查看: 8479|回复: 17
[Allegro16.6以下] TMS320C6678评估板原理图PCB
终身成就奖原创先锋奖特殊贡献奖优秀斑竹奖金点子奖
发表于 2018-12-15 04:41:05 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
Qty
Ref Des
Part Description
Manufacturer
FAN2
FAN0.09 12V 7000PRM 35x35x10mm AFB03512HAL=10cm
Delta Electronics, Inc.
POST1,POST2,POST3,POST4
POST F=M3*11L B=5 H=11 Cu
POST5,POST6
Post F=M3x23L D=5 H=23 CU for DSPM-8301E
SCREW5,SCREW6
F/S D=5.6 H=1.0 +M M3*4L ST/H Ni NK
SCREW9,SCREW10
Screw F/S D=3.5 H=0.7 + T2x4L ST BLK None
SCREW11,SCREW12
S/S D=5 H=1.3 + M3*15L ST Ni
SCREW1,SCREW2,SCREW3,SCREW4
R/S D=5.5 H=2 + M3*5L ST Ni
HEATSINK1
Heatsink O-TMX320TCI6608CYP S-16W 42x36x17-PP
Fever Technology Co., Ltd.
HYPERLINK1
Conn. 36P 90D(F) 76867-0011
Molex Taiwan Ltd.
RST_COLD1,RST_FULL1,RST_WARM1
PUSH SW HDK632AR-ST DIP 2P L=3.85mm
LAN1
PHONE JACK RJ45 17P 90D(F) DIP101112FHBMAM404ZA
DC_IN1
POWER JACK 3P 2.5mm 90D(M) DIP2DC-0005B100
COM_SEL1
PIN HEADER 3x2P 2.54mm 180D(M) DIP201-2*3GS
560V2_PWR1
PIN HEADER 4x2P 2.54mm 180D(M) DIP201-2*4GS
PMBUS1
PIN HEADER 5x1P 2.54mm 180D(M) DIP21N12564
TAP_FPGA1
PIN HEADER 8x1P 2.54mm 180D DIP YP91-01104-08B1
COM_SEL1(1-3),COM_SEL1(2-4)
MINI JUMPER 2P 2.54mm 180D(F) 1132-040-02
USB1
USB Conn. 5P 90D(F) DIP UH11543-H6-4F
COM1
Wafer 2.54mm 3P 180D(M) DIP W/LOCK22-27-2031
SBW_MMC1
WAFER 4P 2.54mm 180D(M) DIP 2542A-WS-4
FAN1
WAFER BOX 3P 2.0mm 180D(M) DIP 2001-WS-3
R167,R473
CR 31.6K 1% 1/16W SMD 0402  RM04FTN3162
R171,R205
CR 56.2K 1% 1/16W SMD 0402 RM04FTN5622
R122
CR 8.06K 1% 1/16W SMD 0402 RM04FTN8061
R564
CR 931 1% 1/16W SMD 0402 RM04FTN9310
R302,R311
CR 33K 5% 1/16W SMD 0402 RM04JTN333
R131,R566
CR 2 1% 1/16W SMD 0402 RM04FTN2CR00
R58,R168,R170,R534,R535
CR 4.75K 1% 1/16W SMD 0402 RM04FTN4751
R18,R60,R72,R332
CR 4.99K 1% 1/16W SMD 0402 RM04FTN4991
R472
CR 1.87k 1% 1/10W SMD 0603 0603WAF1871T5E
R469
CR 45.3 1/16W 1% SMD 0402 RM04FTN45R3
R556,R557
CR 10M 5% 1/4W SMD 1206  232271161106L
104
R2,R6,R8,R15,R36,R42,R43,R44,R45,R46,R47,R49,R71,R85,R91,R92,R96,R100,R101,R102,R103,R105,R110,R113,R114,R116,R129,R137,R139,R141,R159,R161,R162,R163,R164,R175,R176,R178,R180,R185,R197,R204,R208,R229,R230,R233,R234,R266,R295,R308,R315,R318,R319,R327,R333,R334,R341,R348,R360,R367,R382,R388,R395,R399,R403,R409,R411,R412,R416,R425,R429,R435,R438,R439,R440,R454,R459,R460,R475,R476,R489,R490,R491,R492,R493,R494,R495,R496,R502,R509,R513,R514,R515,R516,R517,R518,R519,R520,R521,R527,R560,R561,R577,R578
