查看: 3108|回复: 15
[Allegro16.6以下] DSP_Development_Kit,_Stratix_III_Edition 开发板原理图PCB
发表于 2018-12-10 06:42:42 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
35 REVC DSP_Development_Kit,_Stratix_III_Edition.zip (9.23 MB, 下载次数: 0)
Bill of MaterialReport
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_TOLCOMP_CLASSREFDES
603CAP_0603_0.1UF0.1uf ICC1
603CAP_0603_0.1UF0.1uf ICC2
603CAP_0603_0.1UF0.1uf ICC3
603CAP_0603_0.1UF0.1uf ICC4
603CAP_0603_0.1UF0.1uf ICC5
603CAP_0603_5PF5pF ICC6
603CAP_0603_0.1UF0.1uf ICC7
805CAP_0805_10UF10uF ICC8
603CAP_0603_0.1UF0.1uf ICC9
603CAP_0603_0.1UF0.1uf ICC10
603CAP_0603_0.1UF0.1uf ICC11
603CAP_0603_0.1UF0.1uf ICC12
603CAP_0603_0.1UF0.1uf ICC13
603CAP_0603_1.0NF1.0nF ICC14
603CAP_0603_1.0NF1.0nF ICC15
603CAP_0603_1.0NF1.0nF ICC16
603CAP_0603_1.0NF1.0nF ICC17
603CAP_0603_1.0NF1.0nF ICC18
805CAP_0805_10UF10uF ICC19
603CAP_0603_0.1UF0.1uf ICC20
603CAP_0603_0.1UF0.1uf ICC21
603CAP_0603_1.0NF1.0nF ICC22
603CAP_0603_1.0NF1.0nF ICC23
603CAP_0603_0.1UF0.1uf ICC24
603CAP_0603_0.1UF0.1uf ICC25
603CAP_0603_0.1UF0.1uf ICC26
603CAP_0603_0.1UF0.1uf ICC27
603CAP_0603_0.1UF0.1uf ICC28
603CAP_0603_5PF5pF ICC29
603CAP_0603_0.1UF0.1uf ICC30
805CAP_0805_10UF10uF ICC31
603CAP_0603_0.1UF0.1uf ICC32
603CAP_0603_0.1UF0.1uf ICC33
603CAP_0603_0.1UF0.1uf ICC34
603CAP_0603_0.1UF0.1uf ICC35
603CAP_0603_0.1UF0.1uf ICC36
603CAP_0603_1.0NF1.0nF ICC37
603CAP_0603_1.0NF1.0nF ICC38
603CAP_0603_1.0NF1.0nF ICC39
603CAP_0603_1.0NF1.0nF ICC40
603CAP_0603_1.0NF1.0nF ICC41
805CAP_0805_10UF10uF ICC42
603CAP_0603_0.1UF0.1uf ICC43
603CAP_0603_0.1UF0.1uf ICC44
603CAP_0603_1.0NF1.0nF ICC45
603CAP_0603_1.0NF1.0nF ICC46
603CAP_0603_10PF10pf ICC47
603CAP_0603_10PF10pf ICC48
603CAP_0603_0.1UF0.1uf ICC49
603CAP_0603_0.1UF0.1uf ICC50
603CAP_0603_10PF10pf ICC51
603CAP_0603_10PF10pf ICC52
603CAP_0603_0.1UF0.1uf ICC53
603CAP_0603_0.1UF0.1uf ICC54
603CAP_0603_0.1UF0.1uf ICC55
603CAP_0603_0.47UF0.47uf ICC56
603CAP_0603_0.47UF0.47uf ICC57
603CAP_0603_1.0NF1.0nF ICC58
603CAP_0603_0.1UF0.1uf ICC59
805CAP_0805_10UF10uF ICC60
603CAP_0603_0.1UF0.1uf ICC61
805CAP_0805_10UF10uF ICC62
603CAP_0603_0.47UF0.47uf ICC63
603CAP_0603_0.47UF0.47uf ICC64
603CAP_0603_1.0NF1.0nF ICC65
603CAP_0603_0.1UF0.1uf ICC66
805CAP_0805_10UF10uF ICC67
CAP_SMD_6_3MMPCAP_CAP_SMD_6_3MM_220UF220uF ICC68
CAP_SMD_6_3MMPCAP_CAP_SMD_6_3MM_220UF220uF ICC69
603CAP_0603_0.1UF0.1uf ICC70
CAP_SMD_6_3MMPCAP_CAP_SMD_6_3MM_220UF220uF ICC72
