查看: 3129|回复: 3
[Allegro16.6以下] Cyclone_V_GX_FPGA_Development_Kit Cyclone V GX FPGA 开发套件 原理图 PCB
发表于 2018-12-10 05:48:37 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
08 Cyclone_V_GX_FPGA_Development_Kit.zip (8.84 MB, 下载次数: 8)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUEREFDES
KEYSTONE_BT-2994BATTERY_0_KEYSTONE_BT-2994_BATTBatteryBT1
CAP_PACK_4_1206CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCN1
CAP_PACK_4_1206CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCN2
CAP_PACK_4_1206CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCN3
CAP_PACK_4_1206CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCN4
CAP_PACK_4_1206CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCN5
CAP_PACK_4_1206CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCN6
LUMEX_LED0805GREEN_LED_LUMEX_LED0805_GREEN_LGreen_LEDD1
LUMEX_LED0805GREEN_LED_LUMEX_LED0805_GREEN_LGreen_LEDD2
LUMEX_LED0805GREEN_LED_LUMEX_LED0805_GREEN_LGreen_LEDD3
LUMEX_LED0805GREEN_LED_LUMEX_LED0805_GREEN_LGreen_LEDD4
LUMEX_LED0805GREEN_LED_LUMEX_LED0805_GREEN_LGreen_LEDD5
LUMEX_LED0805GREEN_LED_LUMEX_LED0805_GREEN_LGreen_LEDD6
LUMEX_LED0805GREEN_LED_LUMEX_LED0805_GREEN_LGreen_LEDD7
LUMEX_LED0805LED, YELLOW 0805LUMEX_LUMEX_LEYellow_LEDD8
LUMEX_LED0805LED, YELLOW 0805LUMEX_LUMEX_LEYellow_LEDD9
LUMEX_LED0805LED, YELLOW 0805LUMEX_LUMEX_LEYellow_LEDD10
SOD323DIODE, SCHOTTKYCMDSH-3_SOD323_CMDSH-3D11
LUMEX_LED0805GREEN_LED_LUMEX_LED0805_GREEN_LGreen_LEDD12
LUMEX_LED0805GREEN_LED_LUMEX_LED0805_GREEN_LGreen_LEDD13
LUMEX_LED0805GREEN_LED_LUMEX_LED0805_GREEN_LGreen_LEDD14
LUMEX_LED0805GREEN_LED_LUMEX_LED0805_GREEN_LGreen_LEDD15
LUMEX_LED0805RED_LED_LUMEX_LED0805_RED_LEDRED_LEDD16
LUMEX_LED0805GREEN_LED_LUMEX_LED0805_GREEN_LGreen_LEDD17
LUMEX_LED0805GREEN_LED_LUMEX_LED0805_GREEN_LGreen_LEDD18
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD19
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD20
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD21
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD22
LUMEX_LED0805LED, BLUE 0805LUMEX_LUMEX_LED0BLUE LEDD23
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD24
LUMEX_LED0805GREEN_LED_LUMEX_LED0805_GREEN_LGreen_LEDD25
LUMEX_LED0805GREEN_LED_LUMEX_LED0805_GREEN_LGreen_LEDD26
LUMEX_LED0805GREEN_LED_LUMEX_LED0805_GREEN_LGreen_LEDD27
LUMEX_LED0805GREEN_LED_LUMEX_LED0805_GREEN_LGreen_LEDD28