CR 10K 1% 1/16W SMD 0402 RM04FTN1002
R293,R305,R448
CR 33 1% 1/16W SMD 0402 RM04FTN33R0
31
R78,R118,R134,R177,R329,R330,R340,R370,R377,R387,R396,R536,R537,R538,R539,R540,R541,R542,R543,R544,R545,R546,R547,R548,R549,R550,R551,R552,R553,R554,R565
CR 100 1% 1/16W SMD 0402 RM04FTN1000
24
R13,R67,R111,R127,R135,R143,R144,R165,R188,R213,R214,R217,R218,R320,R325,R346,R353,R365,R368,R386,R434,R436,R457,R555
CR 1K 1% 1/16W SMD 0402 RM04FTN1001
R66,R76,R256,R310,R385,R410
CR 100K 1% 1/16W SMD 0402 RM04FTN1003
R354
CR 1M 1% 1/10W SMD 0603 232270461005L
R458
CR 12.1K 1% 1/10W SMD 0603 0603WAF1212T5E
R456
CR 1.3K1% 1/10W  SMD 0603 232270461302L
R292,R304
CR 150 1% 1/16W SMD 0402 RM04FTN1500
R182,R474
CR 1.69K 1% 1/10W SMD 0603  232270461692L
R98,R99,R150,R238,R239,R306,R307
CR 2K 1% 1/16W SMD 0402 RM04FTN2001
R432,R468
CR 22.6K 1% 1/10W SMD 0603 232270462263L
R501,R503,R504,R505,R510
CR 240 1% 1/10W SMD 0603 RM06FTN2400
R123,R124,R378
CR 2.49K 1% 1/16W SMD 0402 RM04FTN2491
R147,R183
CR 28K 1% 1/10W SMD 0603  232270462803L
R81
CR 36.5K 1% 1/10W SMD 0603 WR06X3655FTL
R80
CR 39.2K 1% 1/10W SMD 0603 2322 70463923L
27
R212,R215,R216,R219,R220,R222,R223,R224,R225,R226,R228,R232,R488,R499,R500,R506,R507,R508,R511,R512,R522,R523,R528,R529,R531,R532,R559
CR 39.2 1% 1/16W SMD 0402 0402WGF392JTCE
R1
CR 475 1% 1/16W SMD 0402 0402WGF4750T5E
R400
CR 48.7K 1% 1/10W SMD 0603 0603WGF4872T5E
9
R3,R4,R7,R9,R16,R21,R57,R64,R68
CR 49.9 1% 1/16W SMD 0402 RM04FTN49R9
R148,R184
CR 56.2K 1% 1/10W SMD 0603 232270465623L
R471
CR 9.09K 1% 1/10W SMD 0603 232270469092L
41
R19,R35,R37,R53,R54,R62,R63,R69,R82,R86,R104,R108,R119,R120,R128,R130,R136,R169,R186,R192,R231,R260,R263,R294,R296,R321,R328,R356,R380,R383,R384,R390,R391,R392,R393,R397,R430,R441,R463,R563,R567
CR 0 5% 1/16W SMD 0402  RM04JTN0
R121
CR 0 5% 1/10W SMD 0603 RM06JTN0
70
R24,R31,R32,R33,R34,R59,R65,R73,R74,R77,R84,R87,R89,R94,R95,R112,R115,R117,R126,R132,R133,R138,R146,R149,R152,R155,R156,R158,R160,R166,R221,R240,R241,R242,R243,R244,R245,R246,R247,R248,R249,R250,R251,R252,R253,R254,R255,R336,R337,R342,R345,R349,R351,R352,R355,R362,R363,R374,R405,R407,R428,R437,R446,R450,R451,R572,R573,R574,R575,R576
