查看: 1769|回复: 1
[Allegro16.6以下] DSP_Development_Kit,_Stratix_III_Edition DATACONVERSION 板原理图PCB
发表于 2018-12-10 06:44:00 | 显示全部楼层 |阅读模式
36 DATACONVERSION DSP_Development_Kit,_Stratix_III_Edition.zip (3.55 MB, 下载次数: 1)
Bill of MaterialReport
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_TOLCOMP_CLASSREFDES
603CAP_0603_0.1UF0.1uf ICC1
603CAP_0603_0.1UF0.1uf ICC2
603CAP_0603_0.1UF0.1uf ICC3
603CAP_0603_0.1UF0.1uf ICC4
603CAP_0603_0.1UF0.1uf ICC5
603CAP_0603_5PF5pF ICC6
603CAP_0603_0.1UF0.1uf ICC7
805CAP_0805_10UF10uF ICC8
603CAP_0603_0.1UF0.1uf ICC9
603CAP_0603_0.1UF0.1uf ICC10
603CAP_0603_0.1UF0.1uf ICC11
603CAP_0603_0.1UF0.1uf ICC12
603CAP_0603_0.1UF0.1uf ICC13
603CAP_0603_1.0NF1.0nF ICC14
603CAP_0603_1.0NF1.0nF ICC15
603CAP_0603_1.0NF1.0nF ICC16
603CAP_0603_1.0NF1.0nF ICC17
603CAP_0603_1.0NF1.0nF ICC18
805CAP_0805_10UF10uF ICC19
603CAP_0603_0.1UF0.1uf ICC20
603CAP_0603_0.1UF0.1uf ICC21
603CAP_0603_1.0NF1.0nF ICC22
603CAP_0603_1.0NF1.0nF ICC23
603CAP_0603_0.1UF0.1uf ICC24
603CAP_0603_0.1UF0.1uf ICC25
603CAP_0603_0.1UF0.1uf ICC26
603CAP_0603_0.1UF0.1uf ICC27
603CAP_0603_0.1UF0.1uf ICC28
603CAP_0603_5PF5pF ICC29
603CAP_0603_0.1UF0.1uf ICC30
805CAP_0805_10UF10uF ICC31
603CAP_0603_0.1UF0.1uf ICC32
603CAP_0603_0.1UF0.1uf ICC33
603CAP_0603_0.1UF0.1uf ICC34
603CAP_0603_0.1UF0.1uf ICC35
603CAP_0603_0.1UF0.1uf ICC36
603CAP_0603_1.0NF1.0nF ICC37
603CAP_0603_1.0NF1.0nF ICC38
603CAP_0603_1.0NF1.0nF ICC39
603CAP_0603_1.0NF1.0nF ICC40
603CAP_0603_1.0NF1.0nF ICC41
805CAP_0805_10UF10uF ICC42
603CAP_0603_0.1UF0.1uf ICC43
603CAP_0603_0.1UF0.1uf ICC44
603CAP_0603_1.0NF1.0nF ICC45
603CAP_0603_1.0NF1.0nF ICC46
603CAP_0603_10PF10pf ICC47
603CAP_0603_10PF10pf ICC48
603CAP_0603_0.1UF0.1uf ICC49
603CAP_0603_0.1UF0.1uf ICC50
603CAP_0603_10PF10pf ICC51
603CAP_0603_10PF10pf ICC52
603CAP_0603_0.1UF0.1uf ICC53
603CAP_0603_0.1UF0.1uf ICC54
603CAP_0603_0.1UF0.1uf ICC55
603CAP_0603_0.47UF0.47uf ICC56
603CAP_0603_0.47UF0.47uf ICC57
603CAP_0603_1.0NF1.0nF ICC58
603CAP_0603_0.1UF0.1uf ICC59
805CAP_0805_10UF10uF ICC60
603CAP_0603_0.1UF0.1uf ICC61
805CAP_0805_10UF10uF ICC62
603CAP_0603_0.47UF0.47uf ICC63
603CAP_0603_0.47UF0.47uf ICC64
603CAP_0603_1.0NF1.0nF ICC65
603CAP_0603_0.1UF0.1uf ICC66
805CAP_0805_10UF10uF ICC67
CAP_SMD_6_3MMPCAP_CAP_SMD_6_3MM_220UF220uF ICC68
CAP_SMD_6_3MMPCAP_CAP_SMD_6_3MM_220UF220uF ICC69
603CAP_0603_0.1UF0.1uf ICC70
