查看: 2841|回复: 3
[Allegro16.6以下] Arria_V_GT_FPGA_Development_Kit 开发板 原理图PCB
发表于 2018-12-10 05:38:11 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
03 Arria_V_GT_FPGA_Development_Kit.zip (12.65 MB, 下载次数: 3)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUEREFDES
CAP_PACK_4_1206CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCN1
CAP_PACK_4_1206CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCN2
CAP_PACK_4_1206CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCN3
CAP_PACK_4_1206CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCN4
CAP_PACK_4_1206CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCN5
CAP_PACK_4_1206CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCN6
LUMEX_LED0805LED_LUMEX_LED0805_BLUELEDBLUE LEDD1
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD2
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD3
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD4
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD5
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD6
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD7
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD8
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD9
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD10
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD11
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD12
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD13
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD14
LUMEX_LED0805LED_LUMEX_LED0805_RED_LEDRed_LEDD15
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD16
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD17
LITE-ON_LTST-C195GEKTBILED_0_LITE-ON_LTST-C195GEKT_LLED_GRD18
LITE-ON_LTST-C195GEKTBILED_0_LITE-ON_LTST-C195GEKT_LLED_GRD19
LITE-ON_LTST-C195GEKTBILED_0_LITE-ON_LTST-C195GEKT_LLED_GRD20
LITE-ON_LTST-C195GEKTBILED_0_LITE-ON_LTST-C195GEKT_LLED_GRD21
LITE-ON_LTST-C195GEKTBILED_0_LITE-ON_LTST-C195GEKT_LLED_GRD22
LITE-ON_LTST-C195GEKTBILED_0_LITE-ON_LTST-C195GEKT_LLED_GRD23
LITE-ON_LTST-C195GEKTBILED_0_LITE-ON_LTST-C195GEKT_LLED_GRD24
LITE-ON_LTST-C195GEKTBILED_0_LITE-ON_LTST-C195GEKT_LLED_GRD25
LITE-ON_LTST-C195GEKTBILED_0_LITE-ON_LTST-C195GEKT_LLED_GRD26
LITE-ON_LTST-C195GEKTBILED_0_LITE-ON_LTST-C195GEKT_LLED_GRD27
LITE-ON_LTST-C195GEKTBILED_0_LITE-ON_LTST-C195GEKT_LLED_GRD28
LITE-ON_LTST-C195GEKTBILED_0_LITE-ON_LTST-C195GEKT_LLED_GRD29
LITE-ON_LTST-C195GEKTBILED_0_LITE-ON_LTST-C195GEKT_LLED_GRD30
LITE-ON_LTST-C195GEKTBILED_0_LITE-ON_LTST-C195GEKT_LLED_GRD31