CR 10 5% 1/16W SMD 0402 RM04JTN100
R265,R298
CR 100 5% 1/16W SMD 0402 RM04JTN101
R498
CR 1K 5% 1/16W SMD 0402 RM04JTN102
R497,R524,R525,R530,R558
CR 100K 5% 1/16W SMD 0402 RM04JTN104
R93
CR 2.2K 5% 1/16W SMD 0402 RM04JTN222
14
R23,R196,R198,R199,R200,R202,R209,R210,R272,R314,R322,R324,R394,R419
CR 22 5% 1/16W SMD 0402 RM04JTN220
9
R56,R287,R288,R289,R290,R422,R442,R444,R467
CR 330 5% 1/16W SMD 0402 RM04JTN331
R299,R301,R317
CR 3.3K 5% 1/16W SMD 0402 0402WGJ0332TCE
R11,R61,R88,R366,R570,R571
CR 33 5% 1/16W SMD 0402 RM04JTN330
R10,R12,R17,R20,R22,R25,R26,R27,R28,R29,R30,R39,R40,R41,R51,R75,R79,R83,R140,R154,R157,R173,R174,R181,R187,R189,R190,R191,R194,R195,R201,R203,R206,R207,R211,R227,R235,R236,R237,R261,R262,R267,R269,R270,R271,R273,R274,R275,R276,R277,R278,R279,R280,R281,R282,R283,R285,R286,R323,R331,R338,R379,R398,R401,R402,R406,R417,R420,R424,R445,R464,R477,R478,R479,R480,R481,R482,R483,R484,R485,R486,R487
CR 4.7K 5% 1/16W SMD 0402 RM04JTN472
R90,R153,R193,R371
CR 8.2K 5% 1/16W SMD 0402 0402WGJ0822TCE
C416
MCC X7R 4.7uF 10% 16V SMD 1206C1206X475K016T
14
C40,C221,C256,C271,C272,C282,C285,C295,C316,C336,C392,C465,C491,C516
MLCC X5R 4.7uF 10% 6.3V SMD 0603GRM188R60J475K
C181,C365,C552
MLCC X7R 0.1uF 10% 50V SMD 0603C1608X7R1H104KT
C547,C551,C555,C559,C560
MLCC X5R 22uF 20% 6.3V SMD 0805C0805B226M007T
297
C2,C6,C7,C8,C13,C15,C16,C17,C18,C19,C20,C21,C22,C23,C24,C25,C26,C27,C30,C31,C32,C33,C34,C35,C36,C37,C38,C39,C42,C44,C48,C49,C50,C51,C53,C56,C57,C59,C61,C62,C63,C64,C65,C69,C71,C73,C74,C75,C76,C79,C80,C81,C83,C84,C85,C86,C87,C89,C91,C92,C94,C95,C96,C97,C98,C99,C100,C103,C108,C109,C110,C111,C112,C115,C117,C118,C121,C122,C128,C129,C133,C134,C136,C137,C141,C143,C144,C146,C147,C148,C149,C150,C151,C156,C157,C158,C159,C160,C161,C162,C163,C164,C165,C168,C169,C170,C172,C173,C175,C177,C180,C184,C185,C186,C187,C188,C190,C191,C195,C197,C198,C199,C201,C202,C203,C204,C205,C206,C208,C209,C210,C211,C212,C213,C214,C215,C216,C217,C218,C220,C225,C226,C228,C229,C230,C233,C236,C237,C238,C240,C241,C242,C243,C244,C245,C246,C248,C250,C251,C252,C255,C257,C259,C261,C263,C266,C268,C269,C270,C273,C274,C275,C276,C277,C278,C279,C283,C284,C286,C288,C290,C292,C293,C294,C297,C298,C299,C300,C301,C303,C304,C305,C306,C307,C308,C310,C311,C313,C317,C318,C322,C323,C328,C338,C341,C342,C343,