查看: 3485|回复: 6
[Allegro16.6以下] Arria_V_SoC_Development_Kit_and_Intel_SoC_FPGA_Embedded_Development_Suite 开
发表于 2018-12-10 06:14:42 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
24 Arria_V_SoC_Development_Kit_and_Intel_SoC_FPGA_Embedded_Development_Suite.zip (10.74 MB, 下载次数: 0)
BT1BATTERY_BT1_BATTERYBatteryBT1
CAP_PACK_4_1206CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCN1
CAP_PACK_4_1206CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCN2
CAP_PACK_4_1206CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCN3
CAP_PACK_4_1206CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCN4
CAP_PACK_4_1206CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCN5
CAP_PACK_4_1206CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCN6
CAP_PACK_4_1206CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCN7
CAP_PACK_4_1206CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCN8
CAP_PACK_4_1206CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCN9
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD1
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD2
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD3
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD4
TSLP-3-7ESD_DIODE_DUAL_TSLP-3-7_ESD5V3UESD5V3U2UD5
TSLP-3-7ESD_DIODE_DUAL_TSLP-3-7_ESD5V3UESD5V3U2UD6
TSLP-3-7ESD_DIODE_DUAL_TSLP-3-7_ESD5V3UESD5V3U2UD7
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD8
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD9
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD10
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD11
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD12
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD13
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD14
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD15
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD16
SOD-123ZC2800E/SOT_SOD-123_DFLS230DFLS230D17
SOD-123ZC2800E/SOT_SOD-123_DFLS230DFLS230D18
SOD323D-SCHOTTKY_0_SOD323_CMDSH-3CMDSH-3D19
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD20
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD21
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD22
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD23
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD24
SOD323DIODE, SCHOTTKYCMDSH-3_SOD323_CMDSH-3D25
