查看: 2485|回复: 0
[Allegro17.4以下] Cyclone_V_GT_FPGA_Development_Kit Cyclone V GT FPGA 开发套件 原理图PCB
发表于 2018-12-10 05:47:05 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
07 Cyclone_V_GT_FPGA_Development_Kit.zip (7.94 MB, 下载次数: 1)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUEREFDES
KEYSTONE_BT-2994BATTERY_0_KEYSTONE_BT-2994_BATTBatteryBT1
CAP_PACK_4_1206CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCN1
CAP_PACK_4_1206CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCN2
CAP_PACK_4_1206CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCN3
CAP_PACK_4_1206CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCN4
CAP_PACK_4_1206CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCN5
CAP_PACK_4_1206CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCN6
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD1
LUMEX_LED0805LED_LUMEX_LED0805_YELLOWLEDYELLOW LEDD35
SOD323DIODE, SCHOTTKYCMDSH-3_SOD323_CMDSH-3D36
SOD323DIODE, SCHOTTKYCMDSH-3_SOD323_CMDSH-3D37
SOD323D-SCHOTTKY_0_SOD323_CMDSH-3CMDSH-3D38
SOT23MMBD1205_SOT23_MMBD1205MMBD1205D39
SOD323D-SCHOTTKY_0_SOD323_CMDSH-3CMDSH-3D40
SOD323DIODE, SCHOTTKYCMDSH-3_SOD323_CMDSH-3D41
SOD323DIODE, SCHOTTKYCMDSH-3_SOD323_CMDSH-3D42
SOD323DIODE, SCHOTTKYCMDSH-3_SOD323_CMDSH-3D43
LUMEX_LED0805LED_LUMEX_LED0805_YELLOWLEDYELLOW LEDD44
LUMEX_LED0805LED_LUMEX_LED0805_YELLOWLEDYELLOW LEDD45
SAMTEC_QSHDP120CUSTOMQSH_HSM_SAMTEC_QSHDP120CUSTOM_AASP-122953-01J1
SAMTEC_QSHDP120CUSTOMQSH_HSM_SAMTEC_QSHDP120CUSTOM_AASP-122953-01J2
SMA_LTI-SASF546-P26-X1SMA_LTI_SASF54GT_0_SMA_LTI-SASFLTI-SASF546-P26-X1J3
SMA_LTI-SASF546-P26-X1SMA_SMA_LTI-SASF546-P26-X1_LTI-LTI-SASF546-P26-X1J4
MOLEX_MINI-AB_USB_THUSB_CON_TH_MOLEX_MINI-AB_USB_THUSB MINI-ABJ5
SMA_LTI-SASF546-P26-X1SMA_LTI_SASF54GT_0_SMA_LTI-SASFLTI-SASF546-P26-X1J6
SMA_LTI-SASF546-P26-X1SMA_SMA_LTI-SASF546-P26-X1_LTI-LTI-SASF546-P26-X1J7
RAPC712CONN JACKPWR_3_RAPC712_CONN JACONN JACK PWRJ8
RJ45HFJ11-1G02E_RJ45_HFJ11-1G02EHFJ11-1G02EJ9
NEWHAVEN_LCDLCD_HEADER_NEWHAVEN_LCD_LCD_HEALCD_HEADERJ10
SMB_RA_JACK_RECEPCONN, MINI SMB, THM,RA_SMB_RA_Mini SMBJ11
SMB_RA_JACK_RECEPCONN, MINI SMB, THM,RA_SMB_RA_Mini SMBJ12
MLX_SHROUD_VRT_HDR_10PIN70247-1051_MLX_SHROUD_VRT_HDR_170246-1004J13
SMA_LTI-SASF546-P26-X1SMA_SMA_LTI-SASF546-P26-X1_LTI-LTI-SASF546-P26-X1J14
MLX_22_23_2021_VRT_HDR_2PCON2_MLX_22_23_2021_MLX_22_23_222_23_2021J15
PCIX-4PORTPCIE_BRACKET_X4_PCIX-4PORT_PCIEPCIE_SlotJ16
SAMTEC_HDR_2X3_2MM_SMTCON6A_SAMTEC_HDR_2X3_2MM_SMT_DNDNIJ17