LITE-ON_LTST-C195GEKTBILED_0_LITE-ON_LTST-C195GEKT_LLED_GRD32
LITE-ON_LTST-C195GEKTBILED_0_LITE-ON_LTST-C195GEKT_LLED_GRD33
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD34
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD35
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD36
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD37
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD38
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD39
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD40
SMB403A_03ZENERDIODE_SMB403A_03_20VZENER20V ZenerD41
LUMEX_LED0805LED_LUMEX_LED0805_YELLOWLEDYELLOW LEDD42
LUMEX_LED0805LED_LUMEX_LED0805_YELLOWLEDYELLOW LEDD43
LUMEX_LED0805LED_LUMEX_LED0805_YELLOWLEDYELLOW LEDD44
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD45
SOD323D-SCHOTTKY_0_SOD323_CMDSH-3CMDSH-3D46
SOD323D-SCHOTTKY_0_SOD323_CMDSH-3CMDSH-3D47
SOT23MMBD1205_SOT23_MMBD1205MMBD1205D48
SOD323D-SCHOTTKY_0_SOD323_CMDSH-3CMDSH-3D49
SOD323D-SCHOTTKY_0_SOD323_CMDSH-3CMDSH-3D50
DFN12_EPADLTC4352CDD_DFN12_EPAD_LTC4352CDLTC4352CDDD51
DFN12_EPADLTC4352CDD_DFN12_EPAD_LTC4352CDLTC4352CDDD52
MLX_SHROUD_VRT_HDR_10PIN70247-1051_MLX_SHROUD_VRT_HDR_170246-1004J1
SAMTEC_QSHDP120CUSTOMQSH_HSM_SAMTEC_QSHDP120CUSTOM_AASP-122953-01J2
SAMTEC_QSHDP120CUSTOMQSH_HSM_SAMTEC_QSHDP120CUSTOM_AASP-122953-01J3
MLX_SD-5569_6POS12V_PCIE_ATX_MLX_SD-5569_6POS_112V_PCIE_ATXJ4
1X3_2MMCON3_0_1X3_2MM_TMM-103-01-G-STMM-103-01-G-SJ5
RAPC712CONN JACKPWR_3_RAPC712_CONN JACONN JACK PWRJ6
MOLEX_MINI-AB_USB_THUSB_CON_TH_MOLEX_MINI-AB_USB_THUSB MINI-ABJ7
RJ45HFJ11-1G02E_RJ45_HFJ11-1G02EHFJ11-1G02EJ8
10X40_ASP_VITA5710X40_VITA57_10X40_ASP_VITA57_AASP-134486-01J9
SAMTEC_SFP_MECT20SFP+_AND_CAGE_SAMTEC_SFP_MECT20SFP+_AND_CAGEJ10
SAMTEC_HDR_2X3_2MM_SMTCON6A_SAMTEC_HDR_2X3_2MM_SMT_2X2x3_2mmJ11
SMA_LTI-SASF546-P26-X1SMA_SMA_LTI-SASF546-P26-X1_LTI-LTI-SASF546-P26-X1J12
SMA_LTI-SASF546-P26-X1SMA_SMA_LTI-SASF546-P26-X1_LTI-LTI-SASF546-P26-X1J13
MLX_22_23_2021_VRT_HDR_2PCON2_MLX_22_23_2021_MLX_22_23_222_23_2021J14
SAMTEC_SFP_MECT20SFP+_AND_CAGE_SAMTEC_SFP_MECT_1DNIJ15
SAMTEC_BULLSEYE22SAMTEC_BULLSEYE22_SAMTEC_BULLSEDNIJ16
SMA_LTI-SASF546-P26-X1SMA_LTI_SASF54GT_0_SMA_LTI-SASFLTI-SASF546-P26-X1J17
SMA_LTI-SASF546-P26-X1SMA_LTI_SASF54GT_0_SMA_LTI-SASFLTI-SASF546-P26-X1J18
SMA_LTI-SASF546-P26-X1SMA_SMA_LTI-SASF546-P26-X1_LTI-LTI-SASF546-P26-X1J19
SMA_LTI-SASF546-P26-X1SMA_SMA_LTI-SASF546-P26-X1_LTI-LTI-SASF546-P26-X1J20
SMA_LTI-SASF546-P26-X1SMA_SMA_LTI-SASF546-P26-X1_LTI-LTI-SASF546-P26-X1J21
SMA_LTI-SASF546-P26-X1SMA_SMA_LTI-SASF546-P26-X1_LTI-LTI-SASF546-P26-X1J22
