查看: 2706|回复: 12
[Allegro16.6以下] Stratix_V_GX_FPGA_Development_Kit 开发板原理图PCB(REVC) 16层 近70
发表于 2018-12-10 06:25:41 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
28 REVC Stratix_V_GX_FPGA_Development_Kit.zip (10.14 MB, 下载次数: 4)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUEREFDES
CAP_PACK_4_1206CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCN1
CAP_PACK_4_1206CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCN2
CAP_PACK_4_1206CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCN3
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD1
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD2
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD3
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD4
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD5
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD6
LITE-ON_LTST-C195GEKTBILED_0_LITE-ON_LTST-C195GEKT_LLED_GRD7
LITE-ON_LTST-C195GEKTBILED_0_LITE-ON_LTST-C195GEKT_LLED_GRD8
LITE-ON_LTST-C195GEKTBILED_0_LITE-ON_LTST-C195GEKT_LLED_GRD9
LITE-ON_LTST-C195GEKTBILED_0_LITE-ON_LTST-C195GEKT_LLED_GRD10
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD11
LUMEX_LED0805LED_LUMEX_LED0805_RED_LEDRed_LEDD12
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD13
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD14
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD15
LUMEX_LED0805LED_LUMEX_LED0805_RED_LEDRed_LEDD16
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD17
LITE-ON_LTST-C195GEKTBILED_0_LITE-ON_LTST-C195GEKT_LLED_GRD18
LITE-ON_LTST-C195GEKTBILED_0_LITE-ON_LTST-C195GEKT_LLED_GRD19
LITE-ON_LTST-C195GEKTBILED_0_LITE-ON_LTST-C195GEKT_LLED_GRD20
LITE-ON_LTST-C195GEKTBILED_0_LITE-ON_LTST-C195GEKT_LLED_GRD21
DFN12_EPADLTC4352CDD_DFN12_EPAD_LTC4352CDLTC4352CDDD22
DFN12_EPADLTC4352CDD_DFN12_EPAD_LTC4352CDLTC4352CDDD23
LUMEX_LED0805LED_LUMEX_LED0805_BLUELEDBLUE LEDD24
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD25
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD26
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD27
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD28
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD29
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD30
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD31
