANANA_JACK_BANBANANA_JACK_REDJ5
BANANA_JACKBANANA_JACK_RED_BANANA_JACK_BANBANANA_JACK_REDJ6
BANANA_JACKBANANA_JACK_RED_BANANA_JACK_BANBANANA_JACK_REDJ7
BANANA_JACKBANANA_JACK_RED_BANANA_JACK_BANBANANA_JACK_REDJ8
BANANA_JACKBANANA_JACK_RED_BANANA_JACK_BANBANANA_JACK_REDJ12
BANANA_JACKBANANA_JACK_RED_BANANA_JACK_BANBANANA_JACK_REDJ13
BANANA_JACKBANANA_JACK_RED_BANANA_JACK_BANBANANA_JACK_REDJ14
2X6HDR-2MMX2MM2X6HDR_2X6HDR-2MMX2MM_2X6HDR2x6HDRJ16
HDR1X3_100MILCON3_HDR1X3_100MIL_HDR1X3HDR1X3J17
HDR2X5_100MIL_SMT2X5_HDR2X5_100MIL_SMT_HDR2X5HDR2X5J18
RJ45HFJ11-1G02E_RJ45_HFJ11-1G02EHFJ11-1G02EJ19
NEWHAVEN_LCDLCD_HEADER_NEWHAVEN_LCD_HDR1X10HDR1X10J20
HDR2X7_100MILHDR2X7_HDR2X7_100MIL_HDR2X7HDR2X7J21
JX440-50014AMPHENOL_CONN_JX440-50014_JX440JX440-50014J22
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J23
CFP2_CONN_X4CFP2-CN121S-104-0001_CFP2_CONN_CFP2-CN121S-104-0001J24
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J25
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J26
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J27
CN120-03-0001_AMOLEX_ZQSFP+_0_CN120-03-0001_A_zQSFP+J28
SAMTEC_SFP_MECT20SFP+_AND_CAGE_SAMTEC_SFP_MECT20SFP+_CONNJ29
73387_0020_SMA2P4MMMOLEX_73387-0020_SMA-2.4MM_73382.4mmJ30
73387_0020_SMA2P4MMMOLEX_73387-0020_SMA-2.4MM_73382.4mmJ31
73387_0020_SMA2P4MMMOLEX_73387-0020_SMA-2.4MM_73382.4mmJ32
73387_0020_SMA2P4MMMOLEX_73387-0020_SMA-2.4MM_73382.4mmJ33
73387_0020_SMA2P4MMMOLEX_73387-0020_SMA-2.4MM_73382.4mmJ34
73387_0020_SMA2P4MMMOLEX_73387-0020_SMA-2.4MM_73382.4mmJ35
73387_0020_SMA2P4MMMOLEX_73387-0020_SMA-2.4MM_73382.4mmJ36
73387_0020_SMA2P4MMMOLEX_73387-0020_SMA-2.4MM_73382.4mmJ37
73387_0020_SMA2P4MMMOLEX_73387-0020_SMA-2.4MM_73382.4mmJ38
73387_0020_SMA2P4MMMOLEX_73387-0020_SMA-2.4MM_73382.4mmJ39
73387_0020_SMA2P4MMMOLEX_73387-0020_SMA-2.4MM_73382.4mmJ40
73387_0020_SMA2P4MMMOLEX_73387-0020_SMA-2.4MM_73382.4mmJ41
73387_0020_SMA2P4MMMOLEX_73387-0020_SMA-2.4MM_73382.4mmJ42
73387_0020_SMA2P4MMMOLEX_73387-0020_SMA-2.4MM_73382.4mmJ43
73387_0020_SMA2P4MMMOLEX_73387-0020_SMA-2.4MM_73382.4mmJ44
73387_0020_SMA2P4MMMOLEX_73387-0020_SMA-2.4MM_73382.4mmJ45
BULLSEYE_HDR-170740-01-BEYESAMTEC_BULLSEYE_BULLSEYE_HDR-17HDR-170740-01-BEYEJ46
BULLSEYE_HDR-170740-01-BEYESAMTEC_BULLSEYE_BULLSEYE_HDR-17HDR-170740-01-BEYEJ47
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J48
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J49
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J50
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J51
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J52
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J53