SOD323DIODE, SCHOTTKYCMDSH-3_SOD323_CMDSH-3D29
SOD323DIODE, SCHOTTKYCMDSH-3_SOD323_CMDSH-3D30
SOT23DIODE PACK 100V 200MAMMBD1205_MMBD1205D31
SOD323DIODE, SCHOTTKYCMDSH-3_SOD323_CMDSH-3D32
SOD323DIODE, SCHOTTKYCMDSH-3_SOD323_CMDSH-3D33
SOD323DIODE, SCHOTTKYCMDSH-3_SOD323_CMDSH-3D34
SAMTEC_QSHDP120CUSTOMCONN,HSMC_MALE_SAMTEC_QSHDP120CONN, HSMC_MaleJ1
SMA_LTI-SASF546-P26-X1CONN,SMA_SMA_LTI-SASF546-P26-XSMAJ2
SMA_LTI-SASF546-P26-X1CONN,SMA_SMA_LTI-SASF546-P26-XSMAJ3
SMA_LTI-SASF546-P26-X1CONN,SMA_SMA_LTI-SASF546-P26-XSMAJ4
SMB_RA_JACK_RECEPCONN, MINI SMB, THM,RA_SMB_RA_Mini SMBJ5
SMA_LTI-SASF546-P26-X1CONN,SMA_SMA_LTI-SASF546-P26-XSMAJ6
SMA_LTI-SASF546-P26-X1CONN,SMA_SMA_LTI-SASF546-P26-XSMAJ7
MLX_22_23_2021_VRT_HDR_2PHDR 1X2, VT, THM,MOLEX, FAN_ML22_23_2021J8
RAPC712CONN, DC JACKRAPC712_RAPC712_CCONN JACK PWRJ9
SMB_RA_JACK_RECEPCONN, MINI SMB, THM,RA_SMB_RA_Mini SMBJ10
RJ45HFJ11-1G02E_RJ45_HFJ11-1G02EHFJ11-1G02EJ11
USB2_0-RACONN, USB TYPEB_USB2_0-RA_USBUSB Type BJ12
MLX_SHROUD_VRT_HDR_10PIN70247-1051_MLX_SHROUD_VRT_HDR_170246-1004J13
HDR2X7_100MILHDR 2X7, VT, THM,TSW-107-07_HDHDR 2X7, VT, THM,TSW-107-07J14
HDR2X5_100MIL_SMTHEADER,2X5-PIN_HDR2X5_100MIL_SDNIJ15
SMA_LTI-SASF546-P26-X1CONN,SMA_SMA_LTI-SASF546-P26-XSMAJ16
SMA_LTI-SASF546-P26-X1CONN,SMA_SMA_LTI-SASF546-P26-XSMAJ17
HDR2X7_100MILHDR 2X7, VT, THM,TSW-107-07_HDHDR 2X7, VT, THM,TSW-107-07J18
PCIX-4PORTPCIE_BRACKET_X4_PCIX-4PORT_PCIEPCIE_SlotJ19
HDR2X5_100MIL_SMTHEADER,2X5-PIN_HDR2X5_100MIL_12x5J20
IND_WURTH_744311470IND 2.2UH IR=9A 7040SMD _IND_W6.5uHL1
IND_WURTH_744311470IND 2.2UH IR=9A 7040SMD _IND_12.2uHL2
402IND 5.6NH 0.76A0402_0402_5.6NH5.6nHL3
603IND FERRITE 06032A/120 OHM_060120 ohm FBL4
402IND 5.6NH 0.76A0402_0402_5.6NH5.6nHL5
IND_WURTH_744310055IND 0.52UH ISAT=20ASMD_IND_WUR0.52uHL6
IND_WURTH_744310055IND 0.52UH ISAT=20ASMD_IND_WUR0.52uHL7
IND_0603IND FERRITE 06033A/30 OHMS_IND3A, 30 Ohm FBL8
IND_0805IND FERRITE 08054A/33 OHMS_IND4A, 33 Ohm FBL9
IND_SUSUMU_PCMC_BTYPEIND 1.2UH IR=6.5ACUBE SMD_IND_1.2uHL10
IND_WURTH_744777002IND 2.2UH IR=6A 7345SMD _IND_W2.2uHL11
402IND 5.6NH 0.76A0402_0402_5.6NH5.6nHL12
IND_0603IND FERRITE 06033A/30 OHMS_IND3A, 30 Ohm FBL13
402IND FERRITE 0402300MA/220_0402BLM15AG221SN1L14
SO8MOSFET N-CHANNEL HILOSI4816BDYSI4816BDYQ1
SO8MOSFET N-CHANNEL HILOSI4816BDYSI4816BDYQ2
SOT23MOSFET, N-CHANNEL,FDV305N_SOT2FDV305NQ3
FDMC8878MOSFET N-CHANNEL,FDMC8878_FDMCFDMC8878Q4