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD32
LUMEX_LED0805LED_LUMEX_LED0805_YELLOWLEDYELLOW LEDD33
LUMEX_LED0805LED_LUMEX_LED0805_YELLOWLEDYELLOW LEDD34
LUMEX_LED0805LED_LUMEX_LED0805_YELLOWLEDYELLOW LEDD35
LUMEX_LED0805LED_LUMEX_LED0805_YELLOWLEDYELLOW LEDD36
LUMEX_LED0805LED_LUMEX_LED0805_YELLOWLEDYELLOW LEDD37
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDD38
SOT23MMBD1205_SOT23_MMBD1205MMBD1205D39
WURTH_MSOP882401646_WURTH_MSOP8_DNIDNID40
SOD323D-SCHOTTKY_0_SOD323_CMDSH-3CMDSH-3D41
SOD323D-SCHOTTKY_0_SOD323_CMDSH-3CMDSH-3D42
WURTH_MSOP882401646_WURTH_MSOP8_DNIDNID43
SOD323D-SCHOTTKY_0_SOD323_CMDSH-3CMDSH-3D44
SOD323D-SCHOTTKY_0_SOD323_CMDSH-3CMDSH-3D45
SAMTEC_QSHDP120CUSTOMQSH_HSM_SAMTEC_QSHDP120CUSTOM_AASP-122953-01J1
SAMTEC_QSHDP120CUSTOMQSH_HSM_SAMTEC_QSHDP120CUSTOM_AASP-122953-01J2
SMA_LTI-SASF546-P26-X1SMA_SMA_LTI-SASF546-P26-X1_LTI-LTI-SASF546-P26-X1J3
RAPC712CONN JACKPWR_3_RAPC712_CONN JACONN JACK PWRJ4
MOLEX_SD-47272-0024DISPLAYPORT_POST_CONN_MOLEX_SD-DNIJ5
SMA_LTI-SASF546-P26-X1SMA_SMA_LTI-SASF546-P26-X1_LTI-LTI-SASF546-P26-X1J6
WURTH_MICRO-USB_SMT_B-TYPEMICRO_USB_CONN_WURTH_MICRO-USB_MICRO_USB_CONNJ7
SAMTEC_HDR_2X3_2MM_SMTCON6A_SAMTEC_HDR_2X3_2MM_SMT_2X2x3_2mmJ8
RJ45HFJ11-1G02E_RJ45_HFJ11-1G02EHFJ11-1G02EJ9
CONN_39_26_710870247-1051_CONN_39_26_7108_702470247-1051J10
MLX_22_23_2021_VRT_HDR_2PCON2_MLX_22_23_2021_MLX_22_23_222_23_2021J11
TYCO_QSFP_38QSFP_AND_CAGE_0_TYCO_QSFP_38_QSQSFP_AND_CAGEJ12
SMA_LTI-SASF546-P26-X1SMA_LTI_SASF54GT_0_SMA_LTI-SASFLTI-SASF546-P26-X1J13
SMA_LTI-SASF546-P26-X1SMA_LTI_SASF54GT_0_SMA_LTI-SASFLTI-SASF546-P26-X1J14
HDR2X7_100MILHDR2X7_HDR2X7_100MIL_HDR2X7HDR2X7J15
AMPHENOL_SMB_JACK_VERTBNC_VERTICAL_4POST_AMPHENOL_SMBBNCJ16
AMPHENOL_SMB_JACK_VERTBNC_VERTICAL_4POST_AMPHENOL_SMBBNCJ17
PCIX-8PORTPCIE_BRACKET_X8_PCIX-8PORT_PCIEPCIE_SlotJ18
HDR2X5_100MIL_SMT2X5_HDR2X5_100MIL_SMT_DNIDNIJ19
IND_WURTH_7443551200INDUCTOR_IND_WURTH_7443551200_22.0uHL1
IND_WURTH_744311470INDUCTORIRON_0_IND_WURTH_744312uHL2
IND_WURTH_744308033INDUCTORIRON_0_IND_WURTH_744300.33uHL3
IND_WURTH_744308033INDUCTORIRON_0_IND_WURTH_744300.33uHL4
603BEAD_FERRITE_SM_0603_120OHM FB120 Ohm FBL5
402BEAD_FERRITE_SM_0402_BLM15AG221BLM15AG221SN1L6
IND_0805BEAD_FERRITE_SM_IND_0805_BLM21PBLM21PG331SN1L7
IND_0603BEAD_FERRITE_SM_IND_0603_3A,303A, 30 Ohm FBL8
