查看: 3280|回复: 10
[Allegro16.6以下] MAX_V_CPLD_Development_Kit 开发板原理图PCB
发表于 2018-12-10 06:12:35 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
23 MAX_V_CPLD_Development_Kit.zip (1.78 MB, 下载次数: 7)
Bill of MaterialReport
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_TOLCOMP_CLASSREFDES
TP_060SQ040TP_60_40_MIL_TP_060SQ040_TP_60_TP_60_40_mil ICBATT+
TP_060SQ040TP_60_40_MIL_TP_060SQ040_TP_60_TP_60_40_mil ICBATT-
402CAP_0402_0.1UF DNI0.1uF DNI ICC1
402CAP 1UF +/-10% 10V0402_0402__11uF DNI ICC2
402CAP_0402_0.1UF0.1uF ICC3
402CAP_0402_0.1UF0.1uF ICC4
402CAP_0402_0.1UF0.1uF ICC5
1210CAP_1210_10UF10uF ICC6
402CAP_0402_0.1UF0.1uF ICC7
402CAP_0402_0.1UF0.1uF ICC8
1210CAP_1210_10UF10uF ICC9
402CAP 1UF +/-10% 10V0402_0402_1U1uF ICC10
1210CAP_1210_10UF10uF ICC11
402CAP 1UF +/-10% 10V0402_0402_1U1uF ICC12
1210CAP_1210_10UF10uF ICC13
402CAP_0402_18PF18pF ICC14
402CAP_0402_18PF18pF ICC15
402CAP 1UF +/-10% 10V0402_0402__11uF DNI ICC16
402CAP_0402_0.1UF0.1uF ICC17
402CAP 1UF +/-10% 10V0402_0402_1U1uF ICC18
402CAP_0402_0.1UF0.1uF ICC19
402CAP 1UF +/-10% 10V0402_0402_1U1uF ICC20
402CAP_0402_0.01UF DNI0.01uF DNI ICC21
402CAP_0402_0.1UF0.1uF ICC22
1210CAP_1210_10UF10uF ICC23
402CAP_0402_0.1UF0.1uF ICC24
402CAP_0402_0.1UF0.1uF ICC25
402CAP 1UF +/-10% 10V0402_0402_1U1uF ICC26
402CAP 1UF +/-10% 10V0402_0402_1U1uF ICC27
1210CAP_1210_10UF DNI10uF DNI ICC28
1210CAP_1210_10UF10uF ICC29
402CAP_0402_0.1UF DNI0.1uF DNI ICC30
402CAP_0402_0.1UF0.1uF ICC31
1210CAP_1210_10UF10uF ICC32
402CAP 1UF +/-10% 10V0402_0402_1U1uF ICC33
1210CAP_1210_10UF10uF ICC34
402CAP 10PF +/-0.5PF 50V0402_040210pF ICC35
1210CAP_1210_10UF DNI10uF DNI ICC36
402CAP_0402_0.1UF0.1uF ICC37
402CAP 1UF +/-10% 10V0402_0402_1U1uF ICC38
402CAP_0402_0.1UF0.1uF ICC39
1210CAP_1210_10UF10uF ICC40
402CAP_0402_0.1UF DNI0.1uF DNI ICC41
402CAP_0402_0.1UF DNI0.1uF DNI ICC42
CAP_PBCAP_PB_MAXV_DK_CAP_PB_<><> ICCPB1
LED-0805LED_2_LED-0805_LEDBLUELED BLUE ICD1
SOT23BAT54S-SOT23_0_SOT23_BAT54SBAT54S ICD2
LUMEX_LED0805GREEN_LED_LUMEX_LED0805_GREEN_LGreen_LED ICD3
SMC403MBRS340_SMC403_MBRS340MBRS340 ICD4
SMC403MBRS340_SMC403_MBRS340MBRS340 ICD5
SOT23BAT54S-SOT23_0_SOT23_BAT54SBAT54S ICD6
LUMEX_LED0805GREEN_LED_LUMEX_LED0805_GREEN_LGreen_LED ICD7
LUMEX_LED0805GREEN_LED_LUMEX_LED0805_GREEN_LGreen_LED ICD8
SOT23BAT54S-SOT23_0_SOT23_BAT54SBAT54S ICD9
SKT_DIP8_4POSC SOCKET- 4PIN_0_SKT_DIP8_4POSC SOCKET- 4 PIN ICJ1
TP_060SQ040T_POINT_TP_060SQ040_T_POINTT_POINT ICJ2
TP_060SQ040T_POINT_TP_060SQ040_T_POINTT_POINT ICJ3
USB2_0-RAUSB TYPE-BRECEPTACLE_USB2_0-RAUSB TYPE-B ICJ4
HDR2X3_100MIL_SMT2X3-PINHEADER_HDR2X3_100MIL_SM2x3-PIN HEADER ICJ5