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J54
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J56
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J57
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J59
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J60
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J62
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J63
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J65
HDR2X5_100MIL70247-1051_HDR2X5_100MIL_HDR2X5HDR2X5J66
73387_0020_SMA2P4MMMOLEX_73387-0020_SMA-2.4MM_73382.4mmJ67
73387_0020_SMA2P4MMMOLEX_73387-0020_SMA-2.4MM_73382.4mmJ68
73387_0020_SMA2P4MMMOLEX_73387-0020_SMA-2.4MM_73382.4mmJ69
73387_0020_SMA2P4MMMOLEX_73387-0020_SMA-2.4MM_73382.4mmJ70
73387_0020_SMA2P4MMMOLEX_73387-0020_SMA-2.4MM_73382.4mmJ71
73387_0020_SMA2P4MMMOLEX_73387-0020_SMA-2.4MM_73382.4mmJ72
73387_0020_SMA2P4MMMOLEX_73387-0020_SMA-2.4MM_73382.4mmJ73
73387_0020_SMA2P4MMMOLEX_73387-0020_SMA-2.4MM_73382.4mmJ74
JMP_SMT_5102JMP_SMT_5102_JMP_SMT_5102_JMP_SJMP_SMT_5102J79
JMP_SMT_5102JMP_SMT_5102_JMP_SMT_5102_JMP_SJMP_SMT_5102J81
JMP_SMT_5102JMP_SMT_5102_JMP_SMT_5102_JMP_SJMP_SMT_5102J82
JMP_SMT_5102JMP_SMT_5102_JMP_SMT_5102_JMP_SJMP_SMT_5102J83
JMP_SMT_5102JMP_SMT_5102_JMP_SMT_5102_JMP_SJMP_SMT_5102J89
JMP_SMT_5102JMP_SMT_5102_JMP_SMT_5102_JMP_SJMP_SMT_5102J90
JMP_SMT_5102JMP_SMT_5102_JMP_SMT_5102_JMP_SJMP_SMT_5102J91
JMP_SMT_5102JMP_SMT_5102_JMP_SMT_5102_JMP_SJMP_SMT_5102J92
HDR2X7_100MILHDR2X7_HDR2X7_100MIL_HDR2X7HDR2X7J95
JMP_SMT_5102JMP_SMT_5102_JMP_SMT_5102_JMP_SJMP_SMT_5102J96
JMP_SMT_5102JMP_SMT_5102_JMP_SMT_5102_JMP_SJMP_SMT_5102J97
JMP_SMT_5102JMP_SMT_5102_JMP_SMT_5102_JMP_SJMP_SMT_5102J98
JMP_SMT_5102JMP_SMT_5102_JMP_SMT_5102_JMP_SJMP_SMT_5102J99
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J100
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J101
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J102
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J103
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J104
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J105
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J106
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J107
JMP_SMT_5102JMP_SMT_5102_JMP_SMT_5102_JMP_SJMP_SMT_5102J108
JMP_SMT_5102JMP_SMT_5102_JMP_SMT_5102_JMP_SJMP_SMT_5102J110
JMP_SMT_5102JMP_SMT_5102_JMP_SMT_5102_JMP_SJMP_SMT_5102J111
BANANA_JACKBANANA_JACK_RED_BANANA_JACK_BANBANANA_JACK_REDJ112
BANANA_JACKBANANA_JACK_RED_BANANA_JACK_BANBANANA_JACK_REDJ113
JMP_SMT_5102JMP_SMT_5102_JMP_SMT_5102_JMP_SJMP_SMT_5102J114
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J122