C351,C356,C360,C361,C364,C366,C368,C372,C379,C380,C382,C390,C391,C397,C399,C400,C401,C404,C415,C417,C420,C422,C427,C429,C430,C432,C435,C436,C437,C445,C446,C457,C467,C474,C480,C482,C483,C484,C485,C486,C488,C490,C493,C496,C498,C500,C502,C503,C507,C508,C514,C515,C517,C518,C519,C521,C523,C524,C525,C526,C528,C529,C531,C532,C533,C534,C537,C538,C539,C540,C541,C542,C543,C548,C549,C550,C553,C556,C561,C562,C564,C565,C566,C568,C569,C570,C571,C576,C577,C578
MLCC X7R 0.1uF 10% 16V SMD 0402  2238 787 15649
C78,C387,C554
MLCC 1uF 10% 25V SMD 0603GRM188R61E105KA12D
22
C1,C4,C9,C10,C12,C14,C28,C29,C41,C145,C166,C183,C194,C196,C207,C219,C232,C234,C314,C315,C489,C495
MLCC X5R 1uF 10% 6.3V SMD 0402C1005X5R0J105KT
C124,C385
MLCC X5R 22uF 20% 16V SMD 1206KC30R1C226M-T
62
C125,C126,C224,C302,C321,C326,C330,C331,C334,C339,C340,C346,C347,C349,C354,C355,C357,C358,C359,C362,C367,C370,C377,C386,C388,C389,C393,C395,C398,C403,C407,C408,C418,C421,C424,C426,C428,C431,C434,C439,C443,C444,C449,C452,C453,C454,C455,C458,C459,C460,C461,C463,C472,C473,C475,C476,C477,C478,C479,C505,C506,C558
MLCC X7R 560pF 10% 50V SMD 0402223858715619
C82,C332,C333,C409,C410,C411,C412,C413,C414,C468,C469
MLCC X5R 47uF 20% 6.3V 0805CL21A476MQYNNNE
C231
MLCC X5R 0.47uF 10% 10V 0402 223824713658
C11,C55,C58,C77,C106,C116,C130,C131,C132,C138,C140,C167,C171,C178,C189,C192,C222,C223,C287,C327,C374,C470,C471,C497,C499,C530,C535,C536
MLCC X5R 10uF 20% 6.3V SMD 0603C1608X5R0J106MT
C119,C120,C239,C258,C352,C353,C423,C450,C494,C504,C512,C513
MLCC X5R 100uF  20% 6.3V SMD 1206
C54,C104,C105,C345
SC 470uF 20% 4V SMD 7.3x4.3x2.8mm4TPF470ML
C348,C438
MLCC X7R 0.22uF 10% 25V 0603C0603X224K025T
C88,C93,C154,C155,C425,C492,C510
MLCC X5R 10uF 10% 16V SMD 0805 GRM21BR61C106K
C46
MLCC X5R 4.7uF 16V 10% SMD 0805222278013672
65
C5,C45,C52,C60,C90,C101,C102,C113,C114,C135,C139,C142,C152,C153,C174,C176,C179,C193,C200,C247,C260,C264,C265,C267,C281,C296,C309,C312,C319,C320,C324,C329,C335,C337,C363,C369,C371,C373,C376,C378,C383,C384,C394,C396,C402,C405,C406,C433,C440,C441,C442,C447,C451,C456,C462,C464,C481,C520,C522,C527,C544,C545,C546,C557,C563
MLCC X7R 0.01uF 10% 16V SMD 0402 2238 78715636
C227,C235
MLCC NPO 22pF 5% 50V SMD 0402223886915229
C66,C67
MLCC NPO 27pF 5% 50V SMD 0402223886915279
C107,C123
MLCC NPO 33pF 5% 50V SMD 0402223886915339