402BEAD_FERRITE_SM_0402_BLM15AG221BLM15AG221SN1L9
SM_FERRITE_BEADINDUCTOR_SMD_1_SM_FERRITE_BEAD_1.0uHL10
402INDUCTOR_0402_5.6NH5.6nHL11
402INDUCTOR_0402_5.6NH5.6nHL12
402INDUCTOR_0402_3.9NH3.9nHL13
SM_FERRITE_BEADINDUCTOR_SMD_1_SM_FERRITE_BEAD_1.0uHL14
SM_FERRITE_BEADINDUCTOR_SMD_1_SM_FERRITE_BEAD_1.0uHL15
LFPAK-4RJK0301DPB_LFPAK-4_RJK0301DPBRJK0301DPBQ1
LFPAK-4RJK0301DPB_LFPAK-4_RJK0301DPBRJK0301DPBQ2
LFPAK-4RJK0301DPB_LFPAK-4_RJK0305DPBRJK0305DPBQ3
LFPAK-4RJK0301DPB_LFPAK-4_RJK0305DPBRJK0305DPBQ4
LFPAK-4RJK0301DPB_LFPAK-4_RJK0305DPBRJK0305DPBQ5
LFPAK-4RJK0301DPB_LFPAK-4_RJK0301DPBRJK0301DPBQ6
LFPAK-4RJK0301DPB_LFPAK-4_RJK0301DPBRJK0301DPBQ7
LFPAK-4RJK0301DPB_LFPAK-4_RJK0305DPBRJK0305DPBQ8
LFPAK-4RJK0301DPB_LFPAK-4_RJK0305DPBRJK0305DPBQ9
LFPAK-4RJK0301DPB_LFPAK-4_RJK0301DPBRJK0301DPBQ10
LFPAK-4RJK0301DPB_LFPAK-4_RJK0301DPBRJK0301DPBQ11
SC-75PNP_TRANS_SC-75_MMBT3906MMBT3906Q12
SC-75PNP_TRANS_SC-75_MMBT3906MMBT3906Q13
SOT23PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NQ14
RES_PACK_8RES_PACK_0_RES_PACK_8_S1+S2+S3+10KRN1
RES_PACK_8RES_PACK_0_RES_PACK_8_S1+S2+S_151RN2
RES_PACK_8RES_PACK_0_RES_PACK_8_S1+S2+S_151RN3
RES_PACK_8RES_PACK_0_RES_PACK_8_S1+S2+S_151RN4
PUSHBUTTON_SMTTS-A02SA-2-S100_PUSHBUTTON_SMT_PB SwitchS1
PUSHBUTTON_SMTTS-A02SA-2-S100_PUSHBUTTON_SMT_PB SwitchS2
PUSHBUTTON_SMTTS-A02SA-2-S100_PUSHBUTTON_SMT_PB SwitchS3
PUSHBUTTON_SMTTS-A02SA-2-S100_PUSHBUTTON_SMT_PB SwitchS4
PUSHBUTTON_SMTTS-A02SA-2-S100_PUSHBUTTON_SMT_PB SwitchS5
PUSHBUTTON_SMTTS-A02SA-2-S100_PUSHBUTTON_SMT_PB SwitchS6
PUSHBUTTON_SMTTS-A02SA-2-S100_PUSHBUTTON_SMT_PB SwitchS7
DIPSWITCH_SMT_OCTAL76SB08_DIPSWITCH_SMT_OCTAL_TDA0TDA08H0SB1SW1
EG4208ASWSLIDE-4P2T_1_EG4208A_SW SLIDSW SLIDE-4P2TSW2
DIPSWITCH_SMT_QUADSPST4_DIPSWITCH_SMT_QUAD_TDA04HTDA04H0SB1SW3
DIPSWITCH_SMT_HEXASPST6_DIPSWITCH_SMT_HEXA_TDA06HTDA06H0SB1SW4
DIPSWITCH_SMT_QUADSPST4_DIPSWITCH_SMT_QUAD_TDA04HTDA04H0SB1SW5
DIPSWITCH_SMT_QUADSPST4_DIPSWITCH_SMT_QUAD_TDA04HTDA04H0SB1SW6
TP_060SQ040T_POINT_R_TP_060SQ040_DNIDNITP1
MSOP10LTC2990_MSOP10_LTC2990LTC2990U1
DFN16_EPAD_5X5LT3021EDH_DFN16_EPAD_5X5_LT3021LT3021EDHU2
QFN40LTC3855_QFN40_LTC3855EUJLTC3855EUJU3
F2565M2210ZF256_F256_5M2210ZF2565M2210ZF256U4
F165CY7C2263KV18_F165_CY7C2263KV18CY7C2263KV18U5
DFN6_EPADLTC4357_DFN6_EPAD_LTC4357LTC4357U6
