查看: 2587|回复: 6
[Allegro16.6以下] Arria_V_GX_FPGA_Development_Kit 开发板原理图PCB (ArriaV_GX_Starter_re
发表于 2018-12-10 05:41:39 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
Arria_V_GX_FPGA_Development_Kit A5GX_STARTER C 版本 B 35 本坛有PAD格式的 但PADS是有Alleg (7.6 MB, 下载次数: 4)
SYM_NAMECOMP_DEVICE_TYPEREFDES
CAP_PACK_4_1206CAP, ARRAY0.1UF_CAP_PACK_4_1206CN1
CAP_PACK_4_1206CAP, ARRAY0.1UF_CAP_PACK_4_1206CN2
CAP_PACK_4_1206CAP, ARRAY0.1UF_CAP_PACK_4_1206CN3
LUMEX_LED0805GREEN_LED_LUMEX_LED0805D1
LUMEX_LED0805GREEN_LED_LUMEX_LED0805D2
LUMEX_LED0805GREEN_LED_LUMEX_LED0805D3
LUMEX_LED0805GREEN_LED_LUMEX_LED0805D4
LUMEX_LED0805GREEN_LED_LUMEX_LED0805D5
LUMEX_LED0805GREEN_LED_LUMEX_LED0805D6
LUMEX_LED0805GREEN_LED_LUMEX_LED0805D7
LUMEX_LED0805GREEN_LED_LUMEX_LED0805D8
LUMEX_LED0805GREEN_LED_LUMEX_LED0805D9
LUMEX_LED0805RED_LED_LUMEX_LED0805D10
LUMEX_LED0805GREEN_LED_LUMEX_LED0805D11
LUMEX_LED0805GREEN_LED_LUMEX_LED0805D12
LUMEX_LED0805GREEN_LED_LUMEX_LED0805D13
LUMEX_LED0805GREEN_LED_LUMEX_LED0805D14
LUMEX_LED0805GREEN_LED_LUMEX_LED0805D15
LUMEX_LED0805LED, YELLOW 0805LUMEX_LUMEX_LED0805D16
LUMEX_LED0805LED, YELLOW 0805LUMEX_LUMEX_LED0805D17
LUMEX_LED0805LED, YELLOW 0805LUMEX_LUMEX_LED0805D18
LUMEX_LED0805LED, YELLOW 0805LUMEX_LUMEX_LED0805D19
LUMEX_LED0805GREEN_LED_LUMEX_LED0805D20
LUMEX_LED0805GREEN_LED_LUMEX_LED0805D21
LUMEX_LED0805GREEN_LED_LUMEX_LED0805D22
LUMEX_LED0805GREEN_LED_LUMEX_LED0805D23
LUMEX_LED0805GREEN_LED_LUMEX_LED0805D24
LUMEX_LED0805GREEN_LED_LUMEX_LED0805D25
LUMEX_LED0805GREEN_LED_LUMEX_LED0805D26
SOT23DIODE PACK 100V 200MAMMBD1205_SOT23D27
SOD323DIODE, SCHOTTKYCMDSH-3_SOD323D28
SOD323DIODE, SCHOTTKYCMDSH-3_SOD323D29
LUMEX_LED0805LED, BLUE 0805LUMEX_LUMEX_LED0805D30
SOD323DIODE, SCHOTTKYCMDSH-3_SOD323D32
LUMEX_LED0805GREEN_LED_LUMEX_LED0805D33
SOD323DIODE, SCHOTTKYCMDSH-3_SOD323D34
SOD323DIODE, SCHOTTKYCMDSH-3_SOD323D35
PCIX-8PORTPCIE X8 EDGEFINGER_PCIX-8PORTJ1
SMA_LTI-SASF546-P26-X1CONN,SMA_SMA_LTI-SASF546-P26-X1J2
