查看: 2914|回复: 0
[Allegro16.6以下] Cyclone_V_SoC_Development_Kit_and_Intel_SoC_FPGA_Embedded_Development_Suite
发表于 2018-12-10 05:53:01 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
10 REVE Cyclone_V_SoC_Development_Kit_and_Intel_SoC_FPGA_Embedded_Development_Suite.zip (8.42 MB, 下载次数: 1)
Bill of MaterialReport
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUEREFDES
BT1BT1BatteryBT1
CAP_PACK_4_1206CN10.1uFCN1
CAP_PACK_4_1206CN20.1uFCN2
CAP_PACK_4_1206CN30.1uFCN3
CAP_PACK_4_1206CN40.1uFCN4
CAP_PACK_4_1206CN50.1uFCN5
CAP_PACK_4_1206CN60.1uFCN6
LUMEX_LED0805D1Green_LEDD1
LUMEX_LED0805D2Green_LEDD2
LUMEX_LED0805D3Green_LEDD3
LUMEX_LED0805D4Green_LEDD4
LUMEX_LED0805D5Green_LEDD5
LUMEX_LED0805D6Green_LEDD6
LUMEX_LED0805D7Green_LEDD7
LUMEX_LED0805D8Green_LEDD8
LUMEX_LED0805D9Green_LEDD9
TSLP-3-7D10ESD5V3U2UD10
TSLP-3-7D11ESD5V3U2UD11
TSLP-3-7D12ESD5V3U2UD12
SOD323D13CMDSH-3D13
LUMEX_LED0805D14Green_LEDD14
LUMEX_LED0805D15Green_LEDD15
LUMEX_LED0805D17Green_LEDD17
SOD-123D20DFLS230D20
SOD-123D21DFLS230D21
SOD323D24CMDSH-3D24
SOD323D26CMDSH-3D26
SOT23D27MMBD1205D27
LUMEX_LED0805D28Green_LEDD28
LUMEX_LED0805D29Green_LEDD29
LUMEX_LED0805D30Green_LEDD30
LUMEX_LED0805D31Green_LEDD31
SOD-123D3240VD32
LUMEX_LED0805D34Green_LEDD34
LUMEX_LED0805D35BLUE LEDD35
LUMEX_LED0805D36Red_LEDD36
LUMEX_LED0805D37Green_LEDD37
LUMEX_LED0805D38Green_LEDD38
LUMEX_LED0805D39Green_LEDD39
LUMEX_LED0805D40Green_LEDD40
LUMEX_LED0805D41Green_LEDD41
MOLEX_MICRO-AB_USB_SMTJ1USB MICRO-ABJ1
BEL_L829-1J1T-43J2ENET_L829-1J1T-43J2
WURTH_MICRO-SD_CARDJ3MicroSD_sktJ3
SMT38J4Mictor38PJ4
HDR2X1_100MILJ5CON2J5
HDR2X1_100MILJ6CON2J6
HDR2X1_100MILJ7CON2J7
MOLEX_MINI-AB_USB_THJ8USB MINI-BJ8
HDR2X1_100MILJ9CON2J9
SMA_LTI-SASF546-P26-X1J10SMAJ10
SMA_LTI-SASF546-P26-X1J11SMAJ11
SAMTEC_QSHDP120CUSTOMJ12ASP-122953-01J12
HDR2X1_100MILJ13CON2J13
SMB_RA_JACK_RECEPJ14Mini SMBJ14
NEWHAVEN_LCDJ15LCD_HEADERJ15
HDR2X1_100MILJ16CON2J16
SMB_RA_JACK_RECEPJ17Mini SMBJ17
SMA_LTI-SASF546-P26-X1J18SMAJ18
SMA_LTI-SASF546-P26-X1J19SMAJ19
MLX_SDA-5566_4POSJ20ATX-POWER_4PJ20