SOD323DIODE, SCHOTTKYCMDSH-3_SOD323_CMDSH-3D26
SOD323DIODE, SCHOTTKYCMDSH-3_SOD323_CMDSH-3D27
SOD323DIODE, SCHOTTKYCMDSH-3_SOD323_CMDSH-3D28
SOD323DIODE, SCHOTTKYCMDSH-3_SOD323_CMDSH-3D29
SOD323DIODE, SCHOTTKYCMDSH-3_SOD323_CMDSH-3D30
SOT23MMBD1205_SOT23_MMBD1205MMBD1205D31
SOD-123DIODE_SOD-123_40V40VD32
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD33
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD34
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD35
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD36
LUMEX_LED0805LED_LUMEX_LED0805_BLUELEDBLUE LEDD37
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD38
LUMEX_LED0805LED_LUMEX_LED0805_RED_LEDRed_LEDD39
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD40
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD41
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD42
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD43
SOD323D-SCHOTTKY_0_SOD323_CMDSH-3CMDSH-3D44
SOD323D-SCHOTTKY_0_SOD323_CMDSH-3CMDSH-3D45
SOD323DIODE, SCHOTTKYCMDSH-3_SOD323_CMDSH-3D46
MOLEX-MICRO-USB-47589-001MICRO_USB_CONN_MOLEX-MICRO-USB-MICRO_USB_CONNJ1
SMA_LTI-SASF546-P26-X1CONN,SMA_SMA_LTI-SASF546-P26-XSMAJ2
HDR2X1_100MILCON2_HDR2X1_100MIL_CON2CON2J3
10X40_ASP_VITA5710X40_VITA57_10X40_ASP_VITA57_AASP-134486-01J4
WURTH_MICRO-SD_CARDSD_SKT_1_WURTH_MICRO-SD_CARD_MIMicroSD_sktJ5
2X5VH2X5_2X5VH_2X5HEADER2x5HeaderJ6
HDR2X1_100MILCON2_HDR2X1_100MIL_CON2CON2J7
SMA_LTI-SASF546-P26-X1CONN,SMA_SMA_LTI-SASF546-P26-XSMAJ8
SMA_LTI-SASF546-P26-X1CONN,SMA_SMA_LTI-SASF546-P26-XSMAJ9
SMA_LTI-SASF546-P26-X1CONN,SMA_SMA_LTI-SASF546-P26-XSMAJ10
SMA_LTI-SASF546-P26-X1CONN,SMA_SMA_LTI-SASF546-P26-XSMAJ11
SMA_LTI-SASF546-P26-X1CONN,SMA_SMA_LTI-SASF546-P26-XSMAJ12
BEL_L829-1J1T-43ENET_L829-1J1T-43_2_BEL_L829-1JENET_L829-1J1T-43J13
MOLEX-MICRO-USB-47589-001MICRO_USB_CONN_MOLEX-MICRO-USB-MICRO_USB_CONNJ14
SMA_LTI-SASF546-P26-X1CONN,SMA_SMA_LTI-SASF546-P26-XSMAJ15
SMA_LTI-SASF546-P26-X1CONN,SMA_SMA_LTI-SASF546-P26-XSMAJ16
SMT382-767004-2_SMT38_MICTOR38PMictor38PJ17
HDR2X1_100MILCON2_HDR2X1_100MIL_CON2CON2J18
HDR2X1_100MILCON2_HDR2X1_100MIL_CON2CON2J19
MLX_22_23_2021_VRT_HDR_2PCON2_MLX_22_23_2021_MLX_22_23_222_23_2021J20
HDR2X1_100MILCON2_HDR2X1_100MIL_CON2CON2J21
MOLEX_MINI-AB_USB_THUSB_CON_TH_MOLEX_MINI-AB_USB_THUSB MINI-BJ22