CAP_SMD_6_3MMPCAP_CAP_SMD_6_3MM_220UF220uF ICC72
805CAP_0805_1.0UF1.0uf ICC73
603CAP_0603_0.1UF0.1uf ICC74
805CAP_0805_1.0UF1.0uf ICC75
805CAP_0805_1.0UF1.0uf ICC76
603CAP_0603_0.1UF0.1uf ICC77
603CAP_0603_1.0NF1.0nF ICC78
805CAP_0805_10UF10uF ICC79
CAP_SMD_6_3MMPCAP_CAP_SMD_6_3MM_220UF220uF ICC81
805CAP_0805_1.0UF1.0uf ICC82
603CAP_0603_0.1UF0.1uf ICC83
805CAP_0805_1.0UF1.0uf ICC84
805CAP_0805_1.0UF1.0uf ICC85
603CAP_0603_0.1UF0.1uf ICC86
603CAP_0603_1.0NF1.0nF ICC87
805CAP_0805_10UF10uF ICC88
CAP_SMD_6_3MMPCAP_CAP_SMD_6_3MM_220UF220uF ICC90
805CAP_0805_1.0UF1.0uf ICC91
805CAP_0805_1.0UF1.0uf ICC92
805CAP_0805_1.0UF1.0uf ICC93
603CAP_0603_0.1UF0.1uf ICC94
603CAP_0603_1.0NF1.0nF ICC95
603CAP_0603_0.1UF0.1uf ICC96
805CAP_0805_10UF10uF ICC97
805CAP_0805_10UF10uF ICC98
603CAP_0603_0.1UF0.1uf ICC99
603CAP_0603_1.0NF1.0nF ICC100
603CAP_0603_0.1UF0.1uf ICC101
603CAP_0603_1.0NF1.0nF ICC102
603CAP_0603_0.1UF0.1uf ICC103
603CAP_0603_1.0NF1.0nF ICC104
603CAP_0603_0.1UF0.1uf ICC105
603CAP_0603_1.0NF1.0nF ICC106
805CAP_0805_1.0UF1.0uf ICC107
603CAP_0603_47P47p ICC108
FUSE_SMTFUSE_FUSE_SMT_FUSE_BLOCK_7AMPFuse_Block_7AMP ICF1
FUSE_SMTFUSE_FUSE_SMT_FUSE_BLOCK_7AMPFuse_Block_7AMP ICF2
FUSE_SMTFUSE_FUSE_SMT_FUSE_BLOCK_7AMPFuse_Block_7AMP ICF3
SAMTEC_QTHDP120CUSTOMQTH_HSM_SAMTEC_QTHDP120CUSTOM_QQTH_HSM ICJ1
2X1VH2X1_2X1VH_2X1HEADER,CONN_22X1Header,CONN_2 ICJ2
2X3VH2X3_2X3VH_2X3HEADER2x3Header ICJ3
SMA_LTI_SASF54GTSMA_SMA_LTI_SASF54GT_LTI-SASF54LTI-SASF54GT ICJ4
2X1VH2X1_2X1VH_2X1HEADER,CONN_22X1Header,CONN_2 ICJ6
2X3VH2X3_2X3VH_2X3HEADER2x3Header ICJ7
SMA_LTI_SASF54GTSMA_SMA_LTI_SASF54GT_LTI-SASF54LTI-SASF54GT ICJ8
2X1VH2X1_2X1VH_2X1HEADER,CONN_22X1Header,CONN_2 ICJ10
2X1VH2X1_2X1VH_2X1HEADER,CONN_22X1Header,CONN_2 ICJ11
SMA_LTI_SASF54GTSMA_SMA_LTI_SASF54GT_LTI-SASF54LTI-SASF54GT ICJ12
2X1VH2X1_2X1VH_2X1HEADER,CONN_22X1Header,CONN_2 ICJ13
SMA_LTI_SASF54GTSMA_SMA_LTI_SASF54GT_LTI-SASF54LTI-SASF54GT ICJ14
2X3VH2X3_2X3VH_2X3HEADER2x3Header ICJ15
2X3VH2X3_2X3VH_2X3HEADER2x3Header ICJ17
SJ3515STEREO_JACK_SJ3515_SJ_3515NSJ_3515N ICJ19
SJ3515STEREO_JACK_SJ3515_SJ_3515NSJ_3515N ICJ20
SJ3515STEREO_JACK_SJ3515_SJ_3515NSJ_3515N ICJ21
2X3VH2X3_2X3VH_2X3HEADER2x3Header ICJ23
SMA_LTI_SASF54GTSMA_SMA_LTI_SASF54GT_LTI-SASF54LTI-SASF54GT ICJ25
SMA_LTI_SASF54GTSMA_SMA_LTI_SASF54GT_LTI-SASF54LTI-SASF54GT ICJ26