MLX_SHROUD_VRT_HDR_2X20_100MIL2X40-PINHEADER_MLX_SHROUD_VRT_2x40-PIN HEADER ICJ6
MLX_SHROUD_VRT_HDR_2X20_100MIL2X40-PINHEADER_MLX_SHROUD_VRT_2x40-PIN HEADER ICJ7
HDR2X5_100MIL_SMT2X5-PINHEADER_HDR2X5_100MIL_SM2X5 ICJ8
HDR4X1_100MIL1X4-PINHEADER_HDR4X1_100MIL_1X1x4-PIN HEADER ICJ9
HDR2X3_100MIL_SMT2X3-PINHEADER_HDR2X3_100MIL_SM2x3-PIN HEADER ICJ10
TP_060SQ040T_POINT_TP_060SQ040_T_POINTT_POINT ICJ11
TP_060SQ040T_POINT_TP_060SQ040_T_POINTT_POINT ICJ12
3M_SHROUD_2X5_100MIL_SMTHDR 2X5, VERTICAL,SMD_3M_SHROUHDR 2X5, VERTICAL,SMD, DNI ICJ13
HDR2X5_100MIL_SMT2X5_HDR2X5_100MIL_SMT_DNIDNI ICJ14
IND_0805BEAD_FERRITE_SM_IND_0805_BLM21PBLM21PG331SN1 ICL1
IND_0805BEAD_FERRITE_SM_IND_0805_BLM21PBLM21PG331SN1 ICL2
IND_COILCRAFT_EPL2014INDUCTOR_IND_COILCRAFT_EPL2014_4.7uH ICL3
402RESISTOR_0402_1.00K1.00K ICR1
402RESISTOR_0402_1.00K1.00K ICR2
402RES 1.00K OHM 1.0%1/16W 0402_01K ICR3
402RES 4.7K OHM 1.0%1/16W 0402_044.7K ICR4
402RES 4.7K OHM 1.0%1/16W 0402_044.7K ICR5
402RES 100 OHM 1% 1/16W0402_0402_100 ICR6
402RES 22 OHM 5% 1/16W0402_0402_222 ICR7
402RES 0 OHM 5% 1/16W0402 SMD_0400 ICR8
402RES 178 OHM 1% 1/16W0402_0402_170 DNI ICR9
402RES 4.7K OHM 1.0%1/16W 0402_044.7K ICR10
402RES 0 OHM 5% 1/16W0402 SMD_0400 ICR11
402RESISTOR_0402_2727 ICR12
402RESISTOR_0402_1.5K1.5K ICR13
402RES 4.7K OHM 1.0%1/16W 0402_044.7K ICR14
402RESISTOR_0402_2.2K2.2K ICR15
402RES 0 OHM 5% 1/16W0402 SMD_0400 ICR16
402RES 0 OHM 5% 1/16W0402 SMD_0400 ICR17
402RES 178 OHM 1% 1/16W0402_0402_170 DNI ICR18
402RES 0 OHM 5% 1/16W0402 SMD_0400 ICR19
402RES 178 OHM 1% 1/16W0402_0402_170 DNI ICR20
402RESISTOR_0402_2727 ICR21
402RESISTOR_0402_1.00K1.00K ICR22
402RESISTOR_0402_470470 ICR23
402RES 0 OHM 5% 1/16W0402 SMD_0400 ICR24
402RES 100 OHM 1% 1/16W0402_0402_100 ICR25
402RES 0 OHM 5% 1/16W0402 SMD_0400 ICR26
402RES 0 OHM 5% 1/16W0402 SMD_0400 ICR27
402RES 0 OHM 5% 1/16W0402 SMD_0400 ICR28
402RES 0 OHM 5% 1/16W0402 SMD_0400 ICR29
402RES 0 OHM 5% 1/16W0402 SMD_0400 ICR30
402RES 0 OHM 5% 1/16W0402 SMD_0400 ICR31
402RES 0 OHM 5% 1/16W0402 SMD_0400 ICR32
402RES 4.7K OHM 1.0%1/16W 0402__14.7K DNI ICR33
402RES 0 OHM 5% 1/16W0402 SMD_0400 ICR34
402RES 1.00K OHM 1.0%1/16W 0402_01K ICR35
402RES 100 OHM 1.0%1/16W 0402_040100 DNI ICR36
402RES 20K OHM 1.0%1/16W 0402_04020K ICR37
402RES 16.2K OHM 1%1/10W 0402_04016.2k ICR38
402RES 20K OHM 1.0%1/16W 0402_04020K ICR39
402RES 6.34K OHM 1%1/10W 0402_0406.34k ICR40
402RES 4.7K OHM 1.0%1/16W 0402__14.7K DNI ICR41
402RES 40.2K OHM 1%1/16W 0402_04040.2k ICR42
402RES 20K OHM 1.0%1/16W 0402_04020K ICR43
2010RESISTOR_2010_0.270.27 ICR44