805CAP_0805_1.0UF1.0uf ICC73
603CAP_0603_0.1UF0.1uf ICC74
805CAP_0805_1.0UF1.0uf ICC75
805CAP_0805_1.0UF1.0uf ICC76
603CAP_0603_0.1UF0.1uf ICC77
603CAP_0603_1.0NF1.0nF ICC78
805CAP_0805_10UF10uF ICC79
CAP_SMD_6_3MMPCAP_CAP_SMD_6_3MM_220UF220uF ICC81
805CAP_0805_1.0UF1.0uf ICC82
603CAP_0603_0.1UF0.1uf ICC83
805CAP_0805_1.0UF1.0uf ICC84
805CAP_0805_1.0UF1.0uf ICC85
603CAP_0603_0.1UF0.1uf ICC86
603CAP_0603_1.0NF1.0nF ICC87
805CAP_0805_10UF10uF ICC88
CAP_SMD_6_3MMPCAP_CAP_SMD_6_3MM_220UF220uF ICC90
805CAP_0805_1.0UF1.0uf ICC91
805CAP_0805_1.0UF1.0uf ICC92
805CAP_0805_1.0UF1.0uf ICC93
603CAP_0603_0.1UF0.1uf ICC94
603CAP_0603_1.0NF1.0nF ICC95
603CAP_0603_0.1UF0.1uf ICC96
805CAP_0805_10UF10uF ICC97
805CAP_0805_10UF10uF ICC98
603CAP_0603_0.1UF0.1uf ICC99
603CAP_0603_1.0NF1.0nF ICC100
603CAP_0603_0.1UF0.1uf ICC101
603CAP_0603_1.0NF1.0nF ICC102
603CAP_0603_0.1UF0.1uf ICC103
603CAP_0603_1.0NF1.0nF ICC104
603CAP_0603_0.1UF0.1uf ICC105
603CAP_0603_1.0NF1.0nF ICC106
805CAP_0805_1.0UF1.0uf ICC107
603CAP_0603_47P47p ICC108
FUSE_SMTFUSE_FUSE_SMT_FUSE_BLOCK_7AMPFuse_Block_7AMP ICF1
FUSE_SMTFUSE_FUSE_SMT_FUSE_BLOCK_7AMPFuse_Block_7AMP ICF2
FUSE_SMTFUSE_FUSE_SMT_FUSE_BLOCK_7AMPFuse_Block_7AMP ICF3
SAMTEC_QTHDP120CUSTOMQTH_HSM_SAMTEC_QTHDP120CUSTOM_QQTH_HSM ICJ1
2X1VH2X1_2X1VH_2X1HEADER,CONN_22X1Header,CONN_2 ICJ2
2X3VH2X3_2X3VH_2X3HEADER2x3Header ICJ3
SMA_LTI_SASF54GTSMA_SMA_LTI_SASF54GT_LTI-SASF54LTI-SASF54GT ICJ4
2X1VH2X1_2X1VH_2X1HEADER,CONN_22X1Header,CONN_2 ICJ6
2X3VH2X3_2X3VH_2X3HEADER2x3Header ICJ7
SMA_LTI_SASF54GTSMA_SMA_LTI_SASF54GT_LTI-SASF54LTI-SASF54GT ICJ8
2X1VH2X1_2X1VH_2X1HEADER,CONN_22X1Header,CONN_2 ICJ10
2X1VH2X1_2X1VH_2X1HEADER,CONN_22X1Header,CONN_2 ICJ11
SMA_LTI_SASF54GTSMA_SMA_LTI_SASF54GT_LTI-SASF54LTI-SASF54GT ICJ12
2X1VH2X1_2X1VH_2X1HEADER,CONN_22X1Header,CONN_2 ICJ13
SMA_LTI_SASF54GTSMA_SMA_LTI_SASF54GT_LTI-SASF54LTI-SASF54GT ICJ14
2X3VH2X3_2X3VH_2X3HEADER2x3Header ICJ15
2X3VH2X3_2X3VH_2X3HEADER2x3Header ICJ17
SJ3515STEREO_JACK_SJ3515_SJ_3515NSJ_3515N ICJ19
SJ3515STEREO_JACK_SJ3515_SJ_3515NSJ_3515N ICJ20
SJ3515STEREO_JACK_SJ3515_SJ_3515NSJ_3515N ICJ21
2X3VH2X3_2X3VH_2X3HEADER2x3Header ICJ23
SMA_LTI_SASF54GTSMA_SMA_LTI_SASF54GT_LTI-SASF54LTI-SASF54GT ICJ25
SMA_LTI_SASF54GTSMA_SMA_LTI_SASF54GT_LTI-SASF54LTI-SASF54GT ICJ26
SMA_LTI_SASF54GTSMA_SMA_LTI_SASF54GT_LTI-SASF54LTI-SASF54GT ICJ28
SMA_LTI_SASF54GTSMA_SMA_LTI_SASF54GT_LTI-SASF54LTI-SASF54GT ICJ30