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J123
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J124
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J125
JMP_SMT_5102JMP_SMT_5102_JMP_SMT_5102_JMP_SJMP_SMT_5102J126
JMP_SMT_5102JMP_SMT_5102_JMP_SMT_5102_JMP_SJMP_SMT_5102J127
JMP_SMT_5102JMP_SMT_5102_JMP_SMT_5102_JMP_SJMP_SMT_5102J128
JMP_SMT_5102JMP_SMT_5102_JMP_SMT_5102_JMP_SJMP_SMT_5102J129
IND_WURTH_74479775210INDUCTOR_SMD_1_IND_WURTH_7447971.0uHL5
IND_WURTH_74479775210INDUCTOR_SMD_1_IND_WURTH_7447971.0uHL6
IND_WURTH_74479775210INDUCTOR_SMD_1_IND_WURTH_7447971.0uHL7
SM_1008_INDINDUCTOR_SM_1008_IND_4.7UH4.7uHL8
SM_1008_INDINDUCTOR_SM_1008_IND_4.7UH4.7uHL9
402BEAD_FERRITE_SM_0402_BLM15AG221BLM15AG221SN1L10
IND_744301025INDUCTOR,DISCRETE_IND_744301020.25uHL25
IND_744301025INDUCTOR,DISCRETE_IND_744301020.25uHL26
IND_744301025INDUCTOR,DISCRETE_IND_744301020.25uHL27
IND_744301025INDUCTOR,DISCRETE_IND_744301020.25uHL28
SOT23PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NQ1
SOT23PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NQ22
SOT23PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NQ25
SOT23PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NQ26
SOT23PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NQ27
SOT23PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NQ28
SOT23PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NQ29
SOT23PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NQ30
SOT23PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NQ31
SOT23PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NQ32
SOT23PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NQ33
SOT23PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NQ34
PG-TDSON-8FDMC8878_4_PG-TDSON-8_BSC050NE2BSC050NE2LSQ39
PG-TDSON-8FDMC8878_4_PG-TDSON-8_BSC010NE2BSC010NE2LSIQ40
PG-TDSON-8FDMC8878_4_PG-TDSON-8_BSC050NE2BSC050NE2LSQ41
PG-TDSON-8FDMC8878_4_PG-TDSON-8_BSC010NE2BSC010NE2LSIQ42
PG-TDSON-8FDMC8878_4_PG-TDSON-8_BSC050NE2BSC050NE2LSQ43
PG-TDSON-8FDMC8878_4_PG-TDSON-8_BSC010NE2BSC010NE2LSIQ44
PG-TDSON-8FDMC8878_4_PG-TDSON-8_BSC050NE2BSC050NE2LSQ45
PG-TDSON-8FDMC8878_4_PG-TDSON-8_BSC010NE2BSC010NE2LSIQ46
SOT23PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NQ47
EXB8PRPAK4_EXB8P_10K10KRP7
PUSHBUTTON_EVQEVQPAC07K_PUSHBUTTON_EVQ_PBSWITPBswitchS1
PUSHBUTTON_EVQEVQPAC07K_PUSHBUTTON_EVQ_PBSWITPBswitchS2
PUSHBUTTON_EVQEVQPAC07K_PUSHBUTTON_EVQ_PBSWITPBswitchS3
PUSHBUTTON_EVQEVQPAC07K_PUSHBUTTON_EVQ_PBSWITPBswitchS4
PUSHBUTTON_EVQEVQPAC07K_PUSHBUTTON_EVQ_PBSWITPBswitchS5
PUSHBUTTON_EVQEVQPAC07K_PUSHBUTTON_EVQ_PBSWITPBswitchS6
PUSHBUTTON_EVQEVQPAC07K_PUSHBUTTON_EVQ_PBSWITPBswitchS7
