查看: 1597|回复: 0
[Allegro16.6以下] Intel_FPGA_Embedded_Systems_Development_Kit,_Cyclone_III_Edition 开发板原
发表于 2018-12-10 06:05:22 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
18 REVD Intel_FPGA_Embedded_Systems_Development_Kit,_Cyclone_III_Edition.zip (8.38 MB, 下载次数: 0)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUEREFDES
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD1
SMB403A_03ZENERDIODE_SMB403A_03_20VZENER20V ZenerD2
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD3
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD4
LUMEX_LED1206LED_LUMEX_LED1206_BLUE_LEDBlue_LedD5
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD6
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD7
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD8
SMCZC2800E/SOT_SMC_B520C-13B520C-13D9
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD10
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD11
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD12
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD13
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD14
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD15
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD16
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD17
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD18
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD19
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD20
LUMEX_LED1206LED_LUMEX_LED1206_RED_LEDRed_LEDD21
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD22
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD23
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD24
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD25
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD26
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD27
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD28
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD29
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD30
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD31
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD32
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD33
DO-214AB_RECTRONDIODE_DO-214AB_RECTRON_FM540FM540D34
SOD-123ZENERDIODE_SOD-123_40VSCHOTTKY40V SchottkyD35
RJ45HFJ11-1G02E_RJ45_HFJ11-1G02EHFJ11-1G02EJ1
RAPC712CONN_JACK_PWR_RAPC712_RAPC712XRAPC712XJ2
USB2_0-RAUSB_CON_USB2_0-RA_USBCONUSB CONJ3
HDR2X7_100MILHDR2X7_HDR2X7_100MIL_HDR2X7HDR2X7J4
HDR4X1_100MIL1X4_HDR4X1_100MIL_HDR4X1HDR4X1J5
HDR2X1_100MILCON2_HDR2X1_100MIL_CON2CON2J6
HDR2X1_100MILCON2_HDR2X1_100MIL_CON2CON2J7
SAMTEC_QSHDP120CUSTOMQSH_HSM_SAMTEC_QSHDP120CUSTOM_AASP-122953-01J8
SAMTEC_QSHDP120CUSTOMQSH_HSM_SAMTEC_QSHDP120CUSTOM_AASP-122953-01J9
SMA_LTI-SASF546-P26-X1SMA_SMA_LTI-SASF546-P26-X1_LTI-LTI-SASF546-P26-X1J10
SMA_LTI-SASF546-P26-X1SMA_SMA_LTI-SASF546-P26-X1_LTI-LTI-SASF546-P26-X1J11
HDR2X1_2MM1X2_HDR2X1_2MM_HDR2X1HDR2X1J12
FH12X_30S_0P5SHFPC_FFC_30PIN_FH12X_30S_0P5SH_FFPC_FFC_30PINJ13
CONN_39_26_710870247-1051_CONN_39_26_7108_702470247-1051J14
FH12X_18S_0P5SHFPC_FFC_18PIN_FH12X_18S_0P5SH_DDNIJ15
IND_0805BEAD_FERRITE_SM_IND_0805_BLM21PBLM21PG331SN1L1
IHLP2525INDUCTOR_IHLP2525_0.2UH0.2uHL2
IHLP2525INDUCTOR_IHLP2525_10UH10uHL3
402BEAD_FERRITE_SM_0402_BLM15AG221BLM15AG221SN1L4