MLX_22_23_2021_VRT_HDR_2PCON2_MLX_22_23_2021_MLX_22_23_222_23_2021J23
SMA_LTI-SASF546-P26-X1SMA_SMA_LTI-SASF546-P26-X1_LTI-LTI-SASF546-P26-X1J24
SMA_LTI-SASF546-P26-X1SMA_SMA_LTI-SASF546-P26-X1_LTI-LTI-SASF546-P26-X1J25
AMPHENOL_SMB_JACK_VERTBNC_VERTICAL_4POST_AMPHENOL_SMBBNCJ26
AMPHENOL_SMB_JACK_VERTBNC_VERTICAL_4POST_AMPHENOL_SMBBNCJ27
1X3_2MMCON3_0_1X3_2MM_TMM-103-01-G-STMM-103-01-G-SJ28
HDR2X7_100MILHDR2X7_HDR2X7_100MIL_HDR2X7HDR2X7J29
PCIX-8PORTPCIE_BRACKET_X8_PCIX-8PORT_PCIEPCIE_SlotJ30
HDR2X5_100MIL_SMT2X5_HDR2X5_100MIL_SMT_DNIDNIJ31
IND_WURTH_7443330068INDUCTOR_IND_WURTH_7443330068_00.68uHL1
IND_WURTH_744777002INDUCTORIRON_0_IND_WURTH_744772.2uHL2
HCM0703INDUCTORIRON_0_HCM0703_0.22UH0.22uHL3
HCM0703INDUCTORIRON_0_HCM0703_0.22UH0.22uHL4
IND_0603BEAD_FERRITE_SM_IND_0603_3A,303A, 30 Ohm FBL5
IND_0603BEAD_FERRITE_SM_IND_0603_3A,303A, 30 Ohm FBL6
603BEAD_FERRITE_SM_0603_120OHM FB120 Ohm FBL7
402BEAD_FERRITE_SM_0402_BLM15AG221BLM15AG221SN1L8
402BEAD_FERRITE_SM_0402_BLM15AG221BLM15AG221SN1L9
IND_0603BEAD_FERRITE_SM_IND_0603_3A,303A, 30 Ohm FBL10
IND_0603BEAD_FERRITE_SM_IND_0603_3A,303A, 30 Ohm FBL11
402BEAD_FERRITE_SM_0402_BLM15AG221BLM15AG221SN1L12
402BEAD_FERRITE_SM_0402_BLM15AG221BLM15AG221SN1L13
IND_COILCRAFT_EPL2014INDUCTOR_IND_COILCRAFT_EPL2014_4.7uHL14
IND_0603BEAD_FERRITE_SM_IND_0603_3A,303A, 30 Ohm FBL15
IND_COILCRAFT_EPL2014INDUCTOR_IND_COILCRAFT_EPL2014_4.7uHL16
402INDUCTOR_0402_5.6NH5.6nHL17
402INDUCTOR_0402_5.6NH5.6nHL18
402INDUCTOR_0402_3.9NH3.9nHL19
IND_COILCRAFT_EPL2014INDUCTOR_IND_COILCRAFT_EPL2014_4.7uHL20
IND_COILCRAFT_EPL2014INDUCTOR_IND_COILCRAFT_EPL2014_4.7uHL21
LFPAK-4RJK0301DPB_LFPAK-4_RJK0301DPBRJK0301DPBQ1
LFPAK-4RJK0301DPB_LFPAK-4_RJK0301DPBRJK0301DPBQ2
SOT23PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NQ3
LFPAK-4RJK0301DPB_LFPAK-4_RJK0301DPBRJK0301DPBQ4
LFPAK-4RJK0301DPB_LFPAK-4_RJK0305DPBRJK0305DPBQ5
LFPAK-4RJK0301DPB_LFPAK-4_RJK0305DPBRJK0305DPBQ6
SO8SI4816BDY_SO8_SI4816BDY-T1SI4816BDY-T1Q7
LFPAK-4RJK0301DPB_LFPAK-4_RJK0305DPBRJK0305DPBQ8
LFPAK-4RJK0301DPB_LFPAK-4_RJK0305DPBRJK0305DPBQ9
POWERPAK_SO8_50MIL_VISHAYPMOS_8LEAD_POWERPAK_SO8_50MIL_VSi7463DPQ10
POWERPAK_SO8_50MIL_VISHAYPMOS_8LEAD_POWERPAK_SO8_50MIL_VSi7463DPQ11
LFPAK-4RJK0301DPB_LFPAK-4_RJK0301DPBRJK0301DPBQ12
LFPAK-4RJK0301DPB_LFPAK-4_RJK0301DPBRJK0301DPBQ13
SC-75PNP_TRANS_SC-75_MMBT3906MMBT3906Q14
SC-75PNP_TRANS_SC-75_MMBT3906MMBT3906Q15
SOT23PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NQ16
RES_PACK_8RES_PACK_0_RES_PACK_8_S1+S2+S3+51RN1
RES_PACK_8RES_PACK_0_RES_PACK_8_S1+S2+S3+51RN2
