查看: 2636|回复: 7
[Allegro16.6以下] Transceiver_Signal_Integrity_Development_Kit,_Stratix_V_GX_Edition 信号完
发表于 2018-12-10 06:39:09 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
33Transceiver_Signal_Integrity_Development_Kit,_Stratix_V_GX_Edition.zip (6.66 MB, 下载次数: 0)
Bill of MaterialReport
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUEREFDES
BT1BATTERY_BT1_BATTERYBatteryBT1
USB-67068-8001CN-USB_USB-67068-8001_CN-USBCN-USBCN1
DO-214AB_RECTRONDIODE_DO-214AB_RECTRON_FM540FM540D1
SOD323D-SCHOTTKY_0_SOD323_CMDSH-3CMDSH-3D2
LUMEX_LED1206LED_LUMEX_LED1206_BLUE_LEDBlue_LedD3
SOD323D-SCHOTTKY_0_SOD323_CMDSH-3CMDSH-3D4
SOD323D-SCHOTTKY_0_SOD323_CMDSH-3CMDSH-3D5
SOD323D-SCHOTTKY_0_SOD323_CMDSH-3CMDSH-3D6
LUMEX_LED1206LED_LUMEX_LED1206_AMBER_LEDAmber_LEDD7
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD8
LUMEX_LED1206LED_LUMEX_LED1206_RED_LEDRed_LEDD9
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD10
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD11
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD12
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD13
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD14
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD15
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD16
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD17
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD18
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD19
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD20
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD21
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD22
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD23
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD24
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDD25
SOD-123DIODE_SOD-123_1N6263W-7,60V1N6263W-7,60vD26
FUSE_SMTFUSE_FUSE_SMT_10 AMPS10 AMPSF1
FUSE_SMTFUSE_FUSE_SMT_10 AMPS10 AMPSF2
FUSE_SMTFUSE_FUSE_SMT_2 AMPS2 AMPSF3
FUSE_SMTFUSE_FUSE_SMT_2 AMPS2 AMPSF4
FUSE_SMTFUSE_FUSE_SMT_2 AMPS2 AMPSF5
FUSE_SMTFUSE_FUSE_SMT_5A5AF6
FUSE_SMTFUSE_FUSE_SMT_2 AMPS2 AMPSF7
FUSE_SMTFUSE_FUSE_SMT_2 AMPS2 AMPSF8
805INDUCTOR_805_120OHM,800MA120ohm, 800mAFB1
805INDUCTOR_805_120OHM,800MA120ohm, 800mAFB2
805INDUCTOR_805_120OHM,800MA120ohm, 800mAFB3
805INDUCTOR_805_120OHM,800MA120ohm, 800mAFB4
805INDUCTOR_805_120OHM,800MA120ohm, 800mAFB5
805INDUCTOR_805_120OHM;800MA120ohm; 800mAFB6
2057389-1_GPG-PIN_TYCO_2057389-1_2057389-1_G-Pin_Tyco_2057389-1GP1
2057389-1_GPG-PIN_TYCO_2057389-1_2057389-1_G-Pin_Tyco_2057389-1GP2
RAPC712CONN_JACK_PWR_RAPC712_RAPC712XRAPC712XJ1
BANANA_JACKBANANA_JACK_RED_BANANA_JACK_B_1BANANA_JACK_BLACKJ3