SMA_LTI_SASF54GTSMA_SMA_LTI_SASF54GT_LTI-SASF54LTI-SASF54GT ICJ28
SMA_LTI_SASF54GTSMA_SMA_LTI_SASF54GT_LTI-SASF54LTI-SASF54GT ICJ30
1X1VHTEST_POINT_1X1VH_TEST_HEADERTest_Header ICJ31
1X1VHTEST_POINT_1X1VH_TEST_HEADERTest_Header ICJ32
1X1VHTEST_POINT_1X1VH_TEST_HEADERTest_Header ICJ33
1X1VHTEST_POINT_1X1VH_TEST_HEADERTest_Header ICJ34
1X1VHTEST_POINT_1X1VH_TEST_HEADERTest_Header ICJ35
1X1VHTEST_POINT_1X1VH_TEST_HEADERTest_Header ICJ38
1X1VHTEST_POINT_1X1VH_TEST_HEADERTest_Header ICJ39
1X1VHTEST_POINT_1X1VH_TEST_HEADERTest_Header ICJ40
1X1VHTEST_POINT_1X1VH_TEST_HEADERTest_Header ICJ41
SJ3515STEREO_JACK_SJ3515_SJ_3515NSJ_3515N ICJ42
805INDUCTOR_0805_120OHM,800MA120ohm, 800mA ICL3
603RESISTOR_0402_0603_49.949.9 ICR1
603RESISTOR_0402_0603_100100 ICR2
603RESISTOR_0402_0603_10K10K ICR3
603RESISTOR_0603_1.00K,1%1.00K, 1% ICR4
603RESISTOR_0603_00 ICR5
603RESISTOR_0603_1.00K,1%1.00K, 1% ICR6
603RESISTOR_0603_33.2R,1%33.2R, 1% ICR7
603RESISTOR_0402_0603_49.949.9 ICR8
603RESISTOR_0603_33.2R,1%33.2R, 1% ICR9
603RESISTOR_0402_0603_49.949.9 ICR10
603RESISTOR_0402_0603_100100 ICR11
603RESISTOR_0402_0603_10K10K ICR12
603RESISTOR_0603_1.00K,1%1.00K, 1% ICR13
603RESISTOR_0603_00 ICR14
603RESISTOR_0603_1.00K,1%1.00K, 1% ICR15
603RESISTOR_0603_33.2R,1%33.2R, 1% ICR16
603RESISTOR_0402_0603_49.949.9 ICR17
603RESISTOR_0603_33.2R,1%33.2R, 1% ICR18
603RESISTOR_0402_0603_49.949.9 ICR19
603RESISTOR_0402_0603_100100 ICR20
603RESISTOR_0402_0603_49.949.9 ICR21
603RESISTOR_0402_0603_49.949.9 ICR22
603RESISTOR_0603_2K2K ICR23
603RESISTOR_0402_0603_100100 ICR24
603RESISTOR_0402_0603_49.949.9 ICR25
603RESISTOR_0603_2K2K ICR26
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR27
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR28
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR29
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR30
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR31
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR32
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR33
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR34
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR35
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR36
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR37
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR38
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR39