SO8MOSFET N-CHANNEL HILOSI4916DY_SI4916DYQ5
SO8MOSFET N-CHANNEL HILOSI4916DY_SI4916DYQ6
FDMC8878MOSFET N-CHANNEL,FDMC8878_FDMCFDMC8878Q7
FDMC8878MOSFET N-CHANNEL,FDMC8878_FDMCFDMC8878Q8
FDMC8878MOSFET N-CHANNEL,FDMC8878_FDMCFDMC8878Q9
FDMC8878MOSFET N-CHANNEL,FDMC8878_FDMCFDMC8878Q10
PUSHBUTTON_SMTTS-A02SA-2-S100_PUSHBUTTON_SMT_PB SwitchS7
EG4208ASW, SLIDE-4P2T, RA,EG4208A_EG4SW SLIDE-4P2TSW1
DIPSWITCH_SMT_QUADSWITCH, DIP X4,TDA04H0SB1_DIPSSwitch, DIP x4,TDA04H0SB1SW2
DIPSWITCH_SMT_QUADSWITCH, DIP X4,TDA04H0SB1_DIPSSwitch, DIP x4,TDA04H0SB1SW3
DIPSWITCH_SMT_QUADSWITCH, DIP X4,TDA04H0SB1_DIPSSwitch, DIP x4,TDA04H0SB1SW4
DIPSWITCH_SMT_QUADSWITCH, DIP X4,TDA04H0SB1_DIPSSwitch, DIP x4,TDA04H0SB1SW5
LLP16_EPADSDI CABLE DRIVER,LMH0303SQX_LLSDI Cable Driver,LMH0303SQxU1
QFN40REG SWITCHING,LTC3855_QFN40_LTLTC3855EUH-1U2
TSSOP14LEVEL SHIFTER,MAX3378_TSSOP14_Level Shifter,MAX3378U3
LLP16_EPADSDI CABLE EQUALIZER,LMH0384SQ_SDI Cable Equalizer,LMH0384SQU4
DFN6_EPADDIODE CONTROLLER,LTC4357_DFN6_LTC4357U5
MICRON_DDR3_96_9X14DDR3 SDRAM,MT41J128M16JT-125D_MT41J128M16JT-125U6
DFN6-2X2_EPADREGULATOR,LT3009EDC_DFN6-2X2_ELT3009xDCU7
DFN6_EPADDIODE CONTROLLER,LTC4357_DFN6_LTC4357U8
DFN6_EPADDIODE CONTROLLER,LTC4357_DFN6_LTC4357U9
BCC9688E1111_BCC96_88E111188E1111U10
F8965CGXFC7150_F896_V1_15_F896_(S1+EP5CGX150C7F896U11
F256MAX V,5M2210ZF256_3_F256_S1+S2MAX V, 5M2210ZF256U12
DFN12_EPADDIODE CONTROLLER,LTC4352CDD_DFLTC4352CDDU13
DFN12_EPADDIODE CONTROLLER,LTC4352CDD_DFLTC4352CDDU14
MICRON_DDR3_96_9X14DDR3 SDRAM,MT41J128M16JT-125D_MT41J128M16JT-125U15
VFBGA56USB MICROCONTROLLER,CY7C68013AUSB Microcontroller,CY7C68013AU16
SSOP28_NARADC, LTC241816-CH_SSOP28_NAR_AADC, LTC2418 16-ChU17
F64_10X8PC28FXXXP30B85_1_F64_10X8_PC28FPC28F512P30BFU18
MICRON_DDR3_78_8X11P5MT41J128M8JP_MICRON_DDR3_78_8X1MT41J128M8JPU19
F100MAX II,EPM570GF100C5N_0_F100_EEPM570GF100U20
MICRON_DDR3_96_9X14TMP_144608_MICRON_DDR3_96_9X14_MT41J128M16JT-125U21
MICRON_DDR3_96_9X14TMP_144412_MICRON_DDR3_96_9X14_MT41J128M16JT-125U22
MICRON_DDR3_78_8X11P5MT41J128M8JP_0_MICRON_DDR3_78_8MT41J128M8JPU23
QFN24REG SWITCHING,LTC3605EUF_QFN24LTC3605EUFU24
QFN24CLOCK GEN,SI5338A_CUSTOM, A5SKSi5338A-CUSTOMU25
QFN20_4X4_05MMREG SWITCHING,LTC3603EUF_QFN20LTC3603EUFU26
UCSP-12LEVEL SHIFTER,MAX13042_UCSP-12Level Shifter,MAX13042U27
DFN6-2X2_EPADREGULATOR,LTC3025-1_DFN6-2X2_ELTC3025-1U28