PUSHBUTTON_EVQEVQPAC07K_PUSHBUTTON_EVQ_PBSWITPBswitchS8
PUSHBUTTON_EVQEVQPAC07K_PUSHBUTTON_EVQ_PBSWITPBswitchS9
PUSHBUTTON_EVQEVQPAC07K_PUSHBUTTON_EVQ_PBSWITPBswitchS10
PUSHBUTTON_EVQEVQPAC07K_PUSHBUTTON_EVQ_PBSWITPBswitchS11
PUSHBUTTON_EVQEVQPAC07K_PUSHBUTTON_EVQ_PBSWITPBswitchS12
DIPSWITCH12SPST6_DIPSWITCH12_SPST6SPST6S13
DIPSWITCH_SMT_2POSMINI_DIP_2POS_DIPSWITCH_SMT_2POmini_dip_2posS14
SWSPDTSWSLIDE-DPDT_SWSPDT_EG2201AEG2201ASW1
DIPSWITCH_SMT_QUADSPST4_DIPSWITCH_SMT_QUAD_TDA04HTDA04H0SB1SW2
DIPSWITCH_SMT_QUADSPST4_DIPSWITCH_SMT_QUAD_TDA04HTDA04H0SB1SW3
DIPSWITCH_SMT_QUADSPST4_DIPSWITCH_SMT_QUAD_TDA04HTDA04H0SB1SW4
DIPSWITCH_SMT_QUADSPST4_DIPSWITCH_SMT_QUAD_TDA04HTDA04H0SB1SW5
DIPSWITCH_SMT_QUADSPST4_DIPSWITCH_SMT_QUAD_TDA04HTDA04H0SB1SW6
DIPSWITCH_SMT_QUADSPST4_DIPSWITCH_SMT_QUAD_TDA04HTDA04H0SB1SW7
DIPSWITCH_SMT_QUADSPST4_DIPSWITCH_SMT_QUAD_TDA04HTDA04H0SB1SW8
DIPSWITCH_SMT_QUADSPST4_DIPSWITCH_SMT_QUAD_TDA04HTDA04H0SB1SW9
QFN-44LTC3877EUK_QFN-44_LTC3877EUKLTC3877EUKU1
QFN68_EN6360EN6360QI_QFN68_EN6360_EN6360QIEN6360QIU8
QFN76_EN63A0EN63A0QI_QFN76_EN63A0_EN63AOQIEN63AOQIU11
LTM4624_BGALTM4624_LTM4624_BGA_LTM4624LTM4624U12
QFN68_EN6360EN6360QI_QFN68_EN6360_EN6360QIEN6360QIU16
QFN68_EN6360EN6360QI_QFN68_EN6360_EN6360QIEN6360QIU17
QFN68_EN6360EN6360QI_QFN68_EN6360_EN6360QIEN6360QIU18
MSOP12LTC4315_MSOP12_LTC4315LTC4315U22
QSOP16MAX1619_QSOP16_MAX1619MAX1619U23
MSOP12LTC4315_MSOP12_LTC4315LTC4315U24
MSOP12LTC4315_MSOP12_LTC4315LTC4315U25
TSSOP14MAX3378_0_TSSOP14_MAX3378MAX3378U26
SOT-143MAX811_SOT-143_MAX811MAX811U27
F100EPM570F100_F100_EPM570F100EPM570F100U28
DRTTPD2EUSB30_DRT_TPD2EUSB30TPD2EUSB30U29
QFN56CY7C68013A_56QFN_QFN56_CY7C6801CY7C68013A_QFNU30
UCSP-12MAX13042_0_UCSP-12_MAX13042MAX13042U31
F2565M2210ZF256_F256_5M2210ZF2565M2210ZF256U32
F64_10X13PC28F00AP30BF_F64_10X13_PC28F00PC28F00AP30BFU33
F64_10X13PC28F00AP30BF_F64_10X13_PC28F00PC28F00AP30BFU34
BCC9688E1111_BCC96_88E111188E1111U35
TSSOP14MAX3378_0_TSSOP14_LSF0204PWRLSF0204PWRU36
TSSOP14MAX3378_0_TSSOP14_MAX3378MAX3378U38
TSSOP14MAX3378_0_TSSOP14_LSF0204PWRLSF0204PWRU40
TSSOP14MAX3378_0_TSSOP14_LSF0204PWRLSF0204PWRU41
TSSOP14MAX3378_0_TSSOP14_LSF0204PWRLSF0204PWRU42
TSSOP14MAX3378_0_TSSOP14_LSF0204PWRLSF0204PWRU43
TSSOP14MAX3378_0_TSSOP14_LSF0204PWRLSF0204PWRU44
TSSOP14MAX3378_0_TSSOP14_LSF0204PWRLSF0204PWRU45
TSSOP14MAX3378_0_TSSOP14_LSF0204PWRLSF0204PWRU46
TSSOP14MAX3378_0_TSSOP14_LSF0204PWRLSF0204PWRU47
TSSOP14MAX3378_0_TSSOP14_LSF0204PWRLSF0204PWRU48
TSSOP16ICS557-03_TSSOP16_ICS557-03ICS557-03U49
TDFN-10SL18860DC_TDFN-10_SL18860DCSL18860DCU50
F193210AX115F1932C_F1932_(S1+S2+S3+S10AX115F1932CU51