HDR2X5_100MIL_SMT2X5_HDR2X5_100MIL_SMT_DNIDNIJ18
IND_SUSUMU_PCMC_BTYPEIND 1.2UH IR=6.5ACUBE SMD_IND_1.2uHL1
IND_SUSUMU_PCMC_BTYPEIND 1.2UH IR=6.5ACUBE SMD_IND_1.2uHL2
IND_WURTH_744325120INDUCTOR_IND_WURTH_744325120_1.1.2uHL3
IND_WURTH_744325120INDUCTOR_IND_WURTH_744325120_1.1.2uHL4
IND_0603BEAD_FERRITE_SM_IND_0603_3A,303A, 30 Ohm FBL5
IND_WURTH_744314047IND 0.47UH IR=18AISAT=20A SMD_0.47uHL6
IND_WURTH_744314047IND 0.47UH IR=18AISAT=20A SMD_0.47uHL7
IND_SUSUMU_PCMC_BTYPEIND 1.2UH IR=6.5ACUBE SMD_IND_1.2uHL8
402INDUCTOR_0402_3.9NH3.9nHL9
603BEAD_FERRITE_SM_0603_120OHM FB120 Ohm FBL10
402INDUCTOR_0402_5.6NH5.6nHL11
402INDUCTOR_0402_5.6NH5.6nHL12
IND_0603BEAD_FERRITE_SM_IND_0603_3A,303A, 30 Ohm FBL13
LFPAK-4RJK0301DPB_LFPAK-4_RJK0305DPBRJK0305DPBQ1
LFPAK-4RJK0301DPB_LFPAK-4_RJK0301DPBRJK0301DPBQ2
LFPAK-4RJK0301DPB_LFPAK-4_RJK0301DPBRJK0301DPBQ3
LFPAK-4RJK0301DPB_LFPAK-4_RJK0305DPBRJK0305DPBQ4
SOT23PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NQ5
RES_PACK_8RES_PACK_0_RES_PACK_8_S1+S2+S3+51RN7
WURTH_6X3P5_TACT_SWITCHTS-A02SA-2-S100_0_WURTH_6X3P5_TPB SwitchS1
WURTH_6X3P5_TACT_SWITCHTS-A02SA-2-S100_0_WURTH_6X3P5_TPB SwitchS2
WURTH_6X3P5_TACT_SWITCHTS-A02SA-2-S100_0_WURTH_6X3P5_TPB SwitchS3
WURTH_6X3P5_TACT_SWITCHTS-A02SA-2-S100_0_WURTH_6X3P5_TPB SwitchS4
WURTH_6X3P5_TACT_SWITCHTS-A02SA-2-S100_0_WURTH_6X3P5_TPB SwitchS5
WURTH_6X3P5_TACT_SWITCHTS-A02SA-2-S100_0_WURTH_6X3P5_TPB SwitchS6
WURTH_6X3P5_TACT_SWITCHTS-A02SA-2-S100_0_WURTH_6X3P5_TPB SwitchS7
DIPSWITCH_SMT_OCTAL76SB08_DIPSWITCH_SMT_OCTAL_TDA0TDA08H0SB1SW1
EG2207SW_SLIDE_DPDT_EG2207_SW_SLIDE_DSW_SLIDE_DPDTSW2
DIPSWITCH_SMT_QUADSPST4_DIPSWITCH_SMT_QUAD_TDA04HTDA04H0SB1SW3
DIPSWITCH_SMT_QUADSPST4_DIPSWITCH_SMT_QUAD_TDA04HTDA04H0SB1SW4
DIPSWITCH_SMT_QUADSPST4_DIPSWITCH_SMT_QUAD_TDA04HTDA04H0SB1SW5
QFN24REG SWITCHING,LTC3605EUF_QFN24LTC3605EUFU1
QFN24REG SWITCHING,LTC3605EUF_QFN24LTC3605EUFU2
VFQFPN-28_EPADIDT5T9306_0_VFQFPN-28_EPAD_IDT5IDT5T9306U3
VFBGA56CY7C68013A_VFBGA_VFBGA56_CY7C68CY7C68013A_VFBGAU4
DRTTPD2EUSB30_DRT_TPD2EUSB30TPD2EUSB30U5
SOT-143MAX811_SOT-143_MAX811MAX811U6
DFN16_EPAD_5X3LT3022EDHC_DFN16_EPAD_5X3_LT302LT3022EDHCU7
MICRON_DDR3_96_9X14MT41J128M16HA_MICRON_DDR3_96_9XMT41K128M16JTU8
FDMC8878_VER2FDMC8878_VER2_FDMC8878_VER2_FDMFDMC8878U9
DFN6-3X2_EPADLTC3085EDCB_DFN6-3X2_EPAD_LT308LT3085EDCBU10
BCC9688E1111_BCC96_88E111188E1111U11
SOT23-8MAX3372EEKA_0_SOT23-8_MAX3373MAX3373U12
F11525CGTFD9E5F35_F1152_5CGTFD9E5F355CGTFD9E5F35U13