402RES 22.6K OHM 1%1/16W 0402_04022.6k ICR45
402RES 16.2K OHM 1%1/10W 0402_04016.2k ICR46
2010RESISTOR_2010_0.270.27 ICR47
402RES 0 OHM 5% 1/16W0402 SMD_0400 ICR48
402RES 0 OHM 5% 1/16W0402 SMD_0400 ICR49
402RES 0 OHM 5% 1/16W0402 SMD_0400 ICR50
402RES 0 OHM 5% 1/16W0402 SMD_0400 ICR51
402RES 0 OHM 5% 1/16W0402 SMD_0400 ICR52
402RES 0 OHM 5% 1/16W0402 SMD_0400 ICR53
402RES 0 OHM 5% 1/16W0402 SMD_0400 ICR54
402RES 0 OHM 5% 1/16W0402 SMD_0400 ICR55
402RES 0 OHM 5% 1/16W0402 SMD_0400 ICR56
402RES 0 OHM 5% 1/16W0402 SMD_0400 ICR57
402RES 0 OHM 5% 1/16W0402 SMD_0400 ICR58
402RES 0 OHM 5% 1/16W0402 SMD_0400 ICR59
402RES 9.31K OHM 1%1/10W 0402_0409.31k ICR60
402RES 4.7K OHM 1.0%1/16W 0402__14.7K DNI ICR61
402RES 6.34K OHM 1%1/10W 0402_0406.34k ICR62
402RES 4.7K OHM 1.0%1/16W 0402__14.7K DNI ICR63
402RES 4.7K OHM 1.0%1/16W 0402__14.7K DNI ICR64
402RES 4.7K OHM 1.0%1/16W 0402__14.7K DNI ICR65
402RES 4.7K OHM 1.0%1/16W 0402__14.7K DNI ICR66
402RES 4.7K OHM 1.0%1/16W 0402__14.7K DNI ICR67
402RES 4.7K OHM 1.0%1/16W 0402__14.7K DNI ICR68
402RES 100 OHM 1% 1/16W0402_0402_100 ICR69
402RES 100 OHM 1% 1/16W0402_0402_100 ICR70
402RES 4.7K OHM 1.0%1/16W 0402_044.7K ICR71
402RES 4.7K OHM 1.0%1/16W 0402_044.7K ICR72
PUSHBUTTON_SMTSW-BUTTON_PUSHBUTTON_SMT_SW-BUTSW-Button ICS1
PUSHBUTTON_SMTSW-BUTTON_PUSHBUTTON_SMT_SW-BUTSW-Button ICS2
TP_060SQ040TP_60_40_MIL_TP_060SQ040_TP_60_TP_60_40_mil ICTP1
TP_060SQ040TP_60_40_MIL_TP_060SQ040_TP_60_TP_60_40_mil ICTP2
TP_060SQ040TP_60_40_MIL_TP_060SQ040_TP_60_TP_60_40_mil ICTP3
TP_060SQ040TP_60_40_MIL_TP_060SQ040_TP_60_TP_60_40_mil ICTP4
SOT23-DBVSN65220DBV_SOT23-DBV_SN65220DBVSN65220DBV ICU1
SO8AT93C46-10_SO8_AT93C46DN-SH-BAT93C46DN-SH-B ICU2
LQFP-32FT245BL_LQFP-32_FT245BLFT245BL ICU3
M100EPM240M100_1_M100_EPM240M100_1EPM240M100_1 ICU4
F256EP5M570ZF256N_DK_F256_(S1+S2+S3EP5M570ZF256N ICU5
SOT23-5EEPROM, 24LC08B,SOT-23, 5-LEA24LC08B, SOT-23,5-LEAD, DNI ICU6
DFN12_EPAD_2X3MMREGULATOR,LTC3670_DFN12_EPAD_2Regulator, LTC3670 ICU7
TSSOP825LC256_TSSOP8_25LC256IST,TSSO25LC256IST, TSSOP, 8LEAD, DNI ICU8
XTL-11-5X4-3MMCRYSTAL, 6MHZ,SMD_XTL-11-5X4-3CRYSTAL, 6MHz, SMD ICX1
XTAL_ASEOSC, 24MHZ,SMD_1_XTAL_ASE_24MH24MHz ICY1
[/hide]
重要提示:PCB作品文件展下载说明
发表于 2018-12-10 10:15:59 | 显示全部楼层
发表于 2018-12-10 10:33:49 | 显示全部楼层
发表于 2021-7-20 15:40:19 | 显示全部楼层
终身成就奖金点子奖
发表于 2022-6-20 07:44:56 | 显示全部楼层
  • 签到天数: 61 天
    发表于 2022-6-20 08:23:16 | 显示全部楼层
    发表于 2022-6-20 08:33:35 | 显示全部楼层
  • 签到天数: 7 天
    社区居民终身成就奖特殊贡献奖
    发表于 2022-6-20 08:58:07 | 显示全部楼层
    发表于 2022-6-20 09:05:45 | 显示全部楼层
    昨天 09:15
  • 签到天数: 235 天
    发表于 2022-6-20 09:07:58 | 显示全部楼层