HDR2X1_100MILCON2_HDR2X1_100MIL_CON2CON2J23
SMA_LTI-SASF546-P26-X1CONN,SMA_SMA_LTI-SASF546-P26-XSMAJ24
SMA_LTI-SASF546-P26-X1CONN,SMA_SMA_LTI-SASF546-P26-XSMAJ25
10X40_ASP_VITA5710X40_VITA57_10X40_ASP_VITA57_AASP-134486-01J26
MOLEX_MINI-AB_USB_THUSB_CON_TH_MOLEX_MINI-AB_USB_THUSB MINI-BJ27
HDR2X1_100MILCON2_HDR2X1_100MIL_CON2CON2J28
NEWHAVEN_LCDLCD_HEADER_NEWHAVEN_LCD_LCD_HEALCD_HEADERJ29
HDR2X1_100MILCON2_HDR2X1_100MIL_CON2CON2J30
SMA_LTI-SASF546-P26-X1CONN,SMA_SMA_LTI-SASF546-P26-XSMAJ31
SMA_LTI-SASF546-P26-X1CONN,SMA_SMA_LTI-SASF546-P26-XSMAJ32
MLX_SDA-5566_4POSATX-POWER_4P_MLX_SDA-5566_4POS_ATX-POWER_4PJ33
RAPC712CONN JACKPWR_3_RAPC712_CONN JACONN JACK PWRJ34
3M_SHROUD_2X5_100MIL_SMT70247-1051_3M_SHROUD_2X5_100MILJTAG_SMDJ35
2X6HDR-2MMX2MM2X6HDR_2X6HDR-2MMX2MM_2X6HDR2x6HDRJ36
CONN_TSW_103_07_L_SHEADER,1X3-PIN_CONN_TSW_103_07HEADER, 1x3-PINJ37
CONN_TSW_103_07_L_SHEADER,1X3-PIN_CONN_TSW_103_07HEADER, 1x3-PINJ38
CONN_TSW_103_07_L_SHEADER,1X3-PIN_CONN_TSW_103_07HEADER, 1x3-PINJ39
CONN_TSW_103_07_L_SHEADER,1X3-PIN_CONN_TSW_103_07HEADER, 1x3-PINJ40
CONN_TSW_103_07_L_SHEADER,1X3-PIN_CONN_TSW_103_07HEADER, 1x3-PINJ41
SAMTEC_PCIE_X4_VERT-64PCIE_BRACKET_X4_1_SAMTEC_PCIE_XPCIE-064-02-F-D-THJ42
SAMTEC_SFP_MECT20SFP+_AND_CAGE_SAMTEC_SFP_MECT20SFP+_AND_CAGEJ43
SAMTEC_SFP_MECT20SFP+_AND_CAGE_SAMTEC_SFP_MECT20SFP+_AND_CAGEJ44
HDR2X1_100MILCON2_HDR2X1_100MIL_CON2CON2J45
HDR2X1_100MILCON2_HDR2X1_100MIL_CON2CON2J46
RJ426ENET-7499011121A_2_RJ426_ENET-7ENET-7499011121AJ47
RJ426ENET-7499011121A_2_RJ426_ENET-7ENET-7499011121AJ48
SMA_LTI-SASF546-P26-X1SMA_LTI_SASF54GT_0_SMA_LTI-SASFSMAJ49
MOLEX_MINI-AB_USB_THUSB_CON_TH_MOLEX_MINI-AB_USB_THUSB MINI-BJ50
HDR2X5_100MIL_SMT2X5_HDR2X5_100MIL_SMT_DNIDNIJ51
402BEAD_FERRITE_SM_0402_7427927807.43E+08L1
IND_0603IND FERRITE 06033A/30 OHMS_IND3A, 30 Ohm FBL2
IND_0603IND FERRITE 06033A/30 OHMS_IND3A, 30 Ohm FBL3
IND_0603IND FERRITE 06033A/30 OHMS_IND3A, 30 Ohm FBL4
IND_0603IND FERRITE 06033A/30 OHMS_IND3A, 30 Ohm FBL5
IND_0603IND FERRITE 06033A/30 OHMS_IND3A, 30 Ohm FBL6
IND_0603IND FERRITE 06033A/30 OHMS_IND3A, 30 Ohm FBL7
IND_0603IND FERRITE 06033A/30 OHMS_IND3A, 30 Ohm FBL8
IND_0603IND FERRITE 06033A/30 OHMS_IND3A, 30 Ohm FBL9
IND_0603IND FERRITE 06033A/30 OHMS_IND3A, 30 Ohm FBL10
402BEAD_FERRITE_SM_0402_7427927807.43E+08L11
IND_0603IND FERRITE 06033A/30 OHMS_IND3A, 30 Ohm FBL12