QFN24SI5338A_0_QFN24_SI5338A-CUSTOMSi5338A-CUSTOMU52
QFN_32SI53311_0_QFN_32_SI53311Si53311U53
QFN_32SI53311_0_QFN_32_SI53311Si53311U54
QFN_32SI53311_0_QFN_32_SI53311Si53311U55
QFN_32SI53311_0_QFN_32_SI53311Si53311U56
T-PBGA-24_6X8MMEPCQL_24TBGA_T-PBGA-24_6X8MM_EPEPCQ1024LU58
TSSOP14MAX3378_0_TSSOP14_MAX3378MAX3378U59
TSSOP14MAX3378_0_TSSOP14_MAX3378MAX3378U60
DFM10-EPADLTC3026_DFM10-EPAD_LTC3026LTC3026U61
DQFN1474VCX08BQX_DQFN14_74VCX08BQX74VCX08BQXU64
FDMC8878_VER2FDMC8878_VER2_FDMC8878_VER2_FDMFDMC2514U67
FDMC8878_VER2FDMC8878_VER2_FDMC8878_VER2_FDMFDMC2514U71
DFN8-EPAD_3X2LTC4365_DFN_DFN8-EPAD_3X2_LTC43LTC4365U72
BGA-144_REVERSELTM4620A_BGA-144_REVERSE_LTM462LTM4620AU82
BGA-144_REVERSELTM4620A_BGA-144_REVERSE_LTM462LTM4620AU83
SOIC8ISL6115A_SOIC8_ISL6115AISL6115AU87
FDMC8878_VER2FDMC8878_VER2_FDMC8878_VER2_FDMFDMC2514U88
DFN8-EPAD_3X2LTC4365_DFN_DFN8-EPAD_3X2_LTC43LTC4365U89
QFN-28LTC3874IUFD#PBF_QFN-28_LTC3874ILTC3874IUFD#PBFU95
FDMC8878_VER2FDMC8878_VER2_FDMC8878_VER2_FDMFDMC2514U207
DFN8-EPAD_3X2LTC4365_DFN_DFN8-EPAD_3X2_LTC43LTC4365U208
BGA-144LT2987CY_2_BGA-144_LTM2987CYLTM2987CYU209
FDMC8878_VER2FDMC8878_VER2_FDMC8878_VER2_FDMFDMC2514U210
FDMC8878_VER2FDMC8878_VER2_FDMC8878_VER2_FDMFDMC2514U213
FDMC8878_VER2FDMC8878_VER2_FDMC8878_VER2_FDMFDMC2514U214
FDMC8878_VER2FDMC8878_VER2_FDMC8878_VER2_FDMFDMC2514U215
FDMC8878_VER2FDMC8878_VER2_FDMC8878_VER2_FDMFDMC2514U216
FDMC8878_VER2FDMC8878_VER2_FDMC8878_VER2_FDMFDMC2514U217
FDMC8878_VER2FDMC8878_VER2_FDMC8878_VER2_FDMFDMC2514U218
QFN76_EN63A0EN63A0QI_QFN76_EN63A0_EN63AOQIEN63AOQIU221
QFN76_EN63A0EN63A0QI_QFN76_EN63A0_EN63AOQIEN63AOQIU222
QFN76_EN63A0EN63A0QI_QFN76_EN63A0_EN63AOQIEN63AOQIU223
QFN76_EN63A0EN63A0QI_QFN76_EN63A0_EN63AOQIEN63AOQIU224
QFN64_UPLTC2974_QFN64_UP_LTC2974LTC2974U225
FDMC8878_VER2FDMC8878_VER2_FDMC8878_VER2_FDMFDMC2514U226
FDMC8878_VER2FDMC8878_VER2_FDMC8878_VER2_FDMFDMC2514U227
FDMC8878_VER2FDMC8878_VER2_FDMC8878_VER2_FDMFDMC2514U228
FDMC8878_VER2FDMC8878_VER2_FDMC8878_VER2_FDMFDMC2514U229
DFM10-EPADLTC3026_DFM10-EPAD_LTC3026LTC3026U230
XTAL_XG-1000CBOSC_ALT_1_XTAL_XG-1000CB_100MHZ100MHzX1
XTAL_PACK_DXTAL_XTAL_PACK_D_25MHZ25MHzX2
OSC_SMD_4PIN_25X2CRYSTAL4PIN_OSC_SMD_4PIN_25X2_ABM10-25MHzX3
ECS3525OSC_ALT_0_ECS3525_50MHZ50MHzX4
XTAL_EG2100635L3C3_XTAL_EG2100_125.0MHZ125.0MHzX5
XTAL_FA-128CRYSTAL_SM_13_XTAL_FA-128_24.0024.00MHzY1
XTAL_FA-128CRYSTAL_SM_13_XTAL_FA-128_25.0025.00MHzY2
OSC_SMD_8PIN_7X5OSC_SI570_OSC_SMD_8PIN_7X5_SI57Si570Y3
OSC_SMD_8PIN_7X5OSC_SI570_OSC_SMD_8PIN_7X5_SI57Si570Y4
OSC_SMD_8PIN_7X5OSC_SI570_OSC_SMD_8PIN_7X5_SI57Si570Y5
OSC_SMD_8PIN_7X5OSC_SI570_OSC_SMD_8PIN_7X5_SI57Si570Y6
重要提示:PCB作品文件展下载说明