MLX_22_23_2021_VRT_HDR_2PJ2122_23_2021J21
RAPC712J22CONN JACK PWRJ22
CONN_39_26_7108J2370247-1051J23
2X6HDR-2MMX2MMJ242x6HDRJ24
SAMTEC_PCIE_X4_VERT-64J25PCIE-064-02-F-D-THJ25
CONN_TSW_103_07_L_SJ26HEADER, 1x3-PINJ26
CONN_TSW_103_07_L_SJ27HEADER, 1x3-PINJ27
CONN_TSW_103_07_L_SJ28HEADER, 1x3-PINJ28
CONN_TSW_103_07_L_SJ29HEADER, 1x3-PINJ29
CONN_TSW_103_07_L_SJ30HEADER, 1x3-PINJ30
HDR2X1_100MILJ31CON2J31
WURTH_HDR2X7_2MM_VRTJ32HDR 2X7, VT, THM, 2mmJ32
RJ426J33ENET-7499011121AJ33
RJ426J34ENET-7499011121AJ34
WURTH_DB9_9_MALEJ356.18E+10J35
SMA_LTI-SASF546-P26-X1J36SMAJ36
MOLEX_MINI-AB_USB_THJ37USB MINI-BJ37
HDR2X5_100MIL_SMTJ38DNIJ38
HDR2X1_100MILJ6CON2J39
IND_0603L13A, 30 Ohm FBL1
402L27.43E+08L2
IND_0603L33A, 30 Ohm FBL3
IND_0603L43A, 30 Ohm FBL4
603L5120 ohm FBL5
402L65.6nHL6
402L77.43E+08L7
402L95.6nHL9
IND_0603L103A, 30 Ohm FBL10
402L115.6nHL11
VITECH_59P9875NL141.5uHL14
IND_WURTH_744311470L166.5uHL16
IND_0603L173A, 30 Ohm FBL17
IND_0603L213A, 30 Ohm FBL21
IND_WURTH_74408943100L2210uHL22
VITECH_59P9875NL230.68uHL23
IND_0603L243A, 30 Ohm FBL24
IND_0603L253A, 30 Ohm FBL25
402L267.43E+08L26
402L277.43E+08L27
IND_WURTH_744311470L286.5uHL28
402L297.43E+08L29
SOT23Q1FDV305NQ1
LFPAK-4Q2RJK0301DPBQ2
LFPAK-4Q3RJK0305DPBQ3
LFPAK-4Q4RJK0305DPBQ4
LFPAK-4Q5RJK0301DPBQ5
LFPAK-4Q6RJK0305DPBQ6
FDMC8878_VER2Q7FDMC8878Q7
FDMC8878_VER2Q8FDMC8878Q8
RES_PACK_8RN551RN5
RES_PACK_8RN651RN6
WURTH_6X3P5_TACT_SWITCHS1PB SwitchS1
WURTH_6X3P5_TACT_SWITCHS2PB SwitchS2
WURTH_6X3P5_TACT_SWITCHS3PB SwitchS3
WURTH_6X3P5_TACT_SWITCHS4PB SwitchS4
WURTH_6X3P5_TACT_SWITCHS5PB SwitchS5
WURTH_6X3P5_TACT_SWITCHS6PB SwitchS6
WURTH_6X3P5_TACT_SWITCHS7PB SwitchS7
WURTH_6X3P5_TACT_SWITCHS8PB SwitchS8
WURTH_6X3P5_TACT_SWITCHS9PB SwitchS9
WURTH_6X3P5_TACT_SWITCHS10PB SwitchS10
WURTH_6X3P5_TACT_SWITCHS11PB SwitchS11
WURTH_6X3P5_TACT_SWITCHS12PB SwitchS12
DIPSWITCH_SMT_OCTALSW1TDA08H0SB1SW1
DIPSWITCH_SMT_QUADSW2TDA04H0SB1SW2
DIPSWITCH_SMT_HEXASW3TDA06H0SB1SW3
DIPSWITCH_SMT_QUADSW4TDA04H0SB1SW4
EG4208ASW5SW SLIDE-4P2TSW5
TP_060SQ040TP1TPTP1
TP_060SQ040TP2TPTP2