SMA_LTI-SASF546-P26-X1CONN,SMA_SMA_LTI-SASF546-P26-X1J3
SMA_LTI-SASF546-P26-X1CONN,SMA_SMA_LTI-SASF546-P26-X1J4
SMA_LTI-SASF546-P26-X1CONN,SMA_SMA_LTI-SASF546-P26-X1J5
SMA_LTI-SASF546-P26-X1CONN,SMA_SMA_LTI-SASF546-P26-X1J6
SMA_LTI-SASF546-P26-X1CONN,SMA_SMA_LTI-SASF546-P26-X1J7
SMA_LTI-SASF546-P26-X1CONN,SMA_SMA_LTI-SASF546-P26-X1J8
CONN_39_26_7108CONN, 2X5-PIN JTAGHEADER_CONN_39_26_7108J9
HDMI-19PINHDMI 19-PINRECEPTACLE_HDMI-19PINJ10
SMB_RA_JACK_RECEPCONN, MINI SMB, THM,RA_SMB_RA_JACK_RECEPJ11
SMB_RA_JACK_RECEPCONN, MINI SMB, THM,RA_SMB_RA_JACK_RECEPJ12
SAMTEC_QSHDP120CUSTOMCONN,HSMC_MALE_SAMTEC_QSHDP120CUSTOMJ13
USB2_0-RACONN, USB TYPEB_USB2_0-RAJ14
HDR2X5_100MIL_SMTHEADER,2X5-PIN_HDR2X5_100MIL_SMTJ15
HDR2X7_100MILHDR 2X7, VT, THM,TSW-107-07_HDR2X7_100MILJ16
RAPC712CONN, DC JACKRAPC712_RAPC712J17
MLX_22_23_2021_VRT_HDR_2PHDR 1X2, VT, THM,MOLEX, FAN_MLX_22_23_2021_VRT_HDR_2PJ18
RJ45_ACONN RJ45 1-PORT TSEBASE-T_RJ45_AJ19
402IND FERRITE 0402300MA/220_0402L1
402IND 5.6NH 0.76A0402_0402L2
402IND 5.6NH 0.76A0402_0402L3
603IND FERRITE 06032A/120 OHM_0603L4
402IND 5.6NH 0.76A0402_0402L5
IHLP2525IND 3.3UH ISAT=13.5ASMD _IHLP2525L6
IND_WURTH_744311470IND 2.2UH IR=9A 7040SMD _IND_WURTH_744311470L7
IND_0603IND FERRITE 06033A/30 OHMS_IND_0603L9
IND_SUSUMU_PCMC_BTYPEIND 1.2UH IR=6.5ACUBE SMD_IND_SUSUMU_PCMC_BTYPEL10
IND_SUSUMU_PCMC_BTYPEIND 1.2UH IR=6.5ACUBE SMD_IND_SUSUMU_PCMC_BTYPEL11
IND_0805IND FERRITE 08054A/33 OHMS_IND_0805L13
IND_SUSUMU_PCMC_BTYPEIND 1.2UH IR=6.5ACUBE SMD_IND_SUSUMU_PCMC_BTYPEL14
IND_0805IND FERRITE 08054A/33 OHMS_IND_0805L15
HCM0703IND 0.22UH ISAT=40ASMD_HCM0703L16
IND_WURTH_74437349012IND 1.2UH ISAT=18A7050 SMD_IND_WURTH_74437349012L18
FDMC8878MOSFET N-CHANNEL,FDMC8878_FDMC8878Q1
FDMC8878MOSFET N-CHANNEL,FDMC8878_FDMC8878Q2
FDMC8878MOSFET N-CHANNEL,FDMC8878_FDMC8878Q3
SO8MOSFET N-CHANNEL HILOSI4816BDY_SO8Q4
LFPAK-4MOSFET N-CHANNELRJK0305DPB_LFPAK-4Q5
FDMC8878MOSFET N-CHANNEL,FDMC8878_FDMC8878Q6