IND_0603IND FERRITE 06033A/30 OHMS_IND3A, 30 Ohm FBL13
402BEAD_FERRITE_SM_0402_7427927807.43E+08L14
402BEAD_FERRITE_SM_0402_7427927807.43E+08L15
IND_SUSUMU_PCMC_BTYPEIND 1.2UH IR=6.5ACUBE SMD_IND_1.2uHL16
IND_SUSUMU_PCMC_BTYPEIND 1.2UH IR=6.5ACUBE SMD_IND_1.2uHL17
IND_SUSUMU_PCMC_BTYPEIND 1.2UH IR=6.5ACUBE SMD_IND_1.2uHL18
IND_0603IND FERRITE 06033A/30 OHMS_IND3A, 30 Ohm FBL19
IND_SUSUMU_PCMC_BTYPEIND 1.2UH IR=6.5ACUBE SMD_IND_1.2uHL20
VITECH_59P9875NINDUCTORIRON_0_VITECH_59P9875N0.68uHL21
IND_SUSUMU_PCMC_BTYPEIND 1.2UH IR=6.5ACUBE SMD_IND_1.2uHL22
IND_SUSUMU_PCMC_BTYPEIND 1.2UH IR=6.5ACUBE SMD_IND_1.2uHL23
IND_0603IND FERRITE 06033A/30 OHMS_IND3A, 30 Ohm FBL24
VITECH_59P9875NINDUCTORIRON_0_VITECH_59P987_11.5uHL25
IND_WURTH_74408943100INDUCTORIRON_0_IND_WURTH_7440810uHL26
HCM0703INDUCTORIRON_0_HCM0703_0.22UH0.22uHL27
IND_0603IND FERRITE 06033A/30 OHMS_IND3A, 30 Ohm FBL28
IND_0603IND FERRITE 06033A/30 OHMS_IND3A, 30 Ohm FBL29
IND_0603IND FERRITE 06033A/30 OHMS_IND3A, 30 Ohm FBL30
IND_WURTH_744311470IND 2.2UH IR=9A 7040SMD _IND_W6.5uHL31
IND_WURTH_744311470IND 2.2UH IR=9A 7040SMD _IND_W6.5uHL32
IND_0603IND FERRITE 06033A/30 OHMS_IND3A, 30 Ohm FBL33
IND_0603IND FERRITE 06033A/30 OHMS_IND3A, 30 Ohm FBL34
402BEAD_FERRITE_SM_0402_7427927807.43E+08L35
IND_0603IND FERRITE 06033A/30 OHMS_IND3A, 30 Ohm FBL36
SM_FERRITE_BEADINDUCTOR_SMD_1_SM_FERRITE_BEAD_1.0uHL37
SM_FERRITE_BEADINDUCTOR_SMD_1_SM_FERRITE_BEAD_1.0uHL38
SM_FERRITE_BEADINDUCTOR_SMD_1_SM_FERRITE_BEAD_1.0uHL39
SM_FERRITE_BEADINDUCTOR_SMD_1_SM_FERRITE_BEAD_1.0uHL40
402BEAD_FERRITE_SM_0402_7427927807.43E+08L41
SOT23PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NQ1
LFPAK-4RJK0301DPB_LFPAK-4_RJK0305DPBRJK0305DPBQ2
LFPAK-4RJK0301DPB_LFPAK-4_RJK0301DPBRJK0301DPBQ3
LFPAK-4RJK0301DPB_LFPAK-4_RJK0305DPBRJK0305DPBQ4
FDMC8878_VER2FDMC8878_VER2_FDMC8878_VER2_FDMFDMC8878Q5
FDMC8878_VER2FDMC8878_VER2_FDMC8878_VER2_FDMFDMC8878Q6
LFPAK-4RJK0301DPB_LFPAK-4_RJK0305DPBRJK0305DPBQ7
LFPAK-4RJK0301DPB_LFPAK-4_RJK0301DPBRJK0301DPBQ8
LFPAK-4RJK0301DPB_LFPAK-4_RJK0301DPBRJK0301DPBQ9
LFPAK-4RJK0301DPB_LFPAK-4_RJK0305DPBRJK0305DPBQ10
RES_PACK_8RES_PACK_0_RES_PACK_8_S1+S2+S3+51RN1
RES_PACK_8RES_PACK_0_RES_PACK_8_S1+S2+S3+51RN2
RES_PACK_8RES_PACK_0_RES_PACK_8_S1+S2+S3+51RN3
RES_PACK_8RES_PACK_0_RES_PACK_8_S1+S2+S3+51RN4
RES_PACK_8RES_PACK_0_RES_PACK_8_S1+S2+S3+51RN5