TP_020RD_SMTTP3DNITP3
TP_020RD_SMTTP4DNITP4
TP_020RD_SMTTP5DNITP5
TP_020RD_SMTTP6DNITP6
TP_060SQ040TP7TPTP7
TP_060SQ040TP8TPTP8
TEST_PAD_SMTTP13T POINT RTP13
TEST_PAD_SMTTP14T POINT RTP14
TEST_PAD_SMTTP15T POINT RTP15
TEST_PAD_SMTTP16T POINT RTP16
TEST_PAD_SMTTP17T POINT RTP17
TEST_PAD_SMTTP18T POINT RTP18
TEST_PAD_SMTTP19T POINT RTP19
TEST_PAD_SMTTP20T POINT RTP20
TEST_PAD_SMTTP21T POINT RTP21
TEST_PAD_SMTTP22T POINT RTP22
TEST_PAD_SMTTP23T POINT RTP23
TEST_PAD_SMTTP24T POINT RTP24
TEST_PAD_SMTTP25T POINT RTP25
TEST_PAD_SMTTP26T POINT RTP26
TEST_PAD_SMTTP27T POINT RTP27
TEST_PAD_SMTTP28T POINT RTP28
TEST_PAD_SMTTP29T POINT RTP29
TEST_PAD_SMTTP30T POINT RTP30
TEST_PAD_SMTTP31T POINT RTP31
TEST_PAD_SMTTP32T POINT RTP32
TEST_PAD_SMTTP33T POINT RTP33
8-TDFN-EPU1MAX14523AATA+TU1
QFN32U2USB3300U2
SO16_WIDEU3DS1339CU3
SOT23-5U4LT1761U4
SO16_WIDEU5N25Q512A83GSF40FU5
F64_10X8U6PC28F512P30BFU6
MSOP10U7TS5A23157U7
MSOP10U8TS5A23157U8
MSOP10U9TS5A23157U9
MSOP10U10TS5A23157U10
QFN48U11KSZ9031RNXU11
SON6U12TPD4S012DRYRU12
QSOP24PU13IDTQS3861U13
MICRON_DDR3_96_9X14U14MT41K256M16HA-125:EU14
TSSOP16U15IDTQS3VH257U15
TSSOP16U16IDTQS3VH257U16
QFN32-FTDIU17FT232RU17
DFM10-EPADU18LTC3026U18
F256U195M2210ZF256U19
SO16_WIDEU20EPCQ256U20
F8965CSXFC6D_F896_14_F896_(S1+S2+S35CSXFC6D_F896U21
MICRON_DDR3_96_9X14U22MT41K256M16HA-125:EU22
TDFN-10U23SL18860DCU23
SOT23-8U24MAX3373U24
LLP16_EPADU25SDI Cable Driver,LMH0303SQxU25
QFN-64_9MMX9MMU26LTC2978U26
SO8U2824LC32AU28
QFN24U29Si5338A-CUSTOMU29
MICRON_DDR3_96_9X14U30MT41K256M16HA-125:EU30
LLP16_EPADU31SDI Cable Equalizer,LMH0384SQU31
QFN-64_9MMX9MMU34LTC2978U34
QFN24U35Si5335U35
DFN14_EPADU36LT3509EDEU36
MICRON_DDR3_96_9X14U37MT41K256M16HA-125:EU37
MICRON_DDR3_96_9X14U38MT41K256M16HA-125:EU38
FDMC8878_VER2U41FDMC8878U41
QFN40U43LTC3855EUJU43
FDMC8878_VER2U44FDMC8878U44
LQFP-80_12X12U45uPD60620AU45
F100U47EPM570GF100U47
SOT-143U48MAX811U48
TDFN10U49Si52112U49
SO8U50SN65HVD230U50
VFBGA56U51CY7C68013A_VFBGAU51
TSSOP16U52ICS83054AGI-01U52
DRTU53TPD2EUSB30U53
TSSOP16U54IDTQS3VH257U54