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR40
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR41
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR42
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR43
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR44
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR45
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR46
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR47
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR48
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR49
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR50
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR51
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR52
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR53
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR54
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR55
603RESISTOR_0402_0603_NL-49.9NL-49.9 ICR56
603RESISTOR_0603_4.70K,1%4.70K, 1% ICR57
603RESISTOR_0603_4.70K,1%4.70K, 1% ICR58
603RESISTOR_0603_4.70K,1%4.70K, 1% ICR59
603RESISTOR_0603_4.70K,1%4.70K, 1% ICR60
603RESISTOR_0603_4.70K,1%4.70K, 1% ICR61
603RESISTOR_0603_4.70K,1%4.70K, 1% ICR62
603RESISTOR_0603_4.70K,1%4.70K, 1% ICR63
603RESISTOR_0603_4.70K,1%4.70K, 1% ICR64
603RESISTOR_0402_0603_100100 ICR65
603RESISTOR_0402_0603_100100 ICR66
603RESISTOR_0603_47.5K1%47.5K 1% ICR67
603RESISTOR_0603_47.5K1%47.5K 1% ICR68
603RESISTOR_0603_47.5K1%47.5K 1% ICR69
603RESISTOR_0603_47.5K1%47.5K 1% ICR70
603RESISTOR_0402_0603_100100 ICR71
603RESISTOR_0402_0603_100100 ICR72
603RESISTOR_0402_0603_100100 ICR73
603RESISTOR_0402_0603_100100 ICR74
603RESISTOR_0603_1.00K,1%1.00K, 1% ICR75
603RESISTOR_0603_1.00K,1%1.00K, 1% ICR76
603RESISTOR_0603_1.00K,1%1.00K, 1% ICR78
WSL2010RESISTOR_WSL2010_NL-0.006NL-0.006 ICR80
WSL2010RESISTOR_WSL2010_00 ICR81
603RESISTOR_0603_576, 1%576, 1% ICR82
WSL2010RESISTOR_WSL2010_NL-0.006NL-0.006 ICR83
603RESISTOR_0603_1.00K,1%1.00K, 1% ICR85
603RESISTOR_0603_931, 1%931, 1% ICR87
603RESISTOR_0603_1.00K,1%1.00K, 1% ICR89
WSL2010RESISTOR_WSL2010_NL-0.006NL-0.006 ICR91
WSL2010RESISTOR_WSL2010_00 ICR92
603RESISTOR_0603_2.05K1%2.05K 1% ICR93
WSL2010RESISTOR_WSL2010_NL-0.006NL-0.006 ICR94
603RESISTOR_0603_1.00K,1%1.00K, 1% ICR95
603RESISTOR_0603_1.00K,1%1.00K, 1% ICR97