1X1VHTEST_POINT_1X1VH_TEST_HEADERTest_Header ICJ31
1X1VHTEST_POINT_1X1VH_TEST_HEADERTest_Header ICJ32
1X1VHTEST_POINT_1X1VH_TEST_HEADERTest_Header ICJ33
1X1VHTEST_POINT_1X1VH_TEST_HEADERTest_Header ICJ34
1X1VHTEST_POINT_1X1VH_TEST_HEADERTest_Header ICJ35
1X1VHTEST_POINT_1X1VH_TEST_HEADERTest_Header ICJ38
1X1VHTEST_POINT_1X1VH_TEST_HEADERTest_Header ICJ39
1X1VHTEST_POINT_1X1VH_TEST_HEADERTest_Header ICJ40
1X1VHTEST_POINT_1X1VH_TEST_HEADERTest_Header ICJ41
SJ3515STEREO_JACK_SJ3515_SJ_3515NSJ_3515N ICJ42
805INDUCTOR_0805_120OHM,800MA120ohm, 800mA ICL3
603RESISTOR_0402_0603_49.949.9 ICR1
603RESISTOR_0402_0603_100100 ICR2
603RESISTOR_0402_0603_10K10K ICR3
603RESISTOR_0603_1.00K,1%1.00K, 1% ICR4
603RESISTOR_0603_00 ICR5
603RESISTOR_0603_1.00K,1%1.00K, 1% ICR6
603RESISTOR_0603_33.2R,1%33.2R, 1% ICR7
603RESISTOR_0402_0603_49.949.9 ICR8
603RESISTOR_0603_33.2R,1%33.2R, 1% ICR9
603RESISTOR_0402_0603_49.949.9 ICR10
603RESISTOR_0402_0603_100100 ICR11
603RESISTOR_0402_0603_10K10K ICR12
603RESISTOR_0603_1.00K,1%1.00K, 1% ICR13
603RESISTOR_0603_00 ICR14
603RESISTOR_0603_1.00K,1%1.00K, 1% ICR15
603RESISTOR_0603_33.2R,1%33.2R, 1% ICR16
603RESISTOR_0402_0603_49.949.9 ICR17
603RESISTOR_0603_33.2R,1%33.2R, 1% ICR18
603RESISTOR_0402_0603_49.949.9 ICR19
603RESISTOR_0402_0603_100100 ICR20
603RESISTOR_0402_0603_49.949.9 ICR21
603RESISTOR_0402_0603_49.949.9 ICR22
603RESISTOR_0603_2K2K ICR23
603RESISTOR_0402_0603_100100 ICR24
603RESISTOR_0402_0603_49.949.9 ICR25
603RESISTOR_0603_2K2K ICR26
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR27
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR28
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR29
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR30
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR31
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR32
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR33
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR34
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR35
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR36
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR37
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR38
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR39
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR40
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR41
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR42