BANANA_JACKBANANA_JACK_RED_BANANA_JACK_BANBANANA_JACK_REDJ6
BANANA_JACKBANANA_JACK_RED_BANANA_JACK_BANBANANA_JACK_REDJ9
BANANA_JACKBANANA_JACK_RED_BANANA_JACK_BANBANANA_JACK_REDJ12
BANANA_JACKBANANA_JACK_RED_BANANA_JACK_BANBANANA_JACK_REDJ15
BANANA_JACKBANANA_JACK_RED_BANANA_JACK_BANBANANA_JACK_REDJ18
BANANA_JACKBANANA_JACK_RED_BANANA_JACK_BANBANANA_JACK_REDJ21
2X6HDR-2MMX2MM2X6HDR_2X6HDR-2MMX2MM_2X6HDR2x6HDRJ24
CONN_FANCON3_CONN_FAN_3X13X1J25
HEADER031X3_HEADER03_1X3HEADER1x3HeaderJ26
2X5VH2X5_2X5VH_2X5HEADER2x5HeaderJ27
HEADER031X3_HEADER03_1X3HEADER1x3HeaderJ28
RJ45HFJ11-1G02E_RJ45_HFJ11-1G02EHFJ11-1G02EJ29
HDR2X7_100MILHDR2X7_HDR2X7_100MIL_HDR2X7HDR2X7J30
2X4VH2X4_2X4VH_2X4HEADER2x4HeaderJ31
AMPHENOL_C-950-400A-500AMPHENOL_CONN_C-950-400A-500_AMAmphenol_conn_C-950-400A-500J32
TYCO_STRADA-2149323-1TYCO_STRADA_2149323-1_TYCO_STRAtyco_strada_2149323-1J33
AIRMAX_10057041-101LFMOLEX-CONN_76160-5020_AIRMAX_10Molex-conn_76160-5020J34
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J35
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J36
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J37
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J38
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J39
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J40
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J41
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J42
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J45
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J46
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J47
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J48
SAMTEC_SFP_MECT20SFP+_AND_CAGE_SAMTEC_SFP_MECT20SFP+_AND_CAGEJ51
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J52
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J53
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J54
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J55
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J56
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J57
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J58
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J59
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J60
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J61
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J62
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J63
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J64
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J65
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J66
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J67