603RESISTOR_0603_NL-1.00K,1%NL-1.00K, 1% ICR98
603RESISTOR_0603_NL-1.00K,1%NL-1.00K, 1% ICR99
603RESISTOR_0603_NL-1.00K,1%NL-1.00K, 1% ICR100
603RESISTOR_0603_1.00K,1%1.00K, 1% ICR101
603RESISTOR_0603_1.00K,1%1.00K, 1% ICR102
603RESISTOR_0603_1.00K,1%1.00K, 1% ICR103
603RESISTOR_0402_0603_00 ICR104
603RESISTOR_0402_0603_00 ICR105
603RESISTOR_0603_10.0K,1%10.0K, 1% ICR106
603RESISTOR_0603_4.70K,1%4.70K, 1% ICR107
603RESISTOR_0603_10.0K,1%10.0K, 1% ICR108
603RESISTOR_0402_0603_00 ICR109
603RESISTOR_0402_0603_00 ICR110
603RESISTOR_0402_0603_00 ICR111
603RESISTOR_0402_0603_00 ICR112
603RESISTOR_0402_0603_100100 ICR113
603RESISTOR_0402_0603_1K1K ICR114
603RESISTOR_0402_0603_1K1K ICR115
603RESISTOR_0603_NL-0RNL-0R ICR116
603RESISTOR_0603_0R0R ICR117
603RESISTOR_0603_NL-0RNL-0R ICR118
603RESISTOR_0603_0R0R ICR119
603RESISTOR_0603_NL-0RNL-0R ICR120
603RESISTOR_0603_0R0R ICR121
603RESISTOR_0603_NL-0RNL-0R ICR122
603RESISTOR_0603_0R0R ICR123
RES_PACK_8RES_PACK_8_RES_PACK_8_00 ICRN1
RES_PACK_8RES_PACK_8_RES_PACK_8_00 ICRN2
RES_PACK_8RES_PACK_8_RES_PACK_8_00 ICRN3
RES_PACK_8RES_PACK_8_RES_PACK_8_00 ICRN4
KK81TRFMRTT1-6-KK81_KK81_TT1_6_KK8TT1_6_KK81 ICT1
KK81TRFMRTT1-6-KK81_KK81_TT1_6_KK8TT1_6_KK81 ICT2
KK81TRFMRTT1-6-KK81_KK81_TT1_6_KK8TT1_6_KK81 ICT3
KK81TRFMRTT1-6-KK81_KK81_TT1_6_KK8TT1_6_KK81 ICT4
KK81TRFMRTT1-6-KK81_KK81_TT1_6_KK8TT1_6_KK81 ICT6
KK81TRFMRTT1-6-KK81_KK81_TT1_6_KK8TT1_6_KK81 ICT7
1X1VHTEST_POINT_1X1VH_TEST_HEADERTest_Header ICTP1
1X1VHTEST_POINT_1X1VH_TEST_HEADERTest_Header ICTP2
1X1VHTEST_POINT_1X1VH_TEST_HEADERTest_Header ICTP5
LFCSP48AD9254_LFCSP48_AD9254AD9254 ICU1
LFCSP48AD9254_LFCSP48_AD9254AD9254 ICU2
TQFP-48DAC5672IPFBR_1_TQFP-48_DAC5672IDAC5672IPFBR ICU3
M08AFIN1028_M08A_FIN1028FIN1028 ICU4
TSSOP-28AIC23_TSSOP-28_AIC23AIC23 ICU5
LTC-S8LT1963_LTC-S8_LT1963LT1963 ICU6
LTC-S8LT1963_LTC-S8_LT1963LT1963 ICU7
LTC-S8LT1963_LTC-S8_LT1963LT1963 ICU8
TSSOP16ICS854054_TSSOP16_ICS854054ICS854054 ICU9
TSSOP16ICS854054_TSSOP16_ICS854054ICS854054 ICU10
TSSOP16ICS854054_TSSOP16_ICS854054ICS854054 ICU11
TSSOP16ICS854054_TSSOP16_ICS854054ICS854054 ICU12
TSSOP16ICS854054_TSSOP16_ICS854054ICS854054 ICU13
TSSOP8IS24C_TSSOP8_IS24C02BIS24C02B ICU14
M08AFIN1027_M08A_FIN1027FIN1027 ICU15
[/hide]
评分
参与人数 1威望 -7 收起 理由
老吴 -7 自己重复了,两个版本看不出任何区别 http://bbs.ntpcb.com/r
查看全部评分
发表于 2018-12-15 23:48:34 | 显示全部楼层
公告:服务器刚移机,
大家请不要下载东西。
会下载失败