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR43
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR44
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR45
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR46
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR47
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR48
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR49
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR50
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR51
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR52
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR53
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR54
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR55
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR56
603RESISTOR_0603_4.70K,1%4.70K, 1% ICR57
603RESISTOR_0603_4.70K,1%4.70K, 1% ICR58
603RESISTOR_0603_4.70K,1%4.70K, 1% ICR59
603RESISTOR_0603_4.70K,1%4.70K, 1% ICR60
603RESISTOR_0603_4.70K,1%4.70K, 1% ICR61
603RESISTOR_0603_4.70K,1%4.70K, 1% ICR62
603RESISTOR_0603_4.70K,1%4.70K, 1% ICR63
603RESISTOR_0603_4.70K,1%4.70K, 1% ICR64
603RESISTOR_0402_0603_100100 ICR65
603RESISTOR_0402_0603_100100 ICR66
603RESISTOR_0603_47.5K1%47.5K 1% ICR67
603RESISTOR_0603_47.5K1%47.5K 1% ICR68
603RESISTOR_0603_47.5K1%47.5K 1% ICR69
603RESISTOR_0603_47.5K1%47.5K 1% ICR70
603RESISTOR_0402_0603_100100 ICR71
603RESISTOR_0402_0603_100100 ICR72
603RESISTOR_0402_0603_100100 ICR73
603RESISTOR_0402_0603_100100 ICR74
603RESISTOR_0603_1.00K,1%1.00K, 1% ICR75
603RESISTOR_0603_1.00K,1%1.00K, 1% ICR76
603RESISTOR_0603_1.00K,1%1.00K, 1% ICR78
WSL2010RESISTOR_WSL2010_NL-0.006NL-0.006 ICR80
WSL2010RESISTOR_WSL2010_00 ICR81
603RESISTOR_0603_576, 1%576, 1% ICR82
WSL2010RESISTOR_WSL2010_NL-0.006NL-0.006 ICR83
603RESISTOR_0603_1.00K,1%1.00K, 1% ICR85
603RESISTOR_0603_931, 1%931, 1% ICR87
603RESISTOR_0603_1.00K,1%1.00K, 1% ICR89
WSL2010RESISTOR_WSL2010_NL-0.006NL-0.006 ICR91
WSL2010RESISTOR_WSL2010_00 ICR92
603RESISTOR_0603_2.05K1%2.05K 1% ICR93
WSL2010RESISTOR_WSL2010_NL-0.006NL-0.006 ICR94
603RESISTOR_0603_1.00K,1%1.00K, 1% ICR95
603RESISTOR_0603_1.00K,1%1.00K, 1% ICR97
603RESISTOR_0603_NL-1.00K,1%NL-1.00K, 1% ICR98
603RESISTOR_0603_NL-1.00K,1%NL-1.00K, 1% ICR99
603RESISTOR_0603_NL-1.00K,1%NL-1.00K, 1% ICR100
603RESISTOR_0603_1.00K,1%1.00K, 1% ICR101
603RESISTOR_0603_1.00K,1%1.00K, 1% ICR102
603RESISTOR_0603_1.00K,1%1.00K, 1% ICR103