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J68
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J69
SMA_LTI-SASF546-P26-X1SMA_SMA_LTI-SASF546-P26-X1_LTI-LTI-SASF546-P26-X1J70
SMA_LTI-SASF546-P26-X1SMA_SMA_LTI-SASF546-P26-X1_LTI-LTI-SASF546-P26-X1J71
SMA_LTI-SASF546-P26-X1SMA_SMA_LTI-SASF546-P26-X1_LTI-LTI-SASF546-P26-X1J72
SMA_LTI-SASF546-P26-X1SMA_SMA_LTI-SASF546-P26-X1_LTI-LTI-SASF546-P26-X1J73
SMA_LTI-SASF546-P26-X1SMA_SMA_LTI-SASF546-P26-X1_LTI-LTI-SASF546-P26-X1J78
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J79
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J80
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J81
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J83
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J84
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J85
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J86
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J87
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J88
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J89
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J90
SMA_LTI-SASF546-P26-X1SMA_0_SMA_LTI-SASF546-P26-X1_LTLTI-SASF546-P26-X1J91
CONN_39_26_710870247-1051_CONN_39_26_7108_702470247-1051J93
96-MMPX-50-0-1SMA-2.4MM_96-MMPX-50-0-1_2.4MM2.4mmJ94
96-MMPX-50-0-1SMA-2.4MM_96-MMPX-50-0-1_2.4MM2.4mmJ95
96-MMPX-50-0-1SMA-2.4MM_96-MMPX-50-0-1_2.4MM2.4mmJ96
96-MMPX-50-0-1SMA-2.4MM_96-MMPX-50-0-1_2.4MM2.4mmJ97
96-MMPX-50-0-1SMA-2.4MM_96-MMPX-50-0-1_2.4MM2.4mmJ98
96-MMPX-50-0-1SMA-2.4MM_96-MMPX-50-0-1_2.4MM2.4mmJ99
96-MMPX-50-0-1SMA-2.4MM_96-MMPX-50-0-1_2.4MM2.4mmJ100
96-MMPX-50-0-1SMA-2.4MM_96-MMPX-50-0-1_2.4MM2.4mmJ101
96-MMPX-50-0-1SMA-2.4MM_96-MMPX-50-0-1_2.4MM2.4mmJ102
96-MMPX-50-0-1SMA-2.4MM_96-MMPX-50-0-1_2.4MM2.4mmJ103
96-MMPX-50-0-1SMA-2.4MM_96-MMPX-50-0-1_2.4MM2.4mmJ104
96-MMPX-50-0-1SMA-2.4MM_96-MMPX-50-0-1_2.4MM2.4mmJ105
96-MMPX-50-0-1SMA-2.4MM_96-MMPX-50-0-1_2.4MM2.4mmJ106
96-MMPX-50-0-1SMA-2.4MM_96-MMPX-50-0-1_2.4MM2.4mmJ107
96-MMPX-50-0-1SMA-2.4MM_96-MMPX-50-0-1_2.4MM2.4mmJ108
96-MMPX-50-0-1SMA-2.4MM_96-MMPX-50-0-1_2.4MM2.4mmJ109
96-MMPX-50-0-1SMA-2.4MM_96-MMPX-50-0-1_2.4MM2.4mmJ110
96-MMPX-50-0-1SMA-2.4MM_96-MMPX-50-0-1_2.4MM2.4mmJ111
96-MMPX-50-0-1SMA-2.4MM_96-MMPX-50-0-1_2.4MM2.4mmJ112
96-MMPX-50-0-1SMA-2.4MM_96-MMPX-50-0-1_2.4MM2.4mmJ113
VITECH_59P9875NINDUCTORIRON_0_VITECH_59P9875N0.68uHL1
7.44E+08INDUCTORIRON_1_744313120_1.2UH1.2uHL2
VITECH_59P9875NINDUCTORIRON_0_VITECH_59P9875N0.68uHL3
VITECH_59P9875NINDUCTORIRON_0_VITECH_59P9875N0.68uHL4
SM_FERRITE_BEADINDUCTOR_SMD_1_SM_FERRITE_BEAD_1.0uHL10