RES_PACK_8RES_PACK_0_RES_PACK_8_S1+S2+S3+51RN6
RES_PACK_8RES_PACK_0_RES_PACK_8_S1+S2+S3+51RN7
RES_PACK_8RES_PACK_0_RES_PACK_8_S1+S2+S3+51RN8
RES_PACK_8RES_PACK_0_RES_PACK_8_S1+S2+S3+51RN9
WURTH_6X3P5_TACT_SWITCHTS-A02SA-2-S100_0_WURTH_6X3P5_TPB SwitchS1
WURTH_6X3P5_TACT_SWITCHTS-A02SA-2-S100_0_WURTH_6X3P5_TPB SwitchS2
WURTH_6X3P5_TACT_SWITCHTS-A02SA-2-S100_0_WURTH_6X3P5_TPB SwitchS3
WURTH_6X3P5_TACT_SWITCHTS-A02SA-2-S100_0_WURTH_6X3P5_TPB SwitchS4
WURTH_6X3P5_TACT_SWITCHTS-A02SA-2-S100_0_WURTH_6X3P5_TPB SwitchS5
WURTH_6X3P5_TACT_SWITCHTS-A02SA-2-S100_0_WURTH_6X3P5_TPB SwitchS6
WURTH_6X3P5_TACT_SWITCHTS-A02SA-2-S100_0_WURTH_6X3P5_TPB SwitchS7
WURTH_6X3P5_TACT_SWITCHTS-A02SA-2-S100_0_WURTH_6X3P5_TPB SwitchS8
WURTH_6X3P5_TACT_SWITCHTS-A02SA-2-S100_0_WURTH_6X3P5_TPB SwitchS9
WURTH_6X3P5_TACT_SWITCHTS-A02SA-2-S100_0_WURTH_6X3P5_TPB SwitchS10
WURTH_6X3P5_TACT_SWITCHTS-A02SA-2-S100_0_WURTH_6X3P5_TPB SwitchS11
WURTH_6X3P5_TACT_SWITCHTS-A02SA-2-S100_0_WURTH_6X3P5_TPB SwitchS12
WURTH_6X3P5_TACT_SWITCHTS-A02SA-2-S100_0_WURTH_6X3P5_TPB SwitchS13
WURTH_6X3P5_TACT_SWITCHTS-A02SA-2-S100_0_WURTH_6X3P5_TPB SwitchS14
DIPSWITCH_SMT_OCTAL76SB08_DIPSWITCH_SMT_OCTAL_TDA0TDA08H0SB1SW1
DIPSWITCH_SMT_QUADSPST4_DIPSWITCH_SMT_QUAD_TDA04HTDA04H0SB1SW2
DIPSWITCH_SMT_HEXASPST6_DIPSWITCH_SMT_HEXA_TDA06HTDA06H0SB1SW3
DIPSWITCH_SMT_QUADSPST4_DIPSWITCH_SMT_QUAD_TDA04HTDA04H0SB1SW4
EG4208ASWSLIDE-4P2T_1_EG4208A_SW SLIDSW SLIDE-4P2TSW5
TP_060SQ040T_POINT_R_TP_060SQ040_TPTPTP1
TP_060SQ040T_POINT_R_TP_060SQ040_TPTPTP2
TP_060SQ040T_POINT_R_TP_060SQ040_TPTPTP3
TP_020RD_SMTT_POINT_R_TP_020RD_SMT_DNIDNITP4
TP_020RD_SMTT_POINT_R_TP_020RD_SMT_DNIDNITP5
TP_020RD_SMTT_POINT_R_TP_020RD_SMT_DNIDNITP6
TP_020RD_SMTT_POINT_R_TP_020RD_SMT_DNIDNITP7
TP_060SQ040T_POINT_R_TP_060SQ040_TPTPTP8
TP_060SQ040T_POINT_R_TP_060SQ040_TPTPTP9
MSOP10TS5A23157_MSOP10_TS5A23157TS5A23157U1
TDFN-8MAX14523B_TDFN-8_MAX14523BMAX14523BU2
QFN16NB6L72MNG_QFN16_NB6L72MNGNB6L72MNGU3
QFN32USB3300_QFN32_USB3300USB3300U4
QFN64-TILMK04828_0_QFN64-TI_LMK04828LMK04828U5
MSOP8-EPADLT3010_1_MSOP8-EPAD_LT3010LT3010U6
QFN48KSZ9021RN_4_QFN48_KSZ9021RNKSZ9021RNU7
QFN32-FTDIFT245RQ_QFN32-FTDI_FT245RQFT245RQU8
LGA77_1O27MM_9X15MM_LTLTM8025_2_LGA77_1O27MM_9X15MM_LLTM8025U9
DFN14_EPADLT3509EDE_DFN14_EPAD_LT3509EDELT3509EDEU10
SO16_WIDEDS1339C_0_SO16_WIDE_DS1339CDS1339CU11