DFN6_EPADLTC4357_DFN6_EPAD_LTC4357LTC4357U7
VFBGA56CY7C68013A_VFBGA_VFBGA56_CY7C68CY7C68013A_VFBGAU8
SOT-143MAX811_SOT-143_MAX811MAX811U9
F64_10X8PC28FXXXP30B85_1_F64_10X8_PC28FPC28F512P30BFU10
F64_10X8PC28FXXXP30B85_1_F64_10X8_PC28FPC28F512P30BFU11
MICRON_DDR3_78_8X11P5MT41J128M8JP_MICRON_DDR3_78_8X1MT41J128M8JPU12
QFN40LTC3880_QFN40_LTC3880LTC3880U13
M100EPM570M100_0_M100_S1,S2,S3_EPM5EPM570GM100U14
F15175SGXA7KF40_F1517_(S1+S2+S3+S4+S5SGXA7KF40U15
DRC-10_EPADTPS51200_DRC-10_EPAD_TPS51200TPS51200U16
MICRON_DDR3_96_9X14MT41J128M16HA_MICRON_DDR3_96_9XMT41J128M16HAU17
LGA144LTM4614_1_LGA144_LTM4614LTM4614U18
BCC9688E1111_BCC96_88E111188E1111U19
FBGA144_SPECMT49H32M18BM_FBGA144_SPEC_MT49HMT49H32M18BMU20
MICRON_DDR3_96_9X14MT41J128M16HA_MICRON_DDR3_96_9XMT41J128M16HAU21
UCSP-12MAX13042_UCSP-12_MAX13042MAX13042U22
MICRON_DDR3_96_9X14MT41J128M16HA_MICRON_DDR3_96_9XMT41J128M16HAU23
LLP16_EPADLMH0384_LLP16_EPAD_LMH0384LMH0384U24
LLP16_EPADLMH0303_LLP16_EPAD_LMH0303LMH0303U25
LGA144LTM4628_1_LGA144_LTM4628LTM4628U26
LGA144LTM4628_1_LGA144_LTM4628LTM4628U27
MICRON_DDR3_96_9X14MT41J128M16HA_MICRON_DDR3_96_9XMT41J128M16HAU28
FDMC8878FDMC8878_FDMC8878_FDMC8878FDMC8878U29
DFN6_EPADLTC4357_DFN6_EPAD_LTC4357LTC4357U30
DFN8_EPADLT3080-1_DFN8_EPAD_LT3080-1/1.1LT3080-1/1.1A LDOU31
DFN8_EPADLT3080-1_DFN8_EPAD_LT3080-1/1.1LT3080-1/1.1A LDOU32
DFN8_EPADLT3080-1_DFN8_EPAD_LT3080-1/1.1LT3080-1/1.1A LDOU33
SO8SN65MLVDS200A_SO8_DNIDNIU34
DRC-10_EPADTPS51200_DRC-10_EPAD_TPS51200TPS51200U35
FDMC8878FDMC8878_FDMC8878_FDMC8878FDMC8878U36
FDMC8878FDMC8878_FDMC8878_FDMC8878FDMC8878U37
QFN24SI5338A_0_QFN24_SI5338A-CUSTOMSi5338A-CUSTOMU38
FDMC8878FDMC8878_FDMC8878_FDMC8878FDMC8878U39
FDMC8878FDMC8878_FDMC8878_FDMC8878FDMC8878U40
VFQFPN-28_EPADIDT5T9306_0_VFQFPN-28_EPAD_IDT5IDT5T9306U41
DFN6-2X2_EPADLTC3025-1_0_DFN6-2X2_EPAD_LTC30LTC3025-1U42
DRTTPD2EUSB30_DRT_TPD2EUSB30TPD2EUSB30U43
DFN8-EPAD_3X2LTC2915DDB_DFN8-EPAD_3X2_LTC291LTC2915U44
QSOP16MAX1619_5_QSOP16_MAX1619MAX1619U45
QFN24SI5338A_0_QFN24_SI5338A-CUSTOMSi5338A-CUSTOMU46
DFN6-2X2_EPADLTC3025-1_0_DFN6-2X2_EPAD_LTC30LTC3025-1U47
DFN12_EPAD_4X4LT3083EDF_DFN12_EPAD_4X4_LT3083LT3083EDFU48
DFN6-2X2_EPADLT3009XDC_0_DFN6-2X2_EPAD_LT300LT3009xDCU49
DFN16_EPAD_5X3LT3022EDHC_DFN16_EPAD_5X3_LT302LT3022EDHCU50
MSOP10TS5A23157_MSOP10_TS5A23157TS5A23157U51