402BEAD_FERRITE_SM_0402_BLM15AG221BLM15AG221SN1L5
IHLP2525INDUCTOR_IHLP2525_0.2UH0.2uHL6
402BEAD_FERRITE_SM_0402_BLM15AG221BLM15AG221SN1L7
LQH1210INDUCTOR_LQH1210_10UH10uHL8
LQH1210INDUCTOR_LQH1210_10UH10uHL9
RES_PACK_8RES_PACK_8_RES_PACK_8_5656RN21
PUSHBUTTON_EVQEVQPAC07K_PUSHBUTTON_EVQ_PBSWITPBSwitchS1
PUSHBUTTON_EVQEVQPAC07K_PUSHBUTTON_EVQ_PBSWITPBSwitchS2
PUSHBUTTON_EVQEVQPAC07K_PUSHBUTTON_EVQ_PBSWITPBSwitchS3
PUSHBUTTON_EVQEVQPAC07K_PUSHBUTTON_EVQ_PBSWITPBSwitchS4
PUSHBUTTON_EVQEVQPAC07K_PUSHBUTTON_EVQ_PBSWITPBSwitchS5
PUSHBUTTON_EVQEVQPAC07K_PUSHBUTTON_EVQ_PBSWITPBSwitchS6
PUSHBUTTON_EVQEVQPAC07K_PUSHBUTTON_EVQ_PBSWITPBSwitchS7
DIPSWITCH16SPST8_DIPSWITCH16_DIP_SW_8DIP_SW_8SW1
EG2201ASWSLIDE-DPDT_EG2201A_EG2201AEG2201ASW2
DIPSWITCH_SMT_QUADSPST4_DIPSWITCH_SMT_QUAD_TDA04HTDA04H0SB1SW3
SW_ROTARY_94HSW_ROTARY_SW_ROTARY_94H_94HCB1694HCB16WTSW4
SW_ROTARY_94HSW_ROTARY_SW_ROTARY_94H_94HCB1694HCB16WTSW5
DIPSWITCH16SPST8_DIPSWITCH16_DIP_SW_8DIP_SW_8SW6
TP_060SQ040T_POINT_R_TP_060SQ040_54101-G0554101-G05-01LFTP1
TP_060SQ040T_POINT_R_TP_060SQ040_54101-G0554101-G05-01LFTP2
TP_060SQ040T_POINT_R_TP_060SQ040_54101-G0554101-G05-01LFTP3
TP_060SQ040T_POINT_R_TP_060SQ040_54101-G0554101-G05-01LFTP4
TP_060SQ040T_POINT_R_TP_060SQ040_54101-G0554101-G05-01LFTP5
TP_060SQ040T_POINT_R_TP_060SQ040_54101-G0554101-G05-01LFTP6
LGA118LTM4601_LGA118_LTM4601LTM4601U1
QFN38LTC3418_QFN38_LTC3418LTC3418U2
SSOP16NTS3A5018_SSOP16N_TS3A5018TS3A5018U3
SSOP16NTS3A5018_SSOP16N_DNIDNIU4
BCC9688E1111_BCC96_88E111188E1111U5
PSOP-DGQ10TPS51100_PSOP-DGQ10_TPS51100DGQTPS51100DGQU6
F256EPM2210GF256_F256_(S1+S2),(S3+SEPM2210_F256FBGAU7
LQFP-32FT245BL_LQFP-32_FT245BLFT245BLU8
QFN56CY7C680_56QFN_QFN56_CY7C68013A-CY7C68013A-56LFXCU9
DFM10-EPADLT3481_DFM10-EPAD_LT3481LT3481U10
MICRON_DDR2_84_12X12P5MT47H32M16CC_MICRON_DDR2_84_12XMT47H32M16CCU11
MICRON_DDR2_84_12X12P5MT47H32M16CC_MICRON_DDR2_84_12XMT47H32M16CCU12
DDR2_60_SPECMT47H32M8BP_DDR2_60_SPEC_MT47H3MT47H32M8BPU13
SOT23-5LT1761_SOT23-5_LT1761LT1761U14
SO824XX128_SO8_QUSB2CP1QUSB2CP1U15
MSOP8LM4990MM_MSOP8_LM4990LM4990U16
SO8AT93C46-10_SO8_AT93C46DN-SH-BAT93C46DN-SH-BU17
SOT23-DBVSN65220DBV_SOT23-DBV_SN65220DBVSN65220DBVU18
SC70-5FXLP34_SC70-5_FXLP34FXLP34U19
F780EP3C780_F780_(S1+S2+S3+S4+S5+S6EP3C120F780U20
SO8LT1963_SO8_LT1963ALT1963AU21
SC70-5FXLP34_SC70-5_FXLP34FXLP34U22
F54K1B3216B2E_F54_K1B3216B2EK1B3216B2EU23
F54K1B3216B2E_F54_K1B3216B2EK1B3216B2EU24
MICRON_DDR2_84_12X12P5MT47H32M16CC_MICRON_DDR2_84_12XMT47H32M16CCU25
MICRON_DDR2_84_12X12P5MT47H32M16CC_MICRON_DDR2_84_12XMT47H32M16CCU26
PSOP-DGQ10TPS51100_PSOP-DGQ10_TPS51100DGQTPS51100DGQU27
QUAD_7SEGQUAD_7_SEG_DSPLY_7_QUAD_7SEG_QUQUAD_7SEG_M2212RIU28
QFN38LTC3418_QFN38_LTC3418LTC3418U29
QUAD_7SEGQUAD_7_SEG_DSPLY_7_QUAD_7SEG_QUQUAD_7SEG_M2212RIU30
F64S29GLXXXN_BGA_F64_S29GL512NS29GL512NU31
MSOP10LTC2402_MSOP10_LTC2402LTC2402U32
SO8LT1963_SO8_LT1963ALT1963AU33
SOT23-5LT1761_SOT23-5_LT1761LT1761U34
LQFP-48ADG726_0_LQFP-48_ADG725ADG725U35
SO8TPS271_SO8_DNIDNIU36
SOT23-5AD8531_SOT23-5_AD8531AD8531U37
SOT23-5LT1931_SOT23-5_LT1931LT1931U38
XTAL_PACK_DXTAL_XTAL_PACK_D_25MHZ25MHzX1
XTAL_HC49CRYSTAL_XTAL_HC49_24.000MHZ24.000 MHZY1
XTAL_HC49CRYSTAL_XTAL_HC49_6.000MHZ6.000 MHZY2
SM55-OSCOSC_ALT_SM55-OSC_24MHZ24MHzY3
SM55-OSCOSC_ALT_SM55-OSC_125MHZ125MHzY4
SM55-OSCOSC_ALT_SM55-OSC_50MHZ50MHzY5
重要提示:PCB作品文件展下载说明