SOT23-5LT1761_SOT23-5_LT1761LT1761U12
F64_10X8PC28FXXXP30B85_1_F64_10X8_PC28FPC28F512P30BFU13
DFM10-EPADLTC3026_DFM10-EPAD_LTC3026LTC3026U14
MSOP10TS5A23157_MSOP10_TS5A23157TS5A23157U15
MSOP10TS5A23157_MSOP10_TS5A23157TS5A23157U16
MSOP10TS5A23157_MSOP10_TS5A23157TS5A23157U17
MSOP10TS5A23157_MSOP10_TS5A23157TS5A23157U18
SO16_WIDEN25Q512A83GSF40F_SO16_WIDE_N25QN25Q512A83GSF40FU19
SON6TPD4S012DRYR_SON6_TPD4S012DRYRTPD4S012DRYRU20
QSOP24PIDTQS3861_QSOP24P_IDTQS3861IDTQS3861U21
DFM10-EPADLTC3026_DFM10-EPAD_LTC3026LTC3026U22
TSSOP16IDTQS3VH257_TSSOP16_IDTQS3VH257IDTQS3VH257U23
TSSOP16IDTQS3VH257_TSSOP16_IDTQS3VH257IDTQS3VH257U24
QFN32-FTDIFT232R_2_QFN32-FTDI_FT232RFT232RU25
DFM10-EPADLTC3026_DFM10-EPAD_LTC3026LTC3026U26
F2565M2210ZF256_F256_5M2210ZF2565M2210ZF256U27
SO16_WIDEEPCQ256_SO16_WIDE_EPCQ256EPCQ256U28
MICRON_DDR3_96_9X14MT41J128M16HA_0_MICRON_DDR3_96_MT41K256M16HA-125:EU29
TDFN-10SL18860DC_TDFN-10_SL18860DCSL18860DCU30
SOT23-8MAX3372EEKA_0_SOT23-8_MAX3373MAX3373U31
SON6TPD4S012DRYR_SON6_TPD4S012DRYRTPD4S012DRYRU32
QFN24REG SWITCHING,LTC3605EUF_QFN24LTC3605EUFU33
SO824LC32A_SO8_24LC32A24LC32AU34
QFN24SI5338A_0_QFN24_SI5338A-CUSTOMSi5338A-CUSTOMU35
QFN32-FTDIFT232R_2_QFN32-FTDI_FT232RFT232RU36
MICRON_DDR3_96_9X14MT41J128M16HA_0_MICRON_DDR3_96_MT41K256M16HA-125:EU37
MICRON_DDR3_96_9X14MT41J128M16HA_0_MICRON_DDR3_96_MT41K256M16HA-125:EU38
QFN24REG SWITCHING,LTC3605EUF_QFN24LTC3605EUFU39
QFN24REG SWITCHING,LTC3605EUF_QFN24LTC3605EUFU40
F15175ASXFB5F40_F1517_F1517_S1,S2,S35ASXFB5_F1517U41
QFN24SI5335_QFN24_SI5335Si5335U42
MICRON_DDR3_96_9X14MT41J128M16HA_0_MICRON_DDR3_96_MT41K256M16HA-125:EU43
MICRON_DDR3_96_9X14MT41J128M16HA_0_MICRON_DDR3_96_MT41K256M16HA-125:EU44
QFN24REG SWITCHING,LTC3605EUF_QFN24LTC3605EUFU45
QFN24REG SWITCHING,LTC3605EUF_QFN24LTC3605EUFU46
FDMC8878_VER2FDMC8878_VER2_FDMC8878_VER2_FDMFDMC8878U47
FDMC8878_VER2FDMC8878_VER2_FDMC8878_VER2_FDMFDMC8878U48
MICRON_DDR3_96_9X14MT41J128M16HA_0_MICRON_DDR3_96_MT41K256M16HA-125:EU49
QFN-64_9MMX9MMLTC2978_9X9_QFN_UP_2_QFN-64_9MMLTC2978U50
MICRON_DDR3_96_9X14MT41J128M16HA_0_MICRON_DDR3_96_MT41K256M16HA-125:EU51
QFN24REG SWITCHING,LTC3605EUF_QFN24LTC3605EUFU52
DFM10-EPADLTC3026_DFM10-EPAD_LTC3026LTC3026U53
QFN-64_9MMX9MMLTC2978_9X9_QFN_UP_2_QFN-64_9MMLTC2978U54
LQFP-80_12X12UPD60620_1_LQFP-80_12X12_UPD606uPD60621U55