SSOP28_NARLTC2418_SSOP28_NAR_LTC2418LTC2418U52
WSON8L_EPADN25QXXXA13EF8_WSON8L_EPAD_N25Q2N25Q256AU53
MSOP10TS5A23157_MSOP10_TS5A23157TS5A23157U54
MSOP10TS5A23157_MSOP10_TS5A23157TS5A23157U55
TSSOP14MAX3378_0_TSSOP14_MAX3378MAX3378U56
DFN16_EPAD_4X3LT3029EDE_DFN16_EPAD_4X3_LT3029LT3029EDEU57
SENSESENSE_PAD_SENSE_SENSE_PADSENSE_PADV1
SENSESENSE_PAD_SENSE_SENSE_PADSENSE_PADV2
SENSESENSE_PAD_SENSE_SENSE_PADSENSE_PADV3
SENSESENSE_PAD_SENSE_SENSE_PADSENSE_PADV4
SENSESENSE_PAD_SENSE_SENSE_PADSENSE_PADV5
SENSESENSE_PAD_SENSE_SENSE_PADSENSE_PADV6
SENSESENSE_PAD_SENSE_SENSE_PADSENSE_PADV7
SENSESENSE_PAD_SENSE_SENSE_PADSENSE_PADV8
SENSESENSE_PAD_SENSE_SENSE_PADSENSE_PADV9
SENSESENSE_PAD_SENSE_SENSE_PADSENSE_PADV10
SENSESENSE_PAD_SENSE_SENSE_PADSENSE_PADV11
SENSESENSE_PAD_SENSE_SENSE_PADSENSE_PADV12
STAR_VIAVIA_1_STAR_VIA_VIA_1VIA_1V13
STAR_VIAVIA_1_STAR_VIA_VIA_1VIA_1V14
STAR_VIAVIA_1_STAR_VIA_VIA_1VIA_1V15
SENSESENSE_PAD_SENSE_SENSE_PADSENSE_PADV16
SENSESENSE_PAD_SENSE_SENSE_PADSENSE_PADV17
SENSESENSE_PAD_SENSE_SENSE_PADSENSE_PADV18
SENSESENSE_PAD_SENSE_SENSE_PADSENSE_PADV19
SENSESENSE_PAD_SENSE_SENSE_PADSENSE_PADV20
SENSESENSE_PAD_SENSE_SENSE_PADSENSE_PADV21
SENSESENSE_PAD_SENSE_SENSE_PADSENSE_PADV22
SENSESENSE_PAD_SENSE_SENSE_PADSENSE_PADV23
SENSESENSE_PAD_SENSE_SENSE_PADSENSE_PADV24
SENSESENSE_PAD_SENSE_SENSE_PADSENSE_PADV25
SENSESENSE_PAD_SENSE_SENSE_PADSENSE_PADV26
SENSESENSE_PAD_SENSE_SENSE_PADSENSE_PADV27
SENSESENSE_PAD_SENSE_SENSE_PADSENSE_PADV28
SENSESENSE_PAD_SENSE_SENSE_PADSENSE_PADV29
XTAL_EG2100635L3C3_XTAL_EG2100_125.0MHZ125.0MHzX1
XTAL_XG-1000CBOSC_ALT_1_XTAL_XG-1000CB_100MHZ100MHzX2
ECS3525OSC_ALT_0_ECS3525_50MHZ50MHzX3
XTAL_SI570SI570_ALT1_XTAL_SI570_SI570SI570X4
XTAL_SG310OSC_ALT_XTAL_SG310_25.00MHZ25.00MHzX5
XTAL_SI570SI571_XTAL_SI570_SI571SI571X6
XTAL_FA-128CRYSTAL_SM_13_XTAL_FA-128_24.0024.00MHzY1
XTAL_FA-128CRYSTAL_SM_13_XTAL_FA-128_25.0025.00MHzY2
XTAL_FA-128CRYSTAL_SM_13_XTAL_FA-128_25.0025.00MHzY3
重要提示:PCB作品文件展下载说明
发表于 2020-12-22 10:21:14 | 显示全部楼层
发表于 2020-12-22 11:12:16 | 显示全部楼层
发表于 2020-12-22 11:57:42 | 显示全部楼层
发表于 2020-12-22 12:33:24 | 显示全部楼层
发表于 2020-12-23 09:22:23 | 显示全部楼层
发表于 2020-12-23 09:54:03 | 显示全部楼层
发表于 2020-12-23 09:55:09 | 显示全部楼层
发表于 2020-12-23 11:41:42 | 显示全部楼层
发表于 2020-12-24 12:17:17 | 显示全部楼层
看一下,论坛有你更精彩哦