RES_PACK_8RES_PACK_0_RES_PACK_8_S1+S2+S3+51RN3
RES_PACK_8RES_PACK_0_RES_PACK_8_S1+S2+S_110KRN4
RES_PACK_8RES_PACK_0_RES_PACK_8_S1+S2+S_110KRN5
RES_PACK_8RES_PACK_0_RES_PACK_8_S1+S2+S3+51RN6
RES_PACK_8RES_PACK_0_RES_PACK_8_S1+S2+S3+51RN7
RES_PACK_8RES_PACK_0_RES_PACK_8_S1+S2+S3+51RN8
PUSHBUTTON_SMTTS-A02SA-2-S100_PUSHBUTTON_SMT_PB SwitchS1
PUSHBUTTON_SMTTS-A02SA-2-S100_PUSHBUTTON_SMT_PB SwitchS2
PUSHBUTTON_SMTTS-A02SA-2-S100_PUSHBUTTON_SMT_PB SwitchS3
PUSHBUTTON_SMTTS-A02SA-2-S100_PUSHBUTTON_SMT_PB SwitchS4
PUSHBUTTON_SMTTS-A02SA-2-S100_PUSHBUTTON_SMT_PB SwitchS5
PUSHBUTTON_SMTTS-A02SA-2-S100_PUSHBUTTON_SMT_PB SwitchS6
PUSHBUTTON_SMTTS-A02SA-2-S100_PUSHBUTTON_SMT_PB SwitchS7
PUSHBUTTON_SMTTS-A02SA-2-S100_PUSHBUTTON_SMT_PB SwitchS8
PUSHBUTTON_SMTTS-A02SA-2-S100_PUSHBUTTON_SMT_PB SwitchS9
PUSHBUTTON_SMTTS-A02SA-2-S100_PUSHBUTTON_SMT_PB SwitchS10
PUSHBUTTON_SMTTS-A02SA-2-S100_PUSHBUTTON_SMT_PB SwitchS11
EG2207SW_SLIDE_DPDT_EG2207_SW_SLIDE_DSW_SLIDE_DPDTSW1
DIPSWITCH_SMT_OCTAL76SB08_DIPSWITCH_SMT_OCTAL_TDA0TDA08H0SB1SW2
DIPSWITCH_SMT_OCTAL76SB08_DIPSWITCH_SMT_OCTAL_TDA0TDA08H0SB1SW3
DIPSWITCH_SMT_QUADSPST4_DIPSWITCH_SMT_QUAD_TDA04HTDA04H0SB1SW4
DIPSWITCH_SMT_QUADSPST4_DIPSWITCH_SMT_QUAD_TDA04HTDA04H0SB1SW5
DIPSWITCH_SMT_QUADSPST4_DIPSWITCH_SMT_QUAD_TDA04HTDA04H0SB1SW6
DIPSWITCH_SMT_QUADSPST4_DIPSWITCH_SMT_QUAD_TDA04HTDA04H0SB1SW7
DIPSWITCH_SMT_QUADSPST4_DIPSWITCH_SMT_QUAD_TDA04HTDA04H0SB1SW8
M100EPM570M100_0_M100_S1,S2,S3_EPM5EPM570GM100U1
F324EPM2210F324_F324_EPM2210F324EPM2210F324U2
QFN40LTC3855_QFN40_LTC3855EUJLTC3855EUJU3
F64_10X8PC28FXXXP30B85_1_F64_10X8_PC28FPC28F00AP30BFU4
VFBGA56CY7C68013A_VFBGA_VFBGA56_CY7C68CY7C68013A_VFBGAU5
MICRON_DDR3_96_9X14MT41J128M16HA_MICRON_DDR3_96_9XMT41J128M16HAU6
MICRON_DDR3_78_8X11P5MT41J128M8JP_MICRON_DDR3_78_8X1MT41J128M8JPU7
BB165ACY7C2265KV18_BB165A_DNIDNIU8
QFN40LTC3880_QFN40_LTC3880LTC3880U9
SOT23-DBVPOWER CONTROLLER,LTC4412_SOT23LTC4412U10
MICRON_DDR3_96_9X14MT41J128M16HA_MICRON_DDR3_96_9XMT41J128M16HAU11
MICRON_DDR3_96_9X14MT41J128M16HA_MICRON_DDR3_96_9XMT41J128M16HAU12
F15175AGXB3H4F40_VCCP_VCC_ORG_F1517_5AGXB3H4F40U13
BCC9688E1111_BCC96_88E111188E1111U14
DFN6-2X2_EPADLTC3025-1_0_DFN6-2X2_EPAD_LTC30LTC3025-1U15
F15175AGXB3H4F40_VCCP_VCC_ORG_F1517_5AGXB3H4F40U16
LGA84LTM4618_LGA84_LTM4618LTM4618U17
MICRON_DDR3_96_9X14MT41J128M16HA_MICRON_DDR3_96_9XMT41J128M16HAU18
MICRON_DDR3_96_9X14MT41J128M16HA_MICRON_DDR3_96_9XMT41J128M16HAU19
LGA118LTM4601_LGA118_LTM4601LTM4601U20
MICRON_DDR3_96_9X14MT41J128M16HA_MICRON_DDR3_96_9XMT41J128M16HAU21
MICRON_DDR3_96_9X14MT41J128M16HA_MICRON_DDR3_96_9XMT41J128M16HAU22