FDMC8878MOSFET N-CHANNEL,FDMC8878_FDMC8878Q7
SOT23MOSFET, N-CHANNEL,FDV305N_SOT23Q8
LFPAK-4MOSFET N-CHANNELRJK0305DPB_LFPAK-4Q9
LFPAK-4MOSFET N-CHANNELRJK0301DPB_LFPAK-4Q10
SC-75PNP MMBT3906SC-75_SC-75Q11
SC-75PNP MMBT3906SC-75_SC-75Q12
LFPAK-4MOSFET N-CHANNELRJK0305DPB_LFPAK-4Q13
LFPAK-4MOSFET N-CHANNELRJK0301DPB_LFPAK-4Q14
LFPAK-4MOSFET N-CHANNELRJK0301DPB_LFPAK-4Q15
PUSHBUTTON_EVQSWITCH, PUSHBUTTON_PUSHBUTTON_EVQS1
PUSHBUTTON_EVQSWITCH, PUSHBUTTON_PUSHBUTTON_EVQS2
PUSHBUTTON_EVQSWITCH, PUSHBUTTON_PUSHBUTTON_EVQS3
PUSHBUTTON_EVQSWITCH, PUSHBUTTON_PUSHBUTTON_EVQS4
PUSHBUTTON_SMTPUSH_BUTTON_SMD_PUSHBUTTON_SMTS5
PUSHBUTTON_SMTPUSH_BUTTON_SMD_PUSHBUTTON_SMTS6
PUSHBUTTON_SMTPUSH_BUTTON_SMD_PUSHBUTTON_SMTS7
DIPSWITCH_SMT_QUADSWITCH, DIP X4,TDA04H0SB1_DIPSWITCH_SMT_QUADSW1
DIPSWITCH_SMT_QUADSWITCH, DIP X4,TDA04H0SB1_DIPSWITCH_SMT_QUADSW2
DIPSWITCH_SMT_QUADSWITCH, DIP X4,TDA04H0SB1_DIPSWITCH_SMT_QUADSW3
DIPSWITCH_SMT_QUADSWITCH, DIP X4,TDA04H0SB1_DIPSWITCH_SMT_QUADSW4
EG4208ASW, SLIDE-4P2T, RA,EG4208A_EG4208ASW5
FBGA11525AGXFB3H6F35_F1152_FBGA1152_(S1+S2+S3+S4+S5+S6+S7+S8+S9+S10+S11+S12+S13+S14)U1
QFN16CLK BUFFER 1TO2 LVDSNB6L11SMNG_QFN16U3
QFN24CLOCK GEN,SI5338A_CUSTOM, A5SK_QFN24U4
VFQFPN-28_EPADCLOCK BUFFER,IDT5T9306_VFQFPN-28_EPADU5
TDFN-10CLK BUFFER 1TO3LVCMOS SL18860_TDFN-10U6
UCSP-12LEVEL SHIFTER,MAX13042_UCSP-12U7
MSOP10DUAL 10 OHM SPDT,TS5A23157_MSOP10U8
MSOP10DUAL 10 OHM SPDT,TS5A23157_MSOP10U9
DDR3_96_SPECDDR3 SDRAM,MT41J64M16LA-15E_DDR3_96_SPECU10
DDR3_96_SPECDDR3 SDRAM,MT41J64M16LA-15E_DDR3_96_SPECU11
F64_10X8FLASH,PC28F00AP30BF_F64_10X8U12
F64_10X8FLASH,PC28F00AP30BF_F64_10X8U13
F165SRAM,IS61VPS51236A_F165U14
F256MAX V,5M2210ZF256_F256U15
PQFN-48_EPADHDMI LEVEL SHIFTERSTHDLS101T_PQFN-48_EPADU16
UCSP-12LEVEL SHIFTER,MAX13042_UCSP-12U17
LLP16_EPADSDI CABLE DRIVER,LMH0303SQX_LLP16_EPADU18
LLP16_EPADSDI CABLE EQUALIZER,LMH0384SQ_LLP16_EPADU19
BCC96ETHERNET PHY,88E1111_BCC96U20
F100MAX II,EPM570GF100C5N_F100U21