TSSOP14LEVEL SHIFTER,MAX3378_TSSOP14_Level Shifter,MAX3378U29
DFN6-2X2_EPADREGULATOR,LTC3025-1_DFN6-2X2_ELTC3025-1U30
PSOP-DGQ10REGULATOR,TPS51100DGQ_PSOP-DGQTPS51100DGQU31
QFN40REG SWITCHING,LTC3855_QFN40_LTLTC3855EUH-1U32
SOT-143RESET,MAX811_SOT-143_RESET, MARESET, MAX811U33
DRTDIODE, ESDTPD2EUSB30_DRT_TPD2ETPD2EUSB30U34
TSSOP14LEVEL SHIFTER,MAX3378_TSSOP14_Level Shifter,MAX3378U35
DFN6-2X2_EPADREGULATOR,LT3009EDC_DFN6-2X2_ELT3009xDCU36
TQFP100PSRAM,IS61VPS102418A-250TQL_5_TSRAM,IS61VPS102418A-250TQLU37
VFQFPN-28_EPADCLOCK BUFFER,IDT5T9306_VFQFPN-Clock Buffer,IDT5T9306U38
TDFN-10CLK BUFFER 1TO3LVCMOS SL18860_SL18860DCU39
TSSOP14LEVEL SHIFTER,MAX3378_TSSOP1_1DNIU40
TSSOP14LEVEL SHIFTER,MAX3378_TSSOP1_1DNIU41
TQFP-100ALTERA EPM570T100DNIU42
SOT-143RESET,MAX811_SOT-143_DNIDNIU43
MSOP10DUAL 10 OHM SPDT,TS5A23157_MSOTS5A23157U44
MSOP10DUAL 10 OHM SPDT,TS5A23157_MSOTS5A23157U45
PSOP-DGQ10REGULATOR,TPS51100DGQ_PSOP-DGQTPS51100DGQU46
SENSESENSEPAD_SENSE_SENSE_PADSENSE_PADV1
SENSESENSEPAD_SENSE_SENSE_PADSENSE_PADV2
STAR_VIATP_18_8_MIL,PTH_STAR_VIA_VIA_1VIA_1V3
SENSESENSEPAD_SENSE_SENSE_PADSENSE_PADV4
SENSESENSEPAD_SENSE_SENSE_PADSENSE_PADV5
SENSESENSEPAD_SENSE_SENSE_PADSENSE_PADV6
SENSESENSEPAD_SENSE_SENSE_PADSENSE_PADV7
SENSESENSEPAD_SENSE_SENSE_PADSENSE_PADV8
SENSESENSEPAD_SENSE_SENSE_PADSENSE_PADV9
SENSESENSEPAD_SENSE_SENSE_PADSENSE_PADV10
SENSESENSEPAD_SENSE_SENSE_PADSENSE_PADV11
SENSESENSEPAD_SENSE_SENSE_PADSENSE_PADV12
SENSESENSEPAD_SENSE_SENSE_PADSENSE_PADV13
STAR_VIATP_18_8_MIL,PTH_STAR_VIA_VIA_1VIA_1V14
STAR_VIATP_18_8_MIL,PTH_STAR_VIA_VIA_1VIA_1V15
SENSESENSEPAD_SENSE_SENSE_PADSENSE_PADV16
STAR_VIATP_18_8_MIL,PTH_STAR_VIA_VIA_1VIA_1V17
SENSESENSEPAD_SENSE_SENSE_PADSENSE_PADV18
SENSESENSEPAD_SENSE_SENSE_PADSENSE_PADV19
SENSESENSEPAD_SENSE_SENSE_PADSENSE_PADV20
SENSESENSEPAD_SENSE_SENSE_PADSENSE_PADV21
SENSESENSEPAD_SENSE_SENSE_PADSENSE_PADV22
SENSESENSEPAD_SENSE_SENSE_PADSENSE_PADV23
SENSESENSEPAD_SENSE_SENSE_PADSENSE_PADV24
SMY3X5_4POSC, 100MHZ 2.5V X1CMOS, SI510Si510 - 100MHzX1
XTAL_SI570VCXO, I2CPROGRAMMABLE, SI571_XSi571X2
XTAL_SG310OSC_ALT_XTAL_SG310_25.00MHZ25.00MHzX3
SMY3X5_4PXO, 50MHZ CMOS,3.2X5MM, SI510_Si510 - 50MHzX4
XTAL_FA-128OSC, CRYSTAL 24MHZMINI XTL_XTA24MHzY1
XTAL_FA-128XTAL 25MHZ 30PPM 18PFMINI_XTAL25.00MHzY2
重要提示:PCB作品文件展下载说明
发表于 2018-12-10 10:33:18 | 显示全部楼层
发表于 2019-6-19 22:25:35 | 显示全部楼层
发表于 2019-6-20 10:15:24 | 显示全部楼层