FDMC8878_VER2FDMC8878_VER2_FDMC8878_VER2_FDMFDMC8878U14
MICRON_DDR3_96_9X14MT41J128M16HA_MICRON_DDR3_96_9XMT41K128M16JTU15
FDMC8878_VER2FDMC8878_VER2_FDMC8878_VER2_FDMFDMC8878U16
FDMC8878_VER2FDMC8878_VER2_FDMC8878_VER2_FDMFDMC8878U17
DFN16_EPAD_5X3LT3022EDHC_DFN16_EPAD_5X3_LT302LT3022EDHCU18
FDMC8878_VER2FDMC8878_VER2_FDMC8878_VER2_FDMFDMC8878U19
F64_10X8PC28FXXXP30B85_1_F64_10X8_PC28FPC28F00AP30BFU20
QFN52_3EPADREG SWITCHING,LTC3608_QFN52_3ELTC3608U21
MICRON_DDR3_96_9X14MT41J128M16HA_MICRON_DDR3_96_9XMT41K128M16JTU22
M100EPM570M100_0_M100_S1,S2,S3_DNIDNIU23
QFN56_7X9MMLTC3613EWKH_7_QFN56_7X9MM_LTC36LTC3613EWKH_6U24
QFN24REG SWITCHING,LTC3605EUF_QFN24LTC3605EUFU25
MICRON_DDR3_96_9X14MT41J128M16HA_MICRON_DDR3_96_9XMT41K128M16JTU26
MICRON_DDR3_96_9X14MT41J128M16HA_MICRON_DDR3_96_9XMT41K128M16JTU27
MICRON_DDR3_96_9X14MT41J128M16HA_MICRON_DDR3_96_9XMT41K128M16JTU28
QSOP24PIDTQS3861_QSOP24P_IDTQS3861IDTQS3861U29
MICRON_DDR3_96_9X14MT41J128M16HA_MICRON_DDR3_96_9XMT41K128M16JTU30
DQFN14FXL5T244_DQFN14_DNIDNIU31
F2565M2210ZF256_F256_5M2210ZF2565M2210ZF256U32
SO16_WIDEEPCQ256_SO16_WIDE_EPCQ256SI16NEPCQ256SI16NU33
DQFN14FXL5T244_DQFN14_DNIDNIU34
TSSOP14MAX3023_TSSOP14_MAX3023MAX3023U35
MSOP10TS5A23157_MSOP10_TS5A23157TS5A23157U36
MSOP10TS5A23157_MSOP10_TS5A23157TS5A23157U37
SOT23-8MAX3372EEKA_0_SOT23-8_MAX3373MAX3373U38
DFN6-2X2_EPADLTC3025-1_0_DFN6-2X2_EPAD_LTC30LTC3025-1U39
QFN40LTC3855_QFN40_LTC3855EUJLTC3855EUJU40
DFN6_EPADLTC4357_DFN6_EPAD_LTC4357LTC4357U41
DFN6-2X2_EPADLT3009XDC_0_DFN6-2X2_EPAD_LT300LT3009xDCU42
DRC-10_EPADTPS51200_DRC-10_EPAD_TPS51200TPS51200U43
DFN6_EPADLTC4357_DFN6_EPAD_LTC4357LTC4357U44
SSOP28_NARLTC2418_SSOP28_NAR_LTC2418LTC2418U45
DFN6_EPADLTC4357_DFN6_EPAD_LTC4357LTC4357U46
LLP16_EPADLMH0384_LLP16_EPAD_LMH0384LMH0384U47
TSSOP14MAX3378_0_TSSOP14_MAX3378MAX3378U48
TQFP100SQEPM570T100EPM570GT100C3NU49
LLP16_EPADLMH0303_LLP16_EPAD_LMH0303LMH0303U50
SOT-143RESET,MAX811_SOT-143_DNIDNIU51
TDFN-10SL18860DC_TDFN-10_SL18860DCSL18860DCU52
DRC-10_EPADTPS51200_DRC-10_EPAD_TPS51200TPS51200U53
SENSESENSE_PAD_SENSE_SENSE_PADSENSE_PADV1
XTAL_SG310OSC_ALT_XTAL_SG310_25.00MHZ25.00MHzX1
XTAL_XG-1000CBOSC_ALT_1_XTAL_XG-1000CB_100MHZ100MHzX2
XTAL_SI570SI571_XTAL_SI570_SI571SI571X3
XTAL_SI570SI570_ALT1_XTAL_SI570_SI570SI570X4
XTAL_EG2100635L3C3_XTAL_EG2100_125.0MHZ125.0MHzX5
ECS3525OSC_ALT_0_ECS3525_50MHZ50MHzX6
XTAL_FA-128CRYSTAL_SM_13_XTAL_FA-128_24.0024.00MHzY1
重要提示:PCB作品文件展下载说明