C43,C249,C291
MLCCNPO 470pF 5% 50V SMD 0402 WO/Pb
C487
MLCC NPO 56pF  5% 50V SMD 0603 223886715569
13
C70,C182,C253,C254,C262,C289,C325,C344,C350,C375,C381,C419,C448
MLCC X7R 1000pF 10% 50V SMD 0402223858715623
C466
MLCC X7R 1200pF 10% 50V SMD 0603 2238 58615624
C127,C501
MLCC X7R 8200pF 10% 50V SMD 0603223858615635
C47
MLCC NPO 8.2pF 0.5pF 50V SMD 0603223886715828
C509,C511
MLCC X7R 1uF 10% 16V SMD 0805C0805X105K016T
L3,L5
Choke 3.3uH 20% 6A SMD PCMC063T-3R3MN
L1
Choke 0.47uH 20% 17.5A SMD PCMC063T-R47MN
L4
Inductor 22uH 20% 2.8A SMD 2PIHLM2525CZER220M11
L2
Choke 0.2uH 20% 24A SMD 2P PCMC063T-R20MN
9
B7,B8,B24,B27,B31,B32,B34,B38,B39
Bead 120ohm 25% 2A SMD 0603 BLM18PG121SN1WO/Pb
27
B1,B2,B3,B4,B10,B11,B12,B13,B14,B15,B16,B17,B18,B19,B20,B23,B25,B28,B29,B30,B33,B35,B36,B37,B40,B43,B44
EMI Filter 0.7A SMD 3P NFM18CC222R1C3
B5,B6,B9,B21,B22,B26,B41,B42
Bead 120ohm 25% 500mA SMD 0402BLM15AG121SN1D
Y2,Y5
X'TAL 25MHz 30ppm 20PF SMD 5x3.2mm 2P7A25000012
Y3
X'TAL 12MHz 30ppm 20PF SMD 5x3.2mm 2P7A12000044
Y4
X'TAL 32.768KHZ 20ppm 12.5pF SMD 4PMC-146(LF)
Y1
Crystal 30.72MHZ 30ppm 20pF SMD 3.2x2.5XSX30720
Y6
OSC 48MHZ 50ppm 3.3V 15pF SMD 4P 7x57W48000032
D4,D5
Polyswitch SMD 0603 PGB1010603
Littelfuse,Inc.
D3
Schottky B340A 3A 40V SMD SMA
VISHAY
D9
Schottky ASD500V 0805 0.1A 40V 500mW SMD0805
FMS (Formosa MS)
D6,D7
DIODE RB751V40 0.2A 40V SMD SOD-32
NXP Semiconductors
D8
ZENER BZX84-C12 12V 350MW SMD SOT-23
PHILIPS
D2,FPGA_D1,FPGA_D2,FPGA_D3,FPGA_D4,SYSPG_D1
LED BLUE SMD 0603 19-215SUBC/S280/TR8
Everlight Electronics Co., Ltd.
D1
LED Red SMD 0603 KPT-1608EC
Q9
MOSFET P-CH AO3401 -4.2A -30V SMD SOT-233P
Alpha & Omega Semiconductor
Q7,Q10
MOSFET N-CH 2N7002 0.3A 60V SMD SOT-23 3P
NXP Semiconductors
Q6
TRANS NPN MMBT3904LT1G 0.2A SMD SOT-23 3P
On Semiconductor
U17
IC SN74LVC00APWR SMD TSSOP 14P
Texas Instruments Incorporated
U25,U28,U30
IC PCA9306DCUT I2C Vol. Trans SMD US8 8P
U2,U7
IC SN74AVC4T245PWR Bus Buffer SMD TSSOP16P
U1
IC ICS557GI-08LFT Rev.C PCIe Bridge SMDTSSOP16
IDT Iinternational Limited
U10
IC AT25128B-SSHL-B EEPROM SMD SOIC 8P
Atmel Corporation
U15
IC TXS0108EPWR Translator SMD TSSOP 20P
PHY1
IC 88E1111-B2-BAB1C000 B2 SMD TFBGA 117P
Marvell Technology Ltd,
U12
IC FT2232HL SMD LQFP 64P
Future Technology Devices InternationalLtd.