SOT-143RESET, MAX811_SOT-143U22
VFBGA56USB MICROCONTROLLER,CY7C68013A_VFBGA56U23
DRTDIODE, ESDTPD2EUSB30_DRTU24
DFN6_EPADDIODE CONTROLLER,LTC4357_DFN6_EPADU25
DFN6_EPADDIODE CONTROLLER,LTC4357_DFN6_EPADU26
QFN40REG SWITCHING,LTC3855_QFN40U27
DFN6_EPADDIODE CONTROLLER,LTC4357_DFN6_EPADU28
DFN12_EPADDIODE CONTROLLER,LTC4352CDD_DFN12_EPADU29
DFN12_EPADDIODE CONTROLLER,LTC4352CDD_DFN12_EPADU30
QFN28-4X5REG SWITCHING,LTC3633_QFN28-4X5U31
QFN24REG SWITCHING,LTC3605EUF_QFN24U33
DFN6-2X2_EPADREGULATOR,LTC3025-1_DFN6-2X2_EPADU34
DFN6-2X2_EPADREGULATOR,LT3009EDC_DFN6-2X2_EPADU35
DFN6-2X2_EPADREGULATOR,LT3009EDC_DFN6-2X2_EPADU36
DFN6-2X2_EPADREGULATOR,LTC3025-1_DFN6-2X2_EPADU37
PSOP-DGQ10REGULATOR,TPS51100DGQ_PSOP-DGQ10U38
DFN6-2X2_EPADREGULATOR,LTC3025-1_DFN6-2X2_EPADU39
SSOP28_NARADC, LTC241816-CH_SSOP28_NARU40
TSSOP14LEVEL SHIFTER,MAX3378_TSSOP14U41
QFN40REG SWITCHING,LTC3880_QFN40U42
UCSP-12LEVEL SHIFTER,MAX13042_UCSP-12U43
DFN8-EPAD_3X2VOLTAGE SUPERVISORLTC2915_DFN8-EPAD_3X2U44
DFN8-EPAD_3X2VOLTAGE SUPERVISORLTC2915_DFN8-EPAD_3X2U45
STAR_VIATP_18_8_MIL,PTH_STAR_VIAV1
STAR_VIATP_18_8_MIL,PTH_STAR_VIAV2
STAR_VIATP_18_8_MIL,PTH_STAR_VIAV3
XTAL_SI570VCXO, I2CPROGRAMMABLE, SI571_XTAL_SI570X1
SMY3X5_6PXO, 125MHZ LVDS,3.2X5MM, SI511_SMY3X5_6PX2
SMY3X5_4POSC, 100MHZ 2.5V X1CMOS, SI510_SMY3X5_4PX3
SMY3X5_4PXO, 50MHZ CMOS,3.2X5MM, SI510_SMY3X5_4PX4
XTAL_SG310OSC, 25MHZ2.5V_XTAL_SG310X5
XTAL_FA-128XTAL 25MHZ 50PPM 18PFMINI_XTAL_FA-128Y1
XTAL_FA-128OSC, CRYSTAL 24MHZMINI XTL_XTAL_FA-128Y3
重要提示:PCB作品文件展下载说明
    昨天 08:45
  • 签到天数: 96 天
    发表于 2022-6-23 16:52:31 | 显示全部楼层
    无聊
    前天 08:52
  • 签到天数: 185 天
    1元学习Allegro(1期)
    发表于 2022-6-24 08:35:24 | 显示全部楼层
  • 签到天数: 9 天
    发表于 2022-6-24 08:45:08 | 显示全部楼层
    1元学习Allegro(1期)
    发表于 2022-6-24 08:56:35 | 显示全部楼层
  • 签到天数: 4 天
    PADS20220105初级班
    发表于 2022-6-24 08:57:04 | 显示全部楼层
    昨天 08:14
  • 签到天数: 201 天
    终身成就奖特殊贡献奖社区居民忠实会员
    发表于 2022-6-25 08:26:29 | 显示全部楼层