LLP16_EPADLMH0384_LLP16_EPAD_LMH0384LMH0384U23
LLP16_EPADLMH0303_LLP16_EPAD_LMH0303LMH0303U24
QFN16NB6L11S_QFN16_NB6L11SMNGNB6L11SMNGU25
LGA144LTM4628_1_LGA144_LTM4628LTM4628U26
LGA144LTM4628_1_LGA144_LTM4628LTM4628U27
MICRON_DDR3_96_9X14MT41J128M16HA_MICRON_DDR3_96_9XMT41J128M16HAU28
SSOP28_NARLTC2418_SSOP28_NAR_LTC2418LTC2418U29
TSSOP14MAX3378_0_TSSOP14_MAX3378MAX3378U30
SSOP28_NARLTC2418_SSOP28_NAR_LTC2418LTC2418U31
DFN16_EPAD_4X3LT3029EDE_DFN16_EPAD_4X3_LT3029LT3029EDEU32
TSSOP14MAX3378_0_TSSOP14_MAX3378MAX3378U33
QFN24SI5338A_0_QFN24_SI5338A-CUSTOMSi5338A-CUSTOMU34
FDMC8878FDMC8878_FDMC8878_FDMC8878FDMC8878U35
MSOP10TS5A23157_MSOP10_TS5A23157TS5A23157U36
MSOP10TS5A23157_MSOP10_TS5A23157TS5A23157U37
MSOP10TS5A23157_MSOP10_TS5A23157TS5A23157U38
DFN6_EPADLTC4357_DFN6_EPAD_LTC4357LTC4357U39
DFN6_EPADLTC4357_DFN6_EPAD_LTC4357LTC4357U40
FDMC8878FDMC8878_FDMC8878_FDMC8878FDMC8878U41
FDMC8878FDMC8878_FDMC8878_FDMC8878FDMC8878U42
DFM10-EPADLTC3026_DFM10-EPAD_LTC3026LTC3026U43
SOT-143MAX811_SOT-143_MAX811MAX811U44
DFN6_EPADLTC4357_DFN6_EPAD_LTC4357LTC4357U45
DRTTPD2EUSB30_DRT_TPD2EUSB30TPD2EUSB30U46
DRC-10_EPADTPS51200_DRC-10_EPAD_TPS51200TPS51200U47
QFN24SI5338A_0_QFN24_SI5338A-CUSTOMSi5338A-CUSTOMU48
FDMC8878FDMC8878_FDMC8878_FDMC8878FDMC8878U49
FDMC8878FDMC8878_FDMC8878_FDMC8878FDMC8878U50
TDFN-10SL18860DC_TDFN-10_SL18860DCSL18860DCU51
QFN24SI5338A_0_QFN24_SI5338A-CUSTOMSi5338A-CUSTOMU52
QFN24SI5338A_0_QFN24_SI5338A-CUSTOMSi5338A-CUSTOMU53
DRC-10_EPADTPS51200_DRC-10_EPAD_TPS51200TPS51200U54
DFN8-EPAD_3X2LTC2915DDB_DFN8-EPAD_3X2_LTC291LTC2915U55
VFQFPN-28_EPADIDT5T9306_0_VFQFPN-28_EPAD_IDT5IDT5T9306U56
WSON8L_EPADN25QXXXA13EF8_WSON8L_EPAD_N25Q2N25Q256AU57
SENSESENSE_PAD_SENSE_SENSE_PADSENSE_PADV1
XTAL_EG2100635L3C3_XTAL_EG2100_125.0MHZ125.0MHzX1
XTAL_SI570SI571_XTAL_SI570_SI571SI571X2
XTAL_XG-1000CBOSC_ALT_1_XTAL_XG-1000CB_100MHZ100MHzX3
XTAL_EG2100635L3C3_XTAL_EG2100_125.0MHZ125.0MHzX4
XTAL_SG310OSC_ALT_XTAL_SG310_25.00MHZ25.00MHzX5
ECS3525OSC_ALT_0_ECS3525_50MHZ50MHzX6
XTAL_SI570SI570_ALT1_XTAL_SI570_SI570SI570X7
XTAL_FA-128CRYSTAL_SM_13_XTAL_FA-128_25.0025.00MHzY1
XTAL_FA-128CRYSTAL_SM_13_XTAL_FA-128_25.0025.00MHzY2
XTAL_FA-128CRYSTAL_SM_13_XTAL_FA-128_24.0024.00MHzY3
XTAL_FA-128CRYSTAL_SM_13_XTAL_FA-128_25.0025.00MHzY4
XTAL_FA-128CRYSTAL_SM_13_XTAL_FA-128_25.0025.00MHzY5
重要提示:PCB作品文件展下载说明
    半小时前
  • 签到天数: 96 天
    发表于 2022-6-23 16:52:01 | 显示全部楼层
  • 签到天数: 10 天
    发表于 2022-6-23 17:54:33 | 显示全部楼层
    郁闷
    昨天 08:30
  • 签到天数: 181 天
    Pads-230522高级班
    发表于 2022-6-24 08:22:14 | 显示全部楼层