SM_FERRITE_BEADINDUCTOR_SMD_1_SM_FERRITE_BEAD_1.0uHL11
MTH250R125MNTHOLE_MTH250R125_LCD MNT HOLLCD MNT HOLEMNT1
MTH250R125MNTHOLE_MTH250R125_LCD MNT HOLLCD MNT HOLEMNT2
PWRPK_SO8RJK0301DPB_PWRPK_SO8_RJK0305DPBRJK0305DPBQ1
PWRPK_SO8RJK0301DPB_PWRPK_SO8_RJK0301DPBRJK0301DPBQ2
PWRPK_SO8RJK0301DPB_PWRPK_SO8_RJK0305DPBRJK0305DPBQ3
PWRPK_SO8RJK0301DPB_PWRPK_SO8_RJK0301DPBRJK0301DPBQ4
PWRPK_SO8RJK0301DPB_PWRPK_SO8_RJK0305DPBRJK0305DPBQ5
PWRPK_SO8RJK0301DPB_PWRPK_SO8_RJK0301DPBRJK0301DPBQ6
PWRPK_SO8RJK0301DPB_PWRPK_SO8_RJK0305DPBRJK0305DPBQ7
PWRPK_SO8RJK0301DPB_PWRPK_SO8_RJK0301DPBRJK0301DPBQ8
TSMT3MOSFET_N_TSMT3_FDV305NFDV305NQ9
402RESISTOR_0402_100K100KR1
PUSHBUTTON_EVQEVQPAC07K_PUSHBUTTON_EVQ_PBSWITPBswitchS1
PUSHBUTTON_EVQEVQPAC07K_PUSHBUTTON_EVQ_PBSWITPBswitchS2
PUSHBUTTON_EVQEVQPAC07K_PUSHBUTTON_EVQ_PBSWITPBswitchS3
PUSHBUTTON_EVQEVQPAC07K_PUSHBUTTON_EVQ_PBSWITPBswitchS4
PUSHBUTTON_EVQEVQPAC07K_PUSHBUTTON_EVQ_PBSWITPBswitchS5
PUSHBUTTON_EVQEVQPAC07K_PUSHBUTTON_EVQ_PBSWITPBswitchS6
DIPSWITCH12SPST6_DIPSWITCH12_SPST6SPST6S7
SWSPDTSWSLIDE-DPDT_SWSPDT_EG2201AEG2201ASW1
DIPSWITCH_SMT_QUADSPST4_DIPSWITCH_SMT_QUAD_TDA04HTDA04H0SB1SW2
DIPSWITCH_SMT_QUADSPST4_DIPSWITCH_SMT_QUAD_TDA04HTDA04H0SB1SW3
DIPSWITCH16SPST8_DIPSWITCH16_DIP_SW_8DIP_SW_8SW4
DIPSWITCH_SMT_QUADSPST4_DIPSWITCH_SMT_QUAD_TDA04HTDA04H0SB1SW5
DIPSWITCH_SMT_QUADSPST4_DIPSWITCH_SMT_QUAD_TDA04HTDA04H0SB1SW6
DIPSWITCH_SMT_QUADSPST4_DIPSWITCH_SMT_QUAD_TDA04HTDA04H0SB1SW7
GNDVIA10T POINTR_GNDVIA10_VIAVIATP3
GNDVIA10T POINTR_GNDVIA10_VIAVIATP4
GNDVIA10T POINTR_GNDVIA10_VIAVIATP5
GNDVIA10T POINTR_GNDVIA10_VIAVIATP6
GNDVIA10T POINTR_GNDVIA10_VIAVIATP7
GNDVIA10T POINTR_GNDVIA10_VIAVIATP8
GNDVIA10T POINTR_GNDVIA10_VIAVIATP9
GNDVIA10T POINTR_GNDVIA10_VIAVIATP10
GNDVIA10T POINTR_GNDVIA10_VIAVIATP11
GNDVIA10T POINTR_GNDVIA10_VIAVIATP12
GNDVIA10T POINTR_GNDVIA10_VIAVIATP17
GNDVIA10T POINTR_GNDVIA10_VIAVIATP18
GNDVIA10T POINTR_GNDVIA10_VIAVIATP19
GNDVIA10T POINTR_GNDVIA10_VIAVIATP20
GNDVIA10T POINTR_GNDVIA10_VIAVIATP21
GNDVIA10T POINTR_GNDVIA10_VIAVIATP22
GNDVIA10T POINTR_GNDVIA10_VIAVIATP23
GNDVIA10T POINTR_GNDVIA10_VIAVIATP24
GNDVIA10T POINTR_GNDVIA10_VIAVIATP25
GNDVIA10T POINTR_GNDVIA10_VIAVIATP26
GNDVIA10T POINTR_GNDVIA10_VIAVIATP27
GNDVIA10T POINTR_GNDVIA10_VIAVIATP28
GNDVIA10T POINTR_GNDVIA10_VIAVIATP29
GNDVIA10T POINTR_GNDVIA10_VIAVIATP30
GNDVIA10T POINTR_GNDVIA10_VIAVIATP31
GNDVIA10T POINTR_GNDVIA10_VIAVIATP32
GNDVIA10T POINTR_GNDVIA10_VIAVIATP33
GNDVIA10T POINTR_GNDVIA10_VIAVIATP34
GNDVIA10T POINTR_GNDVIA10_VIAVIATP35
GNDVIA10T POINTR_GNDVIA10_VIAVIATP36
GNDVIA10T POINTR_GNDVIA10_VIAVIATP37
GNDVIA10T POINTR_GNDVIA10_VIAVIATP38