SOT-143U55MAX811U55
SOT-143U56MAX811U56
MSOP10U57TS5A23157U57
DRC-10_EPADU58TPS51200U58
DFN6_EPADU59LTC4357U59
DFN6_EPADU60LTC4357U60
DRC-10_EPADU61TPS51200U61
DFN6_EPADU62LTC4357U62
DFN6_EPADU63LTC4357U63
QFN-68U66EN2342QIU66
QFN-68U66EN2342QIU67
QFN-68U66EN2342QIU68
QFN-68U66EN2342QIU69
QFN-68U66EN2342QIU70
QFN-68U66EN2342QIU71
QFN-92U72EN23F2QIU72
AD8638ARJZ_SOT235U73DNIU73
LM431S_SOT23U74DNIU74
TS391ILT_SOT23U75DNIU75
16-LEAD_PLASTIC_SSOPLTC4218CGN_16-LEAD_PLASTIC_SSOPLTC4218CGNU76
FDMC8878_VER2U44FDMC8878U77
16-LEAD_PLASTIC_DFNLTC4218CDHC-12_16-LEAD_PLASTIC_LTC4218CDHC-12U78
FDMC8878_VER2U44FDMC8878U79
8-LEAD_PLASTIC_SOLTC1157CS8_8-LEAD_PLASTIC_SO_LTLTC1157CS8U80
FDMC8878_VER2U44FDMC8878U81
STAR_VIAV1VIA_1V1
SENSEV2SENSE_PADV2
SENSEV3SENSE_PADV3
SENSEV6SENSE_PADV6
SENSEV7SENSE_PADV7
SENSEV8SENSE_PADV8
SENSEV9SENSE_PADV9
STAR_VIAV10VIA_1V10
STAR_VIAV11VIA_1V11
STAR_VIAV12VIA_1V12
SENSEV13SENSE_PADV13
SENSEV14SENSE_PADV14
STAR_VIAV15VIA_1V15
STAR_VIAV16VIA_1V16
STAR_VIAV17VIA_1V17
STAR_VIAV18VIA_1V18
STAR_VIAV19VIA_1V19
STAR_VIAV20VIA_1V20
SENSEV21SENSE_PADV21
SENSEV22SENSE_PADV22
STAR_VIAV23VIA_1V23
STAR_VIAV24VIA_1V24
STAR_VIAV25VIA_1V25
STAR_VIAV26VIA_1V26
STAR_VIAV27VIA_1V27
STAR_VIAV28VIA_1V28
STAR_VIAV29VIA_1V29
STAR_VIAV30VIA_1V30
STAR_VIAV31VIA_1V31
STAR_VIAV32VIA_1V32
STAR_VIAV33VIA_1V33
STAR_VIAV34VIA_1V34
STAR_VIAV35VIA_1V35
STAR_VIAV36VIA_1V36
STAR_VIAV37VIA_1V37
STAR_VIAV38VIA_1V38
STAR_VIAV39VIA_1V39
SENSEV40SENSE_PADV40
SENSEV41SENSE_PADV41
STAR_VIAV42VIA_1V42
STAR_VIAV43VIA_1V43
SENSEV44SENSE_PADV44
SENSEV45SENSE_PADV45
SENSEV46SENSE_PADV46
SENSEV47SENSE_PADV47
SENSEV48SENSE_PADV48
SENSEV49SENSE_PADV49
SENSEV50SENSE_PADV50
SENSEV48SENSE_PADV51
SENSEV48SENSE_PADV52
SENSEV48SENSE_PADV53
SENSEV48SENSE_PADV54
SENSEV48SENSE_PADV55
SENSEV48SENSE_PADV56
XTAL_SI570X1SI570X1
XTAL_ECX-32X224MHzX2
XTAL_SI570X3Si571X3
ECS3525X450MHzX4
XTAL_EG2100X5125.0MHzX5
XTAL_FA-128Y125.00MHzY1
XTAL_FA-128Y225.00MHzY2
XTAL_FA-128Y325.00MHzY3
XTAL_FA-128Y425.00MHzY4
XTAL_FA-128Y524.00MHzY5
重要提示:PCB作品文件展下载说明