F100MAX II,EPM570GF100C5N_0_F100_EEPM570GF100U56
SOT-143MAX811_SOT-143_MAX811MAX811U57
DFN6_EPADDIODE CONTROLLER,LTC4357_DFN6_LTC4357U58
TDFN10SI52112_2_TDFN10_SI52112Si52112U59
DFN6_EPADDIODE CONTROLLER,LTC4357_DFN6_LTC4357U60
VFBGA56CY7C68013A_VFBGA_VFBGA56_CY7C68CY7C68013A_VFBGAU61
TSSOP16ICS83054I_0_TSSOP16_ICS83054IICS83054IU62
DRTTPD2EUSB30_DRT_TPD2EUSB30TPD2EUSB30U63
QFN-64_9MMX9MMLTC2978_9X9_QFN_UP_2_QFN-64_9MMLTC2978U64
SOT-143MAX811_SOT-143_MAX811MAX811U65
SOT-143MAX811_SOT-143_MAX811MAX811U66
MSOP10TS5A23157_MSOP10_TS5A23157TS5A23157U67
DRC-10_EPADTPS51200_DRC-10_EPAD_TPS51200TPS51200U68
DRC-10_EPADTPS51200_DRC-10_EPAD_TPS51200TPS51200U69
DFN6_EPADLTC4357_DFN6_EPAD_LTC4357LTC4357U70
QFN40LTC3855_QFN40_LTC3855EUJLTC3855EUJU71
DFN6_EPADLTC4357_DFN6_EPAD_LTC4357LTC4357U72
DRC-10_EPADTPS51200_DRC-10_EPAD_TPS51200TPS51200U73
QFN24LTC3866_1_QFN24_LTC3866LTC3866U74
SENSESENSE_PAD_SENSE_SENSE_PADSENSE_PADV1
SENSESENSE_PAD_SENSE_SENSE_PADSENSE_PADV2
SENSESENSE_PAD_SENSE_SENSE_PADSENSE_PADV3
SENSESENSE_PAD_SENSE_SENSE_PADSENSE_PADV4
SENSESENSE_PAD_SENSE_SENSE_PADSENSE_PADV5
SENSESENSE_PAD_SENSE_SENSE_PADSENSE_PADV6
SENSESENSE_PAD_SENSE_SENSE_PADSENSE_PADV75
SENSESENSE_PAD_SENSE_SENSE_PADSENSE_PADV76
STAR_VIAVIA_1_STAR_VIA_VIA_1VIA_1V77
SENSESENSE_PAD_SENSE_SENSE_PADSENSE_PADV78
SENSESENSE_PAD_SENSE_SENSE_PADSENSE_PADV79
STAR_VIAVIA_1_STAR_VIA_VIA_1VIA_1V80
STAR_VIAVIA_1_STAR_VIA_VIA_1VIA_1V81
XTAL_ECX-32CRYSTALSM_ECS_XTAL_ECX-32_24MHZ24MHzX1
XTAL_SI570SI570_ALT1_XTAL_SI570_SI570SI570X2
XTAL_SI570VCXO, I2CPROGRAMMABLE, SI571_XSi571X3
ECS3525OSC_ALT_0_ECS3525_50MHZ50MHzX4
XTAL_EG2100635L3C3_XTAL_EG2100_125.0MHZ125.0MHzX5
XTAL_FA-128CRYSTAL_SM_13_XTAL_FA-128_25.0025.00MHzY1
XTAL_CRYSTEK_9X14VCXO_CRYSTEK_XTAL_CRYSTEK_9X14_122.88 MHzY2
XTAL_FA-128CRYSTAL_SM_13_XTAL_FA-128_25.0025.00MHzY3
XTAL_FA-128CRYSTAL_SM_13_XTAL_FA-128_25.0025.00MHzY4
XTAL_FA-128CRYSTAL_SM_13_XTAL_FA-128_25.0025.00MHzY5
XTAL_ASEOSC_0_XTAL_ASE_OSC_33MHZOSC_33MHZY6
XTAL_FA-128CRYSTAL_SM_13_XTAL_FA-128_24.0024.00MHzY7
重要提示:PCB作品文件展下载说明
发表于 2018-12-10 08:55:28 | 显示全部楼层
社区居民终身成就奖优秀斑竹奖社区明星宣传大使奖特殊贡献奖原创先锋奖
发表于 2018-12-10 08:56:02 | 显示全部楼层
发表于 2018-12-10 08:56:19 | 显示全部楼层
PADS-181217初级班
发表于 2018-12-11 08:29:16 | 显示全部楼层
    4 天前
  • 签到天数: 188 天
    发表于 2018-12-11 08:32:48 | 显示全部楼层
    发表于 2022-5-6 16:44:53 | 显示全部楼层