QFN_6MMX6MM-40LTC3855_QFN_6MMX6MM-40_LTC3855ELTC3855EUJU1
QFN_6MMX6MM-40LTC3855_QFN_6MMX6MM-40_LTC3855ELTC3855EUJU2
LTM4615EVLTM4615EV_LTM4615EV_LTM4615EVLTM4615EVU3
LGA_4608LTM4608_LGA_4608_LTM4608AEVLTM4608AEVU4
DFM10-EPADLTC3026_DFM10-EPAD_LTC3026LTC3026U5
DFM10-EPADLTC3026_DFM10-EPAD_LTC3026LTC3026U6
DFM10-EPADLTC3026_DFM10-EPAD_LTC3026LTC3026U7
DFM10-EPADLTC3026_DFM10-EPAD_LTC3026LTC3026U8
DFM10-EPADLTC3026_DFM10-EPAD_LTC3026LTC3026U9
QFN-64_9MMX9MMLTC2978_9X9_QFN_UP_2_QFN-64_9MMLTC2978U10
QFN-64_9MMX9MMLTC2978_9X9_QFN_UP_2_QFN-64_9MMLTC2978U11
QSOP16MAX1619_QSOP16_MAX1619MAX1619U12
DCUTXS0102_DCU_TXS0102TXS0102U13
LQFP-32FT245BL_LQFP-32_FT245BLFT245BLU14
MSOP8-EPADLT3010_1_MSOP8-EPAD_LT3010LT3010U15
M100EPM240M100_M100_EPM570M100EPM570M100U16
SOT23-6SN65220_SOT23-6_SN65220SN65220U17
SOIC8P150W93LC46B_SO_0_SOIC8P150W_93LC64B93LC64B_SOU18
256FBGAEPM1270_5_256FBGA_EPM2210_256FBEPM2210_256FBGAU19
F64_10X13PC28F00AP30BF_F64_10X13_PC28F00PC28F00AP30BFU21
BCC9688E1111_BCC96_88E111188E1111U22
SOEIAJ16_SO16FMC14490_SOEIAJ16_SO16F_MC14490MC14490U24
FINISAR_XFP_30XFP_CON_CAGE_FINISAR_XFP_30_XFPXFP_CON_CAGEU25
SOT23-8MAX3372EEKA_0_SOT23-8_MAX3373MAX3373U26
SOT23-8MAX3372EEKA_0_SOT23-8_MAX3373MAX3373U27
EP5SGXA7K1F1517EP5SGXA7K1F1517_EP5SGXA7K1F1517EP5SGXA7K1F1517U29
TSSOP16ICS557-03_TSSOP16_ICS557-03ICS557-03U30
SOIC-8ICS8304_SOIC-8_ICS8304ICS8304U31
VFQFPN-28IDT5T9306_VFQFPN-28_IDT5T9306IDT5T9306U32
VFQFPN-28IDT5T9306_VFQFPN-28_IDT5T9306IDT5T9306U33
VFQFPN-28IDT5T9306_VFQFPN-28_IDT5T9306IDT5T9306U34
VFQFPN-28IDT5T9306_VFQFPN-28_IDT5T9306IDT5T9306U35
MSOP-10TS5A23157_MSOP-10_TS5A23157TS5A23157U36
SOIC-1474LS07_SOIC-14_74LS0774LS07U37
SOIC-1474LS07_SOIC-14_74LS0774LS07U38
XTLSMD_CSM7CRYSTAL_XTLSMD_CSM7_6MHZ6MHZX1
XTAL_PACK_DXTAL_XTAL_PACK_D_25MHZ25MHzX2
OSC_SMD_4PIN_25X2CRYSTAL4PIN_OSC_SMD_4PIN_25X2_ABM10-25MHzX3
XTAL_SG310OSC_ALT_XTAL_SG310_24MHZ24MHzY1
OSC4PSMTCTS_CB3LV_OSC4PSMT_CTS_CB3LVCTS_CB3LVY2
OSC_SMD_8PIN_7X5OSC_SI570_OSC_SMD_8PIN_7X5_SI57Si570Y3
OSC_SMD_8PIN_7X5OSC_SI570_OSC_SMD_8PIN_7X5_SI57Si570Y4
OSC_SMD_8PIN_7X5OSC_SI570_OSC_SMD_8PIN_7X5_SI57Si570Y5
OSC_SMD_8PIN_7X5OSC_SI570_OSC_SMD_8PIN_7X5_SI57Si570Y6
重要提示:PCB作品文件展下载说明
    发表于 2018-12-10 07:58:26 | 显示全部楼层
    PADS-180606高级班
    终身成就奖特殊贡献奖原创先锋奖优秀斑竹奖金点子奖
    发表于 2018-12-10 08:12:41 | 显示全部楼层
    4 天前
  • 签到天数: 188 天
    发表于 2018-12-10 08:28:13 | 显示全部楼层
    昨天 08:17
  • 签到天数: 256 天
    发表于 2018-12-10 21:37:26 | 显示全部楼层
    发表于 2021-10-11 12:29:12 | 显示全部楼层
  • 签到天数: 11 天
    终身成就奖社区居民忠实会员社区劳模最爱沙发优秀斑竹奖
    发表于 2021-10-12 10:21:28 | 显示全部楼层
    社区居民终身成就奖特殊贡献奖原创先锋奖
    发表于 2021-10-12 10:29:31 | 显示全部楼层
    非常感谢楼主大神分享