U24
IC TPS51200DRCT SMD SON 10P
U13,U14
IC TPS54620RGY Step Down Converter SMDQFN 14P
CLK1
IC CDCE62002RHBT SMD QFN 32P
CLK2,CLK3
IC CDCE62005RGZT SMD VQFN 48P
U11
IC TPS54231D DC/DC CONVERTER SMD SOIC 8P
Q1,Q2,Q3,Q4
IC TPS73701DRBT SMD SON 8P
U3
IC UCD9222RGZR SMD VQFN 48P
U16
IC MAX3221ECPWR RS-232 DRIVER/RECE SMDTSSOP 16P
U31,U32
IC TS3L301DGG SMD TSSOP 48P
U29
IC SN74ALVC125PWR  SMD TSSOP 14P
Q5,Q8
IC MCP9700AT-E/LT SMD SC70 5P2.25x1.35x1.0mm
Microchip Technology Ltd.
U8
IC TROY(UCD74110) PWM SMD PQFN 40P TI
U4
IC UCD74106RGMT SMD QFN 13P 3.8x3.8mm
U6
IC AT93C46DN-SH-T SMD SOIC 8P
Atmel Corporation
MMC1
IC MSP430F5435IPN SMD LQFP 80P
EEPROM1
IC M24M01-HRMN6TP I2C 1.8V EEPROM SMD SO88P ST
ST Microelectronics
SPI1
IC N25Q128A11BSF40F FLASH SMD SO16 16P
Numonyx
NAND1
IC NAND512R3A2DZA6E SMD VFBGA 63P
Numonyx
FPGA1
IC XC3S200AN-4FTG256C FPGA SMD FTBGA 256P
XILINX Inc.
U5,U9
IC SN74LVC1G07DBVR BUFFER/DRIVER SMDSOT23 5P
U26,U27
IC SN74LVC2G125DCUR BUS BUFFER GATE SMDUS 8P
SW3,SW4,SW5,SW6,SW9
SW ESD104EZ SMD 2x4P 10.12x6.6x3.1mm
Excel Cell Electronic Co.,Ltd
TEST_PH1
FEMALE HEADER 2x40P 1.27mm 180D(F) SMD22L8742
Jih Vei Electronics Co., Ltd.
EMU1
B/B Conn. 60P 1.27mm 180D(F) SMD  SOLC-115-02-S
Samtec U.S.A.
PCB1
PCB DSPM-8302E AMC A103-1 L:12 C:G 1.6mmIT168G
DSP1
TMX320C6670ACYP for DSPM-8302/XDSE
Texas Instruments
U18,U19,U21,U22
IC K4B1G1646G-BCH9 DDR3 1333 SMD FBGA 96P
Samsung Electronics Taiwan Co.,Ltd
重要提示:PCB作品文件展下载说明
 楼主| 发表于 2018-12-15 04:42:08 | 显示全部楼层
TMDSEVM6678Lx_EVM_REV_3_0.DSN.rar (650 KB, 下载次数: 2) 19C2830103-JOB.brd.rar (3.34 MB, 下载次数: 4) Fr9rSM_F2hguIuw38xZN5nCl3rST.jpg
    无聊
    昨天 08:52
  • 签到天数: 185 天
    1元学习Allegro(1期)
    发表于 2018-12-15 08:40:11 | 显示全部楼层
    终身成就奖原创先锋奖优秀斑竹奖
    发表于 2018-12-15 09:05:30 | 显示全部楼层
    发表于 2018-12-15 10:13:55 | 显示全部楼层
    昨天 15:30
  • 签到天数: 184 天
    1元学习PADS(3期)
    发表于 2018-12-15 12:37:03 | 显示全部楼层
    发表于 2018-12-17 09:14:33 | 显示全部楼层
    1元学习PADS(1期)
    发表于 2019-5-25 10:54:21 | 显示全部楼层
    社区居民终身成就奖特殊贡献奖
    发表于 2019-5-25 22:52:01 | 显示全部楼层
    官网的东西就不要在这里贴啦!
    蔡良弟
  • 签到天数: 58 天
    发表于 2019-5-26 00:07:06 | 显示全部楼层