603RESISTOR_0402_0603_00 ICR104
603RESISTOR_0402_0603_00 ICR105
603RESISTOR_0603_10.0K,1%10.0K, 1% ICR106
603RESISTOR_0603_4.70K,1%4.70K, 1% ICR107
603RESISTOR_0603_10.0K,1%10.0K, 1% ICR108
603RESISTOR_0402_0603_00 ICR109
603RESISTOR_0402_0603_00 ICR110
603RESISTOR_0402_0603_00 ICR111
603RESISTOR_0402_0603_00 ICR112
603RESISTOR_0402_0603_100100 ICR113
603RESISTOR_0402_0603_1K1K ICR114
603RESISTOR_0402_0603_1K1K ICR115
603RESISTOR_0603_NL-0RNL-0R ICR116
603RESISTOR_0603_0R0R ICR117
603RESISTOR_0603_NL-0RNL-0R ICR118
603RESISTOR_0603_0R0R ICR119
603RESISTOR_0603_NL-0RNL-0R ICR120
603RESISTOR_0603_0R0R ICR121
603RESISTOR_0603_NL-0RNL-0R ICR122
603RESISTOR_0603_0R0R ICR123
RES_PACK_8RES_PACK_8_RES_PACK_8_00 ICRN1
RES_PACK_8RES_PACK_8_RES_PACK_8_00 ICRN2
RES_PACK_8RES_PACK_8_RES_PACK_8_00 ICRN3
RES_PACK_8RES_PACK_8_RES_PACK_8_00 ICRN4
KK81TRFMRTT1-6-KK81_KK81_TT1_6_KK8TT1_6_KK81 ICT1
KK81TRFMRTT1-6-KK81_KK81_TT1_6_KK8TT1_6_KK81 ICT2
KK81TRFMRTT1-6-KK81_KK81_TT1_6_KK8TT1_6_KK81 ICT3
KK81TRFMRTT1-6-KK81_KK81_TT1_6_KK8TT1_6_KK81 ICT4
KK81TRFMRTT1-6-KK81_KK81_TT1_6_KK8TT1_6_KK81 ICT6
KK81TRFMRTT1-6-KK81_KK81_TT1_6_KK8TT1_6_KK81 ICT7
1X1VHTEST_POINT_1X1VH_TEST_HEADERTest_Header ICTP1
1X1VHTEST_POINT_1X1VH_TEST_HEADERTest_Header ICTP2
1X1VHTEST_POINT_1X1VH_TEST_HEADERTest_Header ICTP5
LFCSP48AD9254_LFCSP48_AD9254AD9254 ICU1
LFCSP48AD9254_LFCSP48_AD9254AD9254 ICU2
TQFP-48DAC5672IPFBR_1_TQFP-48_DAC5672IDAC5672IPFBR ICU3
M08AFIN1028_M08A_FIN1028FIN1028 ICU4
TSSOP-28AIC23_TSSOP-28_AIC23AIC23 ICU5
LTC-S8LT1963_LTC-S8_LT1963LT1963 ICU6
LTC-S8LT1963_LTC-S8_LT1963LT1963 ICU7
LTC-S8LT1963_LTC-S8_LT1963LT1963 ICU8
TSSOP16ICS854054_TSSOP16_ICS854054ICS854054 ICU9
TSSOP16ICS854054_TSSOP16_ICS854054ICS854054 ICU10
TSSOP16ICS854054_TSSOP16_ICS854054ICS854054 ICU11
TSSOP16ICS854054_TSSOP16_ICS854054ICS854054 ICU12
TSSOP16ICS854054_TSSOP16_ICS854054ICS854054 ICU13
TSSOP8IS24C_TSSOP8_IS24C02BIS24C02B ICU14
M08AFIN1027_M08A_FIN1027FIN1027 ICU15
[/hide]
重要提示:PCB作品文件展下载说明
PADS-180606高级班
终身成就奖特殊贡献奖原创先锋奖优秀斑竹奖金点子奖
发表于 2018-12-10 08:12:30 | 显示全部楼层
发表于 2018-12-10 08:47:39 | 显示全部楼层
    PADS20210122高级班
    发表于 2018-12-10 08:47:49 | 显示全部楼层
    发表于 2018-12-10 08:49:58 | 显示全部楼层
    5 天前
    发表于 2018-12-10 08:53:10 | 显示全部楼层
    发表于 2018-12-10 08:53:35 | 显示全部楼层
    发表于 2018-12-10 08:55:13 | 显示全部楼层
    社区居民终身成就奖优秀斑竹奖社区明星宣传大使奖特殊贡献奖原创先锋奖
    发表于 2018-12-10 08:55:41 | 显示全部楼层
    1元学习PADS(5期)
    发表于 2018-12-10 08:56:48 | 显示全部楼层
